When it try uploading a file to my new elegoo arduino nano i get the following error:
Using Port : COM8
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xfb
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xfb
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xfb
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xfb
avrdude: ser_recv(): read error: Access is denied.
I have tried looking at other guides but am unsure what to do any advice would be appreciated.
@sterretje When I use the ATmega328p processor I get the following error message.
c:/users/joery/appdata/local/arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/../lib/gcc/avr/7.3.0/../../../../avr/lib/avr5/crtatmega328p.o:(.init9+0x0): undefined reference to `main'
collect2.exe: error: ld returned 1 exit status
There should be no difference between 'old bootloader' and '328P' when it comes to that error; the only difference is in the upload, not the compiling/linking.
Please enable verbose output during compilation in file / preferences. Compile the blink example with the 'old bootloader' setting and post the results here. Next compile with the '328P' setting and post the result here as well.
Blink
Turns an LED on for one second, then off for one second, repeatedly.
Most Arduinos have an on-board LED you can control. On the UNO, MEGA and ZERO
it is attached to digital pin 13, on MKR1000 on pin 6. LED_BUILTIN is set to
the correct LED pin independent of which board is used.
If you want to know what pin the on-board LED is connected to on your Arduino
model, check the Technical Specs of your board at:
https://www.arduino.cc/en/Main/Products
modified 8 May 2014
by Scott Fitzgerald
modified 2 Sep 2016
by Arturo Guadalupi
modified 8 Sep 2016
by Colby Newman
This example code is in the public domain.
https://www.arduino.cc/en/Tutorial/BuiltInExamples/Blink
// the setup function runs once when you press reset or power the board
// initialize digital pin LED_BUILTIN as an output.
pinMode(LED_BUILTIN, OUTPUT);
// the loop function runs over and over again forever
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
This is the result when using the old bootloader option
FQBN: arduino:avr:nano:cpu=atmega328old
Using board 'nano' from platform in folder: C:\Users\joery\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\joery\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Detecting libraries used...
C:\Users\joery\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\joery\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\joery\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs C:\Users\joery\AppData\Local\Temp\arduino\sketches\A4EF6F4406D3E7BB3EED85664BF6E542\sketch\Blink.ino.cpp -o nul
Generating function prototypes...
C:\Users\joery\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\joery\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\joery\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs C:\Users\joery\AppData\Local\Temp\arduino\sketches\A4EF6F4406D3E7BB3EED85664BF6E542\sketch\Blink.ino.cpp -o C:\Users\joery\AppData\Local\Temp\2086058556\sketch_merged.cpp
C:\Users\joery\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\joery\AppData\Local\Temp\2086058556\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\joery\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\joery\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\joery\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\joery\\AppData\\Local\\Temp\\arduino\\sketches\\A4EF6F4406D3E7BB3EED85664BF6E542\\sketch\\Blink.ino.cpp" -o "C:\\Users\\joery\\AppData\\Local\\Temp\\arduino\\sketches\\A4EF6F4406D3E7BB3EED85664BF6E542\\sketch\\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\joery\AppData\Local\Temp\arduino\cores\arduino_avr_nano_cpu_atmega328old_a53ecebce414ae04cd0fe51c1bd30e9c\core.a
Linking everything together...
"C:\\Users\\joery\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\joery\\AppData\\Local\\Temp\\arduino\\sketches\\A4EF6F4406D3E7BB3EED85664BF6E542/Blink.ino.elf" "C:\\Users\\joery\\AppData\\Local\\Temp\\arduino\\sketches\\A4EF6F4406D3E7BB3EED85664BF6E542\\sketch\\Blink.ino.cpp.o" "C:\\Users\\joery\\AppData\\Local\\Temp\\arduino\\sketches\\A4EF6F4406D3E7BB3EED85664BF6E542/..\\..\\cores\\arduino_avr_nano_cpu_atmega328old_a53ecebce414ae04cd0fe51c1bd30e9c\\core.a" "-LC:\\Users\\joery\\AppData\\Local\\Temp\\arduino\\sketches\\A4EF6F4406D3E7BB3EED85664BF6E542" -lm
"C:\\Users\\joery\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\joery\\AppData\\Local\\Temp\\arduino\\sketches\\A4EF6F4406D3E7BB3EED85664BF6E542/Blink.ino.elf" "C:\\Users\\joery\\AppData\\Local\\Temp\\arduino\\sketches\\A4EF6F4406D3E7BB3EED85664BF6E542/Blink.ino.eep"
"C:\\Users\\joery\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\joery\\AppData\\Local\\Temp\\arduino\\sketches\\A4EF6F4406D3E7BB3EED85664BF6E542/Blink.ino.elf" "C:\\Users\\joery\\AppData\\Local\\Temp\\arduino\\sketches\\A4EF6F4406D3E7BB3EED85664BF6E542/Blink.ino.hex"
"C:\\Users\\joery\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\joery\\AppData\\Local\\Temp\\arduino\\sketches\\A4EF6F4406D3E7BB3EED85664BF6E542/Blink.ino.elf"
Sketch uses 924 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
"C:\Users\joery\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\joery\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega328p -carduino "-PCOM8" -b57600 -D "-Uflash:w:C:\Users\joery\AppData\Local\Temp\arduino\sketches\A4EF6F4406D3E7BB3EED85664BF6E542/Blink.ino.hex:i"
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\joery\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM8
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x2f
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x2f
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x2f
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x2f
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x2f
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x2f
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x2f
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x2f
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x2f
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x2f
avrdude done. Thank you.
Failed uploading: uploading error: exit status 1```
And here is the output when I use the newer bootloader option
I don't have access to a system with IDE2.x. From memory the directory 'C:\Users\joery\AppData\Local\Temp\arduino' contains two directories, cores and sketches. I would delete those 2 directories; or to play it safe, delete the content of each. Close the IDE first.
Next compile again with the '328P' option; post the output if you get the same error again.
