R307 fingerprint not working properly
after uploading the code in nodemcu esp8266. fingerprint is blinking just for a time . after that my fingerprint is not working .
  This is an example sketch for our optical Fingerprint sensor
  Designed specifically to work with the Adafruit BMP085 Breakout
  ----> http://www.adafruit.com/products/751
  These displays use TTL Serial to communicate, 2 pins are required to
  interface
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  Small bug-fix by Michael cochez
  BSD license, all text above must be included in any redistribution
#include <Adafruit_Fingerprint.h>
#if (defined(__AVR__) || defined(ESP8266)) && !defined(__AVR_ATmega2560__)
// For UNO and others without hardware serial, we must use software serial...
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino  (WHITE wire)
// Set up the serial port to use softwareserial..
SoftwareSerial mySerial(2, 3);
#else
// On Leonardo/M0/etc, others with hardware serial, use hardware serial!
// #0 is green wire, #1 is white
#define mySerial Serial1
#endif
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
uint8_t id;
  while (!Serial);  // For Yun/Leo/Micro/Zero/...
  delay(100);
  Serial.println("\n\nAdafruit Fingerprint sensor enrollment");
  // set the data rate for the sensor serial port
  finger.begin(57600);
  if (finger.verifyPassword()) {
    Serial.println("Found fingerprint sensor!");
    Serial.println("Did not find fingerprint sensor :(");
    while (1) { delay(1); }
  Serial.println(F("Reading sensor parameters"));
  finger.getParameters();
  Serial.print(F("Status: 0x")); Serial.println(finger.status_reg, HEX);
  Serial.print(F("Sys ID: 0x")); Serial.println(finger.system_id, HEX);
  Serial.print(F("Capacity: ")); Serial.println(finger.capacity);
  Serial.print(F("Security level: ")); Serial.println(finger.security_level);
  Serial.print(F("Device address: ")); Serial.println(finger.device_addr, HEX);
  Serial.print(F("Packet len: ")); Serial.println(finger.packet_len);
  Serial.print(F("Baud rate: ")); Serial.println(finger.baud_rate);
uint8_t readnumber(void) {
  uint8_t num = 0;
  while (num == 0) {
    while (! Serial.available());
    num = Serial.parseInt();
  return num;
void loop()                     // run over and over again
  Serial.println("Ready to enroll a fingerprint!");
  Serial.println("Please type in the ID # (from 1 to 127) you want to save this finger as...");
  id = readnumber();
  if (id == 0) {// ID #0 not allowed, try again!
     return;
  Serial.print("Enrolling ID #");
  Serial.println(id);
  while (! getFingerprintEnroll() );
uint8_t getFingerprintEnroll() {
  int p = -1;
  Serial.print("Waiting for valid finger to enroll as #"); Serial.println(id);
  while (p != FINGERPRINT_OK) {
    p = finger.getImage();
    switch (p) {
    case FINGERPRINT_OK:
      Serial.println("Image taken");
    case FINGERPRINT_NOFINGER:
      Serial.print(".");
    case FINGERPRINT_PACKETRECIEVEERR:
      Serial.println("Communication error");
    case FINGERPRINT_IMAGEFAIL:
      Serial.println("Imaging error");
    default:
      Serial.println("Unknown error");
  // OK success!
  p = finger.image2Tz(1);
  switch (p) {
      Serial.println("Image converted");
    case FINGERPRINT_IMAGEMESS:
      Serial.println("Image too messy");
      return p;
      return p;
    case FINGERPRINT_FEATUREFAIL:
      Serial.println("Could not find fingerprint features");
      return p;
    case FINGERPRINT_INVALIDIMAGE:
      return p;
    default:
      return p;
  Serial.println("Remove finger");
  delay(2000);
  p = 0;
  while (p != FINGERPRINT_NOFINGER) {
  Serial.print("ID "); Serial.println(id);
  p = -1;
  Serial.println("Place same finger again");
    switch (p) {
      Serial.print(".");
    default:
  // OK success!
  p = finger.image2Tz(2);
  switch (p) {
      return p;
      return p;
      return p;
      return p;
    default:
      return p;
  // OK converted!
