SO to start off I AM a newb. I've been working on a control system for my schools ROV program and I realised that the PS2 controller has a reasonably understandable interface and plenty of information already on the internet. Plus i had a couple kicking around the house. So i found this code on this site dunk's robot - PS2 Controller on an AVR for the atmega 8 and since it and the arudinos run at the same clock speeds the code should be functional once it had been ported to the arduino ide. Unfortunently I managed to burn out my FTDI chip and while the new on is on the way I was wondering if this code makes sense and would work. So any help would be appreciated. Heres the origonal code. The ported code will follow that ![]()
#define PSclock 2 // PD2
#define PSdata 3 // PD3
#define PSacknolage 4 // PD4
#define PScommand 5 // PD5
#define PSattention 6 // PD6 int main(void)
// set the baud rate of the UART // (needed for transmitting over radio module).
//uartSetUp(2400);
// set port pins to output for status leds:
sbi(DDRC, PC0); // led.
sbi(DDRC, PC1); // led
sbi(DDRC, PC2); // led
sbi(DDRC, PC3); // led
sbi(DDRD, PD7); // led
sbi(DDRB, PB0); // led
sbi(DDRB, PB1); // led
sbi(DDRB, PB2); // led
// PSx controller I/O pin setup:
sbi(DDRD, PD2); // clock. output. (blue)
cbi(DDRD, PD3); // data. input. (brown)
sbi(PORTD, PD3); // enable pullup resistor
cbi(DDRD, PD4); // acknolage. input. (green)
sbi(PORTD, PD4); // enable pullup resistor
sbi(DDRD, PD5); // command. output. (orange)
sbi(DDRD, PD6); // attention. output. (yellow)
// enable interupts
sei();
// watchdog timer reset and enable
//wdt_reset();
//wdt_enable(0x02);
timerInit();
// this loop continues to put PSx controller into analouge mode untill the
// controller responds with 0x73 in the 2nd byte.
// (PS2 controller responds with 0x73 when in analouge mode.)
// the status LEDs will continue to count upwards untill a controller is found.
// if everything is working correctly this should happen on the first pass of
// this loop but occasionally errors occur and a 2nd or 3rd itteration happen.
unsigned char chk_ana = 0, cnt = 0;
while(chk_ana != 0x73){
// put controller in config mode
sbi(PORTD, PScommand);
sbi(PORTD, PSclock);
cbi(PORTD, PSattention);
gameByte(0x01);
gameByte(0x43);
gameByte(0x00);
gameByte(0x01);
gameByte(0x00);
delay_ms(1);
sbi(PORTD, PSattention);
delay_ms(10);
// put controller in analouge mode
gameByte(0x01);
gameByte(0x44);
gameByte(0x00);
gameByte(0x01);
gameByte(0x03);
gameByte(0x00);
gameByte(0x00);
gameByte(0x00);
gameByte(0x00);
delay_ms(1);
delay_ms(10);
// exit config mode
gameByte(0x01);
gameByte(0x43);
gameByte(0x00);
gameByte(0x00);
gameByte(0x5A);
gameByte(0x5A);
gameByte(0x5A);
gameByte(0x5A);
gameByte(0x5A);
delay_ms(1);
delay_ms(10);
// poll controller and check in analouge mode.
gameByte(0x01);
chk_ana = gameByte(0x42); // the 2nd byte to be returned from the controller should = 0x73 for "red" analouge controller.
gameByte(0x00);
gameByte(0x00);
gameByte(0x00);
gameByte(0x00);
gameByte(0x00);
gameByte(0x00);
gameByte(0x00);
delay_ms(1);
delay_ms(10);
// keep increasing counter to be dispalyed untill PSx controller confirms it's in analouge mode.
display(cnt++);
if (cnt > 254){ cnt=0;}
short int temp, data0, data1, data2, data3, data4, data5, i ,debounceSelect;
// main program loop:
while (1){
sbi(PORTD, PScommand); // start communication with PSx controller
gameByte(0x01); // bite 0. header.
temp = gameByte(0x42); // bite 1. header. (should possibly put test on this byte to detect unplugging of controller.)
gameByte(0x00); // bite 2. header.
data0 = gameByte(0x00); // bite 3. first data bite.
data1 = gameByte(0x00); // bite 4.
data2 = gameByte(0x00); // bite 5.
data3 = gameByte(0x00); // bite 6.
data4 = gameByte(0x00); // bite 7.
data5 = gameByte(0x00); // bite 8.
delay_us(1);
sbi(PORTD, PScommand); // close communication with PSx controller
delay_us(1);
sbi(PORTD, PSattention); // all done.
if(!(data0 & _BV(0)) && !debounceSelect) // capture one unique press of the "select" button
debounceSelect = 1;
else if ((data0 & _BV(0)) && debounceSelect)
if(i++ >= 5) i=0;
debounceSelect = 0;
// this switch decides which data register to show on status LEDs depending on how many times
// the "select" button on the PS2 controller has been pressed.
switch(i)
case 0:
display(data0);
case 1:
display(data1);
case 2:
display(data2);
case 3:
display(data3);
case 4:
display(data4);
case 5:
display(data5);
} // this section calls my R/C transmit code (not included here).
//tx_channel(0, data2);
//tx_channel(1, data5);
} // while(1)
} //main
// PSx controller communication function.
// send a byte on the command line and receive one on the data line.
// needs Attention pin to have gone low before called to activate controller.
int gameByte(short int command)
short int i ;
delay_us(1);
short int data = 0x00; // clear data variable to save setting low bits later.
for(i=0;i<8;i++)
if(command & _BV(i)) sbi(PORTD, PScommand); // bit bang "command" out on PScommand wire.
else cbi(PORTD, PScommand);
cbi(PORTD, PSclock); // CLOCK LOW
delay_us(1); // wait for output to stabilise
if((PIND & _BV(PSdata))) sbi(data, i); // read PSdata pin and store
//else cbi(data, i);
sbi(PORTD, PSclock); // CLOCK HIGH
delay_us(20); // wait for ACK to pass.
return(data);
// put 1 byte on the 8 LEDs. obviously you need to change the output pins to // match your board.
void display(short int LEDs)
if(LEDs & _BV(0)) cbi(PORTC, PD0);
else sbi(PORTC, PD0);
if(LEDs & _BV(1)) cbi(PORTC, PD1);
else sbi(PORTC, PD1);
if(LEDs & _BV(2)) cbi(PORTC, PD2);
else sbi(PORTC, PD2);
if(LEDs & _BV(3)) cbi(PORTC, PD3);
else sbi(PORTC, PD3);
if(LEDs & _BV(4)) cbi(PORTD, PD7);
else sbi(PORTD, PD7);
if(LEDs & _BV(5)) cbi(PORTB, PD0);
else sbi(PORTB, PD0);
if(LEDs & _BV(6)) cbi(PORTB, PD1);
else sbi(PORTB, PD1);
if(LEDs & _BV(7)) cbi(PORTB, PD2);
else sbi(PORTB, PD2);
return;
Ported code will be in the next post
