So that worked.
Well, you could try to download a new bootloader but you would either need a programmer or another Arduino to do so. So you might as well just buy a new Uno
okayyy thank youuu. I guess I should buy a new one haha
uhm may I ask what is the possible cause for this issue?
Be carful.
Don't use it on a metal surface. Even a paper clip can short it out
Don't connect/disconnect things while the power is on
Static electricity can also damage the board.
It's usually best to power high current devices with a separate power supply.
okayy thanks for the info
I have the same problem with a UNO R3, I have tried to disconnect, note the USB ports, reupload, but the problem remains.
I do not believe it is a Bootloader problem because I have tried with another board, Arduino NANO, and the problem remains the same (whatever the choice pf the processor is: normal or "Old bootloader").
Here is the compilation error reort in Verbose mode with the UNO R3:
Le croquis utilise 5814 octets (18%) de l'espace de stockage de programmes. Le maximum est de 32256 octets.
Les variables globales utilisent 667 octets (32%) de mémoire dynamique, ce qui laisse 1381 octets pour les variables locales. Le maximum est de 2048 octets.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM1 -b115200 -D -Uflash:w:C:\Users\ordic\AppData\Local\Temp\arduino_build_100444/Code_Tuto_10.4.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM1
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xcf
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xcf
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xcf
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xcf
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xcf
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xcf
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xcf
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xcf
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xcf
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xcf
avrdude done. Thank you.
Problem uploading to board. See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
and here is the upload error report in Verbose mode for the NANO board:
Le croquis utilise 5814 octets (18%) de l'espace de stockage de programmes. Le maximum est de 30720 octets.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM1 -b57600 -D -Uflash:w:C:\Users\ordic\AppData\Local\Temp\arduino_build_951483/Code_Tuto_10.4.ino.hex:i
Using Port : COM1
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x46
I believe that the problem is something else than the Bootloader: maybe the version of the CH340 driver ?
Any solution ?
Thank you
The Uno R3 does not use a CH340.
Did you try the bootloader test?
Did you try the loopback test?
See your topic on the same problem
hello I already use another arduino but it still doesn't work. is this possible that my laptop usb port is the problem?
If you did the loopback test exactly as explained in the link in post #19 then the port is OK, otherwise the test would have failed
Are you sure you have the right board selected.
Does the LED on the board blink a few times (around 3) when you push the reset button?