  Serial.print("Creating model for #");  Serial.println(id);
  p = finger.createModel();
  if (p == FINGERPRINT_OK) {
    Serial.println("Prints matched!");
  } else if (p == FINGERPRINT_PACKETRECIEVEERR) {
    return p;
  } else if (p == FINGERPRINT_ENROLLMISMATCH) {
    Serial.println("Fingerprints did not match");
    return p;
    return p;
  p = finger.storeModel(id);
    Serial.println("Stored!");
    return p;
  } else if (p == FINGERPRINT_BADLOCATION) {
    Serial.println("Could not store in that location");
    return p;
  } else if (p == FINGERPRINT_FLASHERR) {
    Serial.println("Error writing to flash");
    return p;
    return p;
  return true;
Here's a comprehensive guide to help you diagnose and resolve the problem.
  1. Check Connections: Ensure that all connections between the NodeMCU ESP8266 and the fingerprint sensor are secure and properly wired. Even a loose connection can cause intermittent issues.
  2. Power Supply: Make sure that the NodeMCU ESP8266 is receiving an adequate power supply. Insufficient power can cause the device to malfunction or reset unexpectedly.
  3. Code Review: Review the code uploaded to the NodeMCU ESP8266. Check for any errors or issues that might be causing the problem. Pay special attention to the initialization and configuration of the fingerprint sensor.
can you please tell how much power supply should we give to the sensor
I am using R307 fingerprint sensor in creating the biometric attendance system for my college project. when i am uploading the code it is blinking . And when i am uploading the example code of adafruit fingerprint sensor library, its not working .i am using this with nodemcu esp8266 and 1.3 inch oled . and while adding the ssd1306 library display is not showing properly.
here is given code:
#include <SPI.h>
#include <Wire.h>
#include <WiFiClient.h>
#include <ESP8266WiFi.h>
#include <SoftwareSerial.h>
#include <ESP8266WebServer.h>
#include <ESP8266HTTPClient.h>
#include <Adafruit_GFX.h>          //https://github.com/adafruit/Adafruit-GFX-Library
#include <Adafruit_SSD1306.h>      //https://github.com/adafruit/Adafruit_SSD1306
