Hello,
I have a question about how PDM microphones work when selecting the left or right channel. Selection between the 2 channels is done by connecting the appropriate pin to either VCC or GND.
Depending on how the connection is made data is collected on the rising or falling edge of the signal. This is the part that I do not understand. If I select the rising edge does this mean that it will send data to the microcontroller when the noise begins? If I select the falling edge does this mean that it will send data to the microcontroller when the noise ends?
If I have 2 independent systems that are identical except the channel selection and I play a sound will the system that is wired on the rising edge pick up the signal before the system wired on the falling edge?
This is purely a theoretical question to understand how the PDM microphone works. I hope it is not too silly but I do not know much about microphones.
