Program storage space is wrecking my code
When I upload my code, it says it is only 37% of program storage space:
I have 13 bitmaps (as .c files) that I am using (currently using 9 of those), but one of those bitmaps displays as a gray square with diagonal lines in it.
If I remove one of the OTHER bitmaps, they all display correctly, and program storage space drops to 30%.
Why is having that extra 7% program storage space mucking up my bitmap?
Maybe the way you’re passing those bitmaps between functions…
Only you can know, my copy of your code is missing.
WeatherStationComplete.zip (112.0 KB)
That's the code. It's WAY to long to copy and paste, sorry.
As a starter:
The use of memory reported by the compiler is only the minimum needed to start the sketch. During the run more will be needed, but the compiler cannot foresee that as it will depend on the inputs.
Then: how big are your bitmaps? And which type of board do you use?
And finally: show your code so we can see if you make unnecessary copies of your bitmaps. Or if we could assist you storing the bitmaps in PROGMEM.
That is the code.
Each bitmap is a different size.
I am using a Mega2560 and a 3.95" tft lcd
Could you isolate your problem in a smaller bit of code? Most helpers do not like downloading stuff and do not like to wrestle through big piles of code...
...they do like to help you with specific problems...
Yes, it is 5888 lines of code :rofl::rofl::rofl::rofl::rofl:
What parts do you need?
How big is the biggest, the smallest, the average...
I am trying to find out if your project is hopeless (bitmaps of 1000 x 1000 pixels) or doable.... now I still know nothing...
A simple version that prints your bitmaps to your screen... ( independent if weather conditions)
Pixels?
Biggest is 110 x 114 pixels
Smallest is 36 x 21 pixels
#include <SPI.h>          // f.k. for Arduino-1.5.2
#include "Adafruit_GFX.h"// Hardware-specific library
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft;
#define LOWFLASH (defined(__AVR_ATmega328P__) && defined(MCUFRIEND_KBV_H_))
#include "Moon.c"
#include "Gibbous.c"
#include "Third.c"
#include "Crescent.c"
#include "New.c"
#include "GettingBig.c"
#include "First.c"
#include "Large.c"
#include "Full.c"
#include "Draining.c"
#include "Drained.c"
#include "Empty.c"
#include "Charging.c"
#include "Sunny.c"
#define BLACK       0x0000      /*   0,   0,   0 */
#define NAVY        0x000F      /*   0,   0, 128 */
#define DARKGREEN   0x03E0      /*   0, 128,   0 */
#define DARKCYAN    0x03EF      /*   0, 128, 128 */
#define MAROON      0x7800      /* 128,   0,   0 */
#define PURPLE      0x780F      /* 128,   0, 128 */
#define OLIVE       0x7BE0      /* 128, 128,   0 */
#define LIGHTGREY   0xC618      /* 192, 192, 192 */
#define DARKGREY    0x7BEF      /* 128, 128, 128 */
#define BLUE        0x001F      /*   0,   0, 255 */
#define GREEN       0x07E0      /*   0, 255,   0 */
#define CYAN        0x07FF      /*   0, 255, 255 */
#define RED         0xF800      /* 255,   0,   0 */
#define MAGENTA     0xF81F      /* 255,   0, 255 */
#define YELLOW      0xFFE0      /* 255, 255,   0 */
#define WHITE       0xFFFF      /* 255, 255, 255 */
#define ORANGE      0xFD20      /* 255, 165,   0 */
#define GREENYELLOW 0xAFE5      /* 173, 255,  47 */
#define PINK        0xF81F
  tft.reset();
  tft.begin(0x9488);
  tft.setRotation(1);
  tft.drawRGBBitmap(0, 0, Sunny, 110, 114);
  delay(2000);
  tft.drawRGBBitmap(0, 0, Moon, 95, 95);
  delay(2000);
  tft.drawRGBBitmap(0, 0, Gibbous, 95, 95);
  delay(2000);
  tft.drawRGBBitmap(0, 0, Third, 95, 95);
  delay(2000);
  tft.drawRGBBitmap(0, 0, Crescent, 95, 95);
  delay(2000);
  tft.drawRGBBitmap(0, 0, New, 95, 95);
  delay(2000);
  tft.drawRGBBitmap(0, 0, GettingBig, 95, 95);
  delay(2000);
  tft.drawRGBBitmap(0, 0, First, 95, 95);
  delay(2000);
  tft.drawRGBBitmap(0, 0, Large, 95, 95);
  delay(2000);
  tft.drawRGBBitmap(0, 0, Full, 36, 21);
  delay(2000);
  tft.drawRGBBitmap(0, 0, Draining, 36, 21);
  delay(2000);
  tft.drawRGBBitmap(0, 0, Drained, 36, 21);
  delay(2000);
  tft.drawRGBBitmap(0, 0, Empty, 36, 21);
  delay(2000);
  tft.drawRGBBitmap(0, 0, Charging, 36, 21);
  delay(2000);
Charging.c
// Generated by  : ImageConverter 565 v2.3
// Generated from: Charging.png
// Time generated: 21/06/2022 9:18:26 AM
// Dimensions    : 36x21 pixels
// Size          : 1,512 Bytes
#include <avr/pgmspace.h>
const unsigned int Charging[0x2F4] PROGMEM ={
0x0000, 0x4A69, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C,   // 0x0010 (16)
0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x6B4D, 0x630C,   // 0x0020 (32)
0x0000, 0x0000, 0x0000, 0x0000, 0x5AEB, 0x632C, 0x738E, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF,   // 0x0030 (48)
0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF,   // 0x0040 (64)
0x7BCF, 0x7BCF, 0x738E, 0x6B4D, 0x630C, 0x0000, 0x0000, 0x0000, 0x632C, 0x738E, 0xB5B6, 0xEF7D, 0xEF7D, 0xEF7D, 0xEF7D, 0xEF7D,   // 0x0050 (80)
0xEF7D, 0xEF7D, 0xEF7D, 0xEF7D, 0xEF7D, 0xEF7D, 0xEF7D, 0xEF7D, 0xEF7D, 0xEF7D, 0xEF7D, 0xEF7D, 0xEF7D, 0xEF7D, 0xEF7D, 0xEF7D,   // 0x0060 (96)
0xEF7D, 0xEF7D, 0xEF7D, 0xEF7D, 0xEF7D, 0xEF7D, 0xDEFB, 0x8430, 0x630C, 0x52AA, 0x0000, 0x0000, 0x630C, 0x7BEF, 0xFFDF, 0xFFFF,   // 0x0070 (112)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0080 (128)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xB596, 0x5AEB, 0x5ACB, 0x0000, 0x0000,   // 0x0090 (144)
0x630C, 0x8410, 0xF7BE, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x00A0 (160)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xB5B6,   // 0x00B0 (176)
0x5AEB, 0x5ACB, 0x0000, 0x0000, 0x630C, 0x8410, 0xF7BE, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x00C0 (192)
0xFFFF, 0xFFFF, 0xB736, 0x7E8F, 0xD79A, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x00D0 (208)
0xFFFF, 0xFFFF, 0xFFFF, 0xB5B6, 0x5AEB, 0x528A, 0x0000, 0x0000, 0x630C, 0x8410, 0xF7BE, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x00E0 (224)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0x86D0, 0x3E07, 0x564A, 0x9F13, 0xF7DE, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x00F0 (240)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xB596, 0x5AEB, 0x630C, 0x630C, 0x4A69, 0x630C, 0x8410, 0xF7BE, 0xFFFF,   // 0x0100 (256)
0xFFFF, 0xDF9B, 0xA713, 0xCF79, 0xF7DE, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0x8ED1, 0x4648, 0x4E69, 0x4628, 0x666D, 0xC778,   // 0x0110 (272)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xB596, 0x5ACB, 0x6B6D, 0x73AE, 0x632C,   // 0x0120 (288)
0x630C, 0x8410, 0xF7BE, 0xFFFF, 0xFFFF, 0xB736, 0x35E6, 0x4628, 0x5E6B, 0x86B0, 0xB735, 0xDF9B, 0xFFFF, 0xFFFF, 0x8EF2, 0x4648,   // 0x0130 (304)
0x4E69, 0x4E6A, 0x4649, 0x4E29, 0x8ED1, 0xE7BC, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xEF7D,   // 0x0140 (320)
0xDEFB, 0xE71C, 0x9CF3, 0x632C, 0x630C, 0x8410, 0xF7BE, 0xFFFF, 0xFFFF, 0xFFFF, 0xBF37, 0x5E4B, 0x3E27, 0x4628, 0x4628, 0x4E4A,   // 0x0150 (336)
0x6E8D, 0x9EF3, 0x76AE, 0x4E49, 0x4E69, 0x4E6A, 0x4E6A, 0x4E69, 0x4648, 0x5E4B, 0xB736, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0160 (352)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xB5B6, 0x5AEB, 0x630C, 0x8410, 0xF7BE, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xEFBC,   // 0x0170 (368)
0x8ED1, 0x4E29, 0x4E48, 0x4E69, 0x4649, 0x4628, 0x4E49, 0x566A, 0x4E69, 0x4E6A, 0x4E69, 0x4E6A, 0x566A, 0x4E49, 0x4628, 0x7E8E,   // 0x0180 (384)
0xDF9B, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xB596, 0x5AEB, 0x630C, 0x8410, 0xF7BE, 0xFFFF,   // 0x0190 (400)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xCF79, 0x6E8D, 0x4628, 0x4E49, 0x4E6A, 0x4E6A, 0x4E6A, 0x4E6A, 0x4E6A, 0x4E6A, 0x4E49,   // 0x01A0 (416)
0x4628, 0x4648, 0x4E69, 0x4648, 0x564A, 0x9EF3, 0xF7DE, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xB596, 0x5AEB,   // 0x01B0 (432)
0x630C, 0x8410, 0xF7BE, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xF7FE, 0xA713, 0x564A, 0x4648, 0x4E69, 0x4E69,   // 0x01C0 (448)
0x4E69, 0x4E69, 0x566A, 0xAF55, 0xA714, 0x768E, 0x564A, 0x4E28, 0x4628, 0x3E07, 0x666C, 0xCF78, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x01D0 (464)
0xFFFF, 0xFFFF, 0xB5B6, 0x5AEB, 0x630C, 0x8410, 0xF7BE, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x01E0 (480)
0xDF9B, 0x7E8F, 0x4628, 0x4E49, 0x566A, 0x4E49, 0x564A, 0xE7DC, 0xFFFF, 0xFFFF, 0xE7BC, 0xBF57, 0x8ED1, 0x668C, 0x3E27, 0x5E4B,   // 0x01F0 (496)
0xF7FE, 0xFFFF, 0xFFFF, 0xDEFB, 0xBDD7, 0xC618, 0x9492, 0x632C, 0x630C, 0x8410, 0xF7BE, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0200 (512)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xB736, 0x5E4B, 0x4628, 0x4E49, 0x564A, 0xDFBB, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0210 (528)
0xFFFF, 0xF7FE, 0xD79A, 0xD79A, 0xFFFF, 0xFFFF, 0xFFFF, 0xAD75, 0x528A, 0x630C, 0x6B4D, 0x632C, 0x630C, 0x8410, 0xF7BE, 0xFFFF,   // 0x0220 (544)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xEFDC, 0x8ED0, 0x4628, 0x4628, 0xDFBB,   // 0x0230 (560)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xB5B6, 0x5AEB, 0x630C, 0x630C, 0x0000,   // 0x0240 (576)
0x630C, 0x8410, 0xF7BE, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0250 (592)
0xFFFF, 0xC778, 0xA714, 0xF7FE, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xB5B6,   // 0x0260 (608)
0x5AEB, 0x528A, 0x0000, 0x0000, 0x630C, 0x8410, 0xF7BE, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0270 (624)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0280 (640)
0xFFFF, 0xFFFF, 0xFFFF, 0xB5B6, 0x5AEB, 0x52AA, 0x0000, 0x0000, 0x632C, 0x7BCF, 0xF7BE, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0290 (656)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x02A0 (672)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xAD75, 0x630C, 0x5ACB, 0x0000, 0x0000, 0x630C, 0x738E, 0x9CF3, 0xD69A,   // 0x02B0 (688)
0xD6BA, 0xD69A, 0xD69A, 0xD69A, 0xD69A, 0xD69A, 0xD69A, 0xD69A, 0xD69A, 0xD69A, 0xD69A, 0xD69A, 0xD69A, 0xD69A, 0xD69A, 0xD69A,   // 0x02C0 (704)
0xD69A, 0xD69A, 0xD69A, 0xD69A, 0xD69A, 0xD69A, 0xD69A, 0xD69A, 0xD69A, 0xD6BA, 0xC618, 0x7BEF, 0x630C, 0x5AEB, 0x0000, 0x0000,   // 0x02D0 (720)
0x52AA, 0x632C, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D,   // 0x02E0 (736)
0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B6D, 0x6B4D, 0x6B4D,   // 0x02F0 (752)
0x630C, 0x0000, 0x0000, 0x0000, };
Crescent.c
// Generated from: WaningCrescent.jpg
// Time generated: 17/06/2022 8:18:28 AM
// Dimensions    : 95x95 pixels
// Size          : 18,050 Bytes
const unsigned int Crescent[0x2341] PROGMEM ={
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0010 (16)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0020 (32)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000,   // 0x0030 (48)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0040 (64)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0050 (80)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0060 (96)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0070 (112)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0080 (128)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082,   // 0x0090 (144)
0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00A0 (160)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00B0 (176)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00C0 (192)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00D0 (208)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00E0 (224)
0x0020, 0x1082, 0x18E3, 0x2124, 0x2965, 0x3186, 0x3186, 0x2965, 0x2965, 0x2945, 0x2124, 0x2104, 0x18E3, 0x18E3, 0x18C3, 0x10A2,   // 0x00F0 (240)
0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0100 (256)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0110 (272)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0120 (288)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0130 (304)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x18C3, 0x2124, 0x3186,   // 0x0140 (320)
0x39E7, 0x39E7, 0x4208, 0x39E7, 0x39C7, 0x31A6, 0x3186, 0x2965, 0x2945, 0x2124, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x1082,   // 0x0150 (336)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000,   // 0x0160 (352)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0170 (368)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0180 (384)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0190 (400)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x10A2, 0x2965, 0x39C7, 0x4228, 0x528A, 0x4A69, 0x4A49,   // 0x01A0 (416)
0x4228, 0x4228, 0x4208, 0x39E7, 0x31A6, 0x3186, 0x2965, 0x2945, 0x2124, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x0861,   // 0x01B0 (432)
0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0020, 0x0000, 0x0000,   // 0x01C0 (448)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x01D0 (464)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x01E0 (480)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x01F0 (496)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x10A2, 0x31A6, 0x528A, 0x52AA, 0x4A69, 0x4A69, 0x528A, 0x4A69, 0x4A69, 0x4A69,   // 0x0200 (512)
0x4A49, 0x4208, 0x39E7, 0x31A6, 0x3186, 0x2945, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x1082, 0x1082,   // 0x0210 (528)
0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0020, 0x0000,   // 0x0220 (544)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0230 (560)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0240 (576)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0250 (592)
0x0000, 0x0000, 0x0020, 0x10A2, 0x31A6, 0x4A69, 0x52AA, 0x5ACB, 0x528A, 0x52AA, 0x52AA, 0x528A, 0x4A69, 0x4A69, 0x4A69, 0x4228,   // 0x0260 (608)
0x4208, 0x39C7, 0x31A6, 0x2965, 0x2945, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082,   // 0x0270 (624)
0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0020,   // 0x0280 (640)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0290 (656)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x02A0 (672)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x02B0 (688)
0x1082, 0x3186, 0x4A69, 0x630C, 0x52AA, 0x52AA, 0x52AA, 0x52AA, 0x5ACB, 0x52AA, 0x528A, 0x528A, 0x528A, 0x528A, 0x4228, 0x39E7,   // 0x02C0 (704)
0x39C7, 0x3186, 0x2965, 0x2124, 0x2104, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082,   // 0x02D0 (720)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841,   // 0x02E0 (736)
0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x02F0 (752)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0300 (768)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x18E3, 0x4208,   // 0x0310 (784)
0x528A, 0x52AA, 0x5ACB, 0x5ACB, 0x5ACB, 0x5ACB, 0x5AEB, 0x5AEB, 0x5ACB, 0x5ACB, 0x5ACB, 0x528A, 0x528A, 0x4A49, 0x4208, 0x31A6,   // 0x0320 (800)
0x2965, 0x2945, 0x2124, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x1082,   // 0x0330 (816)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0340 (832)
0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0350 (848)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0360 (864)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1082, 0x31A6, 0x4228, 0x4A69, 0x4A69,   // 0x0370 (880)
0x630C, 0x6B4D, 0x630C, 0x630C, 0x630C, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5ACB, 0x528A, 0x4A49, 0x4208, 0x39E7, 0x31A6, 0x2965,   // 0x0380 (896)
0x2124, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0390 (912)
0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x03A0 (928)
0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x03B0 (944)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x03C0 (960)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x18E3, 0x4228, 0x52AA, 0x528A, 0x52AA, 0x5AEB, 0x632C,   // 0x03D0 (976)
0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x5AEB, 0x5ACB, 0x528A, 0x4A69, 0x4208, 0x39E7, 0x3186, 0x2945, 0x2104,   // 0x03E0 (992)
0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x03F0 (1008)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0400 (1024)
0x0861, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0410 (1040)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0420 (1056)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x2945, 0x4A69, 0x528A, 0x52AA, 0x52AA, 0x5AEB, 0x630C, 0x5AEB, 0x630C,   // 0x0430 (1072)
0x632C, 0x632C, 0x630C, 0x632C, 0x6B4D, 0x632C, 0x632C, 0x630C, 0x5AEB, 0x52AA, 0x4208, 0x31A6, 0x2965, 0x2104, 0x18E3, 0x18E3,   // 0x0440 (1088)
0x18C3, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0450 (1104)
0x0861, 0x0861, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0460 (1120)
0x0861, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0470 (1136)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0480 (1152)
0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x39C7, 0x52AA, 0x5AEB, 0x52AA, 0x52AA, 0x5AEB, 0x630C, 0x630C, 0x630C, 0x632C, 0x6B4D,   // 0x0490 (1168)
0x6B4D, 0x6B4D, 0x632C, 0x632C, 0x6B4D, 0x6B6D, 0x73AE, 0x630C, 0x4228, 0x39E7, 0x2965, 0x2124, 0x2104, 0x18C3, 0x10A2, 0x10A2,   // 0x04A0 (1184)
0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841,   // 0x04B0 (1200)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x04C0 (1216)
0x0861, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x04D0 (1232)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x04E0 (1248)
0x0000, 0x0000, 0x0841, 0x4208, 0x632C, 0x630C, 0x630C, 0x5AEB, 0x630C, 0x632C, 0x632C, 0x6B4D, 0x6B4D, 0x6B6D, 0x6B6D, 0x6B6D,   // 0x04F0 (1264)
0x6B6D, 0x632C, 0x632C, 0x632C, 0x5AEB, 0x5AEB, 0x528A, 0x39E7, 0x31A6, 0x2965, 0x2124, 0x2104, 0x18C3, 0x10A2, 0x10A2, 0x1082,   // 0x0500 (1280)
0x1082, 0x0861, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0510 (1296)
0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0520 (1312)
0x0861, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0530 (1328)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0540 (1344)
0x0861, 0x4A49, 0x6B6D, 0x738E, 0x6B6D, 0x632C, 0x632C, 0x632C, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x738E, 0x6B6D, 0x632C,   // 0x0550 (1360)
0x632C, 0x630C, 0x5ACB, 0x4A69, 0x4A49, 0x4208, 0x39C7, 0x3186, 0x2945, 0x2104, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082,   // 0x0560 (1376)
0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0570 (1392)
0x0861, 0x0861, 0x1082, 0x0861, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0580 (1408)
0x0861, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0590 (1424)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0861, 0x4A69,   // 0x05A0 (1440)
0x73AE, 0x7BCF, 0x7BCF, 0x738E, 0x630C, 0x632C, 0x6B4D, 0x6B6D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B6D, 0x6B4D, 0x632C, 0x630C,   // 0x05B0 (1456)
0x5ACB, 0x528A, 0x4A49, 0x4208, 0x39C7, 0x3186, 0x2945, 0x2104, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861,   // 0x05C0 (1472)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x05D0 (1488)
0x0861, 0x0861, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x05E0 (1504)
0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x05F0 (1520)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x4228, 0x6B6D, 0x7BCF,   // 0x0600 (1536)
0x8410, 0x7BCF, 0x738E, 0x6B4D, 0x6B4D, 0x6B6D, 0x6B6D, 0x738E, 0x6B6D, 0x6B6D, 0x6B6D, 0x6B4D, 0x632C, 0x632C, 0x5AEB, 0x52AA,   // 0x0610 (1552)
0x4A49, 0x39E7, 0x39E7, 0x31A6, 0x2945, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861,   // 0x0620 (1568)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0630 (1584)
0x0861, 0x0861, 0x1082, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0640 (1600)
0x0841, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0650 (1616)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x39C7, 0x6B6D, 0x7BEF, 0x8430, 0x8C51,   // 0x0660 (1632)
0x7BCF, 0x6B4D, 0x6B6D, 0x73AE, 0x73AE, 0x73AE, 0x73AE, 0x738E, 0x73AE, 0x738E, 0x6B4D, 0x632C, 0x630C, 0x5ACB, 0x528A, 0x4228,   // 0x0670 (1648)
0x39E7, 0x39C7, 0x3186, 0x2124, 0x18E3, 0x18E3, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082,   // 0x0680 (1664)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0690 (1680)
0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x06A0 (1696)
0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x06B0 (1712)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x2945, 0x6B4D, 0x7BCF, 0x8430, 0x9492, 0x8C51, 0x7BCF,   // 0x06C0 (1728)
0x6B6D, 0x73AE, 0x8C51, 0x7BEF, 0x7BCF, 0x73AE, 0x6B6D, 0x738E, 0x6B6D, 0x6B4D, 0x632C, 0x630C, 0x52AA, 0x4A49, 0x4228, 0x39E7,   // 0x06D0 (1744)
0x31A6, 0x2965, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x0861,   // 0x06E0 (1760)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x06F0 (1776)
0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0700 (1792)
0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0710 (1808)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x10A2, 0x5AEB, 0x7BEF, 0x8410, 0x9492, 0x9492, 0x8410, 0x7BCF, 0x738E,   // 0x0720 (1824)
0x73AE, 0x7BEF, 0x7BCF, 0x7BEF, 0x7BCF, 0x738E, 0x738E, 0x6B4D, 0x632C, 0x630C, 0x5AEB, 0x4A69, 0x4228, 0x4208, 0x31A6, 0x3186,   // 0x0730 (1840)
0x2945, 0x2104, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x0861, 0x0861,   // 0x0740 (1856)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0750 (1872)
0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841,   // 0x0760 (1888)
0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0770 (1904)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x4A49, 0x73AE, 0x8410, 0x8C71, 0x9492, 0x8430, 0x7BCF, 0x73AE, 0x738E, 0x73AE,   // 0x0780 (1920)
0x73AE, 0x7BCF, 0x7BCF, 0x7BCF, 0x73AE, 0x6B6D, 0x632C, 0x5AEB, 0x52AA, 0x528A, 0x4A69, 0x4228, 0x39E7, 0x3186, 0x2965, 0x2945,   // 0x0790 (1936)
0x18E3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x07A0 (1952)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x07B0 (1968)
0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841,   // 0x07C0 (1984)
0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x07D0 (2000)
0x0000, 0x0000, 0x0000, 0x0000, 0x31A6, 0x630C, 0x7BEF, 0x8C71, 0x8C71, 0x8410, 0x73AE, 0x73AE, 0x738E, 0x738E, 0x73AE, 0x73AE,   // 0x07E0 (2016)
0x7BCF, 0x7BCF, 0x73AE, 0x73AE, 0x6B6D, 0x630C, 0x5ACB, 0x52AA, 0x52AA, 0x4A69, 0x4208, 0x39C7, 0x3186, 0x2965, 0x18E3, 0x10A2,   // 0x07F0 (2032)
0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0800 (2048)
0x0861, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x0810 (2064)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x0841, 0x0841,   // 0x0820 (2080)
0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0830 (2096)
0x0000, 0x0000, 0x2104, 0x5AEB, 0x738E, 0x8C51, 0x8C71, 0x8410, 0x7BEF, 0x738E, 0x738E, 0x73AE, 0x73AE, 0x73AE, 0x73AE, 0x7BCF,   // 0x0840 (2112)
0x7BCF, 0x73AE, 0x73AE, 0x6B6D, 0x632C, 0x630C, 0x5ACB, 0x52AA, 0x4A69, 0x4228, 0x39C7, 0x2965, 0x2124, 0x18C3, 0x10A2, 0x10A2,   // 0x0850 (2128)
0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0860 (2144)
0x1082, 0x0861, 0x0861, 0x0861, 0x1082, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2,   // 0x0870 (2160)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x0841,   // 0x0880 (2176)
0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0890 (2192)
0x0861, 0x4A69, 0x738E, 0x8410, 0x7BEF, 0x9492, 0x8C51, 0x7BEF, 0x738E, 0x73AE, 0x7BCF, 0x73AE, 0x738E, 0x73AE, 0x7BCF, 0x7BCF,   // 0x08A0 (2208)
0x7BCF, 0x6B6D, 0x6B4D, 0x632C, 0x630C, 0x5AEB, 0x52AA, 0x528A, 0x4228, 0x31A6, 0x2965, 0x2124, 0x18C3, 0x10A2, 0x10A2, 0x10A2,   // 0x08B0 (2224)
0x10A2, 0x18C3, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x0861, 0x1082, 0x0861, 0x1082,   // 0x08C0 (2240)
0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x10A2,   // 0x08D0 (2256)
0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x08E0 (2272)
0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x3186,   // 0x08F0 (2288)
0x6B6D, 0x7BCF, 0x630C, 0x738E, 0x94B2, 0x9492, 0x7BEF, 0x738E, 0x73AE, 0x73AE, 0x73AE, 0x73AE, 0x7BCF, 0x7BCF, 0x73AE, 0x6B6D,   // 0x0900 (2304)
0x6B4D, 0x632C, 0x630C, 0x5AEB, 0x5AEB, 0x5ACB, 0x528A, 0x4228, 0x31A6, 0x2945, 0x2104, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x0910 (2320)
0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082,   // 0x0920 (2336)
0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2,   // 0x0930 (2352)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0841,   // 0x0940 (2368)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1082, 0x5ACB, 0x7BCF,   // 0x0950 (2384)
0x6B4D, 0x5ACB, 0x8C51, 0x9CD3, 0x8C71, 0x738E, 0x738E, 0x738E, 0x738E, 0x73AE, 0x7BCF, 0x7BEF, 0x73AE, 0x738E, 0x6B4D, 0x632C,   // 0x0960 (2400)
0x630C, 0x630C, 0x630C, 0x5ACB, 0x528A, 0x4A69, 0x4208, 0x3186, 0x2124, 0x18E3, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2,   // 0x0970 (2416)
0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082,   // 0x0980 (2432)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x0990 (2448)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0841, 0x0020,   // 0x09A0 (2464)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x39C7, 0x6B6D, 0x7BEF, 0x73AE,   // 0x09B0 (2480)
0x8430, 0xAD55, 0x9CD3, 0x8C71, 0x7BEF, 0x738E, 0x738E, 0x7BCF, 0x7BEF, 0x7BCF, 0x7BCF, 0x73AE, 0x738E, 0x6B6D, 0x630C, 0x5AEB,   // 0x09C0 (2496)
0x632C, 0x5AEB, 0x528A, 0x4A69, 0x4228, 0x39C7, 0x2965, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2,   // 0x09D0 (2512)
0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x09E0 (2528)
0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3,   // 0x09F0 (2544)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x0841, 0x0020, 0x0000,   // 0x0A00 (2560)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x18C3, 0x5AEB, 0x73AE, 0x8410, 0x8C51, 0x9CF3,   // 0x0A10 (2576)
0x9CF3, 0x9492, 0x8C51, 0x7BEF, 0x73AE, 0x73AE, 0x8410, 0x8C71, 0x7BEF, 0x73AE, 0x73AE, 0x738E, 0x6B6D, 0x630C, 0x630C, 0x632C,   // 0x0A20 (2592)
0x52AA, 0x4A49, 0x4A49, 0x39E7, 0x2965, 0x2124, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2,   // 0x0A30 (2608)
0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x10A2,   // 0x0A40 (2624)
0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x10A2,   // 0x0A50 (2640)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0000, 0x0000,   // 0x0A60 (2656)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x4208, 0x6B6D, 0x7BCF, 0x8430, 0x8C71, 0x9CF3, 0x9CF3,   // 0x0A70 (2672)
0x9CD3, 0x8C51, 0x73AE, 0x73AE, 0x7BCF, 0x8410, 0x8C51, 0x7BCF, 0x73AE, 0x73AE, 0x6B6D, 0x630C, 0x5AEB, 0x630C, 0x5ACB, 0x528A,   // 0x0A80 (2688)
0x4A69, 0x39E7, 0x3186, 0x2945, 0x2124, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x18C3,   // 0x0A90 (2704)
0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2,   // 0x0AA0 (2720)
0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x0AB0 (2736)
0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000,   // 0x0AC0 (2752)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x10A2, 0x5AEB, 0x73AE, 0x8410, 0x9492, 0x94B2, 0x9CF3, 0x9CF3, 0x9CD3,   // 0x0AD0 (2768)
0x8C51, 0x7BEF, 0x73AE, 0x7BCF, 0x8C51, 0x8410, 0x7BCF, 0x73AE, 0x6B6D, 0x6B4D, 0x632C, 0x630C, 0x5ACB, 0x4A69, 0x4A69, 0x4228,   // 0x0AE0 (2784)
0x31A6, 0x2945, 0x2124, 0x2104, 0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2,   // 0x0AF0 (2800)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x0B00 (2816)
0x10A2, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2,   // 0x0B10 (2832)
0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000,   // 0x0B20 (2848)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x2965, 0x6B6D, 0x7BEF, 0x8430, 0x9492, 0x9CF3, 0xA534, 0xA514, 0x9492, 0x8410,   // 0x0B30 (2864)
0x8430, 0x7BCF, 0x73AE, 0x8410, 0x8410, 0x8410, 0x73AE, 0x738E, 0x6B4D, 0x6B6D, 0x630C, 0x528A, 0x4A49, 0x4228, 0x39E7, 0x3186,   // 0x0B40 (2880)
0x2965, 0x2124, 0x2104, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2,   // 0x0B50 (2896)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x0B60 (2912)
0x1082, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2,   // 0x0B70 (2928)
0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000,   // 0x0B80 (2944)
0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x4A49, 0x738E, 0x8410, 0x8430, 0x8C71, 0xA514, 0xB596, 0xA534, 0x8C71, 0x7BEF, 0x8430,   // 0x0B90 (2960)
0x8430, 0x7BEF, 0x8410, 0x7BEF, 0x7BCF, 0x73AE, 0x73AE, 0x6B4D, 0x632C, 0x5AEB, 0x4A69, 0x4228, 0x4208, 0x39C7, 0x3186, 0x2945,   // 0x0BA0 (2976)
0x2104, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2,   // 0x0BB0 (2992)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x0BC0 (3008)
0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082,   // 0x0BD0 (3024)
0x1082, 0x0861, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0BE0 (3040)
0x0000, 0x0000, 0x0000, 0x10A2, 0x630C, 0x7BCF, 0x7BEF, 0x8430, 0x9492, 0xA534, 0xBDD7, 0xAD55, 0x8C71, 0x8C51, 0x9CF3, 0x94B2,   // 0x0BF0 (3056)
0x7BEF, 0x8410, 0x7BEF, 0x73AE, 0x73AE, 0x6B6D, 0x6B4D, 0x632C, 0x52AA, 0x4A69, 0x4228, 0x4208, 0x31A6, 0x2965, 0x2124, 0x2104,   // 0x0C00 (3072)
0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x0C10 (3088)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x0C20 (3104)
0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x0861,   // 0x0C30 (3120)
0x0861, 0x0861, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0C40 (3136)
0x0000, 0x0000, 0x3186, 0x6B6D, 0x7BCF, 0x7BCF, 0x8C51, 0x9CD3, 0xA514, 0xAD75, 0xAD55, 0x9CD3, 0x9CF3, 0xAD55, 0x8C71, 0x8410,   // 0x0C50 (3152)
0x8410, 0x8410, 0x7BCF, 0x73AE, 0x6B6D, 0x6B6D, 0x6B4D, 0x5ACB, 0x4A69, 0x4208, 0x39E7, 0x31A6, 0x2965, 0x2104, 0x18E3, 0x18E3,   // 0x0C60 (3168)
0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x0C70 (3184)
0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2,   // 0x0C80 (3200)
0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082,   // 0x0C90 (3216)
0x0861, 0x0861, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0CA0 (3232)
0x0000, 0x4A49, 0x73AE, 0x7BEF, 0x8C51, 0x94B2, 0x9CF3, 0xA514, 0xAD55, 0xAD55, 0xAD55, 0xA534, 0x9CD3, 0x8C71, 0x9492, 0x8410,   // 0x0CB0 (3248)
0x7BEF, 0x738E, 0x73AE, 0x738E, 0x6B6D, 0x6B4D, 0x52AA, 0x4A69, 0x4228, 0x39E7, 0x3186, 0x2965, 0x2104, 0x18E3, 0x18C3, 0x18C3,   // 0x0CC0 (3264)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082,   // 0x0CD0 (3280)
0x1082, 0x1082, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x0CE0 (3296)
0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x0CF0 (3312)
0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0861,   // 0x0D00 (3328)
0x5AEB, 0x8410, 0x8C51, 0x94B2, 0x9CF3, 0xA514, 0xA534, 0xA534, 0xAD75, 0xAD55, 0x94B2, 0x94B2, 0x9492, 0x9CD3, 0x94B2, 0x8410,   // 0x0D10 (3344)
0x7BCF, 0x7BCF, 0x73AE, 0x6B6D, 0x5AEB, 0x52AA, 0x4A69, 0x4A49, 0x39C7, 0x2965, 0x2124, 0x2124, 0x2104, 0x18C3, 0x18C3, 0x10A2,   // 0x0D20 (3360)
0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x1082, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082,   // 0x0D30 (3376)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861,   // 0x0D40 (3392)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082,   // 0x0D50 (3408)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0020, 0x0000, 0x2104, 0x6B4D,   // 0x0D60 (3424)
0x8410, 0x8C71, 0x9CD3, 0xA514, 0xA534, 0xA534, 0xA534, 0xAD75, 0xA514, 0x9492, 0xA534, 0xA534, 0x9CF3, 0x9CF3, 0x9492, 0x8C71,   // 0x0D70 (3440)
0x8C51, 0x73AE, 0x6B4D, 0x5AEB, 0x52AA, 0x4A69, 0x4228, 0x31A6, 0x3186, 0x2945, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x10A2,   // 0x0D80 (3456)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x0D90 (3472)
0x1082, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861,   // 0x0DA0 (3488)
0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x0861,   // 0x0DB0 (3504)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x39C7, 0x6B6D, 0x8410,   // 0x0DC0 (3520)
0x94B2, 0x9CF3, 0xAD55, 0xAD55, 0xAD55, 0xAD75, 0xA534, 0xA514, 0xA514, 0xA514, 0xA514, 0xA534, 0x9CF3, 0x9CD3, 0x9CF3, 0x9CD3,   // 0x0DD0 (3536)
0x6B6D, 0x630C, 0x5ACB, 0x528A, 0x528A, 0x4228, 0x39E7, 0x39C7, 0x2965, 0x2124, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082,   // 0x0DE0 (3552)
0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x0861,   // 0x0DF0 (3568)
0x0861, 0x0841, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841,   // 0x0E00 (3584)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x0861, 0x0861,   // 0x0E10 (3600)
0x0861, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x4228, 0x6B6D, 0x8430, 0xA514,   // 0x0E20 (3616)
0xA534, 0xAD75, 0xAD55, 0xAD55, 0xAD75, 0xAD55, 0xAD75, 0xAD55, 0xA534, 0xAD55, 0xAD55, 0xA534, 0xA534, 0xA534, 0x8C71, 0x6B6D,   // 0x0E30 (3632)
0x632C, 0x5ACB, 0x52AA, 0x4A49, 0x4228, 0x4208, 0x39E7, 0x3186, 0x2104, 0x18C3, 0x18C3, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x0E40 (3648)
0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x0E50 (3664)
0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0E60 (3680)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0861, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861,   // 0x0E70 (3696)
0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x1082, 0x5ACB, 0x738E, 0x9492, 0xA534, 0xB596,   // 0x0E80 (3712)
0xB596, 0xAD75, 0xAD55, 0xAD55, 0xAD75, 0xB596, 0xB596, 0xB5B6, 0xAD75, 0xAD55, 0xAD55, 0xAD75, 0xAD55, 0x8C71, 0x738E, 0x632C,   // 0x0E90 (3728)
0x5ACB, 0x528A, 0x4228, 0x4228, 0x39E7, 0x31A6, 0x2945, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2,   // 0x0EA0 (3744)
0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0841, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x0EB0 (3760)
0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861,   // 0x0EC0 (3776)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x1082, 0x10A2, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082,   // 0x0ED0 (3792)
0x0861, 0x0861, 0x0861, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x18E3, 0x632C, 0x73AE, 0x9492, 0xAD55, 0xB596, 0xB596,   // 0x0EE0 (3808)
0xBDD7, 0xB596, 0xAD75, 0xB596, 0xB596, 0xC618, 0xC618, 0xB5B6, 0xB5B6, 0xB596, 0xAD55, 0x9CF3, 0x8430, 0x7BCF, 0x6B4D, 0x5ACB,   // 0x0EF0 (3824)
0x4A69, 0x4228, 0x4208, 0x39E7, 0x2965, 0x2104, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x0F00 (3840)
0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x0F10 (3856)
0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0F20 (3872)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861,   // 0x0F30 (3888)
0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x2945, 0x6B6D, 0x73AE, 0x8C51, 0xA534, 0xAD55, 0xAD75, 0xB5B6,   // 0x0F40 (3904)
0xBDD7, 0xB596, 0xB5B6, 0xB5B6, 0xBDF7, 0xBDD7, 0xAD55, 0xA514, 0xB596, 0xAD55, 0x8C51, 0x7BEF, 0x8C51, 0x6B4D, 0x52AA, 0x4A69,   // 0x0F50 (3920)
0x4A49, 0x39E7, 0x3186, 0x2945, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x0F60 (3936)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x0F70 (3952)
0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0F80 (3968)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861,   // 0x0F90 (3984)
0x0861, 0x0861, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x3186, 0x6B4D, 0x73AE, 0x8430, 0x9CF3, 0xA534, 0xAD75, 0xB5B6, 0xBDD7,   // 0x0FA0 (4000)
0xB5B6, 0xBDD7, 0xB5B6, 0xAD75, 0xA514, 0x8C71, 0x8430, 0x9492, 0xA514, 0x8410, 0x8410, 0x7BCF, 0x630C, 0x528A, 0x4228, 0x4228,   // 0x0FB0 (4016)
0x39E7, 0x2965, 0x2945, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x0FC0 (4032)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082,   // 0x0FD0 (4048)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0FE0 (4064)
0x0861, 0x0841, 0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861,   // 0x0FF0 (4080)
0x0841, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x31A6, 0x6B4D, 0x7BCF, 0x8430, 0x9CD3, 0xA514, 0xAD55, 0xB596, 0xBDD7, 0xB5B6,   // 0x1000 (4096)
0xB5B6, 0xBDF7, 0x9CF3, 0x8C51, 0x8410, 0x7BEF, 0x73AE, 0x7BCF, 0x73AE, 0x8430, 0x73AE, 0x6B6D, 0x630C, 0x4228, 0x4208, 0x39E7,   // 0x1010 (4112)
0x2965, 0x2124, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2,   // 0x1020 (4128)
0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082,   // 0x1030 (4144)
0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x10A2, 0x18C3, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x1040 (4160)
0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841,   // 0x1050 (4176)
0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x39C7, 0x6B4D, 0x73AE, 0x8430, 0x94B2, 0xA514, 0xAD75, 0xB5B6, 0xC618, 0xBDD7, 0xB596,   // 0x1060 (4192)
0xBDF7, 0x9CD3, 0x8410, 0x7BEF, 0x7BCF, 0x7BCF, 0x738E, 0x73AE, 0x73AE, 0x6B6D, 0x6B4D, 0x5AEB, 0x4A49, 0x4A49, 0x4208, 0x31A6,   // 0x1070 (4208)
0x2945, 0x2104, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x1080 (4224)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x1082,   // 0x1090 (4240)
0x0861, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x1082, 0x0861, 0x0861, 0x0841, 0x0861, 0x0861, 0x0861,   // 0x10A0 (4256)
0x0841, 0x0841, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841,   // 0x10B0 (4272)
0x0020, 0x0020, 0x0000, 0x0000, 0x39C7, 0x6B6D, 0x7BCF, 0x8430, 0x94B2, 0xA514, 0xAD55, 0xBDD7, 0xC618, 0xBDD7, 0xB596, 0xAD55,   // 0x10C0 (4288)
0x9492, 0x8C51, 0x8C51, 0x7BEF, 0x7BCF, 0x73AE, 0x73AE, 0x7BEF, 0x8410, 0x738E, 0x630C, 0x4A69, 0x4A69, 0x4228, 0x39E7, 0x3186,   // 0x10D0 (4304)
0x2124, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x10A2,   // 0x10E0 (4320)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x1082,   // 0x10F0 (4336)
0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0841, 0x0861, 0x0861, 0x0861, 0x0841,   // 0x1100 (4352)
0x0841, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0020,   // 0x1110 (4368)
0x0020, 0x0000, 0x0000, 0x39E7, 0x738E, 0x7BEF, 0x8430, 0x9492, 0xA514, 0xA534, 0xB5B6, 0xC618, 0xBDD7, 0xB5B6, 0x9CF3, 0x8C51,   // 0x1120 (4384)
0x9492, 0x8430, 0x7BEF, 0x73AE, 0x73AE, 0x738E, 0x8430, 0x94B2, 0x7BEF, 0x6B6D, 0x5ACB, 0x528A, 0x4228, 0x4208, 0x3186, 0x2104,   // 0x1130 (4400)
0x18E3, 0x18C3, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1140 (4416)
0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082,   // 0x1150 (4432)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841,   // 0x1160 (4448)
0x0861, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0020, 0x0020,   // 0x1170 (4464)
0x0000, 0x0020, 0x4208, 0x738E, 0x7BCF, 0x8C51, 0x9492, 0x9CD3, 0xAD55, 0xBDD7, 0xBDF7, 0xBDF7, 0xBDD7, 0xA514, 0x9492, 0x8C71,   // 0x1180 (4480)
0x8410, 0x7BCF, 0x7BCF, 0x738E, 0x73AE, 0x9492, 0x8C71, 0x7BCF, 0x632C, 0x630C, 0x52AA, 0x4228, 0x39C7, 0x2945, 0x18E3, 0x18E3,   // 0x1190 (4496)
0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2,   // 0x11A0 (4512)
0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x18C3,   // 0x11B0 (4528)
0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082,   // 0x11C0 (4544)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0020, 0x0020, 0x0000,   // 0x11D0 (4560)
0x0841, 0x4A49, 0x73AE, 0x738E, 0x8430, 0x8C71, 0x9492, 0xA514, 0xB5B6, 0xC638, 0xC618, 0xBDF7, 0xB596, 0x9CF3, 0x8430, 0x8410,   // 0x11E0 (4576)
0x7BEF, 0x7BEF, 0x73AE, 0x7BEF, 0x8C71, 0x8410, 0x73AE, 0x6B4D, 0x632C, 0x528A, 0x39E7, 0x3186, 0x2124, 0x2104, 0x18E3, 0x18C3,   // 0x11F0 (4592)
0x18C3, 0x1082, 0x10A2, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x10A2,   // 0x1200 (4608)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1210 (4624)
0x10A2, 0x10A2, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0841, 0x0861, 0x0861, 0x1082, 0x10A2, 0x1082,   // 0x1220 (4640)
0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0020, 0x0020, 0x0000, 0x0020,   // 0x1230 (4656)
0x4A49, 0x73AE, 0x738E, 0x8410, 0x94B2, 0x9CD3, 0xA514, 0xAD75, 0xC618, 0xCE59, 0xBDF7, 0xA534, 0xA534, 0x8C51, 0x8430, 0x8430,   // 0x1240 (4672)
0x8410, 0x8410, 0x7BEF, 0x8430, 0x8410, 0x738E, 0x6B4D, 0x5AEB, 0x528A, 0x4208, 0x31A6, 0x2124, 0x2104, 0x18E3, 0x18C3, 0x10A2,   // 0x1250 (4688)
0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1260 (4704)
0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x10A2,   // 0x1270 (4720)
0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082,   // 0x1280 (4736)
0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x4208,   // 0x1290 (4752)
0x738E, 0x738E, 0x8410, 0x9CD3, 0x9CF3, 0xA534, 0xA534, 0xB596, 0xB5B6, 0xBDD7, 0xAD75, 0xA534, 0x9492, 0x94B2, 0x8C51, 0x8430,   // 0x12A0 (4768)
0x9492, 0x8C51, 0x8430, 0x8430, 0x6B6D, 0x630C, 0x5ACB, 0x4A69, 0x4A69, 0x39E7, 0x2945, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x10A2,   // 0x12B0 (4784)
0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x12C0 (4800)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x10A2, 0x1082,   // 0x12D0 (4816)
0x0861, 0x0861, 0x0861, 0x0841, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x1082, 0x0861, 0x0861, 0x0861,   // 0x12E0 (4832)
0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x39C7, 0x6B6D,   // 0x12F0 (4848)
0x73AE, 0x8410, 0x94B2, 0x94B2, 0xA514, 0xAD55, 0xAD55, 0xB596, 0xAD75, 0xB596, 0xAD75, 0x9CF3, 0xA534, 0x9CD3, 0x9492, 0xA514,   // 0x1300 (4864)
0x9CD3, 0x8C71, 0x8C71, 0x6B6D, 0x630C, 0x630C, 0x4A69, 0x4A49, 0x39C7, 0x2945, 0x2124, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x1082,   // 0x1310 (4880)
0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2,   // 0x1320 (4896)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861,   // 0x1330 (4912)
0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x10A2,   // 0x1340 (4928)
0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x3186, 0x6B4D, 0x7BCF,   // 0x1350 (4944)
0x8410, 0x8C71, 0x9492, 0x9CD3, 0xAD75, 0xB5B6, 0xAD55, 0x9CF3, 0xB596, 0xAD75, 0xAD55, 0xA534, 0xA534, 0xAD75, 0xAD55, 0xA514,   // 0x1360 (4960)
0x9492, 0x8C71, 0x6B6D, 0x632C, 0x632C, 0x4A69, 0x4208, 0x31A6, 0x2945, 0x2104, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082,   // 0x1370 (4976)
0x1082, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x18C3,   // 0x1380 (4992)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861,   // 0x1390 (5008)
0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x0841, 0x0861, 0x1082, 0x1082,   // 0x13A0 (5024)
0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x2124, 0x630C, 0x73AE, 0x8430,   // 0x13B0 (5040)
0x8C71, 0x9492, 0x94B2, 0x9CF3, 0xAD55, 0xA534, 0x9CD3, 0xA534, 0xB5B6, 0xAD75, 0xAD55, 0xB596, 0xB596, 0xAD75, 0x94B2, 0x8C71,   // 0x13C0 (5056)
0x8410, 0x6B6D, 0x632C, 0x630C, 0x4A69, 0x39E7, 0x3186, 0x2945, 0x2124, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x10A2, 0x1082, 0x0861,   // 0x13D0 (5072)
0x1082, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x13E0 (5088)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x13F0 (5104)
0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x1082, 0x1082, 0x10A2,   // 0x1400 (5120)
0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x18C3, 0x5AEB, 0x738E, 0x7BEF, 0x8430,   // 0x1410 (5136)
0x8C51, 0x94B2, 0x9CF3, 0x9CF3, 0xAD55, 0x9CD3, 0x9CD3, 0xAD75, 0xB5B6, 0xB596, 0xB596, 0xA514, 0x94B2, 0x8430, 0x8C51, 0x8430,   // 0x1420 (5152)
0x73AE, 0x6B4D, 0x632C, 0x4A69, 0x4208, 0x3186, 0x2945, 0x2124, 0x18E3, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x1082, 0x0861, 0x1082,   // 0x1430 (5168)
0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1440 (5184)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x1450 (5200)
0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x1460 (5216)
0x0861, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0861, 0x52AA, 0x6B6D, 0x7BEF, 0x8410, 0x73AE,   // 0x1470 (5232)
0x8C71, 0xA514, 0xA534, 0xAD75, 0xA514, 0xA534, 0xB5B6, 0xAD75, 0xB5B6, 0xAD75, 0x9CD3, 0x8C51, 0x8C51, 0x9CD3, 0x94B2, 0x7BEF,   // 0x1480 (5248)
0x73AE, 0x6B6D, 0x528A, 0x4208, 0x3186, 0x2945, 0x2124, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x1490 (5264)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18C3, 0x18C3,   // 0x14A0 (5280)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841,   // 0x14B0 (5296)
0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x0861,   // 0x14C0 (5312)
0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0020, 0x4A49, 0x6B6D, 0x7BCF, 0x8410, 0x738E, 0x8C51,   // 0x14D0 (5328)
0xA514, 0xAD55, 0xB596, 0xAD55, 0xAD75, 0xB5B6, 0xB596, 0xAD75, 0xB596, 0x94B2, 0x9492, 0x94B2, 0x9492, 0x94B2, 0x8C51, 0x8430,   // 0x14E0 (5344)
0x6B6D, 0x52AA, 0x4208, 0x3186, 0x2945, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x14F0 (5360)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1500 (5376)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841,   // 0x1510 (5392)
0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x0841, 0x0020,   // 0x1520 (5408)
0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x39C7, 0x6B4D, 0x738E, 0x8430, 0x8410, 0x8C71, 0x9CD3,   // 0x1530 (5424)
0xA514, 0xAD75, 0xB596, 0xB596, 0xB5B6, 0xBDD7, 0xB596, 0xBDD7, 0xAD75, 0xA534, 0xA534, 0x8C71, 0x8430, 0x8C51, 0x8C71, 0x73AE,   // 0x1540 (5440)
0x5ACB, 0x4228, 0x39C7, 0x2965, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1550 (5456)
0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1560 (5472)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841,   // 0x1570 (5488)
0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x0861, 0x0020, 0x0020, 0x0020,   // 0x1580 (5504)
0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x2945, 0x632C, 0x6B6D, 0x7BEF, 0x8C51, 0x8C51, 0x94B2, 0x9CD3,   // 0x1590 (5520)
0x9CD3, 0xAD75, 0xB5B6, 0xB5B6, 0xBDD7, 0xBDD7, 0xBDD7, 0xBDD7, 0xAD55, 0xAD55, 0x9CD3, 0x9492, 0x9492, 0x9492, 0x8410, 0x632C,   // 0x15A0 (5536)
0x528A, 0x4208, 0x3186, 0x2124, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x15B0 (5552)
0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x15C0 (5568)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x15D0 (5584)
0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0861, 0x1082, 0x10A2, 0x1082, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020,   // 0x15E0 (5600)
0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x10A2, 0x5AEB, 0x6B4D, 0x7BCF, 0x8C51, 0x8430, 0x9492, 0x94B2, 0x94B2,   // 0x15F0 (5616)
0xAD55, 0xB5B6, 0xBDF7, 0xBDF7, 0xB5B6, 0xB596, 0xB596, 0xB5B6, 0xB596, 0xB596, 0xA514, 0x9CF3, 0x9CD3, 0x8C51, 0x738E, 0x5ACB,   // 0x1600 (5632)
0x4A49, 0x39C7, 0x2965, 0x2124, 0x18E3, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1610 (5648)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1620 (5664)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841,   // 0x1630 (5680)
0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x1082, 0x10A2, 0x0861, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0020,   // 0x1640 (5696)
0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x4A49, 0x6B4D, 0x738E, 0x8410, 0x8C51, 0x9492, 0x9492, 0x9CD3, 0xAD55,   // 0x1650 (5712)
0xB5B6, 0xBDD7, 0xBDF7, 0xBDD7, 0xB596, 0xAD75, 0xB5B6, 0xB5B6, 0xB596, 0xAD75, 0x9CD3, 0x9CD3, 0x8C71, 0x73AE, 0x630C, 0x4A69,   // 0x1660 (5728)
0x39C7, 0x31A6, 0x2965, 0x2124, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1670 (5744)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1680 (5760)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841,   // 0x1690 (5776)
0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x0861, 0x0841, 0x0020, 0x0020, 0x0020, 0x0000, 0x0020, 0x0020,   // 0x16A0 (5792)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x31A6, 0x632C, 0x6B6D, 0x7BCF, 0x8430, 0x8C51, 0x8C51, 0x94B2, 0xA534, 0xAD75,   // 0x16B0 (5808)
0xB5B6, 0xBDD7, 0xBDD7, 0xBDF7, 0xB5B6, 0xAD55, 0xBDF7, 0xB5B6, 0xAD75, 0x9CF3, 0x9CD3, 0x9492, 0x7BCF, 0x632C, 0x5ACB, 0x4228,   // 0x16C0 (5824)
0x39C7, 0x3186, 0x2945, 0x2104, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x16D0 (5840)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x16E0 (5856)
0x18C3, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841,   // 0x16F0 (5872)
0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x0861, 0x0841, 0x0020, 0x0020, 0x0000, 0x0020, 0x0020, 0x0020, 0x0000,   // 0x1700 (5888)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x2104, 0x5ACB, 0x6B4D, 0x8410, 0x8410, 0x8430, 0x8430, 0x94B2, 0xA514, 0xA514, 0xB596,   // 0x1710 (5904)
0xBDD7, 0xB5B6, 0xBDF7, 0xBDF7, 0xB596, 0xB5B6, 0xB5B6, 0xAD55, 0xA534, 0x9CF3, 0x9492, 0x8410, 0x738E, 0x5AEB, 0x528A, 0x4228,   // 0x1720 (5920)
0x39C7, 0x3186, 0x2945, 0x2124, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1730 (5936)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1740 (5952)
0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x1082, 0x18C3, 0x18C3, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x1750 (5968)
0x0841, 0x0861, 0x0841, 0x0861, 0x1082, 0x1082, 0x0861, 0x0020, 0x0000, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000,   // 0x1760 (5984)
0x0000, 0x0000, 0x0000, 0x0000, 0x0861, 0x4A69, 0x6B4D, 0x7BCF, 0x8430, 0x8430, 0x8C51, 0x9492, 0x94B2, 0xA514, 0xAD75, 0xB5B6,   // 0x1770 (6000)
0xB596, 0xB5B6, 0xBDD7, 0xBDD7, 0xBDD7, 0xB5B6, 0xB596, 0xA534, 0x9CF3, 0x94B2, 0x8C51, 0x73AE, 0x630C, 0x52AA, 0x4A49, 0x39E7,   // 0x1780 (6016)
0x3186, 0x2965, 0x2945, 0x2104, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2,   // 0x1790 (6032)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18C3, 0x10A2, 0x10A2,   // 0x17A0 (6048)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861,   // 0x17B0 (6064)
0x0861, 0x0841, 0x0841, 0x0861, 0x1082, 0x0861, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x17C0 (6080)
0x0000, 0x0000, 0x0000, 0x0000, 0x39C7, 0x632C, 0x73AE, 0x8410, 0x8410, 0x8410, 0x8C71, 0x9CD3, 0xA514, 0xAD75, 0xB5B6, 0xB5B6,   // 0x17D0 (6096)
0xB5B6, 0xB5B6, 0xBDF7, 0xBDF7, 0xBDD7, 0xBDD7, 0xAD75, 0xA534, 0x94B2, 0x8C71, 0x7BCF, 0x6B6D, 0x5AEB, 0x4A69, 0x4208, 0x31A6,   // 0x17E0 (6112)
0x2965, 0x2124, 0x2104, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2,   // 0x17F0 (6128)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082,   // 0x1800 (6144)
0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x1810 (6160)
0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1820 (6176)
0x0000, 0x0000, 0x0000, 0x18E3, 0x5AEB, 0x6B6D, 0x7BCF, 0x7BEF, 0x7BCF, 0x8C51, 0x9CD3, 0x9CD3, 0xAD55, 0xB5B6, 0xB5B6, 0xB596,   // 0x1830 (6192)
0xB5B6, 0xBDD7, 0xBDD7, 0xB5B6, 0xB5B6, 0xB5B6, 0xAD75, 0x9CF3, 0x9492, 0x8410, 0x73AE, 0x630C, 0x528A, 0x4228, 0x39E7, 0x3186,   // 0x1840 (6208)
0x2945, 0x2124, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1850 (6224)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082,   // 0x1860 (6240)
0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841,   // 0x1870 (6256)
0x0841, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1880 (6272)
0x0000, 0x0000, 0x0841, 0x4A69, 0x6B4D, 0x7BCF, 0x8410, 0x7BCF, 0x8430, 0x94B2, 0x9CD3, 0xA534, 0xAD75, 0xAD75, 0xB596, 0xB596,   // 0x1890 (6288)
0xB5B6, 0xC618, 0xBDF7, 0xBDD7, 0xB5B6, 0xB596, 0xA514, 0x94B2, 0x8C51, 0x7BCF, 0x632C, 0x5ACB, 0x4A49, 0x4208, 0x31A6, 0x2965,   // 0x18A0 (6304)
0x2124, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x18B0 (6320)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082,   // 0x18C0 (6336)
0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020,   // 0x18D0 (6352)
0x0841, 0x0861, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x18E0 (6368)
0x0000, 0x0000, 0x2965, 0x632C, 0x738E, 0x8410, 0x7BEF, 0x8410, 0x94B2, 0x9CF3, 0xA514, 0xAD55, 0xAD75, 0xB596, 0xB596, 0xB5B6,   // 0x18F0 (6384)
0xBDF7, 0xBDF7, 0xBDF7, 0xBDD7, 0xAD75, 0x9CF3, 0x94B2, 0x8C51, 0x7BEF, 0x6B4D, 0x5AEB, 0x528A, 0x4228, 0x39C7, 0x2965, 0x2945,   // 0x1900 (6400)
0x2104, 0x2104, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1910 (6416)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2,   // 0x1920 (6432)
0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0861,   // 0x1930 (6448)
0x0861, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1940 (6464)
0x0000, 0x0861, 0x528A, 0x6B6D, 0x7BEF, 0x8430, 0x8410, 0x8C51, 0x94B2, 0x9CF3, 0xA514, 0xA534, 0xAD55, 0xB5B6, 0xB5B6, 0xBDD7,   // 0x1950 (6480)
0xBDF7, 0xC618, 0xBDF7, 0xAD55, 0xAD55, 0x9CF3, 0x8C51, 0x7BEF, 0x738E, 0x630C, 0x528A, 0x4228, 0x39C7, 0x3186, 0x2945, 0x2124,   // 0x1960 (6496)
0x2104, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1970 (6512)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2,   // 0x1980 (6528)
0x10A2, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0841, 0x0841,   // 0x1990 (6544)
0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x19A0 (6560)
0x0000, 0x2965, 0x6B4D, 0x73AE, 0x8410, 0x8430, 0x8C71, 0x9492, 0x9CD3, 0xA514, 0xA514, 0xAD75, 0xB5B6, 0xB5B6, 0xB596, 0xBDF7,   // 0x19B0 (6576)
0xC638, 0xBDD7, 0xAD75, 0xB5B6, 0xAD55, 0x9492, 0x8410, 0x73AE, 0x632C, 0x52AA, 0x4A49, 0x39E7, 0x3186, 0x2945, 0x2124, 0x2104,   // 0x19C0 (6592)
0x2104, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x19D0 (6608)
0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x19E0 (6624)
0x18C3, 0x10A2, 0x0861, 0x0861, 0x1082, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841,   // 0x19F0 (6640)
0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1A00 (6656)
0x0841, 0x528A, 0x73AE, 0x7BEF, 0x8430, 0x9492, 0x94B2, 0x94B2, 0x9CF3, 0xA514, 0xAD55, 0xB5B6, 0xBDD7, 0xBDF7, 0xBDF7, 0xBDF7,   // 0x1A10 (6672)
0xBDD7, 0xB5B6, 0xAD55, 0xA534, 0x9492, 0x8430, 0x7BCF, 0x6B6D, 0x5AEB, 0x4A69, 0x4208, 0x31A6, 0x2965, 0x2945, 0x2104, 0x2104,   // 0x1A20 (6688)
0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1A30 (6704)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2,   // 0x1A40 (6720)
0x10A2, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0841, 0x0020,   // 0x1A50 (6736)
0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1A60 (6752)
0x2124, 0x632C, 0x73AE, 0x8410, 0x8430, 0x8C71, 0x8C71, 0x94B2, 0xA534, 0xAD75, 0xB5B6, 0xBDD7, 0xBDD7, 0xB5B6, 0xBDF7, 0xBDF7,   // 0x1A70 (6768)
0xBDD7, 0xAD75, 0xA514, 0x94B2, 0x8C71, 0x8410, 0x738E, 0x630C, 0x528A, 0x4228, 0x39C7, 0x3186, 0x2945, 0x2124, 0x2104, 0x18E3,   // 0x1A80 (6784)
0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3,   // 0x1A90 (6800)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x1AA0 (6816)
0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020,   // 0x1AB0 (6832)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x1AC0 (6848)
0x4228, 0x6B6D, 0x7BCF, 0x8410, 0x8430, 0x8C71, 0x94B2, 0xA534, 0xAD75, 0xAD75, 0xAD75, 0xB596, 0xBDD7, 0xC618, 0xBDF7, 0xBDD7,   // 0x1AD0 (6864)
0xB596, 0xAD55, 0x9CF3, 0x9492, 0x8430, 0x73AE, 0x632C, 0x52AA, 0x4A49, 0x39E7, 0x31A6, 0x2965, 0x2124, 0x2104, 0x2104, 0x18E3,   // 0x1AE0 (6880)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1AF0 (6896)
0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082,   // 0x1B00 (6912)
0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000,   // 0x1B10 (6928)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x10A2,   // 0x1B20 (6944)
0x5ACB, 0x738E, 0x7BEF, 0x8430, 0x8C51, 0x94B2, 0xA514, 0x9CF3, 0xA514, 0xAD75, 0xB596, 0xBDF7, 0xC618, 0xC618, 0xBDD7, 0xB5B6,   // 0x1B30 (6960)
0xAD75, 0xA534, 0x9CD3, 0x8C51, 0x7BCF, 0x6B4D, 0x5AEB, 0x4A69, 0x4208, 0x39C7, 0x2965, 0x2945, 0x2124, 0x2104, 0x18E3, 0x18E3,   // 0x1B40 (6976)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1B50 (6992)
0x18C3, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x0861, 0x1082, 0x0841,   // 0x1B60 (7008)
0x0020, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000,   // 0x1B70 (7024)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x2965,   // 0x1B80 (7040)
0x6B6D, 0x73AE, 0x7BEF, 0x8410, 0x8C71, 0x94B2, 0x9CD3, 0xA534, 0xAD75, 0xB596, 0xBDD7, 0xBDD7, 0xBDF7, 0xBDD7, 0xB596, 0xB596,   // 0x1B90 (7056)
0xAD55, 0x9CF3, 0x8C71, 0x8410, 0x738E, 0x630C, 0x52AA, 0x4228, 0x39E7, 0x3186, 0x2965, 0x2124, 0x2104, 0x18E3, 0x18E3, 0x18C3,   // 0x1BA0 (7072)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2,   // 0x1BB0 (7088)
0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841,   // 0x1BC0 (7104)
0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1BD0 (7120)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x4A49,   // 0x1BE0 (7136)
0x738E, 0x73AE, 0x7BCF, 0x8410, 0x9492, 0x9CD3, 0x9CF3, 0xA534, 0xB596, 0xB5B6, 0xB596, 0xB5B6, 0xBDD7, 0xAD75, 0xAD75, 0xAD55,   // 0x1BF0 (7152)
0xA534, 0x9CD3, 0x8430, 0x7BCF, 0x6B4D, 0x5ACB, 0x4A69, 0x4208, 0x31A6, 0x2965, 0x2124, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x18C3,   // 0x1C00 (7168)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x1C10 (7184)
0x1082, 0x1082, 0x1082, 0x0861, 0x0841, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841,   // 0x1C20 (7200)
0x0020, 0x0020, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1C30 (7216)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1082, 0x52AA,   // 0x1C40 (7232)
0x6B6D, 0x73AE, 0x7BEF, 0x8430, 0x9492, 0x94B2, 0xA514, 0xB596, 0xAD75, 0xAD75, 0xAD75, 0xAD75, 0xB596, 0xB596, 0xAD55, 0xA514,   // 0x1C50 (7248)
0x9CD3, 0x8C51, 0x7BEF, 0x6B6D, 0x630C, 0x528A, 0x4A49, 0x39C7, 0x3186, 0x2945, 0x2124, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1C60 (7264)
0x18C3, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x1C70 (7280)
0x10A2, 0x1082, 0x0861, 0x0861, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x1C80 (7296)
0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1C90 (7312)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x18E3, 0x5ACB,   // 0x1CA0 (7328)
0x738E, 0x73AE, 0x8410, 0x8C51, 0x94B2, 0x9CF3, 0xAD55, 0xAD55, 0xAD75, 0xAD75, 0xB596, 0xB596, 0xAD75, 0xAD55, 0x9CF3, 0x9CD3,   // 0x1CB0 (7344)
0x94B2, 0x8430, 0x73AE, 0x632C, 0x52AA, 0x4A49, 0x39E7, 0x31A6, 0x2965, 0x2945, 0x2104, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x18C3,   // 0x1CC0 (7360)
0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x1CD0 (7376)
0x10A2, 0x1082, 0x0861, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0020, 0x0841, 0x0861,   // 0x1CE0 (7392)
0x0861, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1CF0 (7408)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x2124, 0x630C,   // 0x1D00 (7424)
0x73AE, 0x7BCF, 0x7BEF, 0x8C71, 0x9CF3, 0x9CF3, 0xA534, 0xAD55, 0xAD55, 0xAD75, 0xAD75, 0xA534, 0xA514, 0xA514, 0xA514, 0x94B2,   // 0x1D10 (7440)
0x8C51, 0x7BCF, 0x6B4D, 0x5ACB, 0x4A69, 0x4208, 0x31A6, 0x3186, 0x2965, 0x2945, 0x2104, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x10A2,   // 0x1D20 (7456)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082,   // 0x1D30 (7472)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0841, 0x0841, 0x0841,   // 0x1D40 (7488)
0x0841, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1D50 (7504)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x2124, 0x632C,   // 0x1D60 (7520)
0x6B6D, 0x738E, 0x8410, 0x9492, 0x94B2, 0x9CF3, 0xA514, 0x9CF3, 0x9CF3, 0xA514, 0xA534, 0xA514, 0xA514, 0x9CF3, 0x9492, 0x8C51,   // 0x1D70 (7536)
0x7BEF, 0x738E, 0x632C, 0x528A, 0x4228, 0x39C7, 0x3186, 0x2965, 0x2124, 0x2104, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x10A2,   // 0x1D80 (7552)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x1D90 (7568)
0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020,   // 0x1DA0 (7584)
0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1DB0 (7600)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x2965, 0x5AEB,   // 0x1DC0 (7616)
0x6B6D, 0x7BCF, 0x8410, 0x8C71, 0x94B2, 0x9CD3, 0x94B2, 0x94B2, 0x9CD3, 0x9CF3, 0xA514, 0x9CF3, 0x94B2, 0x9492, 0x8C51, 0x7BEF,   // 0x1DD0 (7632)
0x73AE, 0x6B4D, 0x5ACB, 0x4A49, 0x4208, 0x31A6, 0x2965, 0x2124, 0x2124, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2,   // 0x1DE0 (7648)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082,   // 0x1DF0 (7664)
0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020,   // 0x1E00 (7680)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1E10 (7696)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x2965, 0x630C,   // 0x1E20 (7712)
0x738E, 0x7BCF, 0x8410, 0x8430, 0x8C51, 0x9492, 0x94B2, 0x9492, 0x94B2, 0x9CD3, 0x9CD3, 0x9CD3, 0x9492, 0x8430, 0x8410, 0x73AE,   // 0x1E30 (7728)
0x6B4D, 0x630C, 0x52AA, 0x4A49, 0x39C7, 0x3186, 0x2965, 0x2945, 0x2124, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2,   // 0x1E40 (7744)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x1E50 (7760)
0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000,   // 0x1E60 (7776)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1E70 (7792)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x2945, 0x630C,   // 0x1E80 (7808)
0x738E, 0x7BCF, 0x7BEF, 0x8410, 0x8C51, 0x8C71, 0x8C71, 0x9492, 0x9492, 0x94B2, 0x9CD3, 0x9492, 0x8430, 0x8410, 0x73AE, 0x6B6D,   // 0x1E90 (7824)
0x632C, 0x5ACB, 0x4A69, 0x39E7, 0x31A6, 0x3186, 0x2945, 0x2124, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2,   // 0x1EA0 (7840)
0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861,   // 0x1EB0 (7856)
0x0861, 0x0841, 0x0841, 0x0841, 0x0861, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1EC0 (7872)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1ED0 (7888)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x2104, 0x52AA,   // 0x1EE0 (7904)
0x738E, 0x73AE, 0x7BCF, 0x7BCF, 0x8430, 0x8C51, 0x8C51, 0x8C51, 0x8C71, 0x94B2, 0x9492, 0x8C51, 0x8410, 0x7BEF, 0x738E, 0x6B4D,   // 0x1EF0 (7920)
0x5AEB, 0x528A, 0x4228, 0x39E7, 0x3186, 0x2965, 0x2124, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2,   // 0x1F00 (7936)
0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861,   // 0x1F10 (7952)
0x0861, 0x0861, 0x0861, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1F20 (7968)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1F30 (7984)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x10A2, 0x4A49,   // 0x1F40 (8000)
0x6B6D, 0x73AE, 0x73AE, 0x7BEF, 0x7BEF, 0x8410, 0x8C51, 0x8C51, 0x8C51, 0x8C51, 0x8C51, 0x8410, 0x7BEF, 0x73AE, 0x6B4D, 0x630C,   // 0x1F50 (8016)
0x52AA, 0x4A69, 0x4208, 0x39C7, 0x3186, 0x2945, 0x2124, 0x2104, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x1F60 (8032)
0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841,   // 0x1F70 (8048)
0x0861, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1F80 (8064)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1F90 (8080)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x31A6,   // 0x1FA0 (8096)
0x632C, 0x73AE, 0x73AE, 0x73AE, 0x7BEF, 0x8410, 0x8410, 0x8410, 0x7BEF, 0x8410, 0x7BEF, 0x7BCF, 0x738E, 0x6B6D, 0x632C, 0x5ACB,   // 0x1FB0 (8112)
0x528A, 0x4A49, 0x39E7, 0x31A6, 0x2965, 0x2945, 0x2124, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082,   // 0x1FC0 (8128)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841,   // 0x1FD0 (8144)
0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1FE0 (8160)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1FF0 (8176)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x2104,   // 0x2000 (8192)
0x528A, 0x6B6D, 0x738E, 0x73AE, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x73AE, 0x738E, 0x6B4D, 0x632C, 0x5ACB, 0x528A,   // 0x2010 (8208)
0x4A49, 0x4208, 0x39C7, 0x3186, 0x2945, 0x2124, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x2020 (8224)
0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020,   // 0x2030 (8240)
0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2040 (8256)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2050 (8272)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0861,   // 0x2060 (8288)
0x39C7, 0x630C, 0x6B4D, 0x738E, 0x73AE, 0x738E, 0x738E, 0x73AE, 0x738E, 0x738E, 0x6B6D, 0x632C, 0x630C, 0x5AEB, 0x52AA, 0x4A69,   // 0x2070 (8304)
0x4228, 0x39E7, 0x31A6, 0x2965, 0x2124, 0x2104, 0x2104, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861,   // 0x2080 (8320)
0x1082, 0x0861, 0x0861, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020,   // 0x2090 (8336)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x20A0 (8352)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x20B0 (8368)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x20C0 (8384)
0x18C3, 0x4208, 0x630C, 0x6B4D, 0x6B6D, 0x6B6D, 0x6B6D, 0x6B6D, 0x6B4D, 0x632C, 0x632C, 0x632C, 0x5AEB, 0x52AA, 0x528A, 0x4A49,   // 0x20D0 (8400)
0x39E7, 0x39C7, 0x3186, 0x2945, 0x2124, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861,   // 0x20E0 (8416)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000,   // 0x20F0 (8432)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2100 (8448)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2110 (8464)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2120 (8480)
0x0020, 0x2104, 0x4228, 0x5AEB, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x630C, 0x5AEB, 0x5ACB, 0x528A, 0x4A69, 0x4228, 0x39E7,   // 0x2130 (8496)
0x31A6, 0x3186, 0x2965, 0x2124, 0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x2140 (8512)
0x0841, 0x0841, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2150 (8528)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2160 (8544)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2170 (8560)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2180 (8576)
0x0000, 0x0020, 0x18E3, 0x39C7, 0x4A69, 0x5AEB, 0x630C, 0x5AEB, 0x630C, 0x5AEB, 0x52AA, 0x528A, 0x4A69, 0x4228, 0x39E7, 0x39C7,   // 0x2190 (8592)
0x3186, 0x2945, 0x2124, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x21A0 (8608)
0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x21B0 (8624)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x21C0 (8640)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x21D0 (8656)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x21E0 (8672)
0x0000, 0x0000, 0x0000, 0x1082, 0x2945, 0x39E7, 0x528A, 0x5ACB, 0x5ACB, 0x52AA, 0x528A, 0x4A69, 0x4228, 0x39E7, 0x39C7, 0x3186,   // 0x21F0 (8688)
0x2945, 0x2124, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020,   // 0x2200 (8704)
0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2210 (8720)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2220 (8736)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2230 (8752)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2240 (8768)
0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x1082, 0x2104, 0x31A6, 0x4208, 0x4208, 0x4208, 0x4208, 0x39E7, 0x39C7, 0x3186, 0x2945,   // 0x2250 (8784)
0x2124, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000,   // 0x2260 (8800)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2270 (8816)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2280 (8832)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2290 (8848)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22A0 (8864)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x1082, 0x18C3, 0x2104, 0x2124, 0x2945, 0x2965, 0x2124, 0x2104,   // 0x22B0 (8880)
0x18E3, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22C0 (8896)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22D0 (8912)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22E0 (8928)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22F0 (8944)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2300 (8960)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0841, 0x0841,   // 0x2310 (8976)
0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2320 (8992)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2330 (9008)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2340 (9024)
0x0000, };
Drained.c
// Generated by  : ImageConverter 565 v2.3
// Generated from: Drained.png
// Time generated: 21/06/2022 9:17:30 AM
// Dimensions    : 36x21 pixels
// Size          : 1,512 Bytes
#include <avr/pgmspace.h>
const unsigned int Drained[0x2F4] PROGMEM ={
0x0000, 0x0000, 0x632C, 0x630C, 0x5ACB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5ACB,   // 0x0010 (16)
0x5ACB, 0x5ACB, 0x5ACB, 0x5ACB, 0x5ACB, 0x5ACB, 0x5ACB, 0x5ACB, 0x5ACB, 0x5ACB, 0x5ACB, 0x5ACB, 0x5ACB, 0x5ACB, 0x630C, 0x5AEB,   // 0x0020 (32)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x6B4D, 0x6B4D, 0x738E, 0x738E, 0x738E, 0x738E, 0x738E, 0x738E, 0x738E, 0x738E, 0x738E,   // 0x0030 (48)
0x738E, 0x738E, 0x738E, 0x738E, 0x738E, 0x738E, 0x738E, 0x738E, 0x738E, 0x738E, 0x738E, 0x738E, 0x738E, 0x738E, 0x738E, 0x6B6D,   // 0x0040 (64)
0x6B6D, 0x738E, 0x6B6D, 0x6B4D, 0x632C, 0x0000, 0x0000, 0x0000, 0x632C, 0x6B4D, 0x9492, 0xDEDC, 0xE73D, 0xE71D, 0xE71D, 0xE71D,   // 0x0050 (80)
0xE71D, 0xE71D, 0xE71C, 0xE71D, 0xE71D, 0xE71D, 0xE71D, 0xE71D, 0xE71C, 0xE71C, 0xE71C, 0xE71C, 0xE71C, 0xE71C, 0xE71C, 0xE71C,   // 0x0060 (96)
0xE71C, 0xE71C, 0xE71C, 0xE71C, 0xE71C, 0xE71C, 0xD69A, 0x8410, 0x632C, 0x5ACB, 0x0000, 0x0000, 0x630C, 0x6B6D, 0xDEDB, 0xFFFD,   // 0x0070 (112)
0xF7B0, 0xF7B0, 0xF7B0, 0xF7B0, 0xF7AF, 0xFFF6, 0xFFFC, 0xF7B0, 0xF7B0, 0xF7B0, 0xF7B0, 0xF7AF, 0xFFFA, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0080 (128)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xB5B6, 0x630C, 0x5ACB, 0x0000, 0x0000,   // 0x0090 (144)
0x5AEB, 0x6B6E, 0xDEFC, 0xFFF2, 0xDF21, 0xE722, 0xE722, 0xE722, 0xDF21, 0xEF8D, 0xFFD8, 0xDF22, 0xE722, 0xE722, 0xE722, 0xDF01,   // 0x00A0 (160)
0xF7B4, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xBDD7,   // 0x00B0 (176)
0x5AEB, 0x52AA, 0x0000, 0x0000, 0x5AEB, 0x6B6D, 0xDEDC, 0xFFD2, 0xE722, 0xE744, 0xE744, 0xE744, 0xE722, 0xEF8F, 0xFFD9, 0xE723,   // 0x00C0 (192)
0xE743, 0xE744, 0xE743, 0xE722, 0xF7B5, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x00D0 (208)
0xFFFF, 0xFFFF, 0xFFFF, 0xBDD7, 0x5AEB, 0x528A, 0x0000, 0x0000, 0x5AEB, 0x6B6D, 0xDEDC, 0xFFD2, 0xE722, 0xE744, 0xE744, 0xE744,   // 0x00E0 (224)
0xE722, 0xEF8F, 0xFFD9, 0xE723, 0xE743, 0xE744, 0xE743, 0xE722, 0xF7B5, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x00F0 (240)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xBDD7, 0x630C, 0x632C, 0x6B4D, 0x4A49, 0x5AEB, 0x6B6D, 0xDEDC, 0xFFD2,   // 0x0100 (256)
0xE722, 0xE744, 0xE744, 0xE744, 0xE722, 0xEF8E, 0xFFD9, 0xE724, 0xE744, 0xE744, 0xE743, 0xE722, 0xF7B5, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0110 (272)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xB5B6, 0x5ACB, 0x6B4D, 0x738E, 0x632C,   // 0x0120 (288)
0x5AEB, 0x6B6D, 0xDEDC, 0xFFD2, 0xE722, 0xE744, 0xE744, 0xE744, 0xE722, 0xEF8F, 0xFFD9, 0xE724, 0xE744, 0xE744, 0xE743, 0xE722,   // 0x0130 (304)
0xF7B5, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xEF5D,   // 0x0140 (320)
0xD69A, 0xD6BA, 0x9CF3, 0x632C, 0x5AEB, 0x6B6D, 0xDEDC, 0xFFD2, 0xE722, 0xE744, 0xE744, 0xE744, 0xE722, 0xEF8F, 0xFFD9, 0xE724,   // 0x0150 (336)
0xE744, 0xE744, 0xE743, 0xE722, 0xF7B5, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0160 (352)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xBDD7, 0x5AEB, 0x5AEB, 0x6B6D, 0xDEDC, 0xFFD2, 0xE722, 0xE744, 0xE744, 0xE744,   // 0x0170 (368)
0xE722, 0xEF8F, 0xFFD9, 0xE724, 0xE744, 0xE744, 0xE743, 0xE722, 0xF7B5, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0180 (384)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xB5B6, 0x5AEB, 0x5AEB, 0x6B6D, 0xDEDC, 0xFFD2,   // 0x0190 (400)
0xE722, 0xE744, 0xE744, 0xE744, 0xE722, 0xEF8E, 0xFFD9, 0xE723, 0xE743, 0xE744, 0xE743, 0xE722, 0xF7B5, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x01A0 (416)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xB5B6, 0x5AEB,   // 0x01B0 (432)
0x5AEB, 0x6B6D, 0xDEDC, 0xFFD2, 0xE722, 0xE744, 0xE744, 0xE744, 0xE722, 0xEF8F, 0xFFD9, 0xE723, 0xE743, 0xE744, 0xE743, 0xE722,   // 0x01C0 (448)
0xF7B5, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x01D0 (464)
0xFFFF, 0xFFFF, 0xBDD7, 0x5AEB, 0x5AEB, 0x6B6D, 0xDEDC, 0xFFD2, 0xE722, 0xE744, 0xE744, 0xE744, 0xE722, 0xEF8F, 0xFFD9, 0xE723,   // 0x01E0 (480)
0xE743, 0xE744, 0xE743, 0xE722, 0xF7B5, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x01F0 (496)
0xFFFF, 0xFFFF, 0xFFFF, 0xDEFB, 0xB5B6, 0xBDF7, 0x9492, 0x632C, 0x5AEB, 0x6B6D, 0xDEDC, 0xFFD2, 0xE722, 0xE744, 0xE744, 0xE744,   // 0x0200 (512)
0xE722, 0xEF8F, 0xFFD9, 0xE723, 0xE743, 0xE744, 0xE743, 0xE722, 0xF7B5, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0210 (528)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xB596, 0x52AA, 0x630C, 0x6B4D, 0x632C, 0x5AEB, 0x6B6D, 0xDEDC, 0xFFD2,   // 0x0220 (544)
0xE722, 0xE744, 0xE744, 0xE744, 0xE722, 0xEF8E, 0xFFD9, 0xE723, 0xE743, 0xE744, 0xE743, 0xE722, 0xF7B5, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0230 (560)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xBDD7, 0x630C, 0x5ACB, 0x5ACB, 0x0000,   // 0x0240 (576)
0x5AEB, 0x6B6D, 0xDEDC, 0xFFD2, 0xE722, 0xE744, 0xE744, 0xE744, 0xE742, 0xEF8E, 0xFFD9, 0xE723, 0xE743, 0xE744, 0xE743, 0xE722,   // 0x0250 (592)
0xF7B5, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xBDD7,   // 0x0260 (608)
0x5AEB, 0x52AA, 0x0000, 0x0000, 0x5AEB, 0x6B6E, 0xDEFC, 0xFFD4, 0xE701, 0xE722, 0xE722, 0xE722, 0xE721, 0xEF6E, 0xF7D8, 0xDF22,   // 0x0270 (624)
0xE722, 0xE722, 0xE722, 0xDF21, 0xF7B4, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0280 (640)
0xFFFF, 0xFFFF, 0xFFFF, 0xBDF7, 0x5AEB, 0x52AA, 0x0000, 0x0000, 0x632C, 0x6B6D, 0xD69A, 0xFFFF, 0xFFF6, 0xFFF5, 0xFFF6, 0xFFF6,   // 0x0290 (656)
0xFFF5, 0xFFFA, 0xFFFE, 0xFFF5, 0xFFF5, 0xFFF5, 0xFFF5, 0xFFF5, 0xFFFC, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x02A0 (672)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xAD75, 0x630C, 0x5ACB, 0x0000, 0x0000, 0x5AEB, 0x632C, 0x8430, 0xC618,   // 0x02B0 (688)
0xCE7B, 0xCE5A, 0xCE5A, 0xCE5A, 0xCE5A, 0xCE5A, 0xCE59, 0xCE5A, 0xCE5A, 0xCE5A, 0xCE5A, 0xCE5A, 0xCE59, 0xCE59, 0xCE59, 0xCE59,   // 0x02C0 (704)
0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xB5B6, 0x7BCF, 0x630C, 0x52AA, 0x0000, 0x0000,   // 0x02D0 (720)
0x0000, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C,   // 0x02E0 (736)
0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x6B4D,   // 0x02F0 (752)
0x630C, 0x0000, 0x0000, 0x0000, };
Draining.c
// Generated from: Draining.png
// Time generated: 21/06/2022 9:16:28 AM
const unsigned int Draining[0x2F4] PROGMEM ={
0x0000, 0x0000, 0x630C, 0x632C, 0x630C, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB,   // 0x0010 (16)
0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x630C, 0x632C, 0x4A69,   // 0x0020 (32)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x630C, 0x6B4D, 0x6B6D, 0x6B6D, 0x6B6D, 0x6B6D, 0x6B6D, 0x6B6D, 0x6B6D, 0x6B6D, 0x6B6D,   // 0x0030 (48)
0x6B6D, 0x6B6D, 0x6B6D, 0x6B6D, 0x6B6D, 0x6B6D, 0x6B6D, 0x6B6D, 0x6B6D, 0x6B6D, 0x6B6D, 0x6B6D, 0x6B6D, 0x6B6D, 0x6B6D, 0x6B6D,   // 0x0040 (64)
0x6B6D, 0x6B6D, 0x6B4D, 0x6B4D, 0x632C, 0x0000, 0x0000, 0x0000, 0x630C, 0x6B4D, 0x8C71, 0xD69A, 0xE6FC, 0xDEFC, 0xDEFC, 0xDEFC,   // 0x0050 (80)
0xDEFC, 0xDEDB, 0xDEDB, 0xDEFC, 0xDEFC, 0xDEFC, 0xDEFC, 0xDEFC, 0xDEDB, 0xDEDB, 0xE6FC, 0xDEFC, 0xDEFC, 0xDEFC, 0xDEFC, 0xDEDB,   // 0x0060 (96)
0xD6BA, 0xD6BA, 0xD6BA, 0xD6BA, 0xD6BA, 0xDEDB, 0xCE59, 0x7BEF, 0x632C, 0x5ACB, 0x0000, 0x0000, 0x630C, 0x6B6D, 0xDEDB, 0xFFFF,   // 0x0070 (112)
0xD755, 0xCF55, 0xCF55, 0xD755, 0xCF34, 0xE7BA, 0xFFFD, 0xCF55, 0xCF55, 0xD755, 0xD735, 0xCF34, 0xF7FD, 0xEFDA, 0xCF34, 0xCF55,   // 0x0080 (128)
0xCF55, 0xCF54, 0xD755, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xB596, 0x630C, 0x5ACB, 0x0000, 0x0000,   // 0x0090 (144)
0x5AEB, 0x6B6D, 0xE6FC, 0xD775, 0x8607, 0x8E28, 0x8E28, 0x8E28, 0x8E07, 0xBEF1, 0xE7BA, 0x8E28, 0x8E28, 0x8E28, 0x8E28, 0x8607,   // 0x00A0 (160)
0xDF78, 0xCF14, 0x8627, 0x8E28, 0x8E28, 0x8E27, 0x9629, 0xF7BC, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xBDD7,   // 0x00B0 (176)
0x630C, 0x5AEB, 0x0000, 0x0000, 0x5AEB, 0x6B6D, 0xE6FC, 0xD775, 0x8E48, 0x966A, 0x966A, 0x966A, 0x8E28, 0xBEF2, 0xEFBB, 0x9649,   // 0x00C0 (192)
0x9669, 0x966A, 0x966A, 0x8E48, 0xDF78, 0xCF34, 0x8E29, 0x964A, 0x964A, 0x9649, 0x9E4B, 0xF7BC, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x00D0 (208)
0xFFFF, 0xFFFF, 0xFFFF, 0xBDD7, 0x630C, 0x52AA, 0x0000, 0x0000, 0x5AEB, 0x6B6D, 0xE6FC, 0xD776, 0x8E28, 0x966A, 0x966A, 0x966A,   // 0x00E0 (224)
0x9648, 0xC6F2, 0xEFBB, 0x9649, 0x966A, 0x966A, 0x966A, 0x8E48, 0xDF78, 0xCF34, 0x8E29, 0x964A, 0x964A, 0x9649, 0x9E4B, 0xF7BC,   // 0x00F0 (240)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xBDD7, 0x630C, 0x632C, 0x6B4D, 0x0000, 0x5AEB, 0x6B6D, 0xE6FC, 0xD756,   // 0x0100 (256)
0x8E28, 0x966A, 0x966A, 0x966A, 0x9648, 0xC6F2, 0xEFBB, 0x9649, 0x9669, 0x966A, 0x966A, 0x8E48, 0xDF78, 0xCF34, 0x8E29, 0x966A,   // 0x0110 (272)
0x966A, 0x9669, 0x9E6B, 0xF7BC, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xB596, 0x52AA, 0x632C, 0x6B6D, 0x632C,   // 0x0120 (288)
0x5AEB, 0x6B6D, 0xE6FC, 0xD756, 0x8E28, 0x966A, 0x966A, 0x966A, 0x9648, 0xC6F2, 0xEFBB, 0x9649, 0x9669, 0x966A, 0x966A, 0x8E48,   // 0x0130 (304)
0xDF78, 0xCF34, 0x8E29, 0x966A, 0x966A, 0x9669, 0x9E6B, 0xF7BC, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xE73C,   // 0x0140 (320)
0xCE59, 0xCE79, 0x9CD3, 0x632C, 0x5AEB, 0x6B6D, 0xE6FC, 0xD755, 0x8E28, 0x966A, 0x966A, 0x966A, 0x9648, 0xC6F2, 0xEFBB, 0x9649,   // 0x0150 (336)
0x9669, 0x966A, 0x966A, 0x8E48, 0xDF78, 0xCF34, 0x8E29, 0x966A, 0x966A, 0x9669, 0x9E6B, 0xF7BC, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0160 (352)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xBDD7, 0x630C, 0x5AEB, 0x6B6D, 0xE6FC, 0xD775, 0x8E28, 0x966A, 0x966A, 0x966A,   // 0x0170 (368)
0x9648, 0xC6F2, 0xEFBB, 0x9649, 0x9669, 0x966A, 0x966A, 0x8E48, 0xDF78, 0xCF34, 0x8E29, 0x966A, 0x966A, 0x9669, 0x9E6B, 0xF7BC,   // 0x0180 (384)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xB5B6, 0x5AEB, 0x5AEB, 0x6B6D, 0xE6FC, 0xD775,   // 0x0190 (400)
0x8E28, 0x966A, 0x966A, 0x966A, 0x9648, 0xC6F2, 0xEFBB, 0x9649, 0x9669, 0x966A, 0x966A, 0x8E48, 0xDF78, 0xCF34, 0x8E29, 0x966A,   // 0x01A0 (416)
0x966A, 0x9669, 0x9E6B, 0xF7BC, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xB5B6, 0x5AEB,   // 0x01B0 (432)
0x5AEB, 0x6B6D, 0xE6FC, 0xD775, 0x8E28, 0x966A, 0x966A, 0x966A, 0x8E48, 0xBEF2, 0xEFBB, 0x9649, 0x9669, 0x966A, 0x966A, 0x8E48,   // 0x01C0 (448)
0xDF78, 0xCF34, 0x8E29, 0x966A, 0x966A, 0x9669, 0x9E6B, 0xF7BC, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x01D0 (464)
0xFFFF, 0xFFFF, 0xBDD7, 0x5AEB, 0x5AEB, 0x6B6D, 0xE6FC, 0xD776, 0x8E28, 0x966A, 0x966A, 0x966A, 0x8E48, 0xBEF2, 0xEFBB, 0x9649,   // 0x01E0 (480)
0x9669, 0x966A, 0x966A, 0x8E48, 0xDF78, 0xCF34, 0x8E29, 0x966A, 0x966A, 0x9669, 0x9E4B, 0xF7BC, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x01F0 (496)
0xFFFF, 0xFFFF, 0xFFFF, 0xE71C, 0xC618, 0xCE59, 0x94B2, 0x632C, 0x5AEB, 0x6B6D, 0xE6FC, 0xD756, 0x8E28, 0x966A, 0x966A, 0x966A,   // 0x0200 (512)
0x8E48, 0xBEF2, 0xEFBB, 0x9649, 0x9669, 0x966A, 0x966A, 0x8E48, 0xDF78, 0xCF34, 0x8E29, 0x966A, 0x966A, 0x9669, 0x9E4B, 0xF7BC,   // 0x0210 (528)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xB596, 0x52AA, 0x632C, 0x6B6D, 0x632C, 0x5AEB, 0x6B6D, 0xE6FC, 0xD776,   // 0x0220 (544)
0x8E28, 0x966A, 0x966A, 0x966A, 0x8E48, 0xBEF2, 0xEFBB, 0x9649, 0x9669, 0x966A, 0x966A, 0x8E48, 0xDF78, 0xCF34, 0x8E29, 0x966A,   // 0x0230 (560)
0x966A, 0x9669, 0x9E6B, 0xF7BC, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xBDD7, 0x630C, 0x5AEB, 0x5AEB, 0x0000,   // 0x0240 (576)
0x5AEB, 0x6B6D, 0xE6FC, 0xD755, 0x8E48, 0x966A, 0x966A, 0x966A, 0x8E48, 0xBEF2, 0xEFBA, 0x9649, 0x9669, 0x966A, 0x9669, 0x8E48,   // 0x0250 (592)
0xDF78, 0xCF34, 0x8E29, 0x966A, 0x966A, 0x9669, 0x9E6B, 0xF7BC, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xBDD7,   // 0x0260 (608)
0x630C, 0x52AA, 0x0000, 0x0000, 0x5AEB, 0x6B6E, 0xE71C, 0xD756, 0x8E07, 0x8E28, 0x8E28, 0x8E28, 0x8607, 0xBEF1, 0xEFBA, 0x8E28,   // 0x0270 (624)
0x8E28, 0x8E28, 0x8E28, 0x8607, 0xDF78, 0xC714, 0x8607, 0x8E28, 0x8E28, 0x8E28, 0x962A, 0xF7BC, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0280 (640)
0xFFFF, 0xFFFF, 0xFFFF, 0xBDF7, 0x630C, 0x5ACB, 0x0000, 0x0000, 0x5AEB, 0x6B6D, 0xDEBB, 0xFFFF, 0xD776, 0xD776, 0xD796, 0xD796,   // 0x0290 (656)
0xD775, 0xEFDA, 0xFFFE, 0xD776, 0xD796, 0xD796, 0xD796, 0xD776, 0xFFFD, 0xF7DB, 0xD775, 0xD776, 0xD776, 0xD775, 0xD776, 0xFFFF,   // 0x02A0 (672)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xB596, 0x630C, 0x5ACB, 0x0000, 0x0000, 0x630C, 0x6B4D, 0x8C51, 0xCE59,   // 0x02B0 (688)
0xD6BB, 0xD6BB, 0xD6BB, 0xD6BB, 0xD6BB, 0xD69A, 0xD69A, 0xD6BB, 0xD6BB, 0xD6BB, 0xD6BB, 0xDEBB, 0xD69A, 0xD69A, 0xDEBB, 0xD6BB,   // 0x02C0 (704)
0xD6BB, 0xD6BB, 0xD6BB, 0xD69A, 0xD69A, 0xD69A, 0xD69A, 0xD69A, 0xD69A, 0xD69A, 0xC5F8, 0x7BEF, 0x632C, 0x52AA, 0x0000, 0x0000,   // 0x02D0 (720)
0x0000, 0x632C, 0x632C, 0x632C, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D,   // 0x02E0 (736)
0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D,   // 0x02F0 (752)
Empty.c
// Generated from: Empty.png
// Time generated: 21/06/2022 9:17:58 AM
const unsigned int Empty[0x2F4] PROGMEM ={
0x0000, 0x0000, 0x630C, 0x632C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C,   // 0x0010 (16)
0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x632C, 0x630C,   // 0x0020 (32)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x632C, 0x6B6D, 0x738E, 0x73AE, 0x73AE, 0x73AE, 0x73AE, 0x73AE, 0x73AE, 0x73AE, 0x73AE,   // 0x0030 (48)
0x73AE, 0x73AE, 0x73AE, 0x73AE, 0x73AE, 0x73AE, 0x73AE, 0x73AE, 0x73AE, 0x73AE, 0x73AE, 0x73AE, 0x73AE, 0x73AE, 0x73AE, 0x73AE,   // 0x0040 (64)
