As the title says for my project I built the love-o-meter but I want to know if its possible to program the crystal display board that comes with the arduino starter kit with the temp sensor. So when making the love o meter as soon as you touch it, the detected temperature shows up on the display. Can someone tell me if this is possible and how with the code and circuit build?
Also I tried this program and an error shows up can someone tell me how to fix this?
*Also attached is the error message we receive when we try to upload the program to the Arduino circuit.
Arduino Starter Kit example
Project 11 - Crystal Ball
This sketch is written to accompany Project 11 in the
Arduino Starter Kit
Parts required:
220 ohm resistor
10 kilohm resistor
10 kilohm potentiometer
16x2 LCD screen
tilt switch
Created 13 September 2012
by Scott Fitzgerald
http://www.arduino.cc/starterKit
This example code is part of the public domain
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// set up a constant for the tilt switchPin
const int switchPin = 6;
// variable to hold the value of the switchPin
int switchState = 0;
// variable to hold previous value of the switchpin
int prevSwitchState = 0;
// a variable to choose which reply from the crystal ball
int reply;
// set up the number of columns and rows on the LCD
lcd.begin(16, 2);
// set up the switch pin as an input
pinMode(switchPin, INPUT);
// Print a message to the LCD.
lcd.print("Ask the");
// set the cursor to column 0, line 1
// line 1 is the second row, since counting begins with 0
lcd.setCursor(0, 1);
// print to the second line
lcd.print("Crystal Ball!");
// check the status of the switch
switchState = digitalRead(switchPin);
// compare the switchState to its previous state
if (switchState != prevSwitchState) {
// if the state has changed from HIGH to LOW
// you know that the ball has been tilted from
// one direction to the other
if (switchState == LOW) {
// randomly chose a reply
reply = random(8);
// clean up the screen before printing a new reply
lcd.clear();
// set the cursor to column 0, line 0
lcd.setCursor(0, 0);
// print some text
lcd.print("the ball says:");
// move the cursor to the second line
// choose a saying to print baed on the value in reply
switch (reply) {
case 0:
lcd.print("Yes");
case 1:
lcd.print("Most likely");
case 2:
lcd.print("Certainly");
case 3:
lcd.print("Outlook good");
case 4:
lcd.print("Unsure");
case 5:
lcd.print("Ask again");
case 6:
lcd.print("Doubtful");
case 7:
lcd.print("No");
// save the current switch state as the last state
prevSwitchState = switchState;
Project 3 - Love-O-Meter
This sketch is written to accompany Project 3 in the
Arduino Starter Kit
Parts required:
1 TMP36 temperature sensor
3 red LEDs
3 220 ohm resistors
by Scott Fitzgerald
// named constant for the pin the sensor is connected to
const int sensorPin = A0;
// room temperature in Celcius
const float baselineTemp = 23.0;
#define SENSOR 0 // select the input pin for
// the LM335A temperature sensor
// open a serial connection to display values
// set the LED pins as outputs
// the for() loop saves some extra coding
for (int pinNumber = 2; pinNumber < 5; pinNumber++) {
pinMode(pinNumber, OUTPUT);
digitalWrite(pinNumber, LOW);
// read the value on AnalogIn pin 0
// and store it in a variable
int sensorVal = analogRead(sensorPin);
// send the 10-bit sensor value out the serial port
Serial.print("sensor Value: ");
Serial.print(sensorVal);
// convert the ADC reading to voltage
float voltage = (sensorVal / 1024.0) * 5.0;
// Send the voltage level out the Serial port
Serial.print(", Volts: ");
Serial.print(voltage);
// convert the voltage to temperature in degrees C
// the sensor changes 10 mV per degree
// the datasheet says there's a 500 mV offset
// ((volatge - 500mV) times 100)
Serial.print(", degrees C: ");
float temperature = (voltage - .5) * 100;
Serial.println(temperature);
// if the current temperature is lower than the baseline
// turn off all LEDs
if (temperature < baselineTemp + 2) {
digitalWrite(8, LOW);
digitalWrite(9, LOW);
digitalWrite(10, LOW);
} // if the temperature rises 2-4 degrees, turn an LED on
else if (temperature >= baselineTemp + 2 && temperature < baselineTemp + 4) {
digitalWrite(8, HIGH);
} // if the temperature rises 4-6 degrees, turn a second LED on
else if (temperature >= baselineTemp + 4 && temperature < baselineTemp + 6) {
digitalWrite(9, HIGH);
} // if the temperature rises more than 6 degrees, turn all LEDs on
else if (temperature >= baselineTemp + 6) {
digitalWrite(10, HIGH);
