Sorry Im new to the forum soo I dont know what code tags mean but here's the code, like i said its the sample code from the QTRSensors Library
#include <QTRSensors.h>
// This example is designed for use with eight QTR-1RC sensors or the eight sensors of a
// QTR-8RC module. These reflectance sensors should be connected to digital inputs 3 to 10.
// The QTR-8RC's emitter control pin (LEDON) can optionally be connected to digital pin 2,
// or you can leave it disconnected and change the EMITTER_PIN #define below from 2 to
// QTR_NO_EMITTER_PIN.
// The setup phase of this example calibrates the sensor for ten seconds and turns on
// the LED built in to the Arduino on pin 13 while calibration is going on.
// During this phase, you should expose each reflectance sensor to the lightest and
// darkest readings they will encounter.
// For example, if you are making a line follower, you should slide the sensors across the
// line during the calibration phase so that each sensor can get a reading of how dark the
// line is and how light the ground is. Improper calibration will result in poor readings.
// If you want to skip the calibration phase, you can get the raw sensor readings
// (pulse times from 0 to 2500 us) by calling qtrrc.read(sensorValues) instead of
// qtrrc.readLine(sensorValues).
// The main loop of the example reads the calibrated sensor values and uses them to
// estimate the position of a line. You can test this by taping a piece of 3/4" black
// electrical tape to a piece of white paper and sliding the sensor across it. It
// prints the sensor values to the serial monitor as numbers from 0 (maximum reflectance)
// to 1000 (minimum reflectance) followed by the estimated location of the line as a number
// from 0 to 5000. 1000 means the line is directly under sensor 1, 2000 means directly
// under sensor 2, etc. 0 means the line is directly under sensor 0 or was last seen by
// sensor 0 before being lost. 5000 means the line is directly under sensor 5 or was
// last seen by sensor 5 before being lost.
#define NUM_SENSORS 8 // number of sensors used
#define TIMEOUT 2500 // waits for 2500 microseconds for sensor outputs to go low
#define EMITTER_PIN 2 // emitter is controlled by digital pin 2
// sensors 0 through 7 are connected to digital pins 3 through 10, respectively
QTRSensorsRC qtrrc((unsigned char[]) {3, 4, 5, 6, 7, 8, 9, 10},
NUM_SENSORS, TIMEOUT, EMITTER_PIN);
unsigned int sensorValues[NUM_SENSORS];
pinMode(13, OUTPUT);
digitalWrite(13, HIGH); // turn on Arduino's LED to indicate we are in calibration mode
for (int i = 0; i < 400; i++) // make the calibration take about 10 seconds
qtrrc.calibrate(); // reads all sensors 10 times at 2500 us per read (i.e. ~25 ms per call)
digitalWrite(13, LOW); // turn off Arduino's LED to indicate we are through with calibration
// print the calibration minimum values measured when emitters were on
for (int i = 0; i < NUM_SENSORS; i++)
Serial.print(qtrrc.calibratedMinimumOn*);*
- Serial.print(' ');*
- Serial.println();*
- // print the calibration maximum values measured when emitters were on*
- for (int i = 0; i < NUM_SENSORS; i++)*
_ Serial.print(qtrrc.calibratedMaximumOn*);_
_ Serial.print(' ');_
_ }_
_ Serial.println();_
_ delay(1000);_
_}_
_{_
_ // read calibrated sensor values and obtain a measure of the line position from 0 to 5000*_
* // To get raw sensor values, call:*
* // qtrrc.read(sensorValues); instead of unsigned int position = qtrrc.readLine(sensorValues);*
* unsigned int position = qtrrc.readLine(sensorValues);*
* // print the sensor values as numbers from 0 to 1000, where 0 means maximum reflectance and*
* // 1000 means minimum reflectance, followed by the line position*
* for (unsigned char i = 0; i < NUM_SENSORS; i++)
_ {_
_ Serial.print(sensorValues);
Serial.print('\t');
//Serial.println(); // uncomment this line if you are using raw values*
* Serial.println(position); // comment this line out if you are using raw values*
* delay(250);
Error Message:
In file included from QTRRCExample.cpp:1:
C:\Users\Russell\Desktop\Codes\arduino-1.0\libraries\QTRSensors/QTRSensors.h:155: error: expected ';' before 'override'
C:\Users\Russell\Desktop\Codes\arduino-1.0\libraries\QTRSensors/QTRSensors.h:158: error: expected ';' before 'override'
C:\Users\Russell\Desktop\Codes\arduino-1.0\libraries\QTRSensors/QTRSensors.h:165: error: expected ';' before 'override'
C:\Users\Russell\Desktop\Codes\arduino-1.0\libraries\QTRSensors/QTRSensors.h:188: error: expected ';' before 'override'
C:\Users\Russell\Desktop\Codes\arduino-1.0\libraries\QTRSensors/QTRSensors.h:247: error: expected ';' before 'override'
C:\Users\Russell\Desktop\Codes\arduino-1.0\libraries\QTRSensors/QTRSensors.h:309: error: expected ';' before 'override'
C:\Users\Russell\Desktop\Codes\arduino-1.0\libraries\QTRSensors/QTRSensors.h:332: error: expected ';' before 'override'
C:\Users\Russell\Desktop\Codes\arduino-1.0\libraries\QTRSensors/QTRSensors.h:358: error: expected ';' before 'override'
QTRRCExample:35: error: cannot declare variable 'qtrrc' to be of abstract type 'QTRSensorsRC'
C:\Users\Russell\Desktop\Codes\arduino-1.0\libraries\QTRSensors/QTRSensors.h:201: note: because the following virtual functions are pure within 'QTRSensorsRC':_
_C:\Users\Russell\Desktop\Codes\arduino-1.0\libraries\QTRSensors/QTRSensors.h:125: note: virtual void QTRSensors::readPrivate(unsigned int, unsigned char, unsigned char)_