0x73AE, 0x73AE, 0x738E, 0x6B4D, 0x630C, 0x0000, 0x0000, 0x0000, 0x630C, 0x6B4D, 0x94B2, 0xE75D, 0xEFBE, 0xEF9E, 0xEF9E, 0xEF9E,   // 0x0050 (80)
0xEF9E, 0xEF9E, 0xEF5D, 0xEF5D, 0xEF5D, 0xEF5D, 0xEF5D, 0xEF5D, 0xEF5D, 0xEF5D, 0xEF5D, 0xEF5D, 0xEF5D, 0xEF5D, 0xEF5D, 0xEF5D,   // 0x0060 (96)
0xEF5D, 0xEF5D, 0xEF5D, 0xEF5D, 0xEF5D, 0xEF5D, 0xDEDB, 0x8430, 0x632C, 0x5ACB, 0x0000, 0x0000, 0x630C, 0x6B6D, 0xDF1C, 0xFF1A,   // 0x0070 (112)
0xEC4C, 0xEC4D, 0xEC6D, 0xEC6D, 0xEC4C, 0xEC8D, 0xFF9D, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0080 (128)
0x5AEB, 0x6B6E, 0xDF3C, 0xEC8E, 0xE180, 0xE1E1, 0xE1E1, 0xE1E1, 0xE1C1, 0xDA22, 0xFF1A, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x00A0 (160)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xBDD7,   // 0x00B0 (176)
0x630C, 0x5ACB, 0x0000, 0x0000, 0x5AEB, 0x6B6D, 0xDF1C, 0xEC8E, 0xE1E1, 0xE243, 0xE243, 0xE243, 0xE222, 0xE264, 0xFF1B, 0xFFFF,   // 0x00C0 (192)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x00D0 (208)
0xFFFF, 0xFFFF, 0xFFFF, 0xBDD7, 0x630C, 0x528A, 0x0000, 0x0000, 0x5AEB, 0x6B6D, 0xDF1C, 0xECAE, 0xE1E1, 0xE243, 0xE243, 0xE243,   // 0x00E0 (224)
0xE222, 0xE264, 0xFF1B, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x00F0 (240)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xB5B6, 0x5AEB, 0x5AEB, 0x632C, 0x5AEB, 0x5AEB, 0x6B6D, 0xDF1C, 0xECAE,   // 0x0100 (256)
0xE1E1, 0xE243, 0xE243, 0xE243, 0xE222, 0xE264, 0xFF1B, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0110 (272)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xB5B6, 0x5ACB, 0x6B6D, 0x73AE, 0x632C,   // 0x0120 (288)
0x5AEB, 0x6B6D, 0xDF1C, 0xECAE, 0xE1E1, 0xE243, 0xE243, 0xE243, 0xE222, 0xE263, 0xFF1A, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0130 (304)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xEF7D,   // 0x0140 (320)
0xDEFB, 0xE71C, 0xA514, 0x632C, 0x5AEB, 0x6B6D, 0xDF1C, 0xECAE, 0xE1E1, 0xE243, 0xE243, 0xE243, 0xE222, 0xE263, 0xFF1B, 0xFFFF,   // 0x0150 (336)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0160 (352)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xBDD7, 0x630C, 0x5AEB, 0x6B6D, 0xDF1C, 0xECAE, 0xE1E1, 0xE243, 0xE243, 0xE243,   // 0x0170 (368)
0xE222, 0xE264, 0xFF1B, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0180 (384)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xB5B6, 0x630C, 0x5AEB, 0x6B6D, 0xDF1C, 0xECAE,   // 0x0190 (400)
0xE1E1, 0xE243, 0xE243, 0xE243, 0xE222, 0xE264, 0xFF1B, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x01A0 (416)
0x5AEB, 0x6B6D, 0xDF1C, 0xECAE, 0xE1E1, 0xE243, 0xE243, 0xE243, 0xE222, 0xE264, 0xFF1B, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x01C0 (448)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x01D0 (464)
0xFFFF, 0xFFFF, 0xBDD7, 0x5AEB, 0x5AEB, 0x6B6D, 0xDF1C, 0xECAE, 0xE1E1, 0xE243, 0xE243, 0xE243, 0xE222, 0xE264, 0xFF1B, 0xFFFF,   // 0x01E0 (480)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x01F0 (496)
0xFFFF, 0xFFFF, 0xFFFF, 0xDEDB, 0xAD55, 0xB596, 0x8C71, 0x632C, 0x5AEB, 0x6B6D, 0xDF1C, 0xECAE, 0xE1E1, 0xE243, 0xE243, 0xE243,   // 0x0200 (512)
0xE222, 0xE264, 0xFF1B, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0210 (528)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xB596, 0x52AA, 0x630C, 0x6B4D, 0x632C, 0x5AEB, 0x6B6D, 0xDF1C, 0xECAE,   // 0x0220 (544)
0xE1E1, 0xE243, 0xE243, 0xE243, 0xE222, 0xE264, 0xFF1B, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0230 (560)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xBDD7, 0x630C, 0x630C, 0x632C, 0x0000,   // 0x0240 (576)
0x5AEB, 0x6B6D, 0xDF3C, 0xEC8D, 0xE1E1, 0xE243, 0xE243, 0xE243, 0xE222, 0xE264, 0xFF1B, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0250 (592)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xBDD7,   // 0x0260 (608)
0x5AEB, 0x52AA, 0x0000, 0x0000, 0x5AEB, 0x6B6D, 0xDF3C, 0xECEF, 0xD9A0, 0xDA02, 0xDA02, 0xDA02, 0xE1E1, 0xDA22, 0xFF1A, 0xFFFF,   // 0x0270 (624)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0280 (640)
0xFFFF, 0xFFFF, 0xFFFF, 0xBDF7, 0x630C, 0x5ACB, 0x0000, 0x0000, 0x630C, 0x6B6D, 0xCE9A, 0xFFFF, 0xF677, 0xFE57, 0xFE57, 0xFE57,   // 0x0290 (656)
0xFE57, 0xF677, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x02A0 (672)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xAD55, 0x630C, 0x52AA, 0x0000, 0x0000, 0x5AEB, 0x632C, 0x83EF, 0xBDD7,   // 0x02B0 (688)
0xC679, 0xC659, 0xC659, 0xC659, 0xC659, 0xC659, 0xBE18, 0xBDF7, 0xBDF7, 0xBDF7, 0xBDF7, 0xBDF7, 0xBDF7, 0xBDF7, 0xBDF7, 0xBDF7,   // 0x02C0 (704)
0xBDF7, 0xBDF7, 0xBDF7, 0xBDF7, 0xBDF7, 0xBDF7, 0xBDF7, 0xBDF7, 0xBDF7, 0xC618, 0xAD75, 0x7BCF, 0x632C, 0x52AA, 0x0000, 0x0000,   // 0x02D0 (720)
0x0000, 0x632C, 0x6B4D, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C,   // 0x02E0 (736)
0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x6B4D,   // 0x02F0 (752)
0x632C, 0x0000, 0x0000, 0x0000, };
First.c
// Generated from: FirstQuarter.jpg
// Time generated: 17/06/2022 8:17:42 AM
// Dimensions    : 95x95 pixels
// Size          : 18,050 Bytes
const unsigned int First[0x2341] PROGMEM ={
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0010 (16)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0020 (32)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0030 (48)
0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0040 (64)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0050 (80)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0060 (96)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0070 (112)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0080 (128)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x1082, 0x18C3, 0x18E3,   // 0x0090 (144)
0x2124, 0x2965, 0x31A6, 0x39E7, 0x39C7, 0x31A6, 0x2965, 0x2104, 0x10A2, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x00A0 (160)
0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00B0 (176)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00C0 (192)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00D0 (208)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00E0 (224)
0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0020, 0x0841, 0x0861, 0x1082, 0x10A2, 0x18E3, 0x2124, 0x3186, 0x39C7,   // 0x00F0 (240)
0x4228, 0x4A69, 0x5AEB, 0x6B4D, 0x6B6D, 0x6B6D, 0x6B6D, 0x632C, 0x5ACB, 0x4A49, 0x3186, 0x18C3, 0x0841, 0x0000, 0x0000, 0x0000,   // 0x0100 (256)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0110 (272)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0120 (288)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0130 (304)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0140 (320)
0x0000, 0x0020, 0x0020, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0861, 0x10A2, 0x18C3, 0x18E3, 0x2945, 0x31A6, 0x39E7, 0x4208,   // 0x0150 (336)
0x4228, 0x528A, 0x630C, 0x6B4D, 0x738E, 0x7BCF, 0x7BCF, 0x7BEF, 0x7BEF, 0x7BCF, 0x6B6D, 0x5ACB, 0x39E7, 0x18E3, 0x0020, 0x0000,   // 0x0160 (352)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0170 (368)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0180 (384)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0190 (400)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0020,   // 0x01A0 (416)
0x0020, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0861, 0x1082, 0x10A2, 0x18E3, 0x2104, 0x2945, 0x31A6, 0x4208, 0x4A69, 0x528A,   // 0x01B0 (432)
0x528A, 0x5AEB, 0x6B4D, 0x738E, 0x73AE, 0x73AE, 0x7BEF, 0x8410, 0x8410, 0x8410, 0x8410, 0x7BEF, 0x6B6D, 0x528A, 0x2945, 0x0841,   // 0x01C0 (448)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x01D0 (464)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x01E0 (480)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x01F0 (496)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020,   // 0x0200 (512)
0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x1082, 0x18C3, 0x18E3, 0x2104, 0x2945, 0x31A6, 0x4A49, 0x630C, 0x6B4D, 0x6B4D,   // 0x0210 (528)
0x738E, 0x7BCF, 0x8430, 0x8430, 0x7BEF, 0x73AE, 0x7BCF, 0x8410, 0x8410, 0x8410, 0x8410, 0x8410, 0x7BEF, 0x738E, 0x5ACB, 0x3186,   // 0x0220 (544)
0x0861, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0230 (560)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0240 (576)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0250 (592)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0841, 0x0841,   // 0x0260 (608)
0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x10A2, 0x18C3, 0x18E3, 0x2124, 0x31A6, 0x4228, 0x52AA, 0x630C, 0x73AE, 0x8410, 0x8C51,   // 0x0270 (624)
0x8C71, 0x94B2, 0x94B2, 0x9492, 0x8C71, 0x8410, 0x7BEF, 0x8410, 0x8430, 0x8410, 0x8410, 0x8410, 0x8410, 0x7BEF, 0x73AE, 0x5AEB,   // 0x0280 (640)
0x3186, 0x0841, 0x0000, 0x0000, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0290 (656)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x02A0 (672)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x02B0 (688)
0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x02C0 (704)
0x0841, 0x0861, 0x0861, 0x1082, 0x10A2, 0x18C3, 0x2124, 0x2965, 0x39E7, 0x4A69, 0x52AA, 0x630C, 0x73AE, 0x8410, 0x9492, 0x9CF3,   // 0x02D0 (720)
0x9CF3, 0xA514, 0xA534, 0xA514, 0x9CD3, 0x94B2, 0x9492, 0x9492, 0x8430, 0x7BEF, 0x7BEF, 0x8410, 0x8430, 0x8410, 0x8410, 0x7BCF,   // 0x02E0 (736)
0x52AA, 0x2124, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x02F0 (752)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0300 (768)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0310 (784)
0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0841, 0x0861,   // 0x0320 (800)
0x0861, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x2945, 0x3186, 0x39E7, 0x4A49, 0x5ACB, 0x6B4D, 0x73AE, 0x8C51, 0x9492, 0x8C51, 0x8C51,   // 0x0330 (816)
0x9CD3, 0xA534, 0xA514, 0xA514, 0x9CF3, 0x9CF3, 0x94B2, 0x8C71, 0x8430, 0x7BEF, 0x7BEF, 0x8410, 0x8430, 0x8430, 0x8430, 0x8430,   // 0x0340 (832)
0x738E, 0x4208, 0x1082, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0350 (848)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0360 (864)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020,   // 0x0370 (880)
0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082,   // 0x0380 (896)
0x1082, 0x10A2, 0x18C3, 0x18E3, 0x2124, 0x3186, 0x39E7, 0x4A69, 0x5AEB, 0x6B4D, 0x7BCF, 0x8430, 0x7BEF, 0x73AE, 0x7BCF, 0x8410,   // 0x0390 (912)
0x8C71, 0x9CD3, 0xA514, 0xA514, 0xA514, 0x9CF3, 0x9CD3, 0x9492, 0x8430, 0x7BEF, 0x7BEF, 0x8410, 0x8410, 0x8410, 0x8430, 0x8430,   // 0x03A0 (928)
0x7BEF, 0x630C, 0x2104, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x03B0 (944)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x03C0 (960)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020,   // 0x03D0 (976)
0x0020, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x03E0 (992)
0x10A2, 0x18C3, 0x18E3, 0x2124, 0x3186, 0x39E7, 0x4A49, 0x528A, 0x5ACB, 0x630C, 0x738E, 0x73AE, 0x73AE, 0x7BEF, 0x8C51, 0x8C51,   // 0x03F0 (1008)
0x8C71, 0xA534, 0xA534, 0xAD55, 0xA514, 0xA514, 0x9CD3, 0x94B2, 0x8C51, 0x8410, 0x8410, 0x7BEF, 0x8410, 0x8430, 0x8430, 0x8430,   // 0x0400 (1024)
0x8430, 0x738E, 0x39C7, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0410 (1040)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0420 (1056)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020,   // 0x0430 (1072)
0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2,   // 0x0440 (1088)
0x18C3, 0x2104, 0x2124, 0x2945, 0x3186, 0x39E7, 0x4A49, 0x52AA, 0x630C, 0x6B4D, 0x6B6D, 0x738E, 0x7BCF, 0x8430, 0x8430, 0x8430,   // 0x0450 (1104)
0x9492, 0x9492, 0x9492, 0x94B2, 0x9CD3, 0x9CF3, 0xA534, 0xA514, 0x8C51, 0x8C51, 0x8410, 0x7BEF, 0x8430, 0x8C51, 0x8C51, 0x8C51,   // 0x0460 (1120)
0x8C51, 0x7BCF, 0x4A49, 0x0861, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0470 (1136)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0480 (1152)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x0490 (1168)
0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x1082, 0x10A2, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3,   // 0x04A0 (1184)
0x2104, 0x2124, 0x2945, 0x3186, 0x4208, 0x4A69, 0x5ACB, 0x632C, 0x6B6D, 0x738E, 0x73AE, 0x73AE, 0x7BEF, 0x7BEF, 0x7BCF, 0x7BEF,   // 0x04B0 (1200)
0x7BEF, 0x8430, 0x9492, 0x9492, 0x8430, 0x9CD3, 0xB596, 0xAD55, 0x9CF3, 0x9492, 0x8430, 0x7BEF, 0x8410, 0x8430, 0x8C51, 0x8C51,   // 0x04C0 (1216)
0x8410, 0x7BEF, 0x528A, 0x1082, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x04D0 (1232)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x04E0 (1248)
0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0841, 0x0841, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x04F0 (1264)
0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x10A2, 0x18C3, 0x18E3,   // 0x0500 (1280)
0x2124, 0x2965, 0x31A6, 0x4228, 0x528A, 0x5AEB, 0x632C, 0x6B4D, 0x738E, 0x738E, 0x73AE, 0x7BEF, 0x8410, 0x7BEF, 0x7BEF, 0x8410,   // 0x0510 (1296)
0x8430, 0x8C71, 0x8C51, 0x8C51, 0x94B2, 0xA534, 0xA534, 0x9CF3, 0xA534, 0x9CD3, 0x8430, 0x73AE, 0x8410, 0x8C51, 0x8430, 0x8410,   // 0x0520 (1312)
0x7BEF, 0x73AE, 0x528A, 0x10A2, 0x0000, 0x0000, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0530 (1328)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0540 (1344)
0x0000, 0x0000, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x0550 (1360)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x2104, 0x2945,   // 0x0560 (1376)
0x2965, 0x31A6, 0x4228, 0x528A, 0x5ACB, 0x632C, 0x6B6D, 0x738E, 0x73AE, 0x73AE, 0x7BEF, 0x8410, 0x8410, 0x8410, 0x8410, 0x8C71,   // 0x0570 (1392)
0x8C71, 0x8C51, 0x9492, 0xA514, 0x9CF3, 0x9CD3, 0x8C51, 0x9CD3, 0xA534, 0x9CF3, 0x8430, 0x7BEF, 0x8410, 0x8430, 0x8430, 0x8410,   // 0x0580 (1408)
0x7BCF, 0x73AE, 0x52AA, 0x10A2, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0590 (1424)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x05A0 (1440)
0x0020, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861,   // 0x05B0 (1456)
0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x2104, 0x2945, 0x3186,   // 0x05C0 (1472)
0x31A6, 0x4208, 0x4A69, 0x52AA, 0x630C, 0x6B6D, 0x73AE, 0x7BCF, 0x7BCF, 0x7BEF, 0x8410, 0x8430, 0x8430, 0x8430, 0x8C71, 0x8C71,   // 0x05D0 (1488)
0x8C71, 0x9492, 0x9CF3, 0x9CD3, 0x9CD3, 0x9CD3, 0xA514, 0xA534, 0xA534, 0x9CD3, 0x8C71, 0x8430, 0x8C51, 0x8C51, 0x8430, 0x7BEF,   // 0x05E0 (1504)
0x7BEF, 0x73AE, 0x52AA, 0x10A2, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x05F0 (1520)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0861,   // 0x0600 (1536)
0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861,   // 0x0610 (1552)
0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18E3, 0x2124, 0x2965, 0x31A6,   // 0x0620 (1568)
0x4208, 0x4A69, 0x52AA, 0x5AEB, 0x6B4D, 0x73AE, 0x7BCF, 0x7BCF, 0x7BEF, 0x8430, 0x8C51, 0x8430, 0x8C51, 0x8C71, 0x8C71, 0x8C71,   // 0x0630 (1584)
0x9492, 0x9492, 0x9CD3, 0x9492, 0x9CD3, 0xAD55, 0xA534, 0xAD75, 0xB596, 0x9CD3, 0x8430, 0x8430, 0x8C51, 0x8430, 0x8410, 0x8410,   // 0x0640 (1600)
0x7BCF, 0x738E, 0x4A69, 0x0861, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0650 (1616)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861,   // 0x0660 (1632)
0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0670 (1648)
0x0861, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18E3, 0x2124, 0x2945, 0x31A6, 0x4228,   // 0x0680 (1664)
0x528A, 0x5ACB, 0x630C, 0x6B4D, 0x738E, 0x7BCF, 0x7BEF, 0x8410, 0x8C51, 0x8C71, 0x8C51, 0x8C71, 0x9492, 0x94B2, 0x94B2, 0x9492,   // 0x0690 (1680)
0x9492, 0x9492, 0x94B2, 0x9492, 0xA534, 0xB596, 0xB596, 0xBDD7, 0x9CF3, 0x8C51, 0x8C71, 0x8C71, 0x8C51, 0x8410, 0x8430, 0x7BEF,   // 0x06A0 (1696)
0x738E, 0x6B6D, 0x4228, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x06B0 (1712)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x06C0 (1728)
0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x06D0 (1744)
0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18E3, 0x2945, 0x2945, 0x31A6, 0x4228, 0x528A,   // 0x06E0 (1760)
0x5AEB, 0x632C, 0x738E, 0x7BCF, 0x7BCF, 0x7BCF, 0x8430, 0x8C71, 0x8C71, 0x8C71, 0x9492, 0x94B2, 0x94B2, 0x9492, 0x9492, 0x9492,   // 0x06F0 (1776)
0x9492, 0x9492, 0x94B2, 0x9CF3, 0xB596, 0xBDD7, 0xBDD7, 0xAD55, 0x9CF3, 0x94B2, 0x8C71, 0x8C71, 0x8410, 0x8410, 0x7BEF, 0x73AE,   // 0x0700 (1792)
0x73AE, 0x6B4D, 0x31A6, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0710 (1808)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x1082, 0x1082, 0x0861, 0x0841,   // 0x0720 (1824)
0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082,   // 0x0730 (1840)
0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x18E3, 0x2124, 0x2945, 0x2945, 0x31A6, 0x4228, 0x528A, 0x5AEB,   // 0x0740 (1856)
0x6B4D, 0x73AE, 0x7BCF, 0x7BEF, 0x8410, 0x8C51, 0x8C71, 0x8C71, 0x8C71, 0x9492, 0x94B2, 0x94B2, 0x9492, 0x9492, 0x9492, 0x94B2,   // 0x0750 (1872)
0x94B2, 0x9CD3, 0x9CD3, 0xAD55, 0xB5B6, 0xB5B6, 0xB5B6, 0xAD55, 0x9CD3, 0x9492, 0x8C71, 0x8430, 0x8410, 0x8410, 0x7BEF, 0x73AE,   // 0x0760 (1888)
0x6B6D, 0x630C, 0x2945, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0770 (1904)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841,   // 0x0780 (1920)
0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082,   // 0x0790 (1936)
0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18E3, 0x2124, 0x2945, 0x2945, 0x39C7, 0x4228, 0x4A69, 0x5AEB, 0x6B4D,   // 0x07A0 (1952)
0x738E, 0x73AE, 0x8410, 0x8C51, 0x8C51, 0x8C71, 0x8C51, 0x8C71, 0x9492, 0x94B2, 0x9492, 0x9492, 0x94B2, 0x9CD3, 0x9CD3, 0x9CF3,   // 0x07B0 (1968)
0x9CD3, 0x9CD3, 0xB596, 0xB596, 0xB5B6, 0xB5B6, 0xAD75, 0x9CF3, 0x9CF3, 0x9492, 0x8C51, 0x8430, 0x7BEF, 0x7BEF, 0x7BCF, 0x73AE,   // 0x07C0 (1984)
0x6B6D, 0x5ACB, 0x18C3, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x07D0 (2000)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x07E0 (2016)
0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x07F0 (2032)
0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18E3, 0x2104, 0x2945, 0x2965, 0x39E7, 0x4A49, 0x528A, 0x5AEB, 0x6B4D, 0x6B6D,   // 0x0800 (2048)
0x73AE, 0x8C51, 0x8C71, 0x8430, 0x8C71, 0x9492, 0x9492, 0x94B2, 0x94B2, 0x9492, 0x9492, 0x9CD3, 0xA514, 0xA514, 0xA514, 0xA534,   // 0x0810 (2064)
0xA514, 0xB596, 0xBDD7, 0xBDF7, 0xBDD7, 0xAD75, 0x9CF3, 0x9CF3, 0x94B2, 0x8C71, 0x8430, 0x7BCF, 0x7BCF, 0x7BCF, 0x73AE, 0x73AE,   // 0x0820 (2080)
0x6B6D, 0x4A49, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0830 (2096)
0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861,   // 0x0840 (2112)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x0850 (2128)
0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18E3, 0x2104, 0x2945, 0x3186, 0x39C7, 0x4A49, 0x528A, 0x630C, 0x632C, 0x6B6D, 0x7BEF,   // 0x0860 (2144)
0x8C51, 0x8C51, 0x8C51, 0x8C71, 0x94B2, 0x94B2, 0x9492, 0x9492, 0x8C71, 0x94B2, 0xA514, 0xA514, 0xAD55, 0xAD75, 0xAD75, 0xA534,   // 0x0870 (2160)
0xB596, 0xB5B6, 0xBDF7, 0xBDD7, 0xB596, 0xA534, 0xA514, 0x9CF3, 0xA514, 0x94B2, 0x8410, 0x7BCF, 0x738E, 0x738E, 0x73AE, 0x738E,   // 0x0880 (2176)
0x632C, 0x3186, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0890 (2192)
0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861,   // 0x08A0 (2208)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x1082, 0x1082,   // 0x08B0 (2224)
0x1082, 0x18C3, 0x18E3, 0x18C3, 0x2104, 0x2124, 0x2945, 0x3186, 0x39C7, 0x4A49, 0x52AA, 0x632C, 0x6B4D, 0x73AE, 0x8410, 0x8430,   // 0x08C0 (2240)
0x8C71, 0x9CD3, 0x94B2, 0x9492, 0x9492, 0x9492, 0x9492, 0x8C71, 0x9CD3, 0xA514, 0xA514, 0xAD55, 0xAD75, 0xAD75, 0xAD55, 0xAD75,   // 0x08D0 (2256)
0xB5B6, 0xBDF7, 0xBDF7, 0xB5B6, 0xAD75, 0xAD55, 0xA514, 0xA534, 0xA534, 0x9492, 0x8410, 0x73AE, 0x6B6D, 0x6B4D, 0x738E, 0x73AE,   // 0x08E0 (2272)
0x5AEB, 0x10A2, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x08F0 (2288)
0x0020, 0x0841, 0x0861, 0x0841, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861,   // 0x0900 (2304)
0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x10A2,   // 0x0910 (2320)
0x18C3, 0x18E3, 0x18E3, 0x2104, 0x2124, 0x2965, 0x3186, 0x39C7, 0x4A69, 0x52AA, 0x632C, 0x6B6D, 0x7BCF, 0x7BEF, 0x8410, 0x9CD3,   // 0x0920 (2336)
0xAD55, 0xA514, 0x9492, 0x9492, 0x9492, 0x94B2, 0x94B2, 0x94B2, 0x9CD3, 0xA534, 0xAD55, 0xA534, 0xAD55, 0xAD75, 0xAD75, 0xBDD7,   // 0x0930 (2352)
0xBDD7, 0xBDF7, 0xB5B6, 0xB596, 0xB596, 0xA534, 0x9CF3, 0xA514, 0x94B2, 0x8C51, 0x7BEF, 0x6B6D, 0x632C, 0x6B6D, 0x73AE, 0x6B6D,   // 0x0940 (2368)
0x39E7, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x0950 (2384)
0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0960 (2400)
0x0841, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x1082, 0x10A2, 0x18C3, 0x18C3,   // 0x0970 (2416)
0x18C3, 0x18E3, 0x2104, 0x2945, 0x2945, 0x3186, 0x39C7, 0x4A49, 0x528A, 0x630C, 0x738E, 0x7BCF, 0x7BCF, 0x8410, 0x8C71, 0x9CD3,   // 0x0980 (2432)
0x9CF3, 0x9CF3, 0x9CF3, 0x9CF3, 0xA514, 0xA534, 0xA534, 0xA514, 0xA534, 0xAD75, 0xB5B6, 0xAD55, 0xA514, 0xAD75, 0xB596, 0xB596,   // 0x0990 (2448)
0xBDF7, 0xBDD7, 0xBDF7, 0xBDD7, 0xBDD7, 0xAD55, 0xA514, 0x9CD3, 0x8C71, 0x8410, 0x73AE, 0x6B4D, 0x6B4D, 0x738E, 0x73AE, 0x630C,   // 0x09A0 (2464)
0x18C3, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861,   // 0x09B0 (2480)
0x0841, 0x0861, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x09C0 (2496)
0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18C3,   // 0x09D0 (2512)
0x18E3, 0x2124, 0x2945, 0x2965, 0x3186, 0x39E7, 0x4A49, 0x52AA, 0x630C, 0x738E, 0x73AE, 0x7BEF, 0x8C51, 0x8C71, 0x9492, 0x94B2,   // 0x09E0 (2528)
0xAD55, 0xB596, 0xB596, 0xB596, 0xAD55, 0xAD75, 0xAD75, 0xAD55, 0xAD75, 0xBDD7, 0xAD75, 0xA534, 0xB596, 0xBDD7, 0xBDF7, 0xC638,   // 0x09F0 (2544)
0xC638, 0xBDF7, 0xBDD7, 0xBDF7, 0xB5B6, 0xAD75, 0xA534, 0x9CD3, 0x8C71, 0x8410, 0x73AE, 0x632C, 0x6B6D, 0x73AE, 0x738E, 0x39E7,   // 0x0A00 (2560)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861,   // 0x0A10 (2576)
0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0861, 0x0841, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861,   // 0x0A20 (2592)
0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x18E3,   // 0x0A30 (2608)
0x2124, 0x2965, 0x3186, 0x39C7, 0x4208, 0x4A49, 0x5AEB, 0x6B4D, 0x738E, 0x7BCF, 0x8410, 0x8C51, 0x8C71, 0x8C51, 0x9492, 0xAD55,   // 0x0A40 (2624)
0xB596, 0xB5B6, 0xB5B6, 0xAD75, 0xAD75, 0xB5B6, 0xB596, 0xB5B6, 0xAD75, 0xA534, 0xA514, 0xAD55, 0xBDD7, 0xC618, 0xC638, 0xC638,   // 0x0A50 (2640)
0xBDD7, 0xB596, 0xB5B6, 0xB596, 0xB596, 0xA534, 0x9CD3, 0x94B2, 0x8C71, 0x7BEF, 0x738E, 0x73AE, 0x738E, 0x73AE, 0x5ACB, 0x10A2,   // 0x0A60 (2656)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0841, 0x0861, 0x1082, 0x1082,   // 0x0A70 (2672)
0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861,   // 0x0A80 (2688)
0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2124,   // 0x0A90 (2704)
0x2965, 0x31A6, 0x39E7, 0x4228, 0x528A, 0x630C, 0x6B4D, 0x738E, 0x7BEF, 0x8430, 0x8C51, 0x8C71, 0x8C51, 0x8C71, 0xAD55, 0xB596,   // 0x0AA0 (2720)
0xB5B6, 0xB5B6, 0xAD75, 0xA534, 0xB596, 0xB5B6, 0xBDD7, 0xB596, 0xAD55, 0xA534, 0xAD55, 0xBDF7, 0xC638, 0xBDD7, 0xBDD7, 0xB5B6,   // 0x0AB0 (2736)
0xBDD7, 0xB5B6, 0xB596, 0xAD75, 0xA534, 0x94B2, 0x9492, 0x8C51, 0x7BEF, 0x8410, 0x7BEF, 0x7BCF, 0x738E, 0x6B6D, 0x3186, 0x0000,   // 0x0AC0 (2752)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082,   // 0x0AD0 (2768)
0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082,   // 0x0AE0 (2784)
0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2124, 0x2965,   // 0x0AF0 (2800)
0x31A6, 0x39E7, 0x4228, 0x52AA, 0x630C, 0x6B6D, 0x73AE, 0x7BEF, 0x8430, 0x9492, 0x94B2, 0x94B2, 0x9492, 0x9CF3, 0xB596, 0xB5B6,   // 0x0B00 (2816)
0xB5B6, 0xB596, 0xA534, 0xAD55, 0xBDD7, 0xB5B6, 0xB596, 0xA534, 0xAD75, 0xB5B6, 0xBDF7, 0xB596, 0x9CD3, 0x94B2, 0x9CF3, 0xB5B6,   // 0x0B10 (2832)
0xBDD7, 0xB596, 0xA534, 0xA514, 0x9CD3, 0x94B2, 0x8C71, 0x8C51, 0x8C51, 0x8430, 0x7BEF, 0x738E, 0x6B6D, 0x4A69, 0x0861, 0x0000,   // 0x0B20 (2848)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x1082, 0x0861,   // 0x0B30 (2864)
0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082,   // 0x0B40 (2880)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x2945, 0x2945, 0x3186, 0x3186,   // 0x0B50 (2896)
0x39E7, 0x4A49, 0x52AA, 0x632C, 0x73AE, 0x7BEF, 0x8430, 0x8C71, 0x94B2, 0x9492, 0x8C71, 0x8C71, 0x8C71, 0xA514, 0xB596, 0xB5B6,   // 0x0B60 (2912)
0xB596, 0xA534, 0x9CD3, 0xAD75, 0xB5B6, 0xAD55, 0xA514, 0xAD55, 0xAD75, 0xAD55, 0x9492, 0x9492, 0x8C71, 0x8C51, 0xA514, 0xB5B6,   // 0x0B70 (2928)
0xB596, 0xA514, 0x9CD3, 0x9CD3, 0x94B2, 0x94B2, 0x9492, 0x8C51, 0x8430, 0x7BEF, 0x73AE, 0x6B6D, 0x5ACB, 0x2104, 0x0000, 0x0000,   // 0x0B80 (2944)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0841,   // 0x0B90 (2960)
0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861,   // 0x0BA0 (2976)
0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2124, 0x2945, 0x3186, 0x3186, 0x39E7,   // 0x0BB0 (2992)
0x4A49, 0x5ACB, 0x632C, 0x73AE, 0x8410, 0x8C51, 0x94B2, 0x9492, 0x9492, 0x9492, 0x9492, 0x8C71, 0xA514, 0xBDD7, 0xBDF7, 0xB5B6,   // 0x0BC0 (3008)
0xAD55, 0x9CF3, 0xA514, 0xBDF7, 0xBDD7, 0xA534, 0x9CD3, 0x9CF3, 0x94B2, 0x8C51, 0x9492, 0x9492, 0x8C71, 0x8C71, 0xAD55, 0xB596,   // 0x0BD0 (3024)
0xA534, 0x9492, 0x9492, 0xA514, 0xA514, 0x9492, 0x8C51, 0x8C51, 0x8430, 0x73AE, 0x6B6D, 0x632C, 0x39E7, 0x0020, 0x0000, 0x0000,   // 0x0BE0 (3040)
0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x1082,   // 0x0BF0 (3056)
0x0861, 0x0841, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0C00 (3072)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2124, 0x2965, 0x3186, 0x39E7, 0x4A49,   // 0x0C10 (3088)
0x5ACB, 0x632C, 0x73AE, 0x8410, 0x8410, 0x9492, 0x9CF3, 0xAD55, 0xAD55, 0xA534, 0xAD55, 0xB5B6, 0xBDF7, 0xC638, 0xC638, 0xC618,   // 0x0C20 (3104)
0xBDD7, 0xB5B6, 0xBDD7, 0xB5B6, 0xAD55, 0x94B2, 0x94B2, 0x9492, 0x8430, 0x8430, 0x8C71, 0x9492, 0x8C71, 0x9CD3, 0xAD55, 0x9CF3,   // 0x0C30 (3120)
0x8C71, 0x94B2, 0x9CD3, 0x9CF3, 0x94B2, 0x8C51, 0x8430, 0x8430, 0x7BEF, 0x738E, 0x6B4D, 0x52AA, 0x1082, 0x0000, 0x0000, 0x0000,   // 0x0C40 (3136)
0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861,   // 0x0C50 (3152)
0x0841, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082,   // 0x0C60 (3168)
0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x2104, 0x2945, 0x3186, 0x39E7, 0x4A49, 0x52AA,   // 0x0C70 (3184)
0x632C, 0x738E, 0x7BEF, 0x8410, 0x8430, 0x94B2, 0xAD55, 0xB596, 0xB5B6, 0xB5B6, 0xBDF7, 0xBDF7, 0xC638, 0xCE79, 0xC638, 0xBDF7,   // 0x0C80 (3200)
0xC638, 0xB5B6, 0xAD75, 0x9CF3, 0x8C71, 0x94B2, 0x94B2, 0x8C51, 0x8C51, 0x8C71, 0x8C71, 0x8C71, 0x94B2, 0xA534, 0xA534, 0x94B2,   // 0x0C90 (3216)
0x9CD3, 0x9492, 0x94B2, 0x94B2, 0x8C71, 0x8430, 0x8410, 0x7BEF, 0x7BCF, 0x6B4D, 0x5AEB, 0x2945, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0CA0 (3232)
0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861,   // 0x0CB0 (3248)
0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x0CC0 (3264)
0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x18C3, 0x18E3, 0x2104, 0x2945, 0x2965, 0x31A6, 0x4A49, 0x52AA, 0x632C,   // 0x0CD0 (3280)
0x6B4D, 0x7BCF, 0x8410, 0x8430, 0x8C71, 0xA534, 0xAD75, 0xB596, 0xBDD7, 0xBDF7, 0xBDD7, 0xBDF7, 0xC618, 0xBDF7, 0xBDD7, 0xBDD7,   // 0x0CE0 (3296)
0xB596, 0xA514, 0x8C71, 0x8C71, 0x94B2, 0x94B2, 0x8C71, 0x8C71, 0x8C51, 0x8C51, 0x8C51, 0x8C71, 0x94B2, 0x9CF3, 0x94B2, 0x94B2,   // 0x0CF0 (3312)
0x94B2, 0x9CD3, 0x94B2, 0x8C71, 0x8C51, 0x7BEF, 0x7BEF, 0x7BEF, 0x6B6D, 0x5AEB, 0x39C7, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0D00 (3328)
0x0000, 0x0841, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082,   // 0x0D10 (3344)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x0D20 (3360)
0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2945, 0x31A6, 0x4228, 0x52AA, 0x630C, 0x6B4D,   // 0x0D30 (3376)
0x738E, 0x7BEF, 0x8410, 0x8C51, 0x9CD3, 0xA534, 0xAD75, 0xBDD7, 0xB5B6, 0xBDD7, 0xB596, 0xB5B6, 0xB5B6, 0xB596, 0xAD55, 0x9CD3,   // 0x0D40 (3392)
0x8C51, 0x8C51, 0x8C71, 0x8C71, 0x8C71, 0x8C51, 0x8C51, 0x8C51, 0x8C51, 0x8430, 0x8C51, 0x8C71, 0x9492, 0x8C51, 0x8C51, 0x9492,   // 0x0D50 (3408)
0x9CD3, 0x9492, 0x8C51, 0x8C71, 0x8410, 0x7BEF, 0x7BEF, 0x6B6D, 0x5AEB, 0x4A49, 0x0861, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x0D60 (3424)
0x0841, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x0D70 (3440)
0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x0D80 (3456)
0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2945, 0x31A6, 0x4228, 0x52AA, 0x5ACB, 0x632C, 0x6B6D,   // 0x0D90 (3472)
0x7BCF, 0x8410, 0x7BEF, 0x8410, 0x94B2, 0xAD55, 0xAD55, 0xA534, 0xAD55, 0xA534, 0xAD75, 0xAD55, 0xAD55, 0x9CF3, 0x8C71, 0x8410,   // 0x0DA0 (3488)
0x8430, 0x8430, 0x8C51, 0x8C71, 0x8C51, 0x8C71, 0x8C71, 0x8430, 0x8430, 0x8C71, 0x8C71, 0x8C51, 0x8C51, 0x8C71, 0x9CD3, 0x9492,   // 0x0DB0 (3504)
0x8430, 0x8410, 0x8C51, 0x8C71, 0x8410, 0x7BEF, 0x6B6D, 0x5AEB, 0x528A, 0x18E3, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841,   // 0x0DC0 (3520)
0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2,   // 0x0DD0 (3536)
0x1082, 0x0841, 0x0861, 0x0841, 0x0861, 0x1082, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082,   // 0x0DE0 (3552)
0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x18E3, 0x2104, 0x2945, 0x3186, 0x4208, 0x4A69, 0x52AA, 0x5AEB, 0x6B6D, 0x7BCF,   // 0x0DF0 (3568)
0x73AE, 0x738E, 0x73AE, 0x8C71, 0x9CF3, 0x9CD3, 0x94B2, 0x9CD3, 0x9CF3, 0xAD75, 0xA534, 0xA514, 0x9CD3, 0x9492, 0x8410, 0x8C51,   // 0x0E00 (3584)
0x8410, 0x8C51, 0x8C71, 0x8C51, 0x8C71, 0x8C71, 0x8C51, 0x8C71, 0x9492, 0x8C51, 0x8430, 0x8C51, 0x9CD3, 0xA514, 0x9492, 0x8410,   // 0x0E10 (3600)
0x7BEF, 0x9492, 0x9492, 0x8430, 0x7BEF, 0x738E, 0x630C, 0x52AA, 0x2965, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861,   // 0x0E20 (3616)
0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082,   // 0x0E30 (3632)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082,   // 0x0E40 (3648)
0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2124, 0x2945, 0x31A6, 0x39C7, 0x39E7, 0x4A49, 0x5ACB, 0x738E, 0x7BEF, 0x7BEF,   // 0x0E50 (3664)
0x7BEF, 0x8410, 0x94B2, 0x94B2, 0x9CD3, 0x9CD3, 0x94B2, 0x94B2, 0xA514, 0xA534, 0xA514, 0x9CF3, 0x94B2, 0x8430, 0x8C51, 0x8C51,   // 0x0E60 (3680)
0x8C71, 0x8C71, 0x8C51, 0x8C51, 0x9492, 0x8C71, 0x8C71, 0x8C71, 0x8C51, 0x8410, 0x8C51, 0xAD75, 0xAD75, 0x94B2, 0x8430, 0x8430,   // 0x0E70 (3696)
0x9CD3, 0x9492, 0x8C51, 0x8410, 0x738E, 0x6B4D, 0x5AEB, 0x31A6, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x1082, 0x10A2,   // 0x0E80 (3712)
0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x0861,   // 0x0E90 (3728)
0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2,   // 0x0EA0 (3744)
0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2124, 0x2945, 0x3186, 0x31A6, 0x39C7, 0x4228, 0x5ACB, 0x6B6D, 0x8410, 0x94B2, 0x9CD3,   // 0x0EB0 (3760)
0x9CD3, 0x9CF3, 0x94B2, 0x9492, 0x94B2, 0x9CD3, 0x9492, 0x9492, 0x9CF3, 0x9CF3, 0x94B2, 0x9CD3, 0x9CD3, 0x9492, 0x8C51, 0x8C51,   // 0x0EC0 (3776)
0x8C51, 0x8C51, 0x9492, 0x94B2, 0x9492, 0x8C71, 0x8430, 0x8410, 0x7BEF, 0x8C51, 0xAD75, 0xB5B6, 0x9CD3, 0x8C71, 0x9492, 0x9492,   // 0x0ED0 (3792)
0x94B2, 0x8430, 0x7BEF, 0x6B6D, 0x6B4D, 0x5AEB, 0x39E7, 0x0020, 0x0000, 0x0000, 0x0000, 0x0841, 0x0841, 0x1082, 0x10A2, 0x10A2,   // 0x0EE0 (3808)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861,   // 0x0EF0 (3824)
0x0861, 0x0841, 0x0861, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2,   // 0x0F00 (3840)
0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2945, 0x3186, 0x39C7, 0x4208, 0x528A, 0x630C, 0x73AE, 0x8C71, 0x9CF3, 0xA534, 0xAD55,   // 0x0F10 (3856)
0xAD75, 0xA534, 0x8C71, 0x8C71, 0x9492, 0x8C71, 0x9492, 0x9CF3, 0xA534, 0x9CD3, 0x9CF3, 0xA534, 0x9492, 0x8430, 0x8C51, 0x8C71,   // 0x0F20 (3872)
0x9CD3, 0x9CD3, 0x9492, 0x8C71, 0x8430, 0x8410, 0x7BEF, 0x7BCF, 0x8410, 0xA534, 0xB596, 0xA514, 0xA514, 0x9CD3, 0x8C51, 0x94B2,   // 0x0F30 (3888)
0x8C51, 0x7BEF, 0x73AE, 0x6B6D, 0x630C, 0x4A49, 0x1082, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2,   // 0x0F40 (3904)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x0861, 0x1082, 0x1082, 0x0861, 0x0861,   // 0x0F50 (3920)
0x0861, 0x0861, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x0F60 (3936)
0x18C3, 0x18C3, 0x18E3, 0x2124, 0x2945, 0x3186, 0x39E7, 0x4228, 0x52AA, 0x632C, 0x7BCF, 0x9CD3, 0xAD55, 0xAD55, 0xAD75, 0xB596,   // 0x0F70 (3952)
0xAD75, 0x94B2, 0x8C71, 0x8C71, 0x8C71, 0x8C71, 0xA534, 0xCE59, 0xB5B6, 0xA514, 0xA514, 0x9CD3, 0x8C51, 0x8C71, 0x94B2, 0x9CD3,   // 0x0F80 (3968)
0x9492, 0x8430, 0x8430, 0x8410, 0x8430, 0x8410, 0x73AE, 0x7BEF, 0x9CF3, 0xAD75, 0xAD75, 0xAD75, 0xA534, 0x9CD3, 0x9CF3, 0x9492,   // 0x0F90 (3984)
0x8430, 0x7BCF, 0x6B6D, 0x630C, 0x528A, 0x18C3, 0x0000, 0x0000, 0x0020, 0x0841, 0x0841, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2,   // 0x0FA0 (4000)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861,   // 0x0FB0 (4016)
0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3,   // 0x0FC0 (4032)
0x18E3, 0x18E3, 0x2104, 0x2965, 0x31A6, 0x4208, 0x4A69, 0x52AA, 0x630C, 0x7BEF, 0x9492, 0xA514, 0xA534, 0xB5B6, 0xBDD7, 0xAD75,   // 0x0FD0 (4048)
0x9CF3, 0x9492, 0x8C51, 0x8410, 0x8C51, 0xA514, 0xBDF7, 0xB596, 0x9CF3, 0x9CD3, 0x9CF3, 0x8C71, 0x9492, 0x94B2, 0x94B2, 0x8C71,   // 0x0FE0 (4064)
0x8430, 0x8410, 0x8410, 0x8430, 0x8410, 0x7BCF, 0x7BEF, 0xA514, 0xB596, 0xB5B6, 0xAD75, 0xAD55, 0xA514, 0x9CF3, 0x9492, 0x8430,   // 0x0FF0 (4080)
0x7BCF, 0x73AE, 0x632C, 0x52AA, 0x18E3, 0x0000, 0x0000, 0x0020, 0x0841, 0x0841, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x1000 (4096)
0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x0861, 0x1082, 0x0861, 0x0861, 0x1082,   // 0x1010 (4112)
0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18E3,   // 0x1020 (4128)
0x2104, 0x2124, 0x3186, 0x39E7, 0x4228, 0x528A, 0x52AA, 0x632C, 0x7BCF, 0x8C71, 0x9CF3, 0xA534, 0xB596, 0xB5B6, 0xB596, 0xA534,   // 0x1030 (4144)
0x9CF3, 0x8C51, 0x7BEF, 0x9492, 0xA514, 0xAD55, 0xA514, 0x9492, 0x94B2, 0xB5B6, 0xB5B6, 0x8C71, 0x8C71, 0x8C71, 0x8C51, 0x8430,   // 0x1040 (4160)
0x8410, 0x8410, 0x8430, 0x7BEF, 0x7BEF, 0x8C71, 0xA534, 0xBDD7, 0xB5B6, 0xB596, 0xAD75, 0xA534, 0x9CD3, 0x9492, 0x8430, 0x7BCF,   // 0x1050 (4176)
0x738E, 0x6B4D, 0x5ACB, 0x2124, 0x0000, 0x0000, 0x0020, 0x0841, 0x0841, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x10A2,   // 0x1060 (4192)
0x10A2, 0x10A2, 0x1082, 0x0841, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082,   // 0x1070 (4208)
0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x18C3, 0x2104, 0x2945,   // 0x1080 (4224)
0x2965, 0x3186, 0x39E7, 0x4A49, 0x52AA, 0x5AEB, 0x6B4D, 0x73AE, 0x8430, 0x9CF3, 0xAD75, 0xAD55, 0xB596, 0xBDD7, 0xB596, 0xAD75,   // 0x1090 (4240)
0x9CD3, 0x8C71, 0x94B2, 0x94B2, 0x9CD3, 0xA514, 0xA514, 0xA514, 0xB596, 0xC638, 0x9CF3, 0x8C51, 0x8C51, 0x8C51, 0x8430, 0x8430,   // 0x10A0 (4256)
0x8430, 0x8430, 0x7BEF, 0x8430, 0xA514, 0xB596, 0xBDD7, 0xBDD7, 0xB596, 0xAD55, 0xA534, 0x9CF3, 0x94B2, 0x8C51, 0x7BEF, 0x73AE,   // 0x10B0 (4272)
0x6B6D, 0x5ACB, 0x2945, 0x0000, 0x0000, 0x0020, 0x0841, 0x0841, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2,   // 0x10C0 (4288)
0x10A2, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x10A2, 0x10A2,   // 0x10D0 (4304)
0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x2104, 0x2945, 0x3186,   // 0x10E0 (4320)
0x31A6, 0x4208, 0x4A69, 0x5ACB, 0x630C, 0x632C, 0x738E, 0x8430, 0x94B2, 0xAD55, 0xB596, 0xC618, 0xC638, 0xB5B6, 0xAD55, 0xAD55,   // 0x10F0 (4336)
0xA514, 0xA514, 0x9CF3, 0xA534, 0xAD55, 0xAD75, 0xB596, 0xAD55, 0xB596, 0xAD55, 0x9CF3, 0x8C51, 0x8410, 0x8430, 0x8C51, 0x8430,   // 0x1100 (4352)
0x7BEF, 0x8410, 0x94B2, 0xA514, 0xB596, 0xBDD7, 0xBDF7, 0xB5B6, 0xAD55, 0xA534, 0xA514, 0x9CD3, 0x8C51, 0x7BEF, 0x7BCF, 0x6B6D,   // 0x1110 (4368)
0x5ACB, 0x2965, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x0861,   // 0x1120 (4384)
0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x1130 (4400)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x2104, 0x2945, 0x3186, 0x31A6,   // 0x1140 (4416)
0x4228, 0x4A69, 0x5ACB, 0x630C, 0x630C, 0x738E, 0x8430, 0x94B2, 0xA534, 0xB5B6, 0xC618, 0xC638, 0xBDF7, 0xAD75, 0xB5B6, 0xAD75,   // 0x1150 (4432)
0xAD55, 0xBDD7, 0xB5B6, 0xB5B6, 0xBDD7, 0xBDD7, 0xA534, 0xA534, 0xA514, 0xA514, 0x9492, 0x8410, 0x7BEF, 0x8410, 0x7BEF, 0x7BEF,   // 0x1160 (4448)
0x8410, 0x9CF3, 0xAD75, 0xAD75, 0xB5B6, 0xBDF7, 0xB596, 0xAD55, 0xA534, 0xA514, 0x94B2, 0x8C51, 0x8410, 0x7BCF, 0x6B4D, 0x5ACB,   // 0x1170 (4464)
0x2965, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861,   // 0x1180 (4480)
0x0861, 0x0841, 0x0861, 0x0841, 0x0841, 0x0861, 0x1082, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082,   // 0x1190 (4496)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x1082, 0x18C3, 0x18E3, 0x2124, 0x2965, 0x31A6, 0x4228,   // 0x11A0 (4512)
0x4A69, 0x5ACB, 0x632C, 0x6B4D, 0x7BCF, 0x8C71, 0x9CD3, 0xAD75, 0xBDD7, 0xBDD7, 0xBDF7, 0xC618, 0xC638, 0xC618, 0xBDD7, 0xBDD7,   // 0x11B0 (4528)
0xBDF7, 0xBDF7, 0xB5B6, 0xB5B6, 0xAD55, 0x8C71, 0x9492, 0x8C51, 0x8430, 0x8C51, 0x94B2, 0x8430, 0x8C51, 0x8410, 0x8430, 0x9CD3,   // 0x11C0 (4544)
0xAD55, 0xAD75, 0xAD55, 0xAD75, 0xB596, 0xAD75, 0xAD75, 0x9CF3, 0x9CF3, 0x9CF3, 0x8C71, 0x7BEF, 0x73AE, 0x632C, 0x5ACB, 0x3186,   // 0x11D0 (4560)
0x0000, 0x0000, 0x0020, 0x0841, 0x0841, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x0861,   // 0x11E0 (4576)
0x0861, 0x0861, 0x0841, 0x0841, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082,   // 0x11F0 (4592)
0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x18C3, 0x18E3, 0x2124, 0x2965, 0x31A6, 0x4208, 0x4A69,   // 0x1200 (4608)
0x5AEB, 0x6B4D, 0x7BCF, 0x8430, 0x94B2, 0xA534, 0xB5B6, 0xBDF7, 0xBDF7, 0xC618, 0xC638, 0xCE79, 0xCE79, 0xC638, 0xC638, 0xC618,   // 0x1210 (4624)
0xC618, 0xB5B6, 0xAD75, 0xA514, 0x8C51, 0x8410, 0x7BEF, 0x7BCF, 0x7BEF, 0x8C71, 0x8410, 0x8430, 0x8410, 0x8430, 0x9CF3, 0xAD75,   // 0x1220 (4640)
0xAD55, 0xAD55, 0x9CF3, 0xAD55, 0xB596, 0xA534, 0x9CF3, 0x9CF3, 0x9CD3, 0x8C51, 0x7BEF, 0x73AE, 0x630C, 0x5ACB, 0x3186, 0x0000,   // 0x1230 (4656)
0x0000, 0x0020, 0x0841, 0x0841, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861,   // 0x1240 (4672)
0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082,   // 0x1250 (4688)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x2104, 0x2124, 0x2965, 0x39C7, 0x4208, 0x528A, 0x5AEB,   // 0x1260 (4704)
0x6B6D, 0x7BEF, 0x8C51, 0x9CD3, 0xAD75, 0xB5B6, 0xBDF7, 0xCE59, 0xCE59, 0xCE79, 0xD6BA, 0xD6BA, 0xCE79, 0xC638, 0xC638, 0xC618,   // 0x1270 (4720)
0xBDD7, 0xAD55, 0x9CD3, 0x8430, 0x7BEF, 0x8410, 0x7BEF, 0x7BEF, 0x7BCF, 0x7BCF, 0x7BEF, 0x7BEF, 0x7BEF, 0x9CD3, 0xA514, 0x9CD3,   // 0x1280 (4736)
0x9CF3, 0x9492, 0xA514, 0xAD75, 0xA514, 0x94B2, 0x9492, 0x8C71, 0x8C51, 0x7BEF, 0x738E, 0x630C, 0x52AA, 0x2965, 0x0000, 0x0000,   // 0x1290 (4752)
0x0020, 0x0841, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x1082, 0x0861,   // 0x12A0 (4768)
0x0861, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x12B0 (4784)
0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18E3, 0x2104, 0x2124, 0x2965, 0x31A6, 0x4208, 0x528A, 0x630C, 0x6B6D,   // 0x12C0 (4800)
0x7BEF, 0x8C71, 0x9CD3, 0xAD55, 0xB5B6, 0xBDF7, 0xC638, 0xCE59, 0xD69A, 0xDEDB, 0xD6BA, 0xCE59, 0xC638, 0xC618, 0xBDD7, 0xB5B6,   // 0x12D0 (4816)
0x9CF3, 0x8430, 0x7BEF, 0x7BCF, 0x8410, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BEF, 0x7BCF, 0x7BEF, 0x8C71, 0x9CD3, 0x8C71, 0x9492,   // 0x12E0 (4832)
0x94B2, 0xB596, 0xAD55, 0x9492, 0x9492, 0x8C71, 0x8C51, 0x8430, 0x73AE, 0x6B6D, 0x632C, 0x52AA, 0x2945, 0x0000, 0x0000, 0x0020,   // 0x12F0 (4848)
0x0841, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x1300 (4864)
0x10A2, 0x1082, 0x1082, 0x10A2, 0x0861, 0x1082, 0x10A2, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x1310 (4880)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x18C3, 0x18E3, 0x2104, 0x2945, 0x2945, 0x3186, 0x4208, 0x4A69, 0x5AEB, 0x6B6D, 0x7BEF,   // 0x1320 (4896)
0x8C71, 0x9CF3, 0xB596, 0xBDD7, 0xC618, 0xC638, 0xCE59, 0xD69A, 0xD6BA, 0xD6BA, 0xCE59, 0xC618, 0xBDD7, 0xB5B6, 0xAD75, 0x94B2,   // 0x1330 (4912)
0x8410, 0x7BEF, 0x7BCF, 0x7BEF, 0x7BCF, 0x7BEF, 0x8410, 0x7BEF, 0x7BEF, 0x7BEF, 0x7BEF, 0x8C51, 0x8C71, 0x8C51, 0x8C51, 0x9492,   // 0x1340 (4928)
0xAD75, 0xA534, 0x9CD3, 0x9CD3, 0x8C71, 0x8430, 0x7BEF, 0x738E, 0x6B6D, 0x632C, 0x52AA, 0x2124, 0x0000, 0x0000, 0x0020, 0x0841,   // 0x1350 (4944)
0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2,   // 0x1360 (4960)
0x1082, 0x1082, 0x10A2, 0x0861, 0x1082, 0x10A2, 0x1082, 0x10A2, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082,   // 0x1370 (4976)
0x1082, 0x1082, 0x10A2, 0x1082, 0x10A2, 0x18E3, 0x2104, 0x2124, 0x2945, 0x3186, 0x39E7, 0x4A69, 0x5AEB, 0x738E, 0x7BEF, 0x8C71,   // 0x1380 (4992)
0xA514, 0xB596, 0xBDF7, 0xC618, 0xC618, 0xCE59, 0xD69A, 0xD69A, 0xCE79, 0xCE59, 0xC618, 0xB5B6, 0xB596, 0xA534, 0x8C71, 0x8C51,   // 0x1390 (5008)
0x8C51, 0x8410, 0x8410, 0x7BEF, 0x8410, 0x8C71, 0x8430, 0x8410, 0x7BEF, 0x73AE, 0x8410, 0x8410, 0x8410, 0x7BCF, 0x8410, 0x9CD3,   // 0x13A0 (5024)
0xAD55, 0xA514, 0x9CD3, 0x8C71, 0x8430, 0x7BEF, 0x73AE, 0x6B4D, 0x630C, 0x528A, 0x18E3, 0x0000, 0x0000, 0x0020, 0x0841, 0x0841,   // 0x13B0 (5040)
0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082,   // 0x13C0 (5056)
0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x0861,   // 0x13D0 (5072)
0x0861, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x2104, 0x2124, 0x2965, 0x31A6, 0x39E7, 0x4A69, 0x630C, 0x738E, 0x7BEF, 0x9492, 0xA514,   // 0x13E0 (5088)
0xAD75, 0xBDD7, 0xBDD7, 0xBDF7, 0xC638, 0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xC618, 0xBDF7, 0xBDD7, 0x9CF3, 0x9492, 0x8C71, 0x9492,   // 0x13F0 (5104)
0x8C51, 0x8C51, 0x8410, 0x7BCF, 0x8410, 0x7BEF, 0x7BEF, 0x7BCF, 0x738E, 0x73AE, 0x7BCF, 0x73AE, 0x7BCF, 0x9492, 0xA514, 0xAD75,   // 0x1400 (5120)
0xA514, 0x9CD3, 0x9492, 0x8410, 0x7BCF, 0x6B6D, 0x630C, 0x5ACB, 0x4A69, 0x10A2, 0x0000, 0x0000, 0x0000, 0x0841, 0x0841, 0x0861,   // 0x1410 (5136)
0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x1420 (5152)
0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x1430 (5168)
0x1082, 0x10A2, 0x18C3, 0x18E3, 0x2104, 0x2124, 0x2965, 0x31A6, 0x39E7, 0x4A69, 0x5AEB, 0x6B6D, 0x8410, 0x94B2, 0xA514, 0xB5B6,   // 0x1440 (5184)
0xBDD7, 0xBDF7, 0xC638, 0xCE59, 0xCE59, 0xCE59, 0xCE79, 0xCE79, 0xC618, 0xBDF7, 0xB5B6, 0x9CF3, 0x8C51, 0x8C51, 0x8C71, 0x8430,   // 0x1450 (5200)
0x8430, 0x7BEF, 0x7BCF, 0x7BCF, 0x738E, 0x738E, 0x738E, 0x738E, 0x6B6D, 0x73AE, 0x6B6D, 0x7BCF, 0x9CF3, 0xA534, 0xB596, 0xAD55,   // 0x1460 (5216)
0x9CF3, 0x8430, 0x6B6D, 0x632C, 0x52AA, 0x5ACB, 0x5ACB, 0x4228, 0x0861, 0x0000, 0x0000, 0x0000, 0x0841, 0x0841, 0x0861, 0x0861,   // 0x1470 (5232)
0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x1082, 0x10A2, 0x10A2,   // 0x1480 (5248)
0x1082, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x0861, 0x1082, 0x10A2, 0x10A2,   // 0x1490 (5264)
0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2124, 0x2965, 0x31A6, 0x4208, 0x528A, 0x5AEB, 0x6B6D, 0x8410, 0x9CD3, 0xAD75, 0xBDF7, 0xBDF7,   // 0x14A0 (5280)
0xC618, 0xC638, 0xCE59, 0xCE59, 0xCE59, 0xCE79, 0xCE79, 0xC618, 0xB5B6, 0xAD55, 0x9CF3, 0x8430, 0x8430, 0x8430, 0x7BEF, 0x8410,   // 0x14B0 (5296)
0x7BCF, 0x7BCF, 0x7BCF, 0x73AE, 0x7BCF, 0x73AE, 0x738E, 0x6B6D, 0x6B6D, 0x6B4D, 0x8430, 0xA514, 0xA514, 0xAD75, 0xB596, 0x9CF3,   // 0x14C0 (5312)
0x7BCF, 0x630C, 0x5ACB, 0x528A, 0x528A, 0x5ACB, 0x39E7, 0x0841, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861,   // 0x14D0 (5328)
0x0861, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x14E0 (5344)
0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x18C3, 0x18C3, 0x18C3,   // 0x14F0 (5360)
0x18C3, 0x18E3, 0x2104, 0x2945, 0x2965, 0x31A6, 0x4208, 0x4A69, 0x5ACB, 0x6B4D, 0x8410, 0x94B2, 0xAD75, 0xBDF7, 0xC618, 0xC618,   // 0x1500 (5376)
0xC638, 0xC638, 0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xC638, 0xBDD7, 0xAD55, 0x94B2, 0x8C51, 0x8430, 0x8430, 0x7BEF, 0x8410, 0x7BCF,   // 0x1510 (5392)
0x7BCF, 0x7BEF, 0x7BCF, 0x73AE, 0x73AE, 0x738E, 0x6B4D, 0x632C, 0x6B4D, 0x9492, 0xA514, 0x9CF3, 0xAD55, 0xB596, 0x9CD3, 0x6B6D,   // 0x1520 (5408)
0x5AEB, 0x5ACB, 0x528A, 0x4A49, 0x4A69, 0x3186, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082,   // 0x1530 (5424)
0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3,   // 0x1540 (5440)
0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1550 (5456)
0x18E3, 0x2104, 0x2945, 0x2965, 0x31A6, 0x4208, 0x528A, 0x5AEB, 0x738E, 0x8430, 0x94B2, 0xA514, 0xB596, 0xBDD7, 0xC618, 0xC638,   // 0x1560 (5472)
0xC638, 0xCE59, 0xCE79, 0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xBDF7, 0x9CD3, 0x8C71, 0x8C51, 0x8C51, 0x8430, 0x8410, 0x7BEF, 0x7BEF,   // 0x1570 (5488)
0x7BEF, 0x7BCF, 0x73AE, 0x738E, 0x6B6D, 0x6B6D, 0x6B6D, 0x6B4D, 0x8430, 0x9CF3, 0x9CD3, 0xAD55, 0xA534, 0x8C51, 0x632C, 0x52AA,   // 0x1580 (5504)
0x4A69, 0x4228, 0x4208, 0x4228, 0x2124, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x1590 (5520)
0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3,   // 0x15A0 (5536)
0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2104,   // 0x15B0 (5552)
0x2124, 0x2124, 0x2965, 0x31A6, 0x4208, 0x528A, 0x630C, 0x738E, 0x8430, 0x9492, 0xA514, 0xAD75, 0xB5B6, 0xC618, 0xCE59, 0xCE59,   // 0x15C0 (5568)
0xCE59, 0xCE79, 0xD69A, 0xD69A, 0xD69A, 0xD69A, 0xC618, 0xAD75, 0x94B2, 0x8C71, 0x8C51, 0x8410, 0x8410, 0x8410, 0x8410, 0x7BEF,   // 0x15D0 (5584)
0x7BCF, 0x738E, 0x738E, 0x738E, 0x73AE, 0x73AE, 0x6B6D, 0x6B6D, 0x9492, 0x9CF3, 0xAD75, 0x9CD3, 0x73AE, 0x5AEB, 0x528A, 0x4A49,   // 0x15E0 (5600)
0x4208, 0x39E7, 0x4228, 0x18C3, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082,   // 0x15F0 (5616)
0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1600 (5632)
0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2104,   // 0x1610 (5648)
0x2945, 0x3186, 0x39C7, 0x4208, 0x528A, 0x630C, 0x6B6D, 0x7BEF, 0x9492, 0xA514, 0xAD75, 0xBDD7, 0xC618, 0xC638, 0xC638, 0xCE59,   // 0x1620 (5664)
0xD6BA, 0xDEDB, 0xDEDB, 0xD6BA, 0xD6BA, 0xCE59, 0xBDF7, 0xA534, 0x9492, 0x8430, 0x8410, 0x8410, 0x8C51, 0x8430, 0x8410, 0x7BCF,   // 0x1630 (5680)
0x7BCF, 0x7BCF, 0x738E, 0x6B6D, 0x73AE, 0x7BEF, 0x73AE, 0x8430, 0x9CF3, 0xAD55, 0x9492, 0x632C, 0x52AA, 0x4A69, 0x4A49, 0x39C7,   // 0x1640 (5696)
0x39E7, 0x39E7, 0x0861, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082,   // 0x1650 (5712)
0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1660 (5728)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x2945,   // 0x1670 (5744)
0x3186, 0x39E7, 0x4208, 0x528A, 0x630C, 0x738E, 0x8410, 0x94B2, 0xA514, 0xAD75, 0xBDD7, 0xC618, 0xC638, 0xCE59, 0xCE79, 0xD6BA,   // 0x1680 (5760)
0xDEFB, 0xDEDB, 0xD69A, 0xCE79, 0xCE59, 0xC638, 0xAD75, 0x94B2, 0x8430, 0x8430, 0x8410, 0x8430, 0x8C51, 0x8410, 0x8410, 0x8410,   // 0x1690 (5776)
0x8410, 0x738E, 0x73AE, 0x8C51, 0x94B2, 0x8C71, 0x8C51, 0x9CD3, 0xA514, 0x8C51, 0x630C, 0x52AA, 0x4A49, 0x4208, 0x31A6, 0x4208,   // 0x16A0 (5792)
0x31A6, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082,   // 0x16B0 (5808)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x16C0 (5824)
0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x2124, 0x2965,   // 0x16D0 (5840)
0x39C7, 0x4228, 0x528A, 0x630C, 0x738E, 0x8430, 0x9492, 0xA514, 0xAD75, 0xBDD7, 0xCE59, 0xD6BA, 0xCE79, 0xCE59, 0xCE79, 0xD6BA,   // 0x16E0 (5856)
0xD69A, 0xCE59, 0xC618, 0xBDF7, 0xBDD7, 0xA534, 0x9492, 0x8C51, 0x8C51, 0x8430, 0x8C71, 0xA534, 0x9492, 0x8410, 0x8410, 0x7BCF,   // 0x16F0 (5872)
0x7BCF, 0x7BEF, 0x7BEF, 0x8C71, 0x8430, 0x9492, 0xA514, 0x9CD3, 0x8410, 0x5AEB, 0x528A, 0x4A49, 0x39E7, 0x39C7, 0x4208, 0x2124,   // 0x1700 (5888)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082,   // 0x1710 (5904)
0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1720 (5920)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2104, 0x2124, 0x2965, 0x39C7,   // 0x1730 (5936)
0x4208, 0x4A69, 0x630C, 0x7BCF, 0x8C51, 0x9492, 0x9CF3, 0xAD75, 0xBDD7, 0xCE59, 0xD69A, 0xD69A, 0xCE79, 0xD69A, 0xD69A, 0xC638,   // 0x1740 (5952)
0xBDF7, 0xB5B6, 0xA534, 0x9CF3, 0x9CD3, 0x9492, 0x8C51, 0x9492, 0xA534, 0xBDF7, 0xBDF7, 0xA514, 0x7BEF, 0x73AE, 0x73AE, 0x7BEF,   // 0x1750 (5968)
0x73AE, 0x8410, 0x8430, 0x7BCF, 0x8430, 0x9CD3, 0x94B2, 0x8410, 0x5ACB, 0x4A49, 0x4208, 0x39E7, 0x4208, 0x4228, 0x10A2, 0x0000,   // 0x1760 (5984)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2,   // 0x1770 (6000)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1780 (6016)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2945, 0x3186, 0x39C7, 0x4208,   // 0x1790 (6032)
0x4A69, 0x630C, 0x73AE, 0x8430, 0x94B2, 0xA514, 0xAD75, 0xBDD7, 0xC618, 0xC638, 0xCE79, 0xD69A, 0xD6BA, 0xD6BA, 0xC638, 0xBDD7,   // 0x17A0 (6048)
0xAD75, 0xA514, 0x9CF3, 0x9CD3, 0x9CD3, 0x9CD3, 0xAD75, 0xBDD7, 0xBDF7, 0xBDD7, 0xA534, 0x8430, 0x73AE, 0x7BCF, 0x8410, 0x8410,   // 0x17B0 (6064)
0x8C71, 0x9492, 0x8430, 0x7BEF, 0x9492, 0x8C71, 0x8410, 0x5ACB, 0x4228, 0x4208, 0x4A69, 0x528A, 0x31A6, 0x0020, 0x0000, 0x0000,   // 0x17C0 (6080)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2,   // 0x17D0 (6096)
0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3,   // 0x17E0 (6112)
0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2124, 0x2965, 0x31A6, 0x4208, 0x4A69,   // 0x17F0 (6128)
0x5AEB, 0x738E, 0x8410, 0x9492, 0xA514, 0xAD55, 0xBDD7, 0xBDF7, 0xC618, 0xCE59, 0xCE79, 0xD69A, 0xD69A, 0xC638, 0xBDD7, 0xAD75,   // 0x1800 (6144)
0xAD55, 0xA534, 0x9CF3, 0xA514, 0xB596, 0xB5B6, 0xB596, 0xAD75, 0xB596, 0xAD75, 0x9CF3, 0x8410, 0x8430, 0x8C51, 0x9492, 0x8430,   // 0x1810 (6160)
0x9492, 0x7BEF, 0x7BEF, 0x8C71, 0x8C51, 0x7BCF, 0x632C, 0x52AA, 0x528A, 0x52AA, 0x4A69, 0x2104, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1820 (6176)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x0841, 0x0861, 0x0861, 0x0841, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x1830 (6192)
0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3,   // 0x1840 (6208)
0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2124, 0x2965, 0x31A6, 0x4208, 0x528A, 0x5AEB,   // 0x1850 (6224)
0x738E, 0x8410, 0x9492, 0x9CD3, 0xAD55, 0xB596, 0xBDD7, 0xC618, 0xCE59, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xC638, 0xBDD7, 0xAD55,   // 0x1860 (6240)
0x9CF3, 0xA514, 0xAD55, 0xB5B6, 0xB5B6, 0xB596, 0xAD75, 0xB596, 0xAD75, 0xA534, 0x94B2, 0x8C71, 0x8C51, 0x8410, 0x7BEF, 0x7BCF,   // 0x1870 (6256)
0x6B6D, 0x738E, 0x8C51, 0x8430, 0x73AE, 0x6B6D, 0x632C, 0x5AEB, 0x52AA, 0x39E7, 0x0861, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1880 (6272)
0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0841, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x1890 (6288)
0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3,   // 0x18A0 (6304)
0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2945, 0x3186, 0x39C7, 0x4228, 0x528A, 0x630C, 0x738E,   // 0x18B0 (6320)
0x8410, 0x8C71, 0x9CD3, 0xAD55, 0xB5B6, 0xBDF7, 0xC638, 0xCE59, 0xD6BA, 0xDEDB, 0xCE79, 0xD69A, 0xCE59, 0xBDD7, 0xA534, 0xA534,   // 0x18C0 (6336)
0xAD75, 0xB5B6, 0xB596, 0xB596, 0xB596, 0xAD75, 0xAD75, 0xA534, 0xA514, 0x9CD3, 0x7BEF, 0x73AE, 0x738E, 0x73AE, 0x632C, 0x630C,   // 0x18D0 (6352)
0x632C, 0x8430, 0x8410, 0x73AE, 0x632C, 0x5AEB, 0x52AA, 0x4A69, 0x2945, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x18E0 (6368)
0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x18F0 (6384)
0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3,   // 0x1900 (6400)
0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2124, 0x2945, 0x3186, 0x39C7, 0x4208, 0x528A, 0x630C, 0x738E, 0x8410,   // 0x1910 (6416)
0x9492, 0x9CF3, 0xAD55, 0xBDD7, 0xBDF7, 0xC618, 0xC638, 0xD6BA, 0xDEDB, 0xCE59, 0xCE59, 0xC618, 0xB596, 0xAD55, 0xAD75, 0xB596,   // 0x1920 (6432)
0xB5B6, 0xB596, 0xB5B6, 0xB5B6, 0xAD55, 0xAD55, 0xA514, 0x9492, 0x7BEF, 0x738E, 0x6B6D, 0x6B6D, 0x6B4D, 0x630C, 0x5ACB, 0x630C,   // 0x1930 (6448)
0x7BEF, 0x7BCF, 0x738E, 0x630C, 0x52AA, 0x4A49, 0x39E7, 0x1082, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1940 (6464)
0x0000, 0x0000, 0x0000, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x1950 (6480)
0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3,   // 0x1960 (6496)
0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2124, 0x2945, 0x3186, 0x39E7, 0x4228, 0x528A, 0x630C, 0x73AE, 0x8410, 0x8C71,   // 0x1970 (6512)
0x9CF3, 0xAD55, 0xB596, 0xB5B6, 0xBDF7, 0xCE59, 0xCE79, 0xD69A, 0xCE79, 0xC638, 0xBDF7, 0xB5B6, 0xBDD7, 0xAD55, 0xAD55, 0xB5B6,   // 0x1980 (6528)
0xB596, 0xBDF7, 0xC618, 0xAD55, 0xA514, 0xA534, 0x8C71, 0x73AE, 0x73AE, 0x738E, 0x6B6D, 0x632C, 0x630C, 0x52AA, 0x5ACB, 0x73AE,   // 0x1990 (6544)
0x73AE, 0x6B6D, 0x5AEB, 0x4A49, 0x4208, 0x2965, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x19A0 (6560)
0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x19B0 (6576)
0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3,   // 0x19C0 (6592)
0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2124, 0x2945, 0x3186, 0x39C7, 0x4228, 0x528A, 0x630C, 0x738E, 0x7BEF, 0x8C71, 0x9CD3,   // 0x19D0 (6608)
0xA534, 0xAD75, 0xBDD7, 0xC618, 0xCE59, 0xD69A, 0xD69A, 0xD69A, 0xC638, 0xBDD7, 0xB5B6, 0xB5B6, 0xA534, 0x9CD3, 0xAD55, 0xBDD7,   // 0x19E0 (6624)
0xC618, 0xBDF7, 0xAD75, 0x94B2, 0x94B2, 0x8C51, 0x73AE, 0x73AE, 0x738E, 0x630C, 0x630C, 0x5AEB, 0x528A, 0x528A, 0x5AEB, 0x6B4D,   // 0x19F0 (6640)
0x632C, 0x528A, 0x39E7, 0x31A6, 0x1082, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1A00 (6656)
0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x1A10 (6672)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3,   // 0x1A20 (6688)
0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2945, 0x2965, 0x31A6, 0x4208, 0x4A69, 0x5AEB, 0x6B6D, 0x7BCF, 0x8C51, 0x94B2, 0xA514,   // 0x1A30 (6704)
0xAD75, 0xBDF7, 0xC618, 0xC638, 0xD6BA, 0xD6BA, 0xC638, 0xB5B6, 0xAD55, 0xA534, 0xA514, 0x9CD3, 0x8C71, 0x9CF3, 0xB596, 0xB5B6,   // 0x1A40 (6720)
0xBDD7, 0xB596, 0x94B2, 0x8430, 0x7BCF, 0x738E, 0x738E, 0x6B4D, 0x630C, 0x5AEB, 0x52AA, 0x4A69, 0x4A69, 0x52AA, 0x630C, 0x52AA,   // 0x1A50 (6736)
0x4A69, 0x4228, 0x2124, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1A60 (6752)
0x0000, 0x0020, 0x0841, 0x0861, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3,   // 0x1A70 (6768)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3,   // 0x1A80 (6784)
0x18E3, 0x18E3, 0x2104, 0x2104, 0x2124, 0x2965, 0x31A6, 0x4208, 0x4A69, 0x5AEB, 0x6B4D, 0x7BCF, 0x8430, 0x94B2, 0x9CF3, 0xAD75,   // 0x1A90 (6800)
0xBDD7, 0xBDF7, 0xC618, 0xCE59, 0xC638, 0xBDD7, 0xA534, 0x9CF3, 0x94B2, 0x8C71, 0x8C71, 0x8C71, 0x9CD3, 0xAD75, 0xB5B6, 0xBDD7,   // 0x1AA0 (6816)
0xA534, 0x8C71, 0x8410, 0x73AE, 0x6B6D, 0x6B4D, 0x632C, 0x630C, 0x5ACB, 0x52AA, 0x4A69, 0x528A, 0x5ACB, 0x528A, 0x4A69, 0x4A49,   // 0x1AB0 (6832)
0x39E7, 0x0861, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1AC0 (6848)
0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3,   // 0x1AD0 (6864)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1AE0 (6880)
0x18E3, 0x2104, 0x2104, 0x2124, 0x2965, 0x31A6, 0x4208, 0x4A69, 0x5ACB, 0x6B6D, 0x7BCF, 0x8C51, 0x9CD3, 0xA514, 0xB596, 0xB5B6,   // 0x1AF0 (6896)
0xBDF7, 0xBDF7, 0xC618, 0xBDF7, 0xAD75, 0xA514, 0x9CD3, 0x9492, 0x9492, 0x9492, 0x9492, 0x9492, 0xAD55, 0xBDD7, 0xBDD7, 0xAD55,   // 0x1B00 (6912)
0x94B2, 0x7BEF, 0x6B6D, 0x738E, 0x632C, 0x630C, 0x5AEB, 0x5ACB, 0x5ACB, 0x52AA, 0x52AA, 0x52AA, 0x4228, 0x4A69, 0x4228, 0x18E3,   // 0x1B10 (6928)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1B20 (6944)
0x0000, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3,   // 0x1B30 (6960)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3,   // 0x1B40 (6976)
0x2104, 0x2104, 0x2945, 0x2965, 0x31A6, 0x39E7, 0x4A69, 0x5AEB, 0x73AE, 0x7BEF, 0x8C71, 0x9CF3, 0xAD75, 0xB5B6, 0xBDD7, 0xC618,   // 0x1B50 (6992)
0xBDF7, 0xC618, 0xC618, 0xB596, 0x9CF3, 0x9492, 0x9492, 0x9492, 0x94B2, 0x94B2, 0x9CF3, 0xAD75, 0xBDD7, 0xB596, 0x94B2, 0x94B2,   // 0x1B60 (7008)
0x73AE, 0x6B4D, 0x632C, 0x5AEB, 0x5AEB, 0x630C, 0x5AEB, 0x5AEB, 0x52AA, 0x52AA, 0x528A, 0x4A49, 0x4A49, 0x2124, 0x0000, 0x0000,   // 0x1B70 (7024)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1B80 (7040)
0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3,   // 0x1B90 (7056)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x2104,   // 0x1BA0 (7072)
0x2104, 0x2945, 0x2965, 0x39C7, 0x4208, 0x528A, 0x630C, 0x738E, 0x8410, 0x8C71, 0xA514, 0xB5B6, 0xBDD7, 0xBDF7, 0xC638, 0xC618,   // 0x1BB0 (7088)
0xBDF7, 0xB5B6, 0xAD55, 0xA514, 0x8C71, 0x8C71, 0x8C51, 0x9492, 0xA534, 0xB5B6, 0xB596, 0xAD55, 0xA514, 0x8C51, 0x8430, 0x73AE,   // 0x1BC0 (7104)
0x6B4D, 0x5AEB, 0x630C, 0x630C, 0x630C, 0x5AEB, 0x52AA, 0x528A, 0x5AEB, 0x52AA, 0x4A49, 0x31A6, 0x0841, 0x0000, 0x0000, 0x0000,   // 0x1BD0 (7120)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1BE0 (7136)
0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3,   // 0x1BF0 (7152)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x2104,   // 0x1C00 (7168)
0x2124, 0x3186, 0x39C7, 0x4228, 0x528A, 0x5AEB, 0x6B6D, 0x7BCF, 0x8C71, 0x9CD3, 0xAD55, 0xB5B6, 0xB5B6, 0xB5B6, 0xB5B6, 0xB596,   // 0x1C10 (7184)
0xA534, 0xA514, 0xA514, 0x8C71, 0x8430, 0x8410, 0x9CF3, 0xBDD7, 0xB5B6, 0xB596, 0xA534, 0xA514, 0x9492, 0x7BEF, 0x738E, 0x6B4D,   // 0x1C20 (7200)
0x632C, 0x6B4D, 0x632C, 0x630C, 0x5ACB, 0x52AA, 0x52AA, 0x5ACB, 0x4A69, 0x39E7, 0x10A2, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1C30 (7216)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x1C40 (7232)
0x0841, 0x0841, 0x0841, 0x0841, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3,   // 0x1C50 (7248)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2124,   // 0x1C60 (7264)
0x2965, 0x31A6, 0x4208, 0x4A69, 0x5AEB, 0x6B4D, 0x7BCF, 0x8C71, 0x94B2, 0xA514, 0xAD75, 0xB5B6, 0xB596, 0xAD75, 0xB596, 0xAD75,   // 0x1C70 (7280)
0xB596, 0xAD55, 0xA514, 0x8C51, 0x8C71, 0xAD75, 0xB5B6, 0x9CF3, 0xA534, 0x9CF3, 0x9CD3, 0x9CF3, 0x8410, 0x738E, 0x6B6D, 0x6B6D,   // 0x1C80 (7296)
0x6B6D, 0x6B4D, 0x6B6D, 0x6B4D, 0x5ACB, 0x528A, 0x4A69, 0x4208, 0x2104, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1C90 (7312)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1CA0 (7328)
0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3,   // 0x1CB0 (7344)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x2124, 0x2945,   // 0x1CC0 (7360)
0x3186, 0x39E7, 0x4A49, 0x5AEB, 0x6B6D, 0x7BEF, 0x8C71, 0x94B2, 0x9CF3, 0xAD75, 0xB5B6, 0xBDD7, 0xB5B6, 0xB5B6, 0xB5B6, 0xB5B6,   // 0x1CD0 (7376)
0xBDD7, 0xB596, 0x9CD3, 0x9CD3, 0xA534, 0x9CF3, 0x9492, 0x9CF3, 0xA514, 0x9CD3, 0x94B2, 0x8C51, 0x7BCF, 0x6B6D, 0x6B4D, 0x6B4D,   // 0x1CE0 (7392)
0x73AE, 0x73AE, 0x6B6D, 0x5ACB, 0x4A69, 0x4228, 0x2124, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1CF0 (7408)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1D00 (7424)
0x0841, 0x0861, 0x0841, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x1D10 (7440)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2124, 0x2945, 0x3186,   // 0x1D20 (7456)
0x39E7, 0x4A49, 0x5ACB, 0x6B6D, 0x7BCF, 0x8C51, 0x9492, 0x9CF3, 0xAD75, 0xB5B6, 0xB5B6, 0xB5B6, 0xB5B6, 0xB596, 0xAD75, 0xB596,   // 0x1D30 (7472)
0xA514, 0x94B2, 0x9CF3, 0xA514, 0x9CD3, 0x9CD3, 0x9CD3, 0x9492, 0x8C71, 0x9492, 0x8430, 0x6B6D, 0x632C, 0x632C, 0x6B4D, 0x738E,   // 0x1D40 (7488)
0x6B6D, 0x5AEB, 0x52AA, 0x4A49, 0x2965, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1D50 (7504)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x1D60 (7520)
0x0841, 0x0841, 0x0841, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x1D70 (7536)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2124, 0x2965, 0x3186, 0x39C7,   // 0x1D80 (7552)
0x4A49, 0x52AA, 0x6B4D, 0x73AE, 0x8410, 0x8C71, 0x9CD3, 0xA534, 0xAD55, 0xAD75, 0xB596, 0xB596, 0xAD75, 0xA534, 0xA534, 0x9CF3,   // 0x1D90 (7568)
0x9CF3, 0xA534, 0x9CF3, 0x9492, 0x94B2, 0x8C51, 0x7BEF, 0x7BEF, 0x7BEF, 0x738E, 0x630C, 0x632C, 0x632C, 0x632C, 0x630C, 0x5AEB,   // 0x1DA0 (7584)
0x52AA, 0x4A69, 0x31A6, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1DB0 (7600)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x1DC0 (7616)
0x0841, 0x0841, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x1DD0 (7632)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x2104, 0x2124, 0x2965, 0x3186, 0x39C7, 0x4A49,   // 0x1DE0 (7648)
0x52AA, 0x632C, 0x73AE, 0x8410, 0x8C71, 0x94B2, 0x9CF3, 0xA534, 0xAD55, 0xAD55, 0xAD55, 0xAD55, 0xA534, 0xAD75, 0xAD75, 0xA534,   // 0x1DF0 (7664)
0x9CF3, 0x94B2, 0x8C71, 0x8C71, 0x7BCF, 0x738E, 0x73AE, 0x6B6D, 0x632C, 0x632C, 0x6B4D, 0x632C, 0x630C, 0x5ACB, 0x528A, 0x4A69,   // 0x1E00 (7680)
0x39C7, 0x1082, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1E10 (7696)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x1E20 (7712)
0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x1E30 (7728)
0x10A2, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x18E3, 0x2124, 0x2945, 0x3186, 0x39E7, 0x4A49, 0x52AA,   // 0x1E40 (7744)
0x630C, 0x738E, 0x7BEF, 0x8C71, 0x94B2, 0x9CF3, 0xAD55, 0xAD75, 0xAD75, 0xAD55, 0xA534, 0xAD55, 0xAD75, 0xAD55, 0xA534, 0x9CF3,   // 0x1E50 (7760)
0x9CD3, 0x94B2, 0x8410, 0x6B6D, 0x6B4D, 0x738E, 0x6B6D, 0x632C, 0x632C, 0x5AEB, 0x5ACB, 0x5ACB, 0x528A, 0x4A49, 0x39C7, 0x1082,   // 0x1E60 (7776)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1E70 (7792)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x1E80 (7808)
0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x1E90 (7824)
0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2124, 0x3186, 0x39C7, 0x4A49, 0x5ACB, 0x632C,   // 0x1EA0 (7840)
0x738E, 0x7BEF, 0x8430, 0x9492, 0x9CF3, 0xAD55, 0xAD75, 0xAD55, 0xAD55, 0xAD55, 0xA534, 0xA534, 0xA534, 0xA534, 0x9CF3, 0x94B2,   // 0x1EB0 (7856)
0x9492, 0x8410, 0x73AE, 0x7BCF, 0x8410, 0x738E, 0x632C, 0x5ACB, 0x528A, 0x52AA, 0x4A69, 0x4A49, 0x31A6, 0x0861, 0x0000, 0x0000,   // 0x1EC0 (7872)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1ED0 (7888)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x1EE0 (7904)
0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x1EF0 (7920)
0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2124, 0x2965, 0x31A6, 0x4228, 0x528A, 0x630C, 0x6B6D,   // 0x1F00 (7936)
0x7BEF, 0x8430, 0x9492, 0x9CD3, 0xA514, 0xA514, 0xA514, 0xA534, 0xA514, 0x9CF3, 0xA534, 0xA514, 0x9CD3, 0x9CD3, 0x94B2, 0x8430,   // 0x1F10 (7952)
0x7BEF, 0x7BEF, 0x7BEF, 0x7BCF, 0x6B6D, 0x5AEB, 0x52AA, 0x528A, 0x4A69, 0x4228, 0x3186, 0x0861, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1F20 (7968)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1F30 (7984)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x1F40 (8000)
0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x1F50 (8016)
0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x2104, 0x2124, 0x2965, 0x31A6, 0x4228, 0x528A, 0x630C, 0x6B6D, 0x7BCF,   // 0x1F60 (8032)
0x8430, 0x8C71, 0x94B2, 0x9CD3, 0x9CD3, 0x9CD3, 0x9CF3, 0x9CF3, 0x9CF3, 0xA534, 0xA514, 0x9CF3, 0x94B2, 0x8C51, 0x7BEF, 0x7BCF,   // 0x1F70 (8048)
0x73AE, 0x73AE, 0x6B4D, 0x5AEB, 0x52AA, 0x528A, 0x4A49, 0x4208, 0x2124, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1F80 (8064)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1F90 (8080)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x1FA0 (8096)
0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x1FB0 (8112)
0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x2104, 0x2124, 0x2965, 0x31A6, 0x4208, 0x4A69, 0x5AEB, 0x6B4D, 0x73AE, 0x7BEF,   // 0x1FC0 (8128)
0x8430, 0x8C71, 0x9492, 0x9CD3, 0x9CD3, 0x9CD3, 0x9CD3, 0xA514, 0xA514, 0x9CD3, 0x94B2, 0x8C71, 0x8410, 0x7BCF, 0x73AE, 0x6B6D,   // 0x1FD0 (8144)
0x632C, 0x5ACB, 0x52AA, 0x528A, 0x4A49, 0x39C7, 0x18E3, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1FE0 (8160)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1FF0 (8176)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2000 (8192)
0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x2010 (8208)
0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x2124, 0x2965, 0x31A6, 0x4208, 0x4A69, 0x5ACB, 0x632C, 0x738E, 0x7BEF, 0x8410,   // 0x2020 (8224)
0x8430, 0x8C51, 0x8C71, 0x94B2, 0x94B2, 0x9CD3, 0xA514, 0x9CD3, 0x9492, 0x8C51, 0x8410, 0x7BEF, 0x73AE, 0x6B6D, 0x632C, 0x5ACB,   // 0x2030 (8240)
0x528A, 0x528A, 0x4A49, 0x2965, 0x0861, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2040 (8256)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2050 (8272)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2060 (8288)
0x0000, 0x0020, 0x0841, 0x0841, 0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082,   // 0x2070 (8304)
0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x2104, 0x2945, 0x3186, 0x4208, 0x4A49, 0x52AA, 0x630C, 0x738E, 0x7BCF, 0x7BEF, 0x8430,   // 0x2080 (8320)
0x8430, 0x8C51, 0x9492, 0x9492, 0x8C71, 0x8C71, 0x8C71, 0x8C51, 0x8410, 0x73AE, 0x738E, 0x6B6D, 0x630C, 0x5AEB, 0x52AA, 0x4A49,   // 0x2090 (8336)
0x39C7, 0x18E3, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x20A0 (8352)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x20B0 (8368)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x20C0 (8384)
0x0000, 0x0000, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x20D0 (8400)
0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x2124, 0x3186, 0x39E7, 0x4A49, 0x52AA, 0x5AEB, 0x632C, 0x738E, 0x73AE, 0x7BEF, 0x8410,   // 0x20E0 (8416)
0x8430, 0x8430, 0x8430, 0x8430, 0x8430, 0x8430, 0x7BCF, 0x738E, 0x6B4D, 0x630C, 0x5AEB, 0x5ACB, 0x4A69, 0x39C7, 0x2104, 0x0841,   // 0x20F0 (8432)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2100 (8448)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2110 (8464)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2120 (8480)
0x0000, 0x0000, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x2130 (8496)
0x1082, 0x10A2, 0x18C3, 0x18E3, 0x2104, 0x2945, 0x31A6, 0x39E7, 0x4A49, 0x52AA, 0x5AEB, 0x632C, 0x6B4D, 0x6B6D, 0x6B6D, 0x738E,   // 0x2140 (8512)
0x7BCF, 0x73AE, 0x738E, 0x738E, 0x6B6D, 0x6B4D, 0x632C, 0x630C, 0x5ACB, 0x4A69, 0x39E7, 0x2124, 0x0861, 0x0000, 0x0000, 0x0000,   // 0x2150 (8528)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2160 (8544)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2170 (8560)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2180 (8576)
0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861,   // 0x2190 (8592)
0x1082, 0x10A2, 0x10A2, 0x18E3, 0x2124, 0x2965, 0x31A6, 0x39E7, 0x4228, 0x528A, 0x5ACB, 0x5ACB, 0x5AEB, 0x5AEB, 0x630C, 0x6B4D,   // 0x21A0 (8608)
0x632C, 0x630C, 0x5AEB, 0x5AEB, 0x5ACB, 0x52AA, 0x4A49, 0x39C7, 0x18E3, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x21B0 (8624)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x21C0 (8640)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x21D0 (8656)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x21E0 (8672)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861,   // 0x21F0 (8688)
0x1082, 0x1082, 0x18C3, 0x2104, 0x2945, 0x3186, 0x39C7, 0x4208, 0x4A49, 0x4A69, 0x528A, 0x52AA, 0x52AA, 0x52AA, 0x52AA, 0x52AA,   // 0x2200 (8704)
0x52AA, 0x52AA, 0x4A49, 0x39C7, 0x2945, 0x10A2, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2210 (8720)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2220 (8736)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2230 (8752)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2240 (8768)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861,   // 0x2250 (8784)
0x1082, 0x10A2, 0x18E3, 0x2124, 0x2945, 0x31A6, 0x39E7, 0x4208, 0x4228, 0x4A69, 0x4A69, 0x4A69, 0x4A49, 0x4228, 0x4208, 0x31A6,   // 0x2260 (8800)
0x2124, 0x10A2, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2270 (8816)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2280 (8832)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2290 (8848)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22A0 (8864)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0841, 0x0841, 0x0861,   // 0x22B0 (8880)
0x1082, 0x10A2, 0x18C3, 0x18E3, 0x2945, 0x2965, 0x3186, 0x3186, 0x3186, 0x3186, 0x2945, 0x2104, 0x10A2, 0x1082, 0x0020, 0x0000,   // 0x22C0 (8896)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22D0 (8912)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22E0 (8928)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22F0 (8944)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2300 (8960)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020,   // 0x2310 (8976)
0x0020, 0x0020, 0x0841, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2320 (8992)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2330 (9008)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2340 (9024)
0x0000, };
Full.c
// Generated by  : ImageConverter 565 v2.3
// Generated from: Full.png
// Time generated: 21/06/2022 9:17:04 AM
// Dimensions    : 36x21 pixels
// Size          : 1,512 Bytes
#include <avr/pgmspace.h>
const unsigned int Full[0x2F4] PROGMEM ={
0x0000, 0x0000, 0x630C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C,   // 0x0010 (16)
0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x5AEB,   // 0x0020 (32)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x632C, 0x6B6D, 0x73AE, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF,   // 0x0030 (48)
0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF,   // 0x0040 (64)
0x7BCF, 0x7BCF, 0x738E, 0x6B6D, 0x632C, 0x0000, 0x0000, 0x0000, 0x630C, 0x6B4D, 0x9CF3, 0xEF5D, 0xF79E, 0xF79E, 0xF79E, 0xF79E,   // 0x0050 (80)
0xF79E, 0xF79E, 0xEF7E, 0xF79E, 0xF79E, 0xF79E, 0xF79E, 0xF79E, 0xF77E, 0xF79E, 0xF79E, 0xF79E, 0xF79E, 0xF79E, 0xF79E, 0xEF7D,   // 0x0060 (96)
0xF79E, 0xF79E, 0xF79E, 0xF79E, 0xF79E, 0xF79E, 0xE71C, 0x8430, 0x630C, 0x630C, 0x0000, 0x0000, 0x5AEB, 0x6B6D, 0xE6FC, 0xEFFC,   // 0x0070 (112)
0x8EF0, 0x86F0, 0x8EF1, 0x8EF1, 0x86D0, 0xB757, 0xEFFD, 0x86D0, 0x86F0, 0x8EF0, 0x8EF1, 0x86CF, 0xDFDB, 0xC798, 0x7ECF, 0x86F0,   // 0x0080 (128)
0x86F0, 0x86F0, 0x96F1, 0xF7FE, 0xA734, 0x86F0, 0x8EF1, 0x8EF1, 0x86F0, 0x8EF2, 0xFFFF, 0xBDD7, 0x630C, 0x52AA, 0x0000, 0x0000,   // 0x0090 (144)
0x5ACB, 0x6B6D, 0xE6FC, 0xAF55, 0x3E07, 0x4628, 0x4628, 0x4628, 0x3E27, 0x8EF1, 0xD7BA, 0x4628, 0x4648, 0x4648, 0x4648, 0x3E07,   // 0x00A0 (160)
0xC778, 0xA714, 0x3E07, 0x4648, 0x4648, 0x4648, 0x562A, 0xE7BC, 0x768E, 0x3E27, 0x4648, 0x4648, 0x4648, 0x4608, 0xCFD9, 0xC5F8,   // 0x00B0 (176)
0x62EB, 0x5ACB, 0x0000, 0x0000, 0x5ACB, 0x6B6D, 0xE6FC, 0xAF55, 0x4628, 0x5669, 0x5669, 0x5669, 0x4648, 0x96F2, 0xDFBB, 0x4E49,   // 0x00C0 (192)
0x4E69, 0x4E69, 0x4E69, 0x4628, 0xCF79, 0xAF35, 0x4628, 0x4E6A, 0x4E6A, 0x4E69, 0x5E6B, 0xE7DC, 0x7EAF, 0x4649, 0x4E6A, 0x4E6A,   // 0x00D0 (208)
0x4E69, 0x4E29, 0xCFD9, 0xC5F8, 0x5AEB, 0x52AA, 0x0000, 0x0000, 0x5AEB, 0x6B6D, 0xE6FC, 0xB755, 0x4628, 0x4E6A, 0x4E6A, 0x4E6A,   // 0x00E0 (224)
0x4648, 0x96F2, 0xDFBB, 0x4E49, 0x4E69, 0x4E6A, 0x4E69, 0x4628, 0xCF79, 0xAF35, 0x4628, 0x4E6A, 0x4E6A, 0x4E69, 0x5E6B, 0xE7DC,   // 0x00F0 (240)
0x7EAF, 0x4649, 0x4E6A, 0x4E6A, 0x4E69, 0x4E29, 0xCFD9, 0xC5F8, 0x5AEB, 0x630C, 0x630C, 0x5ACB, 0x5AEB, 0x6B6D, 0xE6FC, 0xB755,   // 0x0100 (256)
0x4628, 0x4E6A, 0x4E6A, 0x4E6A, 0x4648, 0x96F2, 0xDFBB, 0x4E49, 0x4E69, 0x4E6A, 0x4E69, 0x4648, 0xC779, 0xAF35, 0x4628, 0x4E6A,   // 0x0110 (272)
0x4E6A, 0x4E69, 0x5E4B, 0xE7DC, 0x7EAF, 0x4648, 0x4E69, 0x4E6A, 0x4E69, 0x4E29, 0xCFD9, 0xC5D8, 0x5AEB, 0x738E, 0x73AE, 0x632C,   // 0x0120 (288)
0x5AEB, 0x6B6D, 0xE6FC, 0xAF55, 0x4648, 0x4E6A, 0x4E6A, 0x4E6A, 0x4648, 0x96F2, 0xDFBB, 0x4E49, 0x4E69, 0x4E6A, 0x4E69, 0x4648,   // 0x0130 (304)
0xC779, 0xAF35, 0x4628, 0x4E6A, 0x4E6A, 0x4E69, 0x5E6B, 0xE7DC, 0x7EAF, 0x4649, 0x4E6A, 0x4E6A, 0x4E69, 0x4E29, 0xC778, 0xF7BE,   // 0x0140 (320)
0xE71C, 0xEF5D, 0xA534, 0x632C, 0x5AEB, 0x6B6D, 0xE6FC, 0xAF55, 0x4648, 0x4E6A, 0x4E6A, 0x4E6A, 0x4648, 0x96F2, 0xDFBB, 0x4E49,   // 0x0150 (336)
0x4E69, 0x4E6A, 0x4E69, 0x4648, 0xC779, 0xAF35, 0x4628, 0x4E6A, 0x4E6A, 0x4E69, 0x5E6B, 0xE7DC, 0x7EAF, 0x4649, 0x4E6A, 0x4E6A,   // 0x0160 (352)
0x4E69, 0x4E29, 0xC757, 0xFFFF, 0xFFFF, 0xFFFF, 0xBDD7, 0x630C, 0x5AEB, 0x6B6D, 0xE6FC, 0xAF55, 0x4648, 0x4E6A, 0x4E6A, 0x4E6A,   // 0x0170 (368)
0x4648, 0x96F2, 0xDFBB, 0x4E49, 0x4E69, 0x4E6A, 0x4E69, 0x4628, 0xCF79, 0xAF35, 0x4628, 0x4E6A, 0x4E6A, 0x4E69, 0x5E6B, 0xE7DC,   // 0x0180 (384)
0x7EAF, 0x4649, 0x4E6A, 0x4E69, 0x4E69, 0x4E29, 0xC778, 0xFFFF, 0xFFFF, 0xFFFF, 0xB5B6, 0x5AEB, 0x5AEB, 0x6B6D, 0xE6FC, 0xAF55,   // 0x0190 (400)
0x4648, 0x4E6A, 0x4E6A, 0x4E6A, 0x4648, 0x96F2, 0xDFBB, 0x4E49, 0x4E69, 0x4E6A, 0x4E69, 0x4648, 0xC779, 0xAF35, 0x4628, 0x4E6A,   // 0x01A0 (416)
0x4E6A, 0x4E69, 0x5E6B, 0xE7DC, 0x7EAF, 0x4648, 0x4E69, 0x4E69, 0x4E69, 0x4E29, 0xC778, 0xFFFF, 0xFFFF, 0xFFFF, 0xB5B6, 0x630C,   // 0x01B0 (432)
0x5AEB, 0x6B6D, 0xE6FC, 0xB755, 0x4628, 0x4E6A, 0x4E6A, 0x4E6A, 0x4648, 0x96F2, 0xDFBB, 0x4E49, 0x4E69, 0x4E6A, 0x4E69, 0x4648,   // 0x01C0 (448)
0xC779, 0xAF35, 0x4628, 0x4E6A, 0x4E6A, 0x4E69, 0x5E6B, 0xE7DC, 0x7EAF, 0x4649, 0x4E6A, 0x4E6A, 0x4E69, 0x4E29, 0xC757, 0xFFFF,   // 0x01D0 (464)
0xFFFF, 0xFFFF, 0xBDD7, 0x630C, 0x5AEB, 0x6B6D, 0xE6FC, 0xB755, 0x4628, 0x4E6A, 0x4E6A, 0x4E6A, 0x4648, 0x96F2, 0xDFBB, 0x4E49,   // 0x01E0 (480)
0x4E69, 0x4E6A, 0x4E69, 0x4648, 0xC779, 0xAF35, 0x4628, 0x4E6A, 0x4E6A, 0x4E69, 0x5E6B, 0xE7DC, 0x7EAF, 0x4649, 0x4E6A, 0x4E6A,   // 0x01F0 (496)
0x4E69, 0x4E29, 0xCF98, 0xDEDB, 0xA534, 0xAD75, 0x8C51, 0x632C, 0x5AEB, 0x6B6D, 0xE6FC, 0xAF55, 0x4648, 0x4E6A, 0x4E6A, 0x4E6A,   // 0x0200 (512)
0x4648, 0x96F2, 0xDFBB, 0x4E49, 0x4E69, 0x4E6A, 0x4E69, 0x4628, 0xCF79, 0xAF35, 0x4628, 0x4E6A, 0x4E6A, 0x4E69, 0x5E6B, 0xE7DC,   // 0x0210 (528)
0x7EAF, 0x4649, 0x4E6A, 0x4E6A, 0x4E6A, 0x4E29, 0xCFD9, 0xBDB7, 0x528A, 0x5AEB, 0x6B4D, 0x632C, 0x5AEB, 0x6B6D, 0xE6FC, 0xAF55,   // 0x0220 (544)
0x4648, 0x4E6A, 0x4E6A, 0x4E6A, 0x4648, 0x96F2, 0xDFBB, 0x4E49, 0x4E69, 0x4E6A, 0x4E69, 0x4648, 0xC779, 0xAF35, 0x4628, 0x4E6A,   // 0x0230 (560)
0x4E6A, 0x4E69, 0x5E6B, 0xE7DC, 0x7EAF, 0x4648, 0x4E69, 0x4E69, 0x4E69, 0x4E29, 0xCFD9, 0xC5F8, 0x5AEB, 0x630C, 0x52AA, 0x0000,   // 0x0240 (576)
0x5AEB, 0x6B6D, 0xE6FC, 0xAF55, 0x4648, 0x4E69, 0x4E69, 0x4E69, 0x4648, 0x96F2, 0xDFBB, 0x4E49, 0x4E69, 0x4E69, 0x4E69, 0x4648,   // 0x0250 (592)
0xC779, 0xA735, 0x4628, 0x4E69, 0x4E69, 0x4E69, 0x5E4B, 0xE7DC, 0x7EAF, 0x4648, 0x4E69, 0x4E69, 0x4E69, 0x4628, 0xCFD9, 0xC5F8,   // 0x0260 (608)
0x5AEB, 0x528A, 0x0000, 0x0000, 0x5AEB, 0x736E, 0xEF1D, 0xBF77, 0x4608, 0x4E29, 0x4E29, 0x4E29, 0x3E28, 0x8ED2, 0xD7BA, 0x4608,   // 0x0270 (624)
0x4E49, 0x4E49, 0x4E49, 0x3E27, 0xC778, 0xAF14, 0x3E07, 0x4E29, 0x4E29, 0x4628, 0x562A, 0xE7DC, 0x768E, 0x3E28, 0x4E49, 0x4E49,   // 0x0280 (640)
0x4E49, 0x4E29, 0xDFDB, 0xC5F8, 0x5AEB, 0x5ACB, 0x0000, 0x0000, 0x5AEB, 0x6B6D, 0xCE79, 0xFFFF, 0xDFDB, 0xD7BA, 0xD7BA, 0xD7DA,   // 0x0290 (656)
0xD7BA, 0xEFFD, 0xFFFF, 0xD7BA, 0xD7DA, 0xD7DA, 0xD7DA, 0xD7BA, 0xFFFE, 0xF7FD, 0xD7B9, 0xD7BA, 0xD7BA, 0xD7BA, 0xD7DB, 0xFFFF,   // 0x02A0 (672)
0xE7FC, 0xD7BA, 0xD7DA, 0xD7DA, 0xD7BA, 0xDFDB, 0xFFFF, 0xAD55, 0x630C, 0x5ACB, 0x0000, 0x0000, 0x630C, 0x632C, 0x7BEF, 0xB596,   // 0x02B0 (688)
0xC5F8, 0xC5D8, 0xC5D8, 0xC5D8, 0xC5D8, 0xBDD7, 0xBDB7, 0xC5D8, 0xC5D8, 0xC5D8, 0xC5D8, 0xC5D8, 0xBDB7, 0xBDD7, 0xC5D8, 0xC5D8,   // 0x02C0 (704)
0xC5D8, 0xC5D8, 0xC5D8, 0xBDB6, 0xBDD7, 0xC5D8, 0xC5D8, 0xC5D8, 0xC5D8, 0xC5F8, 0xAD35, 0x73CF, 0x632C, 0x52AA, 0x0000, 0x0000,   // 0x02D0 (720)
0x0000, 0x630C, 0x632C, 0x630C, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x630C, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB,   // 0x02E0 (736)
0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x630C, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x630C, 0x630C, 0x6B4D,   // 0x02F0 (752)
0x630C, 0x0000, 0x0000, 0x0000, };
GettingBig.c
// Generated from: WaxingCrescent.jpg
// Time generated: 17/06/2022 8:18:48 AM
// Dimensions    : 95x95 pixels
// Size          : 18,050 Bytes
const unsigned int GettingBig[0x2341] PROGMEM ={
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0010 (16)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0020 (32)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0030 (48)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0040 (64)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0050 (80)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0060 (96)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0070 (112)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0080 (128)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0841, 0x0861, 0x0861, 0x1082,   // 0x0090 (144)
0x1082, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x1082, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00A0 (160)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00B0 (176)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00C0 (192)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00D0 (208)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00E0 (224)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0020, 0x0841, 0x0861, 0x1082, 0x10A2, 0x18C3, 0x18E3, 0x2104,   // 0x00F0 (240)
0x2965, 0x31A6, 0x39E7, 0x4228, 0x4A49, 0x4A49, 0x4228, 0x4208, 0x3186, 0x2104, 0x1082, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0100 (256)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0110 (272)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0120 (288)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0130 (304)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0140 (320)
0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x18E3, 0x2104, 0x2124,   // 0x0150 (336)
0x2945, 0x31A6, 0x39E7, 0x4A49, 0x528A, 0x5ACB, 0x630C, 0x632C, 0x632C, 0x5AEB, 0x4A49, 0x3186, 0x10A2, 0x0000, 0x0000, 0x0000,   // 0x0160 (352)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0170 (368)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0180 (384)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0190 (400)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020,   // 0x01A0 (416)
0x0841, 0x0841, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x18C3, 0x18E3, 0x2104, 0x2104,   // 0x01B0 (432)
0x2965, 0x31A6, 0x39E7, 0x4228, 0x528A, 0x5ACB, 0x632C, 0x6B6D, 0x738E, 0x73AE, 0x738E, 0x632C, 0x4A49, 0x2104, 0x0841, 0x0000,   // 0x01C0 (448)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x01D0 (464)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x01E0 (480)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x01F0 (496)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0841,   // 0x0200 (512)
0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x18C3, 0x2104, 0x2945, 0x2945, 0x2965,   // 0x0210 (528)
0x31A6, 0x4208, 0x4A49, 0x4A69, 0x528A, 0x5ACB, 0x632C, 0x6B6D, 0x738E, 0x73AE, 0x7BCF, 0x7BCF, 0x6B6D, 0x528A, 0x2965, 0x0861,   // 0x0220 (544)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0230 (560)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0240 (576)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0250 (592)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0841, 0x0841,   // 0x0260 (608)
0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0841, 0x0861, 0x1082, 0x10A2, 0x18C3, 0x2104, 0x2124, 0x2965, 0x31A6, 0x39C7,   // 0x0270 (624)
0x4228, 0x4A69, 0x52AA, 0x5ACB, 0x5ACB, 0x5ACB, 0x632C, 0x738E, 0x738E, 0x73AE, 0x7BCF, 0x7BCF, 0x7BCF, 0x738E, 0x5AEB, 0x2965,   // 0x0280 (640)
0x0841, 0x0000, 0x0000, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0290 (656)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x02A0 (672)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x02B0 (688)
0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x02C0 (704)
0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2945, 0x2965, 0x39C7, 0x4208,   // 0x02D0 (720)
0x4A49, 0x52AA, 0x5AEB, 0x632C, 0x632C, 0x6B4D, 0x738E, 0x73AE, 0x73AE, 0x73AE, 0x7BCF, 0x8410, 0x8410, 0x8410, 0x7BCF, 0x52AA,   // 0x02E0 (736)
0x2124, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x02F0 (752)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0300 (768)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0310 (784)
0x0020, 0x0020, 0x0020, 0x0841, 0x0841, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0320 (800)
0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x2124, 0x2965, 0x3186, 0x31A6, 0x39E7,   // 0x0330 (816)
0x4A69, 0x52AA, 0x5AEB, 0x6B4D, 0x738E, 0x7BCF, 0x7BCF, 0x73AE, 0x73AE, 0x73AE, 0x7BCF, 0x8410, 0x8410, 0x8430, 0x8410, 0x738E,   // 0x0340 (832)
0x4228, 0x1082, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0350 (848)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0360 (864)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020,   // 0x0370 (880)
0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0380 (896)
0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x2104, 0x2124, 0x2124, 0x2124, 0x2965, 0x39C7,   // 0x0390 (912)
0x4A49, 0x52AA, 0x630C, 0x6B6D, 0x73AE, 0x7BCF, 0x7BEF, 0x7BCF, 0x738E, 0x73AE, 0x7BCF, 0x7BEF, 0x7BEF, 0x8410, 0x8430, 0x7BEF,   // 0x03A0 (928)
0x630C, 0x2945, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x03B0 (944)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x03C0 (960)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0841,   // 0x03D0 (976)
