Pushbutton, RF Receiver, and Touchscreen working interchangeably to move servo
Hi, I'm trying to control a servo with a Pushbutton, RF Receiver, and Touchscreen. These 3 will work interchangeably. The servo should move clockwise and then counterclockwise with each press of either one of the 3 methods. The touchscreen and the push button work flawlessly together. When I use the RF Receiver before or after any of the methods, the issue occurs.
I press the RF Receiver button once and the servo moves clockwise infinitely or the servo moves counterclockwise infinitely, depending on the other 2 methods last button press (I don't want it to move infinitely). Click again and the servo moves counterclockwise for the 1000 milliseconds it's supposed to. I've tried changing the braces({ }) and oldSwitchState = newSwitchState; by adding them or removing them from the code, but this is the closest I've gotten it to work.
This is the code where I have all three methods:
#include <LCDWIKI_GUI.h> //libraries are below
#include <LCDWIKI_KBV.h>
#include <Adafruit_GFX.h>
#include <Adafruit_TFTLCD.h>
#include <TouchScreen.h>
#include <MCUFRIEND_kbv.h>
int LFT = 115, RT = 908, TOP = 964, BOT = 80; //calibration of the four corners of the touchscreen
LCDWIKI_KBV mylcd(ILI9486, A3, A2, A1, A0, A4);
#define BLACK       0x0000 //colors for touchscreen
#define NAVY        0x000F
#define DARKGREEN   0x03E0
#define DARKCYAN    0x03EF
#define MAROON      0x7800
#define PURPLE      0x780F
#define OLIVE       0x7BE0
#define LIGHTGREY   0xC618
#define DARKGREY    0x7BEF
#define BLUE        0x001F
#define GREEN       0x07E0
#define CYAN        0x07FF
#define RED         0xF800
#define MAGENTA     0xF81F
#define YELLOW      0xFFE0
#define WHITE       0xFFFF
#define ORANGE      0xFD20
#define GREENYELLOW 0xAFE5
#define PINK        0xF81F
#define YP A3
#define XM A2
#define YM 9
#define XP 8
MCUFRIEND_kbv tft;
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
#include <Servo.h>
Servo myservo1;
const int  buttonPin = 13;//Touchscreen
const int buttonPin1 = 42; //RF RECEIVER
const int buttonPin2 = 27; //Push Button
const int servoPin1 = 49;
const int ledPin1 = 52;
const int ledPin2 = 53;
boolean oldSwitchState = LOW; //Keeping this for the RF Receiver since it seems like it won't work without it.
boolean newSwitchState = LOW;
byte state = 0;
  pinMode(buttonPin, INPUT); //Touchscreen
  pinMode(buttonPin1, INPUT_PULLUP); //RF RECEIVER
  pinMode(buttonPin2, INPUT_PULLUP); //Push Button
  digitalWrite(13, LOW); //Touchscreen
  pinMode(ledPin1, OUTPUT);
  digitalWrite(ledPin1, LOW);
  pinMode(ledPin2, OUTPUT);
  digitalWrite(ledPin2, LOW);
  Serial1.begin(9600);
  pinMode(servoPin1, OUTPUT); //RF RECEIVER
  digitalWrite(servoPin1, LOW); //RF RECEIVER
  myservo1.attach(49);
  myservo1.writeMicroseconds(1490);
  tft.begin(0x9486); //Touchscreen button setup
  Serial.print("TFT size is "); Serial.print(tft.width()); Serial.print("x"); Serial.println(tft.height());
  tft.setRotation(2);
  tft.fillScreen(WHITE);
  tft.fillCircle(160, 240, 60, 0x7BEF);
  touchScreenLoopCode();
  rFReceiverCode();
  pushButtonCode();
void touchScreenLoopCode() {
  int button_on = 0;
  int x, y;
  TSPoint p = ts.getPoint();
  if (p.z > ts.pressureThreshhold) {
    //Portrait Calibration
    x = map(p.x, LFT = 115, RT = 908, 0, 320);
    y = map(p.y, TOP = 964, BOT = 80, 0, 480);
    if (x > 100 && x < 220 && y > 180 && y < 300 ) {
      digitalWrite(13, HIGH);
      newSwitchState = digitalRead(buttonPin); // read the pushbutton input pin:
      if (newSwitchState == HIGH ) // if the current state is HIGH then the button went from off to on
        state++; // increment the counter
        delay(50); // Delay a little bit to avoid bouncing
      if (state > 2) {
        state = 1;
      if (state == 1) {
        digitalWrite(ledPin1, HIGH);
        myservo1.writeMicroseconds(1000);
      if (state == 2) {
        digitalWrite(ledPin2, HIGH);
        myservo1.writeMicroseconds(2000);
void rFReceiverCode() {
  newSwitchState = digitalRead(buttonPin1); // read the pushbutton input pin:
