I'm currently working on a display for a project for a vehicle I'm "updating" as well as adding a few other things. I'm just wondering if I've implemented the TM1637 correctly in my schematic.
PDF of the entire project if you want to look.
Schematic_Arduino Propane Controller_2022-01-13.pdf (172.5 KB)
This is the Grove circuit that I found supplied somewhere else.
This is a snapshot of the datasheet for the TM1637.
Previously I've only used it as a complete module from the standard suppliers with the 4 digit 7 segment display already attached to it. But it is very limiting on what can be done with it simply because of the "total package". I have several other projects that I'm working on that will also use this driver so I'm trying to make sure that I understand how to use it.
My biggest concern right now is that I have my filters and the CLK and DIO setup correctly. The part that drives the actual 7 segments is really easy so I'm not concerned there. However, if you feel that I've done something incorrectly feel free to let me know, all I ask is that you give a reason why so that I can fully understand. I use to be a "spark chaser" on the AH-64 helicopter, but I'm new to circuit design so as long as you explain it I should be able to understand the gist.
Thanks for any help and for looking.
