Hello Guys!
I've just bought the Arduino Nano (3.3 version), I'm a rookie in this field so I thought to try out my new board with an example from the just-downloaded Arduino IDE: "Blink".
My procedure:
connect the Nano to the computer (OS: Windows XP) via Mini Usb cable
Verify and compile the example, with no modify from the original sketch from the one already present in the IDE.
Try to load it in the Nano but... ERROR! I couldn't make this board work
Tried to change the usb cable but nothing different...
Tried to erase the line with the comment "//for Leonardo Only" (where the programme waits for the serial to be ready) but nothing...
This is the message from the IDE (which tries 10 times to establish a "contact" with the board)
C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp\wiring_analog.c.o C:\Programmi\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp/core.a C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp\wiring_digital.c.o C:\Programmi\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp/core.a C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp\wiring_pulse.c.o C:\Programmi\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp/core.a C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp\wiring_shift.c.o C:\Programmi\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp/core.a C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp\abi.cpp.o C:\Programmi\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp/core.a C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp\CDC.cpp.o C:\Programmi\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp/core.a C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp\HardwareSerial.cpp.o C:\Programmi\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp/core.a C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp\HardwareSerial0.cpp.o C:\Programmi\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp/core.a C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp\HardwareSerial1.cpp.o C:\Programmi\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp/core.a C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp\HardwareSerial2.cpp.o C:\Programmi\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp/core.a C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp\HardwareSerial3.cpp.o C:\Programmi\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp/core.a C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp\HID.cpp.o C:\Programmi\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp/core.a C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp\IPAddress.cpp.o C:\Programmi\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp/core.a C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp\main.cpp.o C:\Programmi\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp/core.a C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp\new.cpp.o C:\Programmi\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp/core.a C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp\Print.cpp.o C:\Programmi\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp/core.a C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp\Stream.cpp.o C:\Programmi\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp/core.a C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp\Tone.cpp.o C:\Programmi\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp/core.a C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp\USBCore.cpp.o C:\Programmi\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp/core.a C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp\WMath.cpp.o C:\Programmi\Arduino\hardware\tools\avr/bin/avr-ar rcs C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp/core.a C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp\WString.cpp.o C:\Programmi\Arduino\hardware\tools\avr/bin/avr-gcc -w -Os -Wl,--gc-sections -mmcu=atmega328p -o C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp/Blink.cpp.elf C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp\Blink.cpp.o C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp/core.a -LC:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp -lm C:\Programmi\Arduino\hardware\tools\avr/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp/Blink.cpp.elf C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp/Blink.cpp.eep C:\Programmi\Arduino\hardware\tools\avr/bin/avr-objcopy -O ihex -R .eeprom C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp/Blink.cpp.elf C:\DOCUME~1\Robotics\IMPOST~1\Temp\build6541470071766323829.tmp/Blink.cpp.hex Lo sketch usa 1.030 byte (3%) dello spazio disponibile per i programmi. Il massimo è 30.720 byte. Le variabili globali usano 9 byte (0%) di memoria dinamica, lasciando altri 2.039 byte liberi per le variabili locali. Il massimo è 2.048 byte. avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x60 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x60 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x60 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x60 avrdude: stk500_recv(): programmer is not responding Problema di caricamento sulla scheda. Guarda http://www.arduino.cc/en/Guide/Troubleshooting#upload per suggerimenti avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x60 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x60 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x60 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x60 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x60 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x60
Probably you have a nano "clone" that has a different USB/Serial chip, and you need to install the driver (which is NOT included with the arduino IDE.) Search for "ch340g" to find info...
I tried to download these drivers, set-up is OK, but when I try to load the sketch on the Nano the same problem represent... I don't know what to do now...
There will be a black chip near the usb connector (not the mega328 in the middle, the other big chip. Often it's on the bottom). Read the part number off it.
If it's CH340G, download the driver linked above (it works for CH340/341) and install it (the installer doesn't inspire confidence, but it does work)
If it's an FTDI232, get the FTDI drivers from FTDI's website (though these come with Arduino, I think... they were what the real nano used)
Nano clones are very common and inexpensive, and they're a great low cost arduino option - just gotta use the right driver for the serial adapter on them.
I tried to install both CH341 and FTDI232 drivers but no thing was working at the beginning.
Then I checked the drivers installed on my pc and found that FT232R USB UART (for the virtual port, I suppose) driver was required. Downloaded and installed it...
Up to now it seems working!
