Pump tubing breaks down
Hi everyone,
I am using several 12V DC pumps for a project. One is always on and running. The hardware and code itself are fine. However, this one pump has been running for 4 days now and the tube inside the pump has broken, so I assume there is too much force/pressure on the tube. This is the one I am currently using: Peristaltic Liquid Pump with Silicone Tubing - 12V DC Power : ID 1150 : Adafruit Industries, Unique & fun DIY electronics and kits
Has any of you ever had a project where you used a pump in continuous operation for weeks and if so, what pump did you use? Any tubing recommendations?
Thanks in advance!
Best,
Lea
I doubt there is all that much force on the tube after reading how it works, it's more likely a result of overuse, is it designed for continuous use? E-mail Adafruit and ask that question.
Life has a lot to do with the tubing, some types can get old and become stiff and then break much easier. I highly recommend you follow @sonofcy suggestion and contact the vendor.
The picture shows that the pump is easily disassembled and the tubing can be replaced. Ask a tubing source company for a tubing suitable for your project. What is the temperature of the liquid?
The liquid has 40 °C
But do peristaltic pumps run continuously in your projects?
I would doubt the motor , pump, tubing , is rated for continued use -it is only a cheap hobby part .
Chem labs use Pyrex glass tubing. Art studios use a Bunsen burner to create any shape with Pyrex. Pyrex holds up to major use, like a filled bubble tray with an inverted funnel 2/3 full of "air" and 1/3 full of the reaction of eggshells and hydrochloric acid. When oxidized, the funnel tries to escape the bubble tank NOW, but the funnel tip restricts airflow into the funnel, stoping pressure equalization, so through adhesion, the funnel just holds on to the water and the tank, and everyone launches one meter in the air... and the return to Earth is just as spectacular. No Pyrex broken. Heard it from a friend.
Hi, @lerehmi
Can you please tell us, what is your project application?
Thanks... Tom... :smiley: :+1: :coffee: :australia:
There are several other types of positive displacement pumps than the tubing type and the will run continuously for years. Google will help you.
