Nein, das ist es leider nicht.
Das hab ich schon richtig auskommentiert.
Weiterhin hab ich auch aus Verzweiflung nach der try&error Methode alle Varianten durchprobiert ...ohne Erfolg.
//https://github.com/2dom/PxMatrix
// This is how many color levels the display shows - the more the slower the update
//#define PxMATRIX_COLOR_DEPTH 8
// Defines the buffer height / the maximum height of the matrix
//#define PxMATRIX_MAX_HEIGHT 64
// Defines the buffer width / the maximum width of the matrix
//#define PxMATRIX_MAX_WIDTH 64
// Defines how long we display things by default
//#define PxMATRIX_DEFAULT_SHOWTIME 30
// Defines the speed of the SPI bus (reducing this may help if you experience noisy images)
//#define PxMATRIX_SPI_FREQUENCY 20000000
// Creates a second buffer for backround drawing (doubles the required RAM)
#define PxMATRIX_double_buffer true
#include <PxMatrix.h>
// Pins for LED MATRIX
#ifdef ESP32
#define P_LAT 22
#define P_A 19
#define P_B 23
#define P_C 18
#define P_D 5
#define P_E 15
#define P_OE 16
hw_timer_t * timer = NULL;
portMUX_TYPE timerMux = portMUX_INITIALIZER_UNLOCKED;
#endif
// ifdef ESP8266
//#include <Ticker.h>
//Ticker display_ticker;
//#define P_LAT 16
//#define P_A 5
//#define P_B 4
//#define P_C 15
//#define P_D 12
//#define P_E 0
//#define P_OE 2
//#endif
#define MATRIX_WIDTH 64
#define MATRIX_HEIGHT 64
unsigned long ms_current = 0;
unsigned long ms_previous = 0;
unsigned long ms_animation_max_duration = 10000; // 10 seconds
unsigned long next_frame = 0;
// This defines the 'on' time of the display is us. The larger this number,
// the brighter the display. If too large the ESP will crash
uint8_t display_draw_time=30; //30-60 is usually fine
//PxMATRIX display(32,16,P_LAT, P_OE,P_A,P_B,P_C);
//PxMATRIX display(64,32,P_LAT, P_OE,P_A,P_B,P_C,P_D);
PxMATRIX display(64,64,P_LAT, P_OE,P_A,P_B,P_C,P_D,P_E);
#include <FastLED.h> // Aurora needs fastled
#include "Effects.h"
Effects effects;
#include "Drawable.h"
#include "Playlist.h"
//#include "Geometry.h"
#include "Patterns.h"
Patterns patterns;
// Some standard colors
uint16_t myRED = display.color565(255, 0, 0);
uint16_t myGREEN = display.color565(0, 255, 0);
uint16_t myBLUE = display.color565(0, 0, 255);
uint16_t myWHITE = display.color565(255, 255, 255);
uint16_t myYELLOW = display.color565(255, 255, 0);
uint16_t myCYAN = display.color565(0, 255, 255);
uint16_t myMAGENTA = display.color565(255, 0, 255);
uint16_t myBLACK = display.color565(0, 0, 0);
uint16_t myCOLORS[8]={myRED,myGREEN,myBLUE,myWHITE,myYELLOW,myCYAN,myMAGENTA,myBLACK};
#ifdef ESP8266
// ISR for display refresh
void display_updater()
display.display(display_draw_time);
#endif
#ifdef ESP32
void IRAM_ATTR display_updater(){
// Increment the counter and set the time of ISR
portENTER_CRITICAL_ISR(&timerMux);
portEXIT_CRITICAL_ISR(&timerMux);
#endif
void display_update_enable(bool is_enable)
#ifdef ESP8266
if (is_enable)
display_ticker.attach(0.001, display_updater);
display_ticker.detach();
#endif
#ifdef ESP32
if (is_enable)
timer = timerBegin(0, 80, true);
timerAttachInterrupt(timer, &display_updater, true);
timerAlarmWrite(timer, 2000, true);
timerAlarmEnable(timer);
timerDetachInterrupt(timer);
timerAlarmDisable(timer);
#endif
// Define your display layout here, e.g. 1/8 step, and optional SPI pins begin(row_pattern, CLK, MOSI, MISO, SS)
display.begin(16);
display.setFastUpdate(true);
//display.begin(8, 14, 13, 12, 4);
// Define multiplex implemention here {BINARY, STRAIGHT} (default is BINARY)
//display.setMuxPattern(BINARY);
// Set the multiplex pattern {LINE, ZIGZAG,ZZAGG, ZAGGIZ, WZAGZIG, VZAG, ZAGZIG} (default is LINE)
//display.setScanPattern(LINE);
// Rotate display
//display.setRotate(true);
// Flip display
//display.setFlip(true);
// Helps to reduce display update latency on larger displays
//display.setFastUpdate(true);
// Control the minimum color values that result in an active pixel
//display.setColorOffset(5, 5,5);
// Set the multiplex implemention {BINARY, STRAIGHT} (default is BINARY)
// Set the color order {RRGGBB, RRBBGG, GGRRBB, GGBBRR, BBRRGG, BBGGRR} (default is RRGGBB)
//display.setColorOrder(RRGGBB);
// Set the time in microseconds that we pause after selecting each mux channel
// (May help if some rows are missing / the mux chip is too slow)
//display.setMuxDelay(0,1,0,0,0);
// Set the number of panels that make up the display area width (default is 1)
//display.setPanelsWidth(2);
// Set the brightness of the panels (default is 255)
//display.setBrightness(50);
// Set driver chip type
//display.setDriverChip(FM6124);
display.clearDisplay();
display.setTextColor(myCYAN);
display.setCursor(2,0);
display.print("Pixel");
display.setTextColor(myMAGENTA);
display.setCursor(2,8);
display.print("Time");
display_update_enable(true);
delay(3000);
// setup the effects generator
effects.Setup();
Serial.println("Effects being loaded: ");
listPatterns();
patterns.setPattern(0); // // simple noise
patterns.start();
Serial.print("Starting with pattern: ");
Serial.println(patterns.getCurrentPatternName());
unsigned long last_draw=0;
void scroll_text(uint8_t ypos, unsigned long scroll_delay, String text, uint8_t colorR, uint8_t colorG, uint8_t colorB)
uint16_t text_length = text.length();
display.setTextWrap(false); // we don't wrap text so it scrolls nicely
display.setTextSize(1);
display.setRotation(0);
display.setTextColor(display.color565(colorR,colorG,colorB));
// Asuming 5 pixel average character width
for (int xpos=MATRIX_WIDTH; xpos>-(MATRIX_WIDTH+text_length*5); xpos--)
display.setCursor(xpos,ypos);
display.println(text);
delay(scroll_delay);
yield();
// This might smooth the transition a bit if we go slow
// display.setTextColor(display.color565(colorR/4,colorG/4,colorB/4));
// display.setCursor(xpos-1,ypos);
// display.println(text);
delay(scroll_delay/5);
yield();
// menu.run(mainMenuItems, mainMenuItemCount);
ms_current = millis();
if ( (ms_current - ms_previous) > ms_animation_max_duration )
// patterns.moveRandom(1);
patterns.stop();
patterns.move(1);
patterns.start();
Serial.print("Changing pattern to: ");
ms_previous = ms_current;
// Select a random palette as well
//effects.RandomPalette();
if ( next_frame < ms_current)
next_frame = patterns.drawFrame() + ms_current;
display.showBuffer();
void listPatterns() {
patterns.listPatterns();