0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x03E0 (992)
0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2945, 0x3186, 0x39C7,   // 0x03F0 (1008)
0x4A69, 0x5AEB, 0x6B4D, 0x738E, 0x7BCF, 0x7BEF, 0x8410, 0x7BEF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BEF, 0x8410, 0x8430, 0x8410, 0x8430,   // 0x0400 (1024)
0x73AE, 0x4208, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0410 (1040)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0420 (1056)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020,   // 0x0430 (1072)
0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861,   // 0x0440 (1088)
0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x2124, 0x2965, 0x3186, 0x4208,   // 0x0450 (1104)
0x4A69, 0x52AA, 0x630C, 0x738E, 0x7BCF, 0x8C51, 0x8C71, 0x8410, 0x7BEF, 0x7BEF, 0x7BCF, 0x8410, 0x8C51, 0x8430, 0x8430, 0x8430,   // 0x0460 (1120)
0x7BEF, 0x528A, 0x1082, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0470 (1136)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0480 (1152)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0841,   // 0x0490 (1168)
0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082,   // 0x04A0 (1184)
0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x2124, 0x2945, 0x3186, 0x39C7,   // 0x04B0 (1200)
0x4228, 0x5ACB, 0x632C, 0x632C, 0x73AE, 0x94B2, 0x94B2, 0x9492, 0x8C51, 0x8410, 0x7BEF, 0x8410, 0x8430, 0x8C51, 0x8C51, 0x8430,   // 0x04C0 (1216)
0x7BEF, 0x5ACB, 0x18C3, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x04D0 (1232)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x04E0 (1248)
0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0020, 0x0841, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x04F0 (1264)
0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0500 (1280)
0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x2104, 0x2124, 0x2965, 0x3186, 0x4208,   // 0x0510 (1296)
0x4A69, 0x52AA, 0x5AEB, 0x6B6D, 0x8430, 0x94B2, 0x94B2, 0x9CD3, 0x94B2, 0x8430, 0x7BCF, 0x7BEF, 0x8410, 0x8C51, 0x8430, 0x8410,   // 0x0520 (1312)
0x7BCF, 0x5AEB, 0x2104, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0530 (1328)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0540 (1344)
0x0000, 0x0000, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861,   // 0x0550 (1360)
0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0560 (1376)
0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18E3, 0x2104, 0x2945, 0x3186, 0x39E7, 0x4A49,   // 0x0570 (1392)
0x528A, 0x5AEB, 0x73AE, 0x7BEF, 0x8430, 0x7BEF, 0x8430, 0x9CF3, 0x94B2, 0x8430, 0x7BCF, 0x8410, 0x8C51, 0x8430, 0x8410, 0x7BEF,   // 0x0580 (1408)
0x73AE, 0x5AEB, 0x2104, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0590 (1424)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x05A0 (1440)
0x0841, 0x0841, 0x0861, 0x0861, 0x0841, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861,   // 0x05B0 (1456)
0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x0861,   // 0x05C0 (1472)
0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x2124, 0x2965, 0x39C7, 0x4228, 0x4A69,   // 0x05D0 (1488)
0x5ACB, 0x6B6D, 0x7BCF, 0x7BEF, 0x8430, 0x8C51, 0x9CD3, 0x9CF3, 0x94B2, 0x8C71, 0x8430, 0x8430, 0x8C71, 0x8C51, 0x8410, 0x7BCF,   // 0x05E0 (1504)
0x73AE, 0x5AEB, 0x2104, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x05F0 (1520)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x0861,   // 0x0600 (1536)
0x0841, 0x0861, 0x0841, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0610 (1552)
0x0861, 0x0861, 0x0861, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0620 (1568)
0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18E3, 0x2104, 0x2945, 0x3186, 0x39E7, 0x4A49, 0x52AA,   // 0x0630 (1584)
0x630C, 0x6B6D, 0x73AE, 0x7BEF, 0x9492, 0x9CD3, 0xA514, 0xAD55, 0x9CF3, 0x8C51, 0x8430, 0x8C51, 0x8430, 0x8410, 0x8410, 0x7BCF,   // 0x0640 (1600)
0x738E, 0x52AA, 0x18C3, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0650 (1616)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861,   // 0x0660 (1632)
0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0670 (1648)
0x0861, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082,   // 0x0680 (1664)
0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x18C3, 0x18E3, 0x18E3, 0x2124, 0x2965, 0x39C7, 0x4228, 0x528A, 0x5ACB,   // 0x0690 (1680)
0x632C, 0x738E, 0x73AE, 0x8C51, 0xA514, 0xA534, 0xB5B6, 0xA514, 0x8C71, 0x8C51, 0x8430, 0x8C51, 0x8430, 0x8430, 0x8410, 0x73AE,   // 0x06A0 (1696)
0x6B6D, 0x528A, 0x1082, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x06B0 (1712)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0841, 0x0861, 0x0861, 0x0841,   // 0x06C0 (1728)
0x0841, 0x0841, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x06D0 (1744)
0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x0861,   // 0x06E0 (1760)
0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18E3, 0x2124, 0x2965, 0x31A6, 0x39E7, 0x4A49, 0x528A, 0x5AEB,   // 0x06F0 (1776)
0x6B4D, 0x73AE, 0x8410, 0x94B2, 0xAD55, 0xB596, 0xAD75, 0x9CD3, 0x9492, 0x8C71, 0x8C71, 0x8430, 0x8410, 0x8410, 0x73AE, 0x738E,   // 0x0700 (1792)
0x6B6D, 0x4228, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0710 (1808)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0861, 0x0861, 0x0861, 0x1082, 0x0861, 0x0841, 0x0841,   // 0x0720 (1824)
0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082,   // 0x0730 (1840)
0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x1082, 0x0861, 0x0861,   // 0x0740 (1856)
0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x2104, 0x2945, 0x3186, 0x39C7, 0x4208, 0x4A69, 0x5ACB, 0x632C,   // 0x0750 (1872)
0x738E, 0x7BEF, 0x8C51, 0xA534, 0xAD75, 0xAD75, 0xAD75, 0x9CF3, 0x9492, 0x8C71, 0x8C51, 0x8410, 0x8410, 0x7BEF, 0x73AE, 0x738E,   // 0x0760 (1888)
0x632C, 0x31A6, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0770 (1904)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x0780 (1920)
0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x1082,   // 0x0790 (1936)
0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x1082, 0x0861, 0x0861, 0x0861,   // 0x07A0 (1952)
0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18E3, 0x2124, 0x2965, 0x31A6, 0x39E7, 0x4A69, 0x52AA, 0x632C, 0x738E,   // 0x07B0 (1968)
0x7BCF, 0x8C71, 0xA514, 0xA534, 0xAD75, 0xAD75, 0x9CF3, 0x9CF3, 0x9492, 0x8C51, 0x8430, 0x7BEF, 0x7BEF, 0x7BEF, 0x73AE, 0x738E,   // 0x07C0 (1984)
0x630C, 0x2124, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x07D0 (2000)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x07E0 (2016)
0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861,   // 0x07F0 (2032)
0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0800 (2048)
0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18E3, 0x2104, 0x2945, 0x3186, 0x39C7, 0x4A49, 0x52AA, 0x632C, 0x738E, 0x7BCF,   // 0x0810 (2064)
0x8C71, 0xA514, 0xAD55, 0xB596, 0xAD75, 0x9CF3, 0x9CF3, 0x94B2, 0x8C71, 0x8430, 0x7BEF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x738E,   // 0x0820 (2080)
0x52AA, 0x1082, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0830 (2096)
0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x0840 (2112)
0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082,   // 0x0850 (2128)
0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x1082,   // 0x0860 (2144)
0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x2104, 0x2124, 0x2965, 0x39C7, 0x4228, 0x52AA, 0x632C, 0x738E, 0x7BEF, 0x8C51,   // 0x0870 (2160)
0x9CF3, 0xAD55, 0xB596, 0xAD75, 0xA514, 0x9CF3, 0x9CD3, 0x9CF3, 0x94B2, 0x8430, 0x7BCF, 0x73AE, 0x738E, 0x73AE, 0x73AE, 0x6B6D,   // 0x0880 (2176)
0x4208, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0890 (2192)
0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x08A0 (2208)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x08B0 (2224)
0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082,   // 0x08C0 (2240)
0x10A2, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x2104, 0x2945, 0x31A6, 0x4208, 0x528A, 0x630C, 0x6B6D, 0x7BCF, 0x8430, 0x94B2,   // 0x08D0 (2256)
0xA514, 0xAD75, 0xB596, 0xAD75, 0xAD55, 0xA514, 0xA534, 0xAD55, 0x94B2, 0x8430, 0x7BCF, 0x6B6D, 0x6B6D, 0x6B6D, 0x73AE, 0x632C,   // 0x08E0 (2272)
0x2124, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x08F0 (2288)
0x0841, 0x0861, 0x0841, 0x0841, 0x0861, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861,   // 0x0900 (2304)
0x0841, 0x0841, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2,   // 0x0910 (2320)
0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x10A2,   // 0x0920 (2336)
0x10A2, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x2124, 0x2965, 0x39E7, 0x4A49, 0x52AA, 0x632C, 0x73AE, 0x8410, 0x94B2, 0xA534,   // 0x0930 (2352)
0xAD75, 0xAD75, 0xAD75, 0xAD75, 0xA534, 0xA514, 0xA514, 0x9CF3, 0x8C71, 0x7BEF, 0x738E, 0x632C, 0x6B4D, 0x738E, 0x73AE, 0x528A,   // 0x0940 (2368)
0x0861, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0861,   // 0x0950 (2384)
0x0841, 0x0020, 0x0841, 0x1082, 0x1082, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0841, 0x0841,   // 0x0960 (2400)
0x0841, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x0970 (2416)
0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082,   // 0x0980 (2432)
0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2945, 0x2965, 0x39C7, 0x4228, 0x5ACB, 0x632C, 0x6B4D, 0x7BCF, 0x8C71, 0x94B2, 0xA534,   // 0x0990 (2448)
0xB596, 0xB596, 0xB5B6, 0xB5B6, 0xAD75, 0xA514, 0x9CF3, 0x9492, 0x8410, 0x7BCF, 0x6B6D, 0x632C, 0x6B6D, 0x73AE, 0x6B4D, 0x2965,   // 0x09A0 (2464)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x0861, 0x0861,   // 0x09B0 (2480)
0x0841, 0x1082, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861,   // 0x09C0 (2496)
0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x09D0 (2512)
0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2,   // 0x09E0 (2528)
0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2945, 0x3186, 0x39C7, 0x4208, 0x5ACB, 0x630C, 0x632C, 0x7BCF, 0x8C71, 0x9CD3, 0xAD55, 0xB5B6,   // 0x09F0 (2544)
0xB5B6, 0xB5B6, 0xBDD7, 0xBDD7, 0xAD75, 0xA534, 0x9CF3, 0x9492, 0x8410, 0x7BCF, 0x6B4D, 0x6B4D, 0x738E, 0x738E, 0x528A, 0x0861,   // 0x0A00 (2560)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x1082,   // 0x0A10 (2576)
0x1082, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x1082,   // 0x0A20 (2592)
0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2,   // 0x0A30 (2608)
0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x18C3,   // 0x0A40 (2624)
0x18C3, 0x18E3, 0x2104, 0x2124, 0x2965, 0x39C7, 0x4208, 0x528A, 0x5ACB, 0x5AEB, 0x738E, 0x8C51, 0x9CD3, 0xAD55, 0xB5B6, 0xB5B6,   // 0x0A50 (2640)
0xAD75, 0xB596, 0xB596, 0xAD75, 0xAD55, 0x9CF3, 0x9CD3, 0x9492, 0x8430, 0x73AE, 0x6B6D, 0x738E, 0x738E, 0x632C, 0x2124, 0x0000,   // 0x0A60 (2656)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082,   // 0x0A70 (2672)
0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x1082,   // 0x0A80 (2688)
0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x0A90 (2704)
0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x18C3, 0x18C3,   // 0x0AA0 (2720)
0x18E3, 0x18E3, 0x2104, 0x2945, 0x31A6, 0x4208, 0x4A69, 0x52AA, 0x5AEB, 0x6B6D, 0x8430, 0x9CF3, 0xA514, 0xAD75, 0xAD75, 0xB596,   // 0x0AB0 (2736)
0xB596, 0xB596, 0xAD75, 0xA534, 0x9CD3, 0x8C71, 0x8C71, 0x8410, 0x7BCF, 0x7BEF, 0x7BCF, 0x73AE, 0x6B6D, 0x4228, 0x0020, 0x0000,   // 0x0AC0 (2752)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082,   // 0x0AD0 (2768)
0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082,   // 0x0AE0 (2784)
0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2,   // 0x0AF0 (2800)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x18C3, 0x18C3, 0x18E3,   // 0x0B00 (2816)
0x18E3, 0x2104, 0x2124, 0x3186, 0x39E7, 0x4228, 0x528A, 0x5AEB, 0x6B6D, 0x8430, 0x94B2, 0x8C71, 0x8C51, 0x9492, 0xAD55, 0xB5B6,   // 0x0B10 (2832)
0xAD75, 0xAD55, 0xA514, 0x9CF3, 0x94B2, 0x9492, 0x8430, 0x8C51, 0x8430, 0x7BEF, 0x73AE, 0x6B6D, 0x5AEB, 0x18E3, 0x0000, 0x0000,   // 0x0B20 (2848)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861,   // 0x0B30 (2864)
0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082,   // 0x0B40 (2880)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2,   // 0x0B50 (2896)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18E3,   // 0x0B60 (2912)
0x2104, 0x2104, 0x2945, 0x39C7, 0x4208, 0x4A49, 0x5ACB, 0x6B6D, 0x7BCF, 0x7BCF, 0x73AE, 0x7BEF, 0x7BEF, 0x9492, 0xAD75, 0xB596,   // 0x0B70 (2928)
0xA534, 0x9CD3, 0x9CD3, 0x94B2, 0x9492, 0x8C71, 0x8C71, 0x8C51, 0x7BEF, 0x7BCF, 0x738E, 0x632C, 0x31A6, 0x0000, 0x0000, 0x0000,   // 0x0B80 (2944)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861,   // 0x0B90 (2960)
0x0861, 0x0841, 0x0861, 0x0861, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082,   // 0x0BA0 (2976)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x10A2,   // 0x0BB0 (2992)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18E3, 0x18E3,   // 0x0BC0 (3008)
0x2104, 0x2124, 0x31A6, 0x4228, 0x4A49, 0x528A, 0x5AEB, 0x6B4D, 0x6B4D, 0x738E, 0x8410, 0x8410, 0x8410, 0x9CD3, 0xB596, 0xAD55,   // 0x0BD0 (3024)
0x94B2, 0x9492, 0x9CD3, 0xA514, 0x94B2, 0x8C51, 0x8C51, 0x8430, 0x7BEF, 0x738E, 0x632C, 0x4A69, 0x1082, 0x0000, 0x0000, 0x0000,   // 0x0BE0 (3040)
0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x0861, 0x0861, 0x1082, 0x1082,   // 0x0BF0 (3056)
0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082,   // 0x0C00 (3072)
0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x0C10 (3088)
0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x2124,   // 0x0C20 (3104)
0x2945, 0x31A6, 0x39E7, 0x4A49, 0x4A69, 0x528A, 0x630C, 0x632C, 0x6B4D, 0x7BCF, 0x8410, 0x8410, 0x8C71, 0xA534, 0xA534, 0x8C71,   // 0x0C30 (3120)
0x9492, 0x9CD3, 0xA514, 0x9CD3, 0x9492, 0x8430, 0x8C51, 0x8410, 0x738E, 0x6B4D, 0x5AEB, 0x2124, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0C40 (3136)
0x0000, 0x0000, 0x0000, 0x0841, 0x0841, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x0861,   // 0x0C50 (3152)
0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082,   // 0x0C60 (3168)
0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x0C70 (3184)
0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x2124, 0x2965,   // 0x0C80 (3200)
0x3186, 0x39C7, 0x4208, 0x4228, 0x4A69, 0x5AEB, 0x630C, 0x6B4D, 0x73AE, 0x7BEF, 0x8410, 0x8C71, 0x9CD3, 0xA534, 0x94B2, 0x94B2,   // 0x0C90 (3216)
0x9492, 0x9492, 0x9CD3, 0x94B2, 0x8430, 0x8430, 0x8410, 0x7BCF, 0x6B6D, 0x630C, 0x39C7, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0CA0 (3232)
0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861,   // 0x0CB0 (3248)
0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x0CC0 (3264)
0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x0CD0 (3280)
0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2104, 0x2945, 0x3186,   // 0x0CE0 (3296)
0x31A6, 0x31A6, 0x39E7, 0x4A69, 0x5ACB, 0x630C, 0x6B4D, 0x73AE, 0x7BCF, 0x8410, 0x8430, 0x8C71, 0x9CF3, 0x9CF3, 0x94B2, 0x94B2,   // 0x0CF0 (3312)
0x9CD3, 0x9CD3, 0x9492, 0x8C51, 0x8410, 0x7BEF, 0x7BEF, 0x73AE, 0x630C, 0x4A49, 0x0861, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0D00 (3328)
0x0020, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x0861,   // 0x0D10 (3344)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x0D20 (3360)
0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082,   // 0x0D30 (3376)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2124, 0x2945, 0x2945,   // 0x0D40 (3392)
0x2965, 0x39C7, 0x4A49, 0x52AA, 0x5AEB, 0x632C, 0x6B6D, 0x73AE, 0x7BCF, 0x7BEF, 0x8430, 0x9492, 0x8C71, 0x8430, 0x8C71, 0x94B2,   // 0x0D50 (3408)
0x94B2, 0x8C71, 0x8C71, 0x8410, 0x7BEF, 0x7BEF, 0x73AE, 0x630C, 0x52AA, 0x2104, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x0D60 (3424)
0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861,   // 0x0D70 (3440)
0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x0D80 (3456)
0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x1082,   // 0x0D90 (3472)
0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2965,   // 0x0DA0 (3488)
0x39C7, 0x4208, 0x528A, 0x5AEB, 0x632C, 0x738E, 0x73AE, 0x7BCF, 0x8410, 0x8C51, 0x8C71, 0x8430, 0x8430, 0x9492, 0x94B2, 0x8C71,   // 0x0DB0 (3504)
0x8410, 0x8430, 0x8C71, 0x8430, 0x7BCF, 0x73AE, 0x632C, 0x5ACB, 0x3186, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861,   // 0x0DC0 (3520)
0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2,   // 0x0DD0 (3536)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x10A2,   // 0x0DE0 (3552)
0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x0861,   // 0x0DF0 (3568)
0x0841, 0x0841, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2124, 0x2965, 0x31A6,   // 0x0E00 (3584)
0x39E7, 0x4A69, 0x5ACB, 0x632C, 0x738E, 0x7BCF, 0x7BCF, 0x8C51, 0x8C51, 0x8410, 0x8410, 0x8C71, 0x9CF3, 0x9CD3, 0x8430, 0x7BEF,   // 0x0E10 (3600)
0x8430, 0x9492, 0x8C51, 0x8410, 0x73AE, 0x632C, 0x5AEB, 0x39E7, 0x0020, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x1082,   // 0x0E20 (3616)
0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x0861,   // 0x0E30 (3632)
0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082,   // 0x0E40 (3648)
0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x0861,   // 0x0E50 (3664)
0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x2104, 0x2124, 0x2945, 0x3186, 0x39E7,   // 0x0E60 (3680)
0x4A69, 0x52AA, 0x630C, 0x6B6D, 0x7BCF, 0x7BEF, 0x8430, 0x8430, 0x7BEF, 0x8410, 0x9CF3, 0xAD75, 0x9CD3, 0x8430, 0x8410, 0x9492,   // 0x0E70 (3696)
0x94B2, 0x8C51, 0x8430, 0x73AE, 0x6B4D, 0x5AEB, 0x4A49, 0x0861, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x1082, 0x10A2,   // 0x0E80 (3712)
0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861,   // 0x0E90 (3728)
0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2,   // 0x0EA0 (3744)
0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x0EB0 (3760)
0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x2124, 0x2965, 0x3186, 0x39E7, 0x4A49,   // 0x0EC0 (3776)
0x52AA, 0x630C, 0x738E, 0x7BCF, 0x7BEF, 0x8410, 0x7BEF, 0x7BCF, 0x7BEF, 0xA514, 0xB5B6, 0xA514, 0x8C71, 0x8C51, 0x8C71, 0x94B2,   // 0x0ED0 (3792)
0x8C51, 0x8410, 0x73AE, 0x6B4D, 0x632C, 0x4A69, 0x18C3, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x1082, 0x10A2, 0x10A2,   // 0x0EE0 (3808)
0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861,   // 0x0EF0 (3824)
0x0841, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2,   // 0x0F00 (3840)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x0F10 (3856)
0x1082, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x2104, 0x2945, 0x3186, 0x3186, 0x39C7, 0x4228, 0x5ACB,   // 0x0F20 (3872)
0x6B4D, 0x738E, 0x7BCF, 0x7BEF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x94B2, 0xB596, 0xA534, 0x9CF3, 0x9CF3, 0x8C71, 0x9492, 0x8C71,   // 0x0F30 (3888)
0x8410, 0x7BCF, 0x6B6D, 0x632C, 0x528A, 0x2104, 0x0000, 0x0000, 0x0000, 0x0841, 0x0841, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x0F40 (3904)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x0861, 0x0861, 0x0861,   // 0x0F50 (3920)
0x0861, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x1082,   // 0x0F60 (3936)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x0F70 (3952)
0x1082, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x2104, 0x2104, 0x2104, 0x2124, 0x3186, 0x3186, 0x39C7, 0x4A49, 0x5AEB, 0x6B4D,   // 0x0F80 (3968)
0x6B4D, 0x738E, 0x73AE, 0x73AE, 0x7BEF, 0x73AE, 0x73AE, 0x8C71, 0xAD55, 0xAD55, 0xAD55, 0xAD55, 0x9CD3, 0x9CD3, 0x9CD3, 0x8C51,   // 0x0F90 (3984)
0x7BEF, 0x738E, 0x632C, 0x5ACB, 0x2965, 0x0000, 0x0000, 0x0000, 0x0841, 0x0841, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x0FA0 (4000)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x1082, 0x10A2, 0x0861, 0x1082, 0x1082, 0x0861, 0x0841, 0x0861, 0x0861,   // 0x0FB0 (4016)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2,   // 0x0FC0 (4032)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082,   // 0x0FD0 (4048)
0x1082, 0x0861, 0x0861, 0x0861, 0x1082, 0x18E3, 0x2104, 0x2104, 0x2124, 0x3186, 0x3186, 0x39E7, 0x4A49, 0x5ACB, 0x5AEB, 0x632C,   // 0x0FE0 (4064)
0x6B4D, 0x738E, 0x7BCF, 0x7BEF, 0x73AE, 0x738E, 0x9492, 0xAD75, 0xB596, 0xB596, 0xAD55, 0xA534, 0x9CF3, 0x94B2, 0x8C51, 0x7BEF,   // 0x0FF0 (4080)
0x73AE, 0x6B4D, 0x5AEB, 0x31A6, 0x0000, 0x0000, 0x0000, 0x0841, 0x0841, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2,   // 0x1000 (4096)
0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x1010 (4112)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2,   // 0x1020 (4128)
0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x1082,   // 0x1030 (4144)
0x0861, 0x0861, 0x0861, 0x10A2, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x3186, 0x4208, 0x39E7, 0x4228, 0x528A, 0x5AEB, 0x632C, 0x6B4D,   // 0x1040 (4160)
0x738E, 0x7BCF, 0x7BCF, 0x73AE, 0x8410, 0x9CD3, 0xB596, 0xB5B6, 0xB5B6, 0xAD75, 0xAD55, 0x9CF3, 0x94B2, 0x8C71, 0x7BEF, 0x73AE,   // 0x1050 (4176)
0x6B6D, 0x630C, 0x39C7, 0x0020, 0x0000, 0x0000, 0x0841, 0x0841, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x1060 (4192)
0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082,   // 0x1070 (4208)
0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x1080 (4224)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082,   // 0x1090 (4240)
0x1082, 0x1082, 0x10A2, 0x10A2, 0x18E3, 0x18E3, 0x2124, 0x3186, 0x4A49, 0x4A49, 0x4228, 0x528A, 0x5ACB, 0x632C, 0x6B6D, 0x73AE,   // 0x10A0 (4256)
0x7BCF, 0x73AE, 0x7BCF, 0x94B2, 0xA534, 0xB5B6, 0xBDD7, 0xB596, 0xAD75, 0xAD55, 0xA514, 0x9CD3, 0x9492, 0x7BEF, 0x73AE, 0x738E,   // 0x10B0 (4272)
0x630C, 0x39E7, 0x0841, 0x0000, 0x0000, 0x0841, 0x0841, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x10C0 (4288)
0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2,   // 0x10D0 (4304)
0x10A2, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x10A2,   // 0x10E0 (4320)
0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082,   // 0x10F0 (4336)
0x1082, 0x10A2, 0x10A2, 0x18C3, 0x2104, 0x2945, 0x3186, 0x39E7, 0x4A49, 0x528A, 0x528A, 0x52AA, 0x630C, 0x738E, 0x73AE, 0x7BCF,   // 0x1100 (4352)
0x7BCF, 0x8430, 0x9CD3, 0xAD55, 0xBDD7, 0xC618, 0xBDD7, 0xAD75, 0xAD55, 0xA534, 0x9CD3, 0x9492, 0x8410, 0x7BCF, 0x738E, 0x630C,   // 0x1110 (4368)
0x4208, 0x0841, 0x0000, 0x0000, 0x0841, 0x0841, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861,   // 0x1120 (4384)
0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082,   // 0x1130 (4400)
0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1140 (4416)
0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x1150 (4432)
0x18C3, 0x18E3, 0x18E3, 0x2124, 0x2965, 0x3186, 0x39C7, 0x4228, 0x52AA, 0x5AEB, 0x52AA, 0x5AEB, 0x6B4D, 0x738E, 0x73AE, 0x73AE,   // 0x1160 (4448)
0x8C51, 0xA534, 0xAD55, 0xB5B6, 0xBDF7, 0xB5B6, 0xAD75, 0xAD55, 0xA514, 0x9CD3, 0x8C71, 0x8410, 0x7BCF, 0x738E, 0x630C, 0x4228,   // 0x1170 (4464)
0x0841, 0x0000, 0x0000, 0x0841, 0x0841, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861,   // 0x1180 (4480)
0x0861, 0x0861, 0x0861, 0x0841, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x1082,   // 0x1190 (4496)
0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x11A0 (4512)
0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x18C3,   // 0x11B0 (4528)
0x18E3, 0x18E3, 0x2124, 0x2965, 0x2945, 0x3186, 0x39E7, 0x4228, 0x4A69, 0x630C, 0x630C, 0x6B4D, 0x738E, 0x73AE, 0x8430, 0x9CD3,   // 0x11C0 (4544)
0xAD55, 0xAD55, 0xAD75, 0xB596, 0xB596, 0xB596, 0xA514, 0x9CF3, 0x9CF3, 0x9492, 0x8410, 0x7BCF, 0x6B6D, 0x5AEB, 0x4208, 0x0841,   // 0x11D0 (4560)
0x0000, 0x0020, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861,   // 0x11E0 (4576)
0x0861, 0x0861, 0x0841, 0x0861, 0x1082, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082,   // 0x11F0 (4592)
0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1200 (4608)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3,   // 0x1210 (4624)
0x2104, 0x2124, 0x2945, 0x2945, 0x2965, 0x3186, 0x39C7, 0x4228, 0x630C, 0x632C, 0x6B6D, 0x73AE, 0x73AE, 0x8C71, 0xA534, 0xAD55,   // 0x1220 (4640)
0xAD55, 0xA514, 0xA534, 0xB596, 0xAD55, 0xA514, 0x9CF3, 0x9CF3, 0x8C71, 0x8410, 0x7BCF, 0x6B4D, 0x5ACB, 0x4228, 0x0861, 0x0000,   // 0x1230 (4656)
0x0020, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x1082, 0x10A2, 0x0861, 0x0861, 0x0861,   // 0x1240 (4672)
0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x1250 (4688)
0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1260 (4704)
0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x18E3, 0x2104, 0x2104,   // 0x1270 (4720)
0x2104, 0x2124, 0x2945, 0x2965, 0x31A6, 0x39E7, 0x4228, 0x528A, 0x5ACB, 0x632C, 0x6B6D, 0x738E, 0x8430, 0x9CF3, 0x9CF3, 0x9CF3,   // 0x1280 (4736)
0x94B2, 0x94B2, 0xAD75, 0xAD55, 0x9CF3, 0x9492, 0x8C71, 0x8C51, 0x8410, 0x7BCF, 0x6B4D, 0x5ACB, 0x4208, 0x0841, 0x0000, 0x0020,   // 0x1290 (4752)
0x0841, 0x0841, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861,   // 0x12A0 (4768)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x12B0 (4784)
0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x12C0 (4800)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18E3, 0x2104, 0x2104, 0x2104,   // 0x12D0 (4816)
0x2104, 0x2104, 0x2945, 0x31A6, 0x39E7, 0x4228, 0x528A, 0x5AEB, 0x632C, 0x6B4D, 0x6B6D, 0x8410, 0x94B2, 0x9492, 0x8C71, 0x9492,   // 0x12E0 (4832)
0xA534, 0xB596, 0x9CF3, 0x8C71, 0x8C71, 0x8C51, 0x8C51, 0x7BEF, 0x6B6D, 0x6B4D, 0x5ACB, 0x4208, 0x0841, 0x0000, 0x0000, 0x0841,   // 0x12F0 (4848)
0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x1300 (4864)
0x1082, 0x1082, 0x10A2, 0x1082, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x1310 (4880)
0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1320 (4896)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x18E3, 0x18E3,   // 0x1330 (4912)
0x2104, 0x2945, 0x3186, 0x39C7, 0x4228, 0x52AA, 0x5AEB, 0x632C, 0x6B4D, 0x6B6D, 0x7BEF, 0x8C51, 0x8430, 0x8C51, 0x8C71, 0xAD55,   // 0x1340 (4928)
0xB596, 0x9CD3, 0x94B2, 0x9492, 0x8430, 0x8410, 0x73AE, 0x6B6D, 0x6B4D, 0x5AEB, 0x39E7, 0x0020, 0x0000, 0x0000, 0x0841, 0x0861,   // 0x1350 (4944)
0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x1360 (4960)
0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x0861,   // 0x1370 (4976)
0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1380 (4992)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x18E3, 0x18E3, 0x2124,   // 0x1390 (5008)
0x2965, 0x31A6, 0x39E7, 0x4A49, 0x5ACB, 0x632C, 0x6B4D, 0x738E, 0x6B6D, 0x73AE, 0x8410, 0x8410, 0x7BEF, 0x7BEF, 0x9492, 0xA534,   // 0x13A0 (5024)
0xA534, 0x9CF3, 0x9492, 0x8C51, 0x8410, 0x73AE, 0x6B6D, 0x632C, 0x5AEB, 0x31A6, 0x0020, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861,   // 0x13B0 (5040)
0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082,   // 0x13C0 (5056)
0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x0861,   // 0x13D0 (5072)
0x1082, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x13E0 (5088)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x18E3, 0x2104, 0x2945, 0x3186,   // 0x13F0 (5104)
0x39C7, 0x4208, 0x4A49, 0x5ACB, 0x632C, 0x6B4D, 0x6B6D, 0x6B6D, 0x6B6D, 0x73AE, 0x73AE, 0x738E, 0x8410, 0x94B2, 0xAD55, 0xAD55,   // 0x1400 (5120)
0x9CD3, 0x9492, 0x8430, 0x8410, 0x73AE, 0x632C, 0x5AEB, 0x5ACB, 0x3186, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861,   // 0x1410 (5136)
0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x1082, 0x1082,   // 0x1420 (5152)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x0861, 0x1082,   // 0x1430 (5168)
0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1440 (5184)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2945, 0x3186, 0x39E7,   // 0x1450 (5200)
0x4228, 0x4A49, 0x52AA, 0x5AEB, 0x630C, 0x632C, 0x6B4D, 0x6B4D, 0x738E, 0x738E, 0x738E, 0x9492, 0xA514, 0xAD55, 0xAD75, 0xA514,   // 0x1460 (5216)
0x9492, 0x7BCF, 0x6B4D, 0x5AEB, 0x5ACB, 0x5ACB, 0x528A, 0x2124, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861,   // 0x1470 (5232)
0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2,   // 0x1480 (5248)
0x1082, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x1082, 0x0861, 0x1082, 0x10A2, 0x10A2,   // 0x1490 (5264)
0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x14A0 (5280)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2124, 0x3186, 0x39C7, 0x4208,   // 0x14B0 (5296)
0x4A49, 0x528A, 0x5ACB, 0x630C, 0x632C, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x7BCF, 0x9CD3, 0xA514, 0xA534, 0xB596, 0xA534, 0x8C51,   // 0x14C0 (5312)
0x6B4D, 0x5AEB, 0x52AA, 0x4A69, 0x5ACB, 0x528A, 0x18E3, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861,   // 0x14D0 (5328)
0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x14E0 (5344)
0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18C3,   // 0x14F0 (5360)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1500 (5376)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2945, 0x3186, 0x39C7, 0x4208, 0x4A49,   // 0x1510 (5392)
0x52AA, 0x5AEB, 0x630C, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x632C, 0x8410, 0xA514, 0x9CF3, 0xA514, 0xB5B6, 0xA534, 0x7BEF, 0x630C,   // 0x1520 (5408)
0x5ACB, 0x52AA, 0x4A69, 0x528A, 0x4228, 0x10A2, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082,   // 0x1530 (5424)
0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3,   // 0x1540 (5440)
0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1550 (5456)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1560 (5472)
0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x2104, 0x2965, 0x3186, 0x39C7, 0x4228, 0x4A69, 0x5ACB,   // 0x1570 (5488)
0x630C, 0x630C, 0x632C, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x7BCF, 0x9CF3, 0x9CF3, 0xA514, 0xAD75, 0x9CF3, 0x738E, 0x5ACB, 0x528A,   // 0x1580 (5504)
0x4A69, 0x4228, 0x4A49, 0x39C7, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082,   // 0x1590 (5520)
0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x10A2,   // 0x15A0 (5536)
0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x15B0 (5552)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x15C0 (5568)
0x18C3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2124, 0x2124, 0x2104, 0x2124, 0x2965, 0x31A6, 0x39E7, 0x4A49, 0x528A, 0x5ACB, 0x630C,   // 0x15D0 (5584)
0x632C, 0x632C, 0x632C, 0x6B6D, 0x738E, 0x738E, 0x6B6D, 0x8430, 0x9CF3, 0xA534, 0xA534, 0x8C51, 0x6B4D, 0x52AA, 0x528A, 0x4228,   // 0x15E0 (5600)
0x39E7, 0x4228, 0x3186, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082,   // 0x15F0 (5616)
0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2,   // 0x1600 (5632)
0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1610 (5648)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1620 (5664)
0x18E3, 0x18E3, 0x2104, 0x2124, 0x2124, 0x2124, 0x2945, 0x2945, 0x2965, 0x31A6, 0x4208, 0x4A69, 0x5ACB, 0x630C, 0x632C, 0x6B4D,   // 0x1630 (5680)
0x6B6D, 0x6B4D, 0x6B4D, 0x738E, 0x73AE, 0x73AE, 0x7BEF, 0x9CD3, 0xAD55, 0xA534, 0x7BCF, 0x5ACB, 0x528A, 0x4A49, 0x4208, 0x39C7,   // 0x1640 (5696)
0x4208, 0x2124, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082,   // 0x1650 (5712)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18C3, 0x18C3, 0x10A2,   // 0x1660 (5728)
0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1670 (5744)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3,   // 0x1680 (5760)
0x2104, 0x2104, 0x2124, 0x2945, 0x2965, 0x3186, 0x2965, 0x3186, 0x39C7, 0x4228, 0x4A69, 0x5ACB, 0x632C, 0x6B4D, 0x738E, 0x73AE,   // 0x1690 (5776)
0x738E, 0x6B6D, 0x7BEF, 0x9492, 0x8C71, 0x8430, 0x9492, 0xA514, 0x9CD3, 0x6B6D, 0x5ACB, 0x4A69, 0x4228, 0x39E7, 0x39C7, 0x4208,   // 0x16A0 (5792)
0x10A2, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2,   // 0x16B0 (5808)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2,   // 0x16C0 (5824)
0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x16D0 (5840)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3,   // 0x16E0 (5856)
0x18E3, 0x2104, 0x2124, 0x2945, 0x3186, 0x2965, 0x31A6, 0x39E7, 0x4208, 0x4A69, 0x632C, 0x738E, 0x6B6D, 0x73AE, 0x73AE, 0x738E,   // 0x16F0 (5872)
0x73AE, 0x7BEF, 0x8C51, 0x8C51, 0x8C51, 0x9CD3, 0xA514, 0x8C71, 0x6B4D, 0x528A, 0x4A69, 0x4208, 0x39C7, 0x39E7, 0x39C7, 0x0841,   // 0x1700 (5888)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2,   // 0x1710 (5904)
0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1720 (5920)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1730 (5936)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3,   // 0x1740 (5952)
0x18E3, 0x2104, 0x2124, 0x2965, 0x2965, 0x31A6, 0x4208, 0x52AA, 0x6B6D, 0x8C51, 0x8C51, 0x738E, 0x6B6D, 0x6B6D, 0x73AE, 0x73AE,   // 0x1750 (5968)
0x73AE, 0x8410, 0x7BEF, 0x7BEF, 0x9CD3, 0x9CD3, 0x8C51, 0x632C, 0x4A69, 0x4228, 0x39E7, 0x39E7, 0x4228, 0x2965, 0x0000, 0x0000,   // 0x1760 (5984)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2,   // 0x1770 (6000)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1780 (6016)
0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2,   // 0x1790 (6032)
0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2104,   // 0x17A0 (6048)
0x2104, 0x2124, 0x2965, 0x31A6, 0x39E7, 0x4A69, 0x6B4D, 0x7BEF, 0x8C71, 0x8C71, 0x73AE, 0x6B4D, 0x6B6D, 0x7BCF, 0x7BCF, 0x8430,   // 0x17B0 (6064)
0x8C71, 0x8430, 0x7BCF, 0x9492, 0x94B2, 0x8C51, 0x632C, 0x4A69, 0x4208, 0x4208, 0x4A69, 0x4228, 0x18C3, 0x0000, 0x0000, 0x0000,   // 0x17C0 (6080)
0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2,   // 0x17D0 (6096)
0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x17E0 (6112)
0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x17F0 (6128)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x18E3, 0x2104, 0x2124,   // 0x1800 (6144)
0x2945, 0x2965, 0x39C7, 0x4A49, 0x5AEB, 0x6B6D, 0x7BCF, 0x8410, 0x8C71, 0x8C71, 0x7BCF, 0x73AE, 0x8410, 0x8C51, 0x8C51, 0x8C71,   // 0x1810 (6160)
0x8C51, 0x7BCF, 0x8C51, 0x8C71, 0x8410, 0x6B6D, 0x52AA, 0x4A69, 0x528A, 0x52AA, 0x39C7, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1820 (6176)
0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0841, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x1830 (6192)
0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3,   // 0x1840 (6208)
0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1850 (6224)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2124, 0x2945, 0x2945,   // 0x1860 (6240)
0x3186, 0x39E7, 0x528A, 0x630C, 0x6B6D, 0x7BCF, 0x8C51, 0x9492, 0x94B2, 0x8C71, 0x8430, 0x8C51, 0x8C51, 0x7BEF, 0x7BEF, 0x73AE,   // 0x1870 (6256)
0x6B6D, 0x8410, 0x8C51, 0x7BEF, 0x738E, 0x6B4D, 0x5AEB, 0x5ACB, 0x4A69, 0x2124, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1880 (6272)
0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x1890 (6288)
0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18E3, 0x18E3, 0x18E3,   // 0x18A0 (6304)
0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x18B0 (6320)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2124, 0x2945, 0x2945, 0x2965, 0x39C7,   // 0x18C0 (6336)
0x4228, 0x52AA, 0x632C, 0x738E, 0x7BEF, 0x8C51, 0x9492, 0x9492, 0x94B2, 0x8430, 0x73AE, 0x738E, 0x7BCF, 0x6B6D, 0x632C, 0x630C,   // 0x18D0 (6352)
0x7BEF, 0x8430, 0x7BCF, 0x6B4D, 0x630C, 0x5ACB, 0x52AA, 0x39E7, 0x0861, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x18E0 (6368)
0x0000, 0x0000, 0x0000, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2,   // 0x18F0 (6384)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3,   // 0x1900 (6400)
0x18C3, 0x18C3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1910 (6416)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2124, 0x2945, 0x2945, 0x31A6, 0x39E7, 0x4A69,   // 0x1920 (6432)
0x5AEB, 0x6B4D, 0x7BCF, 0x8410, 0x8430, 0x9492, 0x8C71, 0x7BEF, 0x738E, 0x6B6D, 0x6B6D, 0x6B6D, 0x630C, 0x5AEB, 0x5AEB, 0x73AE,   // 0x1930 (6448)
0x8410, 0x7BCF, 0x6B4D, 0x52AA, 0x528A, 0x4A49, 0x2945, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1940 (6464)
0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3,   // 0x1950 (6480)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3,   // 0x1960 (6496)
0x18C3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1970 (6512)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2124, 0x2124, 0x2945, 0x3186, 0x39C7, 0x4208, 0x528A, 0x5AEB,   // 0x1980 (6528)
0x738E, 0x8430, 0x8C51, 0x8C51, 0x9492, 0x8C71, 0x738E, 0x738E, 0x738E, 0x6B6D, 0x6B4D, 0x632C, 0x5ACB, 0x52AA, 0x738E, 0x7BCF,   // 0x1990 (6544)
0x6B6D, 0x632C, 0x528A, 0x4228, 0x39E7, 0x1082, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x19A0 (6560)
0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x19B0 (6576)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x19C0 (6592)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x19D0 (6608)
0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x2124, 0x2124, 0x2124, 0x2965, 0x31A6, 0x39C7, 0x4208, 0x528A, 0x632C, 0x7BCF,   // 0x19E0 (6624)
0x8C71, 0x8C71, 0x8430, 0x8430, 0x8C51, 0x738E, 0x6B6D, 0x738E, 0x6B6D, 0x5AEB, 0x630C, 0x52AA, 0x528A, 0x5AEB, 0x6B6D, 0x632C,   // 0x19F0 (6640)
0x5AEB, 0x4228, 0x39E7, 0x2945, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1A00 (6656)
0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3,   // 0x1A10 (6672)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1A20 (6688)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1A30 (6704)
0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x2124, 0x2124, 0x2124, 0x2965, 0x3186, 0x39E7, 0x39E7, 0x4A69, 0x6B4D, 0x7BCF, 0x8C51,   // 0x1A40 (6720)
0x9492, 0x8C51, 0x7BEF, 0x7BCF, 0x6B6D, 0x6B6D, 0x6B4D, 0x630C, 0x5ACB, 0x5ACB, 0x528A, 0x4A69, 0x528A, 0x5AEB, 0x630C, 0x528A,   // 0x1A50 (6736)
0x4228, 0x39C7, 0x0861, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1A60 (6752)
0x0000, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3,   // 0x1A70 (6768)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1A80 (6784)
0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1A90 (6800)
0x18C3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2124, 0x2124, 0x2945, 0x2965, 0x31A6, 0x4208, 0x4A69, 0x6B4D, 0x7BEF, 0x9492, 0x9492,   // 0x1AA0 (6816)
0x8410, 0x73AE, 0x738E, 0x6B6D, 0x6B4D, 0x6B4D, 0x630C, 0x5AEB, 0x52AA, 0x528A, 0x528A, 0x52AA, 0x5ACB, 0x528A, 0x4A69, 0x4A49,   // 0x1AB0 (6832)
0x2104, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1AC0 (6848)
0x0020, 0x0841, 0x0861, 0x0841, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3,   // 0x1AD0 (6864)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1AE0 (6880)
0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1AF0 (6896)
0x18E3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2124, 0x2945, 0x3186, 0x39C7, 0x4A49, 0x528A, 0x6B4D, 0x8410, 0x9492, 0x94B2, 0x8C51,   // 0x1B00 (6912)
0x7BEF, 0x6B6D, 0x6B6D, 0x6B4D, 0x630C, 0x5AEB, 0x5AEB, 0x52AA, 0x52AA, 0x52AA, 0x52AA, 0x4A49, 0x4228, 0x4A49, 0x3186, 0x0841,   // 0x1B10 (6928)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1B20 (6944)
0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1B30 (6960)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1B40 (6976)
0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3,   // 0x1B50 (6992)
0x18E3, 0x2124, 0x2124, 0x2124, 0x2945, 0x2965, 0x3186, 0x4228, 0x4A69, 0x5AEB, 0x6B6D, 0x8C51, 0x94B2, 0x8C71, 0x8C51, 0x7BEF,   // 0x1B60 (7008)
0x632C, 0x6B4D, 0x630C, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5ACB, 0x52AA, 0x528A, 0x4A49, 0x4A69, 0x39E7, 0x1082, 0x0000, 0x0000,   // 0x1B70 (7024)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x1B80 (7040)
0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1B90 (7056)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1BA0 (7072)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2104,   // 0x1BB0 (7088)
0x2124, 0x2124, 0x2945, 0x2945, 0x3186, 0x39C7, 0x4228, 0x5ACB, 0x6B6D, 0x8410, 0x8430, 0x8C71, 0x8410, 0x7BEF, 0x73AE, 0x6B4D,   // 0x1BC0 (7104)
0x630C, 0x5AEB, 0x630C, 0x5AEB, 0x630C, 0x5ACB, 0x528A, 0x5ACB, 0x5ACB, 0x4A69, 0x4208, 0x2104, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1BD0 (7120)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x1BE0 (7136)
0x0841, 0x0841, 0x0841, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3,   // 0x1BF0 (7152)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x18C3,   // 0x1C00 (7168)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2104,   // 0x1C10 (7184)
0x2124, 0x2965, 0x2965, 0x3186, 0x39C7, 0x4228, 0x6B4D, 0x7BEF, 0x8430, 0x8C51, 0x8C71, 0x8C51, 0x7BCF, 0x738E, 0x6B6D, 0x630C,   // 0x1C20 (7200)
0x630C, 0x632C, 0x630C, 0x5AEB, 0x52AA, 0x52AA, 0x5ACB, 0x52AA, 0x4A49, 0x2945, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1C30 (7216)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x1C40 (7232)
0x0841, 0x0841, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x18C3,   // 0x1C50 (7248)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x1C60 (7264)
0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2124, 0x2945,   // 0x1C70 (7280)
0x3186, 0x31A6, 0x39C7, 0x39E7, 0x5ACB, 0x73AE, 0x7BCF, 0x7BEF, 0x8C51, 0x8C51, 0x9492, 0x8C51, 0x738E, 0x6B4D, 0x6B4D, 0x6B6D,   // 0x1C80 (7296)
0x632C, 0x6B4D, 0x6B4D, 0x5AEB, 0x52AA, 0x528A, 0x4A49, 0x31A6, 0x0861, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1C90 (7312)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841,   // 0x1CA0 (7328)
0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3,   // 0x1CB0 (7344)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x1CC0 (7360)
0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x2124, 0x2945, 0x3186, 0x39E7,   // 0x1CD0 (7376)
0x4228, 0x4A49, 0x4A69, 0x630C, 0x738E, 0x6B6D, 0x7BEF, 0x8C51, 0x8C71, 0x8C71, 0x8C51, 0x7BCF, 0x6B6D, 0x6B4D, 0x6B4D, 0x6B6D,   // 0x1CE0 (7392)
0x73AE, 0x73AE, 0x630C, 0x528A, 0x4A49, 0x39E7, 0x10A2, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1CF0 (7408)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841,   // 0x1D00 (7424)
0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3,   // 0x1D10 (7440)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2,   // 0x1D20 (7456)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2124, 0x2945, 0x2965, 0x31A6, 0x4208, 0x4228,   // 0x1D30 (7472)
0x4A49, 0x52AA, 0x632C, 0x6B6D, 0x73AE, 0x8410, 0x8430, 0x8430, 0x8C51, 0x8C71, 0x7BCF, 0x6B4D, 0x630C, 0x632C, 0x738E, 0x73AE,   // 0x1D40 (7488)
0x632C, 0x5ACB, 0x4A69, 0x4208, 0x18C3, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1D50 (7504)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841,   // 0x1D60 (7520)
0x0841, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2,   // 0x1D70 (7536)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x1D80 (7552)
0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2124, 0x2945, 0x31A6, 0x39C7, 0x4208, 0x4A49, 0x528A,   // 0x1D90 (7568)
0x630C, 0x6B6D, 0x6B6D, 0x73AE, 0x7BEF, 0x73AE, 0x7BCF, 0x7BEF, 0x7BCF, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x630C, 0x5ACB,   // 0x1DA0 (7584)
0x528A, 0x4208, 0x2104, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1DB0 (7600)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841,   // 0x1DC0 (7616)
0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x1DD0 (7632)
0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x1DE0 (7648)
0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2104, 0x2945, 0x2965, 0x31A6, 0x39E7, 0x4A49, 0x52AA, 0x630C, 0x632C,   // 0x1DF0 (7664)
0x6B6D, 0x6B6D, 0x73AE, 0x73AE, 0x6B4D, 0x738E, 0x6B6D, 0x632C, 0x632C, 0x6B4D, 0x632C, 0x630C, 0x5AEB, 0x52AA, 0x528A, 0x4228,   // 0x1E00 (7680)
0x2124, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1E10 (7696)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841,   // 0x1E20 (7712)
0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2,   // 0x1E30 (7728)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x1E40 (7744)
0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2945, 0x2965, 0x3186, 0x39C7, 0x4228, 0x528A, 0x5AEB, 0x632C, 0x6B6D, 0x73AE,   // 0x1E50 (7760)
0x7BCF, 0x7BCF, 0x6B6D, 0x632C, 0x6B4D, 0x6B6D, 0x632C, 0x6B4D, 0x632C, 0x5AEB, 0x5ACB, 0x52AA, 0x528A, 0x4228, 0x2945, 0x0020,   // 0x1E60 (7776)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1E70 (7792)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841,   // 0x1E80 (7808)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2,   // 0x1E90 (7824)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3,   // 0x1EA0 (7840)
0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2124, 0x2945, 0x3186, 0x39C7, 0x4208, 0x4A49, 0x52AA, 0x630C, 0x6B6D, 0x73AE, 0x7BCF, 0x7BEF,   // 0x1EB0 (7856)
0x7BCF, 0x6B4D, 0x6B6D, 0x7BCF, 0x73AE, 0x6B4D, 0x630C, 0x528A, 0x52AA, 0x52AA, 0x4A69, 0x4228, 0x2124, 0x0020, 0x0000, 0x0000,   // 0x1EC0 (7872)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1ED0 (7888)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841,   // 0x1EE0 (7904)
0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x1EF0 (7920)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3,   // 0x1F00 (7936)
0x18C3, 0x18E3, 0x2104, 0x2945, 0x2965, 0x31A6, 0x39E7, 0x4A49, 0x4A69, 0x5ACB, 0x6B4D, 0x738E, 0x7BCF, 0x7BCF, 0x7BCF, 0x73AE,   // 0x1F10 (7952)
0x73AE, 0x7BCF, 0x7BCF, 0x738E, 0x632C, 0x52AA, 0x528A, 0x528A, 0x4A49, 0x4208, 0x2104, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1F20 (7968)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1F30 (7984)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841,   // 0x1F40 (8000)
0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x1F50 (8016)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18E3,   // 0x1F60 (8032)
0x2104, 0x2124, 0x2965, 0x3186, 0x31A6, 0x4208, 0x4A49, 0x52AA, 0x630C, 0x6B6D, 0x73AE, 0x7BCF, 0x7BEF, 0x73AE, 0x738E, 0x738E,   // 0x1F70 (8048)
0x73AE, 0x6B6D, 0x630C, 0x52AA, 0x52AA, 0x4A69, 0x4228, 0x39C7, 0x18C3, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1F80 (8064)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1F90 (8080)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x1FA0 (8096)
0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x1FB0 (8112)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2104,   // 0x1FC0 (8128)
0x2945, 0x2965, 0x31A6, 0x39E7, 0x4228, 0x4A69, 0x5AEB, 0x6B4D, 0x738E, 0x7BCF, 0x7BCF, 0x7BCF, 0x738E, 0x738E, 0x6B6D, 0x6B4D,   // 0x1FD0 (8144)
0x5AEB, 0x5ACB, 0x528A, 0x4A69, 0x4228, 0x3186, 0x0861, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1FE0 (8160)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1FF0 (8176)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x2000 (8192)
0x0841, 0x0861, 0x0861, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x2010 (8208)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2124, 0x2945,   // 0x2020 (8224)
0x2965, 0x31A6, 0x4208, 0x4A69, 0x5ACB, 0x632C, 0x6B6D, 0x738E, 0x73AE, 0x73AE, 0x738E, 0x738E, 0x6B6D, 0x6B4D, 0x5AEB, 0x52AA,   // 0x2030 (8240)
0x4A69, 0x4A69, 0x39E7, 0x2104, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2040 (8256)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2050 (8272)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2060 (8288)
0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x2070 (8304)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2124, 0x2945, 0x2965, 0x31A6,   // 0x2080 (8320)
0x39E7, 0x4228, 0x528A, 0x5ACB, 0x630C, 0x6B4D, 0x738E, 0x738E, 0x6B6D, 0x6B4D, 0x6B4D, 0x632C, 0x5AEB, 0x52AA, 0x4A69, 0x4228,   // 0x2090 (8336)
0x3186, 0x1082, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x20A0 (8352)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x20B0 (8368)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x20C0 (8384)
0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x20D0 (8400)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x2124, 0x2945, 0x3186, 0x39C7, 0x4208,   // 0x20E0 (8416)
0x4A49, 0x528A, 0x5ACB, 0x630C, 0x6B4D, 0x6B6D, 0x6B4D, 0x632C, 0x630C, 0x5AEB, 0x5ACB, 0x52AA, 0x4A49, 0x31A6, 0x18C3, 0x0020,   // 0x20F0 (8432)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2100 (8448)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2110 (8464)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2120 (8480)
0x0000, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861,   // 0x2130 (8496)
0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x2104, 0x2124, 0x2945, 0x3186, 0x31A6, 0x39E7, 0x4228,   // 0x2140 (8512)
0x528A, 0x52AA, 0x5ACB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x52AA, 0x4A49, 0x31A6, 0x18E3, 0x0020, 0x0000, 0x0000, 0x0000,   // 0x2150 (8528)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2160 (8544)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2170 (8560)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2180 (8576)
0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0841, 0x0841, 0x0861,   // 0x2190 (8592)
0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18E3, 0x2104, 0x2124, 0x2945, 0x2965, 0x31A6, 0x39C7, 0x4208, 0x4A49,   // 0x21A0 (8608)
0x4A69, 0x4A69, 0x4A69, 0x528A, 0x52AA, 0x528A, 0x4228, 0x3186, 0x18C3, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x21B0 (8624)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x21C0 (8640)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x21D0 (8656)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x21E0 (8672)
0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x21F0 (8688)
0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x2104, 0x2124, 0x2945, 0x2965, 0x31A6, 0x39C7, 0x39E7, 0x4208, 0x4228,   // 0x2200 (8704)
0x4A49, 0x4A49, 0x4208, 0x31A6, 0x2124, 0x10A2, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2210 (8720)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2220 (8736)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2230 (8752)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2240 (8768)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861,   // 0x2250 (8784)
0x0861, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x2104, 0x2104, 0x2124, 0x2945, 0x3186, 0x31A6, 0x39C7, 0x39C7, 0x39C7, 0x39C7, 0x3186,   // 0x2260 (8800)
0x2124, 0x10A2, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2270 (8816)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2280 (8832)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2290 (8848)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22A0 (8864)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0841, 0x0841, 0x0861, 0x0861,   // 0x22B0 (8880)
0x1082, 0x1082, 0x1082, 0x10A2, 0x18E3, 0x2104, 0x2124, 0x2124, 0x2945, 0x2124, 0x2104, 0x18C3, 0x10A2, 0x0861, 0x0020, 0x0000,   // 0x22C0 (8896)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22D0 (8912)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22E0 (8928)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22F0 (8944)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2300 (8960)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0020,   // 0x2310 (8976)
0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2320 (8992)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2330 (9008)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2340 (9024)
0x0000, };
Gibbous.c
// Generated by  : ImageConverter 565 v2.3
// Generated from: WaningGibbous.jpg
// Time generated: 17/06/2022 8:18:38 AM
// Dimensions    : 95x95 pixels
// Size          : 18,050 Bytes
#include <avr/pgmspace.h>
const unsigned int Gibbous[0x2341] PROGMEM ={
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0010 (16)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0020 (32)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020,   // 0x0030 (48)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0040 (64)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0050 (80)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0060 (96)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0070 (112)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0080 (128)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0861, 0x10A2, 0x18C3, 0x18E3, 0x2104, 0x2124, 0x2124, 0x2124, 0x2104, 0x18E3,   // 0x0090 (144)
0x18E3, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00A0 (160)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00B0 (176)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00C0 (192)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00D0 (208)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00E0 (224)
0x0020, 0x1082, 0x18E3, 0x2965, 0x31A6, 0x39E7, 0x4208, 0x4208, 0x4228, 0x4208, 0x4208, 0x39E7, 0x39E7, 0x39C7, 0x3186, 0x2965,   // 0x00F0 (240)
0x2965, 0x2945, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0100 (256)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0110 (272)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0120 (288)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0130 (304)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x10A2, 0x2124, 0x31A6,   // 0x0140 (320)
0x4208, 0x4A49, 0x4A69, 0x528A, 0x528A, 0x528A, 0x528A, 0x528A, 0x528A, 0x4A69, 0x4A69, 0x4A49, 0x4228, 0x39E7, 0x31A6, 0x2965,   // 0x0150 (336)
0x2124, 0x2124, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000,   // 0x0160 (352)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0170 (368)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0180 (384)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0190 (400)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x10A2, 0x2124, 0x39C7, 0x4A49, 0x5ACB, 0x5ACB, 0x52AA,   // 0x01A0 (416)
0x52AA, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5ACB, 0x52AA, 0x4A69, 0x4A69, 0x4A49, 0x4228, 0x39C7, 0x2965,   // 0x01B0 (432)
0x2945, 0x2124, 0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0020, 0x0000, 0x0000,   // 0x01C0 (448)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x01D0 (464)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x01E0 (480)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x01F0 (496)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x10A2, 0x3186, 0x4A69, 0x52AA, 0x52AA, 0x52AA, 0x5AEB, 0x5ACB, 0x5AEB, 0x630C,   // 0x0200 (512)
0x632C, 0x632C, 0x632C, 0x6B4D, 0x6B4D, 0x632C, 0x632C, 0x630C, 0x5AEB, 0x52AA, 0x528A, 0x5ACB, 0x5ACB, 0x528A, 0x4208, 0x39C7,   // 0x0210 (528)
0x3186, 0x2965, 0x2945, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0000,   // 0x0220 (544)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0230 (560)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0240 (576)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0250 (592)
0x0000, 0x0000, 0x0020, 0x1082, 0x3186, 0x4A69, 0x5ACB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x630C, 0x6B4D, 0x6B6D, 0x6B6D,   // 0x0260 (608)
0x6B4D, 0x6B4D, 0x6B6D, 0x738E, 0x738E, 0x738E, 0x6B4D, 0x632C, 0x6B6D, 0x6B6D, 0x6B6D, 0x632C, 0x630C, 0x5ACB, 0x4A69, 0x4208,   // 0x0270 (624)
0x39C7, 0x3186, 0x2945, 0x2104, 0x18E3, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0020,   // 0x0280 (640)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0290 (656)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x02A0 (672)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x02B0 (688)
0x0861, 0x3186, 0x4A69, 0x5AEB, 0x5ACB, 0x52AA, 0x5AEB, 0x5AEB, 0x630C, 0x630C, 0x632C, 0x6B4D, 0x738E, 0x73AE, 0x73AE, 0x73AE,   // 0x02C0 (704)
0x73AE, 0x7BCF, 0x7BEF, 0x7BEF, 0x7BCF, 0x7BCF, 0x8410, 0x8430, 0x8410, 0x7BCF, 0x738E, 0x6B4D, 0x630C, 0x5ACB, 0x528A, 0x4228,   // 0x02D0 (720)
0x39C7, 0x3186, 0x2945, 0x2104, 0x18E3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841,   // 0x02E0 (736)
0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x02F0 (752)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0300 (768)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x18E3, 0x39E7,   // 0x0310 (784)
0x528A, 0x5ACB, 0x5ACB, 0x5AEB, 0x5AEB, 0x630C, 0x632C, 0x6B4D, 0x6B4D, 0x738E, 0x73AE, 0x7BCF, 0x8410, 0x8410, 0x8410, 0x8410,   // 0x0320 (800)
0x8430, 0x8410, 0x7BEF, 0x7BEF, 0x8C51, 0x8C71, 0x8C51, 0x8C51, 0x8430, 0x7BCF, 0x73AE, 0x6B6D, 0x632C, 0x528A, 0x4208, 0x39E7,   // 0x0330 (816)
0x39C7, 0x3186, 0x2124, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841,   // 0x0340 (832)
0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0350 (848)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0360 (864)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0861, 0x2965, 0x4228, 0x528A, 0x528A,   // 0x0370 (880)
0x630C, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B6D, 0x738E, 0x7BCF, 0x7BEF, 0x7BEF, 0x8410, 0x8430, 0x8C71, 0x8C51, 0x8C51,   // 0x0380 (896)
0x8430, 0x8430, 0x8430, 0x8C51, 0x9492, 0x8C71, 0x9492, 0x8C71, 0x8410, 0x7BEF, 0x73AE, 0x630C, 0x4A69, 0x39E7, 0x39C7, 0x31A6,   // 0x0390 (912)
0x3186, 0x2965, 0x2945, 0x2104, 0x18E3, 0x18C3, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x03A0 (928)
0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x03B0 (944)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x03C0 (960)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x18C3, 0x39E7, 0x5ACB, 0x528A, 0x52AA, 0x5AEB, 0x632C,   // 0x03D0 (976)
0x6B4D, 0x632C, 0x6B4D, 0x6B6D, 0x738E, 0x73AE, 0x7BCF, 0x8410, 0x8410, 0x8C51, 0x94B2, 0x9492, 0x9CD3, 0x94B2, 0x8C71, 0x8C71,   // 0x03E0 (992)
0x8C51, 0x8430, 0x8430, 0x8C71, 0x9492, 0x8C51, 0x8430, 0x73AE, 0x6B6D, 0x6B6D, 0x5AEB, 0x528A, 0x4A49, 0x4228, 0x39C7, 0x3186,   // 0x03F0 (1008)
0x31A6, 0x2965, 0x2124, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0400 (1024)
0x0861, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0410 (1040)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0420 (1056)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x2945, 0x4A49, 0x528A, 0x52AA, 0x5ACB, 0x5AEB, 0x630C, 0x630C, 0x632C,   // 0x0430 (1072)
0x6B4D, 0x6B6D, 0x738E, 0x73AE, 0x8410, 0x8430, 0x8C71, 0x9CD3, 0xA534, 0xB596, 0x9CF3, 0x94B2, 0x94B2, 0x8C71, 0x8C71, 0x9492,   // 0x0440 (1088)
0x9492, 0x8C71, 0x8430, 0x8410, 0x7BEF, 0x7BCF, 0x73AE, 0x6B6D, 0x6B4D, 0x5AEB, 0x528A, 0x4A69, 0x4A49, 0x39E7, 0x3186, 0x2965,   // 0x0450 (1104)
0x2945, 0x2104, 0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0460 (1120)
0x0861, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0470 (1136)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0480 (1152)
0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x3186, 0x52AA, 0x5AEB, 0x5ACB, 0x52AA, 0x5AEB, 0x630C, 0x632C, 0x632C, 0x6B6D, 0x738E,   // 0x0490 (1168)
0x73AE, 0x7BEF, 0x7BEF, 0x8C51, 0x94B2, 0xAD55, 0xC618, 0xBDF7, 0xA534, 0x9CF3, 0x94B2, 0x94B2, 0x94B2, 0x8C71, 0x8C71, 0x94B2,   // 0x04A0 (1184)
0x9492, 0x8410, 0x8410, 0x8410, 0x8410, 0x7BCF, 0x73AE, 0x738E, 0x632C, 0x5ACB, 0x528A, 0x4A49, 0x4208, 0x31A6, 0x2965, 0x2124,   // 0x04B0 (1200)
0x2104, 0x2104, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x0861,   // 0x04C0 (1216)
0x0861, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x04D0 (1232)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x04E0 (1248)
0x0000, 0x0000, 0x0841, 0x39C7, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x632C, 0x6B4D, 0x6B6D, 0x6B6D, 0x738E, 0x73AE, 0x7BCF,   // 0x04F0 (1264)
0x8410, 0x8430, 0x8C51, 0x9492, 0x9CF3, 0xB596, 0xB596, 0x9CF3, 0x9CF3, 0x9CF3, 0xA514, 0x9CD3, 0x8C71, 0x8C51, 0x8C71, 0x8C71,   // 0x0500 (1280)
0x8C71, 0x8C51, 0x8C71, 0x8C51, 0x8430, 0x7BEF, 0x73AE, 0x6B4D, 0x630C, 0x52AA, 0x4A69, 0x4228, 0x39E7, 0x3186, 0x2965, 0x2124,   // 0x0510 (1296)
0x2104, 0x18E3, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0520 (1312)
0x0861, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0530 (1328)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0540 (1344)
0x0861, 0x4228, 0x6B4D, 0x738E, 0x6B6D, 0x6B4D, 0x630C, 0x632C, 0x6B6D, 0x6B4D, 0x6B6D, 0x738E, 0x73AE, 0x7BEF, 0x7BEF, 0x8410,   // 0x0550 (1360)
0x8430, 0x8C51, 0x8C71, 0x94B2, 0x94B2, 0x9CF3, 0x9CF3, 0x9CF3, 0xA514, 0x9CD3, 0x9492, 0x9492, 0x8C71, 0x9492, 0x9CD3, 0x94B2,   // 0x0560 (1376)
0x8C51, 0x8C71, 0x8C51, 0x8430, 0x8410, 0x7BEF, 0x738E, 0x6B4D, 0x630C, 0x52AA, 0x4A69, 0x4228, 0x39C7, 0x3186, 0x2945, 0x2124,   // 0x0570 (1392)
0x2104, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0580 (1408)
0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0590 (1424)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0861, 0x4A49,   // 0x05A0 (1440)
0x738E, 0x7BCF, 0x7BCF, 0x738E, 0x632C, 0x632C, 0x6B4D, 0x6B6D, 0x6B6D, 0x738E, 0x6B6D, 0x73AE, 0x7BEF, 0x7BEF, 0x8410, 0x8430,   // 0x05B0 (1456)
0x8C51, 0x8C71, 0x9492, 0x94B2, 0x9CD3, 0x94B2, 0x9492, 0x9492, 0x8C71, 0x8C71, 0x9492, 0x9492, 0x94B2, 0x9CD3, 0x94B2, 0x8C71,   // 0x05C0 (1472)
0x8C51, 0x8430, 0x8410, 0x7BEF, 0x7BEF, 0x7BCF, 0x6B6D, 0x632C, 0x5AEB, 0x528A, 0x4A69, 0x4228, 0x39C7, 0x3186, 0x2965, 0x2124,   // 0x05D0 (1488)
0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x05E0 (1504)
0x0861, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x05F0 (1520)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x4208, 0x6B6D, 0x7BCF,   // 0x0600 (1536)
0x7BCF, 0x7BCF, 0x738E, 0x6B4D, 0x6B4D, 0x6B6D, 0x73AE, 0x73AE, 0x73AE, 0x73AE, 0x73AE, 0x7BCF, 0x7BEF, 0x8430, 0x8C51, 0x8C51,   // 0x0610 (1552)
0x8C51, 0x8C51, 0x94B2, 0x9CF3, 0x94B2, 0x8C71, 0x8C71, 0x8430, 0x8C71, 0x8C51, 0x8C51, 0x8C51, 0x8C71, 0x9492, 0x8C51, 0x8C51,   // 0x0620 (1568)
0x8C71, 0x8430, 0x7BEF, 0x7BEF, 0x7BCF, 0x738E, 0x6B4D, 0x630C, 0x5AEB, 0x52AA, 0x4A49, 0x4208, 0x31A6, 0x3186, 0x2945, 0x2104,   // 0x0630 (1584)
0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0640 (1600)
0x0841, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0650 (1616)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x31A6, 0x6B4D, 0x7BCF, 0x8430, 0x8C51,   // 0x0660 (1632)
0x7BCF, 0x6B6D, 0x738E, 0x73AE, 0x73AE, 0x7BCF, 0x7BCF, 0x7BCF, 0x8410, 0x7BEF, 0x7BCF, 0x8410, 0x8C51, 0x8430, 0x8C51, 0x8C71,   // 0x0670 (1648)
0x8C71, 0x9CD3, 0xA514, 0x9492, 0x9492, 0x9CD3, 0x8C71, 0x8C71, 0x8C51, 0x8C71, 0x8C51, 0x8C71, 0x8C71, 0x8C51, 0x8C71, 0x8C71,   // 0x0680 (1664)
0x8C51, 0x8410, 0x8410, 0x7BCF, 0x73AE, 0x6B6D, 0x6B4D, 0x632C, 0x5AEB, 0x4A69, 0x4A49, 0x39E7, 0x31A6, 0x2965, 0x2124, 0x18E3,   // 0x0690 (1680)
0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841,   // 0x06A0 (1696)
0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x06B0 (1712)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x2945, 0x632C, 0x7BCF, 0x8430, 0x8C71, 0x8C71, 0x7BCF,   // 0x06C0 (1728)
0x6B6D, 0x7BCF, 0x8C51, 0x8410, 0x7BEF, 0x7BCF, 0x7BCF, 0x8410, 0x8410, 0x8410, 0x8C51, 0x8C71, 0x8430, 0x8C51, 0x9492, 0x9CD3,   // 0x06D0 (1744)
0xA514, 0x9CF3, 0x9492, 0x9492, 0x9492, 0x9492, 0x9492, 0x9492, 0x8C71, 0x8C71, 0x9492, 0x8C51, 0x8C51, 0x9492, 0x9492, 0x8C71,   // 0x06E0 (1760)
0x8C51, 0x8C51, 0x8410, 0x7BEF, 0x73AE, 0x6B6D, 0x6B6D, 0x630C, 0x52AA, 0x528A, 0x4228, 0x39E7, 0x31A6, 0x2945, 0x2104, 0x18E3,   // 0x06F0 (1776)
0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841,   // 0x0700 (1792)
0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0710 (1808)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x10A2, 0x5ACB, 0x7BEF, 0x8410, 0x94B2, 0x9492, 0x8410, 0x73AE, 0x738E,   // 0x0720 (1824)
0x7BCF, 0x8410, 0x8410, 0x8410, 0x7BEF, 0x7BCF, 0x7BEF, 0x7BEF, 0x8410, 0x8C51, 0x8C71, 0x8C51, 0x8C51, 0x9492, 0x9CD3, 0xA514,   // 0x0730 (1840)
0xA514, 0x94B2, 0x9492, 0x8C71, 0x8C71, 0x9492, 0x94B2, 0x94B2, 0xA514, 0xA514, 0x8C51, 0x8430, 0x9492, 0x9492, 0x9492, 0x8C51,   // 0x0740 (1856)
0x8C51, 0x8C51, 0x7BEF, 0x7BCF, 0x7BCF, 0x738E, 0x6B4D, 0x5AEB, 0x52AA, 0x4A69, 0x4208, 0x31A6, 0x2965, 0x2124, 0x18E3, 0x18C3,   // 0x0750 (1872)
0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0861,   // 0x0760 (1888)
0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0770 (1904)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x4228, 0x73AE, 0x8410, 0x8C51, 0x9492, 0x8430, 0x7BCF, 0x73AE, 0x738E, 0x73AE,   // 0x0780 (1920)
0x7BCF, 0x8410, 0x8410, 0x8410, 0x8410, 0x8410, 0x7BEF, 0x7BEF, 0x7BEF, 0x8430, 0x8C71, 0x9492, 0x94B2, 0x9CD3, 0xAD55, 0xA534,   // 0x0790 (1936)
0x8C71, 0x8C51, 0x8C71, 0x8C71, 0x9492, 0x9CF3, 0xA534, 0xAD55, 0x9CF3, 0x8C51, 0x8C71, 0x94B2, 0x9492, 0x8C71, 0x8C71, 0x8C71,   // 0x07A0 (1952)
0x8430, 0x8430, 0x8430, 0x7BEF, 0x73AE, 0x6B6D, 0x630C, 0x5AEB, 0x528A, 0x4228, 0x39C7, 0x3186, 0x2945, 0x2104, 0x18E3, 0x18C3,   // 0x07B0 (1968)
0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x0841,   // 0x07C0 (1984)
0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x07D0 (2000)
0x0000, 0x0000, 0x0000, 0x0020, 0x3186, 0x630C, 0x7BEF, 0x8C71, 0x8C71, 0x8430, 0x73AE, 0x73AE, 0x738E, 0x738E, 0x73AE, 0x7BCF,   // 0x07E0 (2016)
0x7BEF, 0x8430, 0x8410, 0x8430, 0x7BEF, 0x7BEF, 0x7BEF, 0x8430, 0x8C71, 0x9492, 0x94B2, 0x9CF3, 0x9CF3, 0xA514, 0x94B2, 0x8C71,   // 0x07F0 (2032)
0x8C51, 0x9492, 0x94B2, 0x9CD3, 0x9CD3, 0xA514, 0x9CF3, 0x9CF3, 0x9492, 0x9CD3, 0x9CD3, 0x94B2, 0x9492, 0x9492, 0x8C51, 0x8410,   // 0x0800 (2048)
0x8C71, 0x8C71, 0x8410, 0x7BCF, 0x738E, 0x6B4D, 0x630C, 0x52AA, 0x4A49, 0x39E7, 0x31A6, 0x3186, 0x2945, 0x2104, 0x18E3, 0x18C3,   // 0x0810 (2064)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0820 (2080)
0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0830 (2096)
0x0000, 0x0000, 0x18E3, 0x5ACB, 0x738E, 0x8C51, 0x8C71, 0x8410, 0x7BEF, 0x738E, 0x738E, 0x73AE, 0x73AE, 0x73AE, 0x7BCF, 0x8410,   // 0x0840 (2112)
0x8410, 0x8410, 0x8410, 0x8430, 0x8430, 0x8C51, 0x8C71, 0x9CD3, 0x9CF3, 0xA534, 0xAD55, 0xA514, 0xA514, 0x8C71, 0x8C71, 0x9CF3,   // 0x0850 (2128)
0x9CD3, 0x9CF3, 0xA514, 0x94B2, 0x9CD3, 0x9CD3, 0x9CD3, 0x9CD3, 0x9CD3, 0x94B2, 0x9492, 0x94B2, 0x94B2, 0x8C51, 0x8C71, 0x8C71,   // 0x0860 (2144)
0x8C51, 0x8410, 0x8410, 0x7BCF, 0x738E, 0x632C, 0x5ACB, 0x4A69, 0x4208, 0x4208, 0x31A6, 0x2965, 0x2945, 0x2104, 0x18E3, 0x18C3,   // 0x0870 (2160)
0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x0880 (2176)
0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0890 (2192)
0x0861, 0x4A49, 0x738E, 0x7BEF, 0x7BEF, 0x9492, 0x8C51, 0x7BCF, 0x738E, 0x73AE, 0x7BCF, 0x7BCF, 0x73AE, 0x7BEF, 0x8410, 0x8430,   // 0x08A0 (2208)
0x8430, 0x8410, 0x8430, 0x8C51, 0x94B2, 0x9CF3, 0xA534, 0xB596, 0xB5B6, 0xB596, 0xAD75, 0xA534, 0x94B2, 0x9CD3, 0xA514, 0x9CF3,   // 0x08B0 (2224)
0xB596, 0xB5B6, 0xAD55, 0xA514, 0xA514, 0x9CF3, 0xA514, 0x9492, 0x9CD3, 0x94B2, 0x9CD3, 0x94B2, 0x8C71, 0x94B2, 0x8C71, 0x8C71,   // 0x08C0 (2240)
0x9492, 0x8C51, 0x7BEF, 0x738E, 0x6B4D, 0x5AEB, 0x528A, 0x4A49, 0x4228, 0x39C7, 0x3186, 0x2945, 0x2104, 0x2104, 0x18C3, 0x18C3,   // 0x08D0 (2256)
0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x08E0 (2272)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x3186,   // 0x08F0 (2288)
0x6B4D, 0x7BCF, 0x632C, 0x738E, 0x94B2, 0x9492, 0x8410, 0x738E, 0x7BCF, 0x73AE, 0x7BCF, 0x7BCF, 0x8410, 0x8410, 0x8410, 0x8410,   // 0x0900 (2304)
0x8410, 0x8410, 0x8C51, 0x94B2, 0xA514, 0xB5B6, 0xBDF7, 0xBDD7, 0xB5B6, 0xAD75, 0x9CF3, 0x8C71, 0x8C71, 0x9CF3, 0xAD55, 0xB5B6,   // 0x0910 (2320)
0xBDF7, 0xB5B6, 0xB596, 0xAD75, 0xA534, 0x9CF3, 0x94B2, 0x9CF3, 0x9CF3, 0x9CD3, 0x9CD3, 0x9CD3, 0x9492, 0x8C51, 0x94B2, 0xA534,   // 0x0920 (2336)
0x94B2, 0x8410, 0x73AE, 0x6B6D, 0x632C, 0x5ACB, 0x4A69, 0x4228, 0x39E7, 0x31A6, 0x2965, 0x2124, 0x2104, 0x18E3, 0x18C3, 0x18C3,   // 0x0930 (2352)
0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0020,   // 0x0940 (2368)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x10A2, 0x5ACB, 0x73AE,   // 0x0950 (2384)
0x6B4D, 0x5AEB, 0x8430, 0x94B2, 0x9492, 0x73AE, 0x738E, 0x73AE, 0x738E, 0x73AE, 0x7BEF, 0x8410, 0x7BEF, 0x7BEF, 0x7BEF, 0x7BEF,   // 0x0960 (2400)
0x7BEF, 0x8C71, 0x9CD3, 0xA534, 0xB596, 0xBDF7, 0xC618, 0xB5B6, 0xAD55, 0x94B2, 0x9492, 0x94B2, 0xAD55, 0xBDD7, 0xBDD7, 0xB5B6,   // 0x0970 (2416)
0xB596, 0xB596, 0xB596, 0xA534, 0x9CD3, 0x94B2, 0x9CD3, 0x9CD3, 0x94B2, 0x9CD3, 0x9CD3, 0x8C71, 0x8C71, 0x9492, 0x9CD3, 0x9492,   // 0x0980 (2432)
0x8C71, 0x8430, 0x7BCF, 0x738E, 0x6B4D, 0x5ACB, 0x4A69, 0x4208, 0x39C7, 0x31A6, 0x2945, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x18C3,   // 0x0990 (2448)
0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0841, 0x0020,   // 0x09A0 (2464)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x39C7, 0x6B4D, 0x7BCF, 0x738E,   // 0x09B0 (2480)
0x8410, 0xAD55, 0x9CD3, 0x8C71, 0x7BEF, 0x738E, 0x738E, 0x7BCF, 0x8410, 0x8410, 0x7BEF, 0x7BEF, 0x8410, 0x8410, 0x7BEF, 0x7BEF,   // 0x09C0 (2496)
0x94B2, 0x9CF3, 0x9CF3, 0xB596, 0xBDD7, 0xBDD7, 0xB596, 0xA514, 0x9CD3, 0xA514, 0xA534, 0xAD75, 0xBDD7, 0xBDF7, 0xBDF7, 0xB596,   // 0x09D0 (2512)
0xB5B6, 0xBDD7, 0xAD75, 0xA514, 0xA514, 0x9CF3, 0x9CF3, 0x9CD3, 0x9CD3, 0x94B2, 0x9492, 0x9492, 0x9492, 0x9492, 0x8C71, 0x94B2,   // 0x09E0 (2528)
0x94B2, 0x8C71, 0x8410, 0x738E, 0x630C, 0x5ACB, 0x4A49, 0x4208, 0x39C7, 0x2945, 0x2104, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x18C3,   // 0x09F0 (2544)
0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0000,   // 0x0A00 (2560)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x18C3, 0x5ACB, 0x73AE, 0x8410, 0x8C51, 0x9CF3,   // 0x0A10 (2576)
0xA514, 0x94B2, 0x8C51, 0x7BEF, 0x73AE, 0x7BCF, 0x8410, 0x8C71, 0x8410, 0x7BEF, 0x8410, 0x8410, 0x7BEF, 0x7BEF, 0x8430, 0x9CD3,   // 0x0A20 (2592)
0x94B2, 0x9CD3, 0xB596, 0xB596, 0xA514, 0xA534, 0xA514, 0x9CD3, 0x9CF3, 0xA534, 0xB596, 0xBDD7, 0xBDF7, 0xC618, 0xB5B6, 0xBDD7,   // 0x0A30 (2608)
0xC618, 0xB5B6, 0xB596, 0xAD75, 0xA514, 0xA514, 0xA514, 0x9CF3, 0x9CD3, 0x94B2, 0x94B2, 0x94B2, 0x8C71, 0x8C51, 0x9CD3, 0x9CF3,   // 0x0A40 (2624)
0x9492, 0x8C51, 0x73AE, 0x6B4D, 0x5AEB, 0x528A, 0x4228, 0x39C7, 0x2965, 0x2104, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x18C3, 0x18C3,   // 0x0A50 (2640)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0000,   // 0x0A60 (2656)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x39E7, 0x6B6D, 0x7BEF, 0x8430, 0x8C71, 0x9CF3, 0x9CF3,   // 0x0A70 (2672)
0x94B2, 0x8C51, 0x7BCF, 0x73AE, 0x7BCF, 0x8430, 0x8C71, 0x7BEF, 0x7BEF, 0x8410, 0x7BEF, 0x7BCF, 0x7BEF, 0x8C51, 0x9492, 0x9CD3,   // 0x0A80 (2688)
0xA534, 0xA534, 0x9CD3, 0x94B2, 0x9CF3, 0xA534, 0xA534, 0x9CD3, 0x9CF3, 0xAD75, 0xB5B6, 0xBDD7, 0xBDD7, 0xB5B6, 0xBDD7, 0xC618,   // 0x0A90 (2704)
0xC618, 0xBDD7, 0xB596, 0xAD75, 0xAD75, 0xA534, 0xA514, 0x9CF3, 0x9CD3, 0x9CD3, 0x9492, 0x8C51, 0x8C51, 0x94B2, 0xA514, 0x9CD3,   // 0x0AA0 (2720)
0x9492, 0x7BEF, 0x6B4D, 0x630C, 0x5ACB, 0x4A49, 0x39E7, 0x3186, 0x2124, 0x2104, 0x2104, 0x2104, 0x18E3, 0x10A2, 0x10A2, 0x10A2,   // 0x0AB0 (2736)
0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000,   // 0x0AC0 (2752)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x10A2, 0x5ACB, 0x73AE, 0x8410, 0x8C71, 0x94B2, 0x9CF3, 0x9CF3, 0x9CD3,   // 0x0AD0 (2768)
0x8C51, 0x7BEF, 0x73AE, 0x7BCF, 0x8C51, 0x8430, 0x7BEF, 0x7BEF, 0x7BCF, 0x7BCF, 0x7BEF, 0x8410, 0x8430, 0x8430, 0x94B2, 0x9CF3,   // 0x0AE0 (2784)
0x94B2, 0x94B2, 0x9CF3, 0xA514, 0xA534, 0xAD75, 0xB596, 0xAD55, 0xAD55, 0xB5B6, 0xBDD7, 0xC618, 0xC638, 0xC638, 0xC638, 0xC618,   // 0x0AF0 (2800)
0xBDF7, 0xB5B6, 0xB596, 0xB596, 0xAD55, 0xA534, 0x9CF3, 0x9CF3, 0x9CF3, 0x9CD3, 0x94B2, 0x8C71, 0x8C71, 0xA514, 0x9CF3, 0x94B2,   // 0x0B00 (2816)
0x8430, 0x738E, 0x630C, 0x5AEB, 0x528A, 0x4208, 0x31A6, 0x2945, 0x2124, 0x2104, 0x18E3, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2,   // 0x0B10 (2832)
0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000,   // 0x0B20 (2848)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x2945, 0x6B4D, 0x7BCF, 0x8C51, 0x9492, 0x9CD3, 0xA534, 0xA534, 0x94B2, 0x8410,   // 0x0B30 (2864)
0x8430, 0x7BCF, 0x7BCF, 0x8430, 0x8430, 0x8430, 0x8430, 0x7BEF, 0x7BEF, 0x8C51, 0x8C51, 0x8410, 0x8410, 0x8C51, 0x9492, 0x94B2,   // 0x0B40 (2880)
0x9CD3, 0xA514, 0xA514, 0x9CF3, 0xAD55, 0xB596, 0xAD75, 0xB596, 0xB5B6, 0xB5B6, 0xC638, 0xDEDB, 0xDEDB, 0xD69A, 0xBDF7, 0xBDD7,   // 0x0B50 (2896)
0xB5B6, 0xB596, 0xB5B6, 0xB5B6, 0xAD75, 0xA534, 0xA534, 0xA534, 0x9CD3, 0x9492, 0x8C71, 0x8430, 0x9492, 0x9CD3, 0x94B2, 0x8C51,   // 0x0B60 (2912)
0x738E, 0x5AEB, 0x5ACB, 0x528A, 0x4228, 0x31A6, 0x2965, 0x2945, 0x2104, 0x18C3, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2,   // 0x0B70 (2928)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0B80 (2944)
0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x4228, 0x73AE, 0x8410, 0x8C51, 0x9492, 0xA514, 0xB596, 0xAD55, 0x8C71, 0x7BEF, 0x8430,   // 0x0B90 (2960)
0x8410, 0x7BEF, 0x8410, 0x8410, 0x7BEF, 0x8410, 0x8410, 0x8410, 0x8430, 0x8430, 0x7BEF, 0x8410, 0x8C51, 0x9492, 0x94B2, 0x94B2,   // 0x0BA0 (2976)
0x9CD3, 0x9CF3, 0x94B2, 0x9CF3, 0xAD55, 0xB5B6, 0xB5B6, 0xB5B6, 0xB596, 0xB5B6, 0xCE79, 0xDEDB, 0xD69A, 0xBDF7, 0xBDD7, 0xBDD7,   // 0x0BB0 (2992)
0xB5B6, 0xBDD7, 0xB5B6, 0xB596, 0xAD75, 0xAD75, 0xA514, 0x94B2, 0x9492, 0x9492, 0x8C51, 0x9492, 0xA514, 0x9CF3, 0x8C71, 0x7BCF,   // 0x0BC0 (3008)
0x632C, 0x52AA, 0x52AA, 0x4A69, 0x39C7, 0x2945, 0x2104, 0x18E3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x10A2, 0x1082,   // 0x0BD0 (3024)
0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0BE0 (3040)
0x0000, 0x0000, 0x0000, 0x18C3, 0x5AEB, 0x7BCF, 0x7BEF, 0x8C51, 0x8C71, 0xAD55, 0xBDD7, 0xAD55, 0x8C71, 0x8C51, 0x9CF3, 0x94B2,   // 0x0BF0 (3056)
0x8410, 0x8430, 0x8430, 0x7BEF, 0x8410, 0x7BEF, 0x7BEF, 0x8410, 0x8410, 0x7BEF, 0x8410, 0x8C71, 0x94B2, 0x8C71, 0x9492, 0x9CF3,   // 0x0C00 (3072)
0xA514, 0x9CF3, 0xA514, 0xAD55, 0xB5B6, 0xBDD7, 0xB596, 0xB596, 0xB596, 0xB5B6, 0xBDF7, 0xBDF7, 0xBDD7, 0xB5B6, 0xB5B6, 0xB5B6,   // 0x0C10 (3088)
0xB5B6, 0xB596, 0xB596, 0xA514, 0xAD55, 0xAD75, 0xB596, 0xB596, 0xA534, 0xA514, 0xA534, 0xAD55, 0xA534, 0x9CD3, 0x8C71, 0x7BCF,   // 0x0C20 (3104)
0x632C, 0x5AEB, 0x4A69, 0x39C7, 0x2945, 0x2104, 0x18E3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x0861,   // 0x0C30 (3120)
0x0861, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0C40 (3136)
0x0000, 0x0000, 0x3186, 0x6B6D, 0x73AE, 0x7BEF, 0x8C51, 0x94B2, 0xA514, 0xAD75, 0xAD55, 0x9CD3, 0x9CF3, 0xAD55, 0x9492, 0x8410,   // 0x0C50 (3152)
0x8C51, 0x8430, 0x8410, 0x8410, 0x8410, 0x8430, 0x9492, 0x8430, 0x8410, 0x8430, 0x9492, 0x9492, 0x94B2, 0x9492, 0x9492, 0xA514,   // 0x0C60 (3168)
0xA534, 0xA514, 0xAD75, 0xB596, 0xB5B6, 0xB5B6, 0xB596, 0xB596, 0xAD75, 0xAD75, 0xB596, 0xB5B6, 0xB5B6, 0xB5B6, 0xB5B6, 0xB5B6,   // 0x0C70 (3184)
0xB596, 0xAD75, 0xA514, 0x9CD3, 0xA534, 0xB596, 0xB5B6, 0xB5B6, 0xB596, 0xAD75, 0xAD55, 0xAD55, 0xA534, 0x9CD3, 0x8410, 0x73AE,   // 0x0C80 (3200)
0x5AEB, 0x4A69, 0x39C7, 0x2945, 0x2124, 0x18E3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x0C90 (3216)
0x0861, 0x0861, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0CA0 (3232)
0x0000, 0x4A49, 0x73AE, 0x7BEF, 0x8430, 0x94B2, 0x9CF3, 0xA514, 0xAD55, 0xAD55, 0xAD55, 0xA534, 0xA514, 0x9492, 0x9492, 0x8C51,   // 0x0CB0 (3248)
0x8430, 0x7BEF, 0x8410, 0x8430, 0x8C71, 0x8C71, 0x8430, 0x8C51, 0x9492, 0x9492, 0x94B2, 0xA514, 0x9CD3, 0x9CD3, 0xA514, 0xA534,   // 0x0CC0 (3264)
0xA514, 0xAD55, 0xAD55, 0xB5B6, 0xBDD7, 0xB596, 0xAD55, 0xAD75, 0xAD55, 0xAD55, 0xAD75, 0xAD75, 0xB5B6, 0xB5B6, 0xB596, 0xAD55,   // 0x0CD0 (3280)
0xA534, 0xA534, 0x9CD3, 0x9CD3, 0xAD75, 0xB5B6, 0xB596, 0xB5B6, 0xB596, 0xAD75, 0xA534, 0x9CF3, 0x94B2, 0x7BEF, 0x738E, 0x5AEB,   // 0x0CE0 (3296)
0x4A49, 0x31A6, 0x2945, 0x2124, 0x2104, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x0CF0 (3312)
0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0861,   // 0x0D00 (3328)
0x52AA, 0x7BEF, 0x8C51, 0x94B2, 0x9CF3, 0xA514, 0xA534, 0xA534, 0xAD75, 0xAD75, 0x9CD3, 0x94B2, 0x94B2, 0x9CD3, 0x94B2, 0x8C51,   // 0x0D10 (3344)
0x8410, 0x8430, 0x8C51, 0x8C71, 0x8430, 0x8430, 0x8C71, 0x9CD3, 0x8C71, 0x9492, 0x9492, 0x9CD3, 0xA534, 0x9CF3, 0xA534, 0x9CF3,   // 0x0D20 (3360)
0xA534, 0xB596, 0xBDF7, 0xBDD7, 0xAD75, 0xAD55, 0xAD55, 0xA514, 0x94B2, 0xA514, 0xA514, 0xAD75, 0xB596, 0xAD75, 0xAD55, 0xA514,   // 0x0D30 (3376)
0xA514, 0x9CD3, 0x94B2, 0xA514, 0xAD75, 0xAD75, 0xB596, 0xAD75, 0xAD55, 0x9CF3, 0x94B2, 0x8C51, 0x7BEF, 0x6B6D, 0x52AA, 0x4208,   // 0x0D40 (3392)
0x31A6, 0x2965, 0x2124, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082,   // 0x0D50 (3408)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x2104, 0x6B4D,   // 0x0D60 (3424)
0x8430, 0x8C71, 0x9CD3, 0xA514, 0xA534, 0xA534, 0xAD55, 0xAD75, 0xA514, 0x94B2, 0xA534, 0xAD55, 0xA514, 0xA514, 0x94B2, 0x94B2,   // 0x0D70 (3440)
0x9CF3, 0x8C71, 0x8C51, 0x8430, 0x8C51, 0x9492, 0x94B2, 0x8C71, 0x94B2, 0x9CD3, 0x9CD3, 0xA514, 0x9CF3, 0xA514, 0x9CF3, 0xAD55,   // 0x0D80 (3456)
0xB596, 0xB596, 0xB5B6, 0xB596, 0xAD75, 0xA514, 0x9CD3, 0x8C71, 0x9CD3, 0xA534, 0xAD55, 0xAD75, 0xA534, 0xA514, 0x9CD3, 0x9CD3,   // 0x0D90 (3472)
0x94B2, 0x8C71, 0x8430, 0x94B2, 0xAD55, 0xA534, 0x9CF3, 0x9CF3, 0x94B2, 0x9492, 0x8430, 0x7BCF, 0x6B4D, 0x528A, 0x39E7, 0x31A6,   // 0x0DA0 (3488)
0x2965, 0x2124, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x0861,   // 0x0DB0 (3504)
0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x39C7, 0x738E, 0x7BEF,   // 0x0DC0 (3520)
0x94B2, 0x9CF3, 0xA534, 0xAD75, 0xAD55, 0xAD55, 0xAD55, 0xA514, 0xA514, 0xA534, 0xAD55, 0xAD55, 0xA534, 0xA514, 0xAD55, 0xAD55,   // 0x0DD0 (3536)
0x8C51, 0x8410, 0x8410, 0x8C51, 0x94B2, 0x9CD3, 0x9CF3, 0xAD75, 0xAD75, 0x9CF3, 0x94B2, 0x9CD3, 0x9CD3, 0x94B2, 0x9CF3, 0xA534,   // 0x0DE0 (3552)
0xA534, 0xBDF7, 0xBDD7, 0xAD75, 0x9CD3, 0x9CD3, 0x9CD3, 0x94B2, 0x9CF3, 0xA534, 0xA514, 0x9CF3, 0x94B2, 0x94B2, 0x94B2, 0x8C71,   // 0x0DF0 (3568)
0x8410, 0x7BCF, 0x8C51, 0x9CF3, 0x9CD3, 0x8C71, 0x8C71, 0x9492, 0x9492, 0x8430, 0x738E, 0x632C, 0x52AA, 0x39E7, 0x31A6, 0x2945,   // 0x0E00 (3584)
0x2124, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x0861, 0x0841,   // 0x0E10 (3600)
0x0861, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x4228, 0x6B6D, 0x8430, 0x9CF3,   // 0x0E20 (3616)
0xA534, 0xAD75, 0xAD75, 0xAD55, 0xAD75, 0xAD55, 0xAD75, 0xAD75, 0xA534, 0xAD55, 0xAD75, 0xAD55, 0xB596, 0xB5B6, 0xA514, 0x8C51,   // 0x0E30 (3632)
0x8430, 0x8430, 0x8C71, 0x9492, 0x9CF3, 0xB596, 0xBDF7, 0xB596, 0xAD55, 0x9CD3, 0x9CD3, 0x9492, 0x9492, 0x9CD3, 0x9CF3, 0xA514,   // 0x0E40 (3648)
0xB5B6, 0xB5B6, 0xAD55, 0x9CD3, 0x9CD3, 0xA514, 0xA514, 0xA514, 0x9CD3, 0x8430, 0x8430, 0x8C71, 0x9CD3, 0x9CF3, 0x9492, 0x9492,   // 0x0E50 (3664)
0x8C51, 0x94B2, 0x9CD3, 0x94B2, 0x9492, 0x8C51, 0x8430, 0x8430, 0x8430, 0x7BCF, 0x6B4D, 0x5ACB, 0x4228, 0x39C7, 0x3186, 0x2124,   // 0x0E60 (3680)
0x18E3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x1082, 0x0861, 0x0861, 0x1082,   // 0x0E70 (3696)
0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x1082, 0x528A, 0x738E, 0x9492, 0xAD55, 0xAD75,   // 0x0E80 (3712)
0xB596, 0xAD75, 0xA534, 0xAD55, 0xAD75, 0xB596, 0xB596, 0xB5B6, 0xB596, 0xAD75, 0xB596, 0xBDD7, 0xBDD7, 0xA514, 0x8C71, 0x8430,   // 0x0E90 (3728)
0x8430, 0x8C71, 0x8C71, 0x9CD3, 0xAD75, 0xB5B6, 0xAD75, 0x9CD3, 0x94B2, 0x94B2, 0x9492, 0xA514, 0xA514, 0x9CD3, 0xAD55, 0xB5B6,   // 0x0EA0 (3744)
0xB5B6, 0xA534, 0x9CD3, 0x94B2, 0xA514, 0xA514, 0x9CF3, 0x9492, 0x7BEF, 0x8410, 0x8C51, 0x9492, 0xA514, 0xAD55, 0xAD55, 0xA514,   // 0x0EB0 (3760)
0xA514, 0x9CD3, 0x8C71, 0x9492, 0x8C71, 0x8430, 0x7BEF, 0x7BEF, 0x73AE, 0x632C, 0x5ACB, 0x4A69, 0x39E7, 0x3186, 0x2945, 0x2104,   // 0x0EC0 (3776)
0x18E3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0861, 0x1082, 0x10A2, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082,   // 0x0ED0 (3792)
0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x2104, 0x630C, 0x7BCF, 0x8C71, 0xAD55, 0xB596, 0xB596,   // 0x0EE0 (3808)
0xB5B6, 0xB596, 0xAD55, 0xB596, 0xB596, 0xBDF7, 0xC618, 0xBDD7, 0xBDD7, 0xBDD7, 0xB5B6, 0xAD75, 0xA514, 0x94B2, 0x8C51, 0x8C51,   // 0x0EF0 (3824)
0x8410, 0x8C71, 0x9CD3, 0xAD55, 0xA514, 0x8C71, 0x8C51, 0x8C51, 0x9492, 0x9CD3, 0xAD55, 0xAD55, 0xA534, 0xAD75, 0xB596, 0xB596,   // 0x0F00 (3840)
0xA534, 0x9CF3, 0x9CD3, 0xA514, 0x9CF3, 0x9CD3, 0x94B2, 0x8C51, 0x8C71, 0x9CD3, 0x9CF3, 0xAD75, 0xBDD7, 0xB5B6, 0xB596, 0xB596,   // 0x0F10 (3856)
0xA534, 0x9492, 0x8430, 0x8C51, 0x8430, 0x8410, 0x7BEF, 0x7BEF, 0x6B4D, 0x5AEB, 0x52AA, 0x4208, 0x3186, 0x2945, 0x2104, 0x18E3,   // 0x0F20 (3872)
0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x1082, 0x10A2, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x0861,   // 0x0F30 (3888)
0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x2945, 0x6B4D, 0x73AE, 0x8C51, 0xA534, 0xAD55, 0xAD75, 0xB5B6,   // 0x0F40 (3904)
0xBDD7, 0xB596, 0xB5B6, 0xB5B6, 0xC618, 0xBDF7, 0xAD75, 0xAD75, 0xB5B6, 0xB5B6, 0x9CF3, 0x94B2, 0xAD55, 0x8C71, 0x8430, 0x8430,   // 0x0F50 (3920)
0x94B2, 0x9CF3, 0x94B2, 0x8C71, 0x8C51, 0x8C51, 0x8C71, 0x94B2, 0xA514, 0xA534, 0xAD75, 0xB5B6, 0xB5B6, 0xB596, 0xAD75, 0xAD75,   // 0x0F60 (3936)
0xA534, 0x9CF3, 0x9CF3, 0x9CD3, 0x9CD3, 0x9CD3, 0x9CD3, 0x9CD3, 0x9CF3, 0xAD55, 0xBDD7, 0xC638, 0xBDF7, 0xB5B6, 0xBDD7, 0xB596,   // 0x0F70 (3952)
0x9CD3, 0x8430, 0x8430, 0x8410, 0x7BEF, 0x8430, 0x9CD3, 0x7BEF, 0x632C, 0x52AA, 0x4228, 0x3186, 0x2945, 0x2124, 0x2104, 0x18C3,   // 0x0F80 (3968)
0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861,   // 0x0F90 (3984)
0x0861, 0x0841, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x2965, 0x6B4D, 0x73AE, 0x8430, 0x9CF3, 0xA534, 0xAD75, 0xB5B6, 0xBDD7,   // 0x0FA0 (4000)
0xB5B6, 0xBDD7, 0xBDD7, 0xB596, 0xA534, 0x9492, 0x8C51, 0x9CF3, 0xAD75, 0x9492, 0x9CD3, 0x9CF3, 0x8C51, 0x8410, 0x8430, 0x9492,   // 0x0FB0 (4016)