#include <Adafruit_Fingerprint.h>  //https://github.com/adafruit/Adafruit-Fingerprint-Sensor-Library
//Fingerprint scanner Pins
#define Finger_Rx 14 //D5
#define Finger_Tx 12 //D6
// Declaration for SSD1306 display connected using software I2C
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET     0 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
SoftwareSerial mySerial(Finger_Rx, Finger_Tx);
/* Set these to your desired credentials. */
const char *ssid = "shikhar";  //ENTER YOUR WIFI SETTINGS
const char *password = "mai kyu batau";
String postData ; // post array that will be send to the website
String link = "http://192.168.1.86/biometric/getdata.php"; //computer IP or the server domain
int FingerID = 0;     // The Fingerprint ID from the scanner
uint8_t id;
//*************************Biometric Icons*********************************
#define Wifi_start_width 54
#define Wifi_start_height 49
const uint8_t PROGMEM Wifi_start_bits[] = {
  0x00,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x1f,0xf0,0x00,0x00,0x00
,0x00,0x03,0xff,0xff,0x80,0x00,0x00
,0x00,0x1f,0xf0,0x1f,0xf0,0x00,0x00
,0x00,0x7e,0x00,0x00,0xfc,0x00,0x00
,0x01,0xf0,0x00,0x00,0x1f,0x00,0x00
,0x03,0xc0,0x00,0x00,0x07,0xc0,0x00
,0x0f,0x00,0x00,0x00,0x01,0xe0,0x00
,0x1c,0x00,0x00,0x00,0x00,0x70,0x00
,0x38,0x00,0x07,0xc0,0x00,0x38,0x00
,0x70,0x00,0xff,0xfe,0x00,0x1e,0x00
,0xe0,0x03,0xfc,0x7f,0xc0,0x0e,0x00
,0x00,0x1f,0x80,0x03,0xf0,0x00,0x00
,0x00,0x3c,0x00,0x00,0x78,0x00,0x00
,0x00,0xf0,0x00,0x00,0x1c,0x00,0x00
,0x01,0xe0,0x00,0x00,0x0c,0x00,0x00
,0x03,0x80,0x00,0x00,0x00,0x00,0x00
,0x03,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x3f,0xf8,0x07,0x1e,0x00
,0x00,0x00,0xff,0xfe,0x1f,0xbf,0x80
,0x00,0x03,0xe0,0x04,0x7f,0xff,0xc0
,0x00,0x07,0x80,0x00,0xff,0xff,0xe0
,0x00,0x0e,0x00,0x00,0xff,0xff,0xe0
,0x00,0x0c,0x00,0x00,0x7f,0xff,0xc0
,0x00,0x00,0x00,0x00,0xfe,0x07,0xe0
,0x00,0x00,0x00,0x03,0xf8,0x03,0xf8
,0x00,0x00,0x07,0xe7,0xf9,0xf1,0xfc
,0x00,0x00,0x1f,0xe7,0xf1,0xf9,0xfc
,0x00,0x00,0x1f,0xe7,0xf3,0xf9,0xfc
,0x00,0x00,0x3f,0xe7,0xf3,0xf9,0xfc
,0x00,0x00,0x3f,0xe7,0xf1,0xf1,0xfc
