Hello,
I have a robot car that detects light on either side a car and will swing a 3d printed arm around on a servo to that side. My only problem is that with my code, when there is an even amount of light on both sides the servo will act crazy and start twitching, so i need a way in my code to set a threshold ( if that makes any sense) to only swing to one side if it has substantially more light. Here is the original code.
Servo myservo;
int val;
byte LDRL = 0;
byte LDRR = 1;
myservo.attach(12);
if(analogRead(LDRL) > analogRead(LDRR) ) {
myservo.write(0); // move to angel 80 degrees or what ever you want
else {
myservo.write(180); // move to angel 100 degrees or what ever you want
I am very new to coding. Is there a way to code something like a percentage, Like "only move the servo if it has 20% more light than the other side"??To me that doesn't seem right.
Or do i have to physically measure the resistance of the LDR in the same type of lighting conditions, read the resistances and then implement that into my code.
Not asking to write the code for me, just trying to see which is the best way to tackle this.
Thanks
I really dont know why that doesnt seem right to me, i didnt know you can use percentages in that manner.
Here is my best shot ...if LDRL is bigger than 20% and 20% is bigger that LDRR
if(analogRead(LDRL) >20%> analogRead(LDRR) ) {
else {
I'm sorry, but I still do not understand. i know how to take a voltage reading from a voltage divider circuit with the LDR and a 10k resistor. i just measured it, when it is bright i get 4.7 v ( with a 5v supply) between output and ground. Which that is what is read by A0 of my Arduino.
so would I use something like "move servo when LDRL is .4v more that LDRR"??
if(analogRead(LDRL) > .4v> analogRead(LDRR) ) {
The result of an analogRead(A0) is an integer between 0 and 1023. If you think you've read a voltage then you're imagining things. It's just an integer so trying to compare it with .4V which is very definitely not an integer is never going to work.
You could work out what number you actually read when the voltage is 4.7V and from that you could work out what the number should be for say 10% (1/10th) of that and then use those numbers to do something.
slipstick:
Steve
slipstick:
Steve
im sorry i still dont uderstand , do you have an example?
i understand what you are saying about 750 and 900 but would it work to say,
move servo when LDRL is 200 more than LDRR.( I only want the servo to move from one side to another if there is a significant difference like (200) higher than the other side
if(analogRead(LDRL) > 200> analogRead(LDRR) ) {
Sorry if im not getting it.
If you're wondering why this dosn't work, let's analyse why.
The expression is evaluated left-to-right.
So, is analogRead(LDRL) greater than 200.
Let's say it is - result true, aka 1.
Is 1 greater than analogRead (LDRR) ?
Unlikely.
I see what you are saying, i get what i want to do but dont know how to do it
Your analogReads return values between 0 and 1023.
Read both values into variables (e.g. leftLDR and rightLDR).
If leftLDR reading is greater than (rightLDR reading + 100) then move the arm to the left.
If rightLDR reading is greater than (leftLDR reading + 100) then move the arm to the right.
(100 was chosen as an arbitrary offset as it is roughly 10% of 1023 i.e. full scale. You may want to scale this depending on the maximum light available).
The effect of these three statements is that if the readings from the two analog channels are within 100 of each other no change will be made to the state of the arm.
