Pulldown resistor power requirement
Hey guys
Yipeeee, I got it working (after 2 bloody hours dammit :))
I am using a 10k resistor to "pull_down" ground as the sensor needs stability
I have a 10k connected now but its 1/4 watt
is 1/2w better in case it gets hot ?
Yes No ?
I don't know how to calculate power on that 10k resistor
I know I=V/R, but the rest is rocket science to me..
:frowning:
Any thoughts ?
cheeers
What on earth are you trying to do?
P(watt)=IIR
So you need 50V on the 10k resistor to dissipate 1/4 watt on it..
pito:
P(watt)=IIR
On a pulldown...?
On a pulldown...?
I do not know what firehorse does, but you can have a pulldown 10k resistor with more than 50Volts on it.. :slight_smile:
Pull downs are not normal, are you doing things right?
http://www.thebox.myzen.co.uk/Tutorial/Inputs.html
Edited per Bob:
P = V^2 * R = V * V / R also works.
P = V^2 / R = V * V / R also works.
P = 5V * 5V / 10K = 0.0025 watts
To dissipate 1/4W at 5V, R = V^2 / P = 5V*5V/0.25W = 100 ohms.
So, your 1/4W 10K R is cool [literally], for voltages in the range 0..5V.
little typo there:
P = I^2*R = V^2/R
Comes from P = I*V
V=IR or I=V/R, subbing in for I or V yields the above.
Duh, half right and half wrong.
Wonderful, now rocket science isn't so bad, Ohms law works really well here
thanks guys
Grumpy_Mike:
I dunno, it is working for the situation I need
Here's the story:
I have the 10k resistor connected to ANALOG INPUT and ground because of a floating input, when the sensor open circuits,
ie: INPUT goes LOW
Thanks for the link, I tried both pullup & pulldown, both work fine
They say pullup circuits uses less current traditionally but does my hardware need pullup or will pulldown work OK too ?
Just not sure why I would need, to use pullup if that's the case ???
Ok you never said it was an analogue input.
No I don't think there is anything in that.
just not sure why I would need, to use pullup if that's the case ?
You need one or the other but as I said in that page it is a touch safer having a long lead with a ground rather a long lead with power.
http://www.atmel.com/Images/doc8349.pdf
Atmel uses pullups here as part of power reduction technique.
I think Nick Gammon also did some testing on this
OK, makes sense
thanks for the info