,0x00,0x00,0x3f,0xe3,0xf8,0xe3,0xfc
,0x00,0x00,0x3f,0xf3,0xfc,0x07,0xf8
,0x00,0x00,0x1f,0xf0,0x7f,0x0f,0xc0
,0x00,0x00,0x0f,0xe0,0x7f,0xff,0xe0
,0x00,0x00,0x07,0xc0,0xff,0xff,0xe0
,0x00,0x00,0x00,0x00,0x7f,0xff,0xe0
,0x00,0x00,0x00,0x00,0x3f,0xff,0x80
,0x00,0x00,0x00,0x00,0x1f,0xbf,0x00
,0x00,0x00,0x00,0x00,0x03,0x18,0x00
#define Wifi_connected_width 63
#define Wifi_connected_height 49
const uint8_t PROGMEM Wifi_connected_bits[] = {
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x03,0xff,0xff,0x80,0x00,0x00
,0x00,0x00,0x3f,0xff,0xff,0xf8,0x00,0x00
,0x00,0x01,0xff,0xff,0xff,0xff,0x00,0x00
,0x00,0x0f,0xff,0xff,0xff,0xff,0xe0,0x00
,0x00,0x3f,0xff,0xc0,0x07,0xff,0xf8,0x00
,0x00,0xff,0xf8,0x00,0x00,0x3f,0xfe,0x00
,0x03,0xff,0x80,0x00,0x00,0x03,0xff,0x80
,0x07,0xfe,0x00,0x00,0x00,0x00,0xff,0xc0
,0x1f,0xf8,0x00,0x00,0x00,0x00,0x3f,0xf0
,0x3f,0xe0,0x01,0xff,0xff,0x00,0x0f,0xf8
,0x7f,0x80,0x0f,0xff,0xff,0xe0,0x03,0xfc
,0xff,0x00,0x7f,0xff,0xff,0xfc,0x01,0xfe
,0xfc,0x01,0xff,0xff,0xff,0xff,0x00,0x7e
,0x78,0x07,0xff,0xc0,0x07,0xff,0xc0,0x3c
,0x00,0x0f,0xfc,0x00,0x00,0x7f,0xe0,0x00
,0x00,0x1f,0xf0,0x00,0x00,0x1f,0xf0,0x00
,0x00,0x3f,0xc0,0x00,0x00,0x07,0xf8,0x00
,0x00,0x7f,0x00,0x01,0x00,0x01,0xfc,0x00
,0x00,0x7e,0x00,0x7f,0xfc,0x00,0xfc,0x00
,0x00,0x3c,0x03,0xff,0xff,0x80,0x78,0x00
,0x00,0x00,0x07,0xff,0xff,0xc0,0x00,0x00
,0x00,0x00,0x1f,0xff,0xff,0xf0,0x00,0x00
,0x00,0x00,0x3f,0xf0,0x1f,0xf8,0x00,0x00
,0x00,0x00,0x3f,0x80,0x03,0xf8,0x00,0x00
,0x00,0x00,0x3f,0x00,0x01,0xf8,0x00,0x00
,0x00,0x00,0x1c,0x00,0x00,0x70,0x00,0x00
,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x0f,0xe0,0x00,0x00,0x00
,0x00,0x00,0x00,0x1f,0xf0,0x00,0x00,0x00
,0x00,0x00,0x00,0x3f,0xf8,0x00,0x00,0x00
#define FinPr_start_width 64
#define FinPr_start_height 64
const uint8_t PROGMEM FinPr_start_bits[] = {
  0x00,0x00,0x00,0x1f,0xe0,0x00,0x00,0x00
,0x00,0x00,0x01,0xff,0xfe,0x00,0x00,0x00
,0x00,0x00,0x0f,0xc0,0x0f,0xe0,0x00,0x00
,0x00,0x00,0x1f,0x00,0x01,0xf8,0x00,0x00
,0x00,0x00,0x3c,0x00,0x00,0x7c,0x00,0x00
,0x00,0x00,0x78,0x00,0x00,0x3e,0x00,0x00
,0x00,0x00,0xf0,0x3f,0xf8,0x0f,0x00,0x00
