I have a project enclosure that was laser cut using 3.7mm thick material. I added a cutout for a micro USB female connector. The problem I am having is that the material is slightly too thick to make a reliable USB connection between the male USB cable and the female connector inside the enclosure.
Does anyone know of a place to get male USB cables with a longer header (I am guessing that's the name of the cable part I am referring to. The shiny metal part..:-)) Or, does anyone know of a part number of a female connector that is extended to go further off the PCB? I can go either route, but I can't go with a thinner material for the enclosure.
I am open to all suggestion on how to overcome this problem.
Thanks
