Projects setup s@cks
Why is the setup of projects so utterly clumsy done?
Ie No link to the needed sections, unclear why you cant post the projects or preview.
Why dont keep it on Hackster.io? where it all worked fine?
Pretty stupid move if you ask me Arduino!
What has moved ?
It appears your memory needs a bit of refreshing. Give us examples of what you are talking about. Also remember most of the projects are done by amateurs so give us an example of how you would do it since obviously by your definition they do not know how to do it and you are the expert.
strip-sack-brandon-graham
Hackster is stop #2 after dumping unchecked, unusable code on Instructables.
After several reads of the vague post, I'm taking a guess this is about Arduino Project Hub. So I have moved this topic to the Project Hub forum category since the original Arduino Yún category is not appropriate.
@voske65, in the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Please also make a better effort at communication in your future posts here. You can see that your lack of effort here caused a lot of confusion in the forum helpers.
Thanks in advance for your cooperation.