,0x00,0x01,0xe0,0xff,0xfe,0x07,0x80,0x00
,0x00,0x03,0xc3,0xff,0xff,0x03,0x80,0x00
,0x00,0x03,0x87,0xc0,0x07,0xc3,0xc0,0x00
,0x00,0x07,0x0f,0x00,0x03,0xe1,0xc0,0x00
,0x00,0x0f,0x0e,0x00,0x00,0xe0,0xe0,0x00
,0x00,0x0e,0x1c,0x00,0x00,0xf0,0xe0,0x00
,0x00,0x0c,0x3c,0x1f,0xe0,0x70,0xe0,0x00
,0x00,0x00,0x38,0x3f,0xf0,0x38,0x70,0x00
,0x00,0x00,0x78,0x78,0xf8,0x38,0x70,0x00
,0x00,0x00,0x70,0x70,0x3c,0x18,0x70,0x00
,0x00,0x00,0xe0,0xe0,0x1e,0x1c,0x70,0x00
,0x00,0x03,0xe1,0xe0,0x0e,0x1c,0x70,0x00
,0x00,0x0f,0xc1,0xc3,0x0e,0x1c,0x70,0x00
,0x00,0x3f,0x03,0xc3,0x8e,0x1c,0x70,0x00
,0x00,0x3e,0x03,0x87,0x0e,0x1c,0x70,0x00
,0x00,0x30,0x07,0x07,0x0e,0x18,0xe0,0x00
,0x00,0x00,0x0e,0x0e,0x0e,0x38,0xe0,0x00
,0x00,0x00,0x3e,0x1e,0x1e,0x38,0xe0,0x00
,0x00,0x00,0xf8,0x1c,0x1c,0x38,0xe0,0x00
,0x00,0x03,0xf0,0x38,0x3c,0x38,0xe0,0x00
,0x00,0x3f,0xc0,0xf8,0x78,0x38,0xe0,0x00
,0x00,0x7f,0x01,0xf0,0x70,0x38,0xf0,0x00
,0x00,0x78,0x03,0xe0,0xe0,0x38,0x70,0x00
,0x00,0x00,0x0f,0x81,0xe0,0x38,0x7c,0x00
,0x00,0x00,0x3f,0x03,0xc0,0x38,0x3e,0x00
,0x00,0x00,0xfc,0x0f,0x80,0x38,0x1e,0x00
,0x00,0x07,0xf0,0x1f,0x1c,0x1c,0x04,0x00
,0x00,0x3f,0xc0,0x3e,0x3f,0x1e,0x00,0x00
,0x00,0x7f,0x00,0xf8,0x7f,0x0f,0x00,0x00
,0x00,0x38,0x01,0xf0,0xf7,0x07,0xc0,0x00
,0x00,0x00,0x07,0xe1,0xe3,0x83,0xf8,0x00
,0x00,0x00,0x3f,0x87,0xc3,0xc0,0xfc,0x00
,0x00,0x01,0xfe,0x0f,0x81,0xe0,0x3c,0x00
,0x00,0x0f,0xf8,0x1f,0x00,0xf0,0x00,0x00
,0x00,0x1f,0xc0,0x7c,0x00,0x7c,0x00,0x00
,0x00,0x1e,0x01,0xf8,0x00,0x3f,0x00,0x00
,0x00,0x00,0x07,0xe0,0x78,0x0f,0xc0,0x00
,0x00,0x00,0x3f,0x81,0xfe,0x07,0xf0,0x00
,0x00,0x01,0xfe,0x07,0xff,0x01,0xf0,0x00
,0x00,0x07,0xf8,0x0f,0x87,0x80,0x30,0x00
,0x00,0x07,0xc0,0x3f,0x03,0xe0,0x00,0x00
,0x00,0x06,0x00,0xfc,0x01,0xf8,0x00,0x00
,0x00,0x00,0x03,0xf0,0x00,0x7e,0x00,0x00
,0x00,0x00,0x0f,0xc0,0x00,0x3f,0x80,0x00
,0x00,0x00,0x7f,0x00,0xf8,0x0f,0x80,0x00
,0x00,0x00,0xfc,0x03,0xfe,0x01,0x80,0x00
,0x00,0x00,0xf0,0x1f,0xff,0x80,0x00,0x00
,0x00,0x00,0x00,0x7f,0x07,0xe0,0x00,0x00
,0x00,0x00,0x00,0xfc,0x03,0xf8,0x00,0x00
,0x00,0x00,0x03,0xf0,0x00,0x78,0x00,0x00
,0x00,0x00,0x0f,0xc0,0x00,0x18,0x00,0x00
