i got my fingers on some esp-01 modules and tried to programm them or let them communicatio with an nano.
problem is nothing works..
i wired up a breadboard to programm the esp directly for letting it connect to an Wlan or setting up an AP and delivering an single Webpage.
I've got an FTDI Converter (set to 3.3v) wired up like in the attached picture (10k resistor) and uploaded (esp was in programming mode) the AP Example of the Arduino IDE. Then a reset with 3.3v and GND, but nothing shown up in WiFi Listing.
Now i tried to let it communicate with an nano, wired itup like in the 2nd attachment (1k, and 2,2k Resistors) and tried this example code (replaced only ssid/pwd):
#include <SoftwareSerial.h>
char serialbuffer[1000];//serial buffer for request url
SoftwareSerial Serial1(0,1); // RX, TX
Serial1.begin(9600);//connection to ESP8266
Serial.begin(9600); //serial debug
//set mode needed for new boards
Serial1.println("AT+RST");
Serial1.println("AT+CWMODE=1");
delay(500);//delay after mode change
//connect to wifi network
Serial1.println("AT+CWJAP=\"SSID\",\"PWD\"");
//output everything from ESP8266 to the Arduino Micro Serial output
while (Serial1.available() > 0) {
Serial.write(Serial1.read());
if (Serial.available() > 0) {
//read from serial until terminating character
int len = Serial.readBytesUntil('\n', serialbuffer, sizeof(serialbuffer));
//trim buffer to length of the actual message
String message = String(serialbuffer).substring(0,len-1);
Serial.println("message: " + message);
//check to see if the incoming serial message is a url or an AT command
if(message.substring(0,2)=="AT"){
//make command request
Serial.println("COMMAND REQUEST");
Serial1.println(message);
}else{
//make webrequest
Serial.println("WEB REQUEST");
WebRequest(message);
//web request needs to be sent without the http for now, https still needs some working
void WebRequest(String request){
//find the dividing marker between domain and path
int slash = request.indexOf('/');
//grab the domain
String domain;
if(slash>0){
domain = request.substring(0,slash);
}else{
domain = request;
//get the path
String path;
if(slash>0){
path = request.substring(slash);
}else{
path = "/";
//output domain and path to verify
Serial.println("domain: |" + domain + "|");
Serial.println("path: |" + path + "|");
//create start command
String startcommand = "AT+CIPSTART=\"TCP\",\"" + domain + "\", 80"; //443 is HTTPS, still to do
Serial1.println(startcommand);
Serial.println(startcommand);
//test for a start error
if(Serial1.find("Error")){
Serial.println("error on start");
return;
//create the request command
String sendcommand = "GET http://"+ domain + path + " HTTP/1.0\r\n\r\n\r\n";//works for most cases
Serial.print(sendcommand);
//send
Serial1.print("AT+CIPSEND=");
Serial1.println(sendcommand.length());
//debug the command
Serial.print("AT+CIPSEND=");
Serial.println(sendcommand.length());
//delay(5000);
if(Serial1.find(">"))
Serial.println(">");
}else {
Serial1.println("AT+CIPCLOSE");
Serial.println("connect timeout");
delay(10000);
return;
//Serial.print(getcommand);
Serial1.print(sendcommand);
now i should when i connect to the serial monitor and send "AT" get a "OK", but i get no response... i tried with 9600 and 115200 rate, with an original chip and an flashed one to 9600. the best thing i can get it crumpled output of what i send...
did i missed something in wiring or the code at programming or communication with the nano?