0x9CD3, 0x8C71, 0x9492, 0x8C51, 0x8C71, 0x9492, 0x94B2, 0x9CF3, 0xA534, 0xB596, 0xB5B6, 0xB596, 0xBDD7, 0xAD75, 0xAD75, 0xAD75,   // 0x0FC0 (4032)
0xA514, 0xA514, 0x9CF3, 0xA514, 0xA514, 0xA514, 0x9CD3, 0x94B2, 0xA534, 0xBDD7, 0xBDF7, 0xB5B6, 0xBDF7, 0xC618, 0xB596, 0xA514,   // 0x0FD0 (4048)
0x8C71, 0x8410, 0x73AE, 0x7BCF, 0x8410, 0x9492, 0x8410, 0x630C, 0x528A, 0x4228, 0x31A6, 0x2945, 0x2124, 0x2104, 0x18C3, 0x1082,   // 0x0FE0 (4064)
0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861,   // 0x0FF0 (4080)
0x0841, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x31A6, 0x632C, 0x73AE, 0x8C51, 0x9CD3, 0x9CF3, 0xAD55, 0xB596, 0xBDD7, 0xB5B6,   // 0x1000 (4096)
0xB5B6, 0xBDF7, 0x9CF3, 0x8C51, 0x8430, 0x8410, 0x7BEF, 0x8430, 0x8430, 0x9CF3, 0x94B2, 0x94B2, 0x94B2, 0x8410, 0x8C71, 0x94B2,   // 0x1010 (4112)
0x9492, 0x8C71, 0x8C51, 0x9492, 0x9492, 0x94B2, 0x94B2, 0xAD55, 0xB5B6, 0xB5B6, 0xB5B6, 0xAD75, 0xA534, 0xAD75, 0xB5B6, 0xAD75,   // 0x1020 (4128)
0xAD55, 0xAD75, 0xB596, 0xB596, 0xAD75, 0x9CD3, 0x9CD3, 0xAD55, 0xB596, 0xB5B6, 0xB5B6, 0xBDD7, 0xBDD7, 0xB5B6, 0xAD55, 0x9CD3,   // 0x1030 (4144)
0x8430, 0x738E, 0x7BCF, 0x8430, 0x8410, 0x73AE, 0x5ACB, 0x528A, 0x528A, 0x4A49, 0x2965, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x1082,   // 0x1040 (4160)
0x0861, 0x0861, 0x0861, 0x0841, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841,   // 0x1050 (4176)
0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x39C7, 0x6B4D, 0x7BCF, 0x8430, 0x94B2, 0xA514, 0xAD75, 0xB5B6, 0xC618, 0xBDD7, 0xB5B6,   // 0x1060 (4192)
0xBDF7, 0x9CD3, 0x8430, 0x7BEF, 0x7BEF, 0x8410, 0x7BCF, 0x8410, 0x8C71, 0x8C51, 0x94B2, 0x9CD3, 0x8C51, 0x94B2, 0xA514, 0xA534,   // 0x1070 (4208)
0x9CD3, 0x94B2, 0x9492, 0x9492, 0x94B2, 0x9492, 0xA534, 0xBDF7, 0xBDF7, 0xB5B6, 0xA534, 0x9CF3, 0xA514, 0xBDD7, 0xC638, 0xBDF7,   // 0x1080 (4224)
0xB596, 0xB5B6, 0xC618, 0xB5B6, 0xAD55, 0xA534, 0xA534, 0xAD55, 0xB5B6, 0xBDF7, 0xB5B6, 0xB5B6, 0xBDF7, 0xB596, 0xAD55, 0x94B2,   // 0x1090 (4240)
0x8410, 0x8410, 0x8410, 0x73AE, 0x738E, 0x632C, 0x5ACB, 0x528A, 0x528A, 0x31A6, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x1082,   // 0x10A0 (4256)
0x0861, 0x0841, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841,   // 0x10B0 (4272)
0x0841, 0x0020, 0x0000, 0x0020, 0x39C7, 0x6B4D, 0x7BCF, 0x8430, 0x94B2, 0xA534, 0xAD55, 0xB5B6, 0xC618, 0xBDD7, 0xB5B6, 0xAD75,   // 0x10C0 (4288)
0x94B2, 0x8C71, 0x8C51, 0x8410, 0x8410, 0x8410, 0x8430, 0x9492, 0xA514, 0x9CF3, 0x94B2, 0x8C71, 0xA514, 0xAD55, 0xB5B6, 0xBDD7,   // 0x10D0 (4304)
0xA534, 0x94B2, 0x9492, 0x8C71, 0x94B2, 0xA534, 0xBDD7, 0xBDD7, 0xAD55, 0x9CF3, 0x9CD3, 0xA534, 0xBDF7, 0xD69A, 0xCE59, 0xBDD7,   // 0x10E0 (4320)
0xBDD7, 0xBDF7, 0xBDD7, 0xAD75, 0x9CF3, 0x9CD3, 0xA534, 0xAD75, 0xBDD7, 0xBDD7, 0xC638, 0xCE59, 0xB5B6, 0xA534, 0xA514, 0x94B2,   // 0x10F0 (4336)
0x8C71, 0x8430, 0x8410, 0x7BCF, 0x6B6D, 0x630C, 0x528A, 0x4228, 0x39C7, 0x2945, 0x2104, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861,   // 0x1100 (4352)
0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841,   // 0x1110 (4368)
0x0020, 0x0000, 0x0020, 0x39E7, 0x6B4D, 0x7BCF, 0x8430, 0x9492, 0x9CF3, 0xAD55, 0xBDD7, 0xC618, 0xBDD7, 0xB5B6, 0x9CF3, 0x8C71,   // 0x1120 (4384)
0x9492, 0x8C51, 0x8410, 0x7BEF, 0x8410, 0x8430, 0xA514, 0xBDD7, 0xB596, 0xAD75, 0xA514, 0xAD75, 0xB596, 0xBDF7, 0xB5B6, 0x9CD3,   // 0x1130 (4400)
0x9CF3, 0x94B2, 0x94B2, 0x9CD3, 0xA534, 0xB5B6, 0xB596, 0x9CD3, 0x8C71, 0x94B2, 0xB596, 0xC618, 0xCE59, 0xCE59, 0xC618, 0xCE79,   // 0x1140 (4416)
0xC638, 0xBDF7, 0xB596, 0x9CF3, 0x9CD3, 0xAD55, 0xAD75, 0xB5B6, 0xC618, 0xCE59, 0xCE59, 0xBDF7, 0xAD55, 0xAD55, 0xA534, 0x94B2,   // 0x1150 (4432)
0x9CD3, 0x9492, 0x8410, 0x73AE, 0x6B4D, 0x528A, 0x39E7, 0x31A6, 0x2965, 0x2104, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861,   // 0x1160 (4448)
0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0020, 0x0020,   // 0x1170 (4464)
0x0000, 0x0841, 0x4208, 0x6B6D, 0x7BCF, 0x8430, 0x9492, 0x9CF3, 0xAD55, 0xB5B6, 0xBDF7, 0xBDF7, 0xBDD7, 0xA514, 0x9492, 0x9492,   // 0x1180 (4480)
0x8430, 0x7BEF, 0x7BEF, 0x7BEF, 0x8430, 0xAD75, 0xB5B6, 0xAD55, 0xA534, 0xB596, 0xB5B6, 0xB596, 0xAD75, 0x9CF3, 0x9492, 0x9CF3,   // 0x1190 (4496)
0xA534, 0xAD75, 0x9CF3, 0xA534, 0xBDF7, 0xB596, 0x94B2, 0x9492, 0x9CD3, 0xAD75, 0xBDD7, 0xC638, 0xC638, 0xC618, 0xCE59, 0xC618,   // 0x11A0 (4512)
0xBDF7, 0xBDD7, 0xAD55, 0xA534, 0xB596, 0xB5B6, 0xBDF7, 0xC638, 0xC618, 0xBDF7, 0xC618, 0xC618, 0xBDD7, 0xAD75, 0xA514, 0xA514,   // 0x11B0 (4528)
0x94B2, 0x8430, 0x73AE, 0x630C, 0x4228, 0x39C7, 0x2965, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x1082,   // 0x11C0 (4544)
0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0020, 0x0020, 0x0000,   // 0x11D0 (4560)
0x0841, 0x4A49, 0x738E, 0x73AE, 0x8410, 0x8C71, 0x9492, 0xA514, 0xB5B6, 0xC638, 0xBDF7, 0xBDF7, 0xB596, 0xA514, 0x8C51, 0x8410,   // 0x11E0 (4576)
0x8410, 0x8430, 0x7BEF, 0x8C71, 0xAD55, 0xA534, 0xA534, 0xAD55, 0xB5B6, 0xAD75, 0xA514, 0x9CD3, 0x94B2, 0x9CD3, 0x9CD3, 0xA534,   // 0x11F0 (4592)
0xA534, 0x9CF3, 0xAD75, 0xC618, 0xAD55, 0x9CD3, 0x94B2, 0x94B2, 0xA534, 0xBDD7, 0xC618, 0xC618, 0xC638, 0xC638, 0xC638, 0xC618,   // 0x1200 (4608)
0xBDF7, 0xBDD7, 0xB5B6, 0xBDD7, 0xC618, 0xC638, 0xCE59, 0xCE59, 0xC618, 0xC638, 0xCE59, 0xC638, 0xBDD7, 0xB596, 0xA534, 0x9CD3,   // 0x1210 (4624)
0x8430, 0x738E, 0x5AEB, 0x4208, 0x3186, 0x2124, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082,   // 0x1220 (4640)
0x10A2, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0020, 0x0000, 0x0841,   // 0x1230 (4656)
0x4A49, 0x73AE, 0x73AE, 0x8410, 0x94B2, 0x94B2, 0xA514, 0xAD75, 0xC618, 0xC638, 0xBDF7, 0xAD55, 0xA534, 0x8C51, 0x8C51, 0x8430,   // 0x1240 (4672)
0x8430, 0x8C51, 0x8C71, 0x9CF3, 0xA514, 0xA514, 0xA534, 0xAD75, 0xAD55, 0xAD55, 0xA514, 0x9CD3, 0x9CD3, 0x9CF3, 0x9CF3, 0x94B2,   // 0x1250 (4688)
0x9CF3, 0xAD75, 0xAD55, 0x9CD3, 0x9CF3, 0x9CD3, 0xA514, 0xAD75, 0xBDF7, 0xC618, 0xC618, 0xCE59, 0xCE59, 0xCE79, 0xC638, 0xC618,   // 0x1260 (4704)
0xBDF7, 0xBDD7, 0xBDF7, 0xCE59, 0xCE59, 0xCE59, 0xCE79, 0xCE79, 0xCE59, 0xCE79, 0xCE59, 0xBDF7, 0xB596, 0xA534, 0x9CD3, 0x8430,   // 0x1270 (4720)
0x6B6D, 0x52AA, 0x39E7, 0x3186, 0x2124, 0x2104, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x1280 (4736)
0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0020, 0x0000, 0x0020, 0x4228,   // 0x1290 (4752)
0x738E, 0x73AE, 0x8430, 0x9CD3, 0x9CF3, 0xA534, 0xA534, 0xB596, 0xBDF7, 0xB5B6, 0xAD75, 0xA534, 0x94B2, 0x9CD3, 0x9492, 0x8C71,   // 0x12A0 (4768)
0x9CF3, 0x94B2, 0x9CF3, 0xA534, 0x9CF3, 0x94B2, 0xA534, 0xA534, 0xBDD7, 0xB596, 0x9CD3, 0x9CD3, 0xA534, 0xA514, 0x9CD3, 0x9CF3,   // 0x12B0 (4784)
0xA514, 0x94B2, 0x9492, 0x94B2, 0x9CF3, 0xB5B6, 0xBDD7, 0xC618, 0xC638, 0xC638, 0xC638, 0xC638, 0xCE59, 0xCE59, 0xC638, 0xC618,   // 0x12C0 (4800)
0xC618, 0xC638, 0xC638, 0xCE59, 0xCE59, 0xCE79, 0xCE79, 0xCE79, 0xD69A, 0xCE79, 0xBDF7, 0xAD75, 0xA514, 0x94B2, 0x7BEF, 0x6B4D,   // 0x12D0 (4816)
0x4A49, 0x39C7, 0x2965, 0x2124, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0841, 0x0861, 0x1082, 0x0861, 0x0861, 0x1082,   // 0x12E0 (4832)
0x1082, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0000, 0x0020, 0x39C7, 0x6B4D,   // 0x12F0 (4848)
0x73AE, 0x8410, 0x94B2, 0x9CD3, 0xA514, 0xAD75, 0xAD75, 0xB596, 0xAD75, 0xB596, 0xAD75, 0xA514, 0xAD55, 0x9CF3, 0x9CD3, 0xAD75,   // 0x1300 (4864)
0xAD55, 0xAD55, 0xB596, 0x9CD3, 0x9CD3, 0xAD75, 0xA514, 0xB596, 0xAD75, 0x9CF3, 0x9CF3, 0x9CD3, 0x9CD3, 0x9CF3, 0x9CF3, 0x9CD3,   // 0x1310 (4880)
0x9492, 0x94B2, 0xA514, 0xA534, 0xB5B6, 0xBDF7, 0xC618, 0xCE59, 0xC618, 0xBDD7, 0xC618, 0xC638, 0xC638, 0xC638, 0xC638, 0xC638,   // 0x1320 (4896)
0xC638, 0xCE79, 0xCE59, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xD69A, 0xCE59, 0xBDF7, 0xAD75, 0x9CF3, 0x8C71, 0x7BCF, 0x630C, 0x4A49,   // 0x1330 (4912)
0x39C7, 0x2965, 0x2124, 0x18E3, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082,   // 0x1340 (4928)
0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x3186, 0x632C, 0x7BCF,   // 0x1350 (4944)
0x8410, 0x9492, 0x9492, 0x9CD3, 0xAD75, 0xB596, 0xAD55, 0xA514, 0xB596, 0xB596, 0xA534, 0xAD55, 0xAD55, 0xB596, 0xB5B6, 0xB596,   // 0x1360 (4960)
0xAD75, 0xB596, 0x94B2, 0x9CF3, 0xB596, 0xA534, 0xA534, 0xA514, 0x9CF3, 0x9CF3, 0x94B2, 0x94B2, 0x9492, 0x94B2, 0x9CF3, 0x94B2,   // 0x1370 (4976)
0x9CD3, 0xB596, 0xAD75, 0xA534, 0xAD75, 0xC618, 0xC638, 0xBDF7, 0xBDD7, 0xBDF7, 0xBDF7, 0xC638, 0xCE59, 0xC638, 0xC638, 0xCE59,   // 0x1380 (4992)
0xCE79, 0xCE79, 0xD69A, 0xCE59, 0xCE59, 0xCE79, 0xCE59, 0xC638, 0xBDD7, 0xAD55, 0x9CD3, 0x8C51, 0x73AE, 0x5ACB, 0x4A49, 0x39E7,   // 0x1390 (5008)
0x3186, 0x2124, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0861, 0x1082, 0x10A2,   // 0x13A0 (5024)
0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x2124, 0x630C, 0x73AE, 0x8430,   // 0x13B0 (5040)
0x8C71, 0x9492, 0x94B2, 0x9CF3, 0xA534, 0xA534, 0x9CD3, 0xAD55, 0xB5B6, 0xAD75, 0xAD55, 0xB5B6, 0xBDF7, 0xBDD7, 0xA534, 0xAD55,   // 0x13C0 (5056)
0xA534, 0x94B2, 0x9CF3, 0xAD55, 0xA534, 0x9CF3, 0x94B2, 0x9CD3, 0x9CF3, 0x9492, 0x9492, 0x8C71, 0x8C71, 0x9CF3, 0x9492, 0x8C71,   // 0x13D0 (5072)
0xA514, 0xB596, 0xA534, 0xAD55, 0xC618, 0xCE59, 0xC638, 0xBDF7, 0xBDD7, 0xBDF7, 0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xCE59,   // 0x13E0 (5088)
0xCE79, 0xCE59, 0xC638, 0xC638, 0xC638, 0xC638, 0xBDF7, 0xBDD7, 0xAD55, 0x9CD3, 0x8C71, 0x738E, 0x5ACB, 0x4A49, 0x39E7, 0x3186,   // 0x13F0 (5104)
0x2945, 0x2104, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x1082, 0x10A2, 0x1082,   // 0x1400 (5120)
0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x18E3, 0x5AEB, 0x6B6D, 0x8410, 0x8430,   // 0x1410 (5136)
0x8C51, 0x94B2, 0x9CD3, 0xA514, 0xA534, 0x9CD3, 0x9CF3, 0xB596, 0xB5B6, 0xB5B6, 0xBDD7, 0xAD55, 0xA514, 0x94B2, 0xA514, 0xA534,   // 0x1420 (5152)
0x9CF3, 0xA514, 0xAD55, 0xA514, 0x9CF3, 0x9492, 0x9492, 0xA514, 0x94B2, 0x8C71, 0x9CD3, 0x9CD3, 0x9CF3, 0x94B2, 0x9492, 0x9CF3,   // 0x1430 (5168)
0xAD75, 0xB5B6, 0xC618, 0xC618, 0xC618, 0xC638, 0xC638, 0xC618, 0xC638, 0xC638, 0xC638, 0xCE59, 0xCE79, 0xCE79, 0xCE79, 0xCE79,   // 0x1440 (5184)
0xCE59, 0xCE79, 0xCE59, 0xC638, 0xC638, 0xC618, 0xBDD7, 0xAD75, 0x9CD3, 0x8C51, 0x6B6D, 0x52AA, 0x4228, 0x39E7, 0x2965, 0x2124,   // 0x1450 (5200)
0x18E3, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082,   // 0x1460 (5216)
0x0861, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x1082, 0x528A, 0x6B6D, 0x7BEF, 0x7BEF, 0x7BCF,   // 0x1470 (5232)
0x9492, 0xA514, 0xA534, 0xAD75, 0xA514, 0xA534, 0xB5B6, 0xB596, 0xB5B6, 0xB5B6, 0xA514, 0x9492, 0x9CD3, 0xB596, 0xB5B6, 0xAD55,   // 0x1480 (5248)
0xB596, 0xB596, 0xA514, 0x9CD3, 0x8C71, 0x8C71, 0x9CD3, 0x9CD3, 0x8C71, 0x9CD3, 0x94B2, 0x9CD3, 0x9CD3, 0xAD75, 0xBDD7, 0xBDD7,   // 0x1490 (5264)
0xBDF7, 0xC638, 0xC638, 0xC618, 0xC638, 0xC638, 0xC618, 0xC638, 0xC618, 0xC618, 0xCE59, 0xD69A, 0xD6BA, 0xDEFB, 0xD6BA, 0xCE79,   // 0x14A0 (5280)
0xCE59, 0xCE59, 0xCE59, 0xC618, 0xC618, 0xBDD7, 0xAD75, 0x9CD3, 0x8410, 0x6B4D, 0x528A, 0x4208, 0x39C7, 0x2965, 0x2104, 0x18E3,   // 0x14B0 (5296)
0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x0861,   // 0x14C0 (5312)
0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0841, 0x4A49, 0x6B4D, 0x7BCF, 0x8410, 0x73AE, 0x8C51,   // 0x14D0 (5328)
0xA514, 0xAD55, 0xAD75, 0xAD55, 0xAD75, 0xB5B6, 0xB596, 0xB596, 0xB596, 0x9CF3, 0x9CD3, 0xA534, 0xAD55, 0xB5B6, 0xB5B6, 0xC618,   // 0x14E0 (5344)
0xB5B6, 0xA534, 0x94B2, 0x9492, 0x8C51, 0x8C51, 0x8C71, 0x9492, 0x94B2, 0x8C71, 0x94B2, 0xAD55, 0xC618, 0xCE79, 0xC618, 0xC618,   // 0x14F0 (5360)
0xCE59, 0xC618, 0xC638, 0xC638, 0xBDF7, 0xC638, 0xC638, 0xC618, 0xBDD7, 0xC638, 0xD69A, 0xD6BA, 0xDEFB, 0xD6BA, 0xCE79, 0xCE59,   // 0x1500 (5376)
0xC638, 0xC638, 0xC618, 0xBDF7, 0xBDD7, 0xAD75, 0x9CD3, 0x7BEF, 0x632C, 0x4A69, 0x4208, 0x31A6, 0x2945, 0x2104, 0x18C3, 0x10A2,   // 0x1510 (5392)
0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x0841, 0x0020,   // 0x1520 (5408)
0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x39E7, 0x632C, 0x738E, 0x8430, 0x8410, 0x9492, 0x9CD3,   // 0x1530 (5424)
0xA514, 0xAD75, 0xB596, 0xB596, 0xBDD7, 0xBDF7, 0xB5B6, 0xBDD7, 0xB596, 0xAD75, 0xB596, 0xA514, 0xA534, 0xB5B6, 0xCE59, 0xBDF7,   // 0x1540 (5440)
0xA534, 0x9CD3, 0x94B2, 0x8C71, 0x9492, 0x8C71, 0x9492, 0x9492, 0x9CD3, 0xAD75, 0xB5B6, 0xC618, 0xCE59, 0xC638, 0xC638, 0xCE79,   // 0x1550 (5456)
0xCE59, 0xC638, 0xC618, 0xC618, 0xC638, 0xCE59, 0xC638, 0xC638, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE59,   // 0x1560 (5472)
0xC638, 0xC638, 0xBDF7, 0xB5B6, 0xAD75, 0x9CF3, 0x8C71, 0x6B4D, 0x4A69, 0x4208, 0x39C7, 0x2965, 0x2104, 0x18C3, 0x10A2, 0x1082,   // 0x1570 (5488)
0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x0861, 0x0841, 0x0020, 0x0020,   // 0x1580 (5504)
0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x2945, 0x630C, 0x738E, 0x7BEF, 0x8C51, 0x8C51, 0x94B2, 0x9CD3,   // 0x1590 (5520)
0xA514, 0xAD75, 0xB5B6, 0xBDD7, 0xBDD7, 0xBDD7, 0xBDF7, 0xC618, 0xB5B6, 0xB5B6, 0xAD75, 0xAD55, 0xBDD7, 0xD69A, 0xCE79, 0xBDD7,   // 0x15A0 (5536)
0xAD75, 0xAD55, 0xA514, 0x9492, 0x8C71, 0x94B2, 0x9492, 0x9CF3, 0xAD75, 0xB5B6, 0xC618, 0xCE59, 0xCE59, 0xCE59, 0xCE79, 0xCE59,   // 0x15B0 (5552)
0xC638, 0xC638, 0xC618, 0xC638, 0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xCE79, 0xCE59, 0xC638,   // 0x15C0 (5568)
0xC638, 0xBDF7, 0xBDD7, 0xB596, 0xA514, 0x8C71, 0x738E, 0x528A, 0x4208, 0x39C7, 0x2945, 0x2104, 0x18E3, 0x10A2, 0x1082, 0x0861,   // 0x15D0 (5584)
0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x1082, 0x10A2, 0x1082, 0x0861, 0x0020, 0x0020, 0x0020, 0x0020,   // 0x15E0 (5600)
0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x18C3, 0x5AEB, 0x6B6D, 0x7BCF, 0x8C51, 0x8430, 0x94B2, 0x9CD3, 0x9CD3,   // 0x15F0 (5616)
0xAD55, 0xB5B6, 0xBDD7, 0xBDF7, 0xBDD7, 0xB5B6, 0xBDD7, 0xBDF7, 0xC618, 0xC618, 0xBDF7, 0xC638, 0xD69A, 0xD69A, 0xC638, 0xBDF7,   // 0x1600 (5632)
0xB5B6, 0xAD55, 0xA514, 0x9CF3, 0x9492, 0x94B2, 0xA514, 0xAD55, 0xBDD7, 0xC638, 0xCE79, 0xCE59, 0xCE59, 0xC638, 0xC638, 0xC638,   // 0x1610 (5648)
0xCE79, 0xCE79, 0xC638, 0xC638, 0xC638, 0xC638, 0xC618, 0xCE59, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE59, 0xC638, 0xC638, 0xC638,   // 0x1620 (5664)
0xCE59, 0xBDF7, 0xB596, 0xA534, 0x8C71, 0x73AE, 0x5AEB, 0x4208, 0x3186, 0x2945, 0x2104, 0x18E3, 0x10A2, 0x1082, 0x0861, 0x0861,   // 0x1630 (5680)
0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x1082, 0x1082, 0x1082, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020,   // 0x1640 (5696)
0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x4A49, 0x632C, 0x738E, 0x8410, 0x8C51, 0x9492, 0x8C71, 0x9CD3, 0xAD55,   // 0x1650 (5712)
0xB5B6, 0xBDF7, 0xBDF7, 0xBDF7, 0xB596, 0xB596, 0xBDF7, 0xC638, 0xC638, 0xC638, 0xC638, 0xCE79, 0xD6BA, 0xCE59, 0xC618, 0xBDD7,   // 0x1660 (5728)
0xA534, 0xB5B6, 0xB5B6, 0xAD55, 0xA514, 0xAD55, 0xB5B6, 0xC618, 0xCE59, 0xCE59, 0xCE59, 0xC638, 0xC618, 0xC618, 0xC618, 0xCE79,   // 0x1670 (5744)
0xD6BA, 0xCE79, 0xC638, 0xCE59, 0xC638, 0xCE59, 0xCE79, 0xCE59, 0xCE59, 0xCE59, 0xCE79, 0xCE59, 0xCE59, 0xC638, 0xC638, 0xCE59,   // 0x1680 (5760)
0xBDF7, 0xAD75, 0x9CF3, 0x8C71, 0x7BCF, 0x5AEB, 0x4208, 0x3186, 0x2945, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861,   // 0x1690 (5776)
0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x0861, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020,   // 0x16A0 (5792)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x31A6, 0x632C, 0x6B6D, 0x7BEF, 0x8430, 0x8C51, 0x8C51, 0x9CD3, 0xA534, 0xAD75,   // 0x16B0 (5808)
0xB5B6, 0xBDD7, 0xBDD7, 0xBDF7, 0xBDD7, 0xB5B6, 0xC638, 0xC638, 0xCE59, 0xC618, 0xCE59, 0xDEDB, 0xCE59, 0xCE59, 0xC618, 0xBDF7,   // 0x16C0 (5824)
0xC618, 0xC638, 0xC618, 0xB5B6, 0xB5B6, 0xC638, 0xCE79, 0xCE59, 0xC638, 0xC638, 0xC638, 0xC638, 0xC618, 0xC638, 0xCE59, 0xCE79,   // 0x16D0 (5840)
0xCE79, 0xCE59, 0xCE79, 0xCE59, 0xCE79, 0xCE59, 0xC638, 0xCE59, 0xCE59, 0xD69A, 0xD6BA, 0xD69A, 0xC638, 0xBDF7, 0xBDF7, 0xB5B6,   // 0x16E0 (5856)
0xA534, 0x8C71, 0x7BEF, 0x738E, 0x52AA, 0x39E7, 0x3186, 0x2124, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x0861, 0x0861, 0x0861, 0x0841,   // 0x16F0 (5872)
0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x0861, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000,   // 0x1700 (5888)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x2104, 0x5ACB, 0x6B6D, 0x7BEF, 0x8430, 0x8430, 0x8430, 0x94B2, 0xA514, 0xA534, 0xB596,   // 0x1710 (5904)
0xBDD7, 0xBDD7, 0xC618, 0xC618, 0xB5B6, 0xBDF7, 0xC618, 0xC638, 0xC638, 0xCE79, 0xD6BA, 0xD69A, 0xCE79, 0xCE79, 0xCE79, 0xCE79,   // 0x1720 (5920)
0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xC638, 0xC618, 0xC638, 0xCE59, 0xCE59, 0xCE59, 0xC638, 0xC638, 0xCE79, 0xCE79,   // 0x1730 (5936)
0xC638, 0xCE59, 0xD69A, 0xD69A, 0xCE59, 0xC638, 0xCE59, 0xCE79, 0xD69A, 0xDEDB, 0xD69A, 0xC638, 0xC618, 0xBDF7, 0xAD55, 0x94B2,   // 0x1740 (5952)
0x8410, 0x6B4D, 0x5ACB, 0x4A69, 0x39C7, 0x2965, 0x2945, 0x2124, 0x2124, 0x2104, 0x18C3, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841,   // 0x1750 (5968)
0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x0861, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000,   // 0x1760 (5984)
0x0000, 0x0000, 0x0000, 0x0000, 0x1082, 0x4A69, 0x6B4D, 0x7BCF, 0x8430, 0x8430, 0x8C51, 0x9492, 0x9CD3, 0xA534, 0xAD75, 0xB5B6,   // 0x1770 (6000)
0xB596, 0xBDD7, 0xBDF7, 0xC618, 0xBDF7, 0xC638, 0xCE59, 0xC638, 0xCE79, 0xD69A, 0xD6BA, 0xD69A, 0xD69A, 0xD69A, 0xD6BA, 0xDEDB,   // 0x1780 (6016)
0xD6BA, 0xD6BA, 0xD6BA, 0xD6BA, 0xD69A, 0xCE79, 0xCE79, 0xD69A, 0xD69A, 0xD69A, 0xCE59, 0xC618, 0xCE59, 0xCE59, 0xC618, 0xBDF7,   // 0x1790 (6032)
0xC638, 0xCE79, 0xCE79, 0xCE79, 0xCE59, 0xC638, 0xCE79, 0xCE79, 0xCE59, 0xC638, 0xCE59, 0xC638, 0xBDF7, 0xA534, 0x8C71, 0x7BEF,   // 0x17A0 (6048)
0x632C, 0x528A, 0x4A49, 0x39E7, 0x2965, 0x2965, 0x2945, 0x2124, 0x2104, 0x18C3, 0x1082, 0x0861, 0x0841, 0x0861, 0x0861, 0x0861,   // 0x17B0 (6064)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x17C0 (6080)
0x0000, 0x0000, 0x0000, 0x0020, 0x39C7, 0x630C, 0x73AE, 0x7BEF, 0x8430, 0x8430, 0x8C51, 0x94B2, 0xA514, 0xAD75, 0xB5B6, 0xBDD7,   // 0x17D0 (6096)
0xBDD7, 0xBDD7, 0xC618, 0xC638, 0xCE59, 0xCE79, 0xCE59, 0xD69A, 0xD69A, 0xD69A, 0xD69A, 0xD6BA, 0xDEDB, 0xDEDB, 0xDEDB, 0xDEDB,   // 0x17E0 (6112)
0xDEDB, 0xD6BA, 0xD69A, 0xD6BA, 0xDEDB, 0xD6BA, 0xDEDB, 0xD6BA, 0xCE79, 0xC638, 0xC638, 0xC618, 0xC618, 0xBDF7, 0xC618, 0xC638,   // 0x17F0 (6128)
0xC638, 0xCE59, 0xCE59, 0xCE59, 0xC638, 0xCE59, 0xC638, 0xC618, 0xC618, 0xC618, 0xBDF7, 0xB5B6, 0xA534, 0x8C51, 0x73AE, 0x632C,   // 0x1800 (6144)
0x52AA, 0x4228, 0x39E7, 0x31A6, 0x3186, 0x2945, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x1810 (6160)
0x0861, 0x0841, 0x0861, 0x0861, 0x0861, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1820 (6176)
0x0000, 0x0000, 0x0000, 0x2104, 0x5AEB, 0x6B6D, 0x7BEF, 0x7BEF, 0x7BCF, 0x8C51, 0x9CD3, 0x9CF3, 0xAD75, 0xB5B6, 0xBDD7, 0xB5B6,   // 0x1830 (6192)
0xB5B6, 0xBDF7, 0xC618, 0xC638, 0xCE59, 0xD69A, 0xD69A, 0xD69A, 0xD6BA, 0xD6BA, 0xDEFB, 0xDEFB, 0xDEDB, 0xDEDB, 0xDEFB, 0xDEFB,   // 0x1840 (6208)
0xDEDB, 0xCE79, 0xD69A, 0xDEDB, 0xDEDB, 0xD6BA, 0xD69A, 0xC638, 0xC638, 0xC618, 0xC618, 0xC638, 0xC638, 0xC638, 0xC638, 0xC638,   // 0x1850 (6224)
0xCE59, 0xC638, 0xC638, 0xC618, 0xC618, 0xC618, 0xC618, 0xC618, 0xBDF7, 0xBDD7, 0xB596, 0xA534, 0x9492, 0x7BCF, 0x630C, 0x528A,   // 0x1860 (6240)
0x4208, 0x39C7, 0x31A6, 0x2965, 0x2124, 0x2104, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841,   // 0x1870 (6256)
0x0841, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1880 (6272)
0x0000, 0x0000, 0x0861, 0x4A69, 0x6B4D, 0x7BCF, 0x7BEF, 0x7BCF, 0x8410, 0x94B2, 0x9CD3, 0xA534, 0xAD75, 0xB596, 0xB596, 0xB5B6,   // 0x1890 (6288)
0xBDF7, 0xCE59, 0xC638, 0xCE59, 0xCE79, 0xD69A, 0xD69A, 0xD6BA, 0xDEDB, 0xDEFB, 0xDEFB, 0xDEDB, 0xDEDB, 0xE71C, 0xEF5D, 0xE73C,   // 0x18A0 (6304)
0xDEFB, 0xDEDB, 0xD6BA, 0xD6BA, 0xDEDB, 0xD6BA, 0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xCE79, 0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xC638,   // 0x18B0 (6320)
0xC618, 0xC638, 0xC618, 0xC638, 0xC638, 0xC618, 0xC618, 0xC618, 0xBDF7, 0xAD75, 0xA514, 0x9492, 0x7BCF, 0x630C, 0x4A69, 0x4228,   // 0x18C0 (6336)
0x39E7, 0x31A6, 0x2945, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020,   // 0x18D0 (6352)
0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x18E0 (6368)
0x0000, 0x0000, 0x2965, 0x630C, 0x738E, 0x8410, 0x7BEF, 0x8410, 0x9492, 0x9CD3, 0xA514, 0xAD55, 0xAD75, 0xB596, 0xB5B6, 0xBDF7,   // 0x18F0 (6384)
0xC638, 0xC638, 0xCE59, 0xD69A, 0xCE79, 0xCE79, 0xD69A, 0xD6BA, 0xDEDB, 0xDEDB, 0xDEFB, 0xDEFB, 0xE71C, 0xE71C, 0xDEFB, 0xDEFB,   // 0x1900 (6400)
0xD6BA, 0xD69A, 0xD6BA, 0xD6BA, 0xD69A, 0xCE59, 0xCE59, 0xD6BA, 0xD6BA, 0xCE79, 0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xC638,   // 0x1910 (6416)
0xC638, 0xC638, 0xC638, 0xC638, 0xC618, 0xBDF7, 0xC618, 0xBDF7, 0xAD55, 0x94B2, 0x8C51, 0x6B6D, 0x5ACB, 0x4A69, 0x4228, 0x39C7,   // 0x1920 (6432)
0x2965, 0x2945, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0861,   // 0x1930 (6448)
0x0861, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1940 (6464)
0x0000, 0x1082, 0x528A, 0x6B6D, 0x7BEF, 0x8410, 0x8410, 0x8C71, 0x9CD3, 0x9CF3, 0xA534, 0xA534, 0xAD75, 0xBDD7, 0xBDD7, 0xBDF7,   // 0x1950 (6480)
0xC638, 0xCE79, 0xCE79, 0xCE59, 0xD69A, 0xD6BA, 0xCE79, 0xD69A, 0xD6BA, 0xDEFB, 0xDEFB, 0xDEFB, 0xDEDB, 0xD6BA, 0xD69A, 0xD69A,   // 0x1960 (6496)
0xD69A, 0xD6BA, 0xD6BA, 0xD69A, 0xCE79, 0xCE79, 0xD6BA, 0xD6BA, 0xD69A, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE59, 0xC638, 0xC638,   // 0x1970 (6512)
0xC618, 0xBDF7, 0xBDF7, 0xBDF7, 0xBDD7, 0xBDD7, 0xB596, 0xA514, 0x9492, 0x8410, 0x6B6D, 0x5AEB, 0x4A49, 0x39E7, 0x31A6, 0x2965,   // 0x1980 (6528)
0x2945, 0x2124, 0x18E3, 0x10A2, 0x10A2, 0x1082, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0841, 0x0841,   // 0x1990 (6544)
0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x19A0 (6560)
0x0000, 0x3186, 0x6B4D, 0x7BCF, 0x8410, 0x8430, 0x8C71, 0x94B2, 0x9CD3, 0xA514, 0xA534, 0xAD75, 0xB5B6, 0xB5B6, 0xB5B6, 0xC638,   // 0x19B0 (6576)
0xD69A, 0xCE79, 0xCE59, 0xD6BA, 0xDEDB, 0xCE79, 0xD69A, 0xDEDB, 0xDEDB, 0xDEDB, 0xDEDB, 0xDEDB, 0xD6BA, 0xD69A, 0xD6BA, 0xD6BA,   // 0x19C0 (6592)
0xD6BA, 0xD69A, 0xD69A, 0xCE79, 0xCE79, 0xD69A, 0xD69A, 0xCE79, 0xCE79, 0xCE59, 0xCE59, 0xCE59, 0xC638, 0xC618, 0xC618, 0xBDF7,   // 0x19D0 (6608)
0xBDF7, 0xBDF7, 0xBDF7, 0xBDD7, 0xB5B6, 0xB596, 0xA534, 0x8C71, 0x73AE, 0x632C, 0x52AA, 0x4208, 0x31A6, 0x2965, 0x2965, 0x2945,   // 0x19E0 (6624)
0x2104, 0x18E3, 0x10A2, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0841, 0x0841,   // 0x19F0 (6640)
0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1A00 (6656)
0x0861, 0x528A, 0x73AE, 0x7BEF, 0x8430, 0x9492, 0x9492, 0x94B2, 0x9CF3, 0xA514, 0xAD55, 0xB5B6, 0xBDF7, 0xC618, 0xC638, 0xCE59,   // 0x1A10 (6672)
0xCE59, 0xCE59, 0xCE79, 0xCE79, 0xCE59, 0xD69A, 0xD6BA, 0xDEDB, 0xDEDB, 0xDEDB, 0xD6BA, 0xD6BA, 0xD69A, 0xCE79, 0xD6BA, 0xD69A,   // 0x1A20 (6688)
0xD69A, 0xCE79, 0xCE79, 0xC638, 0xC638, 0xC638, 0xC638, 0xC618, 0xC618, 0xC618, 0xC638, 0xBDF7, 0xBDD7, 0xBDF7, 0xB5B6, 0xBDD7,   // 0x1A30 (6704)
0xBDF7, 0xBDD7, 0xB5B6, 0xB5B6, 0xAD75, 0x9CD3, 0x7BEF, 0x632C, 0x52AA, 0x4228, 0x39C7, 0x2965, 0x2945, 0x2945, 0x2104, 0x18E3,   // 0x1A40 (6720)
0x18C3, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020,   // 0x1A50 (6736)
0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1A60 (6752)
0x2945, 0x632C, 0x738E, 0x7BEF, 0x8C51, 0x8C71, 0x9492, 0x9CD3, 0xA514, 0xAD75, 0xB5B6, 0xBDF7, 0xBDF7, 0xBDF7, 0xC638, 0xCE59,   // 0x1A70 (6768)
0xCE59, 0xCE59, 0xC638, 0xCE59, 0xCE79, 0xD69A, 0xD6BA, 0xD6BA, 0xD6BA, 0xD6BA, 0xD6BA, 0xD69A, 0xD69A, 0xD6BA, 0xD69A, 0xCE59,   // 0x1A80 (6784)
0xCE59, 0xCE59, 0xC638, 0xC618, 0xC618, 0xBDF7, 0xBDF7, 0xBDF7, 0xC618, 0xBDF7, 0xB5B6, 0xB5B6, 0xBDD7, 0xBDD7, 0xBDD7, 0xBDD7,   // 0x1A90 (6800)
0xB596, 0xAD75, 0xAD75, 0x9CF3, 0x8C51, 0x6B6D, 0x5ACB, 0x4A49, 0x39C7, 0x3186, 0x2124, 0x2104, 0x2104, 0x2104, 0x18E3, 0x18C3,   // 0x1AA0 (6816)
0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020,   // 0x1AB0 (6832)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0861,   // 0x1AC0 (6848)
0x4228, 0x6B6D, 0x7BCF, 0x8410, 0x8430, 0x8C71, 0x94B2, 0xA514, 0xAD75, 0xB596, 0xB596, 0xB5B6, 0xBDF7, 0xCE59, 0xCE59, 0xCE79,   // 0x1AD0 (6864)
0xCE79, 0xCE59, 0xCE79, 0xCE79, 0xD69A, 0xD69A, 0xD69A, 0xD69A, 0xD69A, 0xD6BA, 0xD6BA, 0xCE79, 0xCE79, 0xCE59, 0xCE59, 0xCE59,   // 0x1AE0 (6880)
0xCE59, 0xC638, 0xC618, 0xC618, 0xC618, 0xC618, 0xBDF7, 0xBDF7, 0xBDF7, 0xBDF7, 0xBDD7, 0xBDD7, 0xB5B6, 0xB5B6, 0xB5B6, 0xB596,   // 0x1AF0 (6896)
0xAD55, 0xA514, 0x9492, 0x7BCF, 0x630C, 0x528A, 0x4208, 0x31A6, 0x3186, 0x2124, 0x2104, 0x2104, 0x2104, 0x18E3, 0x10A2, 0x1082,   // 0x1B00 (6912)
0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000,   // 0x1B10 (6928)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x18E3,   // 0x1B20 (6944)
0x5ACB, 0x738E, 0x7BEF, 0x8410, 0x8C71, 0x94B2, 0xA514, 0xA514, 0xA534, 0xAD75, 0xB5B6, 0xBDF7, 0xC638, 0xCE79, 0xCE59, 0xCE79,   // 0x1B30 (6960)
0xCE59, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE59, 0xCE59, 0xD69A, 0xD69A, 0xCE59,   // 0x1B40 (6976)
0xCE59, 0xCE59, 0xC618, 0xC618, 0xC618, 0xC618, 0xC618, 0xCE59, 0xC638, 0xBDF7, 0xBDF7, 0xBDF7, 0xBDF7, 0xB5B6, 0xAD75, 0xA514,   // 0x1B50 (6992)
0x9CD3, 0x8C71, 0x73AE, 0x5ACB, 0x4A49, 0x39E7, 0x3186, 0x2965, 0x2124, 0x2104, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x0861,   // 0x1B60 (7008)
0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000,   // 0x1B70 (7024)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x31A6,   // 0x1B80 (7040)
0x6B4D, 0x7BCF, 0x7BCF, 0x8410, 0x8C71, 0x94B2, 0x9CD3, 0xA534, 0xAD75, 0xB5B6, 0xBDF7, 0xBDF7, 0xC638, 0xC638, 0xC618, 0xCE59,   // 0x1B90 (7056)
0xD69A, 0xCE79, 0xCE79, 0xCE59, 0xCE79, 0xCE79, 0xD69A, 0xCE59, 0xCE59, 0xCE79, 0xCE79, 0xC638, 0xCE59, 0xCE79, 0xCE59, 0xC638,   // 0x1BA0 (7072)
0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xCE79, 0xC638, 0xC618, 0xC618, 0xC638, 0xC618, 0xB5B6, 0xB596, 0xA514, 0x9492,   // 0x1BB0 (7088)
0x8410, 0x6B4D, 0x52AA, 0x4208, 0x31A6, 0x2965, 0x2124, 0x2124, 0x2124, 0x2104, 0x18C3, 0x18C3, 0x1082, 0x0861, 0x0861, 0x0841,   // 0x1BC0 (7104)
0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1BD0 (7120)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x4A49,   // 0x1BE0 (7136)
0x738E, 0x73AE, 0x7BCF, 0x8430, 0x9492, 0x9CD3, 0x9CF3, 0xAD55, 0xB596, 0xBDD7, 0xB5B6, 0xBDF7, 0xC618, 0xBDF7, 0xC638, 0xCE79,   // 0x1BF0 (7152)
0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xD69A, 0xCE79, 0xCE79, 0xCE59, 0xC618, 0xC618, 0xC618, 0xC618, 0xBDF7, 0xC618,   // 0x1C00 (7168)
0xCE59, 0xCE59, 0xCE79, 0xCE59, 0xC618, 0xBDF7, 0xBDD7, 0xBDD7, 0xBDD7, 0xBDD7, 0xB5B6, 0xAD75, 0x9CF3, 0x9492, 0x8430, 0x6B6D,   // 0x1C10 (7184)
0x5ACB, 0x528A, 0x39C7, 0x2965, 0x2104, 0x2124, 0x2945, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0841, 0x0841, 0x0020,   // 0x1C20 (7200)
0x0020, 0x0020, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1C30 (7216)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x10A2, 0x5ACB,   // 0x1C40 (7232)
0x738E, 0x73AE, 0x7BEF, 0x8C51, 0x9492, 0x94B2, 0xA514, 0xAD75, 0xB596, 0xB596, 0xB5B6, 0xBDD7, 0xC618, 0xC618, 0xC618, 0xC638,   // 0x1C50 (7248)
0xCE79, 0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xCE79, 0xC638, 0xC618, 0xC638, 0xC618, 0xBDF7, 0xBDF7, 0xBDF7, 0xBDF7, 0xBDF7,   // 0x1C60 (7264)
0xBDF7, 0xC618, 0xBDF7, 0xBDF7, 0xBDD7, 0xB5B6, 0xB5B6, 0xB596, 0xAD75, 0xAD55, 0xA534, 0x94B2, 0x8430, 0x7BCF, 0x6B4D, 0x5AEB,   // 0x1C70 (7280)
0x528A, 0x39E7, 0x2965, 0x2104, 0x2945, 0x2124, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x1C80 (7296)
0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1C90 (7312)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x2104, 0x5AEB,   // 0x1CA0 (7328)
0x6B6D, 0x73AE, 0x8410, 0x8C71, 0x94B2, 0x9CF3, 0xAD55, 0xAD55, 0xB596, 0xB596, 0xB5B6, 0xBDD7, 0xBDF7, 0xBDF7, 0xBDF7, 0xC618,   // 0x1CB0 (7344)
0xCE59, 0xCE59, 0xC638, 0xC638, 0xC638, 0xC618, 0xBDF7, 0xBDF7, 0xC618, 0xC638, 0xC618, 0xC618, 0xC638, 0xC618, 0xBDD7, 0xBDD7,   // 0x1CC0 (7360)
0xBDD7, 0xBDD7, 0xBDF7, 0xC618, 0xBDF7, 0xBDD7, 0xB596, 0xAD55, 0xA534, 0x9CF3, 0x94B2, 0x8C51, 0x7BCF, 0x632C, 0x5ACB, 0x528A,   // 0x1CD0 (7376)
0x4208, 0x3186, 0x2124, 0x2124, 0x18E3, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x1CE0 (7392)
0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1CF0 (7408)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x2945, 0x630C,   // 0x1D00 (7424)
0x73AE, 0x7BCF, 0x8410, 0x9492, 0x9CF3, 0xA514, 0xAD55, 0xAD75, 0xAD75, 0xB596, 0xB5B6, 0xB5B6, 0xB5B6, 0xBDF7, 0xC618, 0xC638,   // 0x1D10 (7440)
0xC638, 0xC618, 0xC618, 0xBDF7, 0xBDD7, 0xBDD7, 0xBDD7, 0xBDF7, 0xCE59, 0xCE59, 0xBDF7, 0xC618, 0xC618, 0xBDD7, 0xB5B6, 0xBDD7,   // 0x1D20 (7456)
0xBDD7, 0xB5B6, 0xBDD7, 0xB5B6, 0xB596, 0xAD55, 0xA534, 0xA514, 0x9CD3, 0x8C51, 0x7BEF, 0x738E, 0x5AEB, 0x528A, 0x4228, 0x31A6,   // 0x1D30 (7472)
0x2945, 0x2124, 0x2104, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841,   // 0x1D40 (7488)
0x0841, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1D50 (7504)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x3186, 0x632C,   // 0x1D60 (7520)
0x6B6D, 0x738E, 0x8410, 0x9492, 0x9CD3, 0xA514, 0xA534, 0xA534, 0xA534, 0xAD55, 0xB596, 0xB596, 0xB5B6, 0xBDD7, 0xBDF7, 0xBDF7,   // 0x1D70 (7536)
0xBDD7, 0xBDF7, 0xBDF7, 0xBDD7, 0xB596, 0xB596, 0xBDD7, 0xC618, 0xC618, 0xBDD7, 0xBDF7, 0xBDF7, 0xBDF7, 0xB5B6, 0xB5B6, 0xB596,   // 0x1D80 (7552)
0xB596, 0xB596, 0xAD75, 0xA534, 0x9CF3, 0x9CD3, 0x94B2, 0x8C51, 0x7BEF, 0x738E, 0x632C, 0x52AA, 0x4228, 0x39C7, 0x3186, 0x2124,   // 0x1D90 (7568)
0x2124, 0x18E3, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020,   // 0x1DA0 (7584)
0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1DB0 (7600)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x3186, 0x630C,   // 0x1DC0 (7616)
0x6B6D, 0x7BCF, 0x8430, 0x9492, 0x94B2, 0x9CD3, 0x9CD3, 0x9CD3, 0x9CF3, 0xA534, 0xAD75, 0xAD75, 0xAD75, 0xB596, 0xB5B6, 0xB5B6,   // 0x1DD0 (7632)
0xBDD7, 0xBDF7, 0xBDD7, 0xB596, 0xB596, 0xB596, 0xB596, 0xB596, 0xBDD7, 0xBDF7, 0xBDF7, 0xBDF7, 0xBDD7, 0xB596, 0xAD75, 0xAD75,   // 0x1DE0 (7648)
0xAD55, 0xA534, 0xA514, 0x9CD3, 0x9492, 0x8C51, 0x7BEF, 0x73AE, 0x632C, 0x5ACB, 0x4A49, 0x4208, 0x39C7, 0x3186, 0x2124, 0x2104,   // 0x1DF0 (7664)
0x18C3, 0x10A2, 0x1082, 0x0861, 0x0841, 0x0861, 0x0841, 0x0841, 0x0020, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020,   // 0x1E00 (7680)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1E10 (7696)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x3186, 0x630C,   // 0x1E20 (7712)
0x73AE, 0x7BCF, 0x8410, 0x8C51, 0x8C71, 0x9492, 0x9CD3, 0x9CD3, 0x9CF3, 0xA514, 0xA534, 0xAD75, 0xAD55, 0xAD75, 0xAD75, 0xAD75,   // 0x1E30 (7728)
0xB596, 0xB5B6, 0xB5B6, 0xB596, 0xB596, 0xB596, 0xB596, 0xB5B6, 0xBDD7, 0xBDD7, 0xB596, 0xBDD7, 0xBDD7, 0xB596, 0xAD55, 0xA514,   // 0x1E40 (7744)
0x9CF3, 0x9CD3, 0x9492, 0x8C51, 0x8410, 0x7BCF, 0x738E, 0x630C, 0x528A, 0x4228, 0x39C7, 0x3186, 0x2945, 0x2104, 0x18E3, 0x18C3,   // 0x1E50 (7760)
0x10A2, 0x1082, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000,   // 0x1E60 (7776)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1E70 (7792)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x3186, 0x630C,   // 0x1E80 (7808)
0x73AE, 0x7BCF, 0x7BEF, 0x8410, 0x8C51, 0x9492, 0x94B2, 0x9CD3, 0x9CD3, 0x9CF3, 0xAD55, 0xA534, 0xA514, 0xA534, 0xAD55, 0xAD55,   // 0x1E90 (7824)
0xAD75, 0xB596, 0xB596, 0xAD55, 0xAD55, 0xAD75, 0xB596, 0xB596, 0xAD75, 0xAD55, 0xAD75, 0xAD75, 0xAD75, 0xAD55, 0xA534, 0x9CF3,   // 0x1EA0 (7840)
0x9492, 0x8C51, 0x8410, 0x7BCF, 0x738E, 0x632C, 0x52AA, 0x4A49, 0x39E7, 0x31A6, 0x2965, 0x2124, 0x2104, 0x18E3, 0x10A2, 0x1082,   // 0x1EB0 (7856)
0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1EC0 (7872)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1ED0 (7888)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x2945, 0x5ACB,   // 0x1EE0 (7904)
0x6B6D, 0x73AE, 0x7BCF, 0x7BEF, 0x8430, 0x8C51, 0x8C71, 0x94B2, 0x9CD3, 0xA514, 0xA514, 0xA514, 0xA514, 0xA534, 0xAD55, 0xAD55,   // 0x1EF0 (7920)
0xAD55, 0xAD55, 0xAD75, 0xAD55, 0xA534, 0xAD55, 0xAD75, 0xAD55, 0xA534, 0xA534, 0xA514, 0xA514, 0xA514, 0x9CF3, 0x94B2, 0x8C71,   // 0x1F00 (7936)
0x8410, 0x7BCF, 0x738E, 0x632C, 0x52AA, 0x4A49, 0x4208, 0x31A6, 0x2965, 0x2945, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x0861,   // 0x1F10 (7952)
0x0861, 0x0861, 0x0861, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1F20 (7968)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1F30 (7984)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x18E3, 0x4A69,   // 0x1F40 (8000)
0x6B6D, 0x73AE, 0x7BCF, 0x7BCF, 0x8410, 0x8430, 0x8C71, 0x9492, 0x9492, 0x9CD3, 0x9CF3, 0x9CF3, 0x9CF3, 0xA534, 0xA534, 0xA534,   // 0x1F50 (8016)
0xA534, 0xA534, 0xA514, 0xA514, 0xA534, 0xAD55, 0xAD75, 0xA534, 0x9CF3, 0x9CF3, 0x9CF3, 0x9CD3, 0x94B2, 0x8C71, 0x8410, 0x7BEF,   // 0x1F60 (8032)
0x738E, 0x632C, 0x5ACB, 0x4A69, 0x39E7, 0x31A6, 0x2965, 0x2945, 0x2124, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861,   // 0x1F70 (8048)
0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1F80 (8064)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1F90 (8080)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1082, 0x39E7,   // 0x1FA0 (8096)
0x6B4D, 0x73AE, 0x73AE, 0x7BCF, 0x8410, 0x8430, 0x8C51, 0x8C51, 0x8C71, 0x9492, 0x9492, 0x94B2, 0x94B2, 0x9CD3, 0x9CF3, 0x9CF3,   // 0x1FB0 (8112)
0x9CF3, 0x9CF3, 0x9CF3, 0x9CF3, 0xA514, 0xA534, 0xA534, 0x9CF3, 0x9CD3, 0x94B2, 0x94B2, 0x8C71, 0x8410, 0x73AE, 0x6B6D, 0x630C,   // 0x1FC0 (8128)
0x52AA, 0x4A69, 0x4208, 0x39C7, 0x2965, 0x2945, 0x2124, 0x2104, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841,   // 0x1FD0 (8144)
0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1FE0 (8160)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1FF0 (8176)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x2945,   // 0x2000 (8192)
0x52AA, 0x738E, 0x73AE, 0x73AE, 0x7BCF, 0x7BEF, 0x7BEF, 0x8410, 0x8430, 0x8C51, 0x8C71, 0x8C71, 0x9492, 0x9492, 0x9492, 0x94B2,   // 0x2010 (8208)
0x9CD3, 0x9CD3, 0x94B2, 0x94B2, 0x9CD3, 0x9CF3, 0x9CD3, 0x8C71, 0x8C51, 0x8C51, 0x8410, 0x7BCF, 0x6B6D, 0x630C, 0x52AA, 0x4A49,   // 0x2020 (8224)
0x39E7, 0x31A6, 0x3186, 0x2945, 0x2124, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0020,   // 0x2030 (8240)
0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2040 (8256)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2050 (8272)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1082,   // 0x2060 (8288)
0x39E7, 0x630C, 0x6B6D, 0x73AE, 0x73AE, 0x7BCF, 0x7BCF, 0x7BEF, 0x8410, 0x8410, 0x8410, 0x8430, 0x8C51, 0x8C51, 0x8C51, 0x8C71,   // 0x2070 (8304)
0x9492, 0x9492, 0x8C71, 0x8C71, 0x9492, 0x9492, 0x8C71, 0x8430, 0x7BEF, 0x73AE, 0x6B6D, 0x630C, 0x5ACB, 0x4A69, 0x4208, 0x39C7,   // 0x2080 (8320)
0x3186, 0x2945, 0x2124, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020,   // 0x2090 (8336)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x20A0 (8352)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x20B0 (8368)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x20C0 (8384)
0x2104, 0x4A49, 0x632C, 0x6B6D, 0x738E, 0x738E, 0x73AE, 0x73AE, 0x7BCF, 0x73AE, 0x7BCF, 0x8410, 0x8410, 0x8430, 0x8C51, 0x8C51,   // 0x20D0 (8400)
0x8C51, 0x8430, 0x8430, 0x8410, 0x8410, 0x8410, 0x7BEF, 0x73AE, 0x6B4D, 0x630C, 0x52AA, 0x4A49, 0x4208, 0x39C7, 0x3186, 0x2945,   // 0x20E0 (8416)
0x2104, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000,   // 0x20F0 (8432)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2100 (8448)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2110 (8464)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2120 (8480)
0x0841, 0x2945, 0x4A49, 0x630C, 0x6B4D, 0x6B6D, 0x6B6D, 0x6B6D, 0x738E, 0x738E, 0x73AE, 0x73AE, 0x73AE, 0x73AE, 0x73AE, 0x73AE,   // 0x2130 (8496)
0x7BCF, 0x7BCF, 0x73AE, 0x6B6D, 0x6B4D, 0x632C, 0x630C, 0x5ACB, 0x528A, 0x4228, 0x39E7, 0x3186, 0x2945, 0x2104, 0x18E3, 0x18E3,   // 0x2140 (8512)
0x18C3, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2150 (8528)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2160 (8544)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2170 (8560)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2180 (8576)
0x0000, 0x0861, 0x2124, 0x4208, 0x52AA, 0x630C, 0x6B4D, 0x6B4D, 0x6B6D, 0x6B6D, 0x6B6D, 0x6B6D, 0x6B6D, 0x6B6D, 0x6B4D, 0x6B4D,   // 0x2190 (8592)
0x6B4D, 0x630C, 0x5AEB, 0x5ACB, 0x528A, 0x4A69, 0x4228, 0x39E7, 0x31A6, 0x2965, 0x2124, 0x2104, 0x18C3, 0x10A2, 0x1082, 0x1082,   // 0x21A0 (8608)
0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x21B0 (8624)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x21C0 (8640)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x21D0 (8656)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x21E0 (8672)
0x0000, 0x0000, 0x0020, 0x10A2, 0x3186, 0x4228, 0x5ACB, 0x630C, 0x632C, 0x632C, 0x632C, 0x632C, 0x630C, 0x630C, 0x5AEB, 0x5ACB,   // 0x21F0 (8688)
0x528A, 0x4A69, 0x4A69, 0x4A49, 0x4208, 0x39C7, 0x3186, 0x2945, 0x2124, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861,   // 0x2200 (8704)
0x0841, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2210 (8720)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2220 (8736)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2230 (8752)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2240 (8768)
0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x18C3, 0x2965, 0x39E7, 0x4A49, 0x52AA, 0x52AA, 0x52AA, 0x52AA, 0x528A, 0x4A69, 0x4A49,   // 0x2250 (8784)
0x4228, 0x4208, 0x39C7, 0x31A6, 0x3186, 0x2945, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x0861, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020,   // 0x2260 (8800)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2270 (8816)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2280 (8832)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2290 (8848)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22A0 (8864)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0861, 0x18C3, 0x2104, 0x2965, 0x31A6, 0x31A6, 0x39C7, 0x31A6, 0x31A6,   // 0x22B0 (8880)
0x2965, 0x2124, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22C0 (8896)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22D0 (8912)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22E0 (8928)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22F0 (8944)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2300 (8960)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x2310 (8976)
0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2320 (8992)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2330 (9008)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2340 (9024)
0x0000, };
Large.c
// Generated by  : ImageConverter 565 v2.3
// Generated from: WaxingGibbous.jpg
// Time generated: 17/06/2022 8:18:59 AM
// Dimensions    : 95x95 pixels
// Size          : 18,050 Bytes
#include <avr/pgmspace.h>
const unsigned int Large[0x2341] PROGMEM ={
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0010 (16)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0020 (32)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0030 (48)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0040 (64)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0050 (80)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0060 (96)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0070 (112)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0080 (128)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0841, 0x0861, 0x1082, 0x10A2,   // 0x0090 (144)
0x10A2, 0x18E3, 0x2104, 0x2104, 0x18E3, 0x18C3, 0x1082, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00A0 (160)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00B0 (176)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00C0 (192)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00D0 (208)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00E0 (224)
0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0841, 0x0841, 0x0861, 0x1082, 0x18C3, 0x18E3, 0x2124, 0x2965, 0x31A6,   // 0x00F0 (240)
0x39E7, 0x4A49, 0x52AA, 0x5ACB, 0x5AEB, 0x5AEB, 0x5ACB, 0x528A, 0x39E7, 0x2945, 0x10A2, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0100 (256)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0110 (272)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0120 (288)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0130 (304)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0140 (320)
0x0000, 0x0020, 0x0020, 0x0020, 0x0841, 0x0841, 0x0861, 0x1082, 0x10A2, 0x18C3, 0x2104, 0x2945, 0x3186, 0x39C7, 0x39E7, 0x4208,   // 0x0150 (336)
0x4228, 0x528A, 0x5AEB, 0x632C, 0x6B6D, 0x73AE, 0x73AE, 0x7BCF, 0x73AE, 0x6B4D, 0x5ACB, 0x39E7, 0x18E3, 0x0020, 0x0000, 0x0000,   // 0x0160 (352)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0170 (368)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0180 (384)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0190 (400)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0020,   // 0x01A0 (416)
0x0841, 0x0841, 0x0841, 0x0861, 0x1082, 0x10A2, 0x18C3, 0x18E3, 0x2104, 0x2945, 0x3186, 0x39C7, 0x4A49, 0x4A69, 0x4A69, 0x4A69,   // 0x01B0 (432)
0x528A, 0x5AEB, 0x632C, 0x6B6D, 0x73AE, 0x73AE, 0x7BCF, 0x8410, 0x8410, 0x7BEF, 0x7BEF, 0x738E, 0x5ACB, 0x3186, 0x0861, 0x0000,   // 0x01C0 (448)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x01D0 (464)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x01E0 (480)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x01F0 (496)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841,   // 0x0200 (512)
0x0841, 0x0861, 0x1082, 0x10A2, 0x18C3, 0x18E3, 0x2104, 0x2945, 0x31A6, 0x39C7, 0x39E7, 0x4A49, 0x5AEB, 0x738E, 0x6B6D, 0x6B4D,   // 0x0210 (528)
0x6B6D, 0x73AE, 0x8410, 0x8410, 0x73AE, 0x73AE, 0x7BEF, 0x8430, 0x8410, 0x8410, 0x7BEF, 0x7BEF, 0x7BCF, 0x632C, 0x39C7, 0x10A2,   // 0x0220 (544)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0230 (560)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0240 (576)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0250 (592)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0861,   // 0x0260 (608)
0x1082, 0x1082, 0x10A2, 0x18E3, 0x2124, 0x2965, 0x3186, 0x39C7, 0x4208, 0x528A, 0x5AEB, 0x6B6D, 0x7BEF, 0x8C51, 0x8C71, 0x8C71,   // 0x0270 (624)
0x9492, 0x94B2, 0x9492, 0x8C51, 0x8430, 0x7BEF, 0x7BEF, 0x8410, 0x8410, 0x8410, 0x8410, 0x8410, 0x8410, 0x7BEF, 0x6B4D, 0x4208,   // 0x0280 (640)
0x10A2, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0290 (656)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x02A0 (672)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x02B0 (688)
0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x10A2, 0x10A2,   // 0x02C0 (704)
0x10A2, 0x18E3, 0x2124, 0x2965, 0x39C7, 0x39E7, 0x4228, 0x5ACB, 0x6B6D, 0x7BCF, 0x7BEF, 0x8430, 0x9492, 0x9492, 0x9CF3, 0xA534,   // 0x02D0 (720)
0xA534, 0xA514, 0xA534, 0xA514, 0x94B2, 0x8C51, 0x8C71, 0x8C51, 0x8430, 0x7BEF, 0x8410, 0x8410, 0x8C51, 0x8410, 0x8410, 0x6B4D,   // 0x02E0 (736)
0x31A6, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x02F0 (752)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0300 (768)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0310 (784)
0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x10A2, 0x18C3, 0x18E3, 0x2104,   // 0x0320 (800)
0x2124, 0x2965, 0x31A6, 0x39E7, 0x4A49, 0x5AEB, 0x6B4D, 0x73AE, 0x8410, 0x8430, 0x8C71, 0x9492, 0x9CF3, 0xA534, 0x9CF3, 0x9CD3,   // 0x0330 (816)
0xA534, 0xAD55, 0xA514, 0x9CF3, 0xA514, 0x9CF3, 0x94B2, 0x8C51, 0x8430, 0x7BEF, 0x7BEF, 0x8430, 0x8430, 0x8430, 0x8430, 0x7BEF,   // 0x0340 (832)
0x5AEB, 0x2104, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0350 (848)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0360 (864)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020,   // 0x0370 (880)
0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x10A2, 0x10A2, 0x18C3, 0x2104, 0x2945, 0x2965,   // 0x0380 (896)
0x31A6, 0x39E7, 0x4228, 0x52AA, 0x630C, 0x738E, 0x7BCF, 0x8C51, 0x9492, 0x94B2, 0xA514, 0xA534, 0x9492, 0x8410, 0x8410, 0x8C71,   // 0x0390 (912)
0x94B2, 0x9CF3, 0xA514, 0xA514, 0xA514, 0x9CF3, 0x94B2, 0x8C71, 0x8410, 0x7BEF, 0x7BEF, 0x8410, 0x8430, 0x8430, 0x8430, 0x8410,   // 0x03A0 (928)
0x738E, 0x4208, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x03B0 (944)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x03C0 (960)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020,   // 0x03D0 (976)
0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x18C3, 0x2104, 0x2945, 0x3186, 0x39C7, 0x39E7,   // 0x03E0 (992)
0x4228, 0x528A, 0x52AA, 0x632C, 0x7BCF, 0x7BEF, 0x8C51, 0x8C71, 0x8430, 0x8C51, 0x9492, 0x8430, 0x8410, 0x8430, 0x8C51, 0x8430,   // 0x03F0 (1008)
0x9CD3, 0xAD55, 0xAD55, 0xAD55, 0xA514, 0x9CF3, 0x94B2, 0x9492, 0x8430, 0x8410, 0x8410, 0x7BEF, 0x8410, 0x8430, 0x8430, 0x8430,   // 0x0400 (1024)
0x8410, 0x5ACB, 0x18C3, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0410 (1040)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0420 (1056)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020,   // 0x0430 (1072)
0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x1082, 0x1082, 0x18C3, 0x18C3, 0x2124, 0x2965, 0x3186, 0x39C7, 0x4208, 0x4228, 0x4A69,   // 0x0440 (1088)
0x5ACB, 0x630C, 0x6B6D, 0x73AE, 0x7BCF, 0x7BCF, 0x7BEF, 0x7BEF, 0x8410, 0x8410, 0x7BEF, 0x7BEF, 0x8430, 0x8C71, 0x8C51, 0x8C51,   // 0x0450 (1104)
0x9CD3, 0x9CD3, 0x94B2, 0x9CF3, 0x9CF3, 0xA514, 0xA534, 0x9492, 0x8430, 0x8C51, 0x8410, 0x7BEF, 0x8C51, 0x8C51, 0x8430, 0x8430,   // 0x0460 (1120)
0x8430, 0x6B4D, 0x2124, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0470 (1136)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0480 (1152)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0841, 0x0841,   // 0x0490 (1168)
0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x18C3, 0x2104, 0x2965, 0x2965, 0x3186, 0x31A6, 0x39E7, 0x4228, 0x4A69, 0x52AA, 0x630C,   // 0x04A0 (1184)
0x738E, 0x738E, 0x738E, 0x73AE, 0x7BCF, 0x8410, 0x8430, 0x8430, 0x8430, 0x8410, 0x7BEF, 0x7BEF, 0x8430, 0x8410, 0x7BCF, 0x7BCF,   // 0x04B0 (1200)
0x8410, 0x8C51, 0x94B2, 0x9492, 0x8C51, 0xA514, 0xB596, 0xA514, 0x94B2, 0x8C51, 0x8410, 0x8430, 0x8C51, 0x8430, 0x8C71, 0x8C51,   // 0x04C0 (1216)
0x8410, 0x738E, 0x31A6, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x04D0 (1232)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x04E0 (1248)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861,   // 0x04F0 (1264)
0x0861, 0x0861, 0x1082, 0x10A2, 0x18C3, 0x2104, 0x3186, 0x2965, 0x3186, 0x39E7, 0x4228, 0x528A, 0x52AA, 0x5ACB, 0x632C, 0x738E,   // 0x0500 (1280)
0x7BCF, 0x7BCF, 0x8410, 0x8C51, 0x8C51, 0x8C71, 0x8C51, 0x8430, 0x8410, 0x8410, 0x8410, 0x8430, 0x8430, 0x7BEF, 0x7BEF, 0x8410,   // 0x0510 (1296)
0x8C51, 0x8C71, 0x8C51, 0x8C51, 0x94B2, 0xAD55, 0xAD55, 0xAD55, 0xA514, 0x9492, 0x7BEF, 0x7BCF, 0x8410, 0x8C51, 0x8C51, 0x8410,   // 0x0520 (1312)
0x7BEF, 0x6B6D, 0x31A6, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0530 (1328)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0540 (1344)
0x0000, 0x0000, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861,   // 0x0550 (1360)
0x0861, 0x1082, 0x10A2, 0x18C3, 0x18E3, 0x2945, 0x3186, 0x39C7, 0x4208, 0x4A69, 0x52AA, 0x5ACB, 0x630C, 0x6B6D, 0x7BCF, 0x8410,   // 0x0560 (1376)
0x8410, 0x8430, 0x8C71, 0x8C71, 0x8C51, 0x8C51, 0x8430, 0x8430, 0x8410, 0x7BEF, 0x8430, 0x8410, 0x8410, 0x8410, 0x8430, 0x8C71,   // 0x0570 (1392)
0x8C71, 0x8C51, 0x94B2, 0xA514, 0x9CF3, 0x9CD3, 0x8C51, 0x9CF3, 0xA534, 0x9492, 0x7BEF, 0x7BEF, 0x8410, 0x8430, 0x8430, 0x8410,   // 0x0580 (1408)
0x7BCF, 0x6B6D, 0x39C7, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0590 (1424)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x05A0 (1440)
0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x05B0 (1456)
0x1082, 0x10A2, 0x18E3, 0x2104, 0x2945, 0x31A6, 0x39C7, 0x4228, 0x528A, 0x528A, 0x630C, 0x6B6D, 0x73AE, 0x8C51, 0x8C51, 0x8C51,   // 0x05C0 (1472)
0x8C51, 0x8430, 0x8430, 0x8430, 0x8430, 0x8C71, 0x8C51, 0x8430, 0x8410, 0x8410, 0x8410, 0x8C51, 0x8430, 0x8C51, 0x8C71, 0x8C71,   // 0x05D0 (1488)
0x8C71, 0x94B2, 0xA514, 0x9CD3, 0x9CD3, 0x9492, 0x9CF3, 0xA514, 0xA514, 0x94B2, 0x8C51, 0x8430, 0x8C51, 0x8C51, 0x8430, 0x7BEF,   // 0x05E0 (1504)
0x73AE, 0x6B6D, 0x39C7, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x05F0 (1520)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x0861,   // 0x0600 (1536)
0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2,   // 0x0610 (1552)
0x18C3, 0x18E3, 0x2124, 0x2965, 0x39C7, 0x39E7, 0x4228, 0x4A69, 0x52AA, 0x632C, 0x6B6D, 0x738E, 0x7BEF, 0x8C51, 0x8C71, 0x8C51,   // 0x0620 (1568)
0x8C51, 0x8C51, 0x8430, 0x8430, 0x8C51, 0x8C51, 0x8430, 0x8430, 0x8430, 0x8430, 0x8430, 0x8C51, 0x8C71, 0x8C71, 0x9492, 0x8C71,   // 0x0630 (1584)
0x9492, 0x9492, 0x9CD3, 0x9492, 0xA514, 0xAD55, 0xAD55, 0xAD55, 0xAD55, 0x94B2, 0x8430, 0x8C51, 0x8C51, 0x8430, 0x8410, 0x7BEF,   // 0x0640 (1600)
0x7BCF, 0x632C, 0x31A6, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0650 (1616)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0841, 0x0861,   // 0x0660 (1632)
0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x18C3,   // 0x0670 (1648)
0x2104, 0x2124, 0x31A6, 0x39E7, 0x4208, 0x4A69, 0x5ACB, 0x5AEB, 0x632C, 0x6B6D, 0x73AE, 0x7BCF, 0x8C51, 0x8430, 0x8C51, 0x9492,   // 0x0680 (1664)
0x8C71, 0x8C51, 0x8430, 0x8430, 0x8430, 0x8430, 0x8430, 0x8C51, 0x9492, 0x8C71, 0x8C51, 0x8C71, 0x9492, 0x94B2, 0x9492, 0x94B2,   // 0x0690 (1680)
0x9492, 0x9CD3, 0x9492, 0x94B2, 0xAD55, 0xB596, 0xB5B6, 0xB5B6, 0x9CD3, 0x8C51, 0x8C51, 0x8C51, 0x8430, 0x8410, 0x8430, 0x7BCF,   // 0x06A0 (1696)
0x73AE, 0x630C, 0x2945, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x06B0 (1712)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x0841, 0x1082, 0x0861, 0x0861,   // 0x06C0 (1728)
0x0841, 0x0841, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18E3, 0x2124,   // 0x06D0 (1744)
0x2965, 0x39C7, 0x4208, 0x4A49, 0x52AA, 0x630C, 0x6B4D, 0x738E, 0x7BCF, 0x7BEF, 0x8410, 0x8430, 0x8430, 0x8C51, 0x9492, 0x9492,   // 0x06E0 (1760)
0x8C71, 0x8C71, 0x8C71, 0x8C51, 0x8C51, 0x8430, 0x8C51, 0x8C71, 0x8C71, 0x8C71, 0x9492, 0x94B2, 0x94B2, 0x9492, 0x9492, 0x9492,   // 0x06F0 (1776)
0x9492, 0x9492, 0x94B2, 0xA514, 0xBDD7, 0xB5B6, 0xBDD7, 0xA534, 0x9CD3, 0x9492, 0x8C71, 0x8C51, 0x8410, 0x8430, 0x7BCF, 0x73AE,   // 0x0700 (1792)
0x738E, 0x5AEB, 0x18C3, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0710 (1808)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x1082, 0x1082, 0x0861, 0x0841,   // 0x0720 (1824)
0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x2104, 0x2945, 0x31A6,   // 0x0730 (1840)
0x4208, 0x4A49, 0x528A, 0x5ACB, 0x5AEB, 0x738E, 0x7BCF, 0x8430, 0x8430, 0x94B2, 0x9492, 0x8430, 0x8C51, 0x94B2, 0x94B2, 0x9492,   // 0x0740 (1856)
0x8C71, 0x9492, 0x9492, 0x8C51, 0x8C51, 0x9492, 0x9492, 0x8C71, 0x9492, 0x94B2, 0x9CD3, 0x94B2, 0x9492, 0x9492, 0x9492, 0x9492,   // 0x0750 (1872)
0x94B2, 0x9CD3, 0x9CD3, 0xAD75, 0xBDD7, 0xB5B6, 0xB596, 0xAD55, 0x94B2, 0x8C71, 0x8C71, 0x8410, 0x8410, 0x8410, 0x7BCF, 0x73AE,   // 0x0760 (1888)
0x6B6D, 0x528A, 0x1082, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0770 (1904)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841,   // 0x0780 (1920)
0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x18C3, 0x18E3, 0x2124, 0x2965, 0x39C7, 0x4A49,   // 0x0790 (1936)
0x4A69, 0x528A, 0x5AEB, 0x632C, 0x738E, 0x7BEF, 0x8C71, 0x9CD3, 0xA514, 0x9492, 0x8430, 0x8C71, 0x9492, 0x8C71, 0x9492, 0x9492,   // 0x07A0 (1952)
0x8C71, 0x8C51, 0x8C71, 0x9492, 0x9492, 0x9492, 0x8C71, 0x9492, 0x94B2, 0x94B2, 0x94B2, 0x9492, 0x94B2, 0x94B2, 0x9CD3, 0x9CD3,   // 0x07B0 (1968)
0x9CD3, 0x9CF3, 0xB596, 0xB596, 0xB5B6, 0xB5B6, 0xAD55, 0x9CF3, 0x9CF3, 0x9492, 0x8430, 0x8410, 0x7BEF, 0x7BEF, 0x7BCF, 0x73AE,   // 0x07C0 (1984)
0x6B6D, 0x4228, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x07D0 (2000)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x0861, 0x1082, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x07E0 (2016)
0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x18C3, 0x2104, 0x2945, 0x3186, 0x39E7, 0x4A69, 0x528A,   // 0x07F0 (2032)
0x528A, 0x5AEB, 0x738E, 0x7BEF, 0x8430, 0x8C71, 0x9CD3, 0x9CF3, 0x9492, 0x8C71, 0x94B2, 0x94B2, 0x9492, 0x94B2, 0x9492, 0x8C51,   // 0x0800 (2048)
0x8C51, 0x9CD3, 0x94B2, 0x8C51, 0x8C71, 0x9492, 0x9492, 0x94B2, 0x94B2, 0x9492, 0x9492, 0x9CD3, 0x9CF3, 0x9CF3, 0x9CF3, 0xA514,   // 0x0810 (2064)
0x9CF3, 0xB596, 0xB5B6, 0xBDF7, 0xBDD7, 0xAD55, 0x9CF3, 0x9CF3, 0x9492, 0x8C51, 0x8410, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x73AE,   // 0x0820 (2080)
0x632C, 0x2965, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0830 (2096)
0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0841, 0x1082, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x0840 (2112)
0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x18C3, 0x18E3, 0x2124, 0x3186, 0x39C7, 0x4228, 0x4A69, 0x528A, 0x630C,   // 0x0850 (2128)
0x6B6D, 0x73AE, 0x8430, 0x8C51, 0x8C51, 0x9492, 0x9492, 0x94B2, 0x94B2, 0x9CD3, 0x9CD3, 0x94B2, 0x9CD3, 0x9492, 0x8C51, 0x9492,   // 0x0860 (2144)
0x9CD3, 0x9492, 0x8C71, 0x94B2, 0x94B2, 0x94B2, 0x94B2, 0x9492, 0x8C71, 0x94B2, 0xA514, 0xA534, 0xAD55, 0xAD55, 0xAD75, 0xA534,   // 0x0870 (2160)
0xB5B6, 0xBDD7, 0xBDF7, 0xBDD7, 0xAD75, 0xA514, 0x9CF3, 0x9CD3, 0x9CD3, 0x8C71, 0x8410, 0x7BCF, 0x738E, 0x73AE, 0x73AE, 0x738E,   // 0x0880 (2176)
0x5AEB, 0x18C3, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0890 (2192)
0x0000, 0x0000, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861,   // 0x08A0 (2208)
0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x18E3, 0x2124, 0x3186, 0x39C7, 0x4228, 0x4A69, 0x52AA, 0x5ACB, 0x6B4D, 0x7BCF,   // 0x08B0 (2224)
0x8410, 0x9CD3, 0x9CF3, 0x94B2, 0x9CF3, 0x9CD3, 0x9CF3, 0x9CD3, 0x9492, 0x94B2, 0x9492, 0x9CD3, 0x8C71, 0x9492, 0x94B2, 0x9492,   // 0x08C0 (2240)
0x9CD3, 0x9CD3, 0x94B2, 0x9492, 0x9492, 0x9492, 0x8C71, 0x8C71, 0x9CF3, 0xA514, 0xA514, 0xAD55, 0xB596, 0xAD75, 0xAD55, 0xB596,   // 0x08D0 (2256)
0xB5B6, 0xBDF7, 0xBDF7, 0xB5B6, 0xAD75, 0xAD55, 0xA514, 0xAD55, 0x9CF3, 0x8C51, 0x7BEF, 0x6B6D, 0x6B6D, 0x6B6D, 0x738E, 0x738E,   // 0x08E0 (2272)
0x4A49, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x08F0 (2288)
0x0020, 0x0841, 0x0861, 0x0841, 0x0861, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861,   // 0x0900 (2304)
0x0861, 0x0861, 0x1082, 0x1082, 0x18C3, 0x2104, 0x2965, 0x39C7, 0x4208, 0x4A49, 0x52AA, 0x52AA, 0x5ACB, 0x6B4D, 0x7BCF, 0x8C71,   // 0x0910 (2320)
0xAD55, 0xB596, 0xAD55, 0xAD55, 0xA534, 0xA514, 0x9CD3, 0x9CD3, 0xA514, 0x9CF3, 0x9CF3, 0x94B2, 0x9CD3, 0x9492, 0x8C71, 0xAD55,   // 0x0920 (2336)
0xB596, 0xA514, 0x9492, 0x8C71, 0x9492, 0x9492, 0x9492, 0x94B2, 0x9CF3, 0xA534, 0xA534, 0xA534, 0xAD55, 0xAD75, 0xB596, 0xBDF7,   // 0x0930 (2352)
0xBDF7, 0xBDF7, 0xB5B6, 0xB596, 0xB596, 0xA534, 0xA514, 0xA514, 0x94B2, 0x8430, 0x73AE, 0x6B4D, 0x632C, 0x6B6D, 0x738E, 0x6B4D,   // 0x0940 (2368)
0x2124, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841,   // 0x0950 (2384)
0x0861, 0x0020, 0x0020, 0x0861, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861,   // 0x0960 (2400)
0x0861, 0x1082, 0x10A2, 0x18E3, 0x2124, 0x3186, 0x39C7, 0x4228, 0x4A69, 0x52AA, 0x52AA, 0x5AEB, 0x6B6D, 0x8C71, 0x9CF3, 0xA534,   // 0x0970 (2416)
0xAD55, 0xAD75, 0xAD75, 0xAD75, 0x9CF3, 0x94B2, 0x94B2, 0x9CD3, 0x9CD3, 0x94B2, 0x9CF3, 0x9CD3, 0x9492, 0x9492, 0x9CF3, 0xAD55,   // 0x0980 (2432)
0xA514, 0x9CF3, 0x9CD3, 0x9CD3, 0xA514, 0xA514, 0xA514, 0xA514, 0xAD55, 0xAD75, 0xB596, 0xA534, 0xA534, 0xAD75, 0xB596, 0xB5B6,   // 0x0990 (2448)
0xBDD7, 0xBDD7, 0xBDD7, 0xBDD7, 0xB5B6, 0xA534, 0x9CF3, 0x94B2, 0x8C51, 0x7BEF, 0x738E, 0x632C, 0x6B4D, 0x73AE, 0x738E, 0x4A69,   // 0x09A0 (2464)
0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861,   // 0x09B0 (2480)
0x0841, 0x0861, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x09C0 (2496)
0x1082, 0x18C3, 0x18E3, 0x2124, 0x3186, 0x39E7, 0x4A69, 0x528A, 0x52AA, 0x630C, 0x738E, 0x7BEF, 0x94B2, 0xA514, 0xAD75, 0xAD75,   // 0x09D0 (2512)
0xA534, 0xB5B6, 0xB5B6, 0xA534, 0x9CD3, 0x9CF3, 0xA514, 0x9CD3, 0x9CD3, 0x9CD3, 0x94B2, 0x9492, 0x9CD3, 0x94B2, 0x9CD3, 0x9CD3,   // 0x09E0 (2528)
0xAD55, 0xB596, 0xAD75, 0xAD75, 0xAD55, 0xAD75, 0xAD55, 0xA534, 0xB596, 0xBDF7, 0xAD55, 0xA534, 0xB5B6, 0xBDD7, 0xBDD7, 0xC638,   // 0x09F0 (2544)
0xC618, 0xBDF7, 0xBDD7, 0xBDF7, 0xB5B6, 0xAD55, 0xA514, 0x94B2, 0x8C51, 0x7BCF, 0x6B6D, 0x632C, 0x738E, 0x73AE, 0x6B4D, 0x2124,   // 0x0A00 (2560)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x0861, 0x0861, 0x1082,   // 0x0A10 (2576)
0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x10A2,   // 0x0A20 (2592)
0x18C3, 0x18C3, 0x2124, 0x31A6, 0x39E7, 0x4208, 0x528A, 0x5ACB, 0x632C, 0x7BCF, 0x8C51, 0x9CD3, 0xAD55, 0xB5B6, 0xB5B6, 0xAD75,   // 0x0A30 (2608)
0xBDD7, 0xBDD7, 0xAD75, 0xAD75, 0xA534, 0x9CF3, 0xA514, 0xA514, 0x9CD3, 0x94B2, 0x94B2, 0x9CD3, 0x9CD3, 0x9492, 0x9CD3, 0xAD75,   // 0x0A40 (2624)
0xB5B6, 0xB5B6, 0xAD75, 0xAD75, 0xB596, 0xB5B6, 0xB596, 0xB5B6, 0xB596, 0xA534, 0xA514, 0xAD75, 0xBDD7, 0xC618, 0xC638, 0xC638,   // 0x0A50 (2640)
0xBDD7, 0xB5B6, 0xB5B6, 0xB596, 0xAD75, 0xA534, 0x9CF3, 0x94B2, 0x8C51, 0x7BEF, 0x6B6D, 0x6B6D, 0x73AE, 0x73AE, 0x4A49, 0x0841,   // 0x0A60 (2656)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x1082, 0x1082,   // 0x0A70 (2672)
0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x18C3,   // 0x0A80 (2688)
0x18E3, 0x2965, 0x31A6, 0x39C7, 0x4208, 0x528A, 0x630C, 0x6B4D, 0x73AE, 0x8430, 0x9CD3, 0xAD55, 0xAD75, 0xB596, 0xB596, 0xBDD7,   // 0x0A90 (2704)
0xC618, 0xBDD7, 0xB5B6, 0xAD75, 0xAD55, 0xAD75, 0xA514, 0x9CF3, 0x9CF3, 0x9CD3, 0x9CD3, 0x94B2, 0x8C71, 0x94B2, 0xAD75, 0xB596,   // 0x0AA0 (2720)
0xBDD7, 0xB5B6, 0xAD55, 0xA534, 0xB596, 0xB5B6, 0xBDD7, 0xB596, 0xA534, 0xA514, 0xAD75, 0xBDF7, 0xC638, 0xBDF7, 0xC618, 0xBDD7,   // 0x0AB0 (2736)
0xBDD7, 0xB5B6, 0xB596, 0xAD75, 0xA514, 0x9492, 0x8C71, 0x8C51, 0x7BEF, 0x7BEF, 0x7BCF, 0x73AE, 0x738E, 0x630C, 0x18E3, 0x0000,   // 0x0AC0 (2752)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082,   // 0x0AD0 (2768)
0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x18C3, 0x2104,   // 0x0AE0 (2784)
0x2945, 0x3186, 0x39C7, 0x4A49, 0x5ACB, 0x6B4D, 0x7BCF, 0x8410, 0x8C51, 0x9CD3, 0xAD55, 0xB5B6, 0xBDD7, 0xBDF7, 0xBDF7, 0xC618,   // 0x0AF0 (2800)
0xC618, 0xBDD7, 0xB596, 0xB596, 0xAD75, 0xAD55, 0xA534, 0x9CF3, 0x9CF3, 0x9CF3, 0x9CD3, 0x9CD3, 0x94B2, 0xA534, 0xBDD7, 0xBDD7,   // 0x0B00 (2816)
0xB5B6, 0xAD75, 0xA534, 0xB596, 0xBDD7, 0xB5B6, 0xB596, 0xAD55, 0xAD75, 0xB5B6, 0xC618, 0xBDD7, 0xA514, 0x9CF3, 0xAD55, 0xBDF7,   // 0x0B10 (2832)
0xBDD7, 0xB596, 0xA534, 0xA514, 0x94B2, 0x94B2, 0x8C51, 0x8430, 0x8C51, 0x8410, 0x7BCF, 0x738E, 0x6B4D, 0x39E7, 0x0000, 0x0000,   // 0x0B20 (2848)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x0861,   // 0x0B30 (2864)
0x0841, 0x0861, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x2104, 0x2945,   // 0x0B40 (2880)
0x31A6, 0x4208, 0x528A, 0x5AEB, 0x6B4D, 0x7BEF, 0x9492, 0x94B2, 0x9CF3, 0xAD75, 0xB5B6, 0xC638, 0xD69A, 0xD69A, 0xCE59, 0xBDF7,   // 0x0B50 (2896)
0xBDD7, 0xB5B6, 0xB596, 0xB5B6, 0xB596, 0xA534, 0xA514, 0xA534, 0xA534, 0x9CF3, 0x94B2, 0x9492, 0x9CD3, 0xAD75, 0xB596, 0xB596,   // 0x0B60 (2912)
0xB596, 0xA534, 0xA514, 0xB5B6, 0xB5B6, 0xAD55, 0xA534, 0xB596, 0xB5B6, 0xAD75, 0x94B2, 0x8C71, 0x8C71, 0x8C71, 0xAD75, 0xBDD7,   // 0x0B70 (2928)
0xAD75, 0x9CF3, 0x9CD3, 0x94B2, 0x94B2, 0x8C71, 0x9492, 0x8C71, 0x8410, 0x7BEF, 0x738E, 0x6B6D, 0x528A, 0x1082, 0x0000, 0x0000,   // 0x0B80 (2944)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861,   // 0x0B90 (2960)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x2104, 0x2945, 0x31A6,   // 0x0BA0 (2976)
0x4208, 0x528A, 0x5ACB, 0x632C, 0x7BCF, 0x8C71, 0x9CD3, 0xA534, 0xAD75, 0xAD55, 0xBDF7, 0xD69A, 0xDEDB, 0xCE59, 0xB5B6, 0xBDD7,   // 0x0BB0 (2992)
0xB5B6, 0xB5B6, 0xBDD7, 0xB5B6, 0xB596, 0xB596, 0xAD55, 0x9CD3, 0x94B2, 0x9492, 0x94B2, 0x8C71, 0xA514, 0xBDD7, 0xBDD7, 0xB596,   // 0x0BC0 (3008)
0xA514, 0x94B2, 0xA534, 0xBDD7, 0xB5B6, 0xA514, 0x9CF3, 0x9CF3, 0x94B2, 0x8C51, 0x9492, 0x9492, 0x8C51, 0x94B2, 0xB596, 0xB596,   // 0x0BD0 (3024)
0x9CF3, 0x9492, 0x9CD3, 0x9CF3, 0x9CD3, 0x8C71, 0x8430, 0x8C51, 0x8410, 0x73AE, 0x6B4D, 0x5AEB, 0x2945, 0x0000, 0x0000, 0x0000,   // 0x0BE0 (3040)
0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861,   // 0x0BF0 (3056)
0x0861, 0x0841, 0x0841, 0x0861, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x2104, 0x2965, 0x31A6, 0x4228,   // 0x0C00 (3072)
0x52AA, 0x630C, 0x6B6D, 0x7BCF, 0x8C71, 0xA514, 0xAD55, 0xAD55, 0xAD75, 0xB596, 0xBDF7, 0xC638, 0xBDF7, 0xB596, 0xB5B6, 0xB5B6,   // 0x0C10 (3088)
0xBDD7, 0xB5B6, 0xB596, 0xAD75, 0xAD55, 0xAD75, 0xAD75, 0xB596, 0xAD55, 0xA534, 0xA534, 0xB596, 0xBDF7, 0xC618, 0xBDF7, 0xBDD7,   // 0x0C20 (3104)
0xB596, 0xB5B6, 0xBDF7, 0xBDD7, 0xA534, 0x9CD3, 0x9CD3, 0x9492, 0x8430, 0x8C51, 0x9492, 0x8C71, 0x8C71, 0xA514, 0xAD75, 0x9CF3,   // 0x0C30 (3120)
0x9492, 0x94B2, 0xA514, 0xA514, 0x94B2, 0x8C51, 0x8430, 0x8430, 0x7BCF, 0x6B6D, 0x632C, 0x4228, 0x0020, 0x0000, 0x0000, 0x0000,   // 0x0C40 (3136)
0x0000, 0x0000, 0x0000, 0x0020, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861,   // 0x0C50 (3152)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18E3, 0x2124, 0x2965, 0x31A6, 0x4208, 0x528A,   // 0x0C60 (3168)
0x632C, 0x738E, 0x8410, 0x94B2, 0x9CF3, 0xAD55, 0xAD75, 0xAD75, 0xAD75, 0xAD55, 0xAD75, 0xB5B6, 0xB5B6, 0xB5B6, 0xB5B6, 0xBDD7,   // 0x0C70 (3184)
0xB5B6, 0xB596, 0xAD75, 0x9CF3, 0xA514, 0xAD75, 0xBDD7, 0xBDD7, 0xBDD7, 0xB5B6, 0xBDF7, 0xC618, 0xC638, 0xCE79, 0xCE59, 0xC618,   // 0x0C80 (3200)
0xC618, 0xB5B6, 0xAD75, 0x9CF3, 0x9492, 0x94B2, 0x8C71, 0x8C51, 0x8C51, 0x8C71, 0x8C71, 0x8C71, 0x94B2, 0xAD55, 0xA514, 0x9492,   // 0x0C90 (3216)
0x94B2, 0x9492, 0x94B2, 0x94B2, 0x8C71, 0x8430, 0x8410, 0x7BEF, 0x738E, 0x6B4D, 0x52AA, 0x10A2, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0CA0 (3232)
0x0000, 0x0000, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x0861, 0x0861,   // 0x0CB0 (3248)
0x0861, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x2104, 0x2124, 0x3186, 0x4208, 0x4228, 0x52AA, 0x6B6D,   // 0x0CC0 (3264)
0x73AE, 0x8410, 0x94B2, 0x9CF3, 0xAD75, 0xAD75, 0xA534, 0xAD55, 0xAD55, 0xAD55, 0xB596, 0xAD75, 0xB596, 0xBDD7, 0xB5B6, 0xB596,   // 0x0CD0 (3280)
0xAD55, 0xAD55, 0xA534, 0x9CF3, 0xA514, 0xB596, 0xB5B6, 0xB5B6, 0xBDF7, 0xBDF7, 0xBDD7, 0xC618, 0xCE59, 0xC618, 0xBDD7, 0xBDF7,   // 0x0CE0 (3296)
0xB596, 0xA534, 0x8C71, 0x8C71, 0x9CD3, 0x94B2, 0x8C71, 0x8C51, 0x8C51, 0x8C51, 0x8C71, 0x9492, 0x9CF3, 0xA534, 0x9CD3, 0x94B2,   // 0x0CF0 (3312)
0x94B2, 0x9CD3, 0x94B2, 0x8C71, 0x8430, 0x7BEF, 0x7BEF, 0x7BCF, 0x632C, 0x5ACB, 0x2945, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0D00 (3328)
0x0000, 0x0841, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x0861,   // 0x0D10 (3344)
0x0841, 0x0841, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x2104, 0x2945, 0x31A6, 0x39E7, 0x528A, 0x5AEB, 0x6B6D, 0x7BCF,   // 0x0D20 (3360)
0x8410, 0x9492, 0xA534, 0xB5B6, 0xB596, 0xA534, 0xA534, 0xAD55, 0xA514, 0x9CD3, 0xA514, 0xA514, 0xB596, 0xB596, 0xAD75, 0xA534,   // 0x0D30 (3376)
0xA534, 0x9CF3, 0x94B2, 0x9CF3, 0xAD75, 0xAD75, 0xB5B6, 0xBDF7, 0xBDD7, 0xBDF7, 0xB5B6, 0xBDD7, 0xB5B6, 0xB596, 0xAD75, 0x9CD3,   // 0x0D40 (3392)
0x8C51, 0x8C51, 0x8C71, 0x9492, 0x9492, 0x8C51, 0x8430, 0x8C51, 0x8430, 0x8430, 0x8430, 0x8C71, 0x9492, 0x8C51, 0x8C71, 0x94B2,   // 0x0D50 (3408)
0x9CD3, 0x8C71, 0x8C51, 0x8C51, 0x7BEF, 0x7BEF, 0x7BEF, 0x6B4D, 0x5AEB, 0x39E7, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x0D60 (3424)
0x0841, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x0861, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861,   // 0x0D70 (3440)
0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x10A2, 0x2104, 0x2104, 0x2945, 0x31A6, 0x4208, 0x52AA, 0x632C, 0x6B6D, 0x7BCF, 0x8430,   // 0x0D80 (3456)
0x9CD3, 0xA534, 0xAD55, 0xAD75, 0xA534, 0xAD55, 0xA514, 0x9492, 0x8C71, 0xA514, 0xAD55, 0xAD75, 0xAD75, 0xA534, 0xA514, 0x9CF3,   // 0x0D90 (3472)
0x9CD3, 0x94B2, 0x8C71, 0x9492, 0xA534, 0xB596, 0xAD75, 0xAD55, 0xB596, 0xAD55, 0xAD75, 0xAD75, 0xAD75, 0x9CF3, 0x8C51, 0x8410,   // 0x0DA0 (3488)
0x8C51, 0x8C51, 0x8C51, 0x8C51, 0x8C51, 0x8C71, 0x8C71, 0x8430, 0x8430, 0x8C71, 0x9492, 0x8C71, 0x8430, 0x8C51, 0x9492, 0x9492,   // 0x0DB0 (3504)
0x8C51, 0x8410, 0x8C51, 0x8C51, 0x8410, 0x7BCF, 0x6B4D, 0x5AEB, 0x4A69, 0x0861, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841,   // 0x0DC0 (3520)
0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2,   // 0x0DD0 (3536)
0x1082, 0x0861, 0x1082, 0x10A2, 0x18C3, 0x2104, 0x2124, 0x3186, 0x39E7, 0x4A49, 0x4A69, 0x5AEB, 0x6B6D, 0x7BCF, 0x7BEF, 0x9492,   // 0x0DE0 (3552)
0x9CF3, 0xA514, 0xBDD7, 0xB596, 0xA534, 0x94B2, 0x9CD3, 0x9CD3, 0x94B2, 0xA534, 0xA534, 0xA534, 0x9CD3, 0x9492, 0x94B2, 0x94B2,   // 0x0DF0 (3568)
0x8C71, 0x7BEF, 0x7BEF, 0x9CD3, 0xAD55, 0x9CF3, 0x94B2, 0x9CD3, 0xA534, 0xAD75, 0xA514, 0x9CF3, 0x9CD3, 0x8C71, 0x8410, 0x8430,   // 0x0E00 (3584)
0x8410, 0x8C51, 0x8C71, 0x8C71, 0x9492, 0x8C71, 0x8430, 0x8C71, 0x9492, 0x8C51, 0x8430, 0x8C51, 0x94B2, 0xA514, 0x9492, 0x7BEF,   // 0x0E10 (3600)
0x7BEF, 0x8C71, 0x8C71, 0x8410, 0x7BCF, 0x6B4D, 0x5AEB, 0x528A, 0x18E3, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x1082,   // 0x0E20 (3616)
0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x1082,   // 0x0E30 (3632)
0x1082, 0x1082, 0x10A2, 0x18C3, 0x18E3, 0x2945, 0x39C7, 0x4228, 0x528A, 0x52AA, 0x5AEB, 0x6B4D, 0x738E, 0x7BEF, 0x8C71, 0x9492,   // 0x0E40 (3648)
0xA514, 0xBDD7, 0xB596, 0xA514, 0x94B2, 0x9CF3, 0x9CF3, 0x9CF3, 0xA514, 0x94B2, 0x8430, 0x8C71, 0x9492, 0x9CF3, 0x9CD3, 0x8C71,   // 0x0E50 (3664)
0x8430, 0x8C51, 0x9CD3, 0x9CF3, 0x9CD3, 0x9CD3, 0x9492, 0x9CD3, 0xA534, 0xA534, 0xA514, 0x9CD3, 0x9492, 0x8410, 0x8C51, 0x8430,   // 0x0E60 (3680)
0x8C71, 0x8C71, 0x8C51, 0x8C51, 0x8C71, 0x8C71, 0x8C71, 0x8C71, 0x8C51, 0x8410, 0x8C71, 0xAD55, 0xAD55, 0x9492, 0x7BEF, 0x8430,   // 0x0E70 (3696)
0x94B2, 0x8C71, 0x8430, 0x8410, 0x6B6D, 0x632C, 0x52AA, 0x2945, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x1082, 0x1082,   // 0x0E80 (3712)
0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x1082, 0x1082,   // 0x0E90 (3728)
0x1082, 0x10A2, 0x18C3, 0x2104, 0x2945, 0x39E7, 0x4A49, 0x528A, 0x52AA, 0x630C, 0x6B4D, 0x73AE, 0x8430, 0x8C51, 0x9492, 0xA534,   // 0x0EA0 (3744)
0xB596, 0xAD75, 0x9CF3, 0x94B2, 0x9CD3, 0xA514, 0xA534, 0x9CF3, 0x8C51, 0x7BCF, 0x8430, 0x8C71, 0x9CD3, 0xA514, 0xAD55, 0xA534,   // 0x0EB0 (3760)
0x9CF3, 0xA514, 0x94B2, 0x94B2, 0x9CD3, 0x9CD3, 0x9492, 0x94B2, 0xA514, 0x9CD3, 0x9CD3, 0x94B2, 0x94B2, 0x9492, 0x8C51, 0x8C51,   // 0x0EC0 (3776)
0x8430, 0x8C51, 0x8C71, 0x94B2, 0x8C71, 0x8C71, 0x8430, 0x8430, 0x7BEF, 0x9492, 0xB5B6, 0xB596, 0x9492, 0x8C51, 0x8C71, 0x94B2,   // 0x0ED0 (3792)
0x9492, 0x8430, 0x7BEF, 0x6B6D, 0x6B4D, 0x5AEB, 0x3186, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x1082, 0x10A2, 0x10A2,   // 0x0EE0 (3808)
0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082,   // 0x0EF0 (3824)
0x1082, 0x18C3, 0x18E3, 0x2965, 0x39E7, 0x4208, 0x4228, 0x4A69, 0x5AEB, 0x6B4D, 0x7BEF, 0x9492, 0x94B2, 0x9CF3, 0xA534, 0xAD75,   // 0x0F00 (3840)
0xAD55, 0xA514, 0x94B2, 0x9CD3, 0xA534, 0x9CD3, 0x9CD3, 0x8C71, 0x8430, 0x8C71, 0x94B2, 0x9CF3, 0xB596, 0xB5B6, 0xB5B6, 0xB5B6,   // 0x0F10 (3856)
0xAD75, 0x9CF3, 0x8C71, 0x8C71, 0x94B2, 0x9492, 0x9492, 0xA514, 0x9CD3, 0x94B2, 0xA514, 0xA514, 0x8C71, 0x8430, 0x8C51, 0x8430,   // 0x0F20 (3872)
0x94B2, 0x9CD3, 0x9492, 0x8C71, 0x8C51, 0x8410, 0x7BEF, 0x7BCF, 0x8430, 0xAD75, 0xAD75, 0x9CD3, 0x9CF3, 0x94B2, 0x8C71, 0x9492,   // 0x0F30 (3888)
0x8430, 0x7BCF, 0x6B6D, 0x6B4D, 0x5AEB, 0x39E7, 0x0020, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x0F40 (3904)
0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082,   // 0x0F50 (3920)
0x18C3, 0x2104, 0x2965, 0x3186, 0x39C7, 0x4208, 0x4A69, 0x5AEB, 0x738E, 0x8430, 0x9492, 0xA514, 0xAD55, 0xAD75, 0xAD75, 0xA534,   // 0x0F60 (3936)
0xAD55, 0xA534, 0x9CF3, 0x9CD3, 0x9CD3, 0x9CD3, 0x94B2, 0x9492, 0x9CD3, 0xA514, 0xAD55, 0xC618, 0xC638, 0xB5B6, 0xB5B6, 0xBDD7,   // 0x0F70 (3952)
0xAD75, 0x94B2, 0x8C71, 0x8C71, 0x8C71, 0x9492, 0xAD75, 0xC618, 0xA534, 0xA514, 0xA534, 0x94B2, 0x8C51, 0x8C71, 0x94B2, 0x9CF3,   // 0x0F80 (3968)
0x9492, 0x8C51, 0x8430, 0x8410, 0x8430, 0x7BEF, 0x73AE, 0x8410, 0xA514, 0xAD75, 0xA534, 0xAD55, 0xA514, 0x94B2, 0x9CD3, 0x9492,   // 0x0F90 (3984)
0x8410, 0x73AE, 0x6B6D, 0x630C, 0x4A49, 0x0861, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2,   // 0x0FA0 (4000)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x10A2, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x18C3,   // 0x0FB0 (4016)
0x2124, 0x2945, 0x2965, 0x39C7, 0x4228, 0x528A, 0x5AEB, 0x738E, 0x8410, 0x9492, 0xA534, 0xAD55, 0xB596, 0xB5B6, 0xAD75, 0xAD75,   // 0x0FC0 (4032)
0xAD55, 0x9CF3, 0x9CF3, 0x9CF3, 0x9CF3, 0xA514, 0xA514, 0x94B2, 0x9CD3, 0xB596, 0xBDF7, 0xC618, 0xBDD7, 0xC618, 0xC618, 0xB596,   // 0x0FD0 (4048)
0x9CF3, 0x9492, 0x8430, 0x8430, 0x8C71, 0xA534, 0xC638, 0xB5B6, 0xA514, 0x9CD3, 0x9CD3, 0x8C71, 0x9492, 0x94B2, 0x9492, 0x8C71,   // 0x0FE0 (4064)
0x8430, 0x8410, 0x8410, 0x8C51, 0x7BEF, 0x73AE, 0x8410, 0xA534, 0xAD75, 0xB596, 0xAD75, 0xAD55, 0xA514, 0x9CD3, 0x9492, 0x8430,   // 0x0FF0 (4080)
0x7BCF, 0x738E, 0x632C, 0x4A69, 0x1082, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2,   // 0x1000 (4096)
0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x2104,   // 0x1010 (4112)
0x2945, 0x3186, 0x39C7, 0x4208, 0x52AA, 0x630C, 0x6B6D, 0x8410, 0x94B2, 0xA534, 0xAD55, 0xAD75, 0xAD55, 0xA534, 0xAD75, 0xAD75,   // 0x1020 (4128)
0xA534, 0xAD55, 0xAD75, 0xB596, 0xB596, 0xA534, 0x9492, 0x9CF3, 0xAD75, 0xBDD7, 0xB5B6, 0xB5B6, 0xC618, 0xBDF7, 0xB596, 0xA514,   // 0x1030 (4144)
0x94B2, 0x8410, 0x7BEF, 0x94B2, 0xA534, 0xB596, 0x9CF3, 0x8C71, 0x9CD3, 0xB596, 0xA534, 0x8C51, 0x9492, 0x8C71, 0x8C51, 0x8430,   // 0x1040 (4160)
0x8410, 0x8430, 0x8410, 0x7BEF, 0x7BEF, 0x8C51, 0xAD55, 0xB5B6, 0xB5B6, 0xB596, 0xAD55, 0xA514, 0x9CD3, 0x9492, 0x8410, 0x7BCF,   // 0x1050 (4176)
0x738E, 0x6B4D, 0x528A, 0x18C3, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x1060 (4192)
0x10A2, 0x10A2, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x2104, 0x2965,   // 0x1070 (4208)
0x39C7, 0x39E7, 0x4228, 0x52AA, 0x630C, 0x6B6D, 0x7BEF, 0x9CD3, 0xB596, 0xB596, 0xAD55, 0xA514, 0x9CF3, 0xAD55, 0xC618, 0xBDF7,   // 0x1080 (4224)
0xB5B6, 0xB5B6, 0xBDF7, 0xBDF7, 0xB596, 0xA534, 0xAD55, 0xA534, 0xB596, 0xBDD7, 0xBDF7, 0xB596, 0xBDD7, 0xBDD7, 0xB596, 0xAD55,   // 0x1090 (4240)
0x9492, 0x8C51, 0x94B2, 0x9CD3, 0x9CF3, 0x9CF3, 0x9CF3, 0x9CF3, 0xC618, 0xC638, 0x9492, 0x8C71, 0x8C51, 0x8C51, 0x8430, 0x8430,   // 0x10A0 (4256)
0x8430, 0x8410, 0x7BCF, 0x8C51, 0xA514, 0xB596, 0xBDD7, 0xB5B6, 0xAD75, 0xAD75, 0xA534, 0x9CD3, 0x94B2, 0x8430, 0x7BCF, 0x738E,   // 0x10B0 (4272)
0x6B4D, 0x52AA, 0x2104, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2,   // 0x10C0 (4288)
0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x2945, 0x3186, 0x4208,   // 0x10D0 (4304)
0x4A69, 0x528A, 0x52AA, 0x630C, 0x6B6D, 0x7BEF, 0x94B2, 0xB596, 0xB596, 0xA514, 0x9CD3, 0x9CD3, 0xA534, 0xC638, 0xD69A, 0xC638,   // 0x10E0 (4320)
0xB5B6, 0xB5B6, 0xC618, 0xB5B6, 0xAD75, 0x9CF3, 0x9CF3, 0xA534, 0xB5B6, 0xBDF7, 0xBDD7, 0xC638, 0xC638, 0xB5B6, 0xAD75, 0xA534,   // 0x10F0 (4336)
0x9CF3, 0x9CF3, 0x9CD3, 0xA514, 0xA534, 0xB596, 0xAD55, 0xAD75, 0xB5B6, 0xA514, 0x94B2, 0x8430, 0x8430, 0x8C51, 0x8C51, 0x8430,   // 0x1100 (4352)
0x8410, 0x8410, 0x94B2, 0xA534, 0xB5B6, 0xBDF7, 0xBDF7, 0xB596, 0xA534, 0xA534, 0xA514, 0x94B2, 0x8430, 0x7BEF, 0x73AE, 0x6B4D,   // 0x1110 (4368)
0x52AA, 0x2124, 0x0000, 0x0000, 0x0841, 0x0841, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x1082,   // 0x1120 (4384)
0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0861, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2965, 0x31A6, 0x4228, 0x4A69,   // 0x1130 (4400)
0x4A69, 0x5ACB, 0x630C, 0x738E, 0x8410, 0x9492, 0xA534, 0xA534, 0x9492, 0x8C71, 0x9CF3, 0xB5B6, 0xC618, 0xD69A, 0xC638, 0xC618,   // 0x1140 (4416)
0xCE79, 0xBDF7, 0xBDF7, 0xAD55, 0x9CD3, 0x9CF3, 0xAD75, 0xAD55, 0xBDD7, 0xC638, 0xCE79, 0xCE79, 0xBDD7, 0xAD55, 0xB596, 0xAD55,   // 0x1150 (4432)
0xAD55, 0xB5B6, 0xB5B6, 0xB596, 0xBDD7, 0xBDD7, 0xAD75, 0xA534, 0xAD55, 0xA534, 0x8C71, 0x7BEF, 0x8410, 0x8410, 0x8410, 0x7BEF,   // 0x1160 (4448)
0x7BEF, 0x9CF3, 0xAD75, 0xAD75, 0xBDF7, 0xBDF7, 0xB596, 0xAD55, 0xA534, 0x9CF3, 0x94B2, 0x8430, 0x7BEF, 0x73AE, 0x6B4D, 0x52AA,   // 0x1170 (4464)
0x2124, 0x0000, 0x0000, 0x0841, 0x0841, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x0861, 0x0861,   // 0x1180 (4480)
0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x1082, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2124, 0x2965, 0x39C7, 0x4208, 0x4208, 0x4A49,   // 0x1190 (4496)
0x630C, 0x738E, 0x7BEF, 0x8410, 0x9CD3, 0xB596, 0x9CF3, 0x8C71, 0x8C71, 0x9CF3, 0xB596, 0xBDF7, 0xCE59, 0xC618, 0xC638, 0xCE79,   // 0x11A0 (4512)
0xC618, 0xBDF7, 0xB596, 0xA514, 0xA534, 0xB596, 0xB5B6, 0xC618, 0xC638, 0xC638, 0xC638, 0xC618, 0xBDF7, 0xBDF7, 0xB5B6, 0xB5B6,   // 0x11B0 (4528)
0xC618, 0xBDF7, 0xB5B6, 0xBDF7, 0xA534, 0x9492, 0x94B2, 0x9492, 0x8C71, 0x8C71, 0x8C71, 0x8410, 0x8430, 0x7BEF, 0x8430, 0x94B2,   // 0x11C0 (4544)
0xAD55, 0xAD75, 0xAD75, 0xAD75, 0xB596, 0xB596, 0xAD55, 0x9CF3, 0x9CF3, 0x9CD3, 0x8C51, 0x7BEF, 0x73AE, 0x632C, 0x52AA, 0x2124,   // 0x11D0 (4560)
0x0000, 0x0000, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x0861,   // 0x11E0 (4576)
0x0861, 0x0861, 0x0861, 0x0841, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x2124, 0x2945, 0x3186, 0x31A6, 0x4208, 0x4A69, 0x5AEB,   // 0x11F0 (4592)
0x738E, 0x7BEF, 0x8410, 0xA514, 0xAD75, 0x9CD3, 0x9492, 0x9492, 0x9CD3, 0xAD55, 0xBDD7, 0xC618, 0xC618, 0xC618, 0xC638, 0xC618,   // 0x1200 (4608)
0xBDF7, 0xBDF7, 0xB5B6, 0xBDD7, 0xBDD7, 0xC618, 0xCE59, 0xC638, 0xC638, 0xC618, 0xCE59, 0xCE79, 0xCE59, 0xC618, 0xC618, 0xC618,   // 0x1210 (4624)
0xBDF7, 0xB596, 0xB596, 0xA514, 0x8C51, 0x8430, 0x7BCF, 0x73AE, 0x8C51, 0x94B2, 0x8430, 0x8C51, 0x8410, 0x8C71, 0xA514, 0xAD75,   // 0x1220 (4640)
0xAD75, 0xA534, 0xA534, 0xAD75, 0xAD75, 0xA534, 0x9CF3, 0x9CF3, 0x9CD3, 0x8430, 0x8410, 0x738E, 0x630C, 0x52AA, 0x2945, 0x0000,   // 0x1230 (4656)
0x0000, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861,   // 0x1240 (4672)
0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x2124, 0x2124, 0x3186, 0x31A6, 0x4208, 0x4A69, 0x5AEB, 0x6B4D,   // 0x1250 (4688)
0x73AE, 0x8430, 0x9CF3, 0x9CF3, 0x94B2, 0x9CD3, 0x9492, 0x9CF3, 0xB596, 0xBDF7, 0xC618, 0xC638, 0xCE59, 0xCE59, 0xCE79, 0xC618,   // 0x1260 (4704)
0xC618, 0xBDF7, 0xBDD7, 0xC618, 0xCE59, 0xCE79, 0xCE79, 0xD69A, 0xCE79, 0xCE79, 0xD6BA, 0xD6BA, 0xCE59, 0xC638, 0xC638, 0xC638,   // 0x1270 (4720)
0xBDD7, 0xAD55, 0x9CD3, 0x8410, 0x7BEF, 0x8410, 0x7BCF, 0x7BCF, 0x7BEF, 0x7BEF, 0x8410, 0x7BEF, 0x8410, 0xA514, 0xA514, 0xA514,   // 0x1280 (4736)
0x9CF3, 0x9492, 0xA534, 0xAD75, 0xA514, 0x94B2, 0x9492, 0x8C71, 0x8410, 0x7BEF, 0x6B6D, 0x5AEB, 0x528A, 0x2124, 0x0000, 0x0000,   // 0x1290 (4752)
0x0841, 0x0841, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861,   // 0x12A0 (4768)
0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x2104, 0x2945, 0x39C7, 0x39C7, 0x4208, 0x528A, 0x630C, 0x6B4D, 0x738E,   // 0x12B0 (4784)
0x8430, 0x8C51, 0x8C51, 0x8C51, 0x9492, 0x9CF3, 0xB5B6, 0xBDD7, 0xBDF7, 0xC638, 0xC638, 0xC638, 0xCE59, 0xCE79, 0xCE59, 0xC638,   // 0x12C0 (4800)
0xBDF7, 0xC618, 0xC618, 0xCE59, 0xCE59, 0xCE79, 0xD69A, 0xCE79, 0xD6BA, 0xDEDB, 0xD6BA, 0xCE59, 0xC638, 0xC618, 0xBDD7, 0xB596,   // 0x12D0 (4816)
0xA514, 0x8430, 0x7BEF, 0x8410, 0x8430, 0x7BEF, 0x7BCF, 0x7BCF, 0x7BEF, 0x7BEF, 0x7BCF, 0x8410, 0x9492, 0x9CD3, 0x9492, 0x94B2,   // 0x12E0 (4832)
0x94B2, 0xAD75, 0xAD75, 0x9492, 0x8C71, 0x8C71, 0x8C51, 0x8430, 0x738E, 0x6B4D, 0x630C, 0x528A, 0x2104, 0x0000, 0x0000, 0x0020,   // 0x12F0 (4848)
0x0841, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082,   // 0x1300 (4864)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18E3, 0x2104, 0x2945, 0x31A6, 0x39C7, 0x4208, 0x4A69, 0x5ACB, 0x632C, 0x738E, 0x8410,   // 0x1310 (4880)
0x8430, 0x8430, 0x8C71, 0x94B2, 0xA534, 0xBDD7, 0xBDF7, 0xC638, 0xCE59, 0xBDF7, 0xBDD7, 0xC638, 0xCE59, 0xC638, 0xC638, 0xC638,   // 0x1320 (4896)
0xC638, 0xCE59, 0xCE59, 0xCE79, 0xCE79, 0xCE79, 0xD69A, 0xD6BA, 0xDEFB, 0xD6BA, 0xCE59, 0xC618, 0xBDD7, 0xB5B6, 0xAD55, 0x94B2,   // 0x1330 (4912)
0x8410, 0x7BEF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BEF, 0x7BEF, 0x7BEF, 0x7BEF, 0x7BCF, 0x7BEF, 0x8C71, 0x8C71, 0x8C51, 0x8C51, 0x9CD3,   // 0x1340 (4928)
0xB5B6, 0xA534, 0x94B2, 0x94B2, 0x8C51, 0x8430, 0x8410, 0x6B6D, 0x6B6D, 0x632C, 0x528A, 0x18E3, 0x0000, 0x0000, 0x0020, 0x0841,   // 0x1350 (4944)
0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x1082, 0x10A2, 0x10A2,   // 0x1360 (4960)
0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x2104, 0x2124, 0x3186, 0x31A6, 0x4208, 0x4A69, 0x52AA, 0x630C, 0x6B6D, 0x7BEF, 0x8430,   // 0x1370 (4976)
0x8430, 0x9CD3, 0xAD55, 0xA514, 0xAD55, 0xB5B6, 0xC618, 0xC638, 0xBDD7, 0xBDD7, 0xBDF7, 0xBDF7, 0xC618, 0xC638, 0xC618, 0xC618,   // 0x1380 (4992)
0xCE59, 0xD69A, 0xD6BA, 0xD69A, 0xCE59, 0xCE79, 0xD69A, 0xD69A, 0xD69A, 0xCE59, 0xC618, 0xB5B6, 0xB596, 0xA534, 0x8C51, 0x8C51,   // 0x1390 (5008)
0x8430, 0x7BEF, 0x7BEF, 0x7BCF, 0x8430, 0x8C71, 0x8410, 0x8410, 0x7BEF, 0x7BCF, 0x8410, 0x8410, 0x8410, 0x7BCF, 0x8430, 0xA514,   // 0x13A0 (5024)
0xAD55, 0xA514, 0x9CD3, 0x8C51, 0x8410, 0x7BEF, 0x738E, 0x6B4D, 0x630C, 0x528A, 0x10A2, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861,   // 0x13B0 (5040)
0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x10A2,   // 0x13C0 (5056)
0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x2104, 0x2124, 0x2965, 0x3186, 0x4208, 0x4A49, 0x528A, 0x5AEB, 0x632C, 0x73AE, 0x8430, 0x8410,   // 0x13D0 (5072)
0x8C71, 0xAD55, 0xAD55, 0x9CD3, 0xB596, 0xC618, 0xC638, 0xC618, 0xBDD7, 0xBDD7, 0xC618, 0xCE59, 0xCE59, 0xC638, 0xCE59, 0xCE59,   // 0x13E0 (5088)
0xCE59, 0xCE79, 0xCE59, 0xC638, 0xCE59, 0xCE79, 0xCE59, 0xCE79, 0xCE59, 0xBDF7, 0xBDD7, 0xB5B6, 0x9CD3, 0x9492, 0x8C71, 0x8C71,   // 0x13F0 (5104)
0x8430, 0x8C51, 0x7BEF, 0x7BEF, 0x8C51, 0x8410, 0x8410, 0x7BEF, 0x738E, 0x7BCF, 0x7BCF, 0x73AE, 0x7BCF, 0x8C71, 0xA514, 0xAD75,   // 0x1400 (5120)
0xA514, 0x94B2, 0x9492, 0x8410, 0x7BEF, 0x738E, 0x630C, 0x5AEB, 0x4A69, 0x1082, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861,   // 0x1410 (5136)
0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2,   // 0x1420 (5152)
0x10A2, 0x10A2, 0x18C3, 0x2104, 0x2104, 0x2945, 0x2965, 0x39E7, 0x4A49, 0x4A69, 0x5AEB, 0x6B6D, 0x7BCF, 0x8430, 0x8410, 0x8430,   // 0x1430 (5168)
0x9CF3, 0xAD55, 0xAD75, 0xBDF7, 0xC618, 0xC618, 0xC638, 0xC618, 0xBDF7, 0xC618, 0xCE59, 0xCE59, 0xCE59, 0xCE79, 0xCE79, 0xD69A,   // 0x1440 (5184)
0xCE79, 0xCE59, 0xCE79, 0xCE59, 0xCE79, 0xCE59, 0xCE79, 0xCE79, 0xBDF7, 0xBDF7, 0xB5B6, 0x9CD3, 0x8C51, 0x8C71, 0x8C71, 0x8C51,   // 0x1450 (5200)
0x8430, 0x7BEF, 0x7BCF, 0x7BCF, 0x7BCF, 0x738E, 0x738E, 0x6B6D, 0x738E, 0x7BCF, 0x738E, 0x7BEF, 0xA514, 0xA534, 0xAD75, 0xA534,   // 0x1460 (5216)
0x9CD3, 0x8430, 0x738E, 0x632C, 0x5AEB, 0x5ACB, 0x5ACB, 0x4208, 0x0861, 0x0000, 0x0000, 0x0000, 0x0841, 0x0841, 0x0861, 0x0861,   // 0x1470 (5232)
0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x1082, 0x10A2, 0x10A2,   // 0x1480 (5248)
0x10A2, 0x18E3, 0x2104, 0x2104, 0x2124, 0x2965, 0x39C7, 0x4A49, 0x528A, 0x5AEB, 0x6B6D, 0x7BCF, 0x7BEF, 0x8C51, 0xA514, 0xAD55,   // 0x1490 (5264)
0xB596, 0xBDD7, 0xC638, 0xC638, 0xBDF7, 0xC638, 0xC618, 0xC618, 0xC618, 0xC618, 0xC638, 0xCE59, 0xD69A, 0xD6BA, 0xDEDB, 0xD69A,   // 0x14A0 (5280)
0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xD69A, 0xCE59, 0xC618, 0xB5B6, 0xAD75, 0x9CD3, 0x8410, 0x8430, 0x8430, 0x8410, 0x7BEF,   // 0x14B0 (5296)
0x7BEF, 0x7BCF, 0x7BCF, 0x73AE, 0x73AE, 0x73AE, 0x6B6D, 0x6B4D, 0x6B6D, 0x6B6D, 0x8C51, 0xA514, 0xA514, 0xB596, 0xAD75, 0x9CD3,   // 0x14C0 (5312)
0x73AE, 0x630C, 0x5ACB, 0x4A69, 0x52AA, 0x5AEB, 0x39C7, 0x0020, 0x0000, 0x0000, 0x0000, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861,   // 0x14D0 (5328)
0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x1082, 0x18C3, 0x18C3, 0x18C3,   // 0x14E0 (5344)
0x18E3, 0x2104, 0x2104, 0x2124, 0x2945, 0x31A6, 0x4208, 0x4A69, 0x5AEB, 0x6B4D, 0x738E, 0x7BEF, 0x9CD3, 0xBDD7, 0xC618, 0xBDD7,   // 0x14F0 (5360)
0xC618, 0xC638, 0xC618, 0xC618, 0xC618, 0xBDF7, 0xC638, 0xC638, 0xBDF7, 0xBDF7, 0xCE59, 0xD69A, 0xDEFB, 0xE71C, 0xD6BA, 0xCE79,   // 0x1500 (5376)
0xCE59, 0xCE59, 0xCE79, 0xCE59, 0xCE79, 0xCE59, 0xC638, 0xB5B6, 0xA514, 0x9CD3, 0x8430, 0x8430, 0x8430, 0x7BEF, 0x7BEF, 0x7BCF,   // 0x1510 (5392)
