question about the 74HC594 !
hello guys,
i need please to know where to connect the RCLR*(pin13) and SRCLR*(pin10) from the 74HC594 should these 2 pins be connected to GND or +5V ?
datasheet in the attachment file
Shift Register SN74HC594.pdf (386 KB)
Assuming you don't want to clear the registers, they should be connected to +5V.
BillO:
ok thank you but what do you mean by clear ? because i never used these 2 pins before for any purpose
When you bring either pin to ground, it clears the associated register to all zeros.
BillO:
ok thanks that is instead of clocking it to zeroes than latching it
Right.
In the datasheet (http://www.nxp.com/documents/data_sheet/74HC_HCT594.pdf) there is a "function table" at the start of page 2 - its a great idea to learn to read these tables!
The description on page 1 also mentions those two signals as "direct overriding clear" negative logic inputs.
The bar over the top of a signal name means it is "active low" or "negative logic", ie LOW means active/true, HIGH
means idle/false. This is a universal notation in logic datasheets you need to know about.
MarkT:
ok many thanks this is a new info about the bar :slight_smile: i wrote it down