,0x00,0x00,0x0f,0x01,0xf8,0x00,0x00,0x00
,0x00,0x00,0x00,0x07,0xfe,0x00,0x00,0x00
,0x00,0x00,0x00,0x1f,0xfe,0x00,0x00,0x00
,0x00,0x00,0x00,0x1e,0x0e,0x00,0x00,0x00
,0x00,0x00,0x00,0x18,0x00,0x00,0x00,0x00
#define FinPr_valid_width 64
#define FinPr_valid_height 64
const uint8_t PROGMEM FinPr_valid_bits[] = {
  0x00,0x00,0x03,0xfe,0x00,0x00,0x00,0x00
,0x00,0x00,0x1f,0xff,0xe0,0x00,0x00,0x00
,0x00,0x00,0x7f,0xff,0xf8,0x00,0x00,0x00
,0x00,0x00,0xfc,0x00,0xfe,0x00,0x00,0x00
,0x00,0x03,0xe0,0x00,0x1f,0x00,0x00,0x00
,0x00,0x07,0xc0,0x00,0x07,0x80,0x00,0x00
,0x00,0x0f,0x80,0x00,0x03,0xe0,0x00,0x00
,0x00,0x0e,0x03,0xff,0x01,0xe0,0x00,0x00
,0x00,0x1c,0x1f,0xff,0xe0,0xf0,0x00,0x00
,0x00,0x3c,0x3f,0xff,0xf0,0x78,0x00,0x00
,0x00,0x78,0x7c,0x00,0xf8,0x3c,0x00,0x00
,0x00,0x70,0xf0,0x00,0x3c,0x1c,0x00,0x00
,0x00,0xe1,0xe0,0x00,0x1e,0x1c,0x00,0x00
,0x00,0xe1,0xc0,0x00,0x0f,0x0e,0x00,0x00
,0x00,0xc3,0x81,0xfc,0x07,0x0e,0x00,0x00
,0x00,0x03,0x83,0xff,0x07,0x8e,0x00,0x00
,0x00,0x07,0x07,0x8f,0x83,0x87,0x00,0x00
,0x00,0x0f,0x0f,0x03,0xc3,0x87,0x00,0x00
,0x00,0x1e,0x0e,0x01,0xc3,0x87,0x00,0x00
,0x00,0x3c,0x1c,0x00,0xe1,0x87,0x00,0x00
,0x00,0xf8,0x1c,0x30,0xe1,0x87,0x00,0x00
,0x07,0xf0,0x38,0x70,0xe1,0x86,0x00,0x00
,0x07,0xc0,0x78,0x70,0xe3,0x8e,0x00,0x00
,0x02,0x00,0xf0,0xf0,0xe3,0x8e,0x00,0x00
,0x00,0x01,0xe0,0xe0,0xe3,0x8e,0x00,0x00
,0x00,0x03,0xc1,0xe1,0xc3,0x8e,0x00,0x00
,0x00,0x0f,0x83,0xc3,0xc3,0x8e,0x00,0x00
,0x00,0x7f,0x07,0x83,0x83,0x0e,0x00,0x00
,0x07,0xfc,0x0f,0x07,0x83,0x0e,0x00,0x00
,0x07,0xf0,0x1e,0x0f,0x03,0x0e,0x00,0x00
,0x07,0x80,0x7c,0x1e,0x03,0x07,0x00,0x00
,0x00,0x00,0xf8,0x3c,0x03,0x87,0x80,0x00
,0x00,0x03,0xf0,0x78,0x03,0x83,0xc0,0x00
,0x00,0x1f,0xc0,0xf0,0x02,0x00,0x00,0x00
,0x00,0xff,0x01,0xe1,0xc0,0x0c,0x00,0x00
,0x07,0xfc,0x03,0xc3,0xe1,0xff,0xc0,0x00
,0x07,0xe0,0x0f,0x87,0xc7,0xff,0xf0,0x00
,0x07,0x00,0x3f,0x0f,0x0f,0xff,0xfc,0x00
,0x00,0x00,0x7c,0x3e,0x3f,0xff,0xfe,0x00
,0x00,0x03,0xf8,0x7c,0x3f,0xff,0xff,0x00
,0x00,0x1f,0xe0,0xf0,0x7f,0xff,0xff,0x80
,0x00,0xff,0x83,0xe0,0xff,0xff,0xff,0x80
,0x01,0xfc,0x07,0xc1,0xff,0xff,0xe3,0xc0
,0x01,0xe0,0x1f,0x01,0xff,0xff,0xc3,0xc0