0x7BCF, 0x7BEF, 0x7BCF, 0x73AE, 0x73AE, 0x738E, 0x6B6D, 0x632C, 0x6B6D, 0x9CD3, 0xA514, 0x9CF3, 0xAD75, 0xB5B6, 0x9492, 0x6B4D,   // 0x1520 (5408)
0x5AEB, 0x5ACB, 0x528A, 0x4A69, 0x528A, 0x3186, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x1530 (5424)
0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x18E3, 0x2104,   // 0x1540 (5440)
0x2104, 0x2104, 0x2124, 0x2945, 0x31A6, 0x39E7, 0x4A49, 0x5ACB, 0x630C, 0x7BCF, 0x9492, 0xA514, 0xB5B6, 0xBDF7, 0xBDF7, 0xC638,   // 0x1550 (5456)
0xCE59, 0xC638, 0xC638, 0xC618, 0xC638, 0xCE59, 0xC638, 0xC618, 0xC618, 0xCE79, 0xCE79, 0xD69A, 0xD6BA, 0xD69A, 0xCE79, 0xCE79,   // 0x1560 (5472)
0xCE59, 0xCE79, 0xCE59, 0xCE79, 0xCE79, 0xC638, 0xC618, 0xB596, 0x9492, 0x8C51, 0x8C51, 0x8C51, 0x8410, 0x8410, 0x7BCF, 0x7BEF,   // 0x1570 (5488)
0x7BEF, 0x7BCF, 0x73AE, 0x738E, 0x6B6D, 0x6B6D, 0x6B4D, 0x6B6D, 0x9492, 0xA534, 0x9CD3, 0xAD55, 0xAD55, 0x8C51, 0x630C, 0x52AA,   // 0x1580 (5504)
0x528A, 0x4228, 0x4228, 0x4228, 0x2124, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082,   // 0x1590 (5520)
0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x18C3, 0x2104, 0x2124,   // 0x15A0 (5536)
0x2124, 0x2945, 0x2965, 0x31A6, 0x39E7, 0x4A49, 0x5ACB, 0x632C, 0x7BEF, 0x9492, 0xA534, 0xB5B6, 0xC618, 0xC618, 0xC638, 0xCE79,   // 0x15B0 (5552)
0xCE59, 0xC618, 0xC638, 0xC618, 0xC638, 0xCE79, 0xCE59, 0xCE79, 0xCE79, 0xCE59, 0xCE79, 0xCE59, 0xCE59, 0xCE79, 0xD69A, 0xCE59,   // 0x15C0 (5568)
0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xD69A, 0xCE79, 0xC618, 0xA514, 0x8C71, 0x8C71, 0x8C51, 0x8410, 0x8410, 0x7BEF, 0x7BEF, 0x7BEF,   // 0x15D0 (5584)
0x7BCF, 0x73AE, 0x6B6D, 0x6B6D, 0x738E, 0x73AE, 0x6B6D, 0x73AE, 0x9CD3, 0xA514, 0xAD55, 0x94B2, 0x7BCF, 0x5AEB, 0x528A, 0x4A49,   // 0x15E0 (5600)
0x39E7, 0x4208, 0x4228, 0x18C3, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082,   // 0x15F0 (5616)
0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2124, 0x2945,   // 0x1600 (5632)
0x2965, 0x3186, 0x39C7, 0x4208, 0x4A49, 0x528A, 0x6B4D, 0x7BCF, 0x8430, 0xA534, 0xB5B6, 0xC618, 0xC618, 0xC618, 0xC638, 0xC618,   // 0x1610 (5648)
0xC618, 0xCE79, 0xC638, 0xC638, 0xCE59, 0xC638, 0xC638, 0xC618, 0xCE59, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE79,   // 0x1620 (5664)
0xD6BA, 0xDEDB, 0xD6BA, 0xD6BA, 0xD69A, 0xC618, 0xBDD7, 0x9CF3, 0x8C51, 0x8430, 0x8410, 0x8410, 0x8C51, 0x8410, 0x7BEF, 0x7BCF,   // 0x1630 (5680)
0x73AE, 0x73AE, 0x738E, 0x738E, 0x738E, 0x738E, 0x738E, 0x8C71, 0xA514, 0xAD75, 0x8C71, 0x632C, 0x52AA, 0x4A69, 0x4A49, 0x39E7,   // 0x1640 (5696)
0x39E7, 0x39E7, 0x0861, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082,   // 0x1650 (5712)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2124, 0x2945, 0x2965,   // 0x1660 (5728)
0x3186, 0x31A6, 0x4A49, 0x528A, 0x5ACB, 0x632C, 0x7BEF, 0x9492, 0xA534, 0xB596, 0xBDF7, 0xC618, 0xBDF7, 0xBDD7, 0xC618, 0xC618,   // 0x1670 (5744)
0xD6BA, 0xD6BA, 0xC638, 0xC638, 0xC638, 0xC638, 0xCE59, 0xCE79, 0xCE59, 0xCE59, 0xD69A, 0xCE79, 0xCE59, 0xCE59, 0xD69A, 0xDEDB,   // 0x1680 (5760)
0xE71C, 0xDEDB, 0xD6BA, 0xD69A, 0xCE79, 0xC618, 0xAD55, 0x8C71, 0x8430, 0x8430, 0x8410, 0x8C51, 0x8430, 0x8410, 0x8410, 0x8430,   // 0x1690 (5776)
0x7BEF, 0x6B6D, 0x73AE, 0x8C51, 0x9492, 0x8C51, 0x8C51, 0x9CF3, 0xA514, 0x8410, 0x5AEB, 0x528A, 0x4A49, 0x39E7, 0x31A6, 0x4208,   // 0x16A0 (5792)
0x3186, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2,   // 0x16B0 (5808)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x2104, 0x2124, 0x2945, 0x2965, 0x3186,   // 0x16C0 (5824)
0x39E7, 0x4A69, 0x5ACB, 0x632C, 0x6B6D, 0x8430, 0x9CD3, 0xAD75, 0xB596, 0xBDD7, 0xBDF7, 0xBDD7, 0xBDF7, 0xC618, 0xCE59, 0xCE59,   // 0x16D0 (5840)
0xD69A, 0xCE79, 0xCE59, 0xCE59, 0xCE59, 0xCE79, 0xCE59, 0xCE59, 0xCE79, 0xCE59, 0xD69A, 0xDEDB, 0xD69A, 0xCE79, 0xD69A, 0xDEDB,   // 0x16E0 (5856)
0xD6BA, 0xCE79, 0xC638, 0xC638, 0xBDF7, 0xA534, 0x9492, 0x8C51, 0x8430, 0x8410, 0x8430, 0x9CF3, 0x8C51, 0x8410, 0x8410, 0x7BEF,   // 0x16F0 (5872)
0x73AE, 0x7BCF, 0x8430, 0x8C71, 0x8C51, 0x94B2, 0xA514, 0x9CD3, 0x7BEF, 0x5AEB, 0x528A, 0x4228, 0x39E7, 0x39C7, 0x4208, 0x2104,   // 0x1700 (5888)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2,   // 0x1710 (5904)
0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2124, 0x2945, 0x2965, 0x31A6, 0x4208,   // 0x1720 (5920)
0x4A69, 0x5AEB, 0x6B4D, 0x7BCF, 0x8C71, 0x9CD3, 0xAD55, 0xAD75, 0xB596, 0xBDD7, 0xC618, 0xC638, 0xC618, 0xC618, 0xC638, 0xCE79,   // 0x1730 (5936)
0xCE59, 0xCE59, 0xCE79, 0xD69A, 0xCE79, 0xC638, 0xC638, 0xCE59, 0xCE79, 0xDEDB, 0xDEFB, 0xD6BA, 0xCE79, 0xD69A, 0xD69A, 0xCE59,   // 0x1740 (5952)
0xC618, 0xB5B6, 0xAD55, 0xA534, 0x9CD3, 0x8C71, 0x8C51, 0x8C71, 0x9CF3, 0xB5B6, 0xBDD7, 0x9CD3, 0x7BCF, 0x73AE, 0x7BCF, 0x7BCF,   // 0x1750 (5968)
0x73AE, 0x7BEF, 0x8410, 0x7BCF, 0x8C71, 0x9CF3, 0x9492, 0x7BEF, 0x52AA, 0x4A49, 0x4208, 0x39E7, 0x39E7, 0x4208, 0x0861, 0x0000,   // 0x1760 (5984)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2,   // 0x1770 (6000)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2104, 0x2124, 0x2965, 0x31A6, 0x4208, 0x4A69,   // 0x1780 (6016)
0x5AEB, 0x6B6D, 0x8410, 0x9492, 0x9CF3, 0xAD55, 0xAD75, 0xB5B6, 0xC618, 0xC638, 0xCE59, 0xC618, 0xC618, 0xCE59, 0xCE59, 0xBDF7,   // 0x1790 (6032)
0xC618, 0xC638, 0xD6BA, 0xCE79, 0xCE79, 0xCE79, 0xCE59, 0xD69A, 0xCE79, 0xD69A, 0xD6BA, 0xD6BA, 0xDEDB, 0xD69A, 0xC618, 0xBDD7,   // 0x17A0 (6048)
0xB596, 0x9CF3, 0x9CD3, 0x9CD3, 0x94B2, 0x9492, 0xAD75, 0xBDF7, 0xC618, 0xBDD7, 0x9CF3, 0x7BCF, 0x738E, 0x7BCF, 0x7BEF, 0x7BEF,   // 0x17B0 (6064)
0x8C71, 0x8C71, 0x7BEF, 0x8430, 0x94B2, 0x9492, 0x7BCF, 0x528A, 0x4228, 0x39E7, 0x4A49, 0x4A69, 0x31A6, 0x0000, 0x0000, 0x0000,   // 0x17C0 (6080)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2,   // 0x17D0 (6096)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x2124, 0x2965, 0x31A6, 0x39E7, 0x4A69, 0x5ACB,   // 0x17E0 (6112)
0x6B4D, 0x7BCF, 0x8C51, 0x9CD3, 0xA534, 0xB5B6, 0xBDF7, 0xC638, 0xCE79, 0xCE59, 0xC618, 0xBDF7, 0xC618, 0xBDF7, 0xBDF7, 0xC618,   // 0x17F0 (6128)
0xC638, 0xCE59, 0xC638, 0xCE79, 0xCE79, 0xCE59, 0xCE79, 0xCE79, 0xCE59, 0xCE79, 0xD69A, 0xD6BA, 0xD69A, 0xC638, 0xB5B6, 0xAD55,   // 0x1800 (6144)
0xAD55, 0xA534, 0x9CF3, 0xA534, 0xAD75, 0xB5B6, 0xB5B6, 0xAD75, 0xB596, 0xAD55, 0x9492, 0x7BEF, 0x7BEF, 0x8C51, 0x8C71, 0x8C51,   // 0x1810 (6160)
0x94B2, 0x8410, 0x8410, 0x9492, 0x8C51, 0x73AE, 0x630C, 0x528A, 0x4A49, 0x52AA, 0x4A69, 0x18E3, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1820 (6176)
0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x1830 (6192)
0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2124, 0x2965, 0x31A6, 0x39E7, 0x4A49, 0x52AA, 0x6B4D,   // 0x1840 (6208)
0x7BCF, 0x8430, 0x8C71, 0xA514, 0xB5B6, 0xBDF7, 0xC638, 0xC618, 0xBDF7, 0xC618, 0xC618, 0xC618, 0xC638, 0xC638, 0xC638, 0xC638,   // 0x1850 (6224)
0xCE59, 0xCE59, 0xC638, 0xC618, 0xC618, 0xC638, 0xC638, 0xCE59, 0xCE79, 0xCE79, 0xCE59, 0xCE79, 0xCE59, 0xBDF7, 0xB5B6, 0xAD55,   // 0x1860 (6240)
0x9CF3, 0x9CF3, 0xAD55, 0xBDD7, 0xB5B6, 0xB5B6, 0xAD75, 0xB596, 0xAD75, 0xA514, 0x8C71, 0x8C71, 0x9492, 0x8430, 0x8410, 0x7BEF,   // 0x1870 (6256)
0x6B6D, 0x7BCF, 0x8C51, 0x8430, 0x73AE, 0x6B6D, 0x630C, 0x5ACB, 0x52AA, 0x39C7, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1880 (6272)
0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x0841, 0x0861, 0x0861, 0x0841, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x1890 (6288)
0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x2124, 0x2945, 0x3186, 0x39C7, 0x4208, 0x528A, 0x632C, 0x7BCF,   // 0x18A0 (6304)
0x8430, 0x9492, 0xA514, 0xB596, 0xBDD7, 0xC638, 0xC638, 0xBDF7, 0xC618, 0xC638, 0xC638, 0xC638, 0xCE59, 0xCE59, 0xCE79, 0xCE59,   // 0x18B0 (6320)
0xC638, 0xC638, 0xC618, 0xC618, 0xC638, 0xCE59, 0xCE79, 0xCE79, 0xD6BA, 0xD6BA, 0xCE79, 0xD69A, 0xCE59, 0xBDD7, 0xA534, 0xA514,   // 0x18C0 (6336)
0xAD55, 0xB596, 0xB5B6, 0xB596, 0xB596, 0xAD75, 0xAD75, 0xA534, 0xA534, 0x9CD3, 0x8410, 0x73AE, 0x73AE, 0x738E, 0x6B4D, 0x630C,   // 0x18D0 (6352)
0x6B6D, 0x8C51, 0x7BEF, 0x738E, 0x632C, 0x5AEB, 0x52AA, 0x4A69, 0x2124, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x18E0 (6368)
0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0841, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x18F0 (6384)
0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x2124, 0x2965, 0x31A6, 0x4208, 0x4A69, 0x5AEB, 0x738E, 0x8410,   // 0x1900 (6400)
0x9492, 0x9CD3, 0xAD55, 0xB5B6, 0xC618, 0xC638, 0xBDF7, 0xC638, 0xD69A, 0xCE79, 0xCE59, 0xCE59, 0xCE59, 0xCE79, 0xCE59, 0xC638,   // 0x1910 (6416)
0xC638, 0xC638, 0xCE59, 0xCE79, 0xCE59, 0xCE59, 0xCE79, 0xDEFB, 0xDEDB, 0xCE79, 0xD69A, 0xC638, 0xB596, 0xA534, 0xAD55, 0xB596,   // 0x1920 (6432)
0xB5B6, 0xB596, 0xB5B6, 0xAD75, 0xAD55, 0xAD55, 0xA514, 0x9492, 0x7BCF, 0x738E, 0x6B6D, 0x738E, 0x6B4D, 0x630C, 0x5ACB, 0x6B4D,   // 0x1930 (6448)
0x8410, 0x7BEF, 0x738E, 0x5AEB, 0x52AA, 0x4A69, 0x39E7, 0x0861, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1940 (6464)
0x0000, 0x0000, 0x0020, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x1950 (6480)
0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2124, 0x2965, 0x31A6, 0x4208, 0x4A49, 0x5ACB, 0x632C, 0x73AE, 0x8410,   // 0x1960 (6496)
0x9492, 0xA514, 0xB596, 0xBDD7, 0xBDF7, 0xC618, 0xCE59, 0xD69A, 0xD69A, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE59, 0xCE59,   // 0x1970 (6512)
0xC638, 0xC638, 0xC638, 0xC638, 0xCE59, 0xCE79, 0xD69A, 0xD69A, 0xCE59, 0xC638, 0xBDF7, 0xBDD7, 0xBDD7, 0xAD55, 0xAD75, 0xB5B6,   // 0x1980 (6528)
0xB596, 0xBDF7, 0xBDD7, 0xAD55, 0xA534, 0xA534, 0x8430, 0x73AE, 0x73AE, 0x738E, 0x6B6D, 0x632C, 0x630C, 0x528A, 0x630C, 0x7BCF,   // 0x1990 (6544)
0x73AE, 0x6B6D, 0x5AEB, 0x4A49, 0x4228, 0x2945, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x19A0 (6560)
0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x19B0 (6576)
0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2945, 0x3186, 0x39C7, 0x4228, 0x528A, 0x630C, 0x6B6D, 0x7BEF, 0x9492,   // 0x19C0 (6592)
0x9CF3, 0xAD75, 0xB5B6, 0xBDD7, 0xC618, 0xC638, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xC638, 0xC618, 0xC638,   // 0x19D0 (6608)
0xC638, 0xC618, 0xC638, 0xCE59, 0xCE79, 0xD6BA, 0xD6BA, 0xD69A, 0xC618, 0xBDD7, 0xBDD7, 0xBDD7, 0xA514, 0xA514, 0xB596, 0xBDD7,   // 0x19E0 (6624)
0xC618, 0xBDF7, 0xA534, 0x94B2, 0x9CF3, 0x8430, 0x73AE, 0x738E, 0x738E, 0x632C, 0x630C, 0x5AEB, 0x4A69, 0x52AA, 0x6B4D, 0x6B4D,   // 0x19F0 (6640)
0x632C, 0x528A, 0x39E7, 0x39C7, 0x1082, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1A00 (6656)
0x0000, 0x0000, 0x0841, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3,   // 0x1A10 (6672)
0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2124, 0x2965, 0x31A6, 0x4208, 0x4A49, 0x5ACB, 0x632C, 0x73AE, 0x8430, 0x9CD3,   // 0x1A20 (6688)
0xA514, 0xAD75, 0xB5B6, 0xBDF7, 0xBDD7, 0xC618, 0xC638, 0xC638, 0xC638, 0xC618, 0xC638, 0xC638, 0xC618, 0xBDF7, 0xBDF7, 0xBDF7,   // 0x1A30 (6704)
0xC618, 0xCE59, 0xCE59, 0xCE79, 0xDEDB, 0xD6BA, 0xCE59, 0xBDD7, 0xAD55, 0xAD55, 0xA534, 0x9CF3, 0x9492, 0xA534, 0xB5B6, 0xBDD7,   // 0x1A40 (6720)
0xBDD7, 0xAD75, 0x9492, 0x8C51, 0x7BEF, 0x73AE, 0x738E, 0x632C, 0x5AEB, 0x5AEB, 0x528A, 0x4A49, 0x4A69, 0x52AA, 0x630C, 0x5AEB,   // 0x1A50 (6736)
0x4A49, 0x4228, 0x2104, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1A60 (6752)
0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3,   // 0x1A70 (6768)
0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2124, 0x2945, 0x31A6, 0x39E7, 0x4228, 0x528A, 0x630C, 0x6B6D, 0x7BEF, 0x8C71, 0x9CD3,   // 0x1A80 (6784)
0xA534, 0xAD75, 0xB5B6, 0xB5B6, 0xBDD7, 0xBDF7, 0xBDF7, 0xBDF7, 0xBDD7, 0xC618, 0xBDF7, 0xBDD7, 0xBDD7, 0xBDD7, 0xBDF7, 0xC638,   // 0x1A90 (6800)
0xC638, 0xC638, 0xCE59, 0xD69A, 0xCE59, 0xBDF7, 0xAD55, 0x9CF3, 0x94B2, 0x9492, 0x8C71, 0x9492, 0x9CF3, 0xAD55, 0xB5B6, 0xBDD7,   // 0x1AA0 (6816)
0xA514, 0x8C51, 0x7BEF, 0x73AE, 0x738E, 0x6B6D, 0x632C, 0x630C, 0x5ACB, 0x528A, 0x528A, 0x52AA, 0x5ACB, 0x5ACB, 0x4A69, 0x4A49,   // 0x1AB0 (6832)
0x39E7, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1AC0 (6848)
0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3,   // 0x1AD0 (6864)
0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x2945, 0x3186, 0x31A6, 0x4208, 0x4A69, 0x5ACB, 0x6B4D, 0x73AE, 0x8430, 0x94B2, 0x9CF3,   // 0x1AE0 (6880)
0xAD55, 0xB5B6, 0xB5B6, 0xB5B6, 0xBDD7, 0xBDD7, 0xC618, 0xBDF7, 0xC618, 0xBDF7, 0xBDD7, 0xBDF7, 0xBDF7, 0xBDF7, 0xC618, 0xC618,   // 0x1AF0 (6896)
0xC638, 0xC638, 0xC638, 0xBDF7, 0xAD75, 0xA514, 0x9CD3, 0x9492, 0x8C71, 0x9492, 0x94B2, 0x94B2, 0xAD75, 0xB5B6, 0xB5B6, 0xA534,   // 0x1B00 (6912)
0x8C71, 0x7BCF, 0x738E, 0x6B6D, 0x6B4D, 0x630C, 0x5AEB, 0x5ACB, 0x52AA, 0x5ACB, 0x52AA, 0x528A, 0x4228, 0x4A49, 0x4228, 0x18E3,   // 0x1B10 (6928)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1B20 (6944)
0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1B30 (6960)
0x18C3, 0x18E3, 0x18E3, 0x2104, 0x2124, 0x2945, 0x3186, 0x39C7, 0x4228, 0x528A, 0x630C, 0x738E, 0x7BCF, 0x8C71, 0x9CF3, 0xAD55,   // 0x1B40 (6976)
0xB596, 0xB5B6, 0xBDD7, 0xBDD7, 0xBDD7, 0xBDF7, 0xC618, 0xC618, 0xCE59, 0xC618, 0xC618, 0xC638, 0xC638, 0xCE59, 0xC638, 0xC618,   // 0x1B50 (6992)
0xC618, 0xC638, 0xBDF7, 0xAD75, 0x9CF3, 0x94B2, 0x9492, 0x9492, 0x94B2, 0x94B2, 0x9CD3, 0xB596, 0xBDF7, 0xB596, 0x9CD3, 0x94B2,   // 0x1B60 (7008)
0x738E, 0x6B6D, 0x6B4D, 0x5AEB, 0x630C, 0x5AEB, 0x5AEB, 0x5AEB, 0x528A, 0x52AA, 0x528A, 0x4A49, 0x4A49, 0x2124, 0x0020, 0x0000,   // 0x1B70 (7024)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1B80 (7040)
0x0020, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1B90 (7056)
0x18E3, 0x18E3, 0x2104, 0x2104, 0x2945, 0x2965, 0x31A6, 0x4208, 0x4A49, 0x5ACB, 0x632C, 0x73AE, 0x8430, 0x94B2, 0x9CF3, 0xAD55,   // 0x1BA0 (7072)
0xB596, 0xBDD7, 0xBDD7, 0xBDF7, 0xC618, 0xC638, 0xCE59, 0xD69A, 0xCE59, 0xC638, 0xCE79, 0xD69A, 0xCE79, 0xCE79, 0xD69A, 0xC638,   // 0x1BB0 (7088)
0xC638, 0xBDF7, 0xAD75, 0x9CF3, 0x9492, 0x9492, 0x8C71, 0x94B2, 0xA534, 0xB596, 0xB596, 0xAD75, 0x9CF3, 0x8C71, 0x8C51, 0x738E,   // 0x1BC0 (7104)
0x6B4D, 0x630C, 0x630C, 0x630C, 0x630C, 0x630C, 0x5ACB, 0x52AA, 0x5ACB, 0x528A, 0x4A49, 0x31A6, 0x0841, 0x0000, 0x0000, 0x0000,   // 0x1BD0 (7120)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1BE0 (7136)
0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1BF0 (7152)
0x18E3, 0x18E3, 0x2104, 0x2124, 0x2965, 0x3186, 0x39E7, 0x4228, 0x528A, 0x5AEB, 0x6B6D, 0x7BCF, 0x8430, 0x94B2, 0xA514, 0xA534,   // 0x1C00 (7168)
0xB5B6, 0xC618, 0xC638, 0xCE59, 0xC618, 0xC618, 0xC618, 0xC618, 0xC618, 0xC638, 0xCE59, 0xCE59, 0xC638, 0xC618, 0xBDD7, 0xB5B6,   // 0x1C10 (7184)
0xAD55, 0xA514, 0x9CD3, 0x8C51, 0x8430, 0x8410, 0x9CD3, 0xB5B6, 0xB5B6, 0xB596, 0xA534, 0xA514, 0x8C51, 0x7BCF, 0x73AE, 0x632C,   // 0x1C20 (7200)
0x632C, 0x632C, 0x630C, 0x5AEB, 0x52AA, 0x528A, 0x5ACB, 0x5ACB, 0x528A, 0x4208, 0x10A2, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1C30 (7216)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x1C40 (7232)
0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18E3,   // 0x1C50 (7248)
0x18E3, 0x18E3, 0x2124, 0x2945, 0x2965, 0x31A6, 0x4208, 0x4A69, 0x52AA, 0x630C, 0x6B6D, 0x7BEF, 0x8C51, 0x9492, 0x9CD3, 0xA534,   // 0x1C60 (7264)
0xB596, 0xB5B6, 0xBDD7, 0xBDD7, 0xBDF7, 0xB5B6, 0xBDD7, 0xBDF7, 0xBDF7, 0xBDF7, 0xC638, 0xC618, 0xB5B6, 0xB596, 0xB596, 0xAD75,   // 0x1C70 (7280)
0xAD75, 0xA534, 0x94B2, 0x8410, 0x8C71, 0xB5B6, 0xB5B6, 0xA534, 0xAD55, 0x9CF3, 0x9CF3, 0x9CD3, 0x7BEF, 0x6B6D, 0x6B4D, 0x6B6D,   // 0x1C80 (7296)
0x6B6D, 0x6B4D, 0x6B4D, 0x630C, 0x5ACB, 0x52AA, 0x528A, 0x4228, 0x2104, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1C90 (7312)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020,   // 0x1CA0 (7328)
0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1CB0 (7344)
0x18E3, 0x2104, 0x2124, 0x2945, 0x3186, 0x39C7, 0x4208, 0x4A69, 0x5ACB, 0x6B4D, 0x73AE, 0x7BEF, 0x9492, 0xA514, 0xA534, 0xAD55,   // 0x1CC0 (7360)
0xAD75, 0xB5B6, 0xB5B6, 0xC618, 0xC618, 0xC618, 0xC618, 0xBDD7, 0xBDF7, 0xBDF7, 0xBDF7, 0xBDF7, 0xBDD7, 0xBDD7, 0xB5B6, 0xB596,   // 0x1CD0 (7376)
0xBDD7, 0xB596, 0x9CD3, 0x9CF3, 0xAD55, 0xA514, 0x9492, 0xA514, 0x9CF3, 0x9CD3, 0x94B2, 0x8430, 0x73AE, 0x6B6D, 0x632C, 0x6B6D,   // 0x1CE0 (7392)
0x73AE, 0x7BCF, 0x6B4D, 0x52AA, 0x4A69, 0x4A49, 0x2965, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1CF0 (7408)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x1D00 (7424)
0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18E3,   // 0x1D10 (7440)
0x18E3, 0x2104, 0x2124, 0x2945, 0x3186, 0x39C7, 0x4208, 0x4A69, 0x5AEB, 0x73AE, 0x7BEF, 0x8C51, 0x94B2, 0x9CF3, 0xA514, 0xAD55,   // 0x1D20 (7456)
0xAD75, 0xB596, 0xB5B6, 0xBDF7, 0xBDF7, 0xBDD7, 0xBDD7, 0xBDD7, 0xBDF7, 0xC618, 0xBDF7, 0xBDF7, 0xB5B6, 0xAD75, 0xB5B6, 0xB5B6,   // 0x1D30 (7472)
0xA514, 0x9CD3, 0x9CD3, 0x9CF3, 0x94B2, 0x9CF3, 0x9CF3, 0x94B2, 0x9492, 0x94B2, 0x8430, 0x738E, 0x632C, 0x632C, 0x6B6D, 0x73AE,   // 0x1D40 (7488)
0x738E, 0x630C, 0x52AA, 0x4A69, 0x3186, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1D50 (7504)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x1D60 (7520)
0x0841, 0x0861, 0x0841, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3,   // 0x1D70 (7536)
0x18E3, 0x2104, 0x2124, 0x2965, 0x3186, 0x39C7, 0x4228, 0x52AA, 0x6B4D, 0x738E, 0x7BEF, 0x8C71, 0x9CD3, 0x9CF3, 0xA514, 0xAD55,   // 0x1D80 (7552)
0xB596, 0xAD75, 0xB5B6, 0xBDD7, 0xB5B6, 0xB5B6, 0xB5B6, 0xBDD7, 0xB5B6, 0xB5B6, 0xB5B6, 0xB596, 0xB596, 0xA534, 0xA534, 0x9CD3,   // 0x1D90 (7568)
0x9CF3, 0xA514, 0x9CF3, 0x9492, 0x94B2, 0x8C71, 0x8410, 0x8410, 0x8410, 0x73AE, 0x630C, 0x632C, 0x632C, 0x632C, 0x6B4D, 0x630C,   // 0x1DA0 (7584)
0x52AA, 0x4A69, 0x31A6, 0x0861, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1DB0 (7600)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x1DC0 (7616)
0x0841, 0x0841, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18E3,   // 0x1DD0 (7632)
0x2104, 0x2124, 0x2945, 0x2965, 0x31A6, 0x39E7, 0x4A49, 0x5ACB, 0x632C, 0x73AE, 0x8410, 0x9492, 0x9CD3, 0x9CD3, 0x9CF3, 0xA534,   // 0x1DE0 (7648)
0xAD55, 0xB596, 0xAD75, 0xB596, 0xB596, 0xB596, 0xB596, 0xAD75, 0xAD75, 0xAD75, 0xAD75, 0xAD55, 0xA534, 0xAD75, 0xAD55, 0xA534,   // 0x1DF0 (7664)
0x9CF3, 0x9492, 0x8C71, 0x94B2, 0x7BEF, 0x73AE, 0x73AE, 0x6B6D, 0x632C, 0x632C, 0x6B4D, 0x632C, 0x630C, 0x5AEB, 0x52AA, 0x4A69,   // 0x1E00 (7680)
0x39E7, 0x1082, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1E10 (7696)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841,   // 0x1E20 (7712)
0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18E3,   // 0x1E30 (7728)
0x18E3, 0x2104, 0x2945, 0x3186, 0x39C7, 0x4208, 0x4A69, 0x5AEB, 0x6B6D, 0x7BCF, 0x8430, 0x9492, 0x9CF3, 0xA514, 0xA514, 0xA514,   // 0x1E40 (7744)
0xA534, 0xAD55, 0xAD75, 0xAD75, 0xAD55, 0xAD75, 0xB5B6, 0xB596, 0xAD75, 0xAD55, 0xAD55, 0xAD55, 0xAD75, 0xAD55, 0xA514, 0x9CD3,   // 0x1E50 (7760)
0x9CD3, 0x9492, 0x8410, 0x6B6D, 0x6B6D, 0x738E, 0x6B4D, 0x632C, 0x6B4D, 0x632C, 0x5AEB, 0x5ACB, 0x528A, 0x4A69, 0x39C7, 0x10A2,   // 0x1E60 (7776)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1E70 (7792)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x1E80 (7808)
0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18E3,   // 0x1E90 (7824)
0x18E3, 0x2124, 0x2965, 0x3186, 0x39C7, 0x4228, 0x528A, 0x5AEB, 0x6B6D, 0x73AE, 0x7BEF, 0x8C71, 0x9CD3, 0x9CF3, 0xAD55, 0xAD55,   // 0x1EA0 (7840)
0xA534, 0xAD55, 0xA534, 0xAD55, 0xAD75, 0xB5B6, 0xB5B6, 0xAD75, 0xAD55, 0xA534, 0xAD55, 0xAD55, 0xA534, 0xA534, 0xA514, 0x9CD3,   // 0x1EB0 (7856)
0x8C71, 0x7BCF, 0x738E, 0x73AE, 0x7BEF, 0x6B6D, 0x6B4D, 0x5ACB, 0x52AA, 0x52AA, 0x528A, 0x4A69, 0x39C7, 0x10A2, 0x0000, 0x0000,   // 0x1EC0 (7872)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1ED0 (7888)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x1EE0 (7904)
0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18E3,   // 0x1EF0 (7920)
0x18E3, 0x2124, 0x2965, 0x3186, 0x39E7, 0x4228, 0x528A, 0x5AEB, 0x6B4D, 0x73AE, 0x8410, 0x8430, 0x9492, 0x9CF3, 0xA514, 0xA534,   // 0x1F00 (7936)
0xA534, 0xA534, 0xAD55, 0xAD55, 0xAD55, 0xAD55, 0xA534, 0xAD55, 0xA534, 0x9CF3, 0xA534, 0xA534, 0x9CF3, 0x9CD3, 0x94B2, 0x8430,   // 0x1F10 (7952)
0x7BEF, 0x8410, 0x8410, 0x7BEF, 0x6B6D, 0x630C, 0x528A, 0x528A, 0x4A69, 0x4A49, 0x3186, 0x1082, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1F20 (7968)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1F30 (7984)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x1F40 (8000)
0x0841, 0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x18E3,   // 0x1F50 (8016)
0x2104, 0x2124, 0x2965, 0x3186, 0x39E7, 0x4A49, 0x52AA, 0x632C, 0x6B4D, 0x73AE, 0x8410, 0x8C51, 0x94B2, 0x9CD3, 0x9CD3, 0x9CF3,   // 0x1F60 (8032)
0xA534, 0xA534, 0xA534, 0xA534, 0xA514, 0x9CF3, 0xA514, 0x9CF3, 0x9CF3, 0xAD55, 0xA514, 0x9CD3, 0x9CD3, 0x8C51, 0x7BEF, 0x7BEF,   // 0x1F70 (8048)
0x73AE, 0x73AE, 0x6B4D, 0x5AEB, 0x52AA, 0x528A, 0x4A49, 0x4228, 0x2965, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1F80 (8064)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1F90 (8080)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1FA0 (8096)
0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18E3, 0x18E3,   // 0x1FB0 (8112)
0x2104, 0x2124, 0x2965, 0x31A6, 0x4208, 0x4A69, 0x5ACB, 0x632C, 0x6B6D, 0x7BCF, 0x8410, 0x8C51, 0x94B2, 0x9492, 0x94B2, 0x9CD3,   // 0x1FC0 (8128)
0x9CD3, 0x9CD3, 0x9CF3, 0x9CF3, 0x9CD3, 0x94B2, 0x9CD3, 0x9CF3, 0xA514, 0x9CD3, 0x9CD3, 0x9492, 0x8430, 0x7BCF, 0x73AE, 0x6B6D,   // 0x1FD0 (8144)
0x6B4D, 0x5AEB, 0x52AA, 0x528A, 0x4A49, 0x39E7, 0x2104, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1FE0 (8160)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1FF0 (8176)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2000 (8192)
0x0020, 0x0861, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18E3,   // 0x2010 (8208)
0x2104, 0x2945, 0x2965, 0x31A6, 0x4208, 0x4A69, 0x5ACB, 0x630C, 0x6B4D, 0x73AE, 0x8410, 0x8430, 0x8C51, 0x8C71, 0x8C71, 0x8C71,   // 0x2020 (8224)
0x8C71, 0x8C71, 0x94B2, 0x9CD3, 0x94B2, 0x9CF3, 0xA534, 0x9CD3, 0x9492, 0x8C71, 0x8430, 0x7BEF, 0x73AE, 0x6B6D, 0x632C, 0x5ACB,   // 0x2030 (8240)
0x528A, 0x528A, 0x4A49, 0x31A6, 0x10A2, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2040 (8256)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2050 (8272)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2060 (8288)
0x0000, 0x0841, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x10A2, 0x10A2, 0x18C3, 0x18E3,   // 0x2070 (8304)
0x2104, 0x2945, 0x2965, 0x31A6, 0x39E7, 0x4A69, 0x5ACB, 0x630C, 0x6B4D, 0x73AE, 0x7BCF, 0x8410, 0x8C51, 0x8C71, 0x8C71, 0x8C51,   // 0x2080 (8320)
0x8C51, 0x8C51, 0x9492, 0x9492, 0x9492, 0x9492, 0x8C71, 0x8C51, 0x8410, 0x73AE, 0x73AE, 0x6B6D, 0x632C, 0x5AEB, 0x52AA, 0x4A69,   // 0x2090 (8336)
0x39E7, 0x2104, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x20A0 (8352)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x20B0 (8368)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x20C0 (8384)
0x0000, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18E3,   // 0x20D0 (8400)
0x2104, 0x2945, 0x2965, 0x31A6, 0x39E7, 0x4A49, 0x52AA, 0x630C, 0x6B4D, 0x738E, 0x73AE, 0x7BCF, 0x8410, 0x8410, 0x8430, 0x8C51,   // 0x20E0 (8416)
0x8C51, 0x8C51, 0x8430, 0x8430, 0x8C51, 0x8430, 0x7BEF, 0x73AE, 0x6B4D, 0x632C, 0x630C, 0x5AEB, 0x52AA, 0x4208, 0x2945, 0x0861,   // 0x20F0 (8432)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2100 (8448)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2110 (8464)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2120 (8480)
0x0000, 0x0000, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3,   // 0x2130 (8496)
0x2104, 0x2124, 0x2965, 0x3186, 0x39E7, 0x4228, 0x4A69, 0x5ACB, 0x630C, 0x632C, 0x6B4D, 0x6B6D, 0x6B6D, 0x738E, 0x738E, 0x73AE,   // 0x2140 (8512)
0x7BCF, 0x7BCF, 0x738E, 0x73AE, 0x738E, 0x6B4D, 0x632C, 0x630C, 0x5AEB, 0x528A, 0x4228, 0x3186, 0x1082, 0x0000, 0x0000, 0x0000,   // 0x2150 (8528)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2160 (8544)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2170 (8560)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2180 (8576)
0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x18C3,   // 0x2190 (8592)
0x18E3, 0x2104, 0x2124, 0x2965, 0x31A6, 0x39C7, 0x4208, 0x4A49, 0x528A, 0x5ACB, 0x5ACB, 0x5AEB, 0x5AEB, 0x5AEB, 0x632C, 0x6B4D,   // 0x21A0 (8608)
0x632C, 0x630C, 0x630C, 0x5AEB, 0x5AEB, 0x5ACB, 0x528A, 0x4228, 0x2945, 0x1082, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x21B0 (8624)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x21C0 (8640)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x21D0 (8656)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x21E0 (8672)
0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2,   // 0x21F0 (8688)
0x18C3, 0x18E3, 0x2104, 0x2965, 0x3186, 0x31A6, 0x39E7, 0x4208, 0x4228, 0x4A49, 0x4A69, 0x528A, 0x52AA, 0x52AA, 0x52AA, 0x5ACB,   // 0x2200 (8704)
0x52AA, 0x52AA, 0x4A69, 0x4228, 0x39C7, 0x2104, 0x0861, 0x0000, 0x0000, 0x0000, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2210 (8720)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2220 (8736)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2230 (8752)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2240 (8768)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2,   // 0x2250 (8784)
0x18C3, 0x18C3, 0x2104, 0x2945, 0x2965, 0x31A6, 0x39C7, 0x39C7, 0x39E7, 0x4228, 0x4228, 0x4A49, 0x4228, 0x4228, 0x4228, 0x39E7,   // 0x2260 (8800)
0x3186, 0x18E3, 0x1082, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2270 (8816)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2280 (8832)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2290 (8848)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22A0 (8864)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0841, 0x0861, 0x0861, 0x1082,   // 0x22B0 (8880)
0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x2124, 0x2945, 0x2965, 0x3186, 0x31A6, 0x3186, 0x2945, 0x2124, 0x18E3, 0x1082, 0x0841, 0x0000,   // 0x22C0 (8896)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22D0 (8912)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22E0 (8928)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22F0 (8944)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2300 (8960)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020,   // 0x2310 (8976)
0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2320 (8992)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2330 (9008)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2340 (9024)
0x0000, };
Moon.c
// Generated by  : ImageConverter 565 v2.3
// Generated from: FullMoon.jpg
// Time generated: 17/06/2022 8:17:54 AM
// Dimensions    : 95x95 pixels
// Size          : 18,050 Bytes
#include <avr/pgmspace.h>
const unsigned int Moon[0x2341] PROGMEM ={
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0010 (16)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0020 (32)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0861, 0x1082, 0x10A2, 0x18C3, 0x18E3,   // 0x0030 (48)
0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0040 (64)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0050 (80)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0060 (96)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0070 (112)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0080 (128)
0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x10A2, 0x18E3, 0x2945, 0x3186, 0x39C7, 0x4208, 0x4A49, 0x4A69, 0x52AA, 0x5ACB, 0x5ACB,   // 0x0090 (144)
0x5ACB, 0x630C, 0x632C, 0x5AEB, 0x52AA, 0x4A69, 0x4208, 0x31A6, 0x18E3, 0x0861, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00A0 (160)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00B0 (176)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00C0 (192)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00D0 (208)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00E0 (224)
0x0861, 0x2104, 0x3186, 0x39E7, 0x4A49, 0x4A69, 0x528A, 0x52AA, 0x5ACB, 0x5ACB, 0x5AEB, 0x630C, 0x632C, 0x632C, 0x6B4D, 0x6B4D,   // 0x00F0 (240)
0x6B6D, 0x738E, 0x7BCF, 0x7BEF, 0x8410, 0x8410, 0x7BEF, 0x738E, 0x632C, 0x528A, 0x31A6, 0x18E3, 0x0020, 0x0000, 0x0000, 0x0000,   // 0x0100 (256)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0110 (272)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0120 (288)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0130 (304)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x1082, 0x2124, 0x39C7, 0x4A49,   // 0x0140 (320)
0x4A69, 0x4A69, 0x528A, 0x52AA, 0x5ACB, 0x5ACB, 0x5AEB, 0x630C, 0x632C, 0x6B4D, 0x6B4D, 0x6B4D, 0x738E, 0x73AE, 0x738E, 0x632C,   // 0x0150 (336)
0x632C, 0x6B6D, 0x738E, 0x73AE, 0x7BCF, 0x7BEF, 0x8410, 0x8430, 0x8410, 0x7BEF, 0x73AE, 0x5AEB, 0x4208, 0x18C3, 0x0000, 0x0000,   // 0x0160 (352)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0170 (368)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0180 (384)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0190 (400)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0861, 0x2124, 0x39E7, 0x4228, 0x528A, 0x5AEB, 0x5AEB, 0x5ACB,   // 0x01A0 (416)
0x5AEB, 0x630C, 0x632C, 0x632C, 0x632C, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B6D, 0x6B6D, 0x6B4D, 0x73AE, 0x7BCF, 0x8410, 0x7BEF, 0x738E,   // 0x01B0 (432)
0x738E, 0x73AE, 0x7BEF, 0x8410, 0x7BCF, 0x7BCF, 0x8410, 0x8430, 0x8410, 0x7BEF, 0x8410, 0x7BEF, 0x6B6D, 0x4A69, 0x2104, 0x0020,   // 0x01C0 (448)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x01D0 (464)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x01E0 (480)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x01F0 (496)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x2124, 0x4228, 0x5ACB, 0x5AEB, 0x52AA, 0x5ACB, 0x5AEB, 0x5ACB, 0x630C, 0x6B4D,   // 0x0200 (512)
0x6B4D, 0x6B4D, 0x6B6D, 0x6B6D, 0x6B6D, 0x738E, 0x738E, 0x73AE, 0x738E, 0x738E, 0x73AE, 0x8430, 0x9CD3, 0x9CF3, 0x94B2, 0x8C71,   // 0x0210 (528)
0x8C71, 0x94B2, 0x94B2, 0x8430, 0x7BEF, 0x7BCF, 0x7BEF, 0x8410, 0x8410, 0x7BEF, 0x7BEF, 0x8410, 0x8410, 0x73AE, 0x528A, 0x2945,   // 0x0220 (544)
0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0230 (560)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0240 (576)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0250 (592)
0x0000, 0x0000, 0x0020, 0x2104, 0x4228, 0x52AA, 0x52AA, 0x5AEB, 0x5AEB, 0x5AEB, 0x630C, 0x630C, 0x630C, 0x6B4D, 0x738E, 0x6B6D,   // 0x0260 (608)
0x6B6D, 0x738E, 0x73AE, 0x7BCF, 0x7BEF, 0x7BEF, 0x7BEF, 0x7BEF, 0x8C71, 0x94B2, 0x9CD3, 0x9CD3, 0xA534, 0xA514, 0xA534, 0xAD55,   // 0x0270 (624)
0xA534, 0xA514, 0x9CF3, 0x9CD3, 0x8C71, 0x8430, 0x8430, 0x8C51, 0x8430, 0x8410, 0x8410, 0x8430, 0x8410, 0x8410, 0x7BCF, 0x528A,   // 0x0280 (640)
0x2104, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0290 (656)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x02A0 (672)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x02B0 (688)
0x18E3, 0x4208, 0x52AA, 0x630C, 0x5ACB, 0x5ACB, 0x5AEB, 0x5AEB, 0x632C, 0x632C, 0x632C, 0x6B4D, 0x738E, 0x7BEF, 0x7BCF, 0x7BEF,   // 0x02C0 (704)
0x7BCF, 0x7BEF, 0x8410, 0x8410, 0x8410, 0x8C71, 0x9CD3, 0x9CD3, 0xA514, 0xA514, 0xA514, 0x9CF3, 0xA514, 0xAD75, 0xB596, 0xA534,   // 0x02D0 (720)
0xAD55, 0xAD75, 0xAD55, 0xA514, 0x9CF3, 0x9CD3, 0x94B2, 0x8C51, 0x8410, 0x8410, 0x8410, 0x8C51, 0x8430, 0x8410, 0x8410, 0x73AE,   // 0x02E0 (736)
0x4A69, 0x1082, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x02F0 (752)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0300 (768)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x2945, 0x4228,   // 0x0310 (784)
0x528A, 0x52AA, 0x5AEB, 0x5AEB, 0x632C, 0x632C, 0x6B4D, 0x6B4D, 0x6B6D, 0x738E, 0x7BCF, 0x7BEF, 0x8410, 0x8430, 0x8430, 0x8C51,   // 0x0320 (800)
0x8C51, 0x8430, 0x8430, 0x8C51, 0x94B2, 0x9CD3, 0x9CD3, 0xA514, 0xA534, 0xA514, 0xAD55, 0xAD75, 0xAD55, 0x94B2, 0x8430, 0x94B2,   // 0x0330 (816)
0xA514, 0xA514, 0xA514, 0xA514, 0xA514, 0x9CD3, 0x9492, 0x8C71, 0x8410, 0x7BCF, 0x7BEF, 0x8430, 0x8430, 0x8430, 0x8430, 0x8410,   // 0x0340 (832)
0x6B4D, 0x2965, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0350 (848)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0360 (864)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x18E3, 0x4208, 0x4A69, 0x528A, 0x528A,   // 0x0370 (880)
0x632C, 0x6B6D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B4D, 0x6B6D, 0x73AE, 0x7BCF, 0x7BEF, 0x8410, 0x8410, 0x8430, 0x9492, 0x8C71, 0x8C71,   // 0x0380 (896)
0x8C71, 0x8C51, 0x8C51, 0x8C71, 0x94B2, 0xA514, 0x9CF3, 0xAD55, 0x9CF3, 0x9CF3, 0xA534, 0x9492, 0x8410, 0x8410, 0x8C51, 0x8C71,   // 0x0390 (912)
0x9492, 0xA514, 0xA534, 0xA534, 0xA514, 0x9CF3, 0x94B2, 0x8C71, 0x8410, 0x7BEF, 0x7BEF, 0x8410, 0x7BEF, 0x8430, 0x8410, 0x8430,   // 0x03A0 (928)
0x7BEF, 0x4A69, 0x1082, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x03B0 (944)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x03C0 (960)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x2945, 0x4A69, 0x5ACB, 0x528A, 0x5ACB, 0x630C, 0x630C,   // 0x03D0 (976)
0x632C, 0x632C, 0x6B4D, 0x6B6D, 0x738E, 0x7BCF, 0x7BEF, 0x8410, 0x8430, 0x9492, 0x9CF3, 0x9CD3, 0x9CD3, 0x9CD3, 0x9492, 0x8C71,   // 0x03E0 (992)
0x8C71, 0x8C51, 0x8C71, 0x94B2, 0x9CD3, 0x9492, 0x9492, 0x8C51, 0x8430, 0x8C71, 0x8C51, 0x8410, 0x8430, 0x8C71, 0x8C51, 0x8C51,   // 0x03F0 (1008)
0xA514, 0xA534, 0xA514, 0x9CF3, 0xA514, 0x9CF3, 0x9CF3, 0x9492, 0x8410, 0x8410, 0x8410, 0x7BEF, 0x8430, 0x8430, 0x8430, 0x8C51,   // 0x0400 (1024)
0x8430, 0x630C, 0x18E3, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0410 (1040)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0420 (1056)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x39C7, 0x5ACB, 0x528A, 0x528A, 0x5ACB, 0x630C, 0x630C, 0x630C, 0x632C,   // 0x0430 (1072)
0x6B4D, 0x738E, 0x738E, 0x7BCF, 0x8430, 0x8C51, 0x9CD3, 0xA534, 0xAD75, 0xB5B6, 0x9CF3, 0x94B2, 0x94B2, 0x9492, 0x9492, 0x94B2,   // 0x0440 (1088)
0x94B2, 0x9492, 0x8C51, 0x8430, 0x8430, 0x8430, 0x8430, 0x8C51, 0x8C51, 0x8430, 0x7BEF, 0x8410, 0x8C51, 0x8430, 0x8410, 0x8430,   // 0x0450 (1104)
0x8430, 0x8C51, 0x94B2, 0x9CD3, 0x94B2, 0xA514, 0xAD75, 0x9CD3, 0x8C71, 0x8430, 0x7BEF, 0x8410, 0x8C51, 0x8C51, 0x8C51, 0x8C51,   // 0x0460 (1120)
0x8430, 0x6B4D, 0x2965, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0470 (1136)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0480 (1152)
0x0000, 0x0000, 0x0000, 0x0000, 0x1082, 0x4228, 0x5AEB, 0x5AEB, 0x5ACB, 0x5ACB, 0x630C, 0x632C, 0x632C, 0x6B4D, 0x6B6D, 0x738E,   // 0x0490 (1168)
0x7BCF, 0x7BEF, 0x7BEF, 0x8C51, 0x9CD3, 0xAD55, 0xCE59, 0xC618, 0x9CF3, 0x9CF3, 0x9CD3, 0x94B2, 0x9CD3, 0x9492, 0x8C71, 0x94B2,   // 0x04A0 (1184)
0x9492, 0x8C51, 0x8430, 0x8C71, 0x8C71, 0x8C71, 0x8C51, 0x8C51, 0x8430, 0x8410, 0x7BEF, 0x8410, 0x8410, 0x7BEF, 0x7BCF, 0x7BEF,   // 0x04B0 (1200)
0x8430, 0x8C71, 0x9492, 0x8430, 0x8C71, 0xAD55, 0xB596, 0xA534, 0x9CF3, 0x8C71, 0x8410, 0x7BEF, 0x8410, 0x8C51, 0x8C51, 0x8430,   // 0x04C0 (1216)
0x7BEF, 0x6B6D, 0x3186, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x04D0 (1232)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x04E0 (1248)
0x0000, 0x0000, 0x1082, 0x4A69, 0x632C, 0x630C, 0x632C, 0x630C, 0x630C, 0x6B4D, 0x6B6D, 0x6B6D, 0x738E, 0x73AE, 0x7BCF, 0x7BEF,   // 0x04F0 (1264)
0x8410, 0x8410, 0x8C51, 0x9492, 0x9CD3, 0xA534, 0xAD55, 0xA534, 0x9CF3, 0xA514, 0xA514, 0x9CD3, 0x8C71, 0x8C71, 0x8C71, 0x94B2,   // 0x0500 (1280)
0x9492, 0x8C71, 0x9492, 0x94B2, 0x9492, 0x8C71, 0x8C51, 0x8430, 0x8410, 0x8410, 0x8410, 0x8430, 0x8410, 0x7BEF, 0x8410, 0x8C51,   // 0x0510 (1296)
0x8C71, 0x8430, 0x8C51, 0x9CD3, 0x9CF3, 0xA534, 0x94B2, 0xA514, 0xA534, 0x9492, 0x7BCF, 0x7BCF, 0x8410, 0x8430, 0x8430, 0x8410,   // 0x0520 (1312)
0x7BCF, 0x6B6D, 0x39C7, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0530 (1328)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0540 (1344)
0x18C3, 0x5ACB, 0x738E, 0x73AE, 0x738E, 0x6B4D, 0x632C, 0x6B4D, 0x6B6D, 0x6B6D, 0x6B6D, 0x738E, 0x73AE, 0x7BEF, 0x7BEF, 0x8410,   // 0x0550 (1360)
0x8430, 0x8C51, 0x8C71, 0x94B2, 0x94B2, 0x9CF3, 0x9CD3, 0x9CD3, 0x9CF3, 0x94B2, 0x8C71, 0x8C71, 0x9492, 0x9CD3, 0x9CF3, 0x94B2,   // 0x0560 (1376)
0x8C71, 0x9492, 0x8C71, 0x8C51, 0x8C51, 0x8C51, 0x8C51, 0x8430, 0x8410, 0x8410, 0x8410, 0x8430, 0x8430, 0x8430, 0x8C71, 0x9492,   // 0x0570 (1392)
0x8C71, 0x9492, 0xA514, 0x9CF3, 0x9CF3, 0x8C51, 0x9492, 0xA514, 0xA514, 0x9492, 0x8430, 0x8410, 0x8C51, 0x8C51, 0x8430, 0x7BEF,   // 0x0580 (1408)
0x7BCF, 0x6B6D, 0x39C7, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0590 (1424)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x10A2, 0x5ACB,   // 0x05A0 (1440)
0x7BCF, 0x7BCF, 0x7BEF, 0x738E, 0x632C, 0x632C, 0x6B4D, 0x738E, 0x738E, 0x738E, 0x738E, 0x73AE, 0x7BEF, 0x7BEF, 0x8410, 0x8430,   // 0x05B0 (1456)
0x8430, 0x8C51, 0x9492, 0x94B2, 0x9CD3, 0x94B2, 0x8C71, 0x8C71, 0x8C51, 0x9492, 0x9492, 0x8C71, 0x94B2, 0x9CD3, 0x94B2, 0x9492,   // 0x05C0 (1472)
0x8C51, 0x8C71, 0x8C51, 0x8430, 0x8C51, 0x8C51, 0x8430, 0x8410, 0x8410, 0x8430, 0x8430, 0x8C51, 0x8430, 0x8C51, 0x8C71, 0x8C71,   // 0x05D0 (1488)
0x9492, 0x9CD3, 0x9CD3, 0x94B2, 0x9CF3, 0xA534, 0xA534, 0xA534, 0xA534, 0x94B2, 0x8C51, 0x8C51, 0x8C71, 0x8C51, 0x8410, 0x7BEF,   // 0x05E0 (1504)
0x7BCF, 0x6B4D, 0x3186, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x05F0 (1520)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1082, 0x528A, 0x738E, 0x7BCF,   // 0x0600 (1536)
0x8410, 0x7BCF, 0x738E, 0x6B4D, 0x6B6D, 0x738E, 0x738E, 0x73AE, 0x7BCF, 0x7BCF, 0x7BEF, 0x7BCF, 0x7BEF, 0x8430, 0x8C71, 0x8C51,   // 0x0610 (1552)
0x8430, 0x8C51, 0x94B2, 0xA514, 0x94B2, 0x8C71, 0x9492, 0x8C51, 0x8C51, 0x8C51, 0x8C51, 0x8430, 0x8C71, 0x9492, 0x8C51, 0x9492,   // 0x0620 (1568)
0x8C71, 0x8C51, 0x8430, 0x8430, 0x8C51, 0x8430, 0x8430, 0x8430, 0x8C71, 0x8C71, 0x8C51, 0x8C51, 0x8C71, 0x9492, 0x94B2, 0x94B2,   // 0x0630 (1584)
0x9492, 0x9CD3, 0x94B2, 0x9492, 0xA534, 0xAD55, 0xAD75, 0xB5B6, 0xA514, 0x8C51, 0x8430, 0x8C51, 0x8430, 0x8410, 0x8430, 0x7BEF,   // 0x0640 (1600)
0x738E, 0x632C, 0x2945, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0650 (1616)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0861, 0x4228, 0x738E, 0x7BEF, 0x8430, 0x8C71,   // 0x0660 (1632)
0x7BCF, 0x6B6D, 0x738E, 0x7BEF, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x8410, 0x8430, 0x7BEF, 0x8430, 0x8C51, 0x8C51, 0x8C51, 0x8C71,   // 0x0670 (1648)
0x94B2, 0x9CD3, 0xA514, 0x94B2, 0x8C71, 0x9CD3, 0x9492, 0x8C71, 0x8C51, 0x8C71, 0x8C51, 0x8C71, 0x8C71, 0x8C51, 0x9492, 0x9492,   // 0x0680 (1664)
0x9492, 0x8C51, 0x8C51, 0x8430, 0x8430, 0x8C51, 0x8430, 0x8C71, 0x9492, 0x8C51, 0x8C71, 0x94B2, 0x94B2, 0x94B2, 0x9492, 0x9492,   // 0x0690 (1680)
0x94B2, 0x9492, 0x9492, 0x9CF3, 0xB5B6, 0xB5B6, 0xBDD7, 0xA534, 0x9492, 0x8C71, 0x8C71, 0x8C71, 0x8410, 0x8430, 0x7BEF, 0x73AE,   // 0x06A0 (1696)
0x73AE, 0x630C, 0x18E3, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x06B0 (1712)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x31A6, 0x6B6D, 0x7BEF, 0x8C71, 0x9492, 0x8C71, 0x7BEF,   // 0x06C0 (1728)
0x738E, 0x7BCF, 0x8C51, 0x8410, 0x8410, 0x7BEF, 0x7BCF, 0x7BEF, 0x8410, 0x8410, 0x8C51, 0x8C71, 0x8C51, 0x8C51, 0x9492, 0x9CD3,   // 0x06D0 (1744)
0xA514, 0x9CD3, 0x94B2, 0x9492, 0x8C71, 0x9492, 0x94B2, 0x9492, 0x8C71, 0x9492, 0x94B2, 0x8C51, 0x8C51, 0x9492, 0x9CD3, 0x94B2,   // 0x06E0 (1760)
0x9492, 0x8C71, 0x8C71, 0x8C71, 0x8C51, 0x8C51, 0x8C71, 0x8C71, 0x8C71, 0x9492, 0x94B2, 0x9CD3, 0x9492, 0x8C71, 0x9492, 0x9492,   // 0x06F0 (1776)
0x9492, 0x94B2, 0x94B2, 0xAD55, 0xBDD7, 0xB5B6, 0xB596, 0xAD55, 0x9CD3, 0x9492, 0x8C71, 0x8430, 0x8410, 0x8410, 0x7BEF, 0x738E,   // 0x0700 (1792)
0x738E, 0x528A, 0x10A2, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0710 (1808)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x18E3, 0x632C, 0x7BEF, 0x8430, 0x9492, 0x9492, 0x8410, 0x73AE, 0x73AE,   // 0x0720 (1824)
0x73AE, 0x7BEF, 0x8410, 0x8410, 0x8410, 0x7BEF, 0x7BEF, 0x7BEF, 0x8410, 0x8430, 0x8C71, 0x8C51, 0x8C71, 0x94B2, 0x9CD3, 0xA514,   // 0x0730 (1840)
0xA534, 0x9492, 0x8C71, 0x8C71, 0x8C71, 0x9492, 0x9CD3, 0x9CD3, 0xAD55, 0xA534, 0x8C51, 0x8C51, 0x94B2, 0x9492, 0x9492, 0x9492,   // 0x0740 (1856)
0x8C71, 0x9492, 0x8C71, 0x8C71, 0x8C71, 0x9492, 0x8C71, 0x9492, 0x9492, 0x94B2, 0x9CD3, 0x9492, 0x9492, 0x9492, 0x9492, 0x9CD3,   // 0x0750 (1872)
0x9CD3, 0x9CD3, 0xA534, 0xB5B6, 0xB596, 0xB5B6, 0xB596, 0x9CF3, 0x94B2, 0x8C71, 0x8430, 0x8430, 0x8410, 0x7BEF, 0x7BCF, 0x738E,   // 0x0760 (1888)
0x6B6D, 0x4228, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0770 (1904)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1082, 0x528A, 0x7BCF, 0x8430, 0x8C71, 0x8C71, 0x7BEF, 0x7BCF, 0x73AE, 0x738E, 0x73AE,   // 0x0780 (1920)
0x7BCF, 0x7BEF, 0x8410, 0x8430, 0x8410, 0x7BEF, 0x7BEF, 0x7BEF, 0x7BEF, 0x8430, 0x9492, 0x94B2, 0x9CD3, 0x9CD3, 0xAD55, 0xA534,   // 0x0790 (1936)
0x8C51, 0x8C51, 0x9492, 0x9492, 0x94B2, 0x9CF3, 0xA534, 0xA534, 0x9CF3, 0x8C51, 0x9492, 0x94B2, 0x9492, 0x9492, 0x9492, 0x9492,   // 0x07A0 (1952)
0x8430, 0x8C71, 0x94B2, 0x9492, 0x9492, 0x8C71, 0x8C71, 0x9492, 0x94B2, 0x94B2, 0x9492, 0x94B2, 0x9CF3, 0x9CD3, 0x9CF3, 0x9CF3,   // 0x07B0 (1968)
0x9CD3, 0xAD55, 0xB596, 0xB5B6, 0xBDD7, 0xB596, 0xA514, 0xA514, 0x94B2, 0x8C51, 0x8430, 0x7BEF, 0x7BCF, 0x7BEF, 0x7BCF, 0x738E,   // 0x07C0 (1984)
0x6B4D, 0x31A6, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x07D0 (2000)
0x0000, 0x0000, 0x0000, 0x0020, 0x4208, 0x630C, 0x7BEF, 0x9492, 0x8C71, 0x8410, 0x738E, 0x73AE, 0x738E, 0x738E, 0x73AE, 0x7BCF,   // 0x07E0 (2016)
0x7BEF, 0x8410, 0x8410, 0x8430, 0x8410, 0x7BEF, 0x7BEF, 0x8C51, 0x8C71, 0x9492, 0x9CD3, 0xA514, 0x9CD3, 0xA514, 0x8C71, 0x8C71,   // 0x07F0 (2032)
0x8C71, 0x8C71, 0x9CD3, 0x9CF3, 0x94B2, 0x9CD3, 0x9CD3, 0x9CD3, 0x94B2, 0x9CD3, 0x9CD3, 0x9CD3, 0x94B2, 0x9492, 0x8C71, 0x8C51,   // 0x0800 (2048)
0x94B2, 0x94B2, 0x8C71, 0x8C71, 0x9492, 0x94B2, 0x94B2, 0x94B2, 0x9492, 0x9492, 0x9CD3, 0xA514, 0xA534, 0xA514, 0xA534, 0xA534,   // 0x0810 (2064)
0xAD75, 0xBDD7, 0xBDD7, 0xBDF7, 0xB596, 0xA514, 0x9CF3, 0x9CD3, 0x94B2, 0x8C51, 0x8410, 0x7BCF, 0x73AE, 0x7BCF, 0x7BCF, 0x738E,   // 0x0820 (2080)
0x630C, 0x18E3, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0830 (2096)
0x0000, 0x0000, 0x2945, 0x630C, 0x7BCF, 0x8C51, 0x8C71, 0x8410, 0x7BCF, 0x73AE, 0x738E, 0x738E, 0x73AE, 0x73AE, 0x7BCF, 0x8410,   // 0x0840 (2112)
0x8410, 0x7BEF, 0x8410, 0x8430, 0x8C51, 0x8C71, 0x9492, 0x9CD3, 0xA514, 0xAD75, 0xAD75, 0xA534, 0xA534, 0x9492, 0x9492, 0xA534,   // 0x0850 (2128)
0x9CF3, 0xA514, 0xA534, 0x9CD3, 0x9CD3, 0x9CF3, 0x9CD3, 0x9CF3, 0x94B2, 0x94B2, 0x9492, 0x94B2, 0x94B2, 0x8C51, 0x94B2, 0x9CD3,   // 0x0860 (2144)
0x9492, 0x9492, 0x9492, 0x94B2, 0x94B2, 0x9492, 0x9492, 0x8C71, 0x9492, 0xA534, 0xA514, 0xA534, 0xB596, 0xB596, 0xA534, 0xAD55,   // 0x0870 (2160)
0xB596, 0xBDD7, 0xBDD7, 0xB596, 0xAD75, 0xA534, 0xA514, 0xA534, 0xA514, 0x8C51, 0x7BEF, 0x73AE, 0x738E, 0x738E, 0x73AE, 0x738E,   // 0x0880 (2176)
0x528A, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0890 (2192)
0x1082, 0x528A, 0x73AE, 0x7BEF, 0x73AE, 0x9492, 0x9492, 0x7BEF, 0x73AE, 0x73AE, 0x7BCF, 0x7BCF, 0x73AE, 0x7BEF, 0x8410, 0x8410,   // 0x08A0 (2208)
0x8430, 0x8430, 0x8410, 0x8C51, 0x9492, 0x9CF3, 0xAD75, 0xB5B6, 0xBDD7, 0xB596, 0xAD75, 0xA534, 0x94B2, 0x94B2, 0x9CF3, 0x9CD3,   // 0x08B0 (2224)
0xB596, 0xBDF7, 0xAD75, 0xAD55, 0xAD55, 0xA514, 0xA514, 0x9492, 0x9CF3, 0x9CD3, 0x9CF3, 0x94B2, 0x94B2, 0x9CD3, 0x9492, 0x9CD3,   // 0x08C0 (2240)
0xAD55, 0xA514, 0x94B2, 0x9492, 0x9492, 0x9492, 0x8C71, 0x94B2, 0x9CF3, 0xA514, 0xAD55, 0xAD55, 0xAD55, 0xAD75, 0xAD75, 0xB5B6,   // 0x08D0 (2256)
0xBDF7, 0xBDF7, 0xB5B6, 0xB596, 0xB596, 0xA534, 0xA514, 0xAD55, 0x9CD3, 0x8C51, 0x7BCF, 0x6B6D, 0x6B4D, 0x738E, 0x73AE, 0x6B6D,   // 0x08E0 (2272)
0x3186, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x39C7,   // 0x08F0 (2288)
0x738E, 0x7BCF, 0x5AEB, 0x6B6D, 0x94B2, 0x9492, 0x7BEF, 0x73AE, 0x7BCF, 0x73AE, 0x73AE, 0x7BEF, 0x8410, 0x8410, 0x7BEF, 0x7BCF,   // 0x0900 (2304)
0x7BEF, 0x8410, 0x8C51, 0x94B2, 0xA514, 0xB596, 0xC618, 0xBDF7, 0xB5B6, 0xAD75, 0x9CD3, 0x8C51, 0x8C71, 0x9CF3, 0xAD75, 0xB5B6,   // 0x0910 (2320)
0xBDD7, 0xBDD7, 0xB596, 0xAD75, 0xAD55, 0x9CF3, 0x9CD3, 0x9CF3, 0x9CF3, 0x9CD3, 0x9CD3, 0x9CF3, 0x9492, 0x8C71, 0x9CD3, 0xB596,   // 0x0920 (2336)
0xAD55, 0x9CD3, 0x9492, 0x9492, 0x94B2, 0x9CD3, 0x94B2, 0x9CD3, 0xA534, 0xAD55, 0xAD55, 0xAD55, 0xAD55, 0xAD55, 0xB5B6, 0xBDD7,   // 0x0930 (2352)
0xBDF7, 0xBDD7, 0xB5B6, 0xB5B6, 0xAD75, 0xA514, 0x9CF3, 0x9CD3, 0x8C51, 0x7BEF, 0x738E, 0x632C, 0x6B4D, 0x738E, 0x73AE, 0x5ACB,   // 0x0940 (2368)
0x1082, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x18C3, 0x630C, 0x7BCF,   // 0x0950 (2384)
0x6B4D, 0x630C, 0x94B2, 0x9CD3, 0x9492, 0x73AE, 0x738E, 0x73AE, 0x738E, 0x73AE, 0x7BEF, 0x8410, 0x7BEF, 0x7BEF, 0x7BEF, 0x7BEF,   // 0x0960 (2400)
0x7BEF, 0x8C71, 0x9CF3, 0xA534, 0xB596, 0xBDF7, 0xC618, 0xBDD7, 0xA534, 0x94B2, 0x94B2, 0x9CF3, 0xAD55, 0xBDD7, 0xBDD7, 0xB5B6,   // 0x0970 (2416)
0xB596, 0xB596, 0xB5B6, 0xAD55, 0x94B2, 0x94B2, 0x9CF3, 0x9CF3, 0x9492, 0x9CD3, 0x9CD3, 0x9492, 0x94B2, 0x9CD3, 0x9CF3, 0x9CF3,   // 0x0980 (2432)
0xA514, 0xA534, 0xA534, 0xA534, 0xAD55, 0xAD55, 0xA534, 0xA534, 0xAD75, 0xBDD7, 0xB596, 0xA514, 0xAD75, 0xB5B6, 0xB5B6, 0xBDF7,   // 0x0990 (2448)
0xBDF7, 0xBDF7, 0xBDF7, 0xBDF7, 0xB5B6, 0xA534, 0xA514, 0x94B2, 0x8C51, 0x7BCF, 0x6B6D, 0x632C, 0x6B6D, 0x73AE, 0x6B6D, 0x3186,   // 0x09A0 (2464)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x4208, 0x6B6D, 0x7BEF, 0x7BEF,   // 0x09B0 (2480)
0x8C71, 0xAD55, 0x9CD3, 0x8C71, 0x7BEF, 0x73AE, 0x73AE, 0x7BEF, 0x8430, 0x8410, 0x7BEF, 0x7BEF, 0x8410, 0x8430, 0x7BEF, 0x7BEF,   // 0x09C0 (2496)
0x9CD3, 0x9CF3, 0x9CD3, 0xB596, 0xBDF7, 0xB5B6, 0xAD75, 0xA514, 0x9CD3, 0xA514, 0xA534, 0xB596, 0xBDD7, 0xC618, 0xC618, 0xB596,   // 0x09D0 (2512)
0xB5B6, 0xBDF7, 0xB596, 0xAD55, 0xA534, 0x9CF3, 0x9CF3, 0x9CF3, 0x9CF3, 0x9CD3, 0x94B2, 0x94B2, 0x9CD3, 0x9CD3, 0x94B2, 0xA534,   // 0x09E0 (2528)
0xB5B6, 0xB5B6, 0xB596, 0xAD55, 0xAD75, 0xB596, 0xAD75, 0xB596, 0xB5B6, 0xAD75, 0xA514, 0xAD75, 0xB5B6, 0xBDF7, 0xC638, 0xC638,   // 0x09F0 (2544)
0xBDF7, 0xB5B6, 0xBDD7, 0xB5B6, 0xB596, 0xAD55, 0x9CF3, 0x94B2, 0x8C51, 0x7BEF, 0x6B4D, 0x6B6D, 0x738E, 0x73AE, 0x52AA, 0x1082,   // 0x0A00 (2560)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x18E3, 0x632C, 0x73AE, 0x8410, 0x8C51, 0xA514,   // 0x0A10 (2576)
0x9CD3, 0x9492, 0x8C51, 0x7BCF, 0x73AE, 0x7BCF, 0x8430, 0x9492, 0x8430, 0x7BEF, 0x7BEF, 0x7BEF, 0x8410, 0x7BCF, 0x8430, 0x9CD3,   // 0x0A20 (2592)
0x94B2, 0x9CD3, 0xB596, 0xAD55, 0x9CF3, 0x9CF3, 0xA514, 0x9CD3, 0x9CF3, 0xA534, 0xAD75, 0xBDD7, 0xBDF7, 0xBDF7, 0xB5B6, 0xBDD7,   // 0x0A30 (2608)
0xBDF7, 0xBDD7, 0xB5B6, 0xAD75, 0xA514, 0xA534, 0xA534, 0x9CF3, 0x9CD3, 0x9CD3, 0x9CD3, 0x9CD3, 0x9492, 0x9492, 0xA534, 0xB596,   // 0x0A40 (2624)
0xB5B6, 0xBDD7, 0xAD75, 0xAD55, 0xB596, 0xB5B6, 0xB5B6, 0xB596, 0xA534, 0xA514, 0xAD55, 0xBDD7, 0xC618, 0xC618, 0xC638, 0xBDD7,   // 0x0A50 (2640)
0xB5B6, 0xB5B6, 0xAD75, 0xAD75, 0xAD55, 0x9CF3, 0x9492, 0x9492, 0x8410, 0x73AE, 0x7BCF, 0x738E, 0x738E, 0x6B4D, 0x2965, 0x0000,   // 0x0A60 (2656)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x4228, 0x738E, 0x7BEF, 0x8430, 0x9492, 0x9CF3, 0xA514,   // 0x0A70 (2672)
0x94B2, 0x8C51, 0x7BCF, 0x73AE, 0x73AE, 0x8410, 0x8C71, 0x7BEF, 0x7BEF, 0x8410, 0x7BEF, 0x7BCF, 0x7BCF, 0x8430, 0x8C71, 0x9CD3,   // 0x0A80 (2688)
0xAD55, 0xA514, 0x8C71, 0x94B2, 0x9CD3, 0xA534, 0xAD55, 0xA514, 0x9CF3, 0xA534, 0xB5B6, 0xBDD7, 0xBDD7, 0xB5B6, 0xBDD7, 0xC618,   // 0x0A90 (2704)
0xC618, 0xBDF7, 0xB5B6, 0xB596, 0xAD75, 0xAD55, 0xA514, 0x9CF3, 0x9CF3, 0x9CD3, 0x9CD3, 0x94B2, 0x9492, 0xA514, 0xB5B6, 0xBDD7,   // 0x0AA0 (2720)
0xBDD7, 0xB596, 0xA534, 0xAD55, 0xBDD7, 0xB5B6, 0xB5B6, 0xAD55, 0xAD55, 0xAD55, 0xBDF7, 0xCE59, 0xB596, 0xAD75, 0xB596, 0xBDD7,   // 0x0AB0 (2736)
0xBDD7, 0xB596, 0xAD75, 0xA534, 0x9CD3, 0x9492, 0x8C71, 0x8430, 0x8410, 0x8410, 0x7BCF, 0x738E, 0x6B6D, 0x4A69, 0x0841, 0x0000,   // 0x0AC0 (2752)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0000, 0x10A2, 0x630C, 0x7BCF, 0x8410, 0x8C71, 0x9CD3, 0x9CF3, 0xA514, 0x94B2,   // 0x0AD0 (2768)
0x8C51, 0x8410, 0x7BCF, 0x7BCF, 0x8C51, 0x8430, 0x7BEF, 0x7BEF, 0x7BCF, 0x7BCF, 0x8410, 0x8430, 0x8410, 0x8410, 0x9492, 0x9CD3,   // 0x0AE0 (2784)
0x94B2, 0x94B2, 0xA534, 0xA534, 0xA534, 0xAD75, 0xBDD7, 0xAD75, 0xAD55, 0xB5B6, 0xBDD7, 0xC638, 0xCE59, 0xCE79, 0xCE59, 0xC618,   // 0x0AF0 (2800)
0xBDF7, 0xB5B6, 0xB596, 0xB596, 0xB596, 0xAD55, 0xA514, 0xA514, 0xA534, 0xA514, 0x9CD3, 0x94B2, 0x94B2, 0xAD75, 0xB5B6, 0xB5B6,   // 0x0B00 (2816)
0xB5B6, 0xAD75, 0xA534, 0xB5B6, 0xBDF7, 0xB596, 0xAD55, 0xAD55, 0xBDD7, 0xBDD7, 0xAD75, 0x9492, 0x9492, 0x8C71, 0xAD55, 0xBDD7,   // 0x0B10 (2832)
0xB596, 0xA534, 0x9CF3, 0x9CF3, 0x94B2, 0x9492, 0x8C51, 0x9492, 0x8430, 0x8410, 0x73AE, 0x6B6D, 0x5AEB, 0x18E3, 0x0000, 0x0000,   // 0x0B20 (2848)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x3186, 0x6B6D, 0x7BEF, 0x8430, 0x9492, 0x9CF3, 0xA534, 0xA534, 0x9492, 0x7BEF,   // 0x0B30 (2864)
0x8430, 0x7BCF, 0x73AE, 0x8410, 0x8410, 0x8430, 0x8430, 0x8430, 0x8410, 0x8C51, 0x8C51, 0x8410, 0x7BEF, 0x8430, 0x9492, 0x9CD3,   // 0x0B40 (2880)
0x94B2, 0x9CF3, 0x9CF3, 0x9CD3, 0xA514, 0xB596, 0xB596, 0xB596, 0xBDD7, 0xB5B6, 0xC618, 0xDEDB, 0xDEDB, 0xD6BA, 0xC618, 0xBDF7,   // 0x0B50 (2896)
0xBDD7, 0xB5B6, 0xB5B6, 0xBDD7, 0xAD75, 0xAD55, 0xAD55, 0xA534, 0x9CD3, 0x9492, 0x9492, 0x8C71, 0x9CD3, 0xAD75, 0xB5B6, 0xB5B6,   // 0x0B60 (2912)
0xAD55, 0x94B2, 0x9CF3, 0xB5B6, 0xAD75, 0xA534, 0xA514, 0xAD55, 0xA514, 0x9492, 0x8C71, 0x9492, 0x8C51, 0x9492, 0xB596, 0xB5B6,   // 0x0B70 (2928)
0xA534, 0x94B2, 0x94B2, 0x9CD3, 0x9CD3, 0x94B2, 0x8C71, 0x8430, 0x8430, 0x7BCF, 0x6B6D, 0x630C, 0x39C7, 0x0000, 0x0000, 0x0000,   // 0x0B80 (2944)
0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x4A69, 0x738E, 0x8410, 0x8C51, 0x8C71, 0xA514, 0xB5B6, 0xAD55, 0x8C71, 0x7BEF, 0x8C51,   // 0x0B90 (2960)
0x8C51, 0x7BEF, 0x8430, 0x8410, 0x7BEF, 0x8410, 0x8430, 0x7BEF, 0x8410, 0x8410, 0x7BEF, 0x8410, 0x8C51, 0x9492, 0x9492, 0x94B2,   // 0x0BA0 (2976)
0x9CF3, 0x9CF3, 0x94B2, 0x9CF3, 0xAD55, 0xB5B6, 0xBDD7, 0xB596, 0xB596, 0xB596, 0xC638, 0xD69A, 0xCE79, 0xBDD7, 0xB5B6, 0xBDD7,   // 0x0BB0 (2992)
0xB5B6, 0xBDD7, 0xB5B6, 0xB596, 0xAD75, 0xB596, 0xA534, 0x9CF3, 0x9CF3, 0x9CD3, 0x94B2, 0xA514, 0xB5B6, 0xBDF7, 0xBDF7, 0xAD75,   // 0x0BC0 (3008)
0xA534, 0xA514, 0xBDD7, 0xC618, 0xAD75, 0x94B2, 0x94B2, 0x94B2, 0x8C71, 0x8C51, 0x9492, 0x9492, 0x8C51, 0x9CF3, 0xB596, 0xA534,   // 0x0BD0 (3024)
0x9492, 0x9492, 0x9CF3, 0xA534, 0x9CD3, 0x8430, 0x8C51, 0x8C51, 0x7BEF, 0x738E, 0x632C, 0x528A, 0x1082, 0x0000, 0x0000, 0x0000,   // 0x0BE0 (3040)
0x0000, 0x0000, 0x0000, 0x18C3, 0x630C, 0x7BCF, 0x7BCF, 0x8430, 0x9492, 0xA534, 0xB5B6, 0xAD75, 0x9492, 0x9492, 0xA514, 0x94B2,   // 0x0BF0 (3056)
0x8410, 0x8430, 0x8C51, 0x8410, 0x8410, 0x7BEF, 0x8410, 0x8C51, 0x8410, 0x7BEF, 0x8410, 0x8C71, 0x94B2, 0x8C71, 0x8C71, 0x9CD3,   // 0x0C00 (3072)
0xA534, 0x9CF3, 0xA534, 0xAD75, 0xB596, 0xBDD7, 0xB5B6, 0xB5B6, 0xB5B6, 0xB596, 0xB5B6, 0xBDD7, 0xBDD7, 0xB5B6, 0xB5B6, 0xB5B6,   // 0x0C10 (3088)
0xBDD7, 0xB596, 0xB596, 0xA514, 0xA514, 0xAD75, 0xBDD7, 0xBDD7, 0xB596, 0xB596, 0xB5B6, 0xC618, 0xC638, 0xC638, 0xCE59, 0xC618,   // 0x0C20 (3104)
0xBDF7, 0xB5B6, 0xB596, 0xAD75, 0x9CD3, 0x94B2, 0x94B2, 0x8C51, 0x8430, 0x8C71, 0x9492, 0x8C71, 0x94B2, 0xA534, 0xA534, 0x9492,   // 0x0C30 (3120)
0x9492, 0x94B2, 0x9CD3, 0x9CD3, 0x9492, 0x8430, 0x8430, 0x7BEF, 0x73AE, 0x6B4D, 0x5AEB, 0x2124, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0C40 (3136)
0x0000, 0x0000, 0x31A6, 0x6B6D, 0x7BCF, 0x7BEF, 0x8C51, 0x9CD3, 0x9CF3, 0xAD55, 0xAD55, 0x9CF3, 0xA534, 0xAD55, 0x9492, 0x8430,   // 0x0C50 (3152)
0x8C51, 0x8430, 0x7BEF, 0x8410, 0x8410, 0x8C51, 0x9492, 0x8430, 0x8410, 0x8C51, 0x8C71, 0x9492, 0x9CD3, 0x94B2, 0x9492, 0xA514,   // 0x0C60 (3168)
0xA534, 0xA514, 0xAD75, 0xB596, 0xB596, 0xB5B6, 0xAD75, 0xB596, 0xAD55, 0xAD75, 0xB596, 0xB596, 0xB5B6, 0xB5B6, 0xB5B6, 0xB5B6,   // 0x0C70 (3184)
0xAD75, 0xAD75, 0xA534, 0x9CF3, 0x9CF3, 0xAD55, 0xBDD7, 0xB5B6, 0xBDD7, 0xBDF7, 0xBDD7, 0xC618, 0xCE59, 0xCE59, 0xBDF7, 0xC618,   // 0x0C80 (3200)
0xBDD7, 0xB596, 0x9CF3, 0x8C71, 0x94B2, 0x94B2, 0x8C71, 0x8C71, 0x8C51, 0x8C51, 0x8C71, 0x9492, 0x9CF3, 0xAD55, 0x9CF3, 0x94B2,   // 0x0C90 (3216)
0x9492, 0x9492, 0x94B2, 0x9492, 0x8430, 0x8410, 0x7BEF, 0x7BCF, 0x6B6D, 0x5AEB, 0x39E7, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0CA0 (3232)
0x0020, 0x4A69, 0x73AE, 0x7BEF, 0x8C71, 0x9CD3, 0x9CF3, 0xA514, 0xAD55, 0xAD55, 0xAD75, 0xA534, 0x9CD3, 0x8C71, 0x9492, 0x8C71,   // 0x0CB0 (3248)
0x8430, 0x7BEF, 0x8410, 0x8C51, 0x8C71, 0x8C71, 0x8410, 0x8C71, 0x9CD3, 0x94B2, 0x94B2, 0xA514, 0x9CD3, 0x9CF3, 0x9CF3, 0xAD55,   // 0x0CC0 (3264)
0x9CF3, 0xA534, 0xAD75, 0xBDD7, 0xBDF7, 0xAD75, 0xAD55, 0xAD55, 0xAD55, 0xA534, 0xA534, 0xA534, 0xB596, 0xB5B6, 0xB596, 0xAD55,   // 0x0CD0 (3280)
0xA534, 0xA534, 0x9CF3, 0x9CD3, 0xAD75, 0xB5B6, 0xB596, 0xBDF7, 0xBDF7, 0xBDD7, 0xBDF7, 0xBDF7, 0xBDF7, 0xB5B6, 0xB5B6, 0xAD75,   // 0x0CE0 (3296)
0x9CF3, 0x8C71, 0x8C51, 0x9492, 0x94B2, 0x8C71, 0x8C51, 0x8C51, 0x8430, 0x8C51, 0x8C51, 0x8C71, 0x9CD3, 0x94B2, 0x9492, 0x94B2,   // 0x0CF0 (3312)
0x9CF3, 0x9CD3, 0x8C71, 0x8C51, 0x7BEF, 0x7BEF, 0x7BEF, 0x73AE, 0x630C, 0x4A49, 0x0861, 0x0000, 0x0000, 0x0000, 0x0000, 0x1082,   // 0x0D00 (3328)
0x5ACB, 0x8410, 0x8C51, 0x94B2, 0x9CD3, 0xA514, 0xA534, 0xA534, 0xB596, 0xAD55, 0x94B2, 0x9CD3, 0x9CD3, 0x9CF3, 0x9CF3, 0x8C71,   // 0x0D10 (3344)
0x8430, 0x8C71, 0x8C71, 0x8C51, 0x8430, 0x8430, 0x8C71, 0x9CD3, 0x9492, 0x9492, 0x9492, 0x9CD3, 0xAD55, 0x9CF3, 0xA514, 0x9CF3,   // 0x0D20 (3360)
0xA534, 0xB5B6, 0xBDD7, 0xBDD7, 0xAD75, 0xAD55, 0xAD55, 0xA514, 0x8C71, 0x9CF3, 0xA534, 0xAD55, 0xB596, 0xAD55, 0xAD55, 0xA514,   // 0x0D30 (3376)
0x9CF3, 0x94B2, 0x94B2, 0x9CD3, 0xA534, 0xB596, 0xB5B6, 0xB596, 0xB5B6, 0xAD75, 0xB596, 0xB596, 0xB596, 0xAD55, 0x9CD3, 0x8430,   // 0x0D40 (3392)
0x8C51, 0x8C51, 0x8C71, 0x8C71, 0x8C51, 0x8C51, 0x8C51, 0x8C51, 0x8410, 0x8430, 0x8C71, 0x8C71, 0x8C51, 0x8430, 0x8C71, 0x94B2,   // 0x0D50 (3408)
0x9492, 0x8430, 0x8C51, 0x8C51, 0x7BEF, 0x7BEF, 0x738E, 0x5AEB, 0x52AA, 0x18E3, 0x0000, 0x0000, 0x0000, 0x0000, 0x2124, 0x6B4D,   // 0x0D60 (3424)
0x8410, 0x8C71, 0x9CD3, 0xA514, 0xA534, 0xAD55, 0xA534, 0xAD75, 0xA514, 0x94B2, 0xA534, 0xAD75, 0xA534, 0xA514, 0x9CD3, 0x9CF3,   // 0x0D70 (3440)
0xA534, 0x8C51, 0x8430, 0x8430, 0x8430, 0x9492, 0x9CD3, 0x8C71, 0x9CD3, 0xA514, 0x9CD3, 0x9CF3, 0x9CF3, 0x9CF3, 0x9CF3, 0xA534,   // 0x0D80 (3456)
0xB596, 0xAD55, 0xB5B6, 0xB5B6, 0xAD55, 0xA514, 0x94B2, 0x9492, 0x94B2, 0xA514, 0xAD55, 0xAD75, 0xA534, 0x9CD3, 0x94B2, 0x9CD3,   // 0x0D90 (3472)
0x94B2, 0x8C51, 0x7BEF, 0x9492, 0xAD55, 0xAD55, 0x9CF3, 0xA534, 0xA534, 0xAD75, 0xA534, 0xAD55, 0xA514, 0x9492, 0x8410, 0x8430,   // 0x0DA0 (3488)
0x8430, 0x8430, 0x8C51, 0x8C51, 0x8C71, 0x8C71, 0x8C51, 0x8430, 0x8C71, 0x9492, 0x8C51, 0x8C51, 0x8C71, 0x9CD3, 0x94B2, 0x8430,   // 0x0DB0 (3504)
0x7BEF, 0x8430, 0x9492, 0x8430, 0x7BEF, 0x6B6D, 0x630C, 0x5ACB, 0x3186, 0x0000, 0x0000, 0x0000, 0x0000, 0x39C7, 0x738E, 0x7BEF,   // 0x0DC0 (3520)
0x9CD3, 0x9CF3, 0xAD55, 0xAD75, 0xAD55, 0xAD75, 0xA534, 0xA534, 0xAD55, 0xA514, 0xA534, 0xAD55, 0xAD55, 0xA534, 0xB596, 0xAD75,   // 0x0DD0 (3536)
0x8C51, 0x8410, 0x8410, 0x8C51, 0x94B2, 0x9CF3, 0xAD55, 0xB5B6, 0xAD75, 0xA534, 0x9CD3, 0x94B2, 0x94B2, 0x9492, 0x9CD3, 0xA514,   // 0x0DE0 (3552)
0xA514, 0xBDD7, 0xBDD7, 0xAD55, 0x9CD3, 0x9CD3, 0xA514, 0x9CD3, 0x9CF3, 0xA514, 0x94B2, 0x94B2, 0x8C71, 0x94B2, 0x9CD3, 0x8C71,   // 0x0DF0 (3568)
0x8410, 0x7BCF, 0x9492, 0xA514, 0x9CF3, 0x94B2, 0x94B2, 0x9CD3, 0xAD55, 0xAD55, 0x9CF3, 0x9CD3, 0x94B2, 0x8430, 0x8430, 0x8430,   // 0x0E00 (3584)
0x8430, 0x8C71, 0x8C71, 0x8C71, 0x8C71, 0x8C71, 0x8C71, 0x9492, 0x8C71, 0x8430, 0x8410, 0x9CD3, 0xAD55, 0x9CD3, 0x8410, 0x7BEF,   // 0x0E10 (3600)
0x8C71, 0x9492, 0x8430, 0x8410, 0x73AE, 0x632C, 0x5ACB, 0x39E7, 0x0020, 0x0000, 0x0000, 0x0020, 0x4228, 0x738E, 0x8430, 0x9CF3,   // 0x0E20 (3616)
0xAD55, 0xAD75, 0xAD55, 0xAD55, 0xAD75, 0xAD75, 0xAD75, 0xAD75, 0xAD55, 0xAD75, 0xAD75, 0xAD75, 0xB596, 0xB5B6, 0xA534, 0x8C51,   // 0x0E30 (3632)
0x8C51, 0x8430, 0x9492, 0x8C71, 0x9CF3, 0xB596, 0xBDF7, 0xB5B6, 0xA534, 0x9CD3, 0x9CD3, 0x9492, 0x94B2, 0x9CD3, 0x9CD3, 0xA514,   // 0x0E40 (3648)
0xB5B6, 0xB5B6, 0xAD55, 0x9CD3, 0x9CD3, 0xA514, 0xA534, 0xA534, 0x9CD3, 0x7BEF, 0x8410, 0x8C71, 0x94B2, 0xA514, 0x9CF3, 0x9CF3,   // 0x0E50 (3664)
0x9492, 0x9CF3, 0x9CF3, 0x9CD3, 0x9CF3, 0x9CD3, 0x94B2, 0x94B2, 0xA514, 0xA534, 0x9CF3, 0x94B2, 0x8C51, 0x8C71, 0x8C71, 0x8C51,   // 0x0E60 (3680)
0x8C71, 0x8C51, 0x8C51, 0x8C71, 0x9492, 0x8C71, 0x8C71, 0x8C51, 0x8410, 0x8410, 0xAD55, 0xB5B6, 0x9CD3, 0x8430, 0x8430, 0x94B2,   // 0x0E70 (3696)
0x94B2, 0x8C51, 0x8410, 0x73AE, 0x6B4D, 0x630C, 0x4228, 0x0841, 0x0000, 0x0000, 0x1082, 0x5ACB, 0x73AE, 0x8C71, 0xAD55, 0xB596,   // 0x0E80 (3712)
0xB596, 0xB596, 0xAD55, 0xAD55, 0xB596, 0xB596, 0xB596, 0xBDD7, 0xB596, 0xB596, 0xB596, 0xB5B6, 0xBDD7, 0xA534, 0x8C51, 0x8C51,   // 0x0E90 (3728)
0x8430, 0x8430, 0x8C51, 0x9CD3, 0xB596, 0xB596, 0xA514, 0x9492, 0x9492, 0x94B2, 0x9492, 0xA534, 0xA534, 0xA514, 0xAD55, 0xB5B6,   // 0x0EA0 (3744)
0xB5B6, 0xA534, 0x9CD3, 0x94B2, 0xA514, 0xA514, 0x9CF3, 0x94B2, 0x7BEF, 0x8410, 0x8C71, 0x94B2, 0xA534, 0xB596, 0xB596, 0xAD75,   // 0x0EB0 (3760)
0xAD55, 0x9CF3, 0x9492, 0x9492, 0x94B2, 0x94B2, 0x9492, 0x9CD3, 0x9CF3, 0x8C71, 0x9CF3, 0x9CF3, 0x9492, 0x8C51, 0x8C71, 0x8C51,   // 0x0EC0 (3776)
0x8C51, 0x94B2, 0x9492, 0x9492, 0x8C71, 0x8430, 0x8410, 0x7BCF, 0x7BEF, 0xA534, 0xBDD7, 0xA514, 0x94B2, 0x9492, 0x8C71, 0x9492,   // 0x0ED0 (3792)
0x8C51, 0x7BEF, 0x738E, 0x6B6D, 0x630C, 0x4A49, 0x1082, 0x0000, 0x0000, 0x18E3, 0x632C, 0x7BCF, 0x8C71, 0xAD55, 0xAD75, 0xAD75,   // 0x0EE0 (3808)
0xB5B6, 0xB5B6, 0xAD75, 0xB596, 0xB596, 0xC618, 0xC638, 0xBDF7, 0xBDF7, 0xBDD7, 0xB596, 0xAD55, 0x9CD3, 0x9CD3, 0x8C71, 0x8C51,   // 0x0EF0 (3824)
0x8430, 0x8C71, 0x9CD3, 0xA534, 0x9CD3, 0x8C71, 0x8430, 0x8C51, 0x8C71, 0xA514, 0xAD75, 0xAD75, 0xAD75, 0xB596, 0xB596, 0xAD75,   // 0x0F00 (3840)
0xAD55, 0xA514, 0x9CD3, 0x9CF3, 0x9CF3, 0x94B2, 0x94B2, 0x8C71, 0x9492, 0x9CD3, 0xA514, 0xB596, 0xC618, 0xBDD7, 0xB5B6, 0xB5B6,   // 0x0F10 (3856)
0xAD75, 0x94B2, 0x8C51, 0x9492, 0x9492, 0x9492, 0x9CF3, 0xB596, 0xA534, 0x9CF3, 0xA534, 0x9CD3, 0x8430, 0x8C51, 0x8C71, 0x9CD3,   // 0x0F20 (3872)
0x9CD3, 0x8C71, 0x8C71, 0x8430, 0x8410, 0x8410, 0x7BCF, 0x7BCF, 0x94B2, 0xAD75, 0xA534, 0xA514, 0xA514, 0x8C71, 0x9CD3, 0x9492,   // 0x0F30 (3888)
0x8410, 0x7BCF, 0x6B6D, 0x632C, 0x52AA, 0x2104, 0x0000, 0x0000, 0x2945, 0x6B4D, 0x73AE, 0x8430, 0xA534, 0xAD55, 0xAD75, 0xB5B6,   // 0x0F40 (3904)
0xBDF7, 0xB596, 0xB5B6, 0xB5B6, 0xBDD7, 0xBDD7, 0xA514, 0xA514, 0xB596, 0xBDD7, 0x9CD3, 0x9492, 0xAD55, 0x9492, 0x8430, 0x8430,   // 0x0F50 (3920)
0x94B2, 0x9CF3, 0x8C71, 0x8C51, 0x8C71, 0x8C51, 0x8C71, 0x9CD3, 0xA534, 0xA514, 0xAD75, 0xBDD7, 0xB5B6, 0xB5B6, 0xB596, 0xAD75,   // 0x0F60 (3936)
0xAD55, 0x9CF3, 0x9CF3, 0x9CD3, 0x9CD3, 0x9CD3, 0x9CF3, 0x9CD3, 0x9CF3, 0xA534, 0xBDD7, 0xC638, 0xBDF7, 0xB5B6, 0xC618, 0xBDD7,   // 0x0F70 (3952)
0xA534, 0x8C71, 0x8C71, 0x8C51, 0x8C71, 0x9CF3, 0xCE59, 0xC618, 0xAD55, 0x9CD3, 0x9CF3, 0x8C51, 0x8C71, 0x9492, 0x9CD3, 0x9492,   // 0x0F80 (3968)
0x8C51, 0x8430, 0x8410, 0x8430, 0x8410, 0x73AE, 0x7BCF, 0x94B2, 0xAD55, 0xAD75, 0xAD75, 0xAD55, 0x9CF3, 0x9CF3, 0x94B2, 0x8430,   // 0x0F90 (3984)
0x7BEF, 0x738E, 0x632C, 0x5ACB, 0x2945, 0x0000, 0x0000, 0x2965, 0x632C, 0x73AE, 0x8410, 0x9CD3, 0xA514, 0xAD75, 0xB596, 0xBDD7,   // 0x0FA0 (4000)
0xB596, 0xBDD7, 0xBDD7, 0xAD55, 0x9CF3, 0x8C71, 0x8410, 0x8C71, 0xA514, 0x8C71, 0x9CD3, 0x94B2, 0x8430, 0x8430, 0x8410, 0x8C71,   // 0x0FB0 (4016)
0x9CD3, 0x8C71, 0x8C71, 0x8430, 0x8C71, 0x94B2, 0x94B2, 0x9CD3, 0xAD55, 0xB5B6, 0xB596, 0xB5B6, 0xBDD7, 0xAD75, 0xAD75, 0xB596,   // 0x0FC0 (4032)
0xA534, 0xA514, 0xA514, 0xA534, 0xA534, 0xAD55, 0x94B2, 0x9492, 0xA534, 0xB5B6, 0xBDD7, 0xB5B6, 0xBDF7, 0xC638, 0xB5B6, 0xA534,   // 0x0FD0 (4048)
0x94B2, 0x8C51, 0x7BEF, 0x8C51, 0x9CF3, 0xB5B6, 0xB596, 0x94B2, 0x9CD3, 0xA514, 0x9CD3, 0x8C51, 0x9492, 0x9492, 0x8C71, 0x8C51,   // 0x0FE0 (4064)
0x8410, 0x7BEF, 0x8C51, 0x8430, 0x7BCF, 0x7BCF, 0x9CD3, 0xB596, 0xB5B6, 0xB596, 0xAD75, 0xAD55, 0x9CF3, 0x94B2, 0x8C51, 0x7BCF,   // 0x0FF0 (4080)
0x73AE, 0x6B4D, 0x5AEB, 0x3186, 0x0000, 0x0000, 0x31A6, 0x6B4D, 0x7BCF, 0x8430, 0x9CD3, 0xA514, 0xAD55, 0xB596, 0xBDF7, 0xB5B6,   // 0x1000 (4096)
0xB5B6, 0xC618, 0x9CF3, 0x8410, 0x8410, 0x8410, 0x7BEF, 0x7BCF, 0x8410, 0x9CD3, 0x94B2, 0x9CF3, 0x9CF3, 0x8430, 0x8C71, 0x9CD3,   // 0x1010 (4112)
0x94B2, 0x8C71, 0x8C51, 0x8C71, 0x9492, 0x94B2, 0x94B2, 0xA534, 0xB5B6, 0xB5B6, 0xB5B6, 0xAD55, 0xA534, 0xA534, 0xB5B6, 0xB596,   // 0x1020 (4128)
0xAD75, 0xAD75, 0xBDD7, 0xBDD7, 0xB596, 0xA514, 0x9CF3, 0xA534, 0xB596, 0xBDD7, 0xBDD7, 0xBDD7, 0xBDD7, 0xBDD7, 0xB596, 0xA534,   // 0x1030 (4144)
0x9492, 0x7BEF, 0x8C71, 0xA514, 0xA514, 0xA534, 0x9492, 0x94B2, 0xAD75, 0xCE79, 0x9CD3, 0x8430, 0x8C71, 0x8C51, 0x8430, 0x8410,   // 0x1040 (4160)
0x8430, 0x8430, 0x7BEF, 0x7BEF, 0x9492, 0xA534, 0xBDD7, 0xBDD7, 0xB596, 0xAD75, 0xAD55, 0x9CF3, 0x94B2, 0x8C71, 0x7BEF, 0x73AE,   // 0x1050 (4176)
0x6B6D, 0x5AEB, 0x31A6, 0x0000, 0x0000, 0x39C7, 0x6B4D, 0x7BCF, 0x8430, 0x94B2, 0xA514, 0xAD55, 0xB5B6, 0xC618, 0xBDF7, 0xAD75,   // 0x1060 (4192)
0xBDF7, 0x9CF3, 0x8430, 0x8410, 0x7BEF, 0x8410, 0x7BEF, 0x8410, 0x8C51, 0x8C51, 0x9492, 0x9492, 0x8430, 0x9CD3, 0xA534, 0xAD75,   // 0x1070 (4208)
0xA534, 0x9CF3, 0x9492, 0x94B2, 0x9492, 0x9492, 0xA534, 0xBDF7, 0xBDF7, 0xB5B6, 0xAD55, 0x9CF3, 0x9CF3, 0xC618, 0xCE79, 0xC638,   // 0x1080 (4224)
0xB5B6, 0xB5B6, 0xBDF7, 0xBDD7, 0xB596, 0xAD55, 0xA514, 0xAD55, 0xB596, 0xC638, 0xBDD7, 0xBDD7, 0xC618, 0xBDD7, 0xB596, 0xA534,   // 0x1090 (4240)
0x94B2, 0x9CD3, 0x9CD3, 0x94B2, 0x9CF3, 0xA534, 0xAD75, 0xAD55, 0xC618, 0xAD75, 0x8C71, 0x8C51, 0x8430, 0x8430, 0x8430, 0x8C51,   // 0x10A0 (4256)
0x8430, 0x7BEF, 0x8430, 0x9CF3, 0xAD75, 0xBDD7, 0xBDF7, 0xB5B6, 0xAD75, 0xA534, 0xA514, 0x9CD3, 0x8C71, 0x7BEF, 0x73AE, 0x738E,   // 0x10B0 (4272)
0x5AEB, 0x39C7, 0x0020, 0x0000, 0x39C7, 0x6B6D, 0x7BCF, 0x8430, 0x94B2, 0xA514, 0xA534, 0xB5B6, 0xC618, 0xBDD7, 0xB596, 0xA534,   // 0x10C0 (4288)
0x9492, 0x8C71, 0x8C51, 0x8410, 0x8410, 0x8410, 0x8410, 0x94B2, 0xAD75, 0xAD55, 0xA514, 0x9492, 0xA534, 0xB596, 0xB596, 0xC618,   // 0x10D0 (4304)
0xAD75, 0x9CD3, 0x9492, 0x8C71, 0x94B2, 0xA534, 0xB5B6, 0xBDD7, 0xA534, 0x94B2, 0x94B2, 0xA534, 0xC618, 0xD69A, 0xCE79, 0xBDF7,   // 0x10E0 (4320)
0xBDF7, 0xBDF7, 0xBDF7, 0xB596, 0x9CD3, 0x9CD3, 0xA514, 0xAD55, 0xB5B6, 0xBDF7, 0xCE79, 0xD69A, 0xBDD7, 0xAD55, 0xAD75, 0xAD55,   // 0x10F0 (4336)
0xA514, 0xA514, 0xAD75, 0xAD75, 0xAD75, 0xB5B6, 0xB596, 0xAD75, 0xAD75, 0xAD55, 0x9492, 0x8410, 0x8410, 0x8C51, 0x8430, 0x7BEF,   // 0x1100 (4352)
0x7BCF, 0x9492, 0xA534, 0xAD75, 0xBDD7, 0xC618, 0xB5B6, 0xAD75, 0xA534, 0xA514, 0x9CF3, 0x8C71, 0x8410, 0x7BCF, 0x738E, 0x5AEB,   // 0x1110 (4368)
0x39E7, 0x0020, 0x0000, 0x39C7, 0x738E, 0x7BEF, 0x8430, 0x9492, 0xA514, 0xA534, 0xBDD7, 0xC618, 0xBDD7, 0xB5B6, 0x9CF3, 0x8C71,   // 0x1120 (4384)
0x9492, 0x8C51, 0x8410, 0x7BEF, 0x7BEF, 0x8410, 0xA514, 0xBDD7, 0xB596, 0xAD75, 0xAD55, 0xB5B6, 0xB5B6, 0xBDF7, 0xAD75, 0x9492,   // 0x1130 (4400)
0x9CF3, 0x9CF3, 0x9CD3, 0x9CF3, 0xAD55, 0xB5B6, 0xB596, 0x94B2, 0x8C71, 0x9CD3, 0xB5B6, 0xBDF7, 0xCE59, 0xCE59, 0xC618, 0xCE79,   // 0x1140 (4416)
0xCE59, 0xBDF7, 0xBDD7, 0x9CF3, 0x9CF3, 0xAD55, 0xB596, 0xBDD7, 0xC638, 0xC638, 0xCE59, 0xC618, 0xB5B6, 0xB5B6, 0xB5B6, 0xAD55,   // 0x1150 (4432)
0xBDD7, 0xBDF7, 0xB5B6, 0xBDD7, 0xBDD7, 0xA514, 0x9CF3, 0x9CF3, 0x9CF3, 0x9CD3, 0x8430, 0x7BEF, 0x8410, 0x7BEF, 0x7BEF, 0x8410,   // 0x1160 (4448)
0x9CD3, 0xAD75, 0xAD75, 0xB596, 0xBDD7, 0xB596, 0xAD75, 0xA534, 0x9CF3, 0x9CD3, 0x8C71, 0x8410, 0x73AE, 0x6B6D, 0x5AEB, 0x39E7,   // 0x1170 (4464)
0x0020, 0x0020, 0x39E7, 0x738E, 0x7BCF, 0x8430, 0x8C71, 0x9CD3, 0xAD55, 0xB5B6, 0xBDF7, 0xBDF7, 0xBDD7, 0xA534, 0x94B2, 0x8C71,   // 0x1180 (4480)
0x8430, 0x8410, 0x8410, 0x7BCF, 0x8430, 0xAD75, 0xB5B6, 0xAD75, 0xA514, 0xB596, 0xB596, 0xAD75, 0xAD55, 0x9CD3, 0x94B2, 0x9CF3,   // 0x1190 (4496)
0xAD55, 0xB596, 0xA514, 0xAD55, 0xC618, 0xB5B6, 0x94B2, 0x9492, 0x9CD3, 0xA534, 0xB5B6, 0xC618, 0xC618, 0xC618, 0xC638, 0xC618,   // 0x11A0 (4512)
0xC618, 0xBDD7, 0xB596, 0xAD75, 0xB5B6, 0xBDD7, 0xBDF7, 0xC638, 0xC618, 0xC618, 0xC638, 0xCE79, 0xCE59, 0xC618, 0xBDD7, 0xBDF7,   // 0x11B0 (4528)
0xBDF7, 0xBDD7, 0xB596, 0xB596, 0x8C71, 0x8C51, 0x8430, 0x7BEF, 0x7BEF, 0x9CF3, 0x8C51, 0x8C51, 0x8430, 0x8430, 0x9CD3, 0xAD75,   // 0x11C0 (4544)
0xAD75, 0xAD75, 0xAD55, 0xAD55, 0xB596, 0xAD75, 0x9CF3, 0x9CF3, 0xA534, 0x9492, 0x8410, 0x7BCF, 0x6B4D, 0x5ACB, 0x39E7, 0x0020,   // 0x11D0 (4560)
0x0000, 0x4228, 0x73AE, 0x73AE, 0x8410, 0x8C71, 0x8C71, 0xA514, 0xB596, 0xC638, 0xC618, 0xBDF7, 0xB596, 0xA534, 0x8C51, 0x8430,   // 0x11E0 (4576)
0x8430, 0x8430, 0x7BEF, 0x8C51, 0xA514, 0xA514, 0xA514, 0xAD55, 0xB5B6, 0xAD55, 0x9CF3, 0x9CD3, 0x94B2, 0x9CD3, 0x9CD3, 0xA514,   // 0x11F0 (4592)
0x9CF3, 0x9CD3, 0xB596, 0xBDF7, 0xA534, 0xA514, 0x94B2, 0x94B2, 0xA514, 0xBDD7, 0xBDF7, 0xC618, 0xC618, 0xCE59, 0xCE59, 0xC638,   // 0x1200 (4608)
0xC618, 0xC618, 0xBDD7, 0xBDD7, 0xC638, 0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xCE79, 0xD69A, 0xCE59, 0xC638, 0xC638, 0xC618,   // 0x1210 (4624)
0xBDF7, 0xAD75, 0xA534, 0x8C71, 0x8410, 0x7BEF, 0x7BEF, 0x7BCF, 0x8430, 0x8410, 0x8410, 0x8430, 0x7BEF, 0x94B2, 0xAD55, 0xA534,   // 0x1220 (4640)
0xA534, 0x9CD3, 0xA514, 0xB596, 0xAD55, 0x9CF3, 0x9CD3, 0x94B2, 0x8C51, 0x8410, 0x7BCF, 0x632C, 0x52AA, 0x39E7, 0x0841, 0x0000,   // 0x1230 (4656)
0x4228, 0x73AE, 0x73AE, 0x7BEF, 0x94B2, 0x9CD3, 0xA534, 0xAD55, 0xBDF7, 0xC638, 0xBDF7, 0xA534, 0xA514, 0x8C71, 0x8C71, 0x8C51,   // 0x1240 (4672)
0x8C51, 0x8C71, 0x8C71, 0x9CF3, 0xA514, 0xA514, 0x9CF3, 0xA534, 0xAD55, 0xB596, 0xAD55, 0x94B2, 0x94B2, 0xA514, 0xA514, 0x94B2,   // 0x1250 (4688)
0x9CF3, 0xAD55, 0xA514, 0x94B2, 0x9CF3, 0x9CD3, 0xA534, 0xB5B6, 0xBDF7, 0xC618, 0xC618, 0xCE59, 0xCE59, 0xCE79, 0xC638, 0xC638,   // 0x1260 (4704)
0xBDF7, 0xBDD7, 0xBDF7, 0xCE59, 0xCE79, 0xCE59, 0xD69A, 0xD69A, 0xD69A, 0xDEDB, 0xDEDB, 0xCE79, 0xC638, 0xC638, 0xC618, 0xB5B6,   // 0x1270 (4720)
0xAD75, 0x94B2, 0x8430, 0x7BEF, 0x8430, 0x8410, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BEF, 0x7BEF, 0x7BEF, 0x9492, 0xA514, 0x94B2, 0x94B2,   // 0x1280 (4736)
0x9492, 0x9CF3, 0xB596, 0xA514, 0x8C71, 0x9492, 0x8C51, 0x8C51, 0x7BEF, 0x738E, 0x632C, 0x52AA, 0x39C7, 0x0020, 0x0000, 0x39E7,   // 0x1290 (4752)
0x6B6D, 0x738E, 0x8410, 0x9CD3, 0x9CD3, 0xA534, 0xA534, 0xAD75, 0xB5B6, 0xB5B6, 0xB596, 0xAD55, 0x94B2, 0x9CF3, 0x9492, 0x8C71,   // 0x12A0 (4768)
0xA534, 0x9CD3, 0xA514, 0xA534, 0x9CD3, 0x94B2, 0xA534, 0xA534, 0xBDD7, 0xB5B6, 0x9CF3, 0x9CF3, 0xA514, 0x9CF3, 0x9CF3, 0x9CD3,   // 0x12B0 (4784)
0x9CD3, 0x94B2, 0x9492, 0x9492, 0xA514, 0xBDD7, 0xBDF7, 0xC618, 0xCE59, 0xC638, 0xC618, 0xC638, 0xCE59, 0xCE59, 0xC638, 0xC638,   // 0x12C0 (4800)
0xC638, 0xC638, 0xCE59, 0xCE59, 0xCE59, 0xD69A, 0xD69A, 0xD69A, 0xDEDB, 0xD6BA, 0xD69A, 0xC638, 0xC618, 0xBDF7, 0xB596, 0xA514,   // 0x12D0 (4816)
0x8C51, 0x7BEF, 0x7BCF, 0x7BEF, 0x7BCF, 0x7BCF, 0x7BEF, 0x7BCF, 0x7BEF, 0x7BCF, 0x7BCF, 0x8430, 0x94B2, 0x8C51, 0x8C71, 0x94B2,   // 0x12E0 (4832)
0xB596, 0xB596, 0x9492, 0x9492, 0x8C71, 0x8430, 0x8C51, 0x738E, 0x6B6D, 0x632C, 0x5ACB, 0x39C7, 0x0020, 0x0000, 0x31A6, 0x6B4D,   // 0x12F0 (4848)
0x73AE, 0x8410, 0x9492, 0x94B2, 0xA514, 0xAD75, 0xAD55, 0xB596, 0xAD55, 0xB596, 0xB596, 0xA534, 0xAD55, 0xA514, 0xA514, 0xAD75,   // 0x1300 (4864)
0xAD75, 0xAD55, 0xBDD7, 0x9CD3, 0x9CD3, 0xAD75, 0xA514, 0xAD75, 0xAD55, 0x9CF3, 0x9CF3, 0x9CD3, 0x94B2, 0x9CD3, 0x9CF3, 0x9CD3,   // 0x1310 (4880)
0x9492, 0x9CD3, 0xAD55, 0xA534, 0xB596, 0xBDF7, 0xBDF7, 0xCE59, 0xC618, 0xBDD7, 0xBDF7, 0xC638, 0xC638, 0xC618, 0xC638, 0xC638,   // 0x1320 (4896)
0xC638, 0xCE79, 0xCE79, 0xD69A, 0xCE79, 0xD69A, 0xD6BA, 0xDEDB, 0xD6BA, 0xCE79, 0xC618, 0xBDD7, 0xB5B6, 0xAD75, 0x94B2, 0x8430,   // 0x1330 (4912)
0x8410, 0x7BEF, 0x7BCF, 0x7BCF, 0x8410, 0x8430, 0x7BEF, 0x7BEF, 0x7BEF, 0x7BCF, 0x8430, 0x8C71, 0x8430, 0x8410, 0x8430, 0xA514,   // 0x1340 (4928)
0xAD55, 0xA514, 0x9CD3, 0x9492, 0x8430, 0x7BEF, 0x738E, 0x6B4D, 0x6B4D, 0x5ACB, 0x3186, 0x0000, 0x0000, 0x2965, 0x632C, 0x7BCF,   // 0x1350 (4944)
0x8430, 0x9492, 0x9492, 0x94B2, 0xA534, 0xB596, 0xAD55, 0x9CD3, 0xB596, 0xB5B6, 0xAD55, 0xA534, 0xAD75, 0xBDD7, 0xBDF7, 0xB5B6,   // 0x1360 (4960)
0xAD75, 0xAD75, 0x94B2, 0x9CD3, 0xAD75, 0xA534, 0xA514, 0x9CF3, 0x9CD3, 0x9CD3, 0x94B2, 0x9492, 0x9492, 0x9492, 0x9CF3, 0x9CD3,   // 0x1370 (4976)
0x94B2, 0xAD75, 0xB596, 0xA514, 0xA534, 0xC618, 0xC638, 0xC618, 0xBDD7, 0xBDD7, 0xBDF7, 0xC638, 0xCE79, 0xC618, 0xC638, 0xCE79,   // 0x1380 (4992)
0xCE79, 0xCE79, 0xD69A, 0xC638, 0xCE59, 0xD69A, 0xD69A, 0xCE79, 0xCE59, 0xC638, 0xBDD7, 0xB5B6, 0xAD55, 0x9492, 0x8C51, 0x8C71,   // 0x1390 (5008)
0x8410, 0x8430, 0x8430, 0x7BEF, 0x8C51, 0x8430, 0x8410, 0x8410, 0x73AE, 0x7BCF, 0x7BEF, 0x7BEF, 0x73AE, 0x7BEF, 0x9492, 0xAD75,   // 0x13A0 (5024)
0xA534, 0x9CD3, 0x9492, 0x8430, 0x8410, 0x7BCF, 0x632C, 0x630C, 0x5ACB, 0x2965, 0x0000, 0x0000, 0x18E3, 0x630C, 0x738E, 0x8410,   // 0x13B0 (5040)
0x8C71, 0x8C71, 0x9492, 0x9CD3, 0xA514, 0xA534, 0x9CD3, 0xA514, 0xB5B6, 0xB5B6, 0xAD75, 0xBDD7, 0xB5B6, 0xBDD7, 0x9CD3, 0xA514,   // 0x13C0 (5056)
0xA514, 0x9CD3, 0x9CF3, 0xA534, 0xA514, 0x9CF3, 0x94B2, 0x94B2, 0xA514, 0x9492, 0x8C71, 0x9492, 0x9492, 0x9CF3, 0x94B2, 0x8C51,   // 0x13D0 (5072)
0x9CD3, 0xB596, 0xAD55, 0xAD75, 0xC618, 0xC638, 0xCE59, 0xBDF7, 0xBDF7, 0xBDF7, 0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xCE59,   // 0x13E0 (5088)
0xCE79, 0xCE59, 0xC638, 0xCE59, 0xCE79, 0xCE79, 0xC638, 0xCE79, 0xC638, 0xBDF7, 0xC618, 0xA514, 0x9492, 0x8C71, 0x9492, 0x8C71,   // 0x13F0 (5104)
0x8C51, 0x8410, 0x7BCF, 0x7BEF, 0x7BEF, 0x73AE, 0x73AE, 0x738E, 0x738E, 0x7BCF, 0x7BCF, 0x73AE, 0x9492, 0xA514, 0xAD75, 0xAD55,   // 0x1400 (5120)
0x9CD3, 0x9492, 0x8410, 0x73AE, 0x6B4D, 0x630C, 0x5ACB, 0x528A, 0x2104, 0x0000, 0x0000, 0x10A2, 0x5ACB, 0x738E, 0x7BCF, 0x8430,   // 0x1410 (5136)
0x8430, 0x94B2, 0xA514, 0xA514, 0xAD55, 0x9CD3, 0x9CF3, 0xB596, 0xB596, 0xBDD7, 0xBDD7, 0xAD55, 0x9CD3, 0x9492, 0xA534, 0xAD55,   // 0x1420 (5152)
0xA514, 0x9CF3, 0xAD75, 0xA514, 0x9CD3, 0x9492, 0x9492, 0xAD55, 0x9CD3, 0x8C71, 0x94B2, 0x9CF3, 0xA514, 0x94B2, 0x9492, 0xA514,   // 0x1430 (5168)
0xAD75, 0xBDD7, 0xC618, 0xC638, 0xC618, 0xC618, 0xCE59, 0xC618, 0xC638, 0xC618, 0xC638, 0xCE59, 0xD69A, 0xCE79, 0xD69A, 0xD69A,   // 0x1440 (5184)
0xCE59, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xD69A, 0xC638, 0xBDF7, 0xB5B6, 0xA534, 0x8C51, 0x8430, 0x8C51, 0x8C51, 0x8410,   // 0x1450 (5200)
0x7BEF, 0x7BCF, 0x7BCF, 0x73AE, 0x738E, 0x738E, 0x6B6D, 0x6B4D, 0x738E, 0x738E, 0x73AE, 0x9CD3, 0xA514, 0xAD55, 0xB596, 0x9CF3,   // 0x1460 (5216)
0x8C51, 0x6B4D, 0x5AEB, 0x52AA, 0x528A, 0x5ACB, 0x4A69, 0x18C3, 0x0000, 0x0000, 0x0841, 0x4A69, 0x6B6D, 0x7BCF, 0x8410, 0x738E,   // 0x1470 (5232)
0x8C71, 0xA514, 0xAD55, 0xB596, 0xA534, 0xA514, 0xB5B6, 0xB596, 0xB5B6, 0xB5B6, 0x9CF3, 0x9492, 0x94B2, 0xB5B6, 0xBDD7, 0xAD75,   // 0x1480 (5248)
0xB5B6, 0xB5B6, 0xA514, 0x94B2, 0x8C71, 0x8C71, 0x9492, 0x94B2, 0x9492, 0x9CD3, 0x94B2, 0x9492, 0x9CD3, 0xB5B6, 0xC638, 0xC618,   // 0x1490 (5264)
0xC618, 0xC638, 0xC638, 0xC618, 0xC638, 0xC618, 0xBDF7, 0xC638, 0xC618, 0xBDF7, 0xCE59, 0xCE79, 0xDEDB, 0xE71C, 0xDEDB, 0xCE79,   // 0x14A0 (5280)
0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xC638, 0xBDD7, 0xAD55, 0xA514, 0x8C51, 0x8410, 0x8410, 0x7BEF, 0x7BEF, 0x7BEF,   // 0x14B0 (5296)
0x7BCF, 0x7BCF, 0x7BCF, 0x7BCF, 0x73AE, 0x738E, 0x6B6D, 0x6B4D, 0x632C, 0x8410, 0x9CF3, 0xA514, 0xA534, 0xB5B6, 0xA514, 0x8410,   // 0x14C0 (5312)
0x630C, 0x5AEB, 0x52AA, 0x4A69, 0x52AA, 0x4A49, 0x1082, 0x0000, 0x0000, 0x0000, 0x4208, 0x6B4D, 0x73AE, 0x8410, 0x7BCF, 0x8C51,   // 0x14D0 (5328)
0x9CF3, 0xAD55, 0xB596, 0xAD75, 0xB596, 0xBDD7, 0xB5B6, 0xAD75, 0xB5B6, 0xA514, 0xA514, 0xAD55, 0xA534, 0xAD75, 0xB5B6, 0xC618,   // 0x14E0 (5344)
0xB5B6, 0xA514, 0x94B2, 0x8C71, 0x8C71, 0x8C51, 0x9492, 0x8C71, 0x94B2, 0x9492, 0x9CF3, 0xAD55, 0xC638, 0xCE59, 0xC638, 0xC638,   // 0x14F0 (5360)
0xCE59, 0xC638, 0xC638, 0xC638, 0xC618, 0xCE59, 0xCE59, 0xBDF7, 0xBDF7, 0xC638, 0xD69A, 0xD6BA, 0xDEDB, 0xD6BA, 0xCE79, 0xCE79,   // 0x1500 (5376)
0xCE59, 0xCE59, 0xCE79, 0xCE59, 0xCE79, 0xCE59, 0xC618, 0xB596, 0x9CD3, 0x8C51, 0x8430, 0x8C51, 0x8410, 0x8410, 0x7BEF, 0x73AE,   // 0x1510 (5392)
0x7BEF, 0x7BCF, 0x73AE, 0x73AE, 0x738E, 0x6B6D, 0x6B4D, 0x632C, 0x8C51, 0xA534, 0x9CF3, 0xA514, 0xB5B6, 0x9CF3, 0x738E, 0x5AEB,   // 0x1520 (5408)
0x52AA, 0x528A, 0x4228, 0x4A49, 0x39C7, 0x0020, 0x0000, 0x0000, 0x0000, 0x31A6, 0x632C, 0x738E, 0x8410, 0x8410, 0x8C71, 0x9CD3,   // 0x1530 (5424)
0x9CD3, 0xAD75, 0xB596, 0xB5B6, 0xB5B6, 0xBDF7, 0xB5B6, 0xBDF7, 0xBDD7, 0xB596, 0xB596, 0xA514, 0xA514, 0xB596, 0xCE79, 0xC638,   // 0x1540 (5440)
0xAD75, 0x9CF3, 0x9CD3, 0x94B2, 0x9492, 0x9492, 0x9492, 0x9492, 0x9CD3, 0xB5B6, 0xBDD7, 0xC618, 0xC638, 0xCE59, 0xC638, 0xCE59,   // 0x1550 (5456)
0xCE59, 0xCE59, 0xC638, 0xC618, 0xC638, 0xCE59, 0xCE59, 0xCE59, 0xCE79, 0xCE59, 0xCE59, 0xCE79, 0xCE79, 0xCE79, 0xD69A, 0xCE79,   // 0x1560 (5472)
0xCE59, 0xD69A, 0xCE79, 0xCE79, 0xCE79, 0xCE59, 0xC638, 0xA534, 0x8C71, 0x8C51, 0x8C71, 0x8430, 0x8410, 0x7BEF, 0x7BEF, 0x7BEF,   // 0x1570 (5488)
0x7BCF, 0x73AE, 0x738E, 0x738E, 0x6B6D, 0x738E, 0x6B6D, 0x7BCF, 0x9CD3, 0x9CD3, 0xA534, 0xA534, 0x8C71, 0x6B4D, 0x52AA, 0x528A,   // 0x1580 (5504)
0x4228, 0x4208, 0x4228, 0x3186, 0x0000, 0x0000, 0x0000, 0x0000, 0x2104, 0x630C, 0x6B6D, 0x7BEF, 0x8C51, 0x8430, 0x9492, 0x9CD3,   // 0x1590 (5520)
0x9CD3, 0xAD75, 0xB5B6, 0xB5B6, 0xBDF7, 0xBDD7, 0xBDD7, 0xC618, 0xB596, 0xBDD7, 0xB5B6, 0xB596, 0xBDF7, 0xD69A, 0xD69A, 0xC618,   // 0x15A0 (5536)
0xB5B6, 0xAD75, 0xAD55, 0x94B2, 0x9492, 0x9492, 0x94B2, 0xA514, 0xAD55, 0xB5B6, 0xC618, 0xCE79, 0xCE59, 0xCE59, 0xCE79, 0xCE59,   // 0x15B0 (5552)
0xC638, 0xC638, 0xC638, 0xC618, 0xCE59, 0xCE59, 0xC638, 0xCE59, 0xC638, 0xCE59, 0xCE79, 0xCE59, 0xCE79, 0xD69A, 0xCE79, 0xCE59,   // 0x15C0 (5568)
0xD69A, 0xD69A, 0xD6BA, 0xD6BA, 0xD6BA, 0xC638, 0xB5B6, 0x9CF3, 0x8C71, 0x8C51, 0x8430, 0x8410, 0x8410, 0x8410, 0x7BEF, 0x7BCF,   // 0x15D0 (5584)
0x73AE, 0x738E, 0x738E, 0x738E, 0x73AE, 0x738E, 0x6B4D, 0x8430, 0xA514, 0xAD75, 0x9CF3, 0x7BCF, 0x5AEB, 0x528A, 0x4A49, 0x4208,   // 0x15E0 (5600)
0x39C7, 0x4228, 0x2104, 0x0000, 0x0000, 0x0000, 0x0000, 0x1082, 0x5ACB, 0x6B4D, 0x73AE, 0x8430, 0x8430, 0x9492, 0x9CD3, 0x94B2,   // 0x15F0 (5616)
0xA534, 0xB596, 0xBDF7, 0xC618, 0xBDD7, 0xB596, 0xB5B6, 0xBDF7, 0xC618, 0xC638, 0xC618, 0xC638, 0xD6BA, 0xD6BA, 0xCE59, 0xC618,   // 0x1600 (5632)
0xB5B6, 0xAD55, 0xAD75, 0xA534, 0x94B2, 0x9CD3, 0xA514, 0xAD55, 0xBDD7, 0xC638, 0xCE79, 0xCE59, 0xCE59, 0xC638, 0xC618, 0xC618,   // 0x1610 (5648)
0xCE79, 0xD69A, 0xCE59, 0xC638, 0xC638, 0xC638, 0xC618, 0xCE59, 0xCE79, 0xCE59, 0xD69A, 0xD69A, 0xCE59, 0xCE59, 0xCE79, 0xD6BA,   // 0x1620 (5664)
0xDEFB, 0xDEFB, 0xD6BA, 0xD6BA, 0xCE59, 0xC618, 0xB5B6, 0x94B2, 0x8430, 0x8430, 0x8430, 0x8C51, 0x8C51, 0x8410, 0x7BEF, 0x7BEF,   // 0x1630 (5680)
0x7BEF, 0x738E, 0x6B6D, 0x7BCF, 0x8430, 0x8410, 0x8410, 0x94B2, 0xA534, 0x9CD3, 0x6B4D, 0x52AA, 0x4A69, 0x4228, 0x39E7, 0x39C7,   // 0x1640 (5696)
0x4208, 0x10A2, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x4208, 0x632C, 0x6B6D, 0x7BEF, 0x8C71, 0x8C71, 0x8C71, 0x94B2, 0xAD55,   // 0x1650 (5712)
0xB5B6, 0xBDD7, 0xBDD7, 0xBDF7, 0xB5B6, 0xAD75, 0xBDF7, 0xC638, 0xC638, 0xCE59, 0xC618, 0xCE79, 0xDEDB, 0xCE79, 0xC638, 0xBDD7,   // 0x1660 (5728)
0xAD55, 0xBDD7, 0xBDF7, 0xB596, 0xA534, 0xAD75, 0xBDF7, 0xC638, 0xCE59, 0xCE59, 0xCE79, 0xC638, 0xBDF7, 0xC618, 0xC638, 0xCE79,   // 0x1670 (5744)
0xD6BA, 0xD69A, 0xCE59, 0xC638, 0xC638, 0xCE59, 0xCE79, 0xCE59, 0xCE59, 0xCE79, 0xD69A, 0xD69A, 0xD69A, 0xCE79, 0xD6BA, 0xDEDB,   // 0x1680 (5760)
0xDEDB, 0xD69A, 0xCE79, 0xCE79, 0xCE59, 0xB5B6, 0x9CD3, 0x8C51, 0x8430, 0x8410, 0x8410, 0x8C51, 0x8C51, 0x8410, 0x8430, 0x8410,   // 0x1690 (5776)
0x73AE, 0x7BCF, 0x8C51, 0x94B2, 0x9492, 0x8C71, 0x9CD3, 0xA514, 0x8C71, 0x632C, 0x528A, 0x4A49, 0x4208, 0x39C7, 0x39E7, 0x39E7,   // 0x16A0 (5792)
0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x2965, 0x630C, 0x6B4D, 0x7BEF, 0x8430, 0x8430, 0x8C51, 0x94B2, 0xA534, 0xAD55,   // 0x16B0 (5808)
0xB5B6, 0xBDD7, 0xBDD7, 0xC618, 0xBDF7, 0xB596, 0xC618, 0xCE59, 0xC638, 0xC638, 0xCE59, 0xD6BA, 0xCE79, 0xCE59, 0xC638, 0xC638,   // 0x16C0 (5824)
0xC638, 0xC638, 0xC638, 0xBDD7, 0xC618, 0xCE59, 0xCE79, 0xCE59, 0xC638, 0xC638, 0xC638, 0xC638, 0xC638, 0xC638, 0xC638, 0xCE59,   // 0x16D0 (5840)
0xCE79, 0xCE59, 0xCE79, 0xD69A, 0xCE79, 0xCE59, 0xC638, 0xCE59, 0xCE79, 0xD69A, 0xDEFB, 0xDEDB, 0xCE79, 0xCE79, 0xD69A, 0xD69A,   // 0x16E0 (5856)
0xCE59, 0xBDF7, 0xB5B6, 0xB5B6, 0xA534, 0x9492, 0x8C51, 0x8430, 0x8430, 0x94B2, 0xAD75, 0xA514, 0x8410, 0x7BEF, 0x7BCF, 0x7BCF,   // 0x16F0 (5872)
0x7BCF, 0x7BCF, 0x8430, 0x8410, 0x8430, 0xA514, 0x9CD3, 0x8C51, 0x632C, 0x528A, 0x4228, 0x39E7, 0x39C7, 0x4208, 0x2965, 0x0000,   // 0x1700 (5888)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x10A2, 0x52AA, 0x6B4D, 0x7BEF, 0x8410, 0x8430, 0x8430, 0x9492, 0x9CF3, 0xA534, 0xB596,   // 0x1710 (5904)
0xBDD7, 0xB5B6, 0xBDF7, 0xC618, 0xBDD7, 0xBDD7, 0xC618, 0xC638, 0xC638, 0xCE79, 0xD6BA, 0xD6BA, 0xD69A, 0xCE79, 0xD69A, 0xD6BA,   // 0x1720 (5920)
0xD69A, 0xD69A, 0xD6BA, 0xD6BA, 0xCE79, 0xD69A, 0xCE59, 0xC638, 0xCE59, 0xCE59, 0xCE79, 0xCE59, 0xC618, 0xC638, 0xCE79, 0xCE79,   // 0x1730 (5936)
0xC618, 0xCE59, 0xD69A, 0xD6BA, 0xCE79, 0xC638, 0xCE59, 0xCE79, 0xD6BA, 0xD6BA, 0xD6BA, 0xD69A, 0xD6BA, 0xD6BA, 0xCE59, 0xBDF7,   // 0x1740 (5952)
0xB5B6, 0xA534, 0x9CF3, 0x9CD3, 0x9492, 0x8C51, 0x9492, 0xAD75, 0xC618, 0xC638, 0xAD75, 0x8410, 0x73AE, 0x73AE, 0x7BEF, 0x7BCF,   // 0x1750 (5968)
0x8410, 0x8C51, 0x7BEF, 0x7BEF, 0x94B2, 0x9CD3, 0x8C51, 0x5AEB, 0x4A49, 0x4228, 0x39E7, 0x4228, 0x4228, 0x18C3, 0x0000, 0x0000,   // 0x1760 (5984)
0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x4228, 0x632C, 0x7BCF, 0x8410, 0x8430, 0x8C51, 0x8C71, 0x94B2, 0xA534, 0xAD75, 0xB5B6,   // 0x1770 (6000)
0xB5B6, 0xB5B6, 0xBDD7, 0xC618, 0xC618, 0xC638, 0xCE59, 0xC638, 0xCE79, 0xCE79, 0xD6BA, 0xD69A, 0xD69A, 0xD6BA, 0xDEDB, 0xDEDB,   // 0x1780 (6016)
0xD6BA, 0xDEDB, 0xDEDB, 0xDEDB, 0xD6BA, 0xD69A, 0xD69A, 0xD6BA, 0xD6BA, 0xD69A, 0xCE59, 0xC618, 0xCE59, 0xC638, 0xBDF7, 0xBDF7,   // 0x1790 (6032)
0xC618, 0xCE59, 0xCE79, 0xCE79, 0xCE79, 0xCE59, 0xD69A, 0xD69A, 0xCE59, 0xCE79, 0xD6BA, 0xDEDB, 0xD6BA, 0xCE59, 0xBDD7, 0xB596,   // 0x17A0 (6048)
0xA534, 0xA514, 0x9CF3, 0x9CF3, 0xA514, 0xB596, 0xBDD7, 0xBDD7, 0xBDD7, 0xAD75, 0x9492, 0x7BCF, 0x7BCF, 0x7BEF, 0x8430, 0x8C51,   // 0x17B0 (6064)
0x94B2, 0x8C51, 0x7BEF, 0x8C71, 0x8C71, 0x8430, 0x632C, 0x4A69, 0x4228, 0x4A69, 0x52AA, 0x39E7, 0x0841, 0x0000, 0x0000, 0x0000,   // 0x17C0 (6080)
0x0000, 0x0000, 0x0000, 0x0000, 0x2965, 0x630C, 0x738E, 0x7BEF, 0x8410, 0x7BEF, 0x8C51, 0x94B2, 0x9CF3, 0xAD55, 0xBDD7, 0xBDD7,   // 0x17D0 (6096)
0xBDF7, 0xBDD7, 0xBDF7, 0xC638, 0xCE59, 0xCE79, 0xCE79, 0xD69A, 0xD69A, 0xD69A, 0xD69A, 0xDEDB, 0xDEDB, 0xDEDB, 0xDEDB, 0xDEDB,   // 0x17E0 (6112)
0xDEDB, 0xD6BA, 0xCE79, 0xD69A, 0xDEDB, 0xDEDB, 0xDEDB, 0xD6BA, 0xCE79, 0xC638, 0xC618, 0xC618, 0xC618, 0xC618, 0xC638, 0xC638,   // 0x17F0 (6128)
0xC618, 0xCE59, 0xCE59, 0xCE59, 0xC638, 0xC638, 0xCE59, 0xC638, 0xCE59, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xBDD7, 0xB596, 0xAD75,   // 0x1800 (6144)
0xA534, 0x9CF3, 0xA514, 0xB596, 0xBDD7, 0xB596, 0xAD75, 0xAD75, 0xB596, 0xA534, 0x8C71, 0x8430, 0x8C71, 0x9492, 0x8430, 0x8C51,   // 0x1810 (6160)
0x8410, 0x7BCF, 0x8C51, 0x8C51, 0x7BEF, 0x738E, 0x630C, 0x52AA, 0x5ACB, 0x528A, 0x2945, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1820 (6176)
0x0000, 0x0000, 0x0000, 0x10A2, 0x5ACB, 0x6B4D, 0x7BCF, 0x7BEF, 0x7BCF, 0x8430, 0x94B2, 0x9CF3, 0xA534, 0xB596, 0xB5B6, 0xB596,   // 0x1830 (6192)
0xB5B6, 0xBDF7, 0xC618, 0xC638, 0xCE59, 0xCE79, 0xD6BA, 0xD6BA, 0xD6BA, 0xDEDB, 0xDEFB, 0xDEFB, 0xDEDB, 0xDEFB, 0xE71C, 0xE71C,   // 0x1840 (6208)
0xDEFB, 0xD69A, 0xD69A, 0xDEDB, 0xD6BA, 0xD6BA, 0xD6BA, 0xCE59, 0xC638, 0xC638, 0xC638, 0xC638, 0xCE59, 0xCE59, 0xCE59, 0xC638,   // 0x1850 (6224)
0xC638, 0xC638, 0xC638, 0xC638, 0xC618, 0xC618, 0xCE59, 0xCE59, 0xCE79, 0xD69A, 0xCE79, 0xD69A, 0xCE59, 0xBDF7, 0xAD75, 0x9CF3,   // 0x1860 (6240)
0xA514, 0xAD55, 0xB5B6, 0xBDD7, 0xB596, 0xAD75, 0xB596, 0xAD75, 0xA534, 0x9CF3, 0x8C71, 0x8430, 0x7BEF, 0x7BCF, 0x73AE, 0x6B4D,   // 0x1870 (6256)
0x6B4D, 0x8430, 0x8C51, 0x7BCF, 0x738E, 0x632C, 0x5AEB, 0x52AA, 0x4228, 0x1082, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1880 (6272)
0x0000, 0x0000, 0x0000, 0x4208, 0x6B4D, 0x73AE, 0x7BEF, 0x7BCF, 0x7BEF, 0x94B2, 0x9CD3, 0xA534, 0xB596, 0xB596, 0xB596, 0xB5B6,   // 0x1890 (6288)
0xBDF7, 0xCE59, 0xC638, 0xCE59, 0xD69A, 0xD69A, 0xD69A, 0xD6BA, 0xDEDB, 0xDEFB, 0xDEFB, 0xDEDB, 0xDEDB, 0xE71C, 0xE73C, 0xE73C,   // 0x18A0 (6304)
