I'm using 2 Piezo discs to start making an E-drum with Arduino Pro Micro. In the end I want to have 11 Piezo discs so I'm using a 16-Channel Analog Multiplexer. Now I have 2 Piezo discs wired-up with each a resister and connected my Arduino with MIDIUSB plugin to a Logic Pro drumset and gave each Piezo it's own note. But when I tap Piezo disc 1 it plays both notes, the same for Piezo disc 2. Is it possible that the 16 inputs in the Analog Multiplexer are always read together?
Please tell me you haven't simply stuck those Dupont connectors through the holes and expected the electrons to magically jump over the air gap between the pin and the side of the hole.
I've read on other topics that there are other people with the same problem as me, and they most likely connected their multiplexer correctly, so the real problem probably doesn't lie there, because mine works, it only reads all the 16 channels at once (i think..) and not the channel with the piezo that is being hit.
thank you guys for all the tips and help! much appreciated! I soldered the header pins to the Mux. Now Piezo 1 has a clearly snare sound and piezo 2 has a clearly kick sound, but there is still some cross-talk. sometimes piezo 2 gives also some snare and piezo 1 sometimes some kick.
What value bleed resistor did you use across the piezo.
1Meg is common when used as microphone, but you can lower sensitivity and cross-talk with lower values. Try 100k or even 10k.
Leo..
Edit: I think I see resistors in series with the piezo. They must be in parallel.
Now I connected the piezo's with each a 1Meg-ohm in parallel. When tapping the snare piezo soft it gives only snare sound, but when I tap it normal it gives also kick with it. The same for the kick piezo. I tried blocking out the weak signal and only giving the strongest thru but that still doesn't solve the problem
Yess. I lowered the resistor values to 100k resistors and when 2 piezo's were wired up the so-called cross-talk was gone, but when i wire up all the 11 piezo's there is back cross-talk.
