I am making a fire fighting robot for my school project. I am using arduino nano with flame sensors. Even when the flame is not detected the pump is on. The pump is powered through a relay module. Please help me . Sorry if I have made any mistake in choosing the catagory for the post. This is my first post. Here's the code:
#include <Wire.h>
#include <Servo.h>
Servo myservo;
#define Left A2
#define Right A1
#define Forward A0
#define LM1 2
#define LM2 3
#define RM1 4
#define RM2 5
#define pump 7
pinMode(Left, INPUT);
pinMode(Right, INPUT);
pinMode(Forward, INPUT);
pinMode(LM1, OUTPUT);
pinMode(LM2, OUTPUT);
pinMode(RM1, OUTPUT);
pinMode(RM2, OUTPUT);
pinMode(pump, OUTPUT);
myservo.attach(11);
myservo.write(90);
digitalWrite(pump, HIGH); // Initialize pump pin to LOW
void sweepServo() {
for (int pos = 50; pos <= 130; pos += 1) {
myservo.write(pos);
delay(10);
for (int pos = 130; pos >= 50; pos -= 1) {
myservo.write(pos);
delay(10);
void put_off_fire() {
digitalWrite(LM1, LOW);
digitalWrite(LM2, LOW);
digitalWrite(RM1, LOW);
digitalWrite(RM2, LOW);
sweepServo();
digitalWrite(pump, LOW); // Turn off the pump after sweeping
int leftSensor = digitalRead(Left);
int rightSensor = digitalRead(Right);
int forwardSensor = digitalRead(Forward);
if (leftSensor && rightSensor && forwardSensor) {
digitalWrite(LM1, HIGH);
digitalWrite(LM2, HIGH);
// Stop the motors
// Adjust movement based on sensor inputs
if(forwardSensor == HIGH) {
digitalWrite(RM1, HIGH);
if (leftSensor == HIGH) {
// Turn left
if (rightSensor == HIGH) {
// Turn right
digitalWrite(RM2, HIGH);
// Check for fire detection (TO DO: implement fire detection logic)
// If fire is detected, call put_off_fire() function
// put_off_fire();
Here's the circuit diagram:
Hey guys we recently found a loophole in our project which is when we connect the signal pin of the relay to any digital pins the relay turns on the arduino nano is mounted on a breadboard is that the cause ?
Please help us we are out of time.
Thanks,