0xE71C, 0xDEDB, 0xD6BA, 0xD6BA, 0xDEDB, 0xDEDB, 0xCE79, 0xCE59, 0xCE79, 0xD69A, 0xCE79, 0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xC638,   // 0x18B0 (6320)
0xC638, 0xC638, 0xC638, 0xCE59, 0xCE59, 0xCE59, 0xCE79, 0xD6BA, 0xDEFB, 0xD69A, 0xCE79, 0xCE79, 0xBDF7, 0xAD55, 0xA514, 0xAD75,   // 0x18C0 (6336)
0xB596, 0xB5B6, 0xB596, 0xAD75, 0xAD55, 0xAD55, 0xA534, 0x9CF3, 0x9492, 0x7BEF, 0x6B6D, 0x738E, 0x738E, 0x632C, 0x630C, 0x630C,   // 0x18D0 (6352)
0x7BEF, 0x8430, 0x73AE, 0x632C, 0x52AA, 0x5ACB, 0x528A, 0x2965, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x18E0 (6368)
0x0000, 0x0000, 0x2104, 0x630C, 0x738E, 0x8410, 0x8410, 0x7BEF, 0x9492, 0x9CD3, 0xA514, 0xAD55, 0xAD75, 0xB596, 0xB5B6, 0xBDF7,   // 0x18F0 (6384)
0xC618, 0xC638, 0xCE79, 0xD69A, 0xCE59, 0xCE59, 0xCE79, 0xD69A, 0xD6BA, 0xDEDB, 0xDEFB, 0xDEFB, 0xE71C, 0xE71C, 0xDEFB, 0xDEDB,   // 0x1900 (6400)
0xD69A, 0xD69A, 0xD6BA, 0xD6BA, 0xD6BA, 0xCE79, 0xCE79, 0xD6BA, 0xD6BA, 0xD69A, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE59, 0xCE59,   // 0x1910 (6416)
0xC638, 0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xD69A, 0xD6BA, 0xCE59, 0xCE59, 0xC638, 0xB5B6, 0xB596, 0xAD55, 0xAD55, 0xB5B6,   // 0x1920 (6432)
0xB596, 0xB5B6, 0xBDD7, 0xAD75, 0xAD55, 0xAD55, 0x94B2, 0x7BCF, 0x73AE, 0x738E, 0x738E, 0x6B4D, 0x630C, 0x5ACB, 0x5ACB, 0x7BCF,   // 0x1930 (6448)
0x7BCF, 0x73AE, 0x632C, 0x52AA, 0x4A49, 0x39E7, 0x10A2, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1940 (6464)
0x0000, 0x0020, 0x4228, 0x6B4D, 0x7BCF, 0x8430, 0x8430, 0x8C51, 0x9492, 0x9CF3, 0xA534, 0xA534, 0xAD75, 0xBDD7, 0xB5B6, 0xBDD7,   // 0x1950 (6480)
0xC638, 0xCE79, 0xCE79, 0xCE59, 0xD6BA, 0xDEDB, 0xCE79, 0xCE79, 0xD6BA, 0xDEFB, 0xDEFB, 0xDEFB, 0xDEDB, 0xD6BA, 0xD69A, 0xD6BA,   // 0x1960 (6496)
0xD6BA, 0xD6BA, 0xD6BA, 0xD6BA, 0xD69A, 0xD69A, 0xD69A, 0xD6BA, 0xD6BA, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE59, 0xC638, 0xC638,   // 0x1970 (6512)
0xC638, 0xC638, 0xC638, 0xC638, 0xCE79, 0xCE79, 0xD69A, 0xD69A, 0xCE59, 0xC618, 0xBDD7, 0xBDF7, 0xAD75, 0xA514, 0xB5B6, 0xB596,   // 0x1980 (6528)
0xBDF7, 0xC638, 0xAD75, 0x9CF3, 0xA514, 0x94B2, 0x73AE, 0x73AE, 0x73AE, 0x6B4D, 0x630C, 0x630C, 0x5ACB, 0x52AA, 0x6B6D, 0x73AE,   // 0x1990 (6544)
0x6B6D, 0x5AEB, 0x4A49, 0x39E7, 0x2965, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x19A0 (6560)
0x0000, 0x2104, 0x632C, 0x73AE, 0x7BEF, 0x8430, 0x9492, 0x9492, 0x9CD3, 0xA514, 0xA534, 0xAD75, 0xB5B6, 0xB5B6, 0xBDD7, 0xC638,   // 0x19B0 (6576)
0xCE79, 0xCE79, 0xCE59, 0xD69A, 0xDEDB, 0xCE79, 0xCE79, 0xD6BA, 0xDEDB, 0xDEDB, 0xDEDB, 0xDEDB, 0xD6BA, 0xD69A, 0xD6BA, 0xDEDB,   // 0x19C0 (6592)
0xD6BA, 0xD6BA, 0xD69A, 0xCE79, 0xCE59, 0xCE79, 0xCE79, 0xCE79, 0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xC638, 0xC618, 0xC618, 0xC618,   // 0x19D0 (6608)
0xC618, 0xC638, 0xCE59, 0xCE59, 0xD69A, 0xDEDB, 0xD6BA, 0xC618, 0xB5B6, 0xB596, 0xAD75, 0xAD55, 0x9CD3, 0x9CF3, 0xB5B6, 0xBDF7,   // 0x19E0 (6624)
0xBDF7, 0xB596, 0x9CF3, 0x8C71, 0x8C71, 0x73AE, 0x738E, 0x738E, 0x632C, 0x5AEB, 0x5AEB, 0x528A, 0x4A69, 0x52AA, 0x632C, 0x630C,   // 0x19F0 (6640)
0x52AA, 0x4208, 0x39E7, 0x1082, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1A00 (6656)
0x0020, 0x4208, 0x738E, 0x7BEF, 0x8430, 0x8C71, 0x9492, 0x9492, 0x9CF3, 0xA534, 0xAD75, 0xB5B6, 0xBDF7, 0xC618, 0xC618, 0xC638,   // 0x1A10 (6672)
0xCE59, 0xCE79, 0xCE59, 0xCE79, 0xCE59, 0xD69A, 0xD69A, 0xDEDB, 0xDEDB, 0xD6BA, 0xD6BA, 0xD69A, 0xD69A, 0xCE79, 0xD6BA, 0xD69A,   // 0x1A20 (6688)
0xCE79, 0xCE79, 0xCE79, 0xC638, 0xC618, 0xC638, 0xC638, 0xC618, 0xBDF7, 0xC618, 0xC638, 0xBDF7, 0xBDD7, 0xBDF7, 0xBDF7, 0xC618,   // 0x1A30 (6704)
0xCE59, 0xC638, 0xCE59, 0xD69A, 0xD6BA, 0xCE59, 0xB5B6, 0xA534, 0x9CF3, 0x9CD3, 0x94B2, 0x9492, 0x9492, 0xAD55, 0xB5B6, 0xBDD7,   // 0x1A40 (6720)
0xB596, 0x9CD3, 0x8430, 0x7BCF, 0x738E, 0x738E, 0x6B4D, 0x630C, 0x5AEB, 0x52AA, 0x4A69, 0x4A69, 0x528A, 0x5AEB, 0x5ACB, 0x4A69,   // 0x1A50 (6736)
0x4228, 0x2965, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1A60 (6752)
0x18C3, 0x5AEB, 0x738E, 0x7BCF, 0x8430, 0x8C51, 0x8C51, 0x94B2, 0xA514, 0xAD75, 0xB5B6, 0xBDD7, 0xBDD7, 0xBDD7, 0xC638, 0xCE59,   // 0x1A70 (6768)
0xCE79, 0xCE79, 0xC638, 0xCE59, 0xCE79, 0xD69A, 0xD6BA, 0xD6BA, 0xD6BA, 0xD6BA, 0xD6BA, 0xD69A, 0xCE79, 0xD69A, 0xCE79, 0xCE59,   // 0x1A80 (6784)
0xCE59, 0xCE59, 0xC638, 0xC618, 0xC618, 0xBDD7, 0xC618, 0xBDF7, 0xC618, 0xBDF7, 0xBDD7, 0xBDD7, 0xC618, 0xBDF7, 0xBDF7, 0xC638,   // 0x1A90 (6800)
0xC618, 0xC638, 0xCE59, 0xC638, 0xBDD7, 0xAD55, 0x9CF3, 0x94B2, 0x8C71, 0x8C71, 0x8C71, 0x94B2, 0xAD55, 0xB596, 0xBDD7, 0xAD55,   // 0x1AA0 (6816)
0x9492, 0x8410, 0x73AE, 0x738E, 0x6B6D, 0x632C, 0x630C, 0x5AEB, 0x5ACB, 0x52AA, 0x528A, 0x52AA, 0x4A69, 0x4228, 0x4A69, 0x39E7,   // 0x1AB0 (6832)
0x0861, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1AC0 (6848)
0x31A6, 0x6B4D, 0x73AE, 0x7BEF, 0x8430, 0x8C51, 0x94B2, 0xA534, 0xAD55, 0xAD55, 0xAD55, 0xB596, 0xBDF7, 0xCE59, 0xCE79, 0xCE79,   // 0x1AD0 (6864)
0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xD69A, 0xCE79, 0xD69A, 0xD69A, 0xD69A, 0xD6BA, 0xD6BA, 0xD69A, 0xCE79, 0xCE59, 0xCE79, 0xCE79,   // 0x1AE0 (6880)
0xCE59, 0xCE59, 0xC638, 0xC618, 0xC638, 0xC618, 0xBDF7, 0xBDF7, 0xC618, 0xC618, 0xBDF7, 0xC618, 0xC618, 0xC638, 0xC638, 0xC618,   // 0x1AF0 (6896)
0xBDF7, 0xC638, 0xC638, 0xB596, 0xA514, 0x9CD3, 0x9492, 0x9492, 0x9492, 0x94B2, 0x9492, 0xA514, 0xB5B6, 0xBDF7, 0xAD75, 0x9CD3,   // 0x1B00 (6912)
0x8410, 0x6B6D, 0x6B6D, 0x632C, 0x5AEB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5ACB, 0x52AA, 0x52AA, 0x4228, 0x4A49, 0x4228, 0x18C3, 0x0000,   // 0x1B10 (6928)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0861,   // 0x1B20 (6944)
0x4A69, 0x738E, 0x7BEF, 0x8430, 0x8C71, 0x9492, 0x9CF3, 0x9CF3, 0xA514, 0xB596, 0xB5B6, 0xBDF7, 0xC638, 0xCE79, 0xCE59, 0xCE59,   // 0x1B30 (6960)
0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE59, 0xCE79, 0xCE79, 0xCE59, 0xCE79, 0xCE79, 0xCE59, 0xCE59, 0xD69A, 0xCE79, 0xCE59,   // 0x1B40 (6976)
0xCE59, 0xCE59, 0xC618, 0xC618, 0xC618, 0xC638, 0xCE59, 0xD69A, 0xCE59, 0xC618, 0xC638, 0xCE79, 0xD69A, 0xCE59, 0xCE79, 0xCE59,   // 0x1B50 (6992)
0xC618, 0xC638, 0xB5B6, 0xA514, 0x94B2, 0x9492, 0x8C71, 0x94B2, 0x94B2, 0xA534, 0xAD75, 0xB5B6, 0xAD75, 0x9492, 0x9492, 0x7BCF,   // 0x1B60 (7008)
0x6B4D, 0x632C, 0x630C, 0x630C, 0x630C, 0x630C, 0x5AEB, 0x52AA, 0x52AA, 0x528A, 0x4A49, 0x4A49, 0x2945, 0x0000, 0x0000, 0x0000,   // 0x1B70 (7024)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x18E3,   // 0x1B80 (7040)
0x632C, 0x73AE, 0x7BCF, 0x7BEF, 0x8C51, 0x94B2, 0x9CD3, 0xA514, 0xAD75, 0xB5B6, 0xBDD7, 0xBDD7, 0xC618, 0xC638, 0xC618, 0xCE59,   // 0x1B90 (7056)
0xD69A, 0xCE79, 0xCE79, 0xCE59, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE59, 0xCE79, 0xCE79, 0xCE59, 0xCE59, 0xCE59, 0xCE59, 0xC638,   // 0x1BA0 (7072)
0xC638, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE59, 0xCE79, 0xCE59, 0xC638, 0xCE59, 0xCE79, 0xCE79, 0xCE59, 0xCE79, 0xC638, 0xC618,   // 0x1BB0 (7088)
0xBDD7, 0xA534, 0xA514, 0x8C71, 0x8C51, 0x8430, 0x8C51, 0xA534, 0xB5B6, 0xB5B6, 0xA534, 0xA534, 0x8C71, 0x8410, 0x7BCF, 0x6B6D,   // 0x1BC0 (7104)
0x630C, 0x630C, 0x632C, 0x630C, 0x5AEB, 0x52AA, 0x52AA, 0x5ACB, 0x5ACB, 0x4A69, 0x31A6, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1BD0 (7120)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x31A6,   // 0x1BE0 (7136)
0x6B6D, 0x73AE, 0x7BCF, 0x8410, 0x8C71, 0x94B2, 0x9CF3, 0xA534, 0xB596, 0xB5B6, 0xB596, 0xBDD7, 0xC618, 0xC618, 0xC618, 0xC638,   // 0x1BF0 (7152)
0xCE79, 0xD69A, 0xCE59, 0xCE79, 0xCE59, 0xCE59, 0xCE79, 0xD69A, 0xCE79, 0xC638, 0xC618, 0xBDF7, 0xC618, 0xC618, 0xBDD7, 0xBDF7,   // 0x1C00 (7168)
0xC638, 0xCE59, 0xCE79, 0xCE59, 0xC618, 0xBDF7, 0xBDD7, 0xBDF7, 0xBDF7, 0xC618, 0xC618, 0xC618, 0xBDD7, 0xB5B6, 0xB5B6, 0xAD55,   // 0x1C10 (7184)
0xA514, 0xAD55, 0x9492, 0x8430, 0x8410, 0x9CD3, 0xBDD7, 0xB596, 0xB596, 0xAD55, 0xA514, 0x9CD3, 0x8430, 0x738E, 0x6B4D, 0x6B4D,   // 0x1C20 (7200)
0x6B4D, 0x632C, 0x632C, 0x5AEB, 0x52AA, 0x52AA, 0x52AA, 0x528A, 0x39E7, 0x10A2, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1C30 (7216)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x4228,   // 0x1C40 (7232)
0x6B6D, 0x738E, 0x7BCF, 0x8430, 0x9492, 0x94B2, 0xA514, 0xAD75, 0xAD75, 0xB596, 0xB5B6, 0xB5B6, 0xBDF7, 0xC618, 0xC618, 0xBDF7,   // 0x1C50 (7248)
0xCE59, 0xCE59, 0xC638, 0xCE59, 0xC638, 0xC638, 0xCE59, 0xC638, 0xC618, 0xC638, 0xC638, 0xBDF7, 0xBDF7, 0xC618, 0xBDF7, 0xBDD7,   // 0x1C60 (7264)
0xBDF7, 0xBDF7, 0xBDF7, 0xC618, 0xC618, 0xBDD7, 0xBDF7, 0xBDF7, 0xBDD7, 0xBDF7, 0xC618, 0xBDD7, 0xB5B6, 0xB5B6, 0xB5B6, 0xB596,   // 0x1C70 (7280)
0xB596, 0xAD75, 0x94B2, 0x8C51, 0xAD55, 0xB596, 0x9CD3, 0x9CD3, 0x9CF3, 0x9CD3, 0x9CD3, 0x8C71, 0x73AE, 0x6B6D, 0x6B6D, 0x6B6D,   // 0x1C80 (7296)
0x6B4D, 0x73AE, 0x738E, 0x5AEB, 0x528A, 0x4A49, 0x4228, 0x2104, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1C90 (7312)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0861, 0x4A69,   // 0x1CA0 (7328)
0x6B6D, 0x73AE, 0x7BEF, 0x8C51, 0x94B2, 0xA514, 0xA534, 0xAD75, 0xB596, 0xB596, 0xB5B6, 0xBDD7, 0xBDD7, 0xBDF7, 0xBDD7, 0xC638,   // 0x1CB0 (7344)
0xCE59, 0xCE59, 0xC638, 0xC638, 0xC618, 0xBDF7, 0xBDF7, 0xC618, 0xC618, 0xC638, 0xC638, 0xC618, 0xC638, 0xC638, 0xBDF7, 0xBDD7,   // 0x1CC0 (7360)
0xBDD7, 0xBDD7, 0xBDF7, 0xC638, 0xC638, 0xC618, 0xBDF7, 0xBDF7, 0xBDF7, 0xC618, 0xC618, 0xC618, 0xBDD7, 0xB5B6, 0xB596, 0xBDD7,   // 0x1CD0 (7376)
0xB5B6, 0xA514, 0x9CD3, 0xA514, 0x9CF3, 0x9492, 0x9CF3, 0xA534, 0x9CD3, 0x94B2, 0x8C71, 0x7BCF, 0x738E, 0x632C, 0x6B6D, 0x73AE,   // 0x1CE0 (7392)
0x7BCF, 0x6B6D, 0x5ACB, 0x4A69, 0x4228, 0x2124, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1CF0 (7408)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x18C3, 0x52AA,   // 0x1D00 (7424)
0x738E, 0x73AE, 0x7BEF, 0x8C51, 0x9CD3, 0x9CF3, 0xA534, 0xAD75, 0xAD75, 0xB596, 0xB596, 0xB5B6, 0xB596, 0xBDD7, 0xC618, 0xC618,   // 0x1D10 (7440)
0xC618, 0xC618, 0xC618, 0xBDF7, 0xB5B6, 0xB596, 0xB5B6, 0xBDF7, 0xCE59, 0xCE59, 0xBDF7, 0xC618, 0xC618, 0xBDD7, 0xB5B6, 0xBDD7,   // 0x1D20 (7456)
0xBDF7, 0xBDD7, 0xBDD7, 0xBDF7, 0xBDD7, 0xBDD7, 0xBDD7, 0xBDD7, 0xBDF7, 0xBDF7, 0xBDD7, 0xB5B6, 0xB5B6, 0xAD75, 0xAD55, 0x9CF3,   // 0x1D30 (7472)
0x94B2, 0xA514, 0xA514, 0x9CD3, 0x94B2, 0x9CD3, 0x8C71, 0x8C51, 0x9492, 0x8C51, 0x6B6D, 0x632C, 0x632C, 0x6B4D, 0x6B6D, 0x6B4D,   // 0x1D40 (7488)
0x5AEB, 0x528A, 0x4A69, 0x3186, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1D50 (7504)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x18C3, 0x5ACB,   // 0x1D60 (7520)
0x6B4D, 0x738E, 0x8410, 0x8C71, 0x94B2, 0x9CF3, 0xA514, 0x9CF3, 0xA514, 0xA534, 0xAD75, 0xB596, 0xB596, 0xB5B6, 0xBDD7, 0xBDD7,   // 0x1D70 (7536)
0xB5B6, 0xBDF7, 0xC618, 0xBDD7, 0xB596, 0xB596, 0xB5B6, 0xBDF7, 0xBDF7, 0xBDD7, 0xBDF7, 0xBDF7, 0xBDF7, 0xBDD7, 0xB5B6, 0xB5B6,   // 0x1D80 (7552)
0xB5B6, 0xBDD7, 0xBDD7, 0xB5B6, 0xB596, 0xB5B6, 0xB5B6, 0xB596, 0xB596, 0xAD75, 0xAD75, 0xAD75, 0xA534, 0xA534, 0xA534, 0xA514,   // 0x1D90 (7568)
0xA534, 0x9CF3, 0x8C71, 0x9492, 0x8C51, 0x7BCF, 0x7BEF, 0x73AE, 0x6B6D, 0x630C, 0x632C, 0x6B4D, 0x630C, 0x5AEB, 0x5ACB, 0x52AA,   // 0x1DA0 (7584)
0x4A69, 0x31A6, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1DB0 (7600)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x18E3, 0x52AA,   // 0x1DC0 (7616)
0x6B6D, 0x73AE, 0x8410, 0x8C51, 0x9492, 0x94B2, 0x94B2, 0x9CD3, 0x9CF3, 0xA514, 0xAD55, 0xAD75, 0xAD75, 0xAD75, 0xB596, 0xB5B6,   // 0x1DD0 (7632)
0xB5B6, 0xBDD7, 0xBDD7, 0xB5B6, 0xAD75, 0xB596, 0xB596, 0xB596, 0xBDD7, 0xBDF7, 0xBDF7, 0xBDF7, 0xBDF7, 0xBDD7, 0xB5B6, 0xB596,   // 0x1DE0 (7648)
0xB596, 0xB596, 0xB5B6, 0xB5B6, 0xB596, 0xB596, 0xB596, 0xB596, 0xB596, 0xAD75, 0xAD55, 0xAD55, 0xAD75, 0xAD75, 0xA534, 0x9CF3,   // 0x1DF0 (7664)
0x9CD3, 0x9492, 0x8C71, 0x7BEF, 0x6B6D, 0x6B6D, 0x6B6D, 0x632C, 0x6B4D, 0x6B4D, 0x632C, 0x5AEB, 0x5ACB, 0x528A, 0x4A69, 0x31A6,   // 0x1E00 (7680)
0x0861, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1E10 (7696)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0000, 0x18C3, 0x5ACB,   // 0x1E20 (7712)
0x738E, 0x73AE, 0x8410, 0x8430, 0x8C51, 0x8C71, 0x94B2, 0x9CD3, 0x9CD3, 0x9CF3, 0xA534, 0xAD75, 0xAD55, 0xAD55, 0xAD75, 0xAD75,   // 0x1E30 (7728)
0xAD75, 0xB596, 0xB5B6, 0xB596, 0xAD75, 0xAD75, 0xB5B6, 0xB5B6, 0xBDD7, 0xBDD7, 0xB596, 0xBDD7, 0xBDD7, 0xBDD7, 0xB5B6, 0xB596,   // 0x1E40 (7744)
0xAD75, 0xAD75, 0xAD75, 0xAD75, 0xAD75, 0xB5B6, 0xBDD7, 0xB596, 0xAD75, 0xAD55, 0xAD55, 0xAD55, 0xAD55, 0xA534, 0xA514, 0x9CD3,   // 0x1E50 (7760)
0x94B2, 0x8430, 0x6B6D, 0x6B4D, 0x73AE, 0x738E, 0x6B4D, 0x632C, 0x5ACB, 0x5ACB, 0x52AA, 0x528A, 0x4A49, 0x31A6, 0x0861, 0x0000,   // 0x1E60 (7776)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1E70 (7792)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x18C3, 0x52AA,   // 0x1E80 (7808)
0x6B6D, 0x73AE, 0x7BCF, 0x7BEF, 0x8430, 0x8C71, 0x9492, 0x94B2, 0x9CD3, 0x9CF3, 0xA534, 0xA534, 0xA514, 0xA534, 0xAD55, 0xAD55,   // 0x1E90 (7824)
0xAD55, 0xAD75, 0xAD75, 0xAD75, 0xAD75, 0xAD75, 0xAD75, 0xB596, 0xAD75, 0xAD75, 0xAD75, 0xAD75, 0xAD75, 0xB5B6, 0xB5B6, 0xB596,   // 0x1EA0 (7840)
0xAD75, 0xAD55, 0xAD75, 0xAD75, 0xAD75, 0xB596, 0xAD75, 0xAD75, 0xAD55, 0xA514, 0xA534, 0xA534, 0xA514, 0xA514, 0x9CD3, 0x8C71,   // 0x1EB0 (7856)
0x8410, 0x7BCF, 0x7BEF, 0x8410, 0x73AE, 0x632C, 0x5ACB, 0x528A, 0x52AA, 0x4A69, 0x4A49, 0x3186, 0x0841, 0x0000, 0x0000, 0x0000,   // 0x1EC0 (7872)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1ED0 (7888)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1082, 0x4228,   // 0x1EE0 (7904)
0x6B6D, 0x73AE, 0x7BCF, 0x7BEF, 0x8410, 0x8C51, 0x8C51, 0x9492, 0x94B2, 0x9CF3, 0xA514, 0xA514, 0xA514, 0xA514, 0xAD55, 0xAD55,   // 0x1EF0 (7920)
0xAD55, 0xAD55, 0xAD55, 0xAD55, 0xA534, 0xA534, 0xAD75, 0xAD75, 0xAD75, 0xAD55, 0xA534, 0xAD55, 0xB596, 0xAD75, 0xAD55, 0xAD75,   // 0x1F00 (7936)
0xAD75, 0xAD75, 0xAD55, 0xAD55, 0xAD55, 0xA534, 0xA534, 0xA534, 0x9CF3, 0xA534, 0xAD55, 0x9CF3, 0x9CD3, 0x94B2, 0x8430, 0x7BEF,   // 0x1F10 (7952)
0x7BEF, 0x7BEF, 0x7BCF, 0x6B4D, 0x5AEB, 0x52AA, 0x4A69, 0x4A69, 0x4228, 0x2965, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1F20 (7968)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1F30 (7984)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0000, 0x0000, 0x0000, 0x0020, 0x31A6,   // 0x1F40 (8000)
0x6B4D, 0x73AE, 0x73AE, 0x7BCF, 0x7BCF, 0x8410, 0x8C51, 0x8C71, 0x9492, 0x9492, 0x9CD3, 0x9CD3, 0x9CF3, 0xA514, 0xA514, 0xA534,   // 0x1F50 (8016)
0xA534, 0xA514, 0xA514, 0xA534, 0xA534, 0xAD55, 0xAD75, 0xB596, 0xAD55, 0xAD55, 0xAD75, 0xAD75, 0xAD75, 0xAD55, 0xA534, 0xA534,   // 0x1F60 (8032)
0xA534, 0xA534, 0xA534, 0xA514, 0x9CD3, 0x9CD3, 0x9CF3, 0x9CF3, 0xA514, 0xA514, 0x9CD3, 0x94B2, 0x8C51, 0x7BEF, 0x7BCF, 0x73AE,   // 0x1F70 (8048)
0x738E, 0x632C, 0x5ACB, 0x52AA, 0x528A, 0x4A49, 0x4208, 0x2104, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1F80 (8064)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1F90 (8080)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x2104,   // 0x1FA0 (8096)
0x5ACB, 0x73AE, 0x73AE, 0x7BCF, 0x7BEF, 0x8410, 0x8430, 0x8430, 0x8430, 0x8C51, 0x8C71, 0x9492, 0x9492, 0x94B2, 0x9CD3, 0x9CD3,   // 0x1FB0 (8112)
0x9CF3, 0x9CF3, 0xA514, 0xA514, 0xA514, 0xA534, 0xAD75, 0xAD55, 0xA514, 0xA534, 0xA534, 0xAD55, 0xA534, 0xA514, 0x9CF3, 0x9CD3,   // 0x1FC0 (8128)
0x9CD3, 0x9CD3, 0x9CD3, 0x9CF3, 0x9CD3, 0x9CD3, 0xA534, 0xA534, 0x9CD3, 0x94B2, 0x8C71, 0x8430, 0x7BEF, 0x73AE, 0x6B6D, 0x630C,   // 0x1FD0 (8144)
0x5ACB, 0x528A, 0x528A, 0x4A49, 0x31A6, 0x10A2, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1FE0 (8160)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1FF0 (8176)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1082,   // 0x2000 (8192)
0x39E7, 0x6B4D, 0x738E, 0x73AE, 0x73AE, 0x7BCF, 0x7BEF, 0x8410, 0x8410, 0x8430, 0x8C51, 0x8C51, 0x8C71, 0x9492, 0x9492, 0x9492,   // 0x2010 (8208)
0x94B2, 0x9CD3, 0x9CD3, 0x94B2, 0x9CD3, 0xA514, 0xA534, 0x9CF3, 0x9CD3, 0xA514, 0xA514, 0x9CF3, 0x9CF3, 0x9CF3, 0x9CD3, 0x9492,   // 0x2020 (8224)
0x8C71, 0x9492, 0x9CD3, 0x9CD3, 0x94B2, 0x9CF3, 0x94B2, 0x8C71, 0x8C51, 0x8410, 0x7BEF, 0x73AE, 0x6B4D, 0x632C, 0x5AEB, 0x52AA,   // 0x2030 (8240)
0x4A69, 0x4208, 0x2124, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2040 (8256)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2050 (8272)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2060 (8288)
0x2104, 0x4A69, 0x6B4D, 0x738E, 0x738E, 0x73AE, 0x73AE, 0x7BCF, 0x7BEF, 0x7BEF, 0x7BEF, 0x8410, 0x8C51, 0x8C51, 0x8C51, 0x8C71,   // 0x2070 (8304)
0x9492, 0x9492, 0x9492, 0x9492, 0x94B2, 0x9CD3, 0x9CF3, 0x9CF3, 0x9CF3, 0x9CD3, 0x9CD3, 0x94B2, 0x94B2, 0x94B2, 0x9492, 0x9492,   // 0x2080 (8320)
0x9492, 0x8C71, 0x8C71, 0x8C71, 0x8C51, 0x8C51, 0x8430, 0x8410, 0x73AE, 0x6B6D, 0x632C, 0x630C, 0x5AEB, 0x52AA, 0x4228, 0x3186,   // 0x2090 (8336)
0x1082, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x20A0 (8352)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x20B0 (8368)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x20C0 (8384)
0x0841, 0x2965, 0x52AA, 0x632C, 0x6B6D, 0x738E, 0x738E, 0x73AE, 0x73AE, 0x73AE, 0x7BCF, 0x7BEF, 0x7BEF, 0x8410, 0x8C51, 0x8C51,   // 0x20D0 (8400)
0x8C51, 0x8C71, 0x8C71, 0x8C51, 0x8C71, 0x8C71, 0x9492, 0x94B2, 0x9492, 0x8C71, 0x8C71, 0x8C71, 0x8C51, 0x8430, 0x8430, 0x8430,   // 0x20E0 (8416)
0x8430, 0x8410, 0x8410, 0x8410, 0x8410, 0x7BCF, 0x6B6D, 0x632C, 0x632C, 0x5ACB, 0x5ACB, 0x4A49, 0x31A6, 0x10A2, 0x0000, 0x0000,   // 0x20F0 (8432)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2100 (8448)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2110 (8464)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2120 (8480)
0x0000, 0x0861, 0x31A6, 0x52AA, 0x630C, 0x6B4D, 0x6B4D, 0x6B6D, 0x6B6D, 0x6B6D, 0x73AE, 0x73AE, 0x73AE, 0x73AE, 0x73AE, 0x73AE,   // 0x2130 (8496)
0x7BCF, 0x8410, 0x7BEF, 0x7BEF, 0x7BEF, 0x7BEF, 0x7BEF, 0x7BEF, 0x7BEF, 0x7BEF, 0x7BCF, 0x73AE, 0x738E, 0x738E, 0x738E, 0x73AE,   // 0x2140 (8512)
0x738E, 0x6B4D, 0x6B4D, 0x6B4D, 0x632C, 0x630C, 0x5AEB, 0x52AA, 0x4A49, 0x3186, 0x18C3, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2150 (8528)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2160 (8544)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2170 (8560)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2180 (8576)
0x0000, 0x0000, 0x0861, 0x2945, 0x4228, 0x5ACB, 0x632C, 0x6B4D, 0x6B4D, 0x6B6D, 0x6B6D, 0x6B4D, 0x6B6D, 0x6B6D, 0x6B6D, 0x73AE,   // 0x2190 (8592)
0x738E, 0x6B6D, 0x6B6D, 0x738E, 0x738E, 0x6B4D, 0x6B4D, 0x6B6D, 0x6B6D, 0x6B4D, 0x6B4D, 0x6B4D, 0x632C, 0x632C, 0x632C, 0x632C,   // 0x21A0 (8608)
0x630C, 0x5AEB, 0x5ACB, 0x52AA, 0x528A, 0x4208, 0x2965, 0x10A2, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x21B0 (8624)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x21C0 (8640)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x21D0 (8656)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x21E0 (8672)
0x0000, 0x0000, 0x0000, 0x0020, 0x18C3, 0x2965, 0x4228, 0x5ACB, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x632C, 0x630C,   // 0x21F0 (8688)
0x630C, 0x630C, 0x632C, 0x6B6D, 0x6B6D, 0x6B4D, 0x630C, 0x630C, 0x5AEB, 0x5AEB, 0x5AEB, 0x5ACB, 0x5ACB, 0x5ACB, 0x52AA, 0x52AA,   // 0x2200 (8704)
0x4A69, 0x4208, 0x3186, 0x18E3, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2210 (8720)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2220 (8736)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2230 (8752)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2240 (8768)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x10A2, 0x2945, 0x39C7, 0x4A49, 0x4A69, 0x52AA, 0x5ACB, 0x5AEB, 0x5AEB, 0x5AEB,   // 0x2250 (8784)
0x5ACB, 0x5ACB, 0x5ACB, 0x5ACB, 0x5AEB, 0x5AEB, 0x5AEB, 0x5ACB, 0x52AA, 0x52AA, 0x4A69, 0x4228, 0x39E7, 0x31A6, 0x2945, 0x18C3,   // 0x2260 (8800)
0x0861, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2270 (8816)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2280 (8832)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2290 (8848)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22A0 (8864)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x1082, 0x18E3, 0x2124, 0x3186, 0x39C7, 0x39E7, 0x4208,   // 0x22B0 (8880)
0x4208, 0x39E7, 0x39C7, 0x39E7, 0x39E7, 0x39C7, 0x31A6, 0x3186, 0x2945, 0x18E3, 0x1082, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22C0 (8896)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22D0 (8912)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22E0 (8928)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22F0 (8944)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2300 (8960)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020,   // 0x2310 (8976)
0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2320 (8992)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2330 (9008)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2340 (9024)
0x0000, };
New.c
// Generated by  : ImageConverter 565 v2.3
// Generated from: MoonNew.jpg
// Time generated: 17/06/2022 8:18:05 AM
// Dimensions    : 95x95 pixels
// Size          : 18,050 Bytes
#include <avr/pgmspace.h>
const unsigned int New[0x2341] PROGMEM ={
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0010 (16)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0020 (32)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0030 (48)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0040 (64)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0050 (80)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0060 (96)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0070 (112)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0080 (128)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020,   // 0x0090 (144)
0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00A0 (160)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00B0 (176)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00C0 (192)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00D0 (208)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00E0 (224)
0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x00F0 (240)
0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0100 (256)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0110 (272)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0120 (288)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0130 (304)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x0140 (320)
0x0020, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x0861, 0x0861,   // 0x0150 (336)
0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000,   // 0x0160 (352)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0170 (368)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0180 (384)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0190 (400)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x01A0 (416)
0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861,   // 0x01B0 (432)
0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0020, 0x0000, 0x0000,   // 0x01C0 (448)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x01D0 (464)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x01E0 (480)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x01F0 (496)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0841, 0x0841, 0x0861,   // 0x0200 (512)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082,   // 0x0210 (528)
0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x0861, 0x0020, 0x0000,   // 0x0220 (544)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0230 (560)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0240 (576)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0250 (592)
0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861,   // 0x0260 (608)
0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x0270 (624)
0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0841,   // 0x0280 (640)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0290 (656)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x02A0 (672)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x02B0 (688)
0x0000, 0x0020, 0x0841, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x0861, 0x0861,   // 0x02C0 (704)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18C3,   // 0x02D0 (720)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861,   // 0x02E0 (736)
0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x02F0 (752)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0300 (768)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x0310 (784)
0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x0320 (800)
0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2,   // 0x0330 (816)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x1082,   // 0x0340 (832)
0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0350 (848)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0360 (864)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0841,   // 0x0370 (880)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082,   // 0x0380 (896)
0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2,   // 0x0390 (912)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x03A0 (928)
0x0861, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x03B0 (944)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x03C0 (960)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x03D0 (976)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x10A2,   // 0x03E0 (992)
0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x03F0 (1008)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x0400 (1024)
0x1082, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0410 (1040)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0420 (1056)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0841, 0x0841,   // 0x0430 (1072)
0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x0440 (1088)
0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x10A2,   // 0x0450 (1104)
0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x0460 (1120)
0x1082, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0470 (1136)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0480 (1152)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861,   // 0x0490 (1168)
0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x04A0 (1184)
0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x04B0 (1200)
0x1082, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x04C0 (1216)
0x1082, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x04D0 (1232)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x04E0 (1248)
0x0000, 0x0000, 0x0000, 0x0841, 0x0861, 0x0861, 0x0861, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082,   // 0x04F0 (1264)
0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18E3, 0x18E3, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x0500 (1280)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x0510 (1296)
0x10A2, 0x10A2, 0x1082, 0x10A2, 0x18C3, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x10A2,   // 0x0520 (1312)
0x10A2, 0x0861, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0530 (1328)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0540 (1344)
0x0000, 0x0841, 0x0861, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082,   // 0x0550 (1360)
0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x10A2,   // 0x0560 (1376)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2,   // 0x0570 (1392)
0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x1082, 0x10A2, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082,   // 0x0580 (1408)
0x1082, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0590 (1424)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841,   // 0x05A0 (1440)
0x0861, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x05B0 (1456)
0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2,   // 0x05C0 (1472)
0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x05D0 (1488)
0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082,   // 0x05E0 (1504)
0x1082, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x05F0 (1520)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x1082, 0x1082,   // 0x0600 (1536)
0x1082, 0x1082, 0x0861, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x0610 (1552)
0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x0620 (1568)
0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x0630 (1584)
0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082,   // 0x0640 (1600)
0x1082, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0650 (1616)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x0861, 0x1082, 0x10A2, 0x10A2,   // 0x0660 (1632)
0x1082, 0x0861, 0x0861, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082,   // 0x0670 (1648)
0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x0680 (1664)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x0690 (1680)
0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x06A0 (1696)
0x1082, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x06B0 (1712)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082,   // 0x06C0 (1728)
0x0861, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x06D0 (1744)
0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x06E0 (1760)
0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x06F0 (1776)
0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x2104, 0x2104, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x0861,   // 0x0700 (1792)
0x0861, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0710 (1808)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861,   // 0x0720 (1824)
0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3,   // 0x0730 (1840)
0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x0740 (1856)
0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x0750 (1872)
0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x0760 (1888)
0x0861, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0770 (1904)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0780 (1920)
0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3,   // 0x0790 (1936)
0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x07A0 (1952)
0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x10A2,   // 0x07B0 (1968)
0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x07C0 (1984)
0x0861, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x07D0 (2000)
0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082,   // 0x07E0 (2016)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2,   // 0x07F0 (2032)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x0800 (2048)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x0810 (2064)
0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x0820 (2080)
0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0830 (2096)
0x0000, 0x0000, 0x0000, 0x0841, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082,   // 0x0840 (2112)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x18C3,   // 0x0850 (2128)
0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2,   // 0x0860 (2144)
0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x0870 (2160)
0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861,   // 0x0880 (2176)
0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0890 (2192)
0x0000, 0x0841, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x08A0 (2208)
0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x08B0 (2224)
0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3,   // 0x08C0 (2240)
0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3,   // 0x08D0 (2256)
0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x1082, 0x0861,   // 0x08E0 (2272)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x08F0 (2288)
0x0861, 0x1082, 0x0861, 0x0861, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x0900 (2304)
0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x2104, 0x18E3, 0x18C3, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18E3,   // 0x0910 (2320)
0x2104, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18E3,   // 0x0920 (2336)
0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3,   // 0x0930 (2352)
0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0841, 0x0861, 0x1082, 0x1082, 0x0841,   // 0x0940 (2368)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x1082,   // 0x0950 (2384)
0x0861, 0x0841, 0x10A2, 0x18C3, 0x10A2, 0x0861, 0x0861, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x0960 (2400)
0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x2104, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x1082, 0x10A2, 0x18C3, 0x18E3, 0x18E3, 0x18E3,   // 0x0970 (2416)
0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3,   // 0x0980 (2432)
0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3,   // 0x0990 (2448)
0x2104, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x0861, 0x0020,   // 0x09A0 (2464)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0861, 0x1082, 0x0861,   // 0x09B0 (2480)
0x1082, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x09C0 (2496)
0x10A2, 0x18C3, 0x10A2, 0x18E3, 0x18E3, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3,   // 0x09D0 (2512)
0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x18C3,   // 0x09E0 (2528)
0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x2104,   // 0x09F0 (2544)
0x2104, 0x18E3, 0x2104, 0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x1082, 0x0841, 0x0000,   // 0x0A00 (2560)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x1082, 0x1082, 0x10A2, 0x18C3,   // 0x0A10 (2576)
0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x10A2, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2,   // 0x0A20 (2592)
0x10A2, 0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x18E3, 0x18E3, 0x18E3,   // 0x0A30 (2608)
0x2104, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x18E3,   // 0x0A40 (2624)
0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x18E3,   // 0x0A50 (2640)
0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x1082, 0x0861, 0x1082, 0x0861, 0x0000, 0x0000,   // 0x0A60 (2656)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0861, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x10A2,   // 0x0A70 (2672)
0x18C3, 0x10A2, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x10A2, 0x10A2, 0x10A2,   // 0x0A80 (2688)
0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x18E3, 0x18E3, 0x18E3, 0x2104,   // 0x0A90 (2704)
0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x18E3,   // 0x0AA0 (2720)
0x18E3, 0x18E3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x18E3,   // 0x0AB0 (2736)
0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0020, 0x0000, 0x0000,   // 0x0AC0 (2752)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0861, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x0AD0 (2768)
0x10A2, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3,   // 0x0AE0 (2784)
0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2104,   // 0x0AF0 (2800)
0x2104, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x18E3,   // 0x0B00 (2816)
0x18E3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x18C3, 0x18E3, 0x18E3,   // 0x0B10 (2832)
0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0841, 0x0000, 0x0000, 0x0000,   // 0x0B20 (2848)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082,   // 0x0B30 (2864)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3,   // 0x0B40 (2880)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2124, 0x2104, 0x2104, 0x2104,   // 0x0B50 (2896)
0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x18E3, 0x18E3,   // 0x0B60 (2912)
0x18C3, 0x10A2, 0x18C3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x18E3, 0x18E3,   // 0x0B70 (2928)
0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0020, 0x0000, 0x0000, 0x0000,   // 0x0B80 (2944)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x1082,   // 0x0B90 (2960)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x0BA0 (2976)
0x10A2, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2124, 0x2104, 0x18E3, 0x18E3, 0x18E3,   // 0x0BB0 (2992)
0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18C3,   // 0x0BC0 (3008)
0x10A2, 0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x18C3, 0x18E3, 0x18C3,   // 0x0BD0 (3024)
0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0BE0 (3040)
0x0000, 0x0000, 0x0000, 0x0000, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x18C3, 0x10A2,   // 0x0BF0 (3056)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x18C3,   // 0x0C00 (3072)
0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18E3, 0x2104, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x18E3,   // 0x0C10 (3088)
0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x18E3, 0x18E3,   // 0x0C20 (3104)
0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x10A2,   // 0x0C30 (3120)
0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0C40 (3136)
0x0000, 0x0000, 0x0020, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x1082,   // 0x0C50 (3152)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3,   // 0x0C60 (3168)
0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3,   // 0x0C70 (3184)
0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x18E3, 0x2104,   // 0x0C80 (3200)
0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x10A2,   // 0x0C90 (3216)
0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0CA0 (3232)
0x0000, 0x0841, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082,   // 0x0CB0 (3248)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18C3,   // 0x0CC0 (3264)
0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18C3,   // 0x0CD0 (3280)
0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x18E3,   // 0x0CE0 (3296)
0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x10A2,   // 0x0CF0 (3312)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0841, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0D00 (3328)
0x0861, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x0D10 (3344)
0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x0D20 (3360)
0x18C3, 0x18E3, 0x18E3, 0x2104, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x18C3,   // 0x0D30 (3376)
0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x1082,   // 0x0D40 (3392)
0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2,   // 0x0D50 (3408)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0861,   // 0x0D60 (3424)
0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2,   // 0x0D70 (3440)
0x18C3, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x0D80 (3456)
0x18E3, 0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18C3, 0x10A2, 0x10A2,   // 0x0D90 (3472)
0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082,   // 0x0DA0 (3488)
0x1082, 0x1082, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082,   // 0x0DB0 (3504)
0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x1082, 0x10A2,   // 0x0DC0 (3520)
0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18E3, 0x18C3, 0x10A2, 0x18E3, 0x18C3,   // 0x0DD0 (3536)
0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3,   // 0x0DE0 (3552)
0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x0DF0 (3568)
0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082,   // 0x0E00 (3584)
0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x10A2, 0x1082, 0x1082,   // 0x0E10 (3600)
0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x1082, 0x10A2, 0x18C3,   // 0x0E20 (3616)
0x18C3, 0x18C3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18C3, 0x1082,   // 0x0E30 (3632)
0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3,   // 0x0E40 (3648)
0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2,   // 0x0E50 (3664)
0x1082, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082,   // 0x0E60 (3680)
0x10A2, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x18C3, 0x18E3, 0x18C3, 0x1082, 0x10A2, 0x10A2,   // 0x0E70 (3696)
0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x1082, 0x10A2, 0x18E3, 0x18E3,   // 0x0E80 (3712)
0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18E3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x1082,   // 0x0E90 (3728)
0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x2104, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3,   // 0x0EA0 (3744)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x0EB0 (3760)
0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082,   // 0x0EC0 (3776)
0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x18C3, 0x18E3, 0x18C3, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x0ED0 (3792)
0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0000, 0x0000, 0x0000, 0x0020, 0x0861, 0x1082, 0x10A2, 0x18E3, 0x18E3, 0x18E3,   // 0x0EE0 (3808)
0x18E3, 0x18E3, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x18E3, 0x18E3, 0x2104, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x1082,   // 0x0EF0 (3824)
0x1082, 0x10A2, 0x18C3, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18C3,   // 0x0F00 (3840)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3,   // 0x0F10 (3856)
0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x10A2, 0x1082, 0x10A2,   // 0x0F20 (3872)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2,   // 0x0F30 (3888)
0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0000, 0x0000, 0x0000, 0x0020, 0x0861, 0x1082, 0x10A2, 0x18C3, 0x18E3, 0x18E3, 0x18E3,   // 0x0F40 (3904)
0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x10A2, 0x10A2, 0x18E3, 0x10A2, 0x1082, 0x10A2,   // 0x0F50 (3920)
0x10A2, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3,   // 0x0F60 (3936)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x18E3, 0x18E3, 0x2104, 0x18E3,   // 0x0F70 (3952)
0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x0F80 (3968)
0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x18C3, 0x10A2, 0x18C3, 0x10A2, 0x10A2,   // 0x0F90 (3984)
0x1082, 0x1082, 0x0861, 0x0841, 0x0000, 0x0000, 0x0000, 0x0020, 0x0861, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3,   // 0x0FA0 (4000)
0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x18C3, 0x18E3, 0x1082, 0x10A2, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x18C3,   // 0x0FB0 (4016)
0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18E3,   // 0x0FC0 (4032)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x2104, 0x18E3, 0x18E3, 0x2104, 0x18E3, 0x18C3,   // 0x0FD0 (4048)
0x10A2, 0x10A2, 0x1082, 0x1082, 0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082,   // 0x0FE0 (4064)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082,   // 0x0FF0 (4080)
0x1082, 0x0861, 0x0841, 0x0020, 0x0000, 0x0000, 0x0020, 0x0861, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3,   // 0x1000 (4096)
0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2,   // 0x1010 (4112)
0x10A2, 0x10A2, 0x1082, 0x10A2, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18C3,   // 0x1020 (4128)
0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3,   // 0x1030 (4144)
0x10A2, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x18E3, 0x18E3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082,   // 0x1040 (4160)
0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082,   // 0x1050 (4176)
0x1082, 0x0861, 0x0020, 0x0000, 0x0000, 0x0020, 0x0861, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x18E3, 0x18E3,   // 0x1060 (4192)
0x18E3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x18C3, 0x18C3,   // 0x1070 (4208)
0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x18E3,   // 0x1080 (4224)
0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x18E3, 0x18E3, 0x2104, 0x18E3, 0x18E3, 0x18C3,   // 0x1090 (4240)
0x1082, 0x10A2, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x18C3, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x10A2,   // 0x10A0 (4256)
0x1082, 0x1082, 0x1082, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861,   // 0x10B0 (4272)
0x0861, 0x0020, 0x0000, 0x0000, 0x0020, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x18E3, 0x18E3, 0x18C3,   // 0x10C0 (4288)
0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x18E3,   // 0x10D0 (4304)
0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x2104, 0x2124, 0x2104, 0x18E3,   // 0x10E0 (4320)
0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x18C3, 0x18E3, 0x2104, 0x18E3, 0x18E3, 0x2104, 0x18E3, 0x18C3, 0x18E3, 0x18C3,   // 0x10F0 (4336)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18C3, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x1100 (4352)
0x1082, 0x10A2, 0x18C3, 0x18E3, 0x2104, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861,   // 0x1110 (4368)
0x0020, 0x0000, 0x0000, 0x0020, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x18E3, 0x18E3, 0x10A2, 0x10A2,   // 0x1120 (4384)
0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18C3,   // 0x1130 (4400)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104,   // 0x1140 (4416)
0x2104, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3,   // 0x1150 (4432)
0x18E3, 0x2104, 0x18E3, 0x18E3, 0x2104, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x1160 (4448)
0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0020,   // 0x1170 (4464)
0x0000, 0x0000, 0x0841, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x10A2,   // 0x1180 (4480)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x10A2, 0x10A2, 0x18C3,   // 0x1190 (4496)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104,   // 0x11A0 (4512)
0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x18E3,   // 0x11B0 (4528)
0x2104, 0x18E3, 0x18E3, 0x18E3, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3,   // 0x11C0 (4544)
0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0841, 0x0020, 0x0000,   // 0x11D0 (4560)
0x0000, 0x0841, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x2104, 0x18E3, 0x2104, 0x18E3, 0x18C3, 0x1082, 0x1082,   // 0x11E0 (4576)
0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3,   // 0x11F0 (4592)
0x18C3, 0x18C3, 0x18E3, 0x2104, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104,   // 0x1200 (4608)
0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104,   // 0x1210 (4624)
0x18E3, 0x18C3, 0x18C3, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x18C3, 0x18E3, 0x18C3,   // 0x1220 (4640)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0841, 0x0020, 0x0000, 0x0000,   // 0x1230 (4656)
0x0841, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082,   // 0x1240 (4672)
0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2,   // 0x1250 (4688)
0x18C3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104,   // 0x1260 (4704)
0x2104, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2124, 0x2124, 0x2104, 0x2104, 0x2104, 0x2104, 0x18E3,   // 0x1270 (4720)
0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18C3,   // 0x1280 (4736)
0x10A2, 0x18C3, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0841, 0x0020, 0x0000, 0x0000, 0x0841,   // 0x1290 (4752)
0x1082, 0x1082, 0x1082, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x18C3, 0x10A2, 0x1082,   // 0x12A0 (4768)
0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x18C3,   // 0x12B0 (4784)
0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x18E3,   // 0x12C0 (4800)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2124, 0x2124, 0x2124, 0x2104, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x18C3,   // 0x12D0 (4816)
0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2,   // 0x12E0 (4832)
0x18E3, 0x18E3, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0020, 0x0000, 0x0000, 0x0841, 0x0861,   // 0x12F0 (4848)
0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x18C3,   // 0x1300 (4864)
0x18C3, 0x18E3, 0x18E3, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18C3,   // 0x1310 (4880)
0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x18E3, 0x2104, 0x2104, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104,   // 0x1320 (4896)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2124, 0x2124, 0x2124, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x1082,   // 0x1330 (4912)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x18C3,   // 0x1340 (4928)
0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0000, 0x0000, 0x0000, 0x0020, 0x0861, 0x1082,   // 0x1350 (4944)
0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3,   // 0x1360 (4960)
0x18E3, 0x18E3, 0x10A2, 0x18C3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x1370 (4976)
0x10A2, 0x18E3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104,   // 0x1380 (4992)
0x2104, 0x2104, 0x2124, 0x2104, 0x2104, 0x2104, 0x2104, 0x2124, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x10A2,   // 0x1390 (5008)
0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3,   // 0x13A0 (5024)
0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0000, 0x0000, 0x0000, 0x0020, 0x0861, 0x1082, 0x1082,   // 0x13B0 (5040)
0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2104, 0x18C3, 0x18C3,   // 0x13C0 (5056)
0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x13D0 (5072)
0x18C3, 0x18E3, 0x18C3, 0x18C3, 0x2104, 0x2104, 0x2104, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104,   // 0x13E0 (5088)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x18E3, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x1082,   // 0x13F0 (5104)
0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x1082, 0x0861, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18C3,   // 0x1400 (5120)
0x18C3, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0861, 0x1082, 0x1082, 0x10A2,   // 0x1410 (5136)
0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18C3,   // 0x1420 (5152)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x1082, 0x10A2,   // 0x1430 (5168)
0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104,   // 0x1440 (5184)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2,   // 0x1450 (5200)
0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1460 (5216)
0x10A2, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x1470 (5232)
0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x18E3, 0x18E3, 0x18C3,   // 0x1480 (5248)
0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x18E3, 0x18E3, 0x18E3,   // 0x1490 (5264)
0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2124, 0x2124, 0x2124, 0x2104,   // 0x14A0 (5280)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x14B0 (5296)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x18C3, 0x1082,   // 0x14C0 (5312)
0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2,   // 0x14D0 (5328)
0x18C3, 0x18C3, 0x18E3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18C3, 0x2104,   // 0x14E0 (5344)
0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x2104, 0x2124, 0x2104, 0x2104,   // 0x14F0 (5360)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x2104, 0x2124, 0x2124, 0x2124, 0x2124, 0x2124, 0x2104,   // 0x1500 (5376)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x1510 (5392)
0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x18C3, 0x10A2, 0x18C3, 0x18E3, 0x18C3, 0x0861, 0x0841,   // 0x1520 (5408)
0x0841, 0x0020, 0x0020, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3,   // 0x1530 (5424)
0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x10A2, 0x18C3, 0x18C3, 0x2104, 0x18E3,   // 0x1540 (5440)
0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x2124,   // 0x1550 (5456)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104,   // 0x1560 (5472)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x1570 (5488)
0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x10A2, 0x0861, 0x0841, 0x0841,   // 0x1580 (5504)
0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x1590 (5520)
0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x18E3, 0x18E3, 0x2104, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18E3, 0x2124, 0x2104, 0x18E3,   // 0x15A0 (5536)
0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x2124, 0x2104,   // 0x15B0 (5552)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104,   // 0x15C0 (5568)
0x2104, 0x2104, 0x2124, 0x2104, 0x2124, 0x2104, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x15D0 (5584)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x1082, 0x0841, 0x0841, 0x0020, 0x0020,   // 0x15E0 (5600)
0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3,   // 0x15F0 (5616)
0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x18E3,   // 0x1600 (5632)
0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104,   // 0x1610 (5648)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2124,   // 0x1620 (5664)
0x2124, 0x2124, 0x2124, 0x2124, 0x2104, 0x2104, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x1630 (5680)
0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x0861, 0x1082, 0x10A2, 0x18E3, 0x18C3, 0x0861, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020,   // 0x1640 (5696)
0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3,   // 0x1650 (5712)
0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2124, 0x2104, 0x2104, 0x18E3,   // 0x1660 (5728)
0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x18E3, 0x2104, 0x2104, 0x2104,   // 0x1670 (5744)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2124, 0x2124,   // 0x1680 (5760)
0x2124, 0x2124, 0x2124, 0x2104, 0x2104, 0x18E3, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x1690 (5776)
0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x18C3, 0x18C3, 0x10A2, 0x0861, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020,   // 0x16A0 (5792)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2, 0x1082, 0x10A2, 0x18C3, 0x18E3,   // 0x16B0 (5808)
0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2124, 0x2104, 0x2104, 0x18E3, 0x18E3,   // 0x16C0 (5824)
0x2104, 0x2104, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2124,   // 0x16D0 (5840)
0x2104, 0x2104, 0x2104, 0x2124, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2124, 0x2124, 0x2104, 0x2124, 0x2124, 0x2104,   // 0x16E0 (5856)
0x2104, 0x2104, 0x18E3, 0x18E3, 0x18E3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x16F0 (5872)
0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000,   // 0x1700 (5888)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18E3,   // 0x1710 (5904)
0x18E3, 0x18E3, 0x2104, 0x2104, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2124, 0x2104, 0x2104, 0x2104, 0x2124, 0x2104,   // 0x1720 (5920)
0x2104, 0x2124, 0x2104, 0x2104, 0x2124, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2124, 0x2104,   // 0x1730 (5936)
0x18E3, 0x2104, 0x2124, 0x2124, 0x2104, 0x2104, 0x2104, 0x2104, 0x2124, 0x2124, 0x2124, 0x2104, 0x2124, 0x2104, 0x2104, 0x18E3,   // 0x1740 (5952)
0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x18C3, 0x2104, 0x2104, 0x18C3, 0x1082, 0x0861, 0x0861, 0x0861, 0x1082,   // 0x1750 (5968)
0x1082, 0x1082, 0x1082, 0x1082, 0x18C3, 0x18C3, 0x1082, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000,   // 0x1760 (5984)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x18E3,   // 0x1770 (6000)
0x18E3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2124, 0x2124, 0x2124, 0x2104, 0x2124, 0x2124, 0x2124,   // 0x1780 (6016)
0x2124, 0x2124, 0x2124, 0x2124, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x18E3,   // 0x1790 (6032)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2124, 0x2124, 0x2124, 0x2124, 0x2104, 0x18E3, 0x18E3,   // 0x17A0 (6048)
0x18C3, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x0861, 0x0861, 0x1082, 0x1082, 0x10A2,   // 0x17B0 (6064)
0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x0841, 0x0020, 0x0020, 0x0020, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x17C0 (6080)
0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x18E3,   // 0x17D0 (6096)
0x18E3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2124, 0x2124, 0x2124, 0x2124, 0x2124, 0x2124, 0x2124,   // 0x17E0 (6112)
0x2124, 0x2104, 0x2104, 0x2124, 0x2124, 0x2124, 0x2124, 0x2124, 0x2104, 0x2104, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104,   // 0x17F0 (6128)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2124, 0x2104, 0x2104, 0x18E3, 0x18C3, 0x18C3,   // 0x1800 (6144)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18E3, 0x18C3, 0x1082, 0x1082, 0x10A2, 0x1082, 0x10A2, 0x10A2,   // 0x1810 (6160)
0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1820 (6176)
0x0000, 0x0000, 0x0000, 0x0020, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3,   // 0x1830 (6192)
0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2124, 0x2124, 0x2124, 0x2124, 0x2124, 0x2124, 0x2124,   // 0x1840 (6208)
0x2124, 0x2104, 0x2124, 0x2124, 0x2124, 0x2124, 0x2124, 0x2104, 0x2104, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104,   // 0x1850 (6224)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2124, 0x2104, 0x2104, 0x2104, 0x18E3, 0x18C3, 0x18C3,   // 0x1860 (6240)
0x10A2, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861,   // 0x1870 (6256)
0x0861, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1880 (6272)
0x0000, 0x0000, 0x0000, 0x0841, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3,   // 0x1890 (6288)
0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2124, 0x2124, 0x2124, 0x2124, 0x2124, 0x2124, 0x2124, 0x2945, 0x2945,   // 0x18A0 (6304)
0x2124, 0x2124, 0x2124, 0x2124, 0x2124, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104,   // 0x18B0 (6320)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2124, 0x2124, 0x2124, 0x2104, 0x2104, 0x2104, 0x18C3, 0x18C3, 0x18C3,   // 0x18C0 (6336)
0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0861,   // 0x18D0 (6352)
0x10A2, 0x1082, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x18E0 (6368)
0x0000, 0x0000, 0x0020, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3,   // 0x18F0 (6384)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2124, 0x2124, 0x2124, 0x2124, 0x2124, 0x2124, 0x2124, 0x2124,   // 0x1900 (6400)
0x2124, 0x2124, 0x2124, 0x2124, 0x2104, 0x2104, 0x2104, 0x2104, 0x2124, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104,   // 0x1910 (6416)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2124, 0x2124, 0x2124, 0x2104, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x18E3, 0x18E3,   // 0x1920 (6432)
0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x1082,   // 0x1930 (6448)
0x1082, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1940 (6464)
0x0000, 0x0000, 0x0841, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3,   // 0x1950 (6480)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2124, 0x2124, 0x2124, 0x2124, 0x2124, 0x2124, 0x2124, 0x2124, 0x2124,   // 0x1960 (6496)
0x2124, 0x2124, 0x2124, 0x2124, 0x2104, 0x2104, 0x2124, 0x2124, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104,   // 0x1970 (6512)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18E3, 0x18E3,   // 0x1980 (6528)
0x2104, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x1082, 0x1082,   // 0x1990 (6544)
0x0861, 0x0861, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x19A0 (6560)
0x0000, 0x0020, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2104,   // 0x19B0 (6576)
0x2104, 0x2104, 0x2104, 0x2124, 0x2124, 0x2104, 0x2124, 0x2124, 0x2124, 0x2124, 0x2124, 0x2124, 0x2124, 0x2124, 0x2124, 0x2124,   // 0x19C0 (6592)
0x2124, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104,   // 0x19D0 (6608)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2124, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x18C3, 0x18E3, 0x2104,   // 0x19E0 (6624)
0x2104, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861,   // 0x19F0 (6640)
0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1A00 (6656)
0x0000, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104,   // 0x1A10 (6672)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2124, 0x2124, 0x2124, 0x2124, 0x2124, 0x2124, 0x2124, 0x2124, 0x2124,   // 0x1A20 (6688)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x2104, 0x2104,   // 0x1A30 (6704)
0x2104, 0x2104, 0x2104, 0x2124, 0x2124, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x18E3, 0x18E3, 0x18E3,   // 0x1A40 (6720)
0x18E3, 0x18C3, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0861, 0x0861, 0x0020,   // 0x1A50 (6736)
0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1A60 (6752)
0x0020, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2124,   // 0x1A70 (6768)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2124, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104,   // 0x1A80 (6784)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2104,   // 0x1A90 (6800)
0x2104, 0x2104, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18C3,   // 0x1AA0 (6816)
0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020,   // 0x1AB0 (6832)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1AC0 (6848)
0x0841, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104,   // 0x1AD0 (6864)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104,   // 0x1AE0 (6880)
0x2104, 0x2104, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x18E3, 0x2104,   // 0x1AF0 (6896)
0x2104, 0x2104, 0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18E3, 0x2104, 0x18C3, 0x10A2,   // 0x1B00 (6912)
0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0841, 0x0841, 0x0020, 0x0841, 0x0020, 0x0000, 0x0000,   // 0x1B10 (6928)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x1B20 (6944)
0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104,   // 0x1B30 (6960)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104,   // 0x1B40 (6976)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104,   // 0x1B50 (6992)
0x2104, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x1082,   // 0x1B60 (7008)
0x0841, 0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000,   // 0x1B70 (7024)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841,   // 0x1B80 (7040)
0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104,   // 0x1B90 (7056)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104,   // 0x1BA0 (7072)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104,   // 0x1BB0 (7088)
0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x10A2, 0x1082, 0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861,   // 0x1BC0 (7104)
0x0841, 0x0841, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1BD0 (7120)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0861,   // 0x1BE0 (7136)
0x1082, 0x0861, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x18E3, 0x2104, 0x2104,   // 0x1BF0 (7152)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104,   // 0x1C00 (7168)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x18C3,   // 0x1C10 (7184)
0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0841,   // 0x1C20 (7200)
0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1C30 (7216)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0861,   // 0x1C40 (7232)
0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2104,   // 0x1C50 (7248)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x18E3, 0x2104, 0x2104,   // 0x1C60 (7264)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18E3, 0x18E3,   // 0x1C70 (7280)
0x18C3, 0x10A2, 0x10A2, 0x1082, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x10A2, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x1C80 (7296)
0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1C90 (7312)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0861,   // 0x1CA0 (7328)
0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x18E3, 0x2104,   // 0x1CB0 (7344)
0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x18E3,   // 0x1CC0 (7360)
0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x2104, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3,   // 0x1CD0 (7376)
0x18E3, 0x18C3, 0x10A2, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x1CE0 (7392)
0x1082, 0x0861, 0x0841, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1CF0 (7408)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0861,   // 0x1D00 (7424)
0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2104,   // 0x1D10 (7440)
0x2104, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x2104, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x18E3, 0x18E3,   // 0x1D20 (7456)
0x18E3, 0x2104, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3,   // 0x1D30 (7472)
0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082,   // 0x1D40 (7488)
0x0861, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1D50 (7504)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0861,   // 0x1D60 (7520)
0x0861, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x2104,   // 0x1D70 (7536)
0x18E3, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x2104, 0x18E3, 0x18E3, 0x2104, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3,   // 0x1D80 (7552)
0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1D90 (7568)
0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841,   // 0x1DA0 (7584)
0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1DB0 (7600)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0861,   // 0x1DC0 (7616)
0x0861, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3,   // 0x1DD0 (7632)
0x18E3, 0x2104, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3,   // 0x1DE0 (7648)
0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x18C3,   // 0x1DF0 (7664)
0x10A2, 0x1082, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0020,   // 0x1E00 (7680)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1E10 (7696)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0861,   // 0x1E20 (7712)
0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3,   // 0x1E30 (7728)
0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18E3,   // 0x1E40 (7744)
0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2,   // 0x1E50 (7760)
0x10A2, 0x10A2, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000,   // 0x1E60 (7776)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1E70 (7792)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0861,   // 0x1E80 (7808)
0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1E90 (7824)
0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18E3,   // 0x1EA0 (7840)
0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2,   // 0x1EB0 (7856)
0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1EC0 (7872)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1ED0 (7888)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0861,   // 0x1EE0 (7904)
0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1EF0 (7920)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3,   // 0x1F00 (7936)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082,   // 0x1F10 (7952)
0x1082, 0x1082, 0x10A2, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1F20 (7968)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1F30 (7984)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841,   // 0x1F40 (8000)
0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1F50 (8016)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18E3, 0x18C3,   // 0x1F60 (8032)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082,   // 0x1F70 (8048)
0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1F80 (8064)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1F90 (8080)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841,   // 0x1FA0 (8096)
0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1FB0 (8112)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1FC0 (8128)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861,   // 0x1FD0 (8144)
0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1FE0 (8160)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1FF0 (8176)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x2000 (8192)
0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3,   // 0x2010 (8208)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2,   // 0x2020 (8224)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841,   // 0x2030 (8240)
0x0841, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2040 (8256)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2050 (8272)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x2060 (8288)
0x0841, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x2070 (8304)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2,   // 0x2080 (8320)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020,   // 0x2090 (8336)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x20A0 (8352)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x20B0 (8368)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x20C0 (8384)
0x0020, 0x0841, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x20D0 (8400)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x20E0 (8416)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000,   // 0x20F0 (8432)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2100 (8448)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2110 (8464)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2120 (8480)
0x0000, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x2130 (8496)
0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x2140 (8512)
0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2150 (8528)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2160 (8544)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2170 (8560)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2180 (8576)
0x0000, 0x0000, 0x0020, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082,   // 0x2190 (8592)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x21A0 (8608)
0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x21B0 (8624)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x21C0 (8640)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x21D0 (8656)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x21E0 (8672)
0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x21F0 (8688)
0x0861, 0x0861, 0x0861, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x2200 (8704)
0x0841, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2210 (8720)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2220 (8736)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2230 (8752)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2240 (8768)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x2250 (8784)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020,   // 0x2260 (8800)
0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2270 (8816)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2280 (8832)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2290 (8848)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22A0 (8864)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x22B0 (8880)
0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22C0 (8896)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22D0 (8912)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22E0 (8928)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22F0 (8944)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2300 (8960)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2310 (8976)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2320 (8992)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2330 (9008)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2340 (9024)
0x0000, };
Sunny.c
// Generated by  : ImageConverter 565 v2.3
// Generated from: Sunny.jpg
// Time generated: 21/06/2022 1:37:12 PM
// Dimensions    : 110x114 pixels
// Size          : 25,080 Bytes
#include <avr/pgmspace.h>
const unsigned int Sunny[0x30FC] PROGMEM ={
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x0010 (16)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0001, 0x0021, 0x0021, 0x0021, 0x0021, 0x0841,   // 0x0020 (32)
0x0841, 0x0021, 0x0021, 0x0841, 0x0821, 0x0041, 0x0040, 0x0040, 0x0040, 0x0041, 0x0021, 0x0021, 0x0001, 0x0021, 0x0021, 0x0021,   // 0x0030 (48)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0020, 0x0020, 0x0040, 0x0020, 0x0021, 0x0021,   // 0x0040 (64)
0x0021, 0x0021, 0x0021, 0x0821, 0x0021, 0x0001, 0x0001, 0x0001, 0x0021, 0x0021, 0x0001, 0x0001, 0x0821, 0x0821, 0x0821, 0x0821,   // 0x0050 (80)
0x0821, 0x0821, 0x0821, 0x0821, 0x0821, 0x0821, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x0060 (96)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0020, 0x0021,   // 0x0070 (112)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x0080 (128)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0821, 0x0021, 0x0021,   // 0x0090 (144)
0x0021, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x00A0 (160)
0x0821, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0840, 0x0820, 0x0840, 0x0840, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x00B0 (176)
0x0021, 0x0021, 0x0821, 0x0821, 0x0821, 0x0821, 0x0821, 0x0821, 0x0821, 0x0821, 0x0821, 0x0821, 0x0821, 0x0821, 0x0821, 0x0821,   // 0x00C0 (192)
0x0821, 0x0821, 0x0821, 0x0821, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x00D0 (208)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x00E0 (224)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x00F0 (240)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0821, 0x0000, 0x0841, 0x0841, 0x0000,   // 0x0100 (256)
0x0020, 0x0040, 0x0040, 0x0040, 0x0040, 0x0040, 0x0040, 0x0040, 0x0020, 0x0021, 0x0041, 0x0041, 0x0021, 0x0021, 0x0841, 0x0841,   // 0x0110 (272)
0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0840, 0x0840, 0x0840, 0x0840, 0x0840, 0x0020, 0x0021, 0x0041, 0x0041, 0x0041, 0x0021,   // 0x0120 (288)
0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0821, 0x0821, 0x0821, 0x0821, 0x0821, 0x0821, 0x0821, 0x0821, 0x0821, 0x0821,   // 0x0130 (304)
0x0821, 0x0821, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x0140 (320)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x0150 (336)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x0160 (352)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0020, 0x0841, 0x0841, 0x0020, 0x0020, 0x0040,   // 0x0170 (368)
0x0040, 0x0041, 0x0041, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x0180 (384)
0x0841, 0x0861, 0x0841, 0x0860, 0x0860, 0x0860, 0x0860, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x0190 (400)
0x0841, 0x0841, 0x0021, 0x0020, 0x0821, 0x0821, 0x0821, 0x0821, 0x0821, 0x0821, 0x0821, 0x0821, 0x0821, 0x0821, 0x0821, 0x0821,   // 0x01A0 (416)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x01B0 (432)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x01C0 (448)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x01D0 (464)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0020, 0x0020, 0x0020, 0x0020, 0x0040, 0x0040, 0x0020, 0x0040, 0x0041,   // 0x01E0 (480)
0x0041, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0860, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x01F0 (496)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x0200 (512)
0x0841, 0x0840, 0x0821, 0x0821, 0x0821, 0x0821, 0x0821, 0x0821, 0x0821, 0x0821, 0x0821, 0x0821, 0x0821, 0x0821, 0x0021, 0x0021,   // 0x0210 (528)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x0220 (544)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x0230 (560)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x0240 (576)
0x0021, 0x0021, 0x0021, 0x0021, 0x0020, 0x0020, 0x0861, 0x0040, 0x0020, 0x0860, 0x0840, 0x0820, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x0250 (592)
0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1081, 0x1081, 0x1081, 0x1081, 0x1081, 0x1081, 0x1081, 0x1081,   // 0x0260 (608)
0x1081, 0x1081, 0x1081, 0x1081, 0x1081, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841,   // 0x0270 (624)
0x0840, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0021, 0x0021, 0x0021,   // 0x0280 (640)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x0290 (656)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x02A0 (672)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0821, 0x0021, 0x0021,   // 0x02B0 (688)
0x0021, 0x0841, 0x0840, 0x0020, 0x0861, 0x0840, 0x0020, 0x0860, 0x1081, 0x0861, 0x0861, 0x0861, 0x0861, 0x0881, 0x1081, 0x0881,   // 0x02C0 (704)
0x0881, 0x1081, 0x1081, 0x1081, 0x1081, 0x1081, 0x1082, 0x1082, 0x10A1, 0x10A1, 0x10A1, 0x10A1, 0x10A1, 0x10A0, 0x10A1, 0x1081,   // 0x02D0 (720)
0x10A1, 0x1081, 0x0881, 0x1081, 0x1081, 0x0881, 0x0881, 0x1081, 0x1081, 0x1081, 0x1081, 0x1081, 0x0881, 0x0861, 0x0861, 0x0841,   // 0x02E0 (736)
0x0841, 0x0020, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0841, 0x0841, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x02F0 (752)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x0300 (768)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x0310 (784)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0821, 0x0021, 0x0021, 0x0021, 0x0841,   // 0x0320 (800)
0x0841, 0x0860, 0x0020, 0x0840, 0x0860, 0x0040, 0x1080, 0x10A1, 0x1081, 0x10A2, 0x1081, 0x10A1, 0x10A2, 0x1081, 0x1081, 0x10A1,   // 0x0330 (816)
0x10A1, 0x10A1, 0x10A1, 0x10A1, 0x10A2, 0x10A2, 0x10A2, 0x10A1, 0x10C1, 0x10C1, 0x10C1, 0x10A1, 0x10C1, 0x10A1, 0x10A1, 0x10A2,   // 0x0340 (832)
0x1081, 0x1081, 0x10A1, 0x1081, 0x1081, 0x10A1, 0x10C2, 0x10A2, 0x10C2, 0x10A2, 0x10A1, 0x1081, 0x0881, 0x0861, 0x0841, 0x0020,   // 0x0350 (848)
0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0841, 0x0841, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x0360 (864)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x0370 (880)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x0380 (896)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0840, 0x0840, 0x0861,   // 0x0390 (912)
0x0860, 0x10A1, 0x1902, 0x10A0, 0x1080, 0x1081, 0x1081, 0x10A1, 0x10A1, 0x1081, 0x10A1, 0x10A1, 0x10A1, 0x18C1, 0x18C1, 0x18C1,   // 0x03A0 (928)
0x18C1, 0x18C2, 0x18C2, 0x18C2, 0x18C2, 0x18E2, 0x18C1, 0x18E1, 0x10C1, 0x10C1, 0x18C1, 0x18C1, 0x10C1, 0x18C2, 0x18C2, 0x10C2,   // 0x03B0 (944)
0x10C2, 0x10A1, 0x10A1, 0x18C2, 0x18E2, 0x18E2, 0x18E2, 0x18C2, 0x10C2, 0x10A1, 0x10A1, 0x0881, 0x0861, 0x0841, 0x0040, 0x0040,   // 0x03C0 (960)
0x0020, 0x0020, 0x0020, 0x0020, 0x0040, 0x0040, 0x0040, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x03D0 (976)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x03E0 (992)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x03F0 (1008)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0841, 0x0841, 0x0840, 0x0840, 0x0840, 0x18C1, 0x2963,   // 0x0400 (1024)
0x31C5, 0x2122, 0x18E1, 0x18C1, 0x10A1, 0x18C1, 0x18C1, 0x10A1, 0x18C1, 0x18C1, 0x18C1, 0x18C2, 0x18C2, 0x18E2, 0x18E2, 0x18E2,   // 0x0410 (1040)
0x18E2, 0x18E2, 0x18E2, 0x18E2, 0x18E1, 0x18E1, 0x18E1, 0x18E1, 0x18C1, 0x1902, 0x18E2, 0x18C2, 0x18E2, 0x18E2, 0x18C2, 0x18C2,   // 0x0420 (1056)
0x18C2, 0x18E2, 0x1902, 0x2103, 0x2103, 0x18E2, 0x18E2, 0x18C2, 0x10A2, 0x1081, 0x0861, 0x0861, 0x0841, 0x0840, 0x0040, 0x0040,   // 0x0430 (1072)
0x0040, 0x0040, 0x0040, 0x0040, 0x0040, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x0440 (1088)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x0450 (1104)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x0460 (1120)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0821, 0x0841, 0x0841, 0x0860, 0x0860, 0x0860, 0x10A1, 0x31C5, 0x5288, 0x2943,   // 0x0470 (1136)
0x2963, 0x31A4, 0x1902, 0x18E2, 0x18E2, 0x18E2, 0x18E2, 0x18E2, 0x18E2, 0x18E2, 0x18E2, 0x18E2, 0x2102, 0x1903, 0x18E3, 0x1903,   // 0x0480 (1152)
0x1902, 0x1902, 0x1901, 0x18E1, 0x2122, 0x2983, 0x1902, 0x2122, 0x2102, 0x18E2, 0x18E2, 0x1902, 0x18E2, 0x18E2, 0x1902, 0x2103,   // 0x0490 (1168)
0x2123, 0x2123, 0x2123, 0x2123, 0x1902, 0x18E2, 0x10C2, 0x10A2, 0x0881, 0x0861, 0x0861, 0x0861, 0x0841, 0x0840, 0x0840, 0x0040,   // 0x04A0 (1184)
0x0040, 0x0040, 0x0020, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x04B0 (1200)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x04C0 (1216)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x04D0 (1232)
0x0021, 0x0021, 0x0021, 0x0021, 0x0841, 0x0841, 0x0861, 0x0861, 0x0860, 0x10A1, 0x1080, 0x2984, 0x52C8, 0x31A4, 0x4A47, 0x4A87,   // 0x04E0 (1248)
0x2963, 0x2102, 0x2102, 0x2102, 0x2102, 0x1902, 0x2102, 0x2102, 0x2103, 0x2103, 0x2123, 0x2103, 0x2103, 0x2103, 0x2123, 0x2122,   // 0x04F0 (1264)
0x2121, 0x1901, 0x31A3, 0x4A87, 0x2984, 0x2122, 0x2102, 0x18E2, 0x2102, 0x2102, 0x2102, 0x2102, 0x2123, 0x2143, 0x2143, 0x2943,   // 0x0500 (1280)
0x2943, 0x2143, 0x2123, 0x2102, 0x18C2, 0x10A2, 0x1081, 0x0881, 0x0861, 0x0861, 0x0861, 0x0841, 0x0840, 0x0040, 0x0040, 0x0020,   // 0x0510 (1296)
0x0020, 0x0020, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x0520 (1312)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x0530 (1328)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0041, 0x0021, 0x0021, 0x0021, 0x0841,   // 0x0540 (1344)
0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x1081, 0x1080, 0x10C1, 0x18C1, 0x2142, 0x4A66, 0x52A7, 0x5AC8, 0x52A7, 0x3A04, 0x2941,   // 0x0550 (1360)
0x2141, 0x2141, 0x2121, 0x2101, 0x2122, 0x2122, 0x2123, 0x2123, 0x2123, 0x2103, 0x2124, 0x2123, 0x2123, 0x2122, 0x2142, 0x2121,   // 0x0560 (1376)