,0x00,0x00,0xfe,0x01,0xff,0xff,0x87,0xe0
,0x00,0x03,0xf8,0x13,0xff,0xff,0x0f,0xe0
,0x00,0x1f,0xe0,0x73,0xff,0xfe,0x1f,0xe0
,0x00,0x7f,0x81,0xf3,0xff,0xfc,0x1f,0xe0
,0x00,0xfc,0x03,0xe3,0xef,0xf8,0x3f,0xe0
,0x00,0x60,0x0f,0xc3,0xc7,0xf0,0x7f,0xe0
,0x00,0x00,0x3f,0x03,0xc3,0xe0,0xff,0xe0
,0x00,0x00,0xfc,0x03,0xc1,0xc1,0xff,0xe0
,0x00,0x07,0xf0,0x13,0xe0,0x83,0xff,0xe0
,0x00,0x0f,0xc0,0x7b,0xf8,0x07,0xff,0xe0
,0x00,0x0f,0x01,0xf9,0xfc,0x0f,0xff,0xc0
,0x00,0x00,0x07,0xf1,0xfe,0x1f,0xff,0xc0
,0x00,0x00,0x1f,0xc0,0xff,0x3f,0xff,0x80
,0x00,0x00,0x7e,0x00,0xff,0xff,0xff,0x80
,0x00,0x00,0xfc,0x00,0x7f,0xff,0xff,0x00
,0x00,0x00,0xf0,0x1f,0x3f,0xff,0xfe,0x00
,0x00,0x00,0x00,0x7f,0x1f,0xff,0xfc,0x00
,0x00,0x00,0x01,0xff,0x8f,0xff,0xf8,0x00
,0x00,0x00,0x03,0xe0,0xe3,0xff,0xe0,0x00
,0x00,0x00,0x01,0x80,0x00,0x7f,0x00,0x00
#define FinPr_invalid_width 64
#define FinPr_invalid_height 64
const uint8_t PROGMEM FinPr_invalid_bits[] = {
,0x00,0xff,0x01,0xe1,0xc0,0x00,0x00,0x00
,0x07,0x00,0x3f,0x0f,0x0f,0xff,0xf8,0x00
,0x00,0x00,0x7c,0x3e,0x1f,0xff,0xfe,0x00
,0x00,0x1f,0xe0,0xf0,0x7f,0xff,0xff,0x00
,0x00,0xff,0x83,0xe0,0xfe,0xff,0xbf,0x80
,0x01,0xfc,0x07,0xc0,0xfc,0x7f,0x1f,0xc0
,0x01,0xe0,0x1f,0x01,0xf8,0x3e,0x0f,0xc0
,0x00,0x00,0xfe,0x01,0xf8,0x1c,0x07,0xe0
,0x00,0x03,0xf8,0x13,0xf8,0x00,0x0f,0xe0
,0x00,0x1f,0xe0,0x73,0xfc,0x00,0x1f,0xe0
,0x00,0x7f,0x81,0xf3,0xfe,0x00,0x3f,0xe0
,0x00,0xfc,0x03,0xe3,0xff,0x00,0x7f,0xe0
,0x00,0x60,0x0f,0xc3,0xff,0x80,0xff,0xe0
,0x00,0x00,0x3f,0x03,0xff,0x00,0x7f,0xe0
,0x00,0x00,0xfc,0x03,0xfe,0x00,0x3f,0xe0
,0x00,0x07,0xf0,0x13,0xfc,0x00,0x1f,0xe0
,0x00,0x0f,0xc0,0x79,0xf8,0x08,0x0f,0xe0
,0x00,0x0f,0x01,0xf9,0xf8,0x1c,0x0f,0xc0
,0x00,0x00,0x07,0xf1,0xfc,0x3e,0x1f,0xc0
,0x00,0x00,0x1f,0xc0,0xfe,0x7f,0x3f,0x80
#define FinPr_failed_width 64
#define FinPr_failed_height 64
const uint8_t PROGMEM FinPr_failed_bits[] = {
0x00,0x00,0x3f,0xe0,0x00,0x00,0x00,0x00
,0x00,0x01,0xff,0xfe,0x00,0x00,0x00,0x00
,0x00,0x0f,0xc0,0x1f,0x80,0x00,0x00,0x00
,0x00,0x1e,0x00,0x03,0xc0,0x00,0x00,0x00
,0x00,0x78,0x00,0x00,0xf0,0x00,0x00,0x00
,0x00,0xe0,0x00,0x00,0x38,0x00,0x00,0x00
,0x01,0xc0,0x00,0x00,0x1c,0x00,0x00,0x00