  if ( newSwitchState != oldSwitchState ) // compare the buttonState to its previous state
    state++; //increment the counter
      if (state > 2) {
        state = 1;
      if (state == 1) {
      if (state == 2) {
    oldSwitchState = newSwitchState; // save the current state as the last state, for next time through the loop
void pushButtonCode() {
  newSwitchState = digitalRead(buttonPin2); // read the pushbutton input pin:
               // Had to put it under state++ in order for it to work
      if (state > 2) {
        state = 1;
      if (state == 1) {
      if (state == 2) {
This is the code where I have the touchscreen and the Pushbutton working flawlessly:
#define NAVY        0x000F
#define BLUE        0x001F
#define CYAN        0x07FF
#define RED         0xF800
#define PINK        0xF81F
#define YP A3
#define XM A2
#define YM 9
#define XP 8
MCUFRIEND_kbv tft;
#include <Servo.h>
Servo myservo1;
byte state = 0;
  tft.setRotation(2);
  pushButtonCode();
  int button_on = 0;
  int x, y;
      if (state > 2) {
        state = 1;
      if (state == 1) {
      if (state == 2) {
      if (state > 2) {
        state = 1;
      if (state == 1) {
      if (state == 2) {
This is the code where I have the touchscreen and the RF Reciever working flawlessly:
#define NAVY        0x000F
#define BLUE        0x001F
#define CYAN        0x07FF
#define RED         0xF800
#define PINK        0xF81F
#define YP A3
#define XM A2
#define YM 9
#define XP 8
MCUFRIEND_kbv tft;
#include <Servo.h>
Servo myservo1;
byte state = 0;
  tft.setRotation(2);
  rFReceiverCode();
  int button_on = 0;
  int x, y;
      if (state > 2) {
        state = 1;
      if (state == 1) {
      if (state == 2) {
      if (state > 2) {
        state = 1;
      if (state == 1) {
      if (state == 2) {
This is the code where I have the RF Reciever working flawlessly by itself:
#include <Servo.h>
Servo myservo1;
byte state = 0;
  rFReceiverCode();
      if (state > 2) {
        state = 1;
      if (state == 1) {
      if (state == 2) {
Is 2 loop codes in the void loop the max amount? Is 3 too many?
I don't know what else to do. Any help would be greatly appreciated.
You need to have an oldSwitchState variable for each of your buttons, not 1 global variable. It would be easier of you made these variables static within each of your functions. That way, they retain the value across calls, yet don't interfere with each other.
You also are missing a few braces to associate multiple lines with your if() statement. Without them, only the single line following the if() statement is tied to the conditional. Notice the difference in indentation:
only that delay(50) is associated with the if(). state++ always gets executed.
Also, HIGH and LOW are not boolean values, so you should not use that type. Use int.
#define NAVY        0x000F
#define BLUE        0x001F
#define CYAN        0x07FF
#define RED         0xF800
#define PINK        0xF81F
#define YP A3
#define XM A2
#define YM 9
#define XP 8
MCUFRIEND_kbv tft;
#include <Servo.h>
Servo myservo1;
//boolean oldSwitchState = LOW; //Keeping this for the RF Receiver since it seems like it won't work without it.
//boolean newSwitchState = LOW;
byte state = 0;
  tft.setRotation(2);
  rFReceiverCode();
  pushButtonCode();
void move() {
  if (state > 2) {
    state = 1;
  if (state == 1) {
  if (state == 2) {
  static int oldSwitchState = LOW;
  int newSwitchState = digitalRead(buttonPin);
  int button_on = 0;
  int x, y;
      if (newSwitchState == HIGH ) {
        move();
  int newSwitchState = digitalRead(buttonPin1); // read the pushbutton input pin:
  if ( newSwitchState != oldSwitchState ) {
      move();
  int newSwitchState = digitalRead(buttonPin2); // read the pushbutton input pin:
      move();
Thank you so much for your reply. I will look at it in detail. If i have any other questions I'll let you know.
Hi @sergioma20
I want to say that you are showing great own effort by posting your different code-versions. In my opinion very well done. To me it is a joy to help users that work this way.
best regards Stefan