0x4205, 0x6B4A, 0x39E4, 0x2122, 0x2102, 0x2123, 0x2123, 0x2123, 0x2102, 0x20E2, 0x2123, 0x3184, 0x39C5, 0x2963, 0x2943, 0x2943,   // 0x0570 (1392)
0x2123, 0x2102, 0x18E2, 0x10A2, 0x10A2, 0x1081, 0x1081, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0840, 0x0040, 0x0040, 0x0020,   // 0x0580 (1408)
0x0020, 0x0020, 0x0020, 0x0021, 0x0041, 0x0021, 0x0021, 0x0041, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x0590 (1424)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x05A0 (1440)
0x0021, 0x0021, 0x0021, 0x0041, 0x0041, 0x0041, 0x0041, 0x0040, 0x0040, 0x0041, 0x0020, 0x0020, 0x0841, 0x0841, 0x0861, 0x0861,   // 0x05B0 (1456)
0x0861, 0x0861, 0x1081, 0x10A0, 0x10A0, 0x10C0, 0x18E1, 0x2121, 0x4225, 0x738A, 0x5AA7, 0x4A45, 0x6328, 0x39C2, 0x2140, 0x2961,   // 0x05C0 (1472)
0x2941, 0x2941, 0x2142, 0x2942, 0x2123, 0x2123, 0x2123, 0x2123, 0x2924, 0x2943, 0x2923, 0x2942, 0x2942, 0x2941, 0x4A45, 0x7BCB,   // 0x05D0 (1488)
0x39E4, 0x2121, 0x2941, 0x2942, 0x2923, 0x2923, 0x2102, 0x2102, 0x2942, 0x4205, 0x52A7, 0x31A4, 0x2963, 0x2942, 0x2922, 0x2122,   // 0x05E0 (1504)
0x20E2, 0x18C2, 0x10A2, 0x10A2, 0x10A1, 0x1081, 0x0881, 0x0881, 0x0861, 0x0861, 0x0841, 0x0041, 0x0041, 0x0040, 0x0020, 0x0020,   // 0x05F0 (1520)
0x0020, 0x0040, 0x0841, 0x0041, 0x0041, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x0600 (1536)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x0610 (1552)
0x0021, 0x0041, 0x0041, 0x0041, 0x0041, 0x0040, 0x0040, 0x0040, 0x0020, 0x0020, 0x0840, 0x0841, 0x0861, 0x0861, 0x1081, 0x1081,   // 0x0620 (1568)
0x10A1, 0x10A1, 0x10A0, 0x18A0, 0x18E1, 0x20E1, 0x39E4, 0x7BCB, 0x5AC7, 0x4A65, 0x8C2C, 0x4224, 0x2961, 0x39E3, 0x2961, 0x3182,   // 0x0630 (1584)
0x2942, 0x2942, 0x2943, 0x2943, 0x2964, 0x2964, 0x2923, 0x2943, 0x3163, 0x3162, 0x2962, 0x2941, 0x4A65, 0x840C, 0x4204, 0x2121,   // 0x0640 (1600)
0x2962, 0x2942, 0x2922, 0x2922, 0x2922, 0x3163, 0x3182, 0x4A66, 0x6B49, 0x4225, 0x3183, 0x2962, 0x2943, 0x2122, 0x20E2, 0x18C2,   // 0x0650 (1616)
0x18A2, 0x18A2, 0x10A2, 0x10A2, 0x1081, 0x1081, 0x0881, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0040, 0x0020, 0x0020, 0x0040,   // 0x0660 (1632)
0x0040, 0x0040, 0x0041, 0x0021, 0x0021, 0x0041, 0x0041, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x0670 (1648)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0041,   // 0x0680 (1664)
0x0041, 0x0041, 0x0041, 0x0040, 0x0040, 0x0041, 0x0840, 0x0841, 0x0841, 0x0861, 0x0861, 0x1062, 0x1082, 0x10A2, 0x10A2, 0x10A1,   // 0x0690 (1680)
0x18A1, 0x18E1, 0x18E1, 0x20E0, 0x3162, 0x6B29, 0x6B29, 0x6B48, 0x8C2C, 0x5285, 0x4224, 0x5285, 0x39E3, 0x31A2, 0x3182, 0x3163,   // 0x06A0 (1696)
0x3163, 0x3184, 0x3164, 0x3164, 0x3164, 0x3164, 0x3183, 0x3183, 0x3182, 0x2961, 0x5286, 0x8C2C, 0x4A24, 0x31A2, 0x41E4, 0x31A3,   // 0x06B0 (1712)
0x3163, 0x2962, 0x2962, 0x39A3, 0x39C3, 0x5AA7, 0x6B49, 0x4224, 0x3162, 0x3162, 0x3183, 0x2922, 0x20E2, 0x18E2, 0x18E2, 0x18C2,   // 0x06C0 (1728)
0x18C2, 0x10C2, 0x10A2, 0x10A2, 0x1082, 0x1081, 0x0881, 0x0861, 0x0861, 0x0861, 0x0840, 0x0040, 0x0020, 0x0020, 0x0020, 0x0020,   // 0x06D0 (1744)
0x0020, 0x0021, 0x0021, 0x0041, 0x0041, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x06E0 (1760)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0041, 0x0041, 0x0041,   // 0x06F0 (1776)
0x0021, 0x0040, 0x0041, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x1061, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x18A2, 0x18E2, 0x2122,   // 0x0700 (1792)
0x2101, 0x2121, 0x2941, 0x4A45, 0x83EB, 0x946D, 0x7BCA, 0x7389, 0x62E6, 0x5AA6, 0x6B28, 0x4A24, 0x39C3, 0x39C4, 0x39A3, 0x39A4,   // 0x0710 (1808)
0x3184, 0x3184, 0x39A4, 0x3983, 0x39A3, 0x39C3, 0x39C3, 0x3181, 0x5285, 0x840B, 0x5AA6, 0x4A44, 0x5286, 0x5286, 0x41E4, 0x3182,   // 0x0720 (1824)
0x3182, 0x39C2, 0x5265, 0x6307, 0x5AC6, 0x41E3, 0x39A2, 0x39C3, 0x41C4, 0x2942, 0x2102, 0x2122, 0x2102, 0x18E2, 0x18E2, 0x18C2,   // 0x0730 (1840)
0x10C2, 0x10C2, 0x10A2, 0x1082, 0x0881, 0x0881, 0x0861, 0x0861, 0x0841, 0x0841, 0x0040, 0x0040, 0x0020, 0x0040, 0x0041, 0x0021,   // 0x0740 (1856)
0x0021, 0x0041, 0x0041, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x0750 (1872)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0040, 0x0040,   // 0x0760 (1888)
0x0041, 0x0861, 0x0861, 0x0861, 0x1061, 0x1081, 0x1081, 0x10A2, 0x18C3, 0x18C2, 0x18A2, 0x18E2, 0x2123, 0x3183, 0x2942, 0x2941,   // 0x0770 (1904)
0x2961, 0x31A2, 0x83EA, 0x9CAD, 0x7368, 0x948C, 0x7388, 0x5AA5, 0x840A, 0x5AC6, 0x5285, 0x5AC6, 0x41E3, 0x39A3, 0x41E4, 0x41C4,   // 0x0780 (1920)
0x41E4, 0x41E4, 0x41E4, 0x4203, 0x4203, 0x39C2, 0x5284, 0x8C2B, 0x6B68, 0x5AC6, 0x5AC6, 0x7389, 0x5265, 0x39C2, 0x39C2, 0x39E2,   // 0x0790 (1936)
0x7388, 0x7BA9, 0x4A43, 0x41E2, 0x4A24, 0x5286, 0x5266, 0x3183, 0x2121, 0x2922, 0x2122, 0x2102, 0x2102, 0x18E2, 0x18E2, 0x18C2,   // 0x07A0 (1952)
0x18C2, 0x10A2, 0x1081, 0x0881, 0x0861, 0x0840, 0x0840, 0x0840, 0x0841, 0x0040, 0x0040, 0x0041, 0x0041, 0x0040, 0x0040, 0x0041,   // 0x07B0 (1968)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x07C0 (1984)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0020, 0x0040, 0x0841, 0x0861,   // 0x07D0 (2000)
0x0861, 0x1081, 0x1081, 0x1081, 0x1081, 0x18A2, 0x18C3, 0x18C3, 0x18C2, 0x2103, 0x2943, 0x39C5, 0x39C4, 0x3182, 0x3161, 0x3181,   // 0x07E0 (2016)
0x6B27, 0x946B, 0x83E9, 0xAD0D, 0x8C2A, 0x6B26, 0x946B, 0x6B26, 0x6B26, 0x7388, 0x4A43, 0x41E2, 0x5265, 0x5286, 0x4A44, 0x4A24,   // 0x07F0 (2032)
0x5264, 0x5AA5, 0x5284, 0x4A23, 0x62E5, 0x9CCC, 0x8C2A, 0x6306, 0x52A4, 0x83E9, 0x52A5, 0x39E2, 0x41E2, 0x4202, 0x8C2A, 0x8C4A,   // 0x0800 (2048)
0x5A84, 0x4A22, 0x5AC5, 0x6B08, 0x5286, 0x3182, 0x2121, 0x2922, 0x2121, 0x2122, 0x2102, 0x2102, 0x18E2, 0x18E2, 0x18C2, 0x10A2,   // 0x0810 (2064)
0x10A2, 0x10A1, 0x0881, 0x0861, 0x0861, 0x0860, 0x0840, 0x0840, 0x0840, 0x0041, 0x0040, 0x0040, 0x0040, 0x0020, 0x0021, 0x0021,   // 0x0820 (2080)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x0830 (2096)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0020, 0x0840, 0x0861, 0x1081, 0x1081, 0x10A1,   // 0x0840 (2112)
0x10A1, 0x10A1, 0x10A2, 0x18C2, 0x20E3, 0x20E3, 0x20E3, 0x2123, 0x2943, 0x39C4, 0x5AC7, 0x5AA6, 0x2960, 0x31A1, 0x5284, 0x83E8,   // 0x0850 (2128)
0xB56D, 0xAD4D, 0x8C49, 0x83E7, 0xA4EC, 0x7BA7, 0x7BC8, 0x83E9, 0x5AC5, 0x4202, 0x5285, 0x7368, 0x62C6, 0x4A44, 0x5AC5, 0x83E9,   // 0x0860 (2144)
0x6B26, 0x5AA4, 0x6B67, 0xAD6E, 0xA52D, 0x7387, 0x5AA3, 0x8409, 0x6306, 0x4A43, 0x4202, 0x5283, 0x8C2A, 0x9CCB, 0x7BA7, 0x5263,   // 0x0870 (2160)
0x7367, 0x7388, 0x39A2, 0x3161, 0x2962, 0x2942, 0x2941, 0x2122, 0x2122, 0x2122, 0x2102, 0x18E2, 0x18E2, 0x18C2, 0x18C2, 0x10C1,   // 0x0880 (2176)
0x10A2, 0x10A2, 0x10A2, 0x0861, 0x0840, 0x0840, 0x0040, 0x0040, 0x0040, 0x0020, 0x0020, 0x0020, 0x0020, 0x0021, 0x0021, 0x0021,   // 0x0890 (2192)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x08A0 (2208)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0041, 0x0841, 0x0021, 0x0020, 0x0841, 0x1081, 0x10A2, 0x10A1, 0x18C2, 0x18C2, 0x18A1,   // 0x08B0 (2224)
0x20E2, 0x20E2, 0x18E2, 0x20E2, 0x2102, 0x2923, 0x2122, 0x2942, 0x6308, 0x7389, 0x39A1, 0x39C1, 0x4201, 0x7386, 0xC5EE, 0xA50B,   // 0x08C0 (2240)
0x9CAA, 0xA52C, 0x9CAA, 0x8C49, 0x948B, 0x94AB, 0x7BC8, 0x5AC5, 0x6B48, 0x9CAD, 0x840B, 0x62E6, 0x7389, 0xB590, 0x8C4B, 0x6306,   // 0x08D0 (2256)
0x7BA8, 0xBDD0, 0xBDD0, 0x8C6A, 0x73A7, 0x9CCC, 0x840A, 0x62E6, 0x5AC4, 0x7387, 0x946A, 0xA4CB, 0x9449, 0x62C4, 0x8C09, 0x83EA,   // 0x08E0 (2272)
0x39A2, 0x39A2, 0x3182, 0x2962, 0x2942, 0x2942, 0x2122, 0x2122, 0x2102, 0x18E2, 0x2102, 0x18E2, 0x10A1, 0x10A1, 0x1902, 0x2123,   // 0x08F0 (2288)
0x10C2, 0x0881, 0x0861, 0x0040, 0x0860, 0x0040, 0x0020, 0x0020, 0x0020, 0x0040, 0x0041, 0x0041, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x0900 (2304)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x0910 (2320)
0x0021, 0x0021, 0x0021, 0x0041, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x1081, 0x10A1, 0x18C2, 0x20E2, 0x2102, 0x20E2, 0x20E2,   // 0x0920 (2336)
0x18E1, 0x20E2, 0x2102, 0x2102, 0x2122, 0x2942, 0x4A45, 0x6B48, 0x6B47, 0x4A22, 0x41E1, 0x6324, 0xAD2B, 0x9CEA, 0xAD4C, 0xB5AE,   // 0x0930 (2352)
0x8C69, 0xA50C, 0xAD6E, 0x9CEC, 0x8C4B, 0x6B47, 0x7BEA, 0xAD70, 0xA4EF, 0x7BAA, 0x8C4D, 0xD695, 0xAD50, 0x840B, 0x8C6C, 0xBDF1,   // 0x0940 (2368)
0xC612, 0xA50E, 0x948B, 0xA50E, 0x8C4B, 0x7368, 0x7BC8, 0xA4ED, 0xA4CB, 0x9C6A, 0x9429, 0x7366, 0x83E8, 0x7B88, 0x4202, 0x39C2,   // 0x0950 (2384)
0x3182, 0x3182, 0x3162, 0x2942, 0x2942, 0x2922, 0x2123, 0x2102, 0x18E2, 0x2102, 0x18E1, 0x1901, 0x31C5, 0x4A89, 0x2144, 0x1081,   // 0x0960 (2400)
0x0861, 0x0860, 0x1081, 0x0840, 0x0040, 0x0040, 0x0040, 0x0040, 0x0841, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x0970 (2416)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x0980 (2432)
0x0021, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x1061, 0x1081, 0x18C2, 0x18A1, 0x2123, 0x3184, 0x2122, 0x2101, 0x2101, 0x2102,   // 0x0990 (2448)
0x2122, 0x2922, 0x3183, 0x3183, 0x3182, 0x5AC6, 0x946C, 0x5284, 0x52A3, 0x7365, 0x8C48, 0xB58D, 0xCE70, 0xBDCE, 0x9489, 0xAD6E,   // 0x09A0 (2464)
0xBDD0, 0xAD6F, 0xB590, 0xA50F, 0xAD50, 0xCE55, 0xCE56, 0xB593, 0xBDF4, 0xEF39, 0xD676, 0xBDF3, 0xC634, 0xD6B6, 0xD695, 0xC633,   // 0x09B0 (2480)
0xBDF2, 0xC633, 0xA50F, 0x948C, 0xA4ED, 0xCE31, 0xB56D, 0x9CAA, 0x9C8A, 0xAD0C, 0x8C09, 0x5AA4, 0x4A22, 0x4A43, 0x4203, 0x39C3,   // 0x09C0 (2496)
0x31A3, 0x3183, 0x3163, 0x2943, 0x2923, 0x2123, 0x2122, 0x18E1, 0x1901, 0x39C4, 0x5AE9, 0x52CA, 0x2944, 0x10A1, 0x10A1, 0x0881,   // 0x09D0 (2512)
0x0861, 0x0840, 0x0840, 0x0040, 0x0040, 0x0040, 0x0841, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x09E0 (2528)
0x0021, 0x0021, 0x0041, 0x0041, 0x0041, 0x0041, 0x0041, 0x0041, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0841,   // 0x09F0 (2544)
0x0841, 0x0841, 0x0841, 0x1061, 0x1081, 0x10A2, 0x18C2, 0x18C2, 0x2923, 0x39A5, 0x41E5, 0x31A3, 0x2941, 0x2941, 0x2922, 0x2942,   // 0x0A00 (2560)
0x3183, 0x39C3, 0x39E3, 0x5AC6, 0x842A, 0x7BA8, 0x83E8, 0x8428, 0x94A9, 0xBDEF, 0xD692, 0xBDEF, 0xAD6E, 0xBDF0, 0xC632, 0xCE53,   // 0x0A10 (2576)
0xE738, 0xF779, 0xF7BB, 0xFFDC, 0xFFBC, 0xF7BC, 0xF79C, 0xFFFD, 0xFFDC, 0xF7BC, 0xFFDC, 0xFFDC, 0xFFDB, 0xF7BA, 0xF7BA, 0xF79A,   // 0x0A20 (2592)
0xD6B5, 0xCE33, 0xCE32, 0xDEB3, 0xCDF0, 0xAD0B, 0xAD0B, 0xCDEF, 0x9449, 0x5A83, 0x5284, 0x6B47, 0x52A6, 0x39C3, 0x39C3, 0x3183,   // 0x0A30 (2608)
0x3183, 0x2963, 0x2923, 0x2123, 0x2943, 0x2943, 0x39E4, 0x52A7, 0x52A8, 0x2143, 0x10A2, 0x1081, 0x10A2, 0x10A1, 0x0861, 0x0861,   // 0x0A40 (2624)
0x0860, 0x0840, 0x0040, 0x0040, 0x0040, 0x0041, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x0A50 (2640)
0x0041, 0x0041, 0x0041, 0x0041, 0x0041, 0x0041, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x0A60 (2656)
0x0861, 0x1081, 0x10A2, 0x18C2, 0x18A1, 0x18E2, 0x2102, 0x3184, 0x5AC8, 0x5AC7, 0x39E3, 0x3182, 0x3182, 0x3162, 0x3182, 0x39C3,   // 0x0A70 (2672)
0x5265, 0x62E6, 0x6B47, 0xA52D, 0xA4EC, 0x94AB, 0xB58E, 0xBDF0, 0xCE52, 0xDED4, 0xEF57, 0xF799, 0xF799, 0xF79A, 0xFFDC, 0xFFFD,   // 0x0A80 (2688)
0xFFFD, 0xFFFD, 0xFFDD, 0xFFFE, 0xFFFE, 0xFFFE, 0xFFFE, 0xFFFE, 0xFFFD, 0xFFFD, 0xFFFD, 0xFFFD, 0xFFFD, 0xFFFC, 0xFFBA, 0xF799,   // 0x0A90 (2704)
0xF778, 0xFFB8, 0xF756, 0xDE92, 0xC5CF, 0xBD8E, 0x9C8A, 0x7BA7, 0x7BC8, 0x948C, 0x6B47, 0x4204, 0x4204, 0x39C4, 0x39A4, 0x31A4,   // 0x0AA0 (2720)
0x3163, 0x2943, 0x2942, 0x4205, 0x6B6A, 0x5AE8, 0x2962, 0x10C1, 0x18E2, 0x10C2, 0x10A1, 0x10C2, 0x10A1, 0x0881, 0x0861, 0x0840,   // 0x0AB0 (2736)
0x0840, 0x0040, 0x0020, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x0AC0 (2752)
0x0021, 0x0021, 0x0021, 0x0021, 0x0841, 0x0021, 0x0020, 0x0820, 0x0820, 0x0841, 0x0841, 0x0861, 0x0861, 0x0881, 0x0882, 0x10A2,   // 0x0AD0 (2768)
0x10C2, 0x10C2, 0x1902, 0x1902, 0x10C0, 0x2942, 0x4A86, 0x6B68, 0x6B48, 0x4203, 0x39C2, 0x39C2, 0x39A2, 0x4A23, 0x6B07, 0x7347,   // 0x0AE0 (2784)
0x8409, 0xB56E, 0xA52D, 0xAD2E, 0xCE73, 0xDED5, 0xE717, 0xF79A, 0xFFDD, 0xFFFE, 0xFFFE, 0xFFFF, 0xFFFE, 0xFFFE, 0xFFFE, 0xFFFE,   // 0x0AF0 (2800)
0xFFDE, 0xFFFE, 0xFFFE, 0xFFFE, 0xFFFE, 0xFFFE, 0xFFFE, 0xFFFE, 0xFFDD, 0xFFDD, 0xFFFD, 0xFFFD, 0xFFDC, 0xFFFC, 0xFFFB, 0xFFDA,   // 0x0B00 (2816)
0xFFB9, 0xF777, 0xE6F5, 0xD652, 0xB58E, 0xA4EC, 0xA50C, 0x9CAB, 0x7BA8, 0x62E6, 0x5265, 0x5AC6, 0x5265, 0x39A2, 0x39A3, 0x2961,   // 0x0B10 (2832)
0x4225, 0x6B6A, 0x6329, 0x3A04, 0x2121, 0x18E1, 0x2102, 0x18E2, 0x10C1, 0x10C1, 0x10A1, 0x10A1, 0x0860, 0x0840, 0x0840, 0x0840,   // 0x0B20 (2848)
0x0820, 0x0020, 0x0021, 0x0021, 0x0021, 0x0021, 0x0041, 0x0041, 0x0041, 0x0040, 0x0040, 0x0040, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x0B30 (2864)
0x0021, 0x0020, 0x0841, 0x0020, 0x0820, 0x0840, 0x0840, 0x0840, 0x0841, 0x0841, 0x0861, 0x1081, 0x10A2, 0x10A2, 0x10C2, 0x18E2,   // 0x0B40 (2880)
0x1902, 0x2122, 0x2121, 0x2121, 0x2961, 0x5B06, 0x8C4B, 0x6B48, 0x4A44, 0x4A23, 0x5244, 0x62C5, 0x7368, 0x946C, 0xAD0E, 0xAD2E,   // 0x0B50 (2896)
0xB58F, 0xCE53, 0xEF58, 0xFFDA, 0xFFFC, 0xFFFE, 0xFFDE, 0xFFFF, 0xFFFF, 0xFFDF, 0xFFFF, 0xFFFF, 0xFFFE, 0xFFFE, 0xFFFE, 0xFFFE,   // 0x0B60 (2912)
0xFFFD, 0xFFFD, 0xFFFD, 0xFFDD, 0xFFDD, 0xFFFD, 0xFFDC, 0xFFDC, 0xFFFC, 0xFFDC, 0xFFBB, 0xFFBB, 0xFFBB, 0xFFBA, 0xFFD9, 0xFFB8,   // 0x0B70 (2928)
0xFFB8, 0xF776, 0xE6D4, 0xD671, 0xCE30, 0xA4CB, 0x83C8, 0x7BA8, 0x83C9, 0x83C9, 0x5AC5, 0x39A1, 0x39C2, 0x4A44, 0x7BCA, 0x842C,   // 0x0B80 (2944)
0x39C3, 0x2141, 0x2121, 0x2122, 0x1902, 0x1902, 0x18E1, 0x10A1, 0x10C1, 0x10A1, 0x1081, 0x0861, 0x0840, 0x0840, 0x0840, 0x0021,   // 0x0B90 (2960)
0x0021, 0x0021, 0x0021, 0x0021, 0x0040, 0x0040, 0x0040, 0x0040, 0x0040, 0x0040, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0020,   // 0x0BA0 (2976)
0x0020, 0x0020, 0x0820, 0x0840, 0x0840, 0x0841, 0x0841, 0x0861, 0x1081, 0x10A2, 0x10A2, 0x10C2, 0x18E2, 0x1902, 0x1902, 0x2122,   // 0x0BB0 (2992)
0x2962, 0x2962, 0x2120, 0x39C1, 0x6326, 0xA52E, 0x840A, 0x62E6, 0x62E5, 0x62E6, 0x8C2B, 0xA4EE, 0xAD4F, 0xC633, 0xE737, 0xF7BA,   // 0x0BC0 (3008)
0xFFFB, 0xFFFC, 0xFFDD, 0xFFFE, 0xFFFE, 0xFFFF, 0xFFFF, 0xFFDE, 0xFFFE, 0xFFFE, 0xFFFE, 0xFFFD, 0xFFFD, 0xFFBC, 0xFFBC, 0xFFDC,   // 0x0BD0 (3024)
0xFFBB, 0xF79A, 0xFF9A, 0xFFBA, 0xFFBA, 0xFFBA, 0xFFDA, 0xFFBA, 0xFF99, 0xFF99, 0xFF99, 0xFF98, 0xFFB8, 0xFFD8, 0xFFD7, 0xFF96,   // 0x0BE0 (3040)
0xFF96, 0xF776, 0xEF34, 0xC5CF, 0x946A, 0x9CAB, 0xB56E, 0x7BA7, 0x4A21, 0x4A42, 0x4A43, 0x8C4B, 0x8C6C, 0x52A5, 0x39E3, 0x2961,   // 0x0BF0 (3056)
0x2101, 0x2122, 0x1902, 0x1902, 0x18C2, 0x1081, 0x10A1, 0x10A1, 0x10A2, 0x1081, 0x0841, 0x0840, 0x0841, 0x0841, 0x0021, 0x0021,   // 0x0C00 (3072)
0x0021, 0x0021, 0x0040, 0x0040, 0x0040, 0x0040, 0x0040, 0x0040, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0020, 0x0020, 0x0020,   // 0x0C10 (3088)
0x0820, 0x0840, 0x0841, 0x0841, 0x0861, 0x1061, 0x1082, 0x10A2, 0x10C2, 0x10E2, 0x1902, 0x2122, 0x2122, 0x1901, 0x2941, 0x3182,   // 0x0C20 (3104)
0x31A2, 0x31A0, 0x4A42, 0x7387, 0x9CCD, 0xA50D, 0x9CAC, 0x948C, 0x946C, 0xBDB2, 0xE718, 0xF77A, 0xFFDB, 0xFFFC, 0xFFFD, 0xFFFE,   // 0x0C30 (3120)
0xFFFE, 0xFFFE, 0xFFFF, 0xFFDE, 0xFFFE, 0xFFFE, 0xFFDD, 0xFFDD, 0xFFFD, 0xFFFD, 0xFFFC, 0xFFBB, 0xFFBB, 0xFFDB, 0xFFDA, 0xFF99,   // 0x0C40 (3136)
0xFFB9, 0xFFB8, 0xFF97, 0xFF77, 0xFF76, 0xF756, 0xFF77, 0xFF77, 0xFF77, 0xFF76, 0xF756, 0xFF76, 0xFF76, 0xFF75, 0xFF96, 0xFF96,   // 0x0C50 (3152)
0xFFB6, 0xEF14, 0xDE70, 0xCE2F, 0xAD0A, 0x9448, 0x7BA6, 0x7366, 0x9CCC, 0x94AC, 0x6B47, 0x4203, 0x2140, 0x2121, 0x2942, 0x2122,   // 0x0C60 (3168)
0x2123, 0x1902, 0x18E2, 0x18E2, 0x10A2, 0x1081, 0x10A2, 0x1082, 0x0841, 0x0821, 0x0841, 0x0841, 0x0041, 0x0041, 0x0021, 0x0021,   // 0x0C70 (3184)
0x0040, 0x0040, 0x0040, 0x0040, 0x0040, 0x0040, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0020, 0x0020, 0x0020, 0x0820, 0x0840,   // 0x0C80 (3200)
0x0841, 0x0861, 0x0861, 0x1081, 0x10A2, 0x10C2, 0x18C2, 0x18E2, 0x1902, 0x2122, 0x2122, 0x2121, 0x2941, 0x4204, 0x5AC6, 0x5AA4,   // 0x0C90 (3216)
0x5263, 0x5AC4, 0x946B, 0xC5F1, 0xBDD0, 0xBDD1, 0xC612, 0xE6F7, 0xFFDB, 0xFFFD, 0xFFFD, 0xFFFE, 0xFFDE, 0xFFFF, 0xFFDE, 0xFFDE,   // 0x0CA0 (3232)
0xFFFF, 0xFFDE, 0xFFDE, 0xFFFE, 0xFFDD, 0xF7BC, 0xF7BB, 0xFFDB, 0xFFBA, 0xFFBA, 0xFF9A, 0xFFB9, 0xFF98, 0xFF77, 0xFF76, 0xFF76,   // 0x0CB0 (3248)
0xFF75, 0xFF74, 0xFF74, 0xFF54, 0xFF75, 0xFF54, 0xFF54, 0xFF34, 0xF713, 0xF733, 0xFF53, 0xFF54, 0xFF54, 0xFF33, 0xFF74, 0xFF74,   // 0x0CC0 (3264)
0xFFB4, 0xEF11, 0xC5CC, 0xAD2A, 0xA4C9, 0xAD0B, 0xAD4D, 0x73A7, 0x4A43, 0x39E2, 0x2961, 0x2962, 0x2962, 0x2122, 0x2942, 0x2102,   // 0x0CD0 (3280)
0x2102, 0x2103, 0x18A1, 0x10A1, 0x1082, 0x1082, 0x1061, 0x0841, 0x0841, 0x0841, 0x0041, 0x0041, 0x0041, 0x0021, 0x0040, 0x0040,   // 0x0CE0 (3296)
0x0040, 0x0040, 0x0040, 0x0040, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0020, 0x0020, 0x0020, 0x0820, 0x0840, 0x0841, 0x0861,   // 0x0CF0 (3312)
0x1061, 0x1081, 0x10A2, 0x18C2, 0x18E2, 0x1902, 0x2122, 0x2122, 0x2122, 0x2941, 0x2941, 0x4203, 0x6B27, 0x83E9, 0x7BC8, 0x6305,   // 0x0D00 (3328)
0x8C4A, 0xBDAF, 0xD693, 0xDED5, 0xF799, 0xFFFC, 0xFFFD, 0xFFFE, 0xFFDE, 0xFFDF, 0xFFFF, 0xFFFF, 0xFFDE, 0xF7BE, 0xFFFE, 0xFFDE,   // 0x0D10 (3344)
0xFFDD, 0xFFDC, 0xFFDC, 0xFFDB, 0xF79A, 0xF799, 0xFF99, 0xFF99, 0xFF98, 0xFF77, 0xF756, 0xF755, 0xFF54, 0xFF54, 0xFF53, 0xFF53,   // 0x0D20 (3360)
0xFF52, 0xFF32, 0xFF72, 0xFF31, 0xF711, 0xFF31, 0xF711, 0xF711, 0xFF51, 0xFF31, 0xFF31, 0xF6F1, 0xFF12, 0xFF12, 0xFF52, 0xFF51,   // 0x0D30 (3376)
0xF731, 0xCDCC, 0xC5AC, 0xCE2E, 0x9489, 0x6305, 0x5283, 0x4A44, 0x4203, 0x31A3, 0x3183, 0x2942, 0x2122, 0x2963, 0x2943, 0x20E2,   // 0x0D40 (3392)
0x18C2, 0x18A2, 0x1082, 0x1082, 0x1082, 0x1062, 0x0841, 0x0841, 0x0841, 0x0841, 0x0041, 0x0040, 0x0040, 0x0040, 0x0040, 0x0040,   // 0x0D50 (3408)
0x0040, 0x0040, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x1081, 0x1081,   // 0x0D60 (3424)
0x10A2, 0x18E3, 0x1903, 0x1902, 0x2102, 0x2142, 0x2121, 0x3182, 0x3161, 0x39A2, 0x5244, 0x83C9, 0xA50E, 0x948B, 0xA50D, 0xC611,   // 0x0D70 (3440)
0xEF57, 0xFFDA, 0xFFFB, 0xFFFC, 0xFFFE, 0xFFFF, 0xFFDF, 0xFFDF, 0xFFDF, 0xFFFF, 0xFFFE, 0xFFDE, 0xFFBD, 0xFFBC, 0xFFBC, 0xFFBA,   // 0x0D80 (3456)
0xFFBA, 0xFFB9, 0xF798, 0xF778, 0xFF98, 0xFF78, 0xFF77, 0xFF56, 0xFF55, 0xFF54, 0xFF33, 0xFF32, 0xFF31, 0xFF11, 0xFF10, 0xFEF0,   // 0x0D90 (3472)
0xFF2F, 0xFF0F, 0xFF0E, 0xFF0E, 0xFF0E, 0xFF0E, 0xF6CD, 0xF6AD, 0xF6CE, 0xFEEF, 0xFF10, 0xFEF0, 0xFF10, 0xFF30, 0xFF71, 0xF730,   // 0x0DA0 (3488)
0xE6AF, 0xC5CD, 0x9C89, 0x7B86, 0x7367, 0x7368, 0x5286, 0x39C4, 0x3163, 0x3162, 0x31A3, 0x4A46, 0x41E6, 0x2102, 0x18C2, 0x18C2,   // 0x0DB0 (3504)
0x18A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0841, 0x0841, 0x0040, 0x0020, 0x0020, 0x0020, 0x0040, 0x0040, 0x0040, 0x0040, 0x0040,   // 0x0DC0 (3520)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841, 0x0861, 0x1061, 0x10A2, 0x18A2, 0x1081, 0x18C2,   // 0x0DD0 (3536)
0x18E2, 0x2102, 0x2102, 0x2942, 0x3183, 0x5286, 0x6307, 0x41E3, 0x5243, 0x6B47, 0x948C, 0xAD6F, 0xCE53, 0xE716, 0xFFDA, 0xFFFB,   // 0x0DE0 (3552)
0xFFFC, 0xFFFD, 0xFFFE, 0xFFFF, 0xFFDF, 0xFFDF, 0xFFDE, 0xFFDE, 0xFFDE, 0xFFDD, 0xFFBB, 0xFFBB, 0xFFBA, 0xFF99, 0xFF98, 0xFF98,   // 0x0DF0 (3568)
0xFF97, 0xFF77, 0xFF77, 0xFF56, 0xFF55, 0xFF34, 0xFF33, 0xFF32, 0xFF11, 0xFF10, 0xFF10, 0xFEEF, 0xFECF, 0xFECE, 0xFEED, 0xFEED,   // 0x0E00 (3584)
0xFEEC, 0xFECC, 0xF6CC, 0xFECC, 0xF6AC, 0xF6AC, 0xF6AC, 0xFECD, 0xFECD, 0xFEAD, 0xF6CD, 0xF6EE, 0xFF0F, 0xFF0F, 0xF710, 0xDE4E,   // 0x0E10 (3600)
0xB50A, 0xB52C, 0x9C8B, 0x6B27, 0x5265, 0x39A3, 0x39C3, 0x5286, 0x6308, 0x4A46, 0x3163, 0x2122, 0x18E2, 0x18E2, 0x18C2, 0x10A2,   // 0x0E20 (3616)
0x1082, 0x1081, 0x0861, 0x0841, 0x0841, 0x0040, 0x0020, 0x0020, 0x0020, 0x0040, 0x0040, 0x0041, 0x0041, 0x0041, 0x0021, 0x0021,   // 0x0E30 (3632)
0x0021, 0x0021, 0x0021, 0x0020, 0x0020, 0x0841, 0x0841, 0x0861, 0x0861, 0x1081, 0x18A2, 0x10A2, 0x18A2, 0x18E2, 0x1902, 0x2102,   // 0x0E40 (3648)
0x2122, 0x2962, 0x39C3, 0x5AA6, 0x7B89, 0x7BA9, 0x7347, 0x7368, 0x8C4B, 0xC612, 0xEF58, 0xFFDB, 0xFFFC, 0xFFFC, 0xFFFD, 0xFFFE,   // 0x0E50 (3664)
0xFFDE, 0xFFDF, 0xFFDE, 0xFFDE, 0xFFDD, 0xFFDD, 0xFFDC, 0xFFBB, 0xFF9A, 0xFF99, 0xFF98, 0xFF77, 0xFF76, 0xFF76, 0xFF75, 0xFF55,   // 0x0E60 (3680)
0xFF34, 0xFF34, 0xFF13, 0xFF12, 0xFF11, 0xFEF0, 0xFEEF, 0xFEEE, 0xFEEE, 0xFECE, 0xFEAD, 0xFEAD, 0xFECC, 0xFEAB, 0xFEAB, 0xF6AA,   // 0x0E70 (3696)
0xF6AA, 0xF6AA, 0xF6AA, 0xF68A, 0xF68B, 0xF68B, 0xFE8B, 0xFE8B, 0xF68B, 0xF6AC, 0xF6CD, 0xF6CD, 0xFF2F, 0xF6EF, 0xD60D, 0xCDEE,   // 0x0E80 (3712)
0xB52D, 0x83C8, 0x5264, 0x5244, 0x62E7, 0x6B48, 0x62E7, 0x4204, 0x2922, 0x2102, 0x2102, 0x20E3, 0x18C2, 0x18A2, 0x10A2, 0x1081,   // 0x0E90 (3728)
0x1081, 0x0861, 0x0861, 0x0840, 0x0040, 0x0020, 0x0040, 0x0040, 0x0040, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x0EA0 (3744)
0x0020, 0x0020, 0x0020, 0x0841, 0x0841, 0x0861, 0x1081, 0x10A2, 0x1081, 0x1081, 0x18E2, 0x2123, 0x2123, 0x2122, 0x2942, 0x2942,   // 0x0EB0 (3760)
0x3162, 0x39A2, 0x62E6, 0xA4EE, 0xA4EE, 0x948D, 0xA52F, 0xDED6, 0xFFBB, 0xFFDC, 0xFFFD, 0xFFFD, 0xFFFE, 0xFFDE, 0xFFDE, 0xFFDE,   // 0x0EC0 (3776)
0xFFBD, 0xFFBD, 0xFFBC, 0xFFBB, 0xFFBA, 0xFF99, 0xFF98, 0xFF77, 0xFF76, 0xFF55, 0xFF55, 0xFF54, 0xFF34, 0xFF33, 0xFF32, 0xFF11,   // 0x0ED0 (3792)
0xFF11, 0xFF10, 0xFEEF, 0xFEEE, 0xFECD, 0xFECD, 0xFECC, 0xFEAC, 0xFE8C, 0xFE8C, 0xFE8B, 0xFE8B, 0xF68A, 0xF66A, 0xF66A, 0xF669,   // 0x0EE0 (3808)
0xF66A, 0xF66A, 0xF669, 0xF64A, 0xF64A, 0xF64A, 0xF66A, 0xF66A, 0xF68B, 0xF6AC, 0xF6CD, 0xFF0E, 0xEECE, 0xCDEC, 0xB52B, 0x9C89,   // 0x0EF0 (3824)
0x83A8, 0x83C9, 0x7BA9, 0x5AC6, 0x41E2, 0x3181, 0x2941, 0x2101, 0x2943, 0x2103, 0x18E2, 0x18C2, 0x10A2, 0x10A1, 0x1081, 0x0861,   // 0x0F00 (3840)
0x0861, 0x0840, 0x0040, 0x0040, 0x0040, 0x0040, 0x0040, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0020,   // 0x0F10 (3856)
0x0841, 0x0841, 0x0861, 0x0861, 0x1081, 0x10A2, 0x18A2, 0x18C2, 0x18E2, 0x2103, 0x2123, 0x2143, 0x2963, 0x3162, 0x3982, 0x39A2,   // 0x0F20 (3872)
0x5244, 0x7327, 0x946C, 0xB570, 0xCE75, 0xF79A, 0xFFFD, 0xFFDD, 0xFFFE, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFDE, 0xFFDD, 0xFFBD, 0xFFBC,   // 0x0F30 (3888)
0xFF9A, 0xFF9A, 0xFF79, 0xFF77, 0xFF76, 0xFF55, 0xFF54, 0xFF54, 0xFF33, 0xFF33, 0xFF12, 0xFF11, 0xFF10, 0xFF0F, 0xFEEF, 0xFEEE,   // 0x0F40 (3904)
0xFEED, 0xFEEC, 0xFECB, 0xFECB, 0xFEAB, 0xFEAB, 0xFE8B, 0xFE8B, 0xFE6B, 0xF66B, 0xF64A, 0xF64A, 0xF649, 0xF649, 0xF649, 0xF649,   // 0x0F50 (3920)
0xF629, 0xF629, 0xF629, 0xF629, 0xF649, 0xEE29, 0xF669, 0xF66A, 0xEE6A, 0xF6CC, 0xFF0E, 0xF6EF, 0xCDCC, 0xA4C9, 0xB54D, 0x9C8A,   // 0x0F60 (3936)
0x6B05, 0x4A02, 0x39A1, 0x3161, 0x3162, 0x3163, 0x2943, 0x2103, 0x20E2, 0x18C2, 0x10C2, 0x10A1, 0x1081, 0x0881, 0x0861, 0x0841,   // 0x0F70 (3952)
0x0040, 0x0040, 0x0040, 0x0041, 0x0040, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0020, 0x0841, 0x0861,   // 0x0F80 (3968)
0x0861, 0x1061, 0x1081, 0x10A2, 0x18C2, 0x18E2, 0x1902, 0x2103, 0x2102, 0x2922, 0x2963, 0x31A3, 0x5286, 0x5265, 0x5244, 0x83A9,   // 0x0F90 (3984)
0xACEE, 0xCE55, 0xF79B, 0xFFFD, 0xFFFE, 0xFFFE, 0xFFFF, 0xFFFF, 0xFFDF, 0xFFDE, 0xFFDE, 0xFFBD, 0xFFBC, 0xFF9A, 0xFF99, 0xFF78,   // 0x0FA0 (4000)
0xFF77, 0xFF56, 0xFF55, 0xFF54, 0xFF33, 0xFF33, 0xFF32, 0xFF11, 0xFEF1, 0xFF10, 0xFEEF, 0xFEEE, 0xFEED, 0xFEEC, 0xFECB, 0xFECA,   // 0x0FB0 (4016)
0xFEAA, 0xFEAA, 0xFEAA, 0xFE8A, 0xFE6A, 0xF66A, 0xF64B, 0xF64B, 0xF62A, 0xF62A, 0xF629, 0xF609, 0xF629, 0xF629, 0xF608, 0xF608,   // 0x0FC0 (4032)
0xF5E8, 0xEDE8, 0xEDE8, 0xEE08, 0xEE28, 0xEE08, 0xEE49, 0xFECC, 0xF6CC, 0xF6EE, 0xEEAE, 0xD60D, 0xC5AD, 0x9C89, 0x6AE4, 0x41E1,   // 0x0FD0 (4048)
0x39C1, 0x4A44, 0x6B28, 0x5AC8, 0x3163, 0x2102, 0x2102, 0x18E2, 0x18C2, 0x10A1, 0x1081, 0x0881, 0x0861, 0x0860, 0x0840, 0x0040,   // 0x0FE0 (4064)
0x0041, 0x0040, 0x0040, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0041, 0x0841, 0x0841, 0x0861, 0x1061, 0x1081,   // 0x0FF0 (4080)
0x1081, 0x10A2, 0x18E2, 0x1902, 0x2102, 0x2102, 0x2102, 0x2922, 0x3142, 0x39A2, 0x5AC6, 0x7B88, 0x83C9, 0x9CAC, 0xC5F2, 0xE719,   // 0x1000 (4096)
0xFFFD, 0xFFFE, 0xFFFE, 0xFFDF, 0xFFDF, 0xFFFF, 0xFFDE, 0xFFDD, 0xFFBB, 0xFFBA, 0xFF99, 0xFF78, 0xFF78, 0xFF57, 0xFF56, 0xFF54,   // 0x1010 (4112)
0xFF33, 0xFF32, 0xFF31, 0xFF11, 0xFF10, 0xFEF0, 0xFEF0, 0xFEEF, 0xFEED, 0xFECC, 0xFECC, 0xFECB, 0xFEAA, 0xFEAA, 0xFEA9, 0xFE89,   // 0x1020 (4128)
0xFE89, 0xFE69, 0xF649, 0xF64A, 0xF62A, 0xF62A, 0xF60A, 0xF609, 0xF609, 0xF5E9, 0xF5E9, 0xF5E8, 0xEDC8, 0xEDC8, 0xEDC8, 0xEDC8,   // 0x1030 (4144)
0xEDC8, 0xEDE7, 0xEE07, 0xEE08, 0xEE28, 0xEE49, 0xF66A, 0xF6AC, 0xFEEE, 0xEEAE, 0xBD4A, 0x9C47, 0x7B64, 0x6AE3, 0x6B05, 0x6B27,   // 0x1040 (4160)
0x7369, 0x5AE8, 0x3183, 0x2102, 0x2102, 0x20E2, 0x18C2, 0x10A1, 0x10A1, 0x0881, 0x0881, 0x0860, 0x0840, 0x0820, 0x0820, 0x0820,   // 0x1050 (4176)
0x0820, 0x0821, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0041, 0x0841, 0x0841, 0x0861, 0x1061, 0x1081, 0x10A1, 0x18A1,   // 0x1060 (4192)
0x18C1, 0x18E0, 0x2102, 0x2943, 0x2943, 0x3163, 0x3983, 0x3181, 0x41E2, 0x946B, 0xBDD0, 0xAD4E, 0xCE54, 0xF77B, 0xFFDE, 0xFFFF,   // 0x1070 (4208)
0xFFDE, 0xFFDF, 0xFFDE, 0xFFDE, 0xFFDD, 0xFFBB, 0xFFBA, 0xFFB8, 0xFF97, 0xFF77, 0xFF56, 0xFF55, 0xFF34, 0xFF33, 0xFF32, 0xFF31,   // 0x1080 (4224)
0xFF10, 0xFF0F, 0xFEEF, 0xFEEF, 0xFECE, 0xFECE, 0xFECC, 0xFECC, 0xFEAB, 0xFEAA, 0xFE8A, 0xFE89, 0xFE89, 0xFE69, 0xFE49, 0xF649,   // 0x1090 (4240)
0xF629, 0xF629, 0xF609, 0xF609, 0xF609, 0xEDE9, 0xEDE8, 0xEDC8, 0xEDC8, 0xEDA8, 0xEDA8, 0xEDA8, 0xED88, 0xED88, 0xEDA7, 0xE5A6,   // 0x10A0 (4256)
0xEDC7, 0xEDE7, 0xEDC7, 0xE5E7, 0xEE29, 0xF64A, 0xF68C, 0xE62C, 0xC569, 0xB4C8, 0xA467, 0xACEB, 0xA4CB, 0x7BA8, 0x4203, 0x2962,   // 0x10B0 (4272)
0x2962, 0x2102, 0x2102, 0x2102, 0x18C2, 0x10C2, 0x10A2, 0x08A1, 0x0881, 0x0860, 0x0840, 0x0840, 0x0820, 0x0820, 0x0821, 0x0821,   // 0x10C0 (4288)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0041, 0x0841, 0x0840, 0x0861, 0x1081, 0x1081, 0x10A1, 0x18C1, 0x18E1, 0x2102,   // 0x10D0 (4304)
0x3184, 0x5288, 0x62E9, 0x4A05, 0x3182, 0x39C2, 0x4A43, 0x948B, 0xC612, 0xD694, 0xF799, 0xFFFD, 0xFFFF, 0xFFDE, 0xFFDE, 0xFFFE,   // 0x10E0 (4320)
0xFFDE, 0xFFDD, 0xFFBB, 0xFF9A, 0xFF98, 0xFF77, 0xFF76, 0xFF56, 0xFF35, 0xFF34, 0xFF33, 0xFF32, 0xFF11, 0xFF10, 0xFEEF, 0xFEEE,   // 0x10F0 (4336)
0xFECE, 0xFECE, 0xFEAD, 0xFEAD, 0xFEAC, 0xFE8B, 0xFE8B, 0xFE8A, 0xF669, 0xF669, 0xF649, 0xF648, 0xF629, 0xF629, 0xF609, 0xF609,   // 0x1100 (4352)
0xEDE9, 0xEDE9, 0xEDE8, 0xEDC8, 0xEDA8, 0xEDA8, 0xEDA8, 0xED88, 0xED87, 0xED68, 0xE567, 0xED68, 0xE567, 0xE546, 0xE566, 0xE5A7,   // 0x1110 (4368)
0xE586, 0xE5A7, 0xEDE8, 0xEE2A, 0xF66B, 0xEE6C, 0xE64D, 0xE64D, 0xDE0D, 0xBD6C, 0x7B86, 0x4A42, 0x39C2, 0x2962, 0x2122, 0x2101,   // 0x1120 (4384)
0x2102, 0x2102, 0x20E2, 0x18C2, 0x10C2, 0x08A1, 0x0881, 0x0861, 0x0840, 0x0840, 0x0820, 0x0821, 0x0821, 0x0821, 0x0021, 0x0021,   // 0x1130 (4400)
0x0021, 0x0021, 0x0021, 0x0021, 0x0041, 0x0840, 0x0860, 0x0861, 0x1081, 0x10A1, 0x10A1, 0x18C2, 0x18E2, 0x1902, 0x2943, 0x41E5,   // 0x1140 (4416)
0x5288, 0x6B29, 0x738A, 0x7BEA, 0x73A8, 0x73C9, 0xAD70, 0xE738, 0xFFFC, 0xFFFE, 0xFFFE, 0xFFDE, 0xFFDE, 0xFFFE, 0xFFBD, 0xFFBB,   // 0x1150 (4432)
0xFF9A, 0xFF78, 0xFF77, 0xFF56, 0xFF55, 0xFF34, 0xFF34, 0xFF33, 0xFF12, 0xFF11, 0xFF10, 0xFEEF, 0xFEEE, 0xFEEE, 0xFECD, 0xFEAD,   // 0x1160 (4448)
0xFEAD, 0xFE8C, 0xFE8B, 0xFE8B, 0xFE6A, 0xFE6A, 0xF669, 0xF649, 0xF648, 0xF628, 0xF628, 0xF608, 0xEDE8, 0xEDE8, 0xEDC8, 0xEDC8,   // 0x1170 (4464)
0xEDC8, 0xEDA8, 0xED88, 0xED88, 0xED88, 0xE567, 0xE567, 0xE547, 0xE547, 0xE547, 0xE547, 0xDD26, 0xE546, 0xE546, 0xE566, 0xE587,   // 0x1180 (4480)
0xEDA8, 0xEDC9, 0xEE0A, 0xEE4C, 0xF68D, 0xF6AE, 0xD5EC, 0x93E6, 0x62C3, 0x41E1, 0x39E2, 0x39E3, 0x3183, 0x2922, 0x2902, 0x2102,   // 0x1190 (4496)
0x20E2, 0x18C2, 0x10C2, 0x10A2, 0x10A1, 0x0881, 0x0840, 0x0840, 0x0821, 0x0821, 0x0821, 0x0821, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x11A0 (4512)
0x0041, 0x0041, 0x0040, 0x0840, 0x0860, 0x0861, 0x1081, 0x10A1, 0x18C1, 0x18E2, 0x2102, 0x2102, 0x2102, 0x2102, 0x39A4, 0x6B29,   // 0x11B0 (4528)
0x946D, 0x94CD, 0x842B, 0x844C, 0xB5D3, 0xEF9B, 0xFFFD, 0xFFFD, 0xFFDD, 0xFFDD, 0xFFDD, 0xFFDD, 0xFF9B, 0xFF9A, 0xFF79, 0xFF57,   // 0x11C0 (4544)
0xFF56, 0xFF34, 0xFF33, 0xFF13, 0xFF12, 0xFF11, 0xFF10, 0xFEEF, 0xFEEF, 0xFECE, 0xFECD, 0xFECD, 0xFEAC, 0xFEAC, 0xFE8C, 0xFE8B,   // 0x11D0 (4560)
0xFE6B, 0xFE6A, 0xF66A, 0xF64A, 0xF649, 0xF629, 0xF628, 0xF608, 0xF608, 0xF5E8, 0xEDC8, 0xEDC8, 0xEDA8, 0xEDA8, 0xEDA8, 0xE588,   // 0x11E0 (4576)
0xE567, 0xE568, 0xE547, 0xE547, 0xE527, 0xE527, 0xE507, 0xE507, 0xE507, 0xE507, 0xDD07, 0xDD26, 0xDD26, 0xE547, 0xE567, 0xDD67,   // 0x11F0 (4592)
0xE588, 0xEE0A, 0xF64C, 0xF64C, 0xCD69, 0x93C5, 0x83A6, 0x62C4, 0x5284, 0x4A45, 0x3162, 0x2922, 0x2922, 0x2902, 0x18E2, 0x18C2,   // 0x1200 (4608)
0x10C2, 0x10C2, 0x10A2, 0x0881, 0x0861, 0x0841, 0x0821, 0x0821, 0x0821, 0x0821, 0x0021, 0x0021, 0x0040, 0x0040, 0x0040, 0x0040,   // 0x1210 (4624)
0x0040, 0x0840, 0x0860, 0x1081, 0x10A1, 0x10A1, 0x18C1, 0x18E2, 0x2102, 0x2103, 0x2123, 0x2943, 0x3163, 0x39E3, 0x4A64, 0x6B67,   // 0x1220 (4640)
0x9D0E, 0xC674, 0xE739, 0xF7DD, 0xFFFE, 0xFFFD, 0xFFDD, 0xFFDD, 0xFFDC, 0xFFBB, 0xFF9A, 0xFF79, 0xFF77, 0xFF56, 0xFF54, 0xFF33,   // 0x1230 (4656)
0xFF12, 0xFF11, 0xFF10, 0xFEF0, 0xFEEF, 0xFECE, 0xFECD, 0xFECD, 0xFECC, 0xFEAC, 0xFE8B, 0xFE8B, 0xF68B, 0xF66B, 0xF64A, 0xF64A,   // 0x1240 (4672)
0xF62A, 0xF629, 0xF629, 0xF608, 0xF608, 0xF5E8, 0xEDE8, 0xEDC8, 0xEDA8, 0xEDA8, 0xE588, 0xE587, 0xE568, 0xE567, 0xE547, 0xE547,   // 0x1250 (4688)
0xE527, 0xE527, 0xE507, 0xDCE6, 0xDCE6, 0xDCE6, 0xDCE7, 0xDCE7, 0xDCC7, 0xDCC6, 0xDCE6, 0xDD07, 0xE527, 0xDD27, 0xE588, 0xEDC9,   // 0x1260 (4704)
0xEE0A, 0xF66C, 0xEE4C, 0xDE0D, 0xD5EE, 0x9C8A, 0x6B27, 0x4A65, 0x3162, 0x2922, 0x2922, 0x2923, 0x20E2, 0x18E2, 0x18C2, 0x10C2,   // 0x1270 (4720)
0x10A2, 0x0881, 0x0861, 0x0841, 0x0821, 0x0821, 0x0821, 0x0821, 0x0021, 0x0022, 0x0040, 0x0040, 0x0040, 0x0040, 0x0040, 0x0840,   // 0x1280 (4736)
0x0860, 0x1081, 0x10A1, 0x10A1, 0x18C1, 0x18E2, 0x2102, 0x2923, 0x2943, 0x2922, 0x2921, 0x3181, 0x4A43, 0x73C9, 0xADB0, 0xDF17,   // 0x1290 (4752)
0xF7DC, 0xF7FE, 0xFFFF, 0xFFFD, 0xFFFC, 0xFFDC, 0xFFBB, 0xFF99, 0xFF78, 0xFF77, 0xFF55, 0xFF34, 0xFF33, 0xFF32, 0xFF11, 0xFEF0,   // 0x12A0 (4768)
0xFEEF, 0xFEEE, 0xFECE, 0xFECD, 0xFECC, 0xFEAC, 0xFEAB, 0xFE8B, 0xF68A, 0xF66A, 0xF66A, 0xF64A, 0xF62A, 0xF62A, 0xF609, 0xF609,   // 0x12B0 (4784)
0xF608, 0xF5E8, 0xEDE8, 0xEDC8, 0xEDC8, 0xEDA8, 0xED88, 0xED88, 0xE567, 0xE567, 0xE547, 0xE547, 0xE527, 0xE527, 0xE507, 0xDD06,   // 0x12C0 (4800)
0xDCE6, 0xDCC6, 0xDCC6, 0xDCA6, 0xDCA7, 0xDCA7, 0xDCA7, 0xDCA6, 0xDCA6, 0xDCC6, 0xDCE6, 0xDD06, 0xE547, 0xE568, 0xE588, 0xEE0A,   // 0x12D0 (4816)
0xF64C, 0xEE6E, 0xCD8C, 0x9407, 0x62C4, 0x41E2, 0x2961, 0x2921, 0x2902, 0x2943, 0x2103, 0x18E2, 0x18C2, 0x10C2, 0x10A2, 0x0881,   // 0x12E0 (4832)
0x0861, 0x0841, 0x0821, 0x0821, 0x0821, 0x0821, 0x0821, 0x0021, 0x0040, 0x0020, 0x0020, 0x0040, 0x0840, 0x0860, 0x0861, 0x1081,   // 0x12F0 (4848)
0x10A1, 0x10A1, 0x18C1, 0x18E2, 0x20E2, 0x2103, 0x2923, 0x2963, 0x39E4, 0x5AE7, 0x73A9, 0x7C0A, 0xAD90, 0xDF17, 0xFFFD, 0xFFFE,   // 0x1300 (4864)
0xFFFF, 0xFFFD, 0xFFDB, 0xFFBA, 0xFF99, 0xFF98, 0xFF77, 0xFF55, 0xFF34, 0xFF32, 0xFF11, 0xFF10, 0xFEF0, 0xFEEE, 0xFEED, 0xFECD,   // 0x1310 (4880)
0xFEAC, 0xFEAC, 0xFEAB, 0xFE8B, 0xFE8B, 0xFE8A, 0xF66A, 0xF64A, 0xF64A, 0xF629, 0xF609, 0xF609, 0xF609, 0xF5E8, 0xEDE8, 0xEDC8,   // 0x1320 (4896)
0xEDC8, 0xEDA8, 0xEDA8, 0xED87, 0xED67, 0xE567, 0xE547, 0xE547, 0xE547, 0xE527, 0xE507, 0xE507, 0xDCE7, 0xDCE6, 0xDCC6, 0xDCC6,   // 0x1330 (4912)
0xDCA6, 0xDC86, 0xDC87, 0xDC87, 0xDC87, 0xD486, 0xDC86, 0xDC86, 0xDCA6, 0xDCA6, 0xDCE6, 0xDD27, 0xED88, 0xEDC9, 0xF62B, 0xEE2C,   // 0x1340 (4928)
0xB4E8, 0x83A5, 0x6AE4, 0x4A43, 0x4A24, 0x39A3, 0x2922, 0x3163, 0x2102, 0x18E2, 0x18E3, 0x10C2, 0x10A2, 0x10A1, 0x1081, 0x0861,   // 0x1350 (4944)
0x0821, 0x0821, 0x0821, 0x0821, 0x0821, 0x0021, 0x0021, 0x0021, 0x0020, 0x0041, 0x0841, 0x0860, 0x0861, 0x1081, 0x10A1, 0x18C1,   // 0x1360 (4960)
0x18C1, 0x18E2, 0x2102, 0x2102, 0x2122, 0x3183, 0x4A46, 0x73AA, 0x9CCD, 0x9CED, 0xB5D1, 0xDEF7, 0xFFFD, 0xFFFF, 0xFFFE, 0xFFFC,   // 0x1370 (4976)
0xFFDA, 0xFFB9, 0xFF98, 0xFF77, 0xFF55, 0xFF34, 0xFF32, 0xFF11, 0xFF10, 0xFEEF, 0xFEEE, 0xFECD, 0xFECC, 0xFECC, 0xFEAC, 0xFE8B,   // 0x1380 (4992)
0xFE8B, 0xFE8A, 0xFE6A, 0xF66A, 0xF64A, 0xF64A, 0xF629, 0xF629, 0xF5E9, 0xF5E9, 0xEDE8, 0xEDC8, 0xEDA8, 0xEDA8, 0xED88, 0xED88,   // 0x1390 (5008)
0xED67, 0xED67, 0xE547, 0xE547, 0xE527, 0xE527, 0xE507, 0xDD06, 0xDCE6, 0xDCE6, 0xDCC6, 0xDCC7, 0xDCA6, 0xDCA6, 0xDC86, 0xDC86,   // 0x13A0 (5024)
0xD486, 0xD467, 0xD466, 0xD446, 0xD446, 0xD465, 0xD465, 0xD485, 0xD4A5, 0xDCE6, 0xE547, 0xEDA8, 0xF60A, 0xE5EA, 0xBD08, 0xACA8,   // 0x13B0 (5040)
0x9428, 0x6B26, 0x5AC6, 0x4204, 0x2942, 0x2922, 0x2102, 0x18E2, 0x18C1, 0x10A1, 0x0881, 0x0881, 0x1081, 0x0861, 0x0840, 0x0821,   // 0x13C0 (5056)
0x0821, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0041, 0x0841, 0x0861, 0x0861, 0x1081, 0x10A1, 0x18C2, 0x18E2, 0x2102,   // 0x13D0 (5072)
0x2102, 0x2122, 0x2943, 0x3184, 0x39C3, 0x5265, 0x842B, 0xBDF2, 0xDEF6, 0xF7BA, 0xFFFD, 0xFFFE, 0xFFDD, 0xFFDB, 0xFFB9, 0xFF98,   // 0x13E0 (5088)
0xFF77, 0xFF55, 0xFF34, 0xFF12, 0xFF11, 0xFEF0, 0xFEEF, 0xFEEE, 0xFECD, 0xFECC, 0xFEAB, 0xFEAB, 0xFE8B, 0xFE8A, 0xF66A, 0xF66A,   // 0x13F0 (5104)
0xF64A, 0xF64A, 0xF629, 0xF629, 0xF609, 0xF5E9, 0xEDC8, 0xEDC8, 0xEDC8, 0xEDA8, 0xED88, 0xED88, 0xED67, 0xED67, 0xE567, 0xE547,   // 0x1400 (5120)
0xE547, 0xE527, 0xE507, 0xE506, 0xDD06, 0xDCE6, 0xDCC6, 0xDCC6, 0xDCA6, 0xDCA6, 0xDC86, 0xDC86, 0xD466, 0xD446, 0xD446, 0xD446,   // 0x1410 (5136)
0xD446, 0xCC25, 0xCC25, 0xCC25, 0xD445, 0xCC45, 0xD465, 0xD4A5, 0xDD06, 0xED68, 0xEDC9, 0xEE2B, 0xEE8D, 0xDE2D, 0xB50B, 0x7B87,   // 0x1420 (5152)
0x5AA5, 0x39C3, 0x2921, 0x2101, 0x2942, 0x2942, 0x2102, 0x1902, 0x10E2, 0x1081, 0x0860, 0x0840, 0x0841, 0x0841, 0x0821, 0x0000,   // 0x1430 (5168)
0x0021, 0x0841, 0x0021, 0x0021, 0x0021, 0x0841, 0x0841, 0x0861, 0x0881, 0x1081, 0x10A2, 0x18C2, 0x18E2, 0x2103, 0x2102, 0x2122,   // 0x1440 (5184)
0x2963, 0x3183, 0x3183, 0x4204, 0x7369, 0xB591, 0xF778, 0xFFFB, 0xFFFC, 0xFFFD, 0xFFDC, 0xFFBA, 0xFF98, 0xFF77, 0xFF56, 0xFF34,   // 0x1450 (5200)
0xFF12, 0xFF11, 0xFEF0, 0xFECF, 0xFECE, 0xFECD, 0xF6AC, 0xFE8B, 0xFE8B, 0xFE8A, 0xF66A, 0xF64A, 0xF64A, 0xF62A, 0xF629, 0xF609,   // 0x1460 (5216)
0xF609, 0xF5E9, 0xEDE8, 0xEDC8, 0xEDC8, 0xEDA8, 0xEDA8, 0xED88, 0xED88, 0xED68, 0xED67, 0xE547, 0xE547, 0xE527, 0xE507, 0xE507,   // 0x1470 (5232)
0xDD06, 0xDCE6, 0xDCE6, 0xDCC6, 0xDCA6, 0xDCA6, 0xDC86, 0xD486, 0xD466, 0xD446, 0xD426, 0xD426, 0xD446, 0xCC46, 0xCC25, 0xCC05,   // 0x1480 (5248)
0xCC05, 0xCC04, 0xCC24, 0xCC24, 0xCC24, 0xCC65, 0xDCC6, 0xE527, 0xE568, 0xEDE9, 0xF6AD, 0xC56A, 0x83C5, 0x5AC3, 0x4202, 0x3181,   // 0x1490 (5264)
0x2941, 0x2921, 0x39C4, 0x4226, 0x4A67, 0x4A67, 0x39E6, 0x2123, 0x1081, 0x0840, 0x0820, 0x0840, 0x0820, 0x0020, 0x0020, 0x0041,   // 0x14A0 (5280)
0x0001, 0x0021, 0x0021, 0x0841, 0x0861, 0x0862, 0x1081, 0x10A1, 0x18A2, 0x18C2, 0x18E2, 0x2102, 0x2122, 0x2942, 0x2963, 0x41E5,   // 0x14B0 (5296)
0x5AA7, 0x6B29, 0x7BCB, 0xB571, 0xF778, 0xFFFB, 0xFFFC, 0xFFDC, 0xFFDC, 0xFF99, 0xFF77, 0xFF56, 0xFF35, 0xFF33, 0xFF12, 0xFEF0,   // 0x14C0 (5312)
0xFECF, 0xFECE, 0xF6CD, 0xF6AC, 0xF68C, 0xF68B, 0xFE6A, 0xFE6A, 0xF64A, 0xF64A, 0xF629, 0xF609, 0xF609, 0xF609, 0xEDE9, 0xEDC9,   // 0x14D0 (5328)
0xEDC8, 0xEDA8, 0xEDA8, 0xED87, 0xED87, 0xE567, 0xE567, 0xE547, 0xE547, 0xE527, 0xE527, 0xE506, 0xDCE6, 0xDCE6, 0xDCE6, 0xDCC6,   // 0x14E0 (5344)
0xDCC6, 0xDCA5, 0xD4A5, 0xD486, 0xD466, 0xD466, 0xD446, 0xD426, 0xD425, 0xCC05, 0xCC25, 0xCC25, 0xCC05, 0xC3E4, 0xCBE4, 0xCBE4,   // 0x14F0 (5360)
0xCC04, 0xCC04, 0xCC04, 0xCC24, 0xD485, 0xDCE7, 0xE527, 0xE5C8, 0xEE2B, 0xBD08, 0x8BE6, 0x7B86, 0x6B46, 0x6B27, 0x6308, 0x5286,   // 0x1500 (5376)
0x5287, 0x4A66, 0x4A66, 0x4226, 0x31C5, 0x2143, 0x18C1, 0x1060, 0x0840, 0x0820, 0x0820, 0x0840, 0x0840, 0x0040, 0x0001, 0x0021,   // 0x1510 (5392)
0x0021, 0x0841, 0x0861, 0x0862, 0x1082, 0x10A2, 0x18C2, 0x18C2, 0x18E2, 0x2103, 0x2102, 0x2121, 0x3183, 0x5266, 0x7BAB, 0x9CAF,   // 0x1520 (5408)
0xAD51, 0xCE55, 0xF7BA, 0xFFFB, 0xFFFB, 0xFFDB, 0xFF9A, 0xFF77, 0xFF56, 0xFF54, 0xFF33, 0xFF31, 0xFF10, 0xFECE, 0xFECD, 0xFEAD,   // 0x1530 (5424)
0xF6AC, 0xF6AC, 0xF68B, 0xF66A, 0xFE69, 0xF649, 0xF649, 0xF629, 0xF629, 0xF609, 0xF5E9, 0xEDE9, 0xEDC8, 0xEDC8, 0xEDA8, 0xEDA8,   // 0x1540 (5440)
0xED87, 0xED67, 0xE567, 0xE547, 0xE547, 0xE527, 0xE527, 0xE506, 0xDCE6, 0xDCE6, 0xDCC6, 0xDCC6, 0xDCA6, 0xDCA6, 0xD4A5, 0xD485,   // 0x1550 (5456)
0xD465, 0xD465, 0xD465, 0xD446, 0xD425, 0xD425, 0xCC05, 0xCC05, 0xCC05, 0xCC04, 0xCBE4, 0xC3E4, 0xC3E4, 0xCBE4, 0xCC04, 0xCC04,   // 0x1560 (5472)
0xC3E4, 0xC404, 0xCC44, 0xD485, 0xDCE6, 0xE5A8, 0xEE2A, 0xDE0B, 0xCDCD, 0xBD6D, 0xA4EC, 0x9CAD, 0x948D, 0x7BAA, 0x5AC8, 0x39C4,   // 0x1570 (5488)
0x2121, 0x1901, 0x10E1, 0x10C1, 0x10A1, 0x1081, 0x0861, 0x0820, 0x0020, 0x0841, 0x0841, 0x0020, 0x0021, 0x0021, 0x0021, 0x0841,   // 0x1580 (5504)
0x0861, 0x1061, 0x1081, 0x10A2, 0x18A2, 0x18C2, 0x20E2, 0x2103, 0x2122, 0x2942, 0x3182, 0x39A3, 0x5285, 0x946D, 0xCE54, 0xF77A,   // 0x1590 (5520)
0xFFDB, 0xFFDB, 0xFFDB, 0xFF9A, 0xFF78, 0xFF76, 0xFF54, 0xFF52, 0xFF31, 0xFF0F, 0xFEED, 0xFECC, 0xFEAC, 0xFE8B, 0xFE8B, 0xF68A,   // 0x15A0 (5536)
0xF66A, 0xF649, 0xF649, 0xF628, 0xF628, 0xF608, 0xF5E8, 0xEDE8, 0xEDC8, 0xEDC8, 0xEDA8, 0xEDA7, 0xE587, 0xE587, 0xE567, 0xE567,   // 0x15B0 (5552)
0xE547, 0xE547, 0xE527, 0xE527, 0xDD06, 0xDCE6, 0xDCE6, 0xDCE6, 0xDCC6, 0xD4A6, 0xD4A5, 0xD4A5, 0xD486, 0xD465, 0xD465, 0xD465,   // 0x15C0 (5568)
0xD445, 0xD425, 0xD405, 0xCC05, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE4, 0xCBC4, 0xCBC4, 0xCBC5, 0xCBE5, 0xCBE5, 0xCBE4, 0xCBE4, 0xCC04,   // 0x15D0 (5584)
0xCC04, 0xD444, 0xDCA5, 0xE568, 0xEDE9, 0xEE6D, 0xE66E, 0xB52B, 0x7BA7, 0x5AA4, 0x4A03, 0x39C3, 0x3183, 0x2962, 0x2121, 0x1901,   // 0x15E0 (5600)
0x18C2, 0x10A1, 0x1081, 0x0861, 0x0841, 0x0021, 0x0021, 0x0021, 0x0021, 0x0041, 0x0021, 0x0021, 0x0021, 0x0841, 0x0861, 0x1061,   // 0x15F0 (5616)
0x1081, 0x10A1, 0x18C2, 0x18C2, 0x20E2, 0x2103, 0x2122, 0x2941, 0x3182, 0x39C2, 0x41E3, 0x5AC6, 0x9CCE, 0xEF59, 0xFFFB, 0xFFFB,   // 0x1600 (5632)
0xFFBA, 0xFF79, 0xFF78, 0xFF55, 0xFF33, 0xFF31, 0xFF0F, 0xFEED, 0xFECC, 0xFEAC, 0xFE8B, 0xF66B, 0xF66A, 0xF66A, 0xF649, 0xF629,   // 0x1610 (5648)
0xF628, 0xF608, 0xF5E8, 0xEDE8, 0xEDC8, 0xEDC8, 0xEDA8, 0xEDA8, 0xE587, 0xE587, 0xE567, 0xE567, 0xE547, 0xE547, 0xE527, 0xE527,   // 0x1620 (5664)
0xE507, 0xDD06, 0xDCE7, 0xDCE6, 0xDCC6, 0xDCC6, 0xDCC6, 0xD4A6, 0xD486, 0xD486, 0xD465, 0xD465, 0xD445, 0xD445, 0xCC25, 0xCC05,   // 0x1630 (5680)
0xCC05, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBC5, 0xCBC4, 0xCBC5, 0xCBC5, 0xCBE5, 0xCBE5, 0xCBE4, 0xCBE4, 0xCBE4, 0xCC04, 0xCC24,   // 0x1640 (5696)
0xD485, 0xDD07, 0xE5A9, 0xE62C, 0xBD29, 0x7B44, 0x5A82, 0x41C1, 0x3140, 0x2900, 0x2921, 0x2101, 0x1901, 0x1902, 0x18E2, 0x10A2,   // 0x1650 (5712)
0x1081, 0x0861, 0x0841, 0x0041, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0841, 0x0861, 0x1061, 0x1081, 0x10A1,   // 0x1660 (5728)
0x18C2, 0x18C2, 0x20E2, 0x2102, 0x2122, 0x2941, 0x39E3, 0x5AA6, 0x5AA6, 0x6307, 0x9CCE, 0xEF79, 0xFFDA, 0xFFBA, 0xFF99, 0xFF78,   // 0x1670 (5744)
0xFF56, 0xFF33, 0xFF32, 0xF710, 0xF6EE, 0xFECD, 0xF6AC, 0xF68B, 0xF66B, 0xF64A, 0xF64A, 0xF649, 0xF629, 0xF608, 0xF608, 0xEDE8,   // 0x1680 (5760)
0xEDE8, 0xEDC7, 0xEDC7, 0xEDA7, 0xEDA7, 0xE587, 0xE567, 0xE567, 0xE547, 0xE547, 0xE527, 0xE526, 0xE506, 0xDD06, 0xDD06, 0xDCE6,   // 0x1690 (5776)
0xDCE6, 0xDCC6, 0xDCA6, 0xDCA6, 0xD4A6, 0xD486, 0xD465, 0xD465, 0xD445, 0xD445, 0xCC25, 0xD425, 0xCC05, 0xCBE5, 0xCBE5, 0xCBE5,   // 0x16A0 (5792)
0xCBE5, 0xCBE5, 0xCBE5, 0xCBC5, 0xCBC5, 0xCBC5, 0xCBC5, 0xCBE5, 0xCBE5, 0xCBE5, 0xC3C4, 0xCBE4, 0xC3E4, 0xCC04, 0xD445, 0xDCE7,   // 0x16B0 (5808)
0xE58A, 0xE5CC, 0xB4E9, 0x7B44, 0x6AE4, 0x5244, 0x41C3, 0x3142, 0x2922, 0x2102, 0x18E1, 0x18E2, 0x18E2, 0x10A1, 0x1081, 0x0861,   // 0x16C0 (5824)
0x0861, 0x0841, 0x0041, 0x0021, 0x0021, 0x0021, 0x0021, 0x0020, 0x0020, 0x0841, 0x0861, 0x1061, 0x1081, 0x10A1, 0x18C1, 0x18E1,   // 0x16D0 (5840)
0x20E2, 0x2102, 0x2942, 0x2961, 0x4A44, 0x7389, 0x8C2B, 0x9CCD, 0xCE53, 0xFFFA, 0xFFFA, 0xFFB9, 0xFFB9, 0xFF77, 0xFF35, 0xFF32,   // 0x16E0 (5856)
0xFF10, 0xF6EE, 0xF6ED, 0xF6CC, 0xF6AB, 0xF68A, 0xF66A, 0xF64A, 0xF64A, 0xF629, 0xEE08, 0xEDE8, 0xEDE8, 0xEDC8, 0xEDC8, 0xEDA7,   // 0x16F0 (5872)
0xEDA7, 0xED87, 0xE587, 0xE567, 0xE567, 0xE547, 0xE527, 0xE527, 0xE507, 0xDD06, 0xDCE6, 0xDCE6, 0xDCE6, 0xDCC6, 0xDCC6, 0xD4A6,   // 0x1700 (5888)
0xD486, 0xD486, 0xD466, 0xD465, 0xD445, 0xD445, 0xCC25, 0xCC25, 0xCC05, 0xCC05, 0xCC05, 0xCBE5, 0xCBE5, 0xCBC5, 0xCBC5, 0xCBE5,   // 0x1710 (5904)
0xCBE5, 0xCBC5, 0xCBC5, 0xCBC5, 0xCBC5, 0xCBC5, 0xCBE5, 0xCBE5, 0xC3C4, 0xCBE4, 0xC3E4, 0xC3E4, 0xCC25, 0xD4C6, 0xDD28, 0xE5CC,   // 0x1720 (5920)
0xE62F, 0xBD2C, 0x8BE9, 0x6B07, 0x5A46, 0x41A4, 0x3163, 0x2922, 0x2102, 0x18E2, 0x18E2, 0x10A1, 0x1081, 0x0881, 0x0861, 0x0841,   // 0x1730 (5936)
0x0041, 0x0041, 0x0041, 0x0040, 0x0020, 0x0020, 0x0040, 0x0840, 0x0861, 0x1061, 0x1081, 0x10A1, 0x18C1, 0x18E1, 0x2102, 0x2122,   // 0x1740 (5952)
0x2121, 0x2120, 0x31A1, 0x5A84, 0x7BC9, 0xAD4F, 0xDED5, 0xFFD9, 0xFFD9, 0xFF98, 0xFFB8, 0xFF76, 0xFF34, 0xFF11, 0xF6EE, 0xF6CD,   // 0x1750 (5968)
0xF6CB, 0xF6AA, 0xF68A, 0xF66A, 0xF64A, 0xF629, 0xF629, 0xEE08, 0xEDE8, 0xEDC8, 0xEDC8, 0xEDA8, 0xEDA7, 0xE587, 0xE567, 0xE567,   // 0x1760 (5984)
0xE567, 0xE547, 0xE547, 0xE527, 0xDD26, 0xDD07, 0xDD06, 0xDCE6, 0xDCE6, 0xDCE6, 0xDCC6, 0xDCC6, 0xDCA6, 0xD486, 0xD486, 0xD466,   // 0x1770 (6000)
0xD466, 0xD445, 0xD425, 0xCC25, 0xCC25, 0xCC05, 0xCC05, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBC5, 0xCBC5, 0xCBC5, 0xCBC5, 0xCBC5, 0xCBC5,   // 0x1780 (6016)
0xCBC5, 0xCBC5, 0xCBC5, 0xCBC5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE4, 0xC3E4, 0xC3E4, 0xCC24, 0xCC65, 0xDD28, 0xEE0D, 0xDDEE, 0xAC8A,   // 0x1790 (6032)
0x8367, 0x62A6, 0x5204, 0x3963, 0x2922, 0x2902, 0x2102, 0x18E2, 0x18C2, 0x10A1, 0x10A1, 0x0881, 0x0861, 0x0841, 0x0841, 0x0041,   // 0x17A0 (6048)
0x0041, 0x0020, 0x0040, 0x0040, 0x0040, 0x0840, 0x0860, 0x1081, 0x1081, 0x10A1, 0x18C1, 0x18C1, 0x20E1, 0x2102, 0x2121, 0x2940,   // 0x17B0 (6064)
0x2940, 0x39A1, 0x5A84, 0x83E9, 0xBDD0, 0xFFB8, 0xFFF9, 0xFFB7, 0xFF76, 0xFF34, 0xFF12, 0xFF0F, 0xF6ED, 0xF6AB, 0xF6AA, 0xF68A,   // 0x17C0 (6080)
0xF669, 0xF649, 0xF629, 0xF609, 0xF5E9, 0xEDE8, 0xEDC8, 0xEDA7, 0xEDA7, 0xED87, 0xED87, 0xE567, 0xE547, 0xE547, 0xE547, 0xE527,   // 0x17D0 (6096)
0xE527, 0xDD07, 0xDD06, 0xDCE6, 0xDCE6, 0xDCC6, 0xDCC6, 0xDCC6, 0xD4A6, 0xD4A6, 0xD486, 0xD486, 0xD466, 0xD466, 0xD445, 0xD445,   // 0x17E0 (6112)
0xCC25, 0xCC25, 0xCC05, 0xCC05, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBC5, 0xCBC5, 0xCBC5, 0xCBC5, 0xCBC5, 0xCBC5, 0xCBC5,   // 0x17F0 (6128)
0xCBC5, 0xCBC5, 0xCBE5, 0xCBE5, 0xCBC5, 0xCBE5, 0xC3E4, 0xC3E4, 0xCC24, 0xCC44, 0xDD07, 0xF60C, 0xD58C, 0x93C6, 0x7305, 0x5A64,   // 0x1800 (6144)
0x41A2, 0x3101, 0x28E1, 0x20E1, 0x20E1, 0x18E1, 0x10C1, 0x10A1, 0x10A1, 0x0881, 0x0861, 0x0841, 0x0841, 0x0041, 0x0041, 0x0020,   // 0x1810 (6160)
0x0840, 0x0040, 0x0040, 0x0860, 0x0861, 0x10A1, 0x18E2, 0x2123, 0x2943, 0x31A4, 0x39C5, 0x4205, 0x4225, 0x5285, 0x5AC5, 0x62E6,   // 0x1820 (6176)
0x6B26, 0x8409, 0xBDD0, 0xFFB7, 0xFFF8, 0xFFB6, 0xFF54, 0xFF13, 0xFEF0, 0xFEEE, 0xF6CC, 0xF68B, 0xF689, 0xF669, 0xF649, 0xF629,   // 0x1830 (6192)
0xF609, 0xEDE9, 0xEDC8, 0xEDC8, 0xEDA7, 0xED87, 0xED87, 0xED67, 0xE567, 0xE547, 0xE547, 0xE527, 0xE527, 0xE507, 0xE507, 0xDCE7,   // 0x1840 (6208)
0xDCE6, 0xDCC6, 0xDCC6, 0xDCC6, 0xD4A6, 0xDCA6, 0xD486, 0xD486, 0xD466, 0xD466, 0xD446, 0xCC45, 0xCC25, 0xCC25, 0xCC05, 0xCC05,   // 0x1850 (6224)
0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBC5, 0xCBC5, 0xCBC5, 0xCBC5, 0xCBC5, 0xCBC5, 0xCBC5,   // 0x1860 (6240)
0xCBC5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE4, 0xCC05, 0xCC04, 0xD464, 0xDCE6, 0xEDEB, 0xDDCC, 0xACA9, 0x8BC7, 0x7306, 0x5A85, 0x5225,   // 0x1870 (6256)
0x4A25, 0x4A25, 0x4205, 0x31C5, 0x2123, 0x10C1, 0x1081, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0040, 0x0040, 0x0020,   // 0x1880 (6272)
0x0040, 0x0860, 0x0881, 0x10A1, 0x2943, 0x39C5, 0x4A27, 0x5AA9, 0x630A, 0x6B4A, 0x6B4A, 0x83EB, 0x946C, 0x9C8C, 0xA50E, 0xBDB0,   // 0x1890 (6288)
0xDED4, 0xFFB7, 0xFFB7, 0xFF95, 0xFF53, 0xFF32, 0xFECF, 0xFECD, 0xF6AB, 0xF68A, 0xF669, 0xF648, 0xF628, 0xF609, 0xF5E9, 0xEDC9,   // 0x18A0 (6304)
0xEDA8, 0xEDA8, 0xED87, 0xE567, 0xED67, 0xE547, 0xE527, 0xE527, 0xE527, 0xDD07, 0xDCE6, 0xDCE7, 0xDCE7, 0xDCC7, 0xDCC6, 0xDCA6,   // 0x18B0 (6320)
0xD4A6, 0xD4A6, 0xD486, 0xD486, 0xD466, 0xD466, 0xD446, 0xD446, 0xD446, 0xCC25, 0xCC25, 0xCC05, 0xCC05, 0xCC05, 0xCBE5, 0xCBE5,   // 0x18C0 (6336)
0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBC5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBC5, 0xCBC5, 0xCBC5, 0xCBC5, 0xCBE5,   // 0x18D0 (6352)
0xCBE5, 0xCBE5, 0xCBE5, 0xCBE4, 0xCC04, 0xD484, 0xD4C5, 0xE5AA, 0xF66E, 0xDE0E, 0xBD4D, 0x9C6B, 0x8BEA, 0x83AA, 0x7BAB, 0x738A,   // 0x18E0 (6368)
0x738A, 0x52C8, 0x31C5, 0x2103, 0x10A1, 0x0881, 0x0881, 0x0861, 0x0861, 0x0841, 0x0841, 0x0040, 0x0020, 0x0020, 0x0040, 0x0860,   // 0x18F0 (6384)
0x0861, 0x10A1, 0x18C2, 0x18E2, 0x2102, 0x2943, 0x3184, 0x31A4, 0x3183, 0x41E3, 0x5245, 0x5AA5, 0x7B88, 0x9CAC, 0xC631, 0xFFB7,   // 0x1900 (6400)
0xFFB6, 0xFF74, 0xFF32, 0xFF10, 0xFECE, 0xFEAC, 0xF68B, 0xF66A, 0xF649, 0xF628, 0xF608, 0xF5E9, 0xEDC8, 0xEDA8, 0xED88, 0xED88,   // 0x1910 (6416)
0xE567, 0xE547, 0xE547, 0xE527, 0xE507, 0xE507, 0xDD07, 0xDCE6, 0xDCC6, 0xDCC6, 0xDCC6, 0xDCA6, 0xDCA6, 0xDC86, 0xD486, 0xD485,   // 0x1920 (6432)
0xD465, 0xD465, 0xD445, 0xD445, 0xD425, 0xD426, 0xD425, 0xCC05, 0xCC05, 0xCC05, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5,   // 0x1930 (6448)
0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE4, 0xCBE4, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5,   // 0x1940 (6464)
0xCBE4, 0xCBE4, 0xCBE3, 0xCC23, 0xDCE6, 0xE5CA, 0xDDCB, 0xACA9, 0x8386, 0x6B05, 0x62A5, 0x5244, 0x4204, 0x39C3, 0x31A3, 0x2963,   // 0x1950 (6480)
0x1902, 0x10A1, 0x10A1, 0x0881, 0x0861, 0x0861, 0x0841, 0x0841, 0x0040, 0x0040, 0x0841, 0x0020, 0x0020, 0x0840, 0x0840, 0x0861,   // 0x1960 (6496)
0x10A1, 0x10A1, 0x10A1, 0x18C1, 0x18E1, 0x20E2, 0x2101, 0x2921, 0x2921, 0x39A2, 0x5264, 0x7387, 0xB58F, 0xF796, 0xFFB6, 0xFF73,   // 0x1970 (6512)
0xFF10, 0xFEEE, 0xFEAD, 0xF68C, 0xF66B, 0xF649, 0xF629, 0xF608, 0xF5E8, 0xEDC8, 0xEDA9, 0xED88, 0xED68, 0xE567, 0xE547, 0xE527,   // 0x1980 (6528)
0xE527, 0xE507, 0xE4E6, 0xDCE6, 0xDCE6, 0xDCC6, 0xDCA6, 0xDCA6, 0xDCA6, 0xDC86, 0xD486, 0xD486, 0xD465, 0xD465, 0xD445, 0xD445,   // 0x1990 (6544)
0xD445, 0xD425, 0xCC25, 0xCC05, 0xCC05, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE4, 0xCBE4, 0xCBE4, 0xCBE4, 0xCBE4, 0xCBE5, 0xCBE5,   // 0x19A0 (6560)
0xCBE5, 0xCBE5, 0xCC05, 0xCBE5, 0xCC04, 0xD404, 0xCBE4, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE4, 0xCBE4, 0xCBE4,   // 0x19B0 (6576)
0xC3E3, 0xCC43, 0xDD06, 0xE5CA, 0xCD6B, 0x9C27, 0x6AE4, 0x5242, 0x41C2, 0x3161, 0x2921, 0x2100, 0x18E0, 0x18E1, 0x10C1, 0x10A1,   // 0x19C0 (6592)
0x10A1, 0x0881, 0x0861, 0x0840, 0x0840, 0x0040, 0x0040, 0x0040, 0x0841, 0x0020, 0x0840, 0x0841, 0x0840, 0x0840, 0x1081, 0x10A1,   // 0x19D0 (6608)
0x18C2, 0x2102, 0x2122, 0x2102, 0x2922, 0x3142, 0x3982, 0x4A04, 0x5A85, 0x7B88, 0xB58F, 0xF775, 0xFFB5, 0xFF73, 0xFF10, 0xFECD,   // 0x19E0 (6624)
0xFE8C, 0xF66B, 0xF64A, 0xEE09, 0xEE08, 0xEDE8, 0xEDC8, 0xEDA8, 0xED68, 0xE548, 0xE547, 0xE547, 0xE526, 0xE506, 0xDD07, 0xDCE6,   // 0x19F0 (6640)
0xDCC6, 0xDCC6, 0xDCC6, 0xDCA6, 0xDCA6, 0xD486, 0xD486, 0xD466, 0xD466, 0xD466, 0xD445, 0xD445, 0xCC45, 0xCC25, 0xCC25, 0xCC05,   // 0x1A00 (6656)
0xCC05, 0xCC05, 0xCBE5, 0xCBE5, 0xCBC5, 0xCBE5, 0xCBE4, 0xCBE4, 0xCBE4, 0xCBE4, 0xCBE5, 0xD3E4, 0xCC05, 0xCC05, 0xCC05, 0xCC05,   // 0x1A10 (6672)
0xD405, 0xD405, 0xD425, 0xD424, 0xD405, 0xD405, 0xCC05, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE4, 0xCBE4, 0xCBE4, 0xC404, 0xCC44,   // 0x1A20 (6688)
0xD4E6, 0xEDEB, 0xDDCC, 0xA468, 0x7325, 0x5A63, 0x39A2, 0x2921, 0x2921, 0x2121, 0x1901, 0x1902, 0x18E1, 0x10C1, 0x10A1, 0x0861,   // 0x1A30 (6704)
0x0861, 0x0861, 0x0040, 0x0040, 0x0040, 0x0040, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x1081, 0x10A1, 0x10A1, 0x18C1,   // 0x1A40 (6720)
0x20E2, 0x2102, 0x2922, 0x39A4, 0x5246, 0x62A7, 0x7B89, 0xA4ED, 0xD672, 0xF775, 0xF774, 0xF731, 0xFF0F, 0xFECD, 0xFE6B, 0xF64B,   // 0x1A50 (6736)
0xF62A, 0xEE09, 0xEDE8, 0xEDC8, 0xEDA8, 0xED68, 0xE548, 0xE528, 0xE527, 0xE507, 0xDD06, 0xDCE6, 0xDCC6, 0xDCC6, 0xDCA6, 0xDCA6,   // 0x1A60 (6752)
0xD486, 0xD486, 0xD466, 0xD466, 0xD466, 0xD446, 0xD446, 0xCC45, 0xCC25, 0xCC25, 0xCC25, 0xCC05, 0xCC05, 0xCC05, 0xCBE5, 0xCBE5,   // 0x1A70 (6768)
0xCBE5, 0xCBE5, 0xCBC5, 0xCBC5, 0xCBE4, 0xCBE4, 0xCBE4, 0xCBE5, 0xCC05, 0xD405, 0xD405, 0xD405, 0xD405, 0xD425, 0xD425, 0xD425,   // 0x1A80 (6784)
0xD425, 0xD425, 0xD425, 0xD425, 0xD405, 0xCC05, 0xCC05, 0xCBE5, 0xCBE4, 0xCBE4, 0xC3E4, 0xC3E4, 0xC404, 0xCC44, 0xDCE8, 0xF60D,   // 0x1A90 (6800)
0xD5AC, 0x9C28, 0x83A7, 0x6AE6, 0x41E3, 0x2921, 0x2922, 0x2122, 0x2122, 0x1901, 0x10C1, 0x10A1, 0x10A1, 0x0861, 0x0861, 0x0841,   // 0x1AA0 (6816)
0x0040, 0x0040, 0x0040, 0x0040, 0x0021, 0x0021, 0x0841, 0x0841, 0x0861, 0x0861, 0x10A2, 0x10A2, 0x10A1, 0x18E2, 0x2103, 0x2123,   // 0x1AB0 (6832)
0x2102, 0x2943, 0x39A4, 0x49E4, 0x6AE7, 0x944B, 0xC5D0, 0xFF95, 0xFF94, 0xFF51, 0xFEEE, 0xFEAC, 0xF66A, 0xF64A, 0xF609, 0xEDE8,   // 0x1AC0 (6848)
0xEDC8, 0xED88, 0xED68, 0xE547, 0xE527, 0xE507, 0xE4E7, 0xDCE7, 0xDCC7, 0xDCA6, 0xDCA6, 0xDCA6, 0xD486, 0xD486, 0xD486, 0xD466,   // 0x1AD0 (6864)
0xD445, 0xD446, 0xD445, 0xCC25, 0xCC25, 0xCC25, 0xCC05, 0xCC05, 0xCC05, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE4, 0xCBE4, 0xCBE5, 0xCBE5,   // 0x1AE0 (6880)
0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCC06, 0xCC06, 0xD406, 0xD426, 0xD426, 0xD426, 0xD445, 0xD445, 0xD445, 0xD445, 0xD445,   // 0x1AF0 (6896)
0xD445, 0xD445, 0xD445, 0xD425, 0xD425, 0xCC05, 0xCC04, 0xCC05, 0xCC04, 0xC404, 0xC404, 0xCC45, 0xDCE8, 0xF60E, 0xCD4C, 0x8345,   // 0x1B00 (6912)
0x6AE5, 0x5A85, 0x4A25, 0x41E4, 0x2942, 0x18E1, 0x2102, 0x18E2, 0x18C2, 0x10A2, 0x1081, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x1B10 (6928)
0x0841, 0x0840, 0x0001, 0x0021, 0x0821, 0x0841, 0x0861, 0x0861, 0x10A1, 0x10A2, 0x10A2, 0x18E2, 0x2103, 0x2103, 0x2102, 0x2102,   // 0x1B20 (6944)
0x3142, 0x3983, 0x5204, 0x6B06, 0xA4CC, 0xF754, 0xFF92, 0xFF50, 0xFEED, 0xFEAB, 0xF64A, 0xF629, 0xF608, 0xEDC8, 0xEDA8, 0xED67,   // 0x1B30 (6960)
0xE547, 0xE527, 0xE507, 0xDCE7, 0xDCC7, 0xDCC7, 0xDCA7, 0xDC86, 0xDC86, 0xD486, 0xD466, 0xD465, 0xD466, 0xD446, 0xD446, 0xD445,   // 0x1B40 (6976)
0xCC25, 0xCC25, 0xCC25, 0xCC05, 0xCC05, 0xCC05, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE4, 0xCBE4, 0xCBE4, 0xCBE4, 0xCBE4, 0xCBE5,   // 0x1B50 (6992)
0xCC05, 0xCC05, 0xCC06, 0xCC06, 0xCC26, 0xD426, 0xD426, 0xD446, 0xD446, 0xD465, 0xD465, 0xD465, 0xD465, 0xD465, 0xD465, 0xD465,   // 0x1B60 (7008)
0xD465, 0xD445, 0xD445, 0xD425, 0xCC05, 0xCC05, 0xCC05, 0xC3E4, 0xC405, 0xCC66, 0xDD29, 0xEDED, 0xC50B, 0x8325, 0x5A64, 0x41C3,   // 0x1B70 (7024)
0x39C3, 0x39C4, 0x2943, 0x2102, 0x20E2, 0x20E2, 0x18C2, 0x18A2, 0x1082, 0x1061, 0x0841, 0x0821, 0x0841, 0x0821, 0x0841, 0x0841,   // 0x1B80 (7040)
0x0021, 0x0821, 0x0821, 0x0841, 0x0861, 0x0861, 0x0881, 0x10A1, 0x10A2, 0x18C2, 0x20E2, 0x2102, 0x2122, 0x2942, 0x39A4, 0x49E4,   // 0x1B90 (7056)
0x4A03, 0x5AA4, 0xA4CB, 0xF793, 0xFF72, 0xF72F, 0xF6CD, 0xFEAB, 0xF64A, 0xF629, 0xEDE8, 0xEDA8, 0xE587, 0xE547, 0xE527, 0xE507,   // 0x1BA0 (7072)
0xDCC6, 0xDCC6, 0xDCA6, 0xDC86, 0xD486, 0xD466, 0xD466, 0xD466, 0xD445, 0xD445, 0xD445, 0xD446, 0xD446, 0xD426, 0xCC25, 0xCC05,   // 0x1BB0 (7088)
0xCC05, 0xCC05, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE4, 0xCBE4, 0xCBE5, 0xCBE5, 0xCC05, 0xCC05, 0xCC25, 0xCC25,   // 0x1BC0 (7104)
0xCC26, 0xD426, 0xCC46, 0xD446, 0xD446, 0xCC46, 0xD466, 0xD465, 0xD485, 0xD485, 0xD465, 0xD485, 0xD485, 0xD485, 0xDC66, 0xD465,   // 0x1BD0 (7120)
0xD445, 0xD445, 0xCC05, 0xCC05, 0xC405, 0xC3E4, 0xC425, 0xD486, 0xDD09, 0xE5AC, 0xD56D, 0x93C7, 0x6263, 0x41A2, 0x3141, 0x2942,   // 0x1BE0 (7136)
0x2102, 0x2102, 0x20E2, 0x18C2, 0x18C2, 0x1882, 0x1082, 0x1062, 0x0841, 0x0841, 0x0821, 0x0841, 0x0841, 0x0020, 0x0821, 0x0841,   // 0x1BF0 (7152)
0x0841, 0x0841, 0x0861, 0x0861, 0x0881, 0x10A1, 0x10C2, 0x18C2, 0x20E2, 0x2102, 0x2102, 0x2963, 0x4A46, 0x6B08, 0x7368, 0x946A,   // 0x1C00 (7168)
0xCE2F, 0xF752, 0xFF91, 0xFF2F, 0xFECD, 0xFEAB, 0xF64A, 0xEDE9, 0xEDC8, 0xE587, 0xE547, 0xE527, 0xDCE6, 0xDCC6, 0xDCA6, 0xDCA6,   // 0x1C10 (7184)
0xD486, 0xD486, 0xD466, 0xD466, 0xD446, 0xD446, 0xD446, 0xD426, 0xD425, 0xCC26, 0xCC26, 0xCC25, 0xCC05, 0xCC05, 0xCBE5, 0xCBE5,   // 0x1C20 (7200)
0xCBE5, 0xCBE5, 0xCBC5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCC05, 0xCC05, 0xCC05, 0xCC25, 0xCC45, 0xCC45, 0xCC46, 0xD446,   // 0x1C30 (7216)
0xD466, 0xD466, 0xD466, 0xD466, 0xD486, 0xD486, 0xD4A5, 0xD4A5, 0xD4A5, 0xD4A6, 0xD4A6, 0xD4A6, 0xDC86, 0xDC86, 0xDC66, 0xD445,   // 0x1C40 (7232)
0xD425, 0xCC05, 0xCC04, 0xC3E4, 0xCC45, 0xD4C7, 0xDD29, 0xEDCC, 0xDD8D, 0x9C08, 0x72E5, 0x49E3, 0x3141, 0x2922, 0x2102, 0x2102,   // 0x1C50 (7248)
0x20E2, 0x18C2, 0x18A2, 0x1081, 0x1082, 0x1062, 0x0841, 0x0841, 0x0821, 0x0021, 0x0021, 0x0020, 0x0821, 0x0841, 0x0841, 0x0841,   // 0x1C60 (7264)
0x0861, 0x0861, 0x0881, 0x10A2, 0x10C2, 0x18C2, 0x20E2, 0x2102, 0x2123, 0x2943, 0x39C4, 0x5245, 0x5264, 0x6B25, 0x9CC9, 0xD66E,   // 0x1C70 (7280)
0xF730, 0xFF4F, 0xFEED, 0xF66B, 0xEE09, 0xEDC8, 0xE588, 0xE547, 0xE526, 0xDCE6, 0xDCC6, 0xDCC6, 0xDCA6, 0xDC86, 0xD486, 0xD466,   // 0x1C80 (7296)
0xD466, 0xD446, 0xD446, 0xD446, 0xD425, 0xCC25, 0xCC25, 0xCC05, 0xCC05, 0xCC05, 0xCC05, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBC5, 0xCBC5,   // 0x1C90 (7312)
0xCBC5, 0xCBE5, 0xCBE5, 0xCC05, 0xCC05, 0xCC05, 0xCC25, 0xCC25, 0xD426, 0xD446, 0xD465, 0xD465, 0xD466, 0xD486, 0xD486, 0xD486,   // 0x1CA0 (7328)
0xD486, 0xD4A6, 0xD4A6, 0xD4A6, 0xD4C6, 0xD4C5, 0xD4C6, 0xD4C6, 0xD4C6, 0xDCA6, 0xDCA6, 0xDC86, 0xDC66, 0xD446, 0xD445, 0xCC25,   // 0x1CB0 (7344)
0xCBE4, 0xCC05, 0xCC45, 0xD4C7, 0xE56A, 0xDD6B, 0xB468, 0x8325, 0x72E5, 0x62A6, 0x5245, 0x4A05, 0x39A4, 0x2943, 0x20E2, 0x18C2,   // 0x1CC0 (7360)
0x18A2, 0x1081, 0x1082, 0x1062, 0x0841, 0x0821, 0x0021, 0x0021, 0x0021, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861,   // 0x1CD0 (7376)
0x0881, 0x10A1, 0x10C2, 0x18C1, 0x18C2, 0x20E2, 0x2123, 0x2122, 0x2121, 0x3161, 0x41C1, 0x5241, 0x7B84, 0xC5CB, 0xEEEE, 0xFF4F,   // 0x1CE0 (7392)
0xFECD, 0xF64B, 0xEDE9, 0xEDA8, 0xE568, 0xE527, 0xDCE6, 0xDCC6, 0xDCA6, 0xDCA6, 0xDC86, 0xD466, 0xD465, 0xD465, 0xCC45, 0xCC25,   // 0x1CF0 (7408)
0xCC26, 0xCC26, 0xCC05, 0xCC05, 0xCC05, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBC5, 0xCBC5, 0xCBE5, 0xCBE5,   // 0x1D00 (7424)
0xCC05, 0xCC05, 0xCC05, 0xCC05, 0xCC26, 0xCC46, 0xD446, 0xD466, 0xD465, 0xD465, 0xD486, 0xD486, 0xDC86, 0xD486, 0xDCA6, 0xDCA6,   // 0x1D10 (7440)
0xDCA6, 0xDCC6, 0xDCC6, 0xDCC6, 0xDCE6, 0xD4E6, 0xDCE7, 0xDCC6, 0xD4C6, 0xDC86, 0xDC86, 0xD465, 0xD445, 0xCC25, 0xCBE4, 0xCC04,   // 0x1D20 (7456)
0xCC45, 0xD4E7, 0xEDCB, 0xD52A, 0x9BC6, 0x72C3, 0x5A43, 0x5244, 0x4A05, 0x4205, 0x3164, 0x2902, 0x20E2, 0x18C2, 0x18A2, 0x1081,   // 0x1D30 (7472)
0x1081, 0x0861, 0x0841, 0x0021, 0x0021, 0x0021, 0x0021, 0x0020, 0x0821, 0x0021, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x1081,   // 0x1D40 (7488)
0x10A2, 0x18C2, 0x18C2, 0x20E2, 0x2122, 0x2102, 0x2101, 0x3161, 0x4201, 0x5AA2, 0x83E5, 0xC5EB, 0xEF0F, 0xFF2F, 0xFEED, 0xF66B,   // 0x1D50 (7504)
0xEDE9, 0xE588, 0xE547, 0xE507, 0xDCC6, 0xDCA6, 0xDC86, 0xDC65, 0xD445, 0xD445, 0xD446, 0xCC45, 0xCC25, 0xCC25, 0xCC05, 0xCC05,   // 0x1D60 (7520)
0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCC05, 0xCC25, 0xCC26,   // 0x1D70 (7536)
0xCC26, 0xD446, 0xD446, 0xD466, 0xD466, 0xD466, 0xD466, 0xDC85, 0xDC85, 0xDC86, 0xDCA6, 0xDCA6, 0xDCC6, 0xDCC6, 0xDCC6, 0xDCC6,   // 0x1D80 (7552)
0xDCC6, 0xDCC6, 0xDCE6, 0xDD07, 0xDD06, 0xDCC6, 0xDCC6, 0xDCA6, 0xD486, 0xD466, 0xD465, 0xCC25, 0xC404, 0xCC04, 0xCC66, 0xDD28,   // 0x1D90 (7568)
0xEDCC, 0xD54A, 0xAC28, 0x8325, 0x5202, 0x3941, 0x3141, 0x2922, 0x2102, 0x20E2, 0x20E2, 0x18C2, 0x10A2, 0x1081, 0x1061, 0x0861,   // 0x1DA0 (7584)
0x0841, 0x0821, 0x0021, 0x0021, 0x0041, 0x0040, 0x0021, 0x0021, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x1081, 0x10A1, 0x18C2,   // 0x1DB0 (7600)
0x18C2, 0x20E2, 0x20E2, 0x2101, 0x3183, 0x4A45, 0x6B26, 0x8C08, 0xA4C9, 0xBD8B, 0xEF10, 0xFF2F, 0xFF0E, 0xF66B, 0xEDE9, 0xE568,   // 0x1DC0 (7616)
0xDD07, 0xE507, 0xDCA6, 0xDCA6, 0xDC86, 0xD425, 0xD425, 0xD445, 0xD425, 0xCC25, 0xCC25, 0xCC05, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5,   // 0x1DD0 (7632)
0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCC05, 0xCC05, 0xCC05, 0xCC25, 0xD426, 0xD426, 0xD446, 0xD446,   // 0x1DE0 (7648)
0xD466, 0xD466, 0xD486, 0xD486, 0xDC86, 0xDC86, 0xDC86, 0xDCA6, 0xE4A6, 0xDCA6, 0xE4C6, 0xE4C6, 0xE4E6, 0xE4E6, 0xE4E6, 0xE4E6,   // 0x1DF0 (7664)
0xDCE6, 0xDD07, 0xDD06, 0xDCE6, 0xDCE7, 0xDCC6, 0xDCA6, 0xD486, 0xD466, 0xCC25, 0xC404, 0xCC25, 0xD4A6, 0xDD6A, 0xEE2D, 0xD56B,   // 0x1E00 (7680)
0xAC69, 0x8B87, 0x5A43, 0x3961, 0x3142, 0x2902, 0x20E1, 0x18C1, 0x18C1, 0x18A1, 0x1081, 0x1081, 0x0861, 0x0861, 0x0841, 0x0821,   // 0x1E10 (7696)
0x0021, 0x0021, 0x0041, 0x0040, 0x0021, 0x0021, 0x0021, 0x0041, 0x0841, 0x0861, 0x0861, 0x1081, 0x10A1, 0x18C1, 0x18C2, 0x20E2,   // 0x1E20 (7712)
0x2102, 0x2101, 0x2921, 0x3982, 0x5223, 0x62C4, 0x7345, 0x8C26, 0xD62D, 0xF70F, 0xFEEE, 0xF68B, 0xEDEA, 0xE568, 0xDD07, 0xE4E7,   // 0x1E30 (7728)
0xDC86, 0xDC86, 0xDC66, 0xDC25, 0xD425, 0xD425, 0xCC25, 0xCC05, 0xC405, 0xCC05, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5,   // 0x1E40 (7744)
0xCBE5, 0xCBE4, 0xCBE4, 0xCBE4, 0xCBE5, 0xCC05, 0xCC05, 0xCC05, 0xCC05, 0xCC25, 0xD426, 0xD446, 0xD445, 0xD466, 0xD466, 0xD486,   // 0x1E50 (7760)
0xD486, 0xD486, 0xDCA6, 0xE4A6, 0xE4A6, 0xE4C6, 0xE4C6, 0xE4C6, 0xE4E6, 0xE4E6, 0xE4E6, 0xE507, 0xE4E7, 0xE4E7, 0xDD07, 0xDD26,   // 0x1E60 (7776)
0xDD07, 0xDCE6, 0xDCE6, 0xDCC6, 0xDCA6, 0xDC86, 0xD465, 0xCC25, 0xC404, 0xCC45, 0xD4C7, 0xDD6A, 0xDDAC, 0xAC27, 0x7B04, 0x6A84,   // 0x1E70 (7792)
0x5203, 0x49E4, 0x39A3, 0x2942, 0x20E2, 0x18E1, 0x18C1, 0x10A1, 0x1081, 0x0881, 0x0861, 0x0861, 0x0841, 0x0021, 0x0021, 0x0021,   // 0x1E80 (7808)
0x0041, 0x0040, 0x0021, 0x0021, 0x0021, 0x0041, 0x0041, 0x0040, 0x0861, 0x0881, 0x10A1, 0x10A1, 0x18C1, 0x20E2, 0x20E1, 0x20E1,   // 0x1E90 (7824)
0x28E1, 0x3121, 0x3141, 0x3980, 0x41E0, 0x6AE3, 0xB52A, 0xE6AE, 0xFF0F, 0xF6AC, 0xEDE9, 0xE548, 0xDCE7, 0xDCC7, 0xDC66, 0xDC46,   // 0x1EA0 (7840)
0xDC45, 0xDC25, 0xD405, 0xD405, 0xCC05, 0xCC05, 0xC3E5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBC4, 0xCBC4, 0xCBE4, 0xCBE4, 0xCBE4,   // 0x1EB0 (7856)
0xCBE4, 0xCBE4, 0xCC04, 0xCC05, 0xCC05, 0xCC05, 0xD425, 0xD445, 0xD445, 0xD466, 0xD465, 0xD486, 0xD486, 0xD4A6, 0xD4A6, 0xDCA6,   // 0x1EC0 (7872)
0xDCC6, 0xDCC6, 0xDCC6, 0xDCE6, 0xE4E6, 0xE4E6, 0xDCE6, 0xE4E6, 0xE507, 0xE507, 0xE507, 0xE507, 0xDD07, 0xDD27, 0xDD27, 0xDD06,   // 0x1ED0 (7888)
0xDD07, 0xDCE7, 0xDCA6, 0xD486, 0xCC45, 0xC424, 0xC425, 0xD486, 0xDD29, 0xE5EC, 0xC50A, 0x8B64, 0x5A21, 0x41A0, 0x41C2, 0x41C3,   // 0x1EE0 (7904)
0x3983, 0x2942, 0x2102, 0x18E1, 0x18C1, 0x10A1, 0x1081, 0x0861, 0x0861, 0x0841, 0x0841, 0x0021, 0x0021, 0x0041, 0x0041, 0x0040,   // 0x1EF0 (7920)
0x0021, 0x0021, 0x0021, 0x0041, 0x0040, 0x0040, 0x0861, 0x0881, 0x1081, 0x10A1, 0x18A1, 0x18C2, 0x20E1, 0x2901, 0x28E1, 0x28E1,   // 0x1F00 (7936)
0x3101, 0x4182, 0x5A64, 0x83A7, 0xB52B, 0xE6AF, 0xFF50, 0xFEED, 0xEDEA, 0xE548, 0xE4E7, 0xDCC7, 0xDC66, 0xDC26, 0xDC25, 0xDC05,   // 0x1F10 (7952)
0xD405, 0xD3E5, 0xCBE5, 0xC405, 0xC405, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE4, 0xCBE4, 0xCBE4, 0xCBE4, 0xCBE4, 0xCBE4, 0xCBE4, 0xCC04,   // 0x1F20 (7968)
0xCC04, 0xD404, 0xD425, 0xD425, 0xD445, 0xD465, 0xD466, 0xD486, 0xD486, 0xD486, 0xD4A6, 0xD4A6, 0xDCC6, 0xDCC6, 0xDCE7, 0xDCE7,   // 0x1F30 (7984)
0xDCE6, 0xDD06, 0xDD06, 0xDD26, 0xDD06, 0xDD26, 0xE527, 0xE547, 0xE548, 0xE528, 0xE527, 0xE547, 0xE527, 0xDD07, 0xE507, 0xDCE7,   // 0x1F40 (8000)
0xDCA6, 0xD465, 0xCC44, 0xC424, 0xCC65, 0xD4C7, 0xE58A, 0xDDCD, 0xB4C9, 0x93C7, 0x6AC4, 0x4180, 0x3961, 0x3121, 0x2921, 0x2101,   // 0x1F50 (8016)
0x18E1, 0x18E1, 0x10C1, 0x10A1, 0x1081, 0x0861, 0x0861, 0x0841, 0x0021, 0x0021, 0x0021, 0x0041, 0x0041, 0x0040, 0x0821, 0x0021,   // 0x1F60 (8032)
0x0021, 0x0041, 0x0040, 0x0040, 0x0861, 0x0881, 0x1081, 0x10A1, 0x18A1, 0x18C1, 0x20E1, 0x2901, 0x3102, 0x3102, 0x4163, 0x62A7,   // 0x1F70 (8048)
0x8BEB, 0x9C8B, 0xA4AA, 0xCDCC, 0xF6EF, 0xFF0D, 0xEE0A, 0xE548, 0xE4E7, 0xE4C7, 0xDC66, 0xDC26, 0xDC05, 0xDBE5, 0xD3E5, 0xCBE5,   // 0x1F80 (8064)
0xCBE5, 0xC3E5, 0xC3E5, 0xCBE5, 0xCBE4, 0xCBE4, 0xCBE4, 0xCBE4, 0xCBE4, 0xCBE4, 0xCBE4, 0xCBE4, 0xCBE4, 0xCC04, 0xCC04, 0xD424,   // 0x1F90 (8080)
0xD425, 0xD445, 0xD445, 0xD465, 0xD486, 0xDC86, 0xDCA6, 0xD4A6, 0xDCA6, 0xDCC6, 0xDCC6, 0xDCE6, 0xDD07, 0xDD07, 0xDD27, 0xDD27,   // 0x1FA0 (8096)
0xDD27, 0xDD47, 0xDD47, 0xDD67, 0xE568, 0xE588, 0xE589, 0xE569, 0xE568, 0xE548, 0xE547, 0xE507, 0xE507, 0xDCE7, 0xD4A6, 0xCC65,   // 0x1FB0 (8112)
0xCC44, 0xCC45, 0xCCA6, 0xDD08, 0xE5AB, 0xD58C, 0xAC89, 0x9C08, 0x8387, 0x5A43, 0x3982, 0x3142, 0x2922, 0x2102, 0x1901, 0x18E1,   // 0x1FC0 (8128)
0x10C1, 0x10A1, 0x1081, 0x0861, 0x0861, 0x0841, 0x0021, 0x0021, 0x0021, 0x0041, 0x0041, 0x0040, 0x0021, 0x0041, 0x0021, 0x0040,   // 0x1FD0 (8144)
0x0040, 0x0040, 0x0840, 0x0881, 0x1081, 0x1081, 0x1081, 0x10A1, 0x18C0, 0x3142, 0x5246, 0x7309, 0x7329, 0x7328, 0x7B48, 0x7326,   // 0x1FE0 (8160)
0x6B04, 0x9C46, 0xDE2C, 0xF6ED, 0xEE6B, 0xE589, 0xE507, 0xDCC6, 0xD445, 0xDC25, 0xDC05, 0xD3C5, 0xD3C5, 0xCBC5, 0xC3C5, 0xC3E5,   // 0x1FF0 (8176)
0xC404, 0xC3E4, 0xCBE4, 0xCBE4, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE4, 0xCC04, 0xCC04, 0xCC24, 0xD425, 0xD445, 0xD445,   // 0x2000 (8192)
0xD465, 0xDC65, 0xDC85, 0xDCA5, 0xDCA5, 0xDCC6, 0xDCC6, 0xDCE6, 0xDCE6, 0xDD07, 0xDD27, 0xDD28, 0xDD28, 0xDD48, 0xDD48, 0xDD68,   // 0x2010 (8208)
0xDD88, 0xE5C9, 0xE5CA, 0xE5CA, 0xE5CB, 0xE5AA, 0xE589, 0xE568, 0xE527, 0xDD07, 0xE4E7, 0xE4C6, 0xDCA5, 0xD465, 0xCC44, 0xCC65,   // 0x2020 (8224)
0xCCC7, 0xE58A, 0xE5CC, 0xC52B, 0x8BA6, 0x6AC4, 0x6AA5, 0x5A65, 0x5246, 0x5246, 0x41C5, 0x2923, 0x18E1, 0x10C1, 0x10C1, 0x10A1,   // 0x2030 (8240)
0x0881, 0x0861, 0x0841, 0x0841, 0x0021, 0x0021, 0x0021, 0x0021, 0x0040, 0x0040, 0x0021, 0x0021, 0x0021, 0x0041, 0x0041, 0x0840,   // 0x2040 (8256)
0x0040, 0x0860, 0x0860, 0x0880, 0x18C1, 0x2963, 0x39C4, 0x4A05, 0x62C7, 0x7B8A, 0x7349, 0x5A85, 0x49E2, 0x49C1, 0x5A82, 0x9406,   // 0x2050 (8272)
0xD60C, 0xEEED, 0xF6EC, 0xEDEA, 0xDD27, 0xDCC6, 0xDC65, 0xDC65, 0xD3E5, 0xD3A5, 0xD3C5, 0xCBC6, 0xCBE5, 0xC405, 0xC404, 0xC404,   // 0x2060 (8288)
0xCBE4, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBC5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCC05, 0xCC25, 0xCC45, 0xD445, 0xD445, 0xD465, 0xDC66, 0xDC85,   // 0x2070 (8304)
0xDC85, 0xDCA5, 0xDCA5, 0xDCC6, 0xDCE6, 0xDCE6, 0xDD06, 0xDD07, 0xDD08, 0xE528, 0xE549, 0xDD49, 0xDD89, 0xE5CA, 0xE5EB, 0xE62C,   // 0x2080 (8320)
0xEE4D, 0xEE4D, 0xEE2D, 0xE60D, 0xE5CB, 0xE5A9, 0xDD28, 0xDD06, 0xE4E6, 0xE4A6, 0xDC65, 0xD424, 0xCC24, 0xCC86, 0xD508, 0xEE0D,   // 0x2090 (8336)
0xE60D, 0xACC9, 0x6AC3, 0x49A0, 0x49A2, 0x49E4, 0x5A46, 0x5A47, 0x49E6, 0x39A5, 0x2964, 0x20E2, 0x10A2, 0x1081, 0x0861, 0x0841,   // 0x20A0 (8352)
0x0841, 0x0841, 0x0021, 0x0021, 0x0021, 0x0021, 0x0020, 0x0020, 0x0041, 0x0021, 0x0021, 0x0021, 0x0041, 0x0840, 0x0861, 0x0860,   // 0x20B0 (8368)
0x0860, 0x10A1, 0x2964, 0x4A68, 0x62EA, 0x5AA8, 0x4A05, 0x3983, 0x3141, 0x3141, 0x3961, 0x5223, 0x7B66, 0xB4EB, 0xDE4E, 0xEEAD,   // 0x20C0 (8384)
0xF6AD, 0xF62B, 0xE547, 0xDD06, 0xDCA5, 0xDC44, 0xD3C4, 0xD3C5, 0xD3E6, 0xD3E6, 0xCBE6, 0xC3E5, 0xC405, 0xC3E4, 0xCBE4, 0xCBE5,   // 0x20D0 (8400)
0xCBE5, 0xCBE5, 0xCBC5, 0xCBE5, 0xCBE5, 0xCC05, 0xCC05, 0xCC25, 0xCC45, 0xD445, 0xD465, 0xD465, 0xDC86, 0xDC86, 0xDCA5, 0xDCA6,   // 0x20E0 (8416)
0xDCC6, 0xDCE6, 0xDD06, 0xDD06, 0xDD06, 0xDD27, 0xDD28, 0xE549, 0xE56A, 0xE5AA, 0xEDEC, 0xEE2D, 0xEE6E, 0xF68F, 0xFEAF, 0xFEAF,   // 0x20F0 (8432)
0xFEAF, 0xF66E, 0xEE0C, 0xE5AA, 0xE548, 0xE507, 0xE4C6, 0xDC85, 0xDC44, 0xCC03, 0xCC44, 0xCCA7, 0xE58B, 0xE5CC, 0xCD6B, 0x93E6,   // 0x2100 (8448)
0x6282, 0x49C1, 0x3941, 0x3101, 0x3122, 0x3123, 0x3164, 0x41C5, 0x39C5, 0x2103, 0x1081, 0x0861, 0x0861, 0x0841, 0x0840, 0x0841,   // 0x2110 (8464)
0x0021, 0x0021, 0x0021, 0x0021, 0x0020, 0x0020, 0x0041, 0x0041, 0x0041, 0x0041, 0x0040, 0x0020, 0x0000, 0x0881, 0x2124, 0x39C6,   // 0x2120 (8480)
0x39E6, 0x31A5, 0x3164, 0x3143, 0x2902, 0x20E1, 0x2901, 0x3962, 0x4A04, 0x6286, 0x5A64, 0x6AC3, 0x8BC5, 0xB509, 0xE64C, 0xF66C,   // 0x2130 (8496)
0xEDC9, 0xDD47, 0xD4A5, 0xD424, 0xD404, 0xD3E5, 0xD3C5, 0xCBC6, 0xCBC6, 0xCBE5, 0xC3E5, 0xCBE4, 0xCBE4, 0xCBE4, 0xCBC5, 0xCBC5,   // 0x2140 (8512)
0xCBC5, 0xCBC5, 0xCBE5, 0xCC05, 0xCC05, 0xD425, 0xD445, 0xD445, 0xD465, 0xD486, 0xDC86, 0xDCA6, 0xDCC6, 0xDCE6, 0xE4E6, 0xE506,   // 0x2150 (8528)
0xDD06, 0xDD07, 0xDD27, 0xDD48, 0xE569, 0xE58A, 0xEDCB, 0xEE2D, 0xF66F, 0xFED0, 0xFEF1, 0xFF12, 0xFF31, 0xFF31, 0xFF11, 0xFEAF,   // 0x2160 (8544)
0xF62D, 0xEDAA, 0xE548, 0xE507, 0xDCA6, 0xD464, 0xD444, 0xCC24, 0xD486, 0xDD29, 0xEDEC, 0xC4E9, 0x93C5, 0x7B65, 0x7325, 0x5A64,   // 0x2170 (8560)
0x4182, 0x3122, 0x2902, 0x2902, 0x2902, 0x2923, 0x2102, 0x18A2, 0x1081, 0x1081, 0x0861, 0x0841, 0x0841, 0x0841, 0x0021, 0x0021,   // 0x2180 (8576)
0x0021, 0x0021, 0x0021, 0x0020, 0x0021, 0x0041, 0x0041, 0x0041, 0x0040, 0x0020, 0x0860, 0x1081, 0x18C2, 0x2123, 0x2143, 0x18E2,   // 0x2190 (8592)
0x1081, 0x18A2, 0x20E2, 0x20E2, 0x2902, 0x3142, 0x3983, 0x49E4, 0x41C2, 0x49C1, 0x6281, 0x9C67, 0xE66E, 0xFECE, 0xF62B, 0xDD67,   // 0x21A0 (8608)
0xDD06, 0xD465, 0xCC04, 0xCBC4, 0xCBA5, 0xCBC5, 0xCBC5, 0xCBC5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE4, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5,   // 0x21B0 (8624)
0xCBE5, 0xCC05, 0xD425, 0xD445, 0xD445, 0xD465, 0xD466, 0xD486, 0xDCA6, 0xDCA6, 0xDCC6, 0xE4E6, 0xDCE6, 0xDD06, 0xDD07, 0xDD27,   // 0x21C0 (8640)
0xDD48, 0xE568, 0xE5CA, 0xEE0C, 0xEE4D, 0xF68F, 0xFEF1, 0xFF32, 0xFF33, 0xFF33, 0xFF53, 0xFF52, 0xFF31, 0xFECF, 0xF62D, 0xEDAB,   // 0x21D0 (8656)
0xE529, 0xDCC7, 0xD465, 0xCC04, 0xCC24, 0xCC45, 0xDD08, 0xEDCC, 0xE5ED, 0xAC67, 0x72C2, 0x5A41, 0x6284, 0x5A45, 0x5226, 0x49E6,   // 0x21E0 (8672)
0x3123, 0x20E2, 0x20E2, 0x20E2, 0x18C1, 0x1081, 0x1081, 0x1081, 0x0841, 0x0841, 0x0841, 0x0841, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x21F0 (8688)
0x0021, 0x0020, 0x0041, 0x0041, 0x0041, 0x0041, 0x0040, 0x0040, 0x0040, 0x0040, 0x0840, 0x0860, 0x1081, 0x1081, 0x1081, 0x18A2,   // 0x2200 (8704)
0x18C2, 0x18C1, 0x2102, 0x2922, 0x2901, 0x2900, 0x3141, 0x5A43, 0x83A7, 0xACAA, 0xCDCD, 0xEE6D, 0xFEAD, 0xE5EA, 0xDD47, 0xD4A5,   // 0x2210 (8720)
0xCC03, 0xCBE4, 0xCBC5, 0xCBC5, 0xCBC5, 0xCBC5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCC05, 0xCC05,   // 0x2220 (8736)
0xD425, 0xD445, 0xD465, 0xD466, 0xD486, 0xD4A6, 0xDCA6, 0xDCC6, 0xDCE6, 0xDD06, 0xDCE6, 0xDD06, 0xDD27, 0xDD48, 0xE589, 0xE5AA,   // 0x2230 (8752)
0xEE2C, 0xF66E, 0xF6CF, 0xFEF1, 0xFF33, 0xFF54, 0xFF34, 0xFF33, 0xFF33, 0xFF52, 0xFF31, 0xF6CF, 0xEE0C, 0xED49, 0xE4E8, 0xDCA7,   // 0x2240 (8768)
0xD445, 0xCC04, 0xCC45, 0xDCC7, 0xE56A, 0xE5CC, 0xBCC9, 0x9C07, 0x7303, 0x41C1, 0x3981, 0x41A3, 0x5206, 0x4A06, 0x3985, 0x2903,   // 0x2250 (8784)
0x18C2, 0x18C1, 0x18C2, 0x1081, 0x0861, 0x0861, 0x0861, 0x0041, 0x0041, 0x0041, 0x0021, 0x0021, 0x0021, 0x0021, 0x0041, 0x0040,   // 0x2260 (8800)
0x0842, 0x0041, 0x0021, 0x0020, 0x0020, 0x0040, 0x0020, 0x0840, 0x0861, 0x0861, 0x0860, 0x1081, 0x10A1, 0x1881, 0x18A1, 0x18C1,   // 0x2270 (8816)
0x2122, 0x2922, 0x2901, 0x3162, 0x4A04, 0x7B89, 0xAD0D, 0xA4CB, 0x9407, 0xBD09, 0xF6AE, 0xF66C, 0xDD88, 0xD4E6, 0xD4C6, 0xCC45,   // 0x2280 (8832)
0xCBE4, 0xCBC5, 0xCBC5, 0xCBC5, 0xCBC5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCBE5, 0xCC05, 0xCC05, 0xCC25, 0xD445,   // 0x2290 (8848)
0xD466, 0xD466, 0xD486, 0xD4A6, 0xDCC6, 0xDCC6, 0xDCE6, 0xDD06, 0xDD06, 0xDD27, 0xE547, 0xE568, 0xEDAA, 0xEE0B, 0xF66D, 0xF6CF,   // 0x22A0 (8864)
0xFF31, 0xFF33, 0xFF54, 0xFF54, 0xFF34, 0xFF54, 0xFF33, 0xFF32, 0xFF10, 0xEE6E, 0xE5AB, 0xDCC8, 0xD486, 0xD486, 0xCC45, 0xCC45,   // 0x22B0 (8880)
0xD4C7, 0xE56A, 0xE5AC, 0xCD4B, 0x8BA5, 0x8385, 0x7325, 0x5244, 0x39A2, 0x3142, 0x2902, 0x2903, 0x3985, 0x2944, 0x18C2, 0x1081,   // 0x22C0 (8896)
0x1081, 0x0861, 0x0861, 0x0861, 0x0861, 0x0041, 0x0021, 0x0041, 0x0021, 0x0021, 0x0021, 0x0021, 0x0041, 0x0040, 0x0041, 0x0041,   // 0x22D0 (8912)
0x0041, 0x0041, 0x0041, 0x0040, 0x0020, 0x0020, 0x0020, 0x0840, 0x0861, 0x0881, 0x10A1, 0x18C2, 0x18E1, 0x18E1, 0x18E0, 0x18E0,   // 0x22E0 (8928)
0x2101, 0x4A25, 0x8C2C, 0x8C2B, 0x7B47, 0x6AE4, 0x62A2, 0x8BA5, 0xCDAB, 0xEE6D, 0xEE4C, 0xDD88, 0xDD07, 0xCC65, 0xC404, 0xCBE5,   // 0x22F0 (8944)
0xCBE5, 0xCBC5, 0xCBC5, 0xCBE5, 0xCBE5, 0xC3E5, 0xCBC4, 0xCBE4, 0xCBE5, 0xCBE5, 0xCBE5, 0xCC05, 0xCC25, 0xD446, 0xD466, 0xD466,   // 0x2300 (8960)
0xD486, 0xD4A6, 0xD4A6, 0xDCC6, 0xDCE6, 0xDD06, 0xDD06, 0xDD27, 0xE548, 0xE589, 0xEDCB, 0xF64C, 0xF6AE, 0xFF30, 0xFF52, 0xFF53,   // 0x2310 (8976)
0xFF54, 0xFF34, 0xFF34, 0xFF54, 0xFF53, 0xFF12, 0xFEAF, 0xEE0C, 0xDD29, 0xDCA7, 0xCC25, 0xC425, 0xCC45, 0xD486, 0xDD29, 0xF60D,   // 0x2320 (8992)
0xE5CD, 0xAC89, 0x6AC3, 0x5241, 0x5A63, 0x5265, 0x5225, 0x3984, 0x2903, 0x20E3, 0x2903, 0x20E3, 0x18A1, 0x1081, 0x1081, 0x1081,   // 0x2330 (9008)
0x0861, 0x0841, 0x0840, 0x0841, 0x0021, 0x0021, 0x0021, 0x0041, 0x0021, 0x0021, 0x0021, 0x0040, 0x0021, 0x0041, 0x0041, 0x0041,   // 0x2340 (9024)
0x0041, 0x0841, 0x0020, 0x0020, 0x0020, 0x0840, 0x0840, 0x0860, 0x0861, 0x10A1, 0x18E1, 0x18E1, 0x10C0, 0x2962, 0x5286, 0x6B69,   // 0x2350 (9040)
0x7B8A, 0x62E7, 0x41A1, 0x39A0, 0x5A83, 0x8BC7, 0xB50B, 0xCDAB, 0xE64D, 0xE60B, 0xDD68, 0xCCC6, 0xCC65, 0xCC25, 0xCBE5, 0xCBC4,   // 0x2360 (9056)
0xCBC5, 0xCBE5, 0xCBE5, 0xC3E5, 0xCBE4, 0xCBE5, 0xCBE5, 0xCC05, 0xCC04, 0xCC05, 0xCC25, 0xD446, 0xD466, 0xD466, 0xD486, 0xD4A6,   // 0x2370 (9072)
0xDCC6, 0xDCC6, 0xDCE6, 0xE506, 0xDD06, 0xDD27, 0xE548, 0xE569, 0xF5EB, 0xFE4D, 0xFEEF, 0xFF31, 0xFF32, 0xFF32, 0xFF33, 0xFF33,   // 0x2380 (9088)
0xFF13, 0xFF13, 0xFEF1, 0xF68F, 0xEE0C, 0xDD49, 0xCCA7, 0xCC65, 0xCC45, 0xC445, 0xCC86, 0xDD08, 0xDD8A, 0xD58C, 0xC52B, 0x9C28,   // 0x2390 (9104)
0x5A62, 0x39A0, 0x39C1, 0x4204, 0x41C4, 0x3143, 0x2103, 0x20E3, 0x20C2, 0x18A2, 0x18A1, 0x10A1, 0x10A2, 0x1081, 0x0861, 0x0841,   // 0x23A0 (9120)
0x0041, 0x0041, 0x0041, 0x0041, 0x0021, 0x0021, 0x0021, 0x0041, 0x0041, 0x0041, 0x0041, 0x0041, 0x0041, 0x0041, 0x0041, 0x0040,   // 0x23B0 (9136)
0x0041, 0x0841, 0x0841, 0x0841, 0x0841, 0x0860, 0x0840, 0x0860, 0x10C1, 0x18C0, 0x2962, 0x4A86, 0x6B49, 0x6309, 0x41E4, 0x3182,   // 0x23C0 (9152)
0x3161, 0x4A03, 0x62E5, 0x83A8, 0x9C49, 0x9C47, 0xC56A, 0xDE0B, 0xE5EA, 0xDD68, 0xD4E7, 0xCC65, 0xCC05, 0xCBE4, 0xCBC4, 0xCBC5,   // 0x23D0 (9168)
0xCBE5, 0xC3E5, 0xC3E4, 0xCBE4, 0xCBE4, 0xCC04, 0xCC04, 0xCC05, 0xCC25, 0xD446, 0xCC66, 0xD466, 0xD486, 0xD4A6, 0xDCC6, 0xDCC6,   // 0x23E0 (9184)
0xDCE6, 0xDD06, 0xE506, 0xE527, 0xE548, 0xE569, 0xF5EB, 0xFE4D, 0xFECF, 0xFF11, 0xFF11, 0xFF32, 0xFF32, 0xFF12, 0xFF12, 0xFED1,   // 0x23F0 (9200)
0xF64F, 0xEDCC, 0xDD29, 0xCCA7, 0xCC65, 0xC404, 0xC444, 0xD4C7, 0xDD28, 0xE5AB, 0xE5EC, 0xAC47, 0x8B85, 0x7B66, 0x5AA4, 0x4203,   // 0x2400 (9216)
0x3181, 0x2941, 0x2922, 0x20E2, 0x20E3, 0x20E3, 0x18A2, 0x18A2, 0x10A1, 0x1081, 0x1081, 0x1061, 0x0841, 0x0041, 0x0041, 0x0041,   // 0x2410 (9232)
0x0041, 0x0041, 0x0021, 0x0041, 0x0021, 0x0021, 0x0041, 0x0041, 0x0041, 0x0041, 0x0041, 0x0041, 0x0020, 0x0020, 0x0000, 0x0000,   // 0x2420 (9248)
0x0020, 0x0840, 0x0841, 0x0861, 0x1081, 0x1081, 0x0860, 0x2122, 0x52C8, 0x6329, 0x4205, 0x2963, 0x2102, 0x2921, 0x39C3, 0x5285,   // 0x2430 (9264)
0x5A85, 0x5224, 0x5222, 0x5A61, 0xA487, 0xDDEB, 0xEE4B, 0xEE0A, 0xE588, 0xD4C6, 0xD486, 0xD445, 0xCC04, 0xCBE5, 0xC3E5, 0xC3E5,   // 0x2440 (9280)
0xC3C4, 0xCBE4, 0xCBE4, 0xCBE4, 0xCC04, 0xCC05, 0xCC25, 0xCC26, 0xCC46, 0xCC66, 0xD486, 0xD486, 0xDCA6, 0xDCA6, 0xDCC5, 0xDCE6,   // 0x2450 (9296)
0xE506, 0xE527, 0xE528, 0xE569, 0xEDAB, 0xF60D, 0xFE6E, 0xFED0, 0xFEF0, 0xFEF0, 0xFEF1, 0xFEB0, 0xF66E, 0xEDEC, 0xDD4A, 0xD4A8,   // 0x2460 (9312)
0xCC46, 0xC405, 0xC424, 0xC444, 0xCCA6, 0xDD28, 0xE5CA, 0xEE2D, 0xDDCC, 0x8BA5, 0x5A61, 0x5A83, 0x62C6, 0x5266, 0x3182, 0x2921,   // 0x2470 (9328)
0x2122, 0x2102, 0x20E3, 0x18E3, 0x10A2, 0x18A2, 0x10A1, 0x1081, 0x0860, 0x0841, 0x0841, 0x0041, 0x0040, 0x0041, 0x0021, 0x0021,   // 0x2480 (9344)
0x0041, 0x0021, 0x0021, 0x0021, 0x0041, 0x0041, 0x0041, 0x0041, 0x0041, 0x0041, 0x0041, 0x0020, 0x0041, 0x0841, 0x0020, 0x0020,   // 0x2490 (9360)
0x0840, 0x0840, 0x0841, 0x0861, 0x18C2, 0x2984, 0x3A05, 0x31C4, 0x1901, 0x18E1, 0x2102, 0x2922, 0x3183, 0x39C4, 0x3962, 0x3942,   // 0x24A0 (9376)
0x41A2, 0x6AE4, 0xB52A, 0xD60C, 0xDE0A, 0xEE4B, 0xF62A, 0xED89, 0xDD07, 0xDCA6, 0xCC24, 0xCC05, 0xCC05, 0xCBE5, 0xCBE5, 0xC3C4,   // 0x24B0 (9392)
0xCBE4, 0xCBE4, 0xCBE4, 0xCC04, 0xCC05, 0xCC25, 0xCC46, 0xCC46, 0xD466, 0xD486, 0xD486, 0xDCA5, 0xDCA5, 0xDCC5, 0xDCE5, 0xDCE6,   // 0x24C0 (9408)
0xDD07, 0xDD28, 0xE549, 0xE58B, 0xE5AC, 0xE5EC, 0xEDED, 0xE5EC, 0xE5EC, 0xDDAB, 0xD549, 0xD4E8, 0xCC66, 0xCC25, 0xC404, 0xCC05,   // 0x24D0 (9424)
0xD485, 0xD4C6, 0xDD27, 0xEDEA, 0xD548, 0xBCA7, 0xD5AC, 0xACCA, 0x6AE4, 0x39A0, 0x39C2, 0x4225, 0x39C4, 0x2121, 0x2101, 0x18E1,   // 0x24E0 (9440)
0x18E2, 0x18E3, 0x10A2, 0x10A2, 0x10A1, 0x1081, 0x0840, 0x0841, 0x0821, 0x0021, 0x0020, 0x0021, 0x0021, 0x0021, 0x0041, 0x0021,   // 0x24F0 (9456)
0x0021, 0x0021, 0x0041, 0x0041, 0x0021, 0x0021, 0x0041, 0x0041, 0x0041, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0841,   // 0x2500 (9472)
0x0841, 0x0861, 0x10C2, 0x2143, 0x1902, 0x10A1, 0x10A1, 0x10A1, 0x2123, 0x2923, 0x2922, 0x2922, 0x2901, 0x3142, 0x5A65, 0x942A,   // 0x2510 (9488)
0xACCA, 0x9C67, 0xA465, 0xD589, 0xEE4C, 0xF62C, 0xED8A, 0xE508, 0xDCC7, 0xD446, 0xCC25, 0xCC05, 0xCBE4, 0xCBE4, 0xCBE4, 0xC3E4,   // 0x2520 (9504)
0xCBE4, 0xCC04, 0xCC04, 0xCC05, 0xCC25, 0xCC26, 0xD446, 0xD466, 0xD465, 0xD485, 0xD485, 0xDCA5, 0xD4A5, 0xDCC6, 0xDCE7, 0xDCE8,   // 0x2530 (9520)
0xDCE8, 0xDD09, 0xDD2A, 0xDD2A, 0xD509, 0xD508, 0xCCE7, 0xCCA6, 0xC465, 0xBC24, 0xBC04, 0xC404, 0xCC05, 0xD466, 0xDCC7, 0xE589,   // 0x2540 (9536)
0xE5CA, 0xDDAA, 0xAC25, 0x7B01, 0x9C27, 0xB50B, 0x8C09, 0x4202, 0x2920, 0x3183, 0x3183, 0x2121, 0x2102, 0x18E2, 0x18C2, 0x18C2,   // 0x2550 (9552)
0x10A2, 0x1081, 0x1081, 0x1081, 0x0861, 0x0841, 0x0821, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0041, 0x0021, 0x0021, 0x0021,   // 0x2560 (9568)
0x0041, 0x0041, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0040, 0x0860,   // 0x2570 (9584)
0x0860, 0x0881, 0x1081, 0x10A2, 0x10A2, 0x18C2, 0x20E2, 0x20E2, 0x2102, 0x2101, 0x2921, 0x4A04, 0x7B8A, 0x9CAD, 0x6AE5, 0x5200,   // 0x2580 (9600)
0x6AA2, 0x9C07, 0xCD6B, 0xEE2E, 0xEE0C, 0xE5AB, 0xE58A, 0xDCE7, 0xD486, 0xCC65, 0xCC24, 0xCC45, 0xCC04, 0xC3E4, 0xC3E4, 0xCC04,   // 0x2590 (9616)
0xCBE4, 0xCBE4, 0xCBE5, 0xCC05, 0xCC25, 0xCC25, 0xCC25, 0xD445, 0xD466, 0xD466, 0xD466, 0xDCA7, 0xD4A7, 0xD467, 0xD487, 0xD487,   // 0x25A0 (9632)
0xD488, 0xD487, 0xD466, 0xCC45, 0xCC24, 0xCC23, 0xC423, 0xC403, 0xC444, 0xC445, 0xD4C8, 0xDD29, 0xDD6B, 0xEE0D, 0xEE2E, 0xBCC9,   // 0x25B0 (9648)
0x8344, 0x5A00, 0x5201, 0x83C8, 0x946B, 0x6B48, 0x39C2, 0x2120, 0x2121, 0x1902, 0x1902, 0x18E2, 0x10C2, 0x10A2, 0x10A1, 0x0881,   // 0x25C0 (9664)
0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x25D0 (9680)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0040, 0x0060, 0x0860, 0x0861,   // 0x25E0 (9696)
0x0882, 0x1082, 0x1082, 0x18A2, 0x18C2, 0x18C1, 0x20E1, 0x2101, 0x2921, 0x6B28, 0x946D, 0x5244, 0x3981, 0x49E1, 0x7305, 0x8BC7,   // 0x25F0 (9712)
0x93C6, 0xB488, 0xD58B, 0xEE0D, 0xEDEC, 0xEDAA, 0xE569, 0xE528, 0xD4C6, 0xCC85, 0xCC65, 0xCC45, 0xCC04, 0xC404, 0xCC04, 0xCC05,   // 0x2600 (9728)
0xCC05, 0xCBE4, 0xCBE4, 0xCC24, 0xD425, 0xCC25, 0xCC05, 0xCC25, 0xD446, 0xD446, 0xCC25, 0xC405, 0xCC25, 0xCC26, 0xCC05, 0xCC05,   // 0x2610 (9744)
0xD425, 0xD425, 0xCC03, 0xC403, 0xCC44, 0xCC64, 0xD4C7, 0xD508, 0xDD6A, 0xEDED, 0xDD8C, 0xCD6C, 0xD58D, 0xB4CB, 0x7B25, 0x51E0,   // 0x2620 (9760)
0x3980, 0x39A1, 0x6307, 0x8C2C, 0x6B28, 0x39C3, 0x18E0, 0x18E2, 0x18E2, 0x10C2, 0x10A2, 0x10A1, 0x10A1, 0x0881, 0x0861, 0x0841,   // 0x2630 (9776)
0x0841, 0x0041, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2640 (9792)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0040, 0x0040, 0x0840, 0x0861, 0x0881, 0x1082,   // 0x2650 (9808)
0x1082, 0x1082, 0x18A1, 0x18A1, 0x18C1, 0x2101, 0x2942, 0x4A25, 0x62C7, 0x3162, 0x3141, 0x5264, 0x6AE5, 0x5A63, 0x5A21, 0x7AE2,   // 0x2660 (9824)
0xA406, 0xD56B, 0xEE0D, 0xF62D, 0xF5EB, 0xED8A, 0xE528, 0xDD07, 0xDCE7, 0xD4A6, 0xD485, 0xCC45, 0xCC45, 0xD445, 0xCC25, 0xCBE4,   // 0x2670 (9840)
0xCBE3, 0xCC04, 0xD424, 0xCBE4, 0xCBE3, 0xCBE4, 0xCC04, 0xCC04, 0xCBE4, 0xCC04, 0xCC25, 0xCC04, 0xC404, 0xC404, 0xCC25, 0xCC45,   // 0x2680 (9856)
0xCC24, 0xCC65, 0xD4A6, 0xD4E7, 0xE58A, 0xF60D, 0xEE0D, 0xDD8B, 0xAC27, 0x8323, 0x8B65, 0xBD0C, 0x9C49, 0x62A4, 0x3980, 0x2900,   // 0x2690 (9872)
0x39A2, 0x5286, 0x736A, 0x5AC7, 0x39C4, 0x18E2, 0x18E2, 0x10C2, 0x10A1, 0x1081, 0x1081, 0x0881, 0x0861, 0x0040, 0x0040, 0x0041,   // 0x26A0 (9888)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x26B0 (9904)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0040, 0x0040, 0x0840, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082,   // 0x26C0 (9920)
0x1081, 0x18A1, 0x18C1, 0x20E1, 0x2942, 0x2942, 0x2101, 0x2942, 0x39A3, 0x5245, 0x4A23, 0x3960, 0x49A0, 0x6261, 0x8B85, 0xBCEA,   // 0x26D0 (9936)
0xBCC9, 0xCCE9, 0xF5EC, 0xF62C, 0xF60C, 0xEDCA, 0xE589, 0xDD28, 0xDD07, 0xDCE7, 0xD4A6, 0xD465, 0xD465, 0xD465, 0xD444, 0xD444,   // 0x26E0 (9952)
0xD444, 0xCC04, 0xCC04, 0xCC24, 0xCC24, 0xCC24, 0xCC04, 0xD444, 0xD445, 0xCC24, 0xCC65, 0xCC65, 0xD486, 0xD486, 0xD4A7, 0xE54A,   // 0x26F0 (9968)
0xED8B, 0xEDEC, 0xE5CC, 0xD56B, 0xD56B, 0xC50A, 0x8B64, 0x5A00, 0x5200, 0x9C29, 0xA4AC, 0x7B68, 0x3981, 0x3140, 0x2100, 0x2921,   // 0x2700 (9984)
0x5246, 0x6B09, 0x5287, 0x2102, 0x18E2, 0x10C2, 0x10A1, 0x0881, 0x0881, 0x0861, 0x0841, 0x0040, 0x0040, 0x0041, 0x0021, 0x0021,   // 0x2710 (10000)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2720 (10016)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0040, 0x0040, 0x0040, 0x0841, 0x0861, 0x0861, 0x0861, 0x1081, 0x1081, 0x18C1,   // 0x2730 (10032)
0x18A1, 0x18A1, 0x20E1, 0x2102, 0x18E1, 0x20E1, 0x39C4, 0x39C4, 0x2921, 0x3140, 0x41A1, 0x5A63, 0x8366, 0x9C28, 0x7AE3, 0x8B43,   // 0x2740 (10048)
0xEDED, 0xF62D, 0xEE0C, 0xEDEC, 0xEDEB, 0xEDCA, 0xED89, 0xED69, 0xE548, 0xE507, 0xE508, 0xE507, 0xE4E6, 0xDCC6, 0xD4A5, 0xDCA5,   // 0x2750 (10064)
0xDCA5, 0xDCA5, 0xDCC6, 0xDCA5, 0xD465, 0xD485, 0xDCC6, 0xDCC6, 0xDD07, 0xE508, 0xE528, 0xE56A, 0xE58B, 0xE58C, 0xEDCD, 0xEE0E,   // 0x2760 (10080)
0xC50A, 0x93A5, 0x8B64, 0xB4A9, 0x8B86, 0x5A41, 0x49A0, 0x5222, 0x83C9, 0x8C2B, 0x5265, 0x3141, 0x18C0, 0x2901, 0x20E1, 0x5246,   // 0x2770 (10096)
0x4A26, 0x2103, 0x18E2, 0x10A2, 0x0881, 0x0861, 0x0861, 0x0861, 0x0841, 0x0020, 0x0041, 0x0041, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2780 (10112)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2790 (10128)
0x0021, 0x0021, 0x0021, 0x0021, 0x0020, 0x0020, 0x0040, 0x0040, 0x0841, 0x0841, 0x0861, 0x0861, 0x1061, 0x18C2, 0x10A1, 0x1060,   // 0x27A0 (10144)
0x10A0, 0x18C2, 0x18C2, 0x18E1, 0x2943, 0x2942, 0x20E0, 0x2900, 0x4A03, 0x6AE6, 0x6AC5, 0x6AC4, 0x72C3, 0x93A6, 0xE60E, 0xB4A8,   // 0x27B0 (10160)
0xB467, 0xCD4A, 0xE5EC, 0xF66D, 0xFE4D, 0xEDEB, 0xEDCA, 0xEDAA, 0xED8A, 0xE569, 0xE568, 0xDD27, 0xDD27, 0xE548, 0xDD27, 0xDD07,   // 0x27C0 (10176)
0xDD27, 0xDD27, 0xDD27, 0xDD27, 0xE568, 0xE569, 0xED89, 0xEDCA, 0xF5EC, 0xFE4E, 0xF60E, 0xCCEB, 0xAC08, 0xA408, 0x9BC7, 0x8325,   // 0x27D0 (10192)
0x6AA2, 0x9428, 0x9409, 0x62A4, 0x3980, 0x3140, 0x62C6, 0x7BAA, 0x5286, 0x3162, 0x2901, 0x2902, 0x20C1, 0x2902, 0x2902, 0x18E2,   // 0x27E0 (10208)
0x10C2, 0x0881, 0x0860, 0x0840, 0x0840, 0x0840, 0x0040, 0x0040, 0x0041, 0x0021, 0x0020, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x27F0 (10224)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2800 (10240)
0x0021, 0x0021, 0x0041, 0x0040, 0x0040, 0x0041, 0x0041, 0x0841, 0x0841, 0x0861, 0x0861, 0x1081, 0x10A1, 0x10A1, 0x18C2, 0x18E2,   // 0x2810 (10256)
0x18E2, 0x18E2, 0x18E2, 0x18E2, 0x2101, 0x2942, 0x41C3, 0x5A85, 0x62A5, 0x49C1, 0x6AC4, 0xACCB, 0xCD8D, 0x8B44, 0x8343, 0xA447,   // 0x2820 (10272)
0xBCC8, 0xC509, 0xCD29, 0xD549, 0xE5AB, 0xEE0C, 0xEDEC, 0xEE0C, 0xF62D, 0xEE2C, 0xF62C, 0xEDEB, 0xE5CB, 0xEE0B, 0xEE2C, 0xF62C,   // 0x2830 (10288)
0xF62C, 0xEE0B, 0xEDEB, 0xE5CB, 0xEE0C, 0xD549, 0xBC87, 0xBCA9, 0xB489, 0x9BA7, 0x7AE4, 0x6A63, 0x6263, 0x6AA4, 0x6AC4, 0x7305,   // 0x2840 (10304)
0x83C8, 0x6B06, 0x41C2, 0x2940, 0x3182, 0x5AA7, 0x736A, 0x4A05, 0x20E1, 0x20C1, 0x18A1, 0x1881, 0x18A1, 0x10A1, 0x0881, 0x0860,   // 0x2850 (10320)
0x0840, 0x0040, 0x0840, 0x0040, 0x0041, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2860 (10336)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2870 (10352)
0x0041, 0x0041, 0x0041, 0x0041, 0x0041, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x1081, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C2,   // 0x2880 (10368)
0x18C2, 0x18E2, 0x1902, 0x2963, 0x2921, 0x39C3, 0x5265, 0x41E2, 0x7B88, 0xB50D, 0x9C49, 0x6AC3, 0x72E3, 0x93C6, 0x9C27, 0x8B84,   // 0x2890 (10384)
0x8B84, 0xAC67, 0xB4A8, 0xBCA9, 0xC50A, 0xD56B, 0xD5AC, 0xCD8B, 0xD58B, 0xD5AC, 0xDDEC, 0xDDEC, 0xD5AC, 0xCD4A, 0xD5AB, 0xDDCC,   // 0x28A0 (10400)
0xCD49, 0xB4A7, 0xCD2A, 0xB467, 0x8303, 0x72C2, 0x72A3, 0x72C5, 0x6AA5, 0x51E2, 0x49C2, 0x5A44, 0x62A5, 0x4A23, 0x5264, 0x62C7,   // 0x28B0 (10416)
0x5AA6, 0x3162, 0x18C0, 0x39A4, 0x5AC9, 0x4A27, 0x2943, 0x18C1, 0x1881, 0x18A1, 0x1881, 0x1081, 0x0881, 0x0860, 0x0840, 0x0040,   // 0x28C0 (10432)
0x0840, 0x0040, 0x0041, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x28D0 (10448)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x28E0 (10464)
0x0021, 0x0021, 0x0021, 0x0040, 0x0040, 0x0041, 0x0840, 0x0861, 0x0861, 0x1081, 0x1081, 0x0861, 0x1082, 0x10A2, 0x10C2, 0x18E2,   // 0x28F0 (10480)
0x18E2, 0x18E1, 0x1901, 0x2101, 0x2921, 0x5265, 0x946D, 0xA4CD, 0x6AE5, 0x5A63, 0x62A3, 0x8386, 0x9C69, 0x72E3, 0x6AA2, 0x8385,   // 0x2900 (10496)
0x7B04, 0x6AA2, 0x7B24, 0x8BA6, 0x8385, 0x8385, 0x8385, 0x9C27, 0xA468, 0xA468, 0x8BC6, 0x72E2, 0x8364, 0x9C07, 0x8364, 0x6281,   // 0x2910 (10512)
0x8B85, 0x8B66, 0x6A82, 0x5A01, 0x49C1, 0x6285, 0x6B07, 0x49E3, 0x3161, 0x41C3, 0x4A24, 0x3182, 0x3161, 0x4224, 0x5286, 0x2962,   // 0x2920 (10528)
0x18E1, 0x2122, 0x31A4, 0x4206, 0x31A5, 0x18C2, 0x18A1, 0x1061, 0x1040, 0x0881, 0x0861, 0x0840, 0x0040, 0x0040, 0x0040, 0x0040,   // 0x2930 (10544)
0x0041, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2940 (10560)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2950 (10576)
0x0021, 0x0040, 0x0040, 0x0040, 0x0041, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1062, 0x10A2, 0x10A2, 0x10A2, 0x10C2, 0x18E2,   // 0x2960 (10592)
0x18E1, 0x1901, 0x1900, 0x4A45, 0x8C4C, 0x944C, 0x5244, 0x5264, 0x5243, 0x62C5, 0x8C09, 0x62C5, 0x5A63, 0x62A4, 0x5243, 0x5A43,   // 0x2970 (10608)
0x6AC5, 0x6AE5, 0x5A63, 0x6283, 0x6AC4, 0x6AC4, 0x62A4, 0x7305, 0x7305, 0x5A42, 0x5A62, 0x7325, 0x7325, 0x5221, 0x6283, 0x72E5,   // 0x2980 (10624)
0x6284, 0x49E2, 0x3981, 0x4A04, 0x5AA7, 0x39A3, 0x2101, 0x2942, 0x39A4, 0x3162, 0x2942, 0x2962, 0x3183, 0x2122, 0x2122, 0x18E2,   // 0x2990 (10640)
0x18E2, 0x2103, 0x18E2, 0x1081, 0x18A2, 0x1060, 0x1060, 0x0860, 0x0840, 0x0840, 0x0040, 0x0040, 0x0040, 0x0021, 0x0021, 0x0021,   // 0x29A0 (10656)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x29B0 (10672)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0040,   // 0x29C0 (10688)
0x0040, 0x0040, 0x0040, 0x0041, 0x0041, 0x0861, 0x0861, 0x0861, 0x1062, 0x1082, 0x10A2, 0x10A2, 0x10A1, 0x10C1, 0x18E1, 0x1901,   // 0x29D0 (10704)
0x2141, 0x6308, 0x7BCB, 0x6B28, 0x41E3, 0x4A24, 0x4A03, 0x5244, 0x6B27, 0x62C6, 0x5264, 0x41E3, 0x41C2, 0x5265, 0x5A86, 0x5224,   // 0x29E0 (10720)
0x41C2, 0x5244, 0x62A6, 0x5224, 0x41C2, 0x6285, 0x6AC6, 0x5203, 0x49C2, 0x6264, 0x6AC6, 0x51E3, 0x51E3, 0x6286, 0x6286, 0x3982,   // 0x29F0 (10736)
0x2941, 0x31A2, 0x41E4, 0x3183, 0x2942, 0x2922, 0x2943, 0x2102, 0x2122, 0x2101, 0x2122, 0x1901, 0x18E1, 0x10C1, 0x10C2, 0x10A1,   // 0x2A00 (10752)
0x0881, 0x1081, 0x10A1, 0x1060, 0x0860, 0x0840, 0x0840, 0x0040, 0x0040, 0x0040, 0x0020, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2A10 (10768)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2A20 (10784)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0040, 0x0040, 0x0040,   // 0x2A30 (10800)
0x0040, 0x0041, 0x0041, 0x0041, 0x0861, 0x0861, 0x0861, 0x0861, 0x0881, 0x10A1, 0x10A1, 0x10A1, 0x10A0, 0x18E1, 0x3183, 0x7BEC,   // 0x2A40 (10816)
0x6B49, 0x39E3, 0x3161, 0x3982, 0x4A25, 0x5265, 0x4204, 0x4A24, 0x41E3, 0x2961, 0x3162, 0x4A45, 0x4A46, 0x39A3, 0x3142, 0x5225,   // 0x2A50 (10832)
0x5225, 0x41C3, 0x3962, 0x5245, 0x5A66, 0x4182, 0x41A3, 0x5225, 0x5A45, 0x41A3, 0x3962, 0x5226, 0x62C8, 0x2942, 0x2921, 0x2942,   // 0x2A60 (10848)
0x2963, 0x2963, 0x2963, 0x2103, 0x2103, 0x20C2, 0x20E2, 0x18E1, 0x18E1, 0x10C1, 0x18C1, 0x10A1, 0x10C2, 0x10A1, 0x10A1, 0x1081,   // 0x2A70 (10864)
0x0860, 0x1060, 0x0840, 0x0040, 0x0040, 0x0040, 0x0040, 0x0020, 0x0020, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2A80 (10880)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2A90 (10896)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2AA0 (10912)
0x0041, 0x0041, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0881, 0x10A1, 0x10C1, 0x0880, 0x1901, 0x4225, 0x6B6A, 0x4A86, 0x2942,   // 0x2AB0 (10928)
0x2922, 0x2922, 0x41E5, 0x4A26, 0x3162, 0x3183, 0x31A3, 0x2942, 0x2942, 0x39C5, 0x41C5, 0x3163, 0x3163, 0x4A25, 0x4A05, 0x3963,   // 0x2AC0 (10944)
0x3142, 0x41E4, 0x49E4, 0x3122, 0x3142, 0x41E4, 0x49E4, 0x3962, 0x3142, 0x4A05, 0x5AA8, 0x2922, 0x2101, 0x2102, 0x2923, 0x2123,   // 0x2AD0 (10960)
0x2103, 0x18E2, 0x20E3, 0x18E3, 0x18E2, 0x18C2, 0x18C2, 0x10A2, 0x10C2, 0x10A2, 0x1081, 0x0861, 0x0881, 0x0860, 0x0840, 0x0860,   // 0x2AE0 (10976)
0x0840, 0x0040, 0x0040, 0x0040, 0x0040, 0x0040, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2AF0 (10992)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2B00 (11008)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2B10 (11024)
0x0021, 0x0841, 0x0841, 0x0840, 0x0860, 0x0860, 0x0880, 0x10A0, 0x1080, 0x2962, 0x4A86, 0x4A66, 0x2983, 0x2101, 0x2102, 0x18C1,   // 0x2B20 (11040)
0x2923, 0x3163, 0x2922, 0x2922, 0x2922, 0x2902, 0x2922, 0x3984, 0x3164, 0x2922, 0x3142, 0x39C4, 0x41C4, 0x3162, 0x2922, 0x3983,   // 0x2B30 (11056)
0x3983, 0x2922, 0x2901, 0x3162, 0x3983, 0x3142, 0x2922, 0x41E5, 0x5267, 0x2922, 0x20E2, 0x20E2, 0x2103, 0x2103, 0x18C2, 0x18C2,   // 0x2B40 (11072)
0x18E3, 0x18E2, 0x18C2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1081, 0x0861, 0x0861, 0x0861, 0x0860, 0x0860, 0x0840, 0x0840, 0x0040,   // 0x2B50 (11088)
0x0040, 0x0040, 0x0040, 0x0041, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2B60 (11104)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2B70 (11120)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0840,   // 0x2B80 (11136)
0x0840, 0x0840, 0x0840, 0x0860, 0x0860, 0x0880, 0x0880, 0x31A4, 0x5AE8, 0x31C4, 0x1901, 0x18E1, 0x2102, 0x18E1, 0x18E1, 0x20E2,   // 0x2B90 (11152)
0x20E1, 0x2102, 0x2102, 0x2102, 0x2102, 0x2943, 0x2923, 0x20E1, 0x2901, 0x3142, 0x3163, 0x2922, 0x2901, 0x2922, 0x2922, 0x2942,   // 0x2BA0 (11168)
0x2921, 0x2101, 0x2922, 0x2942, 0x2901, 0x3983, 0x4A06, 0x2943, 0x2903, 0x20E2, 0x20C2, 0x20E3, 0x18C2, 0x18C2, 0x18A2, 0x18C2,   // 0x2BB0 (11184)
0x18C2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0860, 0x0840, 0x0840, 0x0840, 0x0040, 0x0040, 0x0040,   // 0x2BC0 (11200)
0x0040, 0x0041, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2BD0 (11216)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2BE0 (11232)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0020,   // 0x2BF0 (11248)
0x0020, 0x0840, 0x0840, 0x0860, 0x1080, 0x2964, 0x4A67, 0x2142, 0x10C0, 0x18C1, 0x18C1, 0x18E2, 0x1902, 0x18E2, 0x18C1, 0x18E2,   // 0x2C00 (11264)
0x2102, 0x2102, 0x2102, 0x2122, 0x2923, 0x20E2, 0x20E1, 0x2102, 0x2922, 0x2922, 0x2102, 0x2101, 0x2102, 0x2922, 0x2102, 0x20E1,   // 0x2C10 (11280)
0x2102, 0x2922, 0x20E1, 0x2942, 0x39A4, 0x2943, 0x2923, 0x20C2, 0x18C2, 0x18E2, 0x18C2, 0x10A2, 0x1081, 0x10A2, 0x10A2, 0x1082,   // 0x2C20 (11296)
0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0840, 0x0840, 0x0020, 0x0820, 0x0040, 0x0040, 0x0040, 0x0040, 0x0041,   // 0x2C30 (11312)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2C40 (11328)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2C50 (11344)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0020,   // 0x2C60 (11360)
0x0840, 0x0840, 0x0880, 0x18E2, 0x2143, 0x10A1, 0x1080, 0x10A1, 0x1080, 0x10A1, 0x10C1, 0x18C1, 0x18C1, 0x18C1, 0x18E2, 0x18E2,   // 0x2C70 (11376)
0x18C2, 0x18E2, 0x2102, 0x2102, 0x20E2, 0x2102, 0x2102, 0x2102, 0x2102, 0x20E2, 0x20E2, 0x2102, 0x20E2, 0x20E2, 0x20E2, 0x18E1,   // 0x2C80 (11392)
0x20C1, 0x2102, 0x2923, 0x2923, 0x2103, 0x18C2, 0x18C2, 0x18C2, 0x18C2, 0x10A2, 0x1081, 0x1081, 0x1081, 0x0881, 0x0861, 0x0861,   // 0x2C90 (11408)
0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0021, 0x0020, 0x0040, 0x0040, 0x0040, 0x0040, 0x0041, 0x0021, 0x0021,   // 0x2CA0 (11424)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2CB0 (11440)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2CC0 (11456)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0841, 0x0840, 0x0020,   // 0x2CD0 (11472)
0x0020, 0x10A1, 0x10A1, 0x1081, 0x10C1, 0x10A1, 0x0880, 0x10C1, 0x10A1, 0x10A1, 0x18E2, 0x10A1, 0x10A1, 0x18C2, 0x18C2, 0x18C2,   // 0x2CE0 (11488)
0x18C2, 0x18E2, 0x18E2, 0x18E2, 0x18C2, 0x18E2, 0x2102, 0x18E2, 0x18E2, 0x18E2, 0x18E2, 0x18E2, 0x18E2, 0x18C1, 0x18C1, 0x18C1,   // 0x2CF0 (11504)
0x18C1, 0x20E2, 0x18C2, 0x18A2, 0x10A2, 0x1081, 0x1081, 0x10A2, 0x1082, 0x1081, 0x0861, 0x0860, 0x0840, 0x0840, 0x0840, 0x0840,   // 0x2D00 (11520)
0x0840, 0x0020, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0040, 0x0040, 0x0040, 0x0040, 0x0041, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2D10 (11536)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2D20 (11552)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2D30 (11568)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0821, 0x0021, 0x0021, 0x0021, 0x0021, 0x0841, 0x0841, 0x0000, 0x0861,   // 0x2D40 (11584)
0x0861, 0x0861, 0x1081, 0x0881, 0x0860, 0x10C1, 0x10A1, 0x10A1, 0x10A1, 0x1081, 0x10A1, 0x10A2, 0x10C2, 0x10A2, 0x10A2, 0x18C2,   // 0x2D50 (11600)
0x18C2, 0x18C2, 0x18C2, 0x18C2, 0x18C2, 0x18C2, 0x10C2, 0x18C2, 0x18C2, 0x18C2, 0x18C2, 0x10A1, 0x18C1, 0x18C1, 0x10A1, 0x18A1,   // 0x2D60 (11616)
0x10A1, 0x10A1, 0x1081, 0x0861, 0x0861, 0x1081, 0x1081, 0x0861, 0x0841, 0x0840, 0x0840, 0x0840, 0x0040, 0x0020, 0x0020, 0x0020,   // 0x2D70 (11632)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0040, 0x0040, 0x0040, 0x0041, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2D80 (11648)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2D90 (11664)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2DA0 (11680)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0020, 0x0020, 0x0841, 0x0861,   // 0x2DB0 (11696)
0x0861, 0x0861, 0x0860, 0x0860, 0x0881, 0x0881, 0x0861, 0x0881, 0x10A1, 0x1081, 0x1081, 0x10A1, 0x10A1, 0x10A1, 0x10A2, 0x10A2,   // 0x2DC0 (11712)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A1, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A1, 0x10A1, 0x1081, 0x1081, 0x1081, 0x1061,   // 0x2DD0 (11728)
0x1081, 0x0881, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0840, 0x0840, 0x0840, 0x0020, 0x0020, 0x0020, 0x0021, 0x0021, 0x0021,   // 0x2DE0 (11744)
0x0021, 0x0021, 0x0021, 0x0021, 0x0040, 0x0040, 0x0040, 0x0041, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2DF0 (11760)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2E00 (11776)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2E10 (11792)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0821, 0x0021, 0x0841, 0x0841, 0x0861,   // 0x2E20 (11808)
0x0860, 0x0040, 0x0040, 0x0860, 0x0881, 0x0881, 0x0881, 0x1081, 0x1081, 0x1081, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x2E30 (11824)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1081, 0x1081, 0x0861, 0x0861, 0x0861, 0x0861, 0x0881, 0x0881,   // 0x2E40 (11840)
0x0861, 0x0841, 0x0041, 0x0021, 0x0041, 0x0840, 0x0841, 0x0841, 0x0020, 0x0020, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2E50 (11856)
0x0021, 0x0021, 0x0040, 0x0040, 0x0040, 0x0041, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2E60 (11872)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2E70 (11888)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2E80 (11904)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0821, 0x0841, 0x0021, 0x0001, 0x0821, 0x0841, 0x0041, 0x0040,   // 0x2E90 (11920)
0x0020, 0x0041, 0x0861, 0x0861, 0x0841, 0x0861, 0x0861, 0x1061, 0x1062, 0x1081, 0x1081, 0x1081, 0x1081, 0x1081, 0x1081, 0x1081,   // 0x2EA0 (11936)
0x1081, 0x1081, 0x1081, 0x1081, 0x1081, 0x1081, 0x0861, 0x0861, 0x0861, 0x0861, 0x0860, 0x0840, 0x0861, 0x0861, 0x0861, 0x0041,   // 0x2EB0 (11952)
0x0021, 0x0021, 0x0021, 0x0841, 0x0841, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0040,   // 0x2EC0 (11968)
0x0040, 0x0040, 0x0040, 0x0041, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2ED0 (11984)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2EE0 (12000)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2EF0 (12016)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0821, 0x0821, 0x0021, 0x0021, 0x0821, 0x0021, 0x0021, 0x0021, 0x0841, 0x0021,   // 0x2F00 (12032)
0x0041, 0x0821, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x1061, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x2F10 (12048)
0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0861, 0x0861, 0x0861, 0x0841, 0x0840, 0x0040, 0x0040, 0x0041, 0x0021, 0x0021, 0x0021,   // 0x2F20 (12064)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0020, 0x0020, 0x0020, 0x0040, 0x0040, 0x0040,   // 0x2F30 (12080)
0x0040, 0x0041, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2F40 (12096)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2F50 (12112)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2F60 (12128)
0x0021, 0x0021, 0x0021, 0x0841, 0x0821, 0x0021, 0x0821, 0x0821, 0x0821, 0x0021, 0x0021, 0x0021, 0x0821, 0x0821, 0x0021, 0x0821,   // 0x2F70 (12144)
0x0821, 0x0821, 0x0821, 0x0821, 0x0821, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0841, 0x0841, 0x0841,   // 0x2F80 (12160)
0x0840, 0x0841, 0x0841, 0x0041, 0x0041, 0x0041, 0x0040, 0x0040, 0x0040, 0x0040, 0x0040, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2F90 (12176)
0x0021, 0x0021, 0x0021, 0x0821, 0x0821, 0x0021, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0040, 0x0040, 0x0040, 0x0040, 0x0041,   // 0x2FA0 (12192)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2FB0 (12208)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2FC0 (12224)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x2FD0 (12240)
0x0021, 0x0841, 0x0021, 0x0021, 0x0821, 0x0841, 0x0821, 0x0821, 0x0041, 0x0021, 0x0021, 0x0021, 0x0821, 0x0821, 0x0821, 0x0821,   // 0x2FE0 (12256)
0x0821, 0x0821, 0x0821, 0x0821, 0x0841, 0x0840, 0x0840, 0x0840, 0x0840, 0x0840, 0x0841, 0x0841, 0x0841, 0x0840, 0x0840, 0x0840,   // 0x2FF0 (12272)
0x0041, 0x0041, 0x0041, 0x0041, 0x0040, 0x0040, 0x0040, 0x0041, 0x0041, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x3000 (12288)
0x0021, 0x0821, 0x0821, 0x0021, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0040, 0x0040, 0x0040, 0x0040, 0x0041, 0x0021, 0x0021,   // 0x3010 (12304)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x3020 (12320)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x3030 (12336)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x3040 (12352)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0041, 0x0041, 0x0041, 0x0041, 0x0041, 0x0021, 0x0021, 0x0021, 0x0020, 0x0020, 0x0020,   // 0x3050 (12368)
0x0820, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0021, 0x0021,   // 0x3060 (12384)
0x0021, 0x0021, 0x0021, 0x0041, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x3070 (12400)
0x0021, 0x0021, 0x0021, 0x0021, 0x0041, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x3080 (12416)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x3090 (12432)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x30A0 (12448)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x30B0 (12464)
0x0021, 0x0021, 0x0021, 0x0041, 0x0041, 0x0041, 0x0041, 0x0041, 0x0021, 0x0021, 0x0021, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020,   // 0x30C0 (12480)
0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x30D0 (12496)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x30E0 (12512)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021,   // 0x30F0 (12528)
0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, 0x0021, };
Third.c
// Generated by  : ImageConverter 565 v2.3
// Generated from: ThirdQuarter.jpg
// Time generated: 17/06/2022 8:18:17 AM
// Dimensions    : 95x95 pixels
// Size          : 18,050 Bytes
#include <avr/pgmspace.h>
const unsigned int Third[0x2341] PROGMEM ={
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0010 (16)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0020 (32)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0030 (48)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0040 (64)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0050 (80)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0060 (96)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0070 (112)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0080 (128)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x0841, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861,   // 0x0090 (144)
0x0861, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00A0 (160)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00B0 (176)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00C0 (192)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00D0 (208)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00E0 (224)
0x0000, 0x0020, 0x0861, 0x18E3, 0x2945, 0x2965, 0x31A6, 0x39C7, 0x39C7, 0x39C7, 0x31A6, 0x3186, 0x2965, 0x2945, 0x2104, 0x18E3,   // 0x00F0 (240)
0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0841, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0100 (256)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0110 (272)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0120 (288)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0130 (304)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x1082, 0x2124,   // 0x0140 (320)
0x31A6, 0x39E7, 0x4228, 0x4A69, 0x4A69, 0x4A69, 0x4A49, 0x4A49, 0x4228, 0x39E7, 0x39C7, 0x31A6, 0x2965, 0x2124, 0x18E3, 0x10A2,   // 0x0150 (336)
0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0160 (352)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0170 (368)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0180 (384)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0190 (400)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x10A2, 0x2945, 0x39E7, 0x4A69, 0x528A, 0x528A,   // 0x01A0 (416)
0x528A, 0x52AA, 0x5ACB, 0x52AA, 0x52AA, 0x528A, 0x528A, 0x4A69, 0x4228, 0x39E7, 0x31A6, 0x3186, 0x2124, 0x18E3, 0x10A2, 0x1082,   // 0x01B0 (432)
0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000,   // 0x01C0 (448)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x01D0 (464)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x01E0 (480)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x01F0 (496)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x2104, 0x39E7, 0x4A69, 0x4A69, 0x52AA, 0x5AEB, 0x5AEB, 0x5AEB, 0x630C,   // 0x0200 (512)
0x632C, 0x630C, 0x630C, 0x630C, 0x5AEB, 0x52AA, 0x528A, 0x4A49, 0x4208, 0x31A6, 0x2965, 0x2945, 0x2945, 0x18E3, 0x10A2, 0x1082,   // 0x0210 (528)
0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000,   // 0x0220 (544)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0230 (560)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0240 (576)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0250 (592)
0x0000, 0x0000, 0x0000, 0x0020, 0x2124, 0x39E7, 0x528A, 0x5AEB, 0x5ACB, 0x5ACB, 0x5ACB, 0x5ACB, 0x5AEB, 0x632C, 0x6B4D, 0x632C,   // 0x0260 (608)
0x632C, 0x632C, 0x630C, 0x630C, 0x5AEB, 0x52AA, 0x4A69, 0x4228, 0x39E7, 0x31A6, 0x3186, 0x2965, 0x2124, 0x2104, 0x18C3, 0x10A2,   // 0x0270 (624)
0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0020, 0x0000,   // 0x0280 (640)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0290 (656)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x02A0 (672)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x02B0 (688)
0x0020, 0x18E3, 0x4208, 0x5ACB, 0x5ACB, 0x5ACB, 0x5AEB, 0x5AEB, 0x5AEB, 0x630C, 0x630C, 0x632C, 0x6B6D, 0x738E, 0x6B6D, 0x6B4D,   // 0x02C0 (704)
0x6B6D, 0x6B4D, 0x6B4D, 0x632C, 0x5AEB, 0x52AA, 0x4A69, 0x4A69, 0x4208, 0x31A6, 0x2965, 0x2124, 0x2104, 0x18E3, 0x18C3, 0x10A2,   // 0x02D0 (720)
0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0020,   // 0x02E0 (736)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x02F0 (752)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0300 (768)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1082, 0x31A6,   // 0x0310 (784)
0x528A, 0x5ACB, 0x5AEB, 0x5ACB, 0x5ACB, 0x5AEB, 0x630C, 0x6B4D, 0x6B4D, 0x6B6D, 0x738E, 0x7BCF, 0x7BEF, 0x7BCF, 0x7BCF, 0x7BCF,   // 0x0320 (800)
0x7BCF, 0x738E, 0x632C, 0x630C, 0x630C, 0x5ACB, 0x4A69, 0x4208, 0x31A6, 0x2965, 0x2124, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x10A2,   // 0x0330 (816)
0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841,   // 0x0340 (832)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0350 (848)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0360 (864)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x2104, 0x39E7, 0x4A69, 0x528A,   // 0x0370 (880)
0x5AEB, 0x632C, 0x630C, 0x6B4D, 0x632C, 0x6B4D, 0x6B6D, 0x6B6D, 0x7BCF, 0x7BEF, 0x7BEF, 0x8410, 0x8410, 0x8430, 0x7BEF, 0x7BCF,   // 0x0380 (896)
0x73AE, 0x6B6D, 0x632C, 0x630C, 0x5ACB, 0x4A49, 0x4208, 0x39C7, 0x2965, 0x2945, 0x2104, 0x18C3, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x0390 (912)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841,   // 0x03A0 (928)
0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x03B0 (944)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x03C0 (960)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1082, 0x31A6, 0x4A69, 0x528A, 0x528A, 0x5ACB, 0x632C,   // 0x03D0 (976)
0x6B6D, 0x632C, 0x6B4D, 0x6B6D, 0x738E, 0x73AE, 0x7BCF, 0x7BEF, 0x7BEF, 0x8410, 0x8430, 0x8C51, 0x8C71, 0x8C51, 0x8410, 0x7BCF,   // 0x03E0 (992)
0x6B6D, 0x632C, 0x5AEB, 0x5ACB, 0x4A69, 0x4208, 0x31A6, 0x2945, 0x2124, 0x18E3, 0x10A2, 0x1082, 0x0861, 0x1082, 0x0861, 0x1082,   // 0x03F0 (1008)
0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0400 (1024)
0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0410 (1040)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0420 (1056)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x18E3, 0x4208, 0x528A, 0x52AA, 0x52AA, 0x5AEB, 0x630C, 0x630C, 0x630C,   // 0x0430 (1072)
0x6B4D, 0x6B6D, 0x738E, 0x73AE, 0x7BEF, 0x8410, 0x8C51, 0x8C71, 0x9CF3, 0xA534, 0x94B2, 0x94B2, 0x8C71, 0x8410, 0x7BEF, 0x73AE,   // 0x0440 (1088)
0x632C, 0x5AEB, 0x528A, 0x4A49, 0x39C7, 0x2965, 0x2124, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082,   // 0x0450 (1104)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x0861,   // 0x0460 (1120)
0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0470 (1136)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0480 (1152)
0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x2945, 0x528A, 0x5ACB, 0x52AA, 0x52AA, 0x5AEB, 0x630C, 0x630C, 0x632C, 0x6B4D, 0x6B6D,   // 0x0490 (1168)
0x73AE, 0x7BCF, 0x7BEF, 0x8C51, 0x94B2, 0xA534, 0xB5B6, 0xB596, 0xA534, 0x94B2, 0x8C71, 0x8C51, 0x8410, 0x7BEF, 0x73AE, 0x738E,   // 0x04A0 (1184)
0x5AEB, 0x4A69, 0x4208, 0x31A6, 0x2965, 0x2124, 0x2104, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x04B0 (1200)
0x0861, 0x1082, 0x0861, 0x0861, 0x1082, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x04C0 (1216)
0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x04D0 (1232)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x04E0 (1248)
0x0000, 0x0000, 0x0000, 0x3186, 0x5ACB, 0x5AEB, 0x630C, 0x5AEB, 0x5AEB, 0x632C, 0x6B4D, 0x6B4D, 0x6B6D, 0x738E, 0x73AE, 0x7BCF,   // 0x04F0 (1264)
0x7BEF, 0x8410, 0x8C71, 0x9CD3, 0xAD55, 0xC638, 0xB596, 0x9CF3, 0x94B2, 0x94B2, 0x9492, 0x8C51, 0x7BCF, 0x738E, 0x6B6D, 0x5AEB,   // 0x0500 (1280)
0x4A69, 0x4228, 0x39C7, 0x3186, 0x2124, 0x2104, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0861,   // 0x0510 (1296)
0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0520 (1312)
0x0861, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0530 (1328)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0540 (1344)
0x0020, 0x31A6, 0x630C, 0x6B4D, 0x632C, 0x632C, 0x630C, 0x632C, 0x6B4D, 0x6B6D, 0x738E, 0x738E, 0x73AE, 0x7BEF, 0x7BEF, 0x8410,   // 0x0550 (1360)
0x8430, 0x8C71, 0x9492, 0x94B2, 0x9CF3, 0xA514, 0x9CF3, 0x9CD3, 0x9CD3, 0x9492, 0x8410, 0x7BCF, 0x73AE, 0x6B6D, 0x630C, 0x52AA,   // 0x0560 (1376)
0x4228, 0x39E7, 0x3186, 0x2124, 0x2104, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0861, 0x0861, 0x0861,   // 0x0570 (1392)
0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0580 (1408)
0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0590 (1424)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x39E7,   // 0x05A0 (1440)
0x6B6D, 0x73AE, 0x73AE, 0x738E, 0x632C, 0x632C, 0x6B4D, 0x6B6D, 0x6B6D, 0x6B6D, 0x738E, 0x73AE, 0x7BEF, 0x7BEF, 0x8410, 0x8430,   // 0x05B0 (1456)
0x8C51, 0x8C71, 0x9492, 0x9CD3, 0x9CF3, 0x94B2, 0x9492, 0x9492, 0x8430, 0x8410, 0x7BCF, 0x73AE, 0x738E, 0x6B4D, 0x52AA, 0x4228,   // 0x05C0 (1472)
0x39C7, 0x3186, 0x2124, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x05D0 (1488)
0x0861, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0861,   // 0x05E0 (1504)
0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x05F0 (1520)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x39C7, 0x6B6D, 0x7BCF,   // 0x0600 (1536)
0x7BCF, 0x7BCF, 0x6B6D, 0x632C, 0x6B4D, 0x738E, 0x738E, 0x738E, 0x738E, 0x738E, 0x73AE, 0x7BEF, 0x8410, 0x8430, 0x8C51, 0x8C51,   // 0x0610 (1552)
0x8C51, 0x8C71, 0x94B2, 0x9CD3, 0x9492, 0x8C51, 0x8430, 0x7BEF, 0x8410, 0x7BCF, 0x738E, 0x6B4D, 0x630C, 0x52AA, 0x4228, 0x39C7,   // 0x0620 (1568)
0x3186, 0x2124, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0630 (1584)
0x0861, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841,   // 0x0640 (1600)
0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0650 (1616)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x2965, 0x632C, 0x7BCF, 0x8410, 0x8410,   // 0x0660 (1632)
0x73AE, 0x6B6D, 0x6B6D, 0x738E, 0x73AE, 0x73AE, 0x7BCF, 0x7BCF, 0x7BEF, 0x7BEF, 0x7BEF, 0x8410, 0x8430, 0x8C71, 0x8C51, 0x8C51,   // 0x0670 (1648)
0x8C71, 0x9CD3, 0x9CF3, 0x8C71, 0x8C71, 0x8C71, 0x8410, 0x7BEF, 0x73AE, 0x738E, 0x632C, 0x5AEB, 0x528A, 0x4228, 0x39E7, 0x3186,   // 0x0680 (1664)
0x2124, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0690 (1680)
0x1082, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x0861, 0x0861, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841,   // 0x06A0 (1696)
0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x06B0 (1712)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x2104, 0x630C, 0x7BCF, 0x8410, 0x8C71, 0x8C51, 0x73AE,   // 0x06C0 (1728)
0x6B6D, 0x7BCF, 0x8430, 0x7BEF, 0x7BCF, 0x7BCF, 0x7BEF, 0x8410, 0x8410, 0x7BEF, 0x8C51, 0x8C51, 0x8C51, 0x8C71, 0x9492, 0x94B2,   // 0x06D0 (1744)
0x9CF3, 0x9CD3, 0x9492, 0x8C71, 0x8C71, 0x8C51, 0x8410, 0x7BCF, 0x6B6D, 0x632C, 0x5AEB, 0x4A69, 0x4228, 0x39E7, 0x3186, 0x2945,   // 0x06E0 (1760)
0x2104, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x06F0 (1776)
0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841,   // 0x0700 (1792)
0x0841, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0710 (1808)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1082, 0x52AA, 0x7BCF, 0x8410, 0x9492, 0x9492, 0x8430, 0x73AE, 0x73AE,   // 0x0720 (1824)
0x7BCF, 0x8430, 0x7BEF, 0x8410, 0x7BEF, 0x7BCF, 0x7BEF, 0x8410, 0x8430, 0x8C71, 0x8C71, 0x8430, 0x8C51, 0x94B2, 0x9CD3, 0xA514,   // 0x0730 (1840)
0x9CD3, 0x9492, 0x8C71, 0x8C51, 0x8C51, 0x8430, 0x8410, 0x73AE, 0x738E, 0x632C, 0x4A69, 0x4228, 0x39E7, 0x31A6, 0x2945, 0x2104,   // 0x0740 (1856)
0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0750 (1872)
0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841,   // 0x0760 (1888)
0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0770 (1904)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x4208, 0x73AE, 0x8410, 0x8C51, 0x94B2, 0x8C51, 0x7BEF, 0x73AE, 0x738E, 0x73AE,   // 0x0780 (1920)
0x7BCF, 0x7BEF, 0x8410, 0x8410, 0x7BEF, 0x7BEF, 0x8410, 0x8410, 0x8410, 0x8C51, 0x8C71, 0x9492, 0x94B2, 0x9CD3, 0xA534, 0x9CF3,   // 0x0790 (1936)
0x8C51, 0x8C51, 0x8430, 0x8430, 0x8430, 0x8430, 0x8410, 0x7BEF, 0x6B4D, 0x4A69, 0x4228, 0x39E7, 0x3186, 0x2124, 0x2104, 0x18C3,   // 0x07A0 (1952)
0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082,   // 0x07B0 (1968)
0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841,   // 0x07C0 (1984)
0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x07D0 (2000)
0x0000, 0x0000, 0x0000, 0x0000, 0x2965, 0x632C, 0x7BEF, 0x8C51, 0x9492, 0x8430, 0x7BCF, 0x7BCF, 0x73AE, 0x738E, 0x73AE, 0x7BCF,   // 0x07E0 (2016)
0x8410, 0x8430, 0x8410, 0x8430, 0x7BEF, 0x7BCF, 0x7BEF, 0x8410, 0x8C51, 0x9492, 0x94B2, 0x9CD3, 0x9CF3, 0xA534, 0x94B2, 0x8430,   // 0x07F0 (2032)
0x8430, 0x8C71, 0x8C51, 0x8C51, 0x8430, 0x8430, 0x7BCF, 0x632C, 0x528A, 0x4A69, 0x39E7, 0x3186, 0x2945, 0x2104, 0x18C3, 0x10A2,   // 0x0800 (2048)
0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x0810 (2064)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841,   // 0x0820 (2080)
0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0830 (2096)
0x0000, 0x0000, 0x18E3, 0x52AA, 0x6B6D, 0x8C51, 0x8C71, 0x8430, 0x7BEF, 0x738E, 0x73AE, 0x738E, 0x738E, 0x73AE, 0x7BEF, 0x8410,   // 0x0840 (2112)
0x8410, 0x8410, 0x8430, 0x8410, 0x8410, 0x8430, 0x8C71, 0x94B2, 0x94B2, 0xA514, 0xA534, 0x9CF3, 0x9CF3, 0x8C51, 0x8C71, 0x9492,   // 0x0850 (2128)
0x8C71, 0x9492, 0x8C71, 0x7BEF, 0x7BCF, 0x738E, 0x632C, 0x5ACB, 0x4A69, 0x4208, 0x31A6, 0x2945, 0x2104, 0x18C3, 0x10A2, 0x10A2,   // 0x0860 (2144)
0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2,   // 0x0870 (2160)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x0880 (2176)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0890 (2192)
0x0841, 0x4A49, 0x6B6D, 0x8410, 0x8C51, 0x8C71, 0x8410, 0x7BEF, 0x73AE, 0x738E, 0x73AE, 0x73AE, 0x73AE, 0x7BEF, 0x8410, 0x8410,   // 0x08A0 (2208)
0x8430, 0x8410, 0x8430, 0x8C51, 0x9492, 0x94B2, 0xA534, 0xAD75, 0xB596, 0xAD75, 0xAD55, 0xA514, 0x9492, 0x94B2, 0x9CF3, 0x9CD3,   // 0x08B0 (2224)
0xA514, 0x9CD3, 0x8430, 0x8410, 0x738E, 0x632C, 0x5AEB, 0x4A49, 0x39E7, 0x3186, 0x2945, 0x2104, 0x18C3, 0x18C3, 0x10A2, 0x1082,   // 0x08C0 (2240)
0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2,   // 0x08D0 (2256)
0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0020,   // 0x08E0 (2272)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x3186,   // 0x08F0 (2288)
0x632C, 0x73AE, 0x6B6D, 0x7BCF, 0x94B2, 0x8C71, 0x7BEF, 0x73AE, 0x7BCF, 0x73AE, 0x73AE, 0x7BCF, 0x7BEF, 0x8410, 0x8410, 0x8430,   // 0x0900 (2304)
0x8410, 0x8430, 0x8C51, 0x94B2, 0xA534, 0xB596, 0xBDD7, 0xBDD7, 0xB596, 0xAD75, 0x9CD3, 0x8C71, 0x9492, 0x9CD3, 0x9CD3, 0xAD75,   // 0x0910 (2320)
0xAD55, 0x9CD3, 0x8C71, 0x7BEF, 0x6B6D, 0x5ACB, 0x4A49, 0x4208, 0x31A6, 0x2945, 0x2104, 0x18E3, 0x18C3, 0x1082, 0x10A2, 0x10A2,   // 0x0920 (2336)
0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2,   // 0x0930 (2352)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0841, 0x0000,   // 0x0940 (2368)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1082, 0x5ACB, 0x7BCF,   // 0x0950 (2384)
0x6B6D, 0x5AEB, 0x8410, 0x94B2, 0x8C71, 0x73AE, 0x738E, 0x73AE, 0x73AE, 0x73AE, 0x7BEF, 0x8410, 0x7BEF, 0x7BEF, 0x7BCF, 0x7BEF,   // 0x0960 (2400)
0x8410, 0x8C71, 0x9CD3, 0xA534, 0xB5B6, 0xC618, 0xBDF7, 0xB5B6, 0xA534, 0x9492, 0x8C51, 0x9492, 0xA534, 0xAD55, 0xAD75, 0xA534,   // 0x0970 (2416)
0x9CF3, 0x9492, 0x8410, 0x6B4D, 0x5ACB, 0x4A49, 0x4208, 0x31A6, 0x2945, 0x2124, 0x18E3, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x1082,   // 0x0980 (2432)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x0990 (2448)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0000,   // 0x09A0 (2464)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x39C7, 0x6B4D, 0x7BCF, 0x632C,   // 0x09B0 (2480)
0x7BCF, 0xA514, 0x94B2, 0x8C51, 0x7BCF, 0x738E, 0x73AE, 0x7BCF, 0x7BEF, 0x8410, 0x7BEF, 0x7BEF, 0x7BEF, 0x8410, 0x7BEF, 0x8410,   // 0x09C0 (2496)
0x94B2, 0x9CF3, 0xA534, 0xB5B6, 0xBDF7, 0xBDF7, 0xB5B6, 0x9CF3, 0x9CD3, 0x9CF3, 0x9CF3, 0xAD75, 0xB596, 0xB596, 0xA534, 0x94B2,   // 0x09D0 (2512)
0x9492, 0x8430, 0x6B6D, 0x5ACB, 0x4A69, 0x4208, 0x31A6, 0x2945, 0x2124, 0x18E3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x09E0 (2528)
0x1082, 0x1082, 0x10A2, 0x1082, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x18C3,   // 0x09F0 (2544)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0841, 0x0020, 0x0000,   // 0x0A00 (2560)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x18C3, 0x5ACB, 0x73AE, 0x8410, 0x8430, 0x9CF3,   // 0x0A10 (2576)
0xA534, 0x9492, 0x8C51, 0x7BCF, 0x73AE, 0x73AE, 0x8430, 0x8C71, 0x8410, 0x7BEF, 0x7BEF, 0x8410, 0x8410, 0x7BEF, 0x8430, 0xA514,   // 0x0A20 (2592)
0x94B2, 0x9CD3, 0xBDD7, 0xB5B6, 0xAD55, 0xAD55, 0x9CF3, 0x94B2, 0x9CF3, 0xA534, 0xAD75, 0xB5B6, 0xB5B6, 0xAD75, 0x9CD3, 0x94B2,   // 0x0A30 (2608)
0x8C71, 0x73AE, 0x632C, 0x528A, 0x4208, 0x31A6, 0x2965, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2,   // 0x0A40 (2624)
0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x0A50 (2640)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x0841, 0x0020, 0x0000, 0x0000,   // 0x0A60 (2656)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x39E7, 0x6B6D, 0x7BEF, 0x8410, 0x9492, 0x9CF3, 0x9CF3,   // 0x0A70 (2672)
0x9492, 0x8430, 0x73AE, 0x73AE, 0x7BCF, 0x8430, 0x8C71, 0x7BEF, 0x8410, 0x8410, 0x7BEF, 0x7BEF, 0x7BEF, 0x8C71, 0x9CD3, 0x9CD3,   // 0x0A80 (2688)
0xA534, 0xAD75, 0x9CF3, 0x94B2, 0x9CF3, 0xA514, 0x9CD3, 0x9CD3, 0xA514, 0xAD75, 0xB596, 0xB596, 0xAD75, 0x9CF3, 0x94B2, 0x9492,   // 0x0A90 (2704)
0x7BEF, 0x6B4D, 0x52AA, 0x4228, 0x39C7, 0x2965, 0x2124, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x0AA0 (2720)
0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x10A2, 0x18C3, 0x18C3, 0x10A2,   // 0x0AB0 (2736)
0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0000, 0x0000, 0x0000,   // 0x0AC0 (2752)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x18C3, 0x5AEB, 0x73AE, 0x8410, 0x8C51, 0x94B2, 0x9CF3, 0x9CF3, 0x94B2,   // 0x0AD0 (2768)
0x8C51, 0x7BCF, 0x73AE, 0x7BCF, 0x8C71, 0x8430, 0x7BEF, 0x7BEF, 0x7BEF, 0x7BEF, 0x7BCF, 0x8410, 0x8430, 0x8C71, 0x9CF3, 0xA514,   // 0x0AE0 (2784)
0x94B2, 0x9492, 0x9CD3, 0xA514, 0xAD55, 0xAD55, 0xA534, 0x9CF3, 0xAD55, 0xB596, 0xAD75, 0xAD75, 0xA514, 0x9CD3, 0x9492, 0x7BEF,   // 0x0AF0 (2800)
0x6B6D, 0x5ACB, 0x4A69, 0x39E7, 0x3186, 0x2124, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x0B00 (2816)
0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2,   // 0x0B10 (2832)
0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000,   // 0x0B20 (2848)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x3186, 0x6B6D, 0x7BCF, 0x8C51, 0x9492, 0x9CF3, 0xA514, 0xA514, 0x94B2, 0x8430,   // 0x0B30 (2864)
0x8410, 0x73AE, 0x7BEF, 0x8C51, 0x8430, 0x8430, 0x7BEF, 0x7BCF, 0x7BCF, 0x8C51, 0x8C51, 0x8410, 0x8430, 0x8C71, 0x94B2, 0x94B2,   // 0x0B40 (2880)
0x9CD3, 0xA534, 0xA534, 0xA514, 0xAD75, 0xB5B6, 0xAD55, 0xAD75, 0xB596, 0xAD75, 0xB5B6, 0xB5B6, 0xA534, 0x94B2, 0x8410, 0x6B6D,   // 0x0B50 (2896)
0x5ACB, 0x4A69, 0x4208, 0x3186, 0x2945, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x0B60 (2912)
0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x10A2, 0x18C3, 0x10A2,   // 0x0B70 (2928)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0B80 (2944)
0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x4A69, 0x73AE, 0x7BEF, 0x8C51, 0x9492, 0xA534, 0xAD75, 0xA514, 0x8C51, 0x8410, 0x8410,   // 0x0B90 (2960)
0x7BCF, 0x7BEF, 0x8410, 0x8410, 0x8410, 0x8410, 0x8430, 0x8410, 0x8C51, 0x8430, 0x7BEF, 0x8410, 0x8C51, 0x94B2, 0x94B2, 0x9CD3,   // 0x0BA0 (2976)
0x9CF3, 0x9CF3, 0x94B2, 0xA514, 0xB596, 0xB596, 0xB596, 0xB596, 0xAD55, 0xAD75, 0xBDD7, 0xB596, 0x9CD3, 0x7BEF, 0x6B6D, 0x5AEB,   // 0x0BB0 (2992)
0x4A69, 0x4208, 0x31A6, 0x2945, 0x2104, 0x18E3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082,   // 0x0BC0 (3008)
0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x10A2, 0x10A2, 0x1082,   // 0x0BD0 (3024)
0x0861, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0BE0 (3040)
0x0000, 0x0000, 0x0000, 0x18E3, 0x630C, 0x7BCF, 0x8410, 0x8C51, 0x9492, 0xAD55, 0xB5B6, 0xA534, 0x8430, 0x8430, 0x94B2, 0x8C51,   // 0x0BF0 (3056)
0x8410, 0x8430, 0x8410, 0x7BEF, 0x8410, 0x7BEF, 0x7BEF, 0x8410, 0x8410, 0x7BEF, 0x8410, 0x8C71, 0x9492, 0x9492, 0x94B2, 0xA514,   // 0x0C00 (3072)
0xA514, 0x9CD3, 0xA514, 0xAD55, 0xB5B6, 0xB596, 0xAD55, 0xA534, 0xA514, 0xA534, 0xA534, 0x9492, 0x7BCF, 0x6B4D, 0x5AEB, 0x4A69,   // 0x0C10 (3088)
0x4208, 0x31A6, 0x2945, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x1082,   // 0x0C20 (3104)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x0861,   // 0x0C30 (3120)
0x0861, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0C40 (3136)
0x0000, 0x0000, 0x39C7, 0x6B4D, 0x7BCF, 0x7BCF, 0x8C51, 0x94B2, 0xAD55, 0xB596, 0xA534, 0x9492, 0x9CF3, 0xA534, 0x8C71, 0x8430,   // 0x0C50 (3152)
0x8430, 0x8430, 0x7BEF, 0x8410, 0x8410, 0x8430, 0x8C71, 0x8410, 0x7BEF, 0x8430, 0x9492, 0x9492, 0x8C71, 0x94B2, 0x9CD3, 0xA534,   // 0x0C60 (3168)
0xA514, 0xA534, 0xAD75, 0xB596, 0xB596, 0xAD75, 0xAD55, 0x9CF3, 0x94B2, 0x8C71, 0x8430, 0x7BCF, 0x6B4D, 0x5ACB, 0x4A69, 0x4208,   // 0x0C70 (3184)
0x31A6, 0x2945, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2,   // 0x0C80 (3200)
0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x0861,   // 0x0C90 (3216)
0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0CA0 (3232)
0x0841, 0x528A, 0x738E, 0x7BEF, 0x8410, 0x94B2, 0x9CD3, 0xA534, 0xAD55, 0xAD55, 0xA514, 0xA534, 0xA514, 0x9492, 0x8C71, 0x8430,   // 0x0CB0 (3248)
0x8430, 0x7BEF, 0x8410, 0x8410, 0x8C71, 0x8C71, 0x8410, 0x8C51, 0x8C71, 0x8C71, 0x94B2, 0xA514, 0x94B2, 0x94B2, 0xA534, 0xA534,   // 0x0CC0 (3264)
0xA514, 0xAD75, 0xAD75, 0xB596, 0xAD75, 0xA514, 0x9CD3, 0x8C71, 0x8C71, 0x8410, 0x73AE, 0x6B4D, 0x5ACB, 0x4A69, 0x39E7, 0x3186,   // 0x0CD0 (3280)
0x2945, 0x2104, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2,   // 0x0CE0 (3296)
0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082,   // 0x0CF0 (3312)
0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x10A2,   // 0x0D00 (3328)
0x630C, 0x7BEF, 0x8430, 0x9492, 0x9CF3, 0xA514, 0xA514, 0xA534, 0xAD75, 0xAD75, 0x9CF3, 0x94B2, 0x9492, 0x9CD3, 0x9492, 0x8410,   // 0x0D10 (3344)
0x8410, 0x8430, 0x8C51, 0x8C71, 0x8430, 0x8430, 0x9492, 0x9CD3, 0x9492, 0x94B2, 0x9CD3, 0x9CF3, 0xA514, 0xA514, 0xA534, 0x9CF3,   // 0x0D20 (3360)
0xAD55, 0xAD75, 0xBDD7, 0xB5B6, 0x9CF3, 0x9CD3, 0x9492, 0x8430, 0x738E, 0x6B6D, 0x630C, 0x5ACB, 0x4A69, 0x39E7, 0x3186, 0x2124,   // 0x0D30 (3376)
0x2104, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861,   // 0x0D40 (3392)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082,   // 0x0D50 (3408)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x2945, 0x6B4D,   // 0x0D60 (3424)
0x8430, 0x8C71, 0x9CD3, 0xA514, 0xA534, 0xA534, 0xAD55, 0xB596, 0xA514, 0x9492, 0xA514, 0x9CF3, 0x9CF3, 0x9CF3, 0x8C71, 0x9492,   // 0x0D70 (3440)
0x9492, 0x8C71, 0x8430, 0x8430, 0x8C51, 0x9492, 0x9492, 0x8C71, 0x9492, 0x94B2, 0x9CF3, 0xA534, 0xA514, 0xA514, 0xA514, 0xAD55,   // 0x0D80 (3456)
0xB596, 0xB596, 0xAD75, 0xA514, 0x9CD3, 0x8C71, 0x7BCF, 0x6B4D, 0x6B4D, 0x5AEB, 0x52AA, 0x4A49, 0x39C7, 0x2965, 0x2124, 0x18E3,   // 0x0D90 (3472)
0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861,   // 0x0DA0 (3488)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x0861,   // 0x0DB0 (3504)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x4208, 0x738E, 0x8430,   // 0x0DC0 (3520)
0x94B2, 0x9CD3, 0xA534, 0xAD55, 0xAD55, 0xAD75, 0xAD55, 0x9CF3, 0x9CF3, 0xA534, 0xAD55, 0xA534, 0xA514, 0x9CF3, 0xAD55, 0xA514,   // 0x0DD0 (3536)
0x8430, 0x8430, 0x8430, 0x8C51, 0x9CD3, 0x94B2, 0x94B2, 0xA534, 0xA534, 0x9CD3, 0x9CD3, 0x9CF3, 0x9CF3, 0x9CD3, 0xA514, 0xAD55,   // 0x0DE0 (3552)
0xA534, 0xB5B6, 0xAD55, 0x94B2, 0x8430, 0x7BCF, 0x6B6D, 0x630C, 0x5AEB, 0x52AA, 0x4228, 0x31A6, 0x2945, 0x2124, 0x18E3, 0x10A2,   // 0x0DF0 (3568)
0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0E00 (3584)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x0861, 0x0841, 0x0841,   // 0x0E10 (3600)
0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x4A69, 0x738E, 0x8C51, 0x9CF3,   // 0x0E20 (3616)
0xA534, 0xAD75, 0xAD55, 0xAD55, 0xAD55, 0xA534, 0xAD75, 0xAD55, 0xA514, 0xAD55, 0xAD55, 0xAD55, 0xAD55, 0xB596, 0xA514, 0x8430,   // 0x0E30 (3632)
0x8410, 0x8430, 0x8C71, 0x94B2, 0x9CF3, 0xB5B6, 0xBDD7, 0xAD75, 0xA534, 0x94B2, 0x9CD3, 0x9492, 0x9492, 0x9CD3, 0x9CD3, 0xA514,   // 0x0E40 (3648)
0xB596, 0xA534, 0x94B2, 0x8410, 0x7BEF, 0x73AE, 0x632C, 0x5AEB, 0x4A69, 0x39C7, 0x2965, 0x2945, 0x2124, 0x18E3, 0x10A2, 0x1082,   // 0x0E50 (3664)
0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0841, 0x0861, 0x0861, 0x0861,   // 0x0E60 (3680)
0x0861, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0861, 0x1082, 0x1082, 0x0861, 0x0841, 0x0861, 0x1082,   // 0x0E70 (3696)
0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x10A2, 0x5ACB, 0x738E, 0x8C71, 0xA534, 0xAD75,   // 0x0E80 (3712)
0xB596, 0xAD55, 0xAD55, 0xAD55, 0xAD75, 0xB596, 0xAD75, 0xB596, 0xAD75, 0xAD75, 0xB596, 0xB5B6, 0xB5B6, 0x9CF3, 0x8C51, 0x8430,   // 0x0E90 (3728)
0x8C51, 0x8C71, 0x9492, 0xA514, 0xB596, 0xBDD7, 0xB596, 0x9CF3, 0x94B2, 0x9CD3, 0x8C71, 0x9CF3, 0x9CF3, 0x9CD3, 0xA534, 0xAD75,   // 0x0EA0 (3744)
0xA534, 0x94B2, 0x8410, 0x7BCF, 0x7BCF, 0x6B6D, 0x5AEB, 0x4228, 0x3186, 0x2965, 0x2945, 0x2104, 0x2104, 0x18C3, 0x10A2, 0x10A2,   // 0x0EB0 (3760)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x0861, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0EC0 (3776)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0861, 0x10A2, 0x10A2, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082,   // 0x0ED0 (3792)
0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x2124, 0x632C, 0x7BEF, 0x94B2, 0xAD75, 0xB596, 0xB596,   // 0x0EE0 (3808)
0xB5B6, 0xAD55, 0xAD75, 0xB596, 0xB596, 0xBDF7, 0xBDF7, 0xB5B6, 0xB5B6, 0xB5B6, 0xBDD7, 0xB596, 0xA514, 0x8C71, 0x8430, 0x8430,   // 0x0EF0 (3824)
0x8430, 0x8C71, 0x9CF3, 0xB596, 0xA534, 0x94B2, 0x8C71, 0x9492, 0x9492, 0x9CD3, 0xAD75, 0xA514, 0xA514, 0xAD55, 0xAD55, 0xA534,   // 0x0F00 (3840)
0x9492, 0x8430, 0x7BEF, 0x7BCF, 0x6B4D, 0x5ACB, 0x4228, 0x31A6, 0x3186, 0x2945, 0x2124, 0x2104, 0x2104, 0x18E3, 0x18C3, 0x10A2,   // 0x0F10 (3856)
0x1082, 0x0861, 0x0861, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x0F20 (3872)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0861, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x0861,   // 0x0F30 (3888)
0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x39C7, 0x6B6D, 0x7BCF, 0x9492, 0xAD75, 0xAD75, 0xAD75, 0xBDD7,   // 0x0F40 (3904)
0xB5B6, 0xB596, 0xB5B6, 0xB5B6, 0xC638, 0xC618, 0xB5B6, 0xBDD7, 0xB5B6, 0xB5B6, 0x9CF3, 0x9CD3, 0xA514, 0x8C71, 0x8430, 0x8C51,   // 0x0F50 (3920)
0x94B2, 0x9CD3, 0x9CF3, 0x8C71, 0x8C51, 0x8C51, 0x8C71, 0x94B2, 0xA534, 0xAD55, 0xAD55, 0xB596, 0xAD75, 0xAD55, 0x9CF3, 0x9CF3,   // 0x0F60 (3936)
0x8C71, 0x7BEF, 0x73AE, 0x632C, 0x5ACB, 0x4A49, 0x39E7, 0x31A6, 0x2965, 0x2945, 0x2124, 0x2124, 0x18E3, 0x18C3, 0x18C3, 0x10A2,   // 0x0F70 (3952)
0x1082, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082,   // 0x0F80 (3968)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0861, 0x1082, 0x10A2, 0x1082, 0x10A2, 0x1082, 0x0861, 0x1082, 0x0861, 0x0861,   // 0x0F90 (3984)
0x0841, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0020, 0x39E7, 0x6B6D, 0x73AE, 0x8C51, 0xA534, 0xAD55, 0xAD75, 0xB5B6, 0xBDD7,   // 0x0FA0 (4000)
0xB5B6, 0xBDD7, 0xB5B6, 0xBDD7, 0xAD75, 0x94B2, 0x94B2, 0xB596, 0xB596, 0x9492, 0x9CF3, 0x9CF3, 0x8C51, 0x8410, 0x8C51, 0x9CD3,   // 0x0FB0 (4016)
0x94B2, 0x8C51, 0x8C71, 0x8C51, 0x8C71, 0x9492, 0x9CD3, 0xA514, 0xA534, 0xB596, 0xB596, 0xB596, 0xB5B6, 0xA514, 0x9CF3, 0x9492,   // 0x0FC0 (4032)
0x7BEF, 0x73AE, 0x6B4D, 0x5ACB, 0x4A69, 0x4228, 0x31A6, 0x2945, 0x2945, 0x2945, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x1082,   // 0x0FD0 (4048)
0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x0861, 0x0861, 0x0861,   // 0x0FE0 (4064)
0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861,   // 0x0FF0 (4080)
0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0020, 0x4208, 0x6B6D, 0x7BCF, 0x8C51, 0xA514, 0xA514, 0xAD75, 0xB596, 0xBDD7, 0xB596,   // 0x1000 (4096)
0xBDD7, 0xB5B6, 0x9CF3, 0x9492, 0x8C51, 0x8410, 0x8C51, 0x8C71, 0x8C51, 0xA514, 0x9492, 0x9492, 0x8C51, 0x8410, 0x9492, 0x94B2,   // 0x1010 (4112)
0x8C71, 0x8C71, 0x8C51, 0x9492, 0x9492, 0x94B2, 0x9CD3, 0xAD75, 0xB596, 0xB596, 0xAD75, 0xAD55, 0x9CF3, 0x9CF3, 0x9CD3, 0x8430,   // 0x1020 (4128)
0x7BCF, 0x738E, 0x632C, 0x52AA, 0x4228, 0x31A6, 0x2945, 0x2945, 0x2124, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082,   // 0x1030 (4144)
0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x1040 (4160)
0x0841, 0x0861, 0x0841, 0x0841, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841,   // 0x1050 (4176)
0x0841, 0x0020, 0x0000, 0x0000, 0x0841, 0x4228, 0x6B6D, 0x7BEF, 0x8C51, 0x9CD3, 0xA514, 0xAD75, 0xB5B6, 0xBDF7, 0xB5B6, 0xBDD7,   // 0x1060 (4192)
0xBDF7, 0x9492, 0x8410, 0x8410, 0x7BEF, 0x7BCF, 0x7BCF, 0x8430, 0x9492, 0x8C51, 0x9CF3, 0x94B2, 0x8430, 0x94B2, 0x9CF3, 0x9CF3,   // 0x1070 (4208)
0x9492, 0x8C71, 0x8C71, 0x9492, 0x94B2, 0x94B2, 0xAD55, 0xB5B6, 0xBDD7, 0xAD75, 0x9CF3, 0x94B2, 0x9CD3, 0xA514, 0x94B2, 0x8430,   // 0x1080 (4224)
0x7BCF, 0x6B6D, 0x5AEB, 0x4A49, 0x39C7, 0x2965, 0x2124, 0x2104, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x0861,   // 0x1090 (4240)
0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x10A0 (4256)
0x0861, 0x0841, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841,   // 0x10B0 (4272)
0x0020, 0x0020, 0x0000, 0x0841, 0x4A49, 0x6B6D, 0x7BEF, 0x8430, 0x9CD3, 0xA534, 0xAD55, 0xBDD7, 0xC618, 0xBDD7, 0xB596, 0xB596,   // 0x10C0 (4288)
0x94B2, 0x8430, 0x8410, 0x8410, 0x8410, 0x7BEF, 0x8430, 0x9492, 0x9492, 0x9CD3, 0x8C71, 0x8C51, 0xA514, 0xAD55, 0xB596, 0xB596,   // 0x10D0 (4304)
0x9CF3, 0x9492, 0x9492, 0x9492, 0x94B2, 0xAD55, 0xBDF7, 0xBDD7, 0xAD55, 0x9CD3, 0x9492, 0x94B2, 0xAD55, 0xAD55, 0x9492, 0x7BCF,   // 0x10E0 (4320)
0x6B4D, 0x5AEB, 0x4A69, 0x39E7, 0x2965, 0x2124, 0x2104, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082,   // 0x10F0 (4336)
0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x1100 (4352)
0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0020,   // 0x1110 (4368)
0x0020, 0x0000, 0x0861, 0x4A49, 0x738E, 0x7BEF, 0x8430, 0x9CD3, 0xA534, 0xAD55, 0xBDD7, 0xC618, 0xBDD7, 0xB596, 0x9CF3, 0x9492,   // 0x1120 (4384)
0x8C71, 0x8C51, 0x8410, 0x7BEF, 0x8410, 0x8430, 0xA534, 0xB5B6, 0xAD75, 0xA514, 0x9CD3, 0xAD75, 0xB596, 0xBDF7, 0xBDD7, 0xA514,   // 0x1130 (4400)
0x9CD3, 0x9492, 0x9492, 0x9CD3, 0xA534, 0xB596, 0xAD75, 0x94B2, 0x8C51, 0x8C71, 0x9CF3, 0xAD55, 0xAD55, 0x94B2, 0x7BEF, 0x73AE,   // 0x1140 (4416)
0x630C, 0x528A, 0x39E7, 0x2965, 0x2124, 0x2104, 0x18E3, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082,   // 0x1150 (4432)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x0861, 0x0841, 0x0861, 0x0861, 0x0861, 0x0841, 0x0861,   // 0x1160 (4448)
0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0020, 0x0020,   // 0x1170 (4464)
0x0000, 0x1082, 0x4A69, 0x738E, 0x7BEF, 0x8C51, 0x94B2, 0x9CF3, 0xAD75, 0xBDD7, 0xBDF7, 0xBDF7, 0xB5B6, 0x9CD3, 0x8C71, 0x9492,   // 0x1180 (4480)
0x8410, 0x7BEF, 0x7BEF, 0x7BEF, 0x8430, 0xB596, 0xBDD7, 0xAD75, 0xAD75, 0xB596, 0xB5B6, 0xB5B6, 0xB5B6, 0x9CF3, 0x94B2, 0xA514,   // 0x1190 (4496)
0xA514, 0xA534, 0x9CF3, 0xAD55, 0xBDD7, 0xAD75, 0x8C71, 0x8C51, 0x94B2, 0xA514, 0xA514, 0xA514, 0x9492, 0x8410, 0x7BCF, 0x632C,   // 0x11A0 (4512)
0x528A, 0x4208, 0x2965, 0x2124, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x11B0 (4528)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0861, 0x0861, 0x1082,   // 0x11C0 (4544)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0020, 0x0020, 0x0000,   // 0x11D0 (4560)
0x1082, 0x528A, 0x738E, 0x7BCF, 0x8C51, 0x8C71, 0x94B2, 0xAD55, 0xBDF7, 0xC618, 0xBDF7, 0xBDF7, 0xAD55, 0x9CD3, 0x8C51, 0x8430,   // 0x11E0 (4576)
0x8410, 0x8410, 0x7BCF, 0x9492, 0xAD75, 0xAD75, 0xA514, 0xAD55, 0xB5B6, 0xB596, 0xA534, 0xA514, 0x94B2, 0x94B2, 0x9CF3, 0xAD55,   // 0x11F0 (4592)
0xAD55, 0x9CF3, 0xB596, 0xBDF7, 0xA534, 0x9492, 0x8C71, 0x8C71, 0x9CD3, 0x9CF3, 0x9CF3, 0x9492, 0x8410, 0x73AE, 0x630C, 0x528A,   // 0x1200 (4608)
0x4208, 0x31A6, 0x2945, 0x2124, 0x2104, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2,   // 0x1210 (4624)
0x10A2, 0x10A2, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2,   // 0x1220 (4640)
0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0020, 0x0000, 0x0000, 0x10A2,   // 0x1230 (4656)
0x5ACB, 0x73AE, 0x73AE, 0x8430, 0x9492, 0x94B2, 0xA534, 0xB596, 0xCE59, 0xC618, 0xBDF7, 0xAD55, 0xA514, 0x8430, 0x8430, 0x8430,   // 0x1240 (4672)
0x8430, 0x8410, 0x9492, 0xA514, 0xA514, 0xA514, 0xAD75, 0xB596, 0xA534, 0x9CF3, 0x9CD3, 0x94B2, 0x94B2, 0x9CF3, 0x9CF3, 0x94B2,   // 0x1250 (4688)
0xA514, 0xB596, 0xAD75, 0x9CD3, 0x9CF3, 0x8C71, 0x9492, 0x9CF3, 0xA514, 0x9CD3, 0x9492, 0x8410, 0x73AE, 0x632C, 0x528A, 0x4228,   // 0x1260 (4704)
0x31A6, 0x2965, 0x2945, 0x2124, 0x2104, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x1270 (4720)
0x10A2, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x1280 (4736)
0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x1082, 0x52AA,   // 0x1290 (4752)
0x73AE, 0x738E, 0x8430, 0x9CD3, 0xA514, 0xA534, 0xAD55, 0xBDF7, 0xC618, 0xB5B6, 0xAD55, 0xA514, 0x8C71, 0x9492, 0x8C51, 0x8C71,   // 0x12A0 (4768)
0x94B2, 0x8C71, 0xA514, 0xA534, 0xA514, 0x9CD3, 0xAD55, 0xAD55, 0xBDD7, 0xA534, 0x94B2, 0x9CD3, 0xA534, 0x9CF3, 0x94B2, 0xA514,   // 0x12B0 (4784)
0xA514, 0x94B2, 0x8C71, 0x9492, 0x94B2, 0xA534, 0xA534, 0xA534, 0x9CF3, 0x9492, 0x8430, 0x73AE, 0x6B4D, 0x52AA, 0x4228, 0x39C7,   // 0x12C0 (4800)
0x2965, 0x2945, 0x2124, 0x2104, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082,   // 0x12D0 (4816)
0x0861, 0x0841, 0x0841, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x1082, 0x0861, 0x0861, 0x0861,   // 0x12E0 (4832)
0x10A2, 0x10A2, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0020, 0x0020, 0x0000, 0x0000, 0x0861, 0x4A69, 0x738E,   // 0x12F0 (4848)
0x73AE, 0x8C51, 0x9CF3, 0x9CD3, 0xA534, 0xAD55, 0xAD75, 0xB5B6, 0xB596, 0xB596, 0xA534, 0x9CF3, 0xA514, 0x94B2, 0x94B2, 0xAD55,   // 0x1300 (4864)
0x9CF3, 0xAD55, 0xA534, 0x94B2, 0x9CD3, 0xAD55, 0xA534, 0xBDD7, 0xAD75, 0x9CD3, 0x9CF3, 0x9CF3, 0x9CD3, 0x9CF3, 0x9CF3, 0x9CD3,   // 0x1310 (4880)
0x9492, 0x9492, 0x94B2, 0x9CF3, 0xB596, 0xAD55, 0xAD55, 0xA534, 0x9492, 0x7BEF, 0x738E, 0x632C, 0x52AA, 0x4228, 0x39E7, 0x3186,   // 0x1320 (4896)
0x2945, 0x2124, 0x2104, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0841,   // 0x1330 (4912)
0x0841, 0x0841, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x10A2,   // 0x1340 (4928)
0x10A2, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0000, 0x0020, 0x4228, 0x6B6D, 0x7BCF,   // 0x1350 (4944)
0x8430, 0x94B2, 0x94B2, 0xA514, 0xB596, 0xAD75, 0xAD55, 0xAD55, 0xB5B6, 0xAD75, 0xA534, 0xA534, 0xA534, 0xAD55, 0xB5B6, 0xAD75,   // 0x1360 (4960)
0xB596, 0xB596, 0x94B2, 0xA514, 0xAD75, 0xA534, 0xAD55, 0xA534, 0x9CF3, 0x9CF3, 0x94B2, 0x94B2, 0x94B2, 0x9CD3, 0x9CD3, 0x9492,   // 0x1370 (4976)
0x9CF3, 0xAD75, 0x9CF3, 0xA514, 0xAD55, 0xAD55, 0xA514, 0x8C71, 0x7BEF, 0x738E, 0x630C, 0x52AA, 0x4228, 0x39C7, 0x3186, 0x2945,   // 0x1380 (4992)
0x2124, 0x2104, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0841, 0x0841,   // 0x1390 (5008)
0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2,   // 0x13A0 (5024)
0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x39C7, 0x6B4D, 0x7BCF, 0x8430,   // 0x13B0 (5040)
0x9492, 0x8C71, 0x94B2, 0xA534, 0xAD75, 0xA514, 0x9CF3, 0xB596, 0xB5B6, 0xAD55, 0xAD75, 0xB5B6, 0xBDF7, 0xBDD7, 0xAD75, 0xAD75,   // 0x13C0 (5056)
0xA534, 0x94B2, 0xA514, 0xAD55, 0xA514, 0x9CF3, 0x9CD3, 0x9CD3, 0x9CD3, 0x9492, 0x9492, 0x8C51, 0x9492, 0x9CD3, 0x9492, 0x9492,   // 0x13D0 (5072)
0xAD55, 0xA534, 0x94B2, 0x9CF3, 0xAD55, 0xA514, 0x8C71, 0x7BEF, 0x6B6D, 0x5AEB, 0x52AA, 0x4A49, 0x39E7, 0x3186, 0x2945, 0x2124,   // 0x13E0 (5088)
0x2104, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x13F0 (5104)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x1082, 0x10A2, 0x1082,   // 0x1400 (5120)
0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0000, 0x0000, 0x0000, 0x2965, 0x632C, 0x73AE, 0x8410, 0x8C71,   // 0x1410 (5136)
0x8C71, 0x94B2, 0x9CF3, 0xA534, 0xA514, 0x94B2, 0xA514, 0xB596, 0xB596, 0xB5B6, 0xB5B6, 0xB596, 0xAD55, 0x94B2, 0x9CF3, 0xA514,   // 0x1420 (5152)
0x9CD3, 0xA514, 0xA534, 0x9CF3, 0x9CD3, 0x9492, 0x94B2, 0xA514, 0x9492, 0x9492, 0x94B2, 0x94B2, 0x9CF3, 0x9492, 0x8C51, 0x9CD3,   // 0x1430 (5168)
0xAD55, 0xA514, 0xAD55, 0xA534, 0x9CF3, 0x9492, 0x8410, 0x738E, 0x5AEB, 0x52AA, 0x4A49, 0x39E7, 0x3186, 0x2945, 0x2124, 0x2104,   // 0x1440 (5184)
0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x1450 (5200)
0x0841, 0x0841, 0x0841, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082,   // 0x1460 (5216)
0x0861, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x2104, 0x5AEB, 0x738E, 0x8410, 0x8410, 0x8410,   // 0x1470 (5232)
0x9CD3, 0xA514, 0xA534, 0xAD55, 0x9CD3, 0xA534, 0xB596, 0xB5B6, 0xBDD7, 0xB596, 0xA514, 0x9492, 0x9CD3, 0xAD75, 0xAD75, 0xA514,   // 0x1480 (5248)
0xAD55, 0xAD55, 0xA514, 0x94B2, 0x8C71, 0x9492, 0xA514, 0x94B2, 0x9492, 0x9CD3, 0x9CF3, 0x9CD3, 0x94B2, 0xA514, 0xAD55, 0xAD75,   // 0x1490 (5264)
0xB596, 0xB5B6, 0xAD75, 0x9CD3, 0x9492, 0x8430, 0x738E, 0x630C, 0x52AA, 0x4228, 0x39C7, 0x31A6, 0x2965, 0x2945, 0x2104, 0x18E3,   // 0x14A0 (5280)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841,   // 0x14B0 (5296)
0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x0861,   // 0x14C0 (5312)
0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x10A2, 0x52AA, 0x738E, 0x8410, 0x7BEF, 0x73AE, 0x9492,   // 0x14D0 (5328)
0xA534, 0xAD55, 0xAD75, 0xA534, 0xAD75, 0xB5B6, 0xAD75, 0xB596, 0xAD75, 0x9CD3, 0x94B2, 0x9CF3, 0xB596, 0xBDD7, 0xB596, 0xBDF7,   // 0x14E0 (5344)
0xAD75, 0xA514, 0x9492, 0x8C71, 0x8C51, 0x8C71, 0x9492, 0x9492, 0x94B2, 0x8C71, 0x9492, 0xA534, 0xBDF7, 0xC638, 0xBDD7, 0xB5B6,   // 0x14F0 (5360)
0xB5B6, 0xAD55, 0x9CF3, 0x9492, 0x8410, 0x738E, 0x632C, 0x528A, 0x4228, 0x39C7, 0x31A6, 0x2965, 0x2945, 0x2104, 0x18E3, 0x18E3,   // 0x1500 (5376)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841,   // 0x1510 (5392)
0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x0841, 0x0020,   // 0x1520 (5408)
0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0841, 0x4A69, 0x6B4D, 0x7BCF, 0x8410, 0x7BEF, 0x9492, 0x9CF3,   // 0x1530 (5424)
0xAD55, 0xB596, 0xAD75, 0xB596, 0xB5B6, 0xB5B6, 0xB596, 0xBDD7, 0xA534, 0xAD55, 0xAD75, 0xA514, 0xAD55, 0xBDD7, 0xC638, 0xB596,   // 0x1540 (5440)
0xA514, 0x9492, 0x9492, 0x8C71, 0x8C71, 0x8C71, 0x9492, 0x9492, 0x94B2, 0xAD55, 0xB596, 0xC618, 0xC618, 0xBDF7, 0xBDF7, 0xBDD7,   // 0x1550 (5456)
0xAD75, 0xA514, 0x9492, 0x8410, 0x73AE, 0x632C, 0x528A, 0x4228, 0x39E7, 0x31A6, 0x2965, 0x2945, 0x2104, 0x18E3, 0x18E3, 0x18C3,   // 0x1560 (5472)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x1570 (5488)
0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0861, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x0861, 0x0020, 0x0020, 0x0020,   // 0x1580 (5504)
0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x4208, 0x632C, 0x73AE, 0x8430, 0x8430, 0x9492, 0x9CD3, 0x9CF3,   // 0x1590 (5520)
0xAD55, 0xB596, 0xB5B6, 0xBDD7, 0xBDF7, 0xBDD7, 0xBDF7, 0xBDD7, 0xB596, 0xAD75, 0xA534, 0xAD55, 0xBDD7, 0xD69A, 0xC618, 0xAD55,   // 0x15A0 (5536)
0xA534, 0x9CF3, 0x94B2, 0x8C71, 0x8C71, 0x94B2, 0x8C71, 0xA514, 0xB5B6, 0xBDD7, 0xC618, 0xC638, 0xC618, 0xBDF7, 0xBDD7, 0xB596,   // 0x15B0 (5552)
0xA514, 0x9492, 0x8410, 0x73AE, 0x632C, 0x52AA, 0x4A49, 0x39E7, 0x3186, 0x2945, 0x2124, 0x2104, 0x18E3, 0x18E3, 0x18C3, 0x18C3,   // 0x15C0 (5568)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x15D0 (5584)
0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x1082, 0x1082, 0x1082, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020,   // 0x15E0 (5600)
0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x2965, 0x632C, 0x738E, 0x8410, 0x8C51, 0x8C51, 0x94B2, 0x9CD3, 0x9CF3,   // 0x15F0 (5616)
0xB596, 0xBDD7, 0xBDF7, 0xBDD7, 0xBDD7, 0xBDF7, 0xBDF7, 0xB5B6, 0xBDF7, 0xBDD7, 0xBDD7, 0xCE59, 0xD6BA, 0xCE79, 0xC618, 0xB5B6,   // 0x1600 (5632)
0xAD75, 0xA534, 0x9CD3, 0x94B2, 0x9492, 0x94B2, 0xA514, 0xAD55, 0xBDD7, 0xC638, 0xC638, 0xC618, 0xBDF7, 0xB5B6, 0xAD55, 0x9CF3,   // 0x1610 (5648)
0x94B2, 0x8430, 0x73AE, 0x632C, 0x52AA, 0x4228, 0x39C7, 0x3186, 0x2945, 0x2124, 0x2104, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3,   // 0x1620 (5664)
0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841,   // 0x1630 (5680)
0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x1082, 0x10A2, 0x1082, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020,   // 0x1640 (5696)
0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x18E3, 0x5AEB, 0x6B4D, 0x73AE, 0x8430, 0x8C51, 0x9492, 0x9492, 0x9CD3, 0xAD75,   // 0x1650 (5712)
0xBDD7, 0xC618, 0xC618, 0xBDD7, 0xB596, 0xB5B6, 0xC618, 0xC618, 0xC638, 0xC618, 0xC638, 0xDEDB, 0xD69A, 0xC638, 0xBDF7, 0xB596,   // 0x1660 (5728)
0xA534, 0xB596, 0xAD55, 0x9CD3, 0x9CF3, 0xA534, 0xB596, 0xBDF7, 0xC618, 0xCE59, 0xC618, 0xB5B6, 0xAD75, 0xA534, 0x9CF3, 0x9CD3,   // 0x1670 (5744)
0x8C71, 0x73AE, 0x630C, 0x52AA, 0x4228, 0x39C7, 0x3186, 0x2945, 0x2124, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x18E3, 0x18E3, 0x18E3,   // 0x1680 (5760)
0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0861, 0x0841,   // 0x1690 (5776)
0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x0861, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020,   // 0x16A0 (5792)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x4A69, 0x632C, 0x738E, 0x7BEF, 0x8C51, 0x8C71, 0x9492, 0x9CD3, 0xAD55, 0xB5B6,   // 0x16B0 (5808)
0xBDD7, 0xBDD7, 0xBDD7, 0xB5B6, 0xB596, 0xBDF7, 0xC638, 0xCE59, 0xCE59, 0xC618, 0xD69A, 0xD6BA, 0xCE59, 0xCE59, 0xBDD7, 0xB596,   // 0x16C0 (5824)
0xC618, 0xBDF7, 0xB5B6, 0xAD55, 0xB5B6, 0xC618, 0xC638, 0xC638, 0xC638, 0xBDF7, 0xB5B6, 0xAD75, 0xA534, 0xA514, 0x94B2, 0x8C71,   // 0x16D0 (5840)
0x7BCF, 0x632C, 0x5ACB, 0x4A49, 0x39E7, 0x3186, 0x2945, 0x2124, 0x2104, 0x18E3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x16E0 (5856)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841,   // 0x16F0 (5872)
0x0841, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x1082, 0x0861, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000,   // 0x1700 (5888)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x31A6, 0x630C, 0x738E, 0x8410, 0x8410, 0x8430, 0x8C51, 0x9CF3, 0xA534, 0xAD55, 0xB5B6,   // 0x1710 (5904)
0xBDD7, 0xBDF7, 0xC618, 0xBDF7, 0xB5B6, 0xC638, 0xC638, 0xC638, 0xC638, 0xCE79, 0xD6BA, 0xCE79, 0xCE79, 0xCE79, 0xCE79, 0xCE59,   // 0x1720 (5920)
0xCE59, 0xC638, 0xC638, 0xCE59, 0xCE59, 0xCE79, 0xC618, 0xBDF7, 0xBDF7, 0xBDD7, 0xB5B6, 0xAD55, 0x9CF3, 0x9492, 0x8C51, 0x7BCF,   // 0x1730 (5936)
0x632C, 0x5ACB, 0x4A69, 0x39E7, 0x3186, 0x2945, 0x2124, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3,   // 0x1740 (5952)
0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841,   // 0x1750 (5968)
0x0861, 0x0861, 0x0841, 0x0861, 0x1082, 0x1082, 0x0861, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000,   // 0x1760 (5984)
0x0000, 0x0000, 0x0000, 0x0000, 0x2104, 0x5ACB, 0x6B6D, 0x8410, 0x8430, 0x8430, 0x8C51, 0x94B2, 0x9CF3, 0xA534, 0xB596, 0xB5B6,   // 0x1770 (6000)
0xB5B6, 0xBDF7, 0xC618, 0xBDF7, 0xBDF7, 0xC638, 0xC638, 0xC638, 0xD69A, 0xD69A, 0xD6BA, 0xD69A, 0xCE79, 0xD69A, 0xD6BA, 0xD6BA,   // 0x1780 (6016)
0xD69A, 0xD6BA, 0xD69A, 0xD69A, 0xCE79, 0xC638, 0xC618, 0xC638, 0xC618, 0xBDD7, 0xAD75, 0x9CF3, 0x94B2, 0x8430, 0x738E, 0x630C,   // 0x1790 (6032)
0x52AA, 0x4A69, 0x39E7, 0x3186, 0x2945, 0x2124, 0x2104, 0x18E3, 0x18E3, 0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x10A2,   // 0x17A0 (6048)
0x1082, 0x0861, 0x1082, 0x0861, 0x0861, 0x1082, 0x10A2, 0x18C3, 0x18C3, 0x1082, 0x0841, 0x0841, 0x0841, 0x0841, 0x0861, 0x0861,   // 0x17B0 (6064)
0x0861, 0x0841, 0x0841, 0x1082, 0x1082, 0x0861, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x17C0 (6080)
0x0000, 0x0000, 0x0000, 0x0861, 0x4A69, 0x6B4D, 0x73AE, 0x8410, 0x8430, 0x8C51, 0x8C71, 0x9CD3, 0xA534, 0xB596, 0xB5B6, 0xB5B6,   // 0x17D0 (6096)
0xBDD7, 0xBDD7, 0xC618, 0xC638, 0xCE59, 0xCE59, 0xCE59, 0xD69A, 0xD69A, 0xD69A, 0xD69A, 0xD6BA, 0xD6BA, 0xDEDB, 0xDEDB, 0xDEDB,   // 0x17E0 (6112)
0xD6BA, 0xD6BA, 0xD6BA, 0xD69A, 0xD69A, 0xCE79, 0xCE79, 0xCE59, 0xBDF7, 0xAD75, 0x9CF3, 0x9492, 0x8410, 0x6B6D, 0x630C, 0x52AA,   // 0x17F0 (6128)
0x4A49, 0x39E7, 0x3186, 0x2945, 0x2124, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082,   // 0x1800 (6144)
0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x0861, 0x0841, 0x0841, 0x0861, 0x0861, 0x0861, 0x0861,   // 0x1810 (6160)
0x0861, 0x0841, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1820 (6176)
0x0000, 0x0000, 0x0000, 0x31A6, 0x632C, 0x738E, 0x8410, 0x7BEF, 0x7BCF, 0x9492, 0x9CD3, 0xA514, 0xAD75, 0xBDD7, 0xBDD7, 0xB5B6,   // 0x1830 (6192)
0xBDD7, 0xC618, 0xC638, 0xC638, 0xCE59, 0xD69A, 0xD69A, 0xD69A, 0xD6BA, 0xD6BA, 0xDEFB, 0xDEFB, 0xDEDB, 0xDEFB, 0xDEFB, 0xDEDB,   // 0x1840 (6208)
0xD69A, 0xCE59, 0xD69A, 0xD6BA, 0xD69A, 0xCE79, 0xC638, 0xB596, 0xAD55, 0x9CF3, 0x9492, 0x8410, 0x738E, 0x632C, 0x52AA, 0x4228,   // 0x1850 (6224)
0x39C7, 0x3186, 0x2945, 0x2104, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082,   // 0x1860 (6240)
0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841,   // 0x1870 (6256)
0x0841, 0x0861, 0x0861, 0x0841, 0x0861, 0x0841, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1880 (6272)
0x0000, 0x0000, 0x18E3, 0x5AEB, 0x6B6D, 0x7BEF, 0x7BEF, 0x7BCF, 0x8C51, 0x94B2, 0x9CF3, 0xAD55, 0xB596, 0xB596, 0xB596, 0xB5B6,   // 0x1890 (6288)
0xC618, 0xC638, 0xC638, 0xCE59, 0xD69A, 0xD6BA, 0xD6BA, 0xDEDB, 0xDEDB, 0xDEFB, 0xDEFB, 0xDEDB, 0xDEFB, 0xE73C, 0xE73C, 0xDEFB,   // 0x18A0 (6304)
0xD6BA, 0xD6BA, 0xD6BA, 0xD69A, 0xCE79, 0xC638, 0xB5B6, 0xAD75, 0xA514, 0x9492, 0x8430, 0x73AE, 0x632C, 0x52AA, 0x4A49, 0x39C7,   // 0x18B0 (6320)
0x2965, 0x2945, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x1082, 0x1082, 0x1082,   // 0x18C0 (6336)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020,   // 0x18D0 (6352)
0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x18E0 (6368)
0x0000, 0x0841, 0x4A49, 0x6B4D, 0x7BCF, 0x8410, 0x7BEF, 0x8430, 0x94B2, 0x9CF3, 0xA534, 0xAD75, 0xB596, 0xB5B6, 0xB5B6, 0xC618,   // 0x18F0 (6384)
0xCE59, 0xC638, 0xCE59, 0xD69A, 0xCE79, 0xCE79, 0xD69A, 0xDEDB, 0xDEDB, 0xDEDB, 0xDEFB, 0xDEFB, 0xE73C, 0xE73C, 0xE71C, 0xDEFB,   // 0x1900 (6400)
0xD69A, 0xD69A, 0xD69A, 0xCE79, 0xCE59, 0xBDD7, 0xB596, 0xAD55, 0x9CF3, 0x8C51, 0x73AE, 0x632C, 0x5ACB, 0x4A49, 0x39E7, 0x3186,   // 0x1910 (6416)
0x2945, 0x2124, 0x2104, 0x18E3, 0x18E3, 0x18C3, 0x18E3, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2,   // 0x1920 (6432)
0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0841, 0x0861,   // 0x1930 (6448)
0x0861, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1940 (6464)
0x0000, 0x2945, 0x632C, 0x73AE, 0x8430, 0x8410, 0x8410, 0x9492, 0x9CD3, 0xA514, 0xAD55, 0xAD55, 0xB596, 0xBDD7, 0xBDF7, 0xC618,   // 0x1950 (6480)
0xCE59, 0xD69A, 0xCE79, 0xCE59, 0xCE79, 0xCE79, 0xD69A, 0xD6BA, 0xDEDB, 0xDEFB, 0xDEFB, 0xDEFB, 0xDEDB, 0xD6BA, 0xD6BA, 0xCE79,   // 0x1960 (6496)
0xCE79, 0xCE79, 0xCE59, 0xC638, 0xBDD7, 0xB596, 0xAD75, 0xA514, 0x8C51, 0x7BCF, 0x632C, 0x5ACB, 0x4A49, 0x39E7, 0x3186, 0x2945,   // 0x1970 (6512)
0x2124, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2,   // 0x1980 (6528)
0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0841, 0x0841, 0x0841,   // 0x1990 (6544)
0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x19A0 (6560)
0x0841, 0x4A69, 0x738E, 0x7BEF, 0x8410, 0x8430, 0x8C71, 0x94B2, 0x9CF3, 0xA534, 0xA534, 0xB596, 0xBDD7, 0xB5B6, 0xBDD7, 0xC638,   // 0x19B0 (6576)
0xD69A, 0xCE79, 0xCE59, 0xDEDB, 0xDEDB, 0xCE79, 0xD69A, 0xDEDB, 0xDEDB, 0xDEDB, 0xDEDB, 0xD6BA, 0xD69A, 0xD69A, 0xD69A, 0xD69A,   // 0x19C0 (6592)
0xD69A, 0xCE59, 0xC638, 0xBDD7, 0xB596, 0xAD55, 0x9CF3, 0x8C51, 0x7BCF, 0x6B4D, 0x5ACB, 0x4A49, 0x39C7, 0x3186, 0x2945, 0x2104,   // 0x19D0 (6608)
0x2104, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x10A2,   // 0x19E0 (6624)
0x10A2, 0x1082, 0x1082, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0841, 0x0841,   // 0x19F0 (6640)
0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1A00 (6656)
0x2945, 0x632C, 0x73AE, 0x8410, 0x8C71, 0x94B2, 0x94B2, 0x9CD3, 0xA514, 0xA534, 0xB596, 0xB5B6, 0xBDD7, 0xBDF7, 0xC638, 0xCE79,   // 0x1A10 (6672)
0xCE59, 0xCE59, 0xD69A, 0xD6BA, 0xCE79, 0xD69A, 0xD6BA, 0xDEDB, 0xDEDB, 0xDEDB, 0xD6BA, 0xD69A, 0xD69A, 0xD69A, 0xD6BA, 0xCE79,   // 0x1A20 (6688)
0xCE59, 0xBDF7, 0xB5B6, 0xAD75, 0xA514, 0x94B2, 0x8430, 0x73AE, 0x632C, 0x52AA, 0x4228, 0x39C7, 0x2965, 0x2945, 0x2104, 0x2104,   // 0x1A30 (6704)
0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x18C3, 0x18C3,   // 0x1A40 (6720)
0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0841, 0x0020, 0x0020,   // 0x1A50 (6736)
0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841,   // 0x1A60 (6752)
0x4228, 0x738E, 0x7BCF, 0x8410, 0x8C71, 0x8C71, 0x9492, 0x9CD3, 0xA534, 0xAD75, 0xB5B6, 0xBDF7, 0xC618, 0xC618, 0xCE59, 0xCE79,   // 0x1A70 (6768)
0xCE59, 0xC638, 0xCE59, 0xCE59, 0xD69A, 0xD6BA, 0xDEDB, 0xDEDB, 0xD6BA, 0xD6BA, 0xD69A, 0xD69A, 0xCE79, 0xD69A, 0xCE59, 0xC638,   // 0x1A80 (6784)
0xBDF7, 0xB5B6, 0xAD55, 0x9CF3, 0x9492, 0x8410, 0x738E, 0x630C, 0x528A, 0x4228, 0x31A6, 0x2965, 0x2945, 0x2104, 0x2104, 0x18E3,   // 0x1A90 (6800)
0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082,   // 0x1AA0 (6816)
0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020,   // 0x1AB0 (6832)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x2104,   // 0x1AC0 (6848)
0x5AEB, 0x738E, 0x7BEF, 0x8430, 0x8C51, 0x8C71, 0x94B2, 0xA534, 0xB596, 0xB5B6, 0xB5B6, 0xB5B6, 0xBDF7, 0xCE59, 0xCE79, 0xCE79,   // 0x1AD0 (6864)
0xCE59, 0xCE59, 0xCE79, 0xCE79, 0xD69A, 0xD6BA, 0xD6BA, 0xD69A, 0xD6BA, 0xD6BA, 0xD69A, 0xCE79, 0xCE79, 0xC638, 0xC618, 0xBDF7,   // 0x1AE0 (6880)
0xB5B6, 0xAD55, 0x9CF3, 0x8C71, 0x8410, 0x738E, 0x630C, 0x528A, 0x4228, 0x31A6, 0x2965, 0x2945, 0x2104, 0x18E3, 0x18E3, 0x18C3,   // 0x1AF0 (6896)
0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x1082,   // 0x1B00 (6912)
0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000,   // 0x1B10 (6928)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x39E7,   // 0x1B20 (6944)
0x6B6D, 0x73AE, 0x7BEF, 0x8C51, 0x8C71, 0x9CD3, 0xA534, 0xA534, 0xAD55, 0xAD75, 0xB5B6, 0xC618, 0xCE59, 0xCE59, 0xCE79, 0xCE79,   // 0x1B30 (6960)
0xCE59, 0xCE79, 0xCE79, 0xCE79, 0xD69A, 0xD69A, 0xCE79, 0xD69A, 0xD69A, 0xD69A, 0xCE79, 0xC638, 0xC638, 0xCE59, 0xBDF7, 0xB5B6,   // 0x1B40 (6976)
0xAD75, 0xA514, 0x9492, 0x8410, 0x738E, 0x630C, 0x528A, 0x4228, 0x39C7, 0x2965, 0x2945, 0x2104, 0x18E3, 0x18E3, 0x18C3, 0x18C3,   // 0x1B50 (6992)
0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0841,   // 0x1B60 (7008)
0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000,   // 0x1B70 (7024)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1082, 0x528A,   // 0x1B80 (7040)
0x738E, 0x7BEF, 0x8410, 0x8C51, 0x9492, 0x9CD3, 0x9CF3, 0xA534, 0xB596, 0xB5B6, 0xBDF7, 0xC638, 0xCE59, 0xCE59, 0xC638, 0xCE59,   // 0x1B90 (7056)
0xCE79, 0xCE79, 0xCE79, 0xCE59, 0xCE79, 0xD69A, 0xD69A, 0xCE59, 0xCE59, 0xCE59, 0xC638, 0xC638, 0xC638, 0xBDF7, 0xB5B6, 0xAD75,   // 0x1BA0 (7072)
0xA534, 0x9492, 0x8430, 0x73AE, 0x632C, 0x52AA, 0x4A49, 0x39E7, 0x2965, 0x2945, 0x2124, 0x2104, 0x18E3, 0x18E3, 0x18C3, 0x18C3,   // 0x1BB0 (7088)
0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x1082, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0841, 0x0020,   // 0x1BC0 (7104)
0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1BD0 (7120)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x2104, 0x632C,   // 0x1BE0 (7136)
0x73AE, 0x7BCF, 0x8410, 0x8C51, 0x94B2, 0x9CD3, 0xA534, 0xAD75, 0xB5B6, 0xBDD7, 0xBDD7, 0xC618, 0xC638, 0xC618, 0xCE59, 0xD69A,   // 0x1BF0 (7152)
0xD69A, 0xCE79, 0xCE79, 0xD69A, 0xCE79, 0xCE79, 0xCE79, 0xCE59, 0xCE59, 0xC638, 0xBDF7, 0xBDF7, 0xBDD7, 0xB596, 0xAD55, 0xA514,   // 0x1C00 (7168)
0x94B2, 0x8C51, 0x7BCF, 0x632C, 0x52AA, 0x4228, 0x39C7, 0x3186, 0x2945, 0x2124, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x10A2,   // 0x1C10 (7184)
0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020,   // 0x1C20 (7200)
0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1C30 (7216)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x39C7, 0x6B6D,   // 0x1C40 (7232)
0x738E, 0x7BCF, 0x8410, 0x8C71, 0x94B2, 0x9CD3, 0xAD55, 0xB5B6, 0xB5B6, 0xB596, 0xB5B6, 0xBDF7, 0xC618, 0xC618, 0xC638, 0xCE59,   // 0x1C50 (7248)
0xCE79, 0xCE59, 0xCE79, 0xCE59, 0xC638, 0xCE79, 0xCE79, 0xCE59, 0xC618, 0xBDF7, 0xB5B6, 0xB5B6, 0xAD55, 0xA514, 0x94B2, 0x9492,   // 0x1C60 (7264)
0x8410, 0x73AE, 0x630C, 0x528A, 0x4228, 0x31A6, 0x3186, 0x2945, 0x2104, 0x18E3, 0x18E3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082,   // 0x1C70 (7280)
0x1082, 0x0861, 0x0861, 0x0861, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x1C80 (7296)
0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1C90 (7312)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x4228, 0x6B6D,   // 0x1CA0 (7328)
0x738E, 0x7BCF, 0x8430, 0x9492, 0x94B2, 0xA514, 0xAD75, 0xAD75, 0xB596, 0xB596, 0xB5B6, 0xBDF7, 0xC618, 0xC618, 0xBDD7, 0xCE59,   // 0x1CB0 (7344)
0xCE59, 0xCE59, 0xC638, 0xC618, 0xC638, 0xC638, 0xC618, 0xBDF7, 0xBDF7, 0xBDD7, 0xB596, 0xAD75, 0xAD75, 0x9CF3, 0x8C51, 0x7BEF,   // 0x1CC0 (7360)
0x738E, 0x630C, 0x528A, 0x4228, 0x39C7, 0x2965, 0x2124, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2,   // 0x1CD0 (7376)
0x1082, 0x0861, 0x1082, 0x10A2, 0x1082, 0x0861, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x1CE0 (7392)
0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1CF0 (7408)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0861, 0x4A69, 0x6B6D,   // 0x1D00 (7424)
0x73AE, 0x7BCF, 0x8C51, 0x94B2, 0xA514, 0xA534, 0xAD75, 0xAD75, 0xB5B6, 0xB5B6, 0xB5B6, 0xBDD7, 0xB5B6, 0xBDF7, 0xC638, 0xCE59,   // 0x1D10 (7440)
0xC638, 0xC638, 0xC618, 0xBDF7, 0xBDD7, 0xBDD7, 0xBDD7, 0xBDF7, 0xC618, 0xBDD7, 0xB596, 0xAD55, 0x9CD3, 0x8C51, 0x7BCF, 0x6B6D,   // 0x1D20 (7456)
0x5AEB, 0x4A69, 0x4228, 0x39C7, 0x2965, 0x2124, 0x2104, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x10A2, 0x1082,   // 0x1D30 (7472)
0x1082, 0x0861, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x1D40 (7488)
0x0841, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1D50 (7504)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x10A2, 0x4A69, 0x6B6D,   // 0x1D60 (7520)
0x738E, 0x7BCF, 0x8C51, 0x9CD3, 0x9CF3, 0xA534, 0xAD55, 0xAD55, 0xAD75, 0xB596, 0xB596, 0xB596, 0xBDF7, 0xC618, 0xBDF7, 0xBDF7,   // 0x1D70 (7536)
0xBDF7, 0xBDF7, 0xBDD7, 0xB5B6, 0xB596, 0xB596, 0xBDD7, 0xC618, 0xB5B6, 0xAD55, 0xA534, 0x9CD3, 0x8C51, 0x7BCF, 0x6B6D, 0x5AEB,   // 0x1D80 (7552)
0x4A69, 0x4208, 0x31A6, 0x2965, 0x2124, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x1D90 (7568)
0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020,   // 0x1DA0 (7584)
0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1DB0 (7600)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x18C3, 0x528A, 0x6B4D,   // 0x1DC0 (7616)
0x738E, 0x8410, 0x8C51, 0x9492, 0x9CD3, 0x9CF3, 0x9CD3, 0xA514, 0xA534, 0xAD55, 0xB596, 0xB596, 0xB596, 0xB5B6, 0xB5B6, 0xB5B6,   // 0x1DD0 (7632)
0xBDF7, 0xBDF7, 0xBDD7, 0xAD75, 0xAD75, 0xB596, 0xB596, 0xAD75, 0xAD55, 0xA534, 0x9CD3, 0x8C71, 0x7BCF, 0x632C, 0x5ACB, 0x4A69,   // 0x1DE0 (7648)
0x4208, 0x31A6, 0x2945, 0x2124, 0x2104, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082,   // 0x1DF0 (7664)
0x1082, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020,   // 0x1E00 (7680)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1E10 (7696)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x18E3, 0x528A, 0x738E,   // 0x1E20 (7712)
0x73AE, 0x7BEF, 0x8C51, 0x9492, 0x9492, 0x94B2, 0x9CD3, 0x9CD3, 0xA514, 0xA534, 0xAD55, 0xAD75, 0xAD75, 0xAD75, 0xB596, 0xB596,   // 0x1E30 (7728)
0xB5B6, 0xB5B6, 0xB596, 0xAD75, 0xAD75, 0xAD55, 0xA534, 0xAD55, 0xA534, 0x9CD3, 0x8C51, 0x7BEF, 0x6B6D, 0x5ACB, 0x4A49, 0x39E7,   // 0x1E40 (7744)
0x31A6, 0x2945, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082,   // 0x1E50 (7760)
0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000,   // 0x1E60 (7776)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1E70 (7792)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x18C3, 0x528A, 0x738E,   // 0x1E80 (7808)
0x7BCF, 0x7BEF, 0x8410, 0x8C51, 0x8C71, 0x94B2, 0x9CD3, 0x9CF3, 0x9CF3, 0xA534, 0xAD75, 0xA534, 0xA534, 0xAD55, 0xAD55, 0xAD55,   // 0x1E90 (7824)
0xAD75, 0xB596, 0xAD75, 0xAD55, 0xA534, 0xA534, 0xA514, 0x9CF3, 0x9492, 0x8410, 0x7BCF, 0x6B6D, 0x5ACB, 0x4A69, 0x39E7, 0x3186,   // 0x1EA0 (7840)
0x2945, 0x2104, 0x18E3, 0x18C3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861,   // 0x1EB0 (7856)
0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1EC0 (7872)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1ED0 (7888)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x18C3, 0x4A69, 0x6B4D,   // 0x1EE0 (7904)
0x738E, 0x7BCF, 0x7BEF, 0x8430, 0x8C71, 0x9492, 0x9492, 0x94B2, 0x9CF3, 0xA534, 0xA514, 0xA514, 0xA514, 0xA534, 0xAD55, 0xAD55,   // 0x1EF0 (7920)
0xAD55, 0xAD55, 0xAD55, 0xA514, 0x9CF3, 0x9CD3, 0x94B2, 0x8C51, 0x7BEF, 0x738E, 0x630C, 0x52AA, 0x4A49, 0x39E7, 0x3186, 0x2945,   // 0x1F00 (7936)
0x2104, 0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x10A2, 0x10A2, 0x1082, 0x1082, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861,   // 0x1F10 (7952)
0x0861, 0x0841, 0x0861, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1F20 (7968)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1F30 (7984)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1082, 0x4208, 0x632C,   // 0x1F40 (8000)
0x738E, 0x73AE, 0x7BEF, 0x8410, 0x8430, 0x8C51, 0x8C71, 0x94B2, 0x9CD3, 0x9CF3, 0x9CF3, 0x9CF3, 0xA514, 0xA534, 0xA534, 0xA534,   // 0x1F50 (8016)
0xA534, 0xA514, 0x9CF3, 0x9CD3, 0x9CD3, 0x94B2, 0x8C71, 0x7BEF, 0x6B6D, 0x630C, 0x5ACB, 0x4A49, 0x39E7, 0x3186, 0x2945, 0x2104,   // 0x1F60 (8032)
0x18E3, 0x18C3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841,   // 0x1F70 (8048)
0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1F80 (8064)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1F90 (8080)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x3186, 0x630C,   // 0x1FA0 (8096)
0x73AE, 0x73AE, 0x7BCF, 0x7BCF, 0x8430, 0x8C51, 0x8C71, 0x8C71, 0x9492, 0x94B2, 0x94B2, 0x9CD3, 0x9CD3, 0x9CF3, 0x9CF3, 0x9CF3,   // 0x1FB0 (8112)
0x9CF3, 0x9CD3, 0x94B2, 0x94B2, 0x9492, 0x8C71, 0x8410, 0x6B6D, 0x630C, 0x52AA, 0x4A49, 0x39E7, 0x3186, 0x2945, 0x2104, 0x18E3,   // 0x1FC0 (8128)
0x18C3, 0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841,   // 0x1FD0 (8144)
0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1FE0 (8160)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1FF0 (8176)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x18E3, 0x4A69,   // 0x2000 (8192)
0x6B6D, 0x738E, 0x7BCF, 0x7BEF, 0x7BEF, 0x8410, 0x8430, 0x8430, 0x8C51, 0x8C71, 0x9492, 0x9492, 0x94B2, 0x94B2, 0x94B2, 0x94B2,   // 0x2010 (8208)
0x94B2, 0x94B2, 0x8C51, 0x8430, 0x8430, 0x7BEF, 0x6B6D, 0x5AEB, 0x528A, 0x4228, 0x39C7, 0x2965, 0x2124, 0x18E3, 0x18C3, 0x10A2,   // 0x2020 (8224)
0x10A2, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0020, 0x0020,   // 0x2030 (8240)
0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2040 (8256)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2050 (8272)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0841, 0x31A6,   // 0x2060 (8288)
0x5AEB, 0x738E, 0x738E, 0x73AE, 0x7BCF, 0x7BCF, 0x7BEF, 0x8410, 0x8430, 0x8430, 0x8430, 0x8C51, 0x8C51, 0x8C71, 0x8C71, 0x8C71,   // 0x2070 (8304)
0x8C71, 0x8C51, 0x8410, 0x7BEF, 0x7BCF, 0x6B4D, 0x5AEB, 0x4A69, 0x4208, 0x31A6, 0x2965, 0x2124, 0x18E3, 0x18C3, 0x10A2, 0x1082,   // 0x2080 (8320)
0x1082, 0x1082, 0x1082, 0x1082, 0x1082, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020,   // 0x2090 (8336)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x20A0 (8352)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x20B0 (8368)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x18C3,   // 0x20C0 (8384)
0x4228, 0x632C, 0x738E, 0x738E, 0x73AE, 0x73AE, 0x7BCF, 0x7BCF, 0x7BEF, 0x7BEF, 0x8410, 0x8430, 0x8430, 0x8430, 0x8C51, 0x8C51,   // 0x20D0 (8400)
0x8410, 0x7BEF, 0x73AE, 0x6B6D, 0x632C, 0x5AEB, 0x4A69, 0x4208, 0x31A6, 0x2945, 0x2104, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x1082,   // 0x20E0 (8416)
0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000,   // 0x20F0 (8432)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2100 (8448)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2110 (8464)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020,   // 0x2120 (8480)
0x2104, 0x4A49, 0x630C, 0x6B6D, 0x6B6D, 0x6B6D, 0x738E, 0x73AE, 0x73AE, 0x73AE, 0x7BCF, 0x7BCF, 0x7BCF, 0x7BEF, 0x7BCF, 0x73AE,   // 0x2130 (8496)
0x73AE, 0x6B6D, 0x632C, 0x5AEB, 0x528A, 0x4228, 0x39E7, 0x3186, 0x2124, 0x18E3, 0x18C3, 0x10A2, 0x1082, 0x1082, 0x0861, 0x0861,   // 0x2140 (8512)
0x0861, 0x0861, 0x0841, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2150 (8528)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2160 (8544)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2170 (8560)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2180 (8576)
0x0841, 0x2104, 0x4228, 0x5AEB, 0x632C, 0x6B4D, 0x6B4D, 0x6B6D, 0x6B6D, 0x738E, 0x738E, 0x6B6D, 0x6B6D, 0x6B6D, 0x6B4D, 0x6B4D,   // 0x2190 (8592)
0x632C, 0x5ACB, 0x528A, 0x4228, 0x39C7, 0x3186, 0x2945, 0x2104, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841,   // 0x21A0 (8608)
0x0841, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x21B0 (8624)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x21C0 (8640)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x21D0 (8656)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x21E0 (8672)
0x0000, 0x0841, 0x18E3, 0x3186, 0x4A69, 0x5ACB, 0x630C, 0x6B4D, 0x6B4D, 0x6B4D, 0x632C, 0x632C, 0x632C, 0x630C, 0x5AEB, 0x5ACB,   // 0x21F0 (8688)
0x4A69, 0x4228, 0x39E7, 0x31A6, 0x2965, 0x2104, 0x18E3, 0x18C3, 0x1082, 0x0861, 0x0861, 0x0841, 0x0841, 0x0841, 0x0841, 0x0020,   // 0x2200 (8704)
0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2210 (8720)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2220 (8736)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2230 (8752)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2240 (8768)
0x0000, 0x0000, 0x0000, 0x0861, 0x2104, 0x31A6, 0x4A49, 0x52AA, 0x5AEB, 0x630C, 0x5AEB, 0x5AEB, 0x5ACB, 0x52AA, 0x4A69, 0x4228,   // 0x2250 (8784)
0x39E7, 0x39C7, 0x31A6, 0x2945, 0x2104, 0x18C3, 0x10A2, 0x1082, 0x0861, 0x0841, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020,   // 0x2260 (8800)
0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2270 (8816)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2280 (8832)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2290 (8848)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22A0 (8864)
0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x0841, 0x18C3, 0x2945, 0x31A6, 0x39E7, 0x4228, 0x4A49, 0x4A49, 0x4A49, 0x4208, 0x39C7,   // 0x22B0 (8880)
0x3186, 0x2945, 0x2104, 0x18E3, 0x10A2, 0x1082, 0x0861, 0x0841, 0x0841, 0x0020, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000,   // 0x22C0 (8896)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22D0 (8912)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22E0 (8928)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x22F0 (8944)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2300 (8960)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0020, 0x1082, 0x10A2, 0x18C3, 0x2104, 0x2104, 0x18E3, 0x18C3,   // 0x2310 (8976)
0x10A2, 0x1082, 0x0861, 0x0841, 0x0020, 0x0020, 0x0020, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2320 (8992)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2330 (9008)
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2340 (9024)
0x0000, };