,0x03,0x80,0x00,0x00,0x0e,0x00,0x00,0x00
,0x07,0x00,0x7f,0xe0,0x07,0x00,0x00,0x00
,0x06,0x01,0xff,0xf8,0x03,0x00,0x00,0x00
,0x0c,0x03,0xc0,0x3c,0x03,0x80,0x00,0x00
,0x1c,0x0f,0x00,0x0e,0x01,0x80,0x00,0x00
,0x18,0x0c,0x00,0x03,0x00,0xc0,0x00,0x00
,0x18,0x18,0x00,0x01,0x80,0xc0,0x00,0x00
,0x30,0x38,0x00,0x01,0xc0,0xe0,0x00,0x00
,0x30,0x30,0x0f,0x00,0xc0,0x60,0x00,0x00
,0x30,0x30,0x3f,0xc0,0xe0,0x60,0x00,0x00
,0x70,0x60,0x78,0xe0,0x60,0x60,0x00,0x00
,0x60,0x60,0x60,0x60,0x60,0x70,0x00,0x00
,0x60,0x60,0x60,0x60,0x60,0x30,0x00,0x00
,0x60,0x60,0x60,0x60,0x30,0x30,0x00,0x00
,0x60,0x60,0x60,0x30,0x30,0x20,0x00,0x00
,0x60,0x60,0x60,0x30,0x30,0x01,0xe0,0x00
,0x60,0x60,0x60,0x30,0x30,0x0f,0xfc,0x00
,0x60,0x60,0x60,0x30,0x30,0x3f,0xff,0x00
,0x60,0x60,0x60,0x30,0x18,0x78,0x03,0x80
,0x60,0x60,0x60,0x30,0x1c,0x60,0x01,0x80
,0x60,0x60,0x30,0x38,0x0c,0xc0,0x00,0xc0
,0x00,0x60,0x30,0x18,0x00,0xc0,0x00,0xc0
,0x00,0xe0,0x30,0x0c,0x01,0xc0,0x00,0xe0
,0x00,0xc0,0x18,0x0e,0x01,0xc0,0x00,0xe0
,0x60,0xc0,0x18,0x07,0x01,0xc0,0x00,0xe0
,0x01,0xc0,0x1c,0x03,0x81,0xc0,0x00,0xe0
,0x01,0x80,0x0c,0x01,0xc1,0xc0,0x00,0xe0
,0x03,0x80,0x0e,0x00,0xf1,0xc0,0x00,0xe0
,0x0f,0x00,0x06,0x00,0x01,0xc0,0x00,0xe0
,0x3e,0x01,0x03,0x00,0x01,0xc0,0x00,0xe0
,0x30,0x03,0x83,0x80,0x1f,0xff,0xff,0xfe
,0x00,0x03,0x81,0xc0,0x3f,0xff,0xff,0xff
,0x00,0x07,0xc0,0xe0,0x30,0x00,0x00,0x03
,0x00,0x0e,0xc0,0x78,0x30,0x00,0x00,0x03
,0x00,0x3c,0x60,0x1e,0x30,0x00,0x00,0x03
,0x00,0x78,0x70,0x0f,0x30,0x00,0x00,0x03
,0x03,0xe0,0x38,0x03,0x30,0x00,0x00,0x03
,0x07,0x80,0x1c,0x00,0x30,0x00,0x00,0x03
,0xc0,0x00,0x0f,0x00,0x30,0x00,0x00,0x03
,0xc0,0x00,0x03,0x80,0x30,0x01,0xe0,0x03
,0x00,0x18,0x01,0xe0,0x30,0x03,0xf0,0x03
,0x00,0x18,0x00,0x7c,0x30,0x07,0x38,0x03
,0x00,0x0c,0x00,0x1f,0x30,0x06,0x18,0x03
,0x18,0x0e,0x00,0x07,0x30,0x06,0x18,0x03
,0x0c,0x07,0x80,0x00,0x30,0x07,0x38,0x03
,0x0e,0x03,0xc0,0x00,0x30,0x03,0x30,0x03
,0x07,0x00,0xf0,0x00,0x30,0x03,0x30,0x03
,0x03,0x00,0x7e,0x00,0x30,0x03,0x30,0x03
,0x01,0x80,0x1f,0xc0,0x30,0x03,0x30,0x03
,0x01,0xc0,0x03,0xe1,0x30,0x07,0xf8,0x03
,0x00,0xf0,0x00,0x01,0x30,0x03,0xf0,0x03
,0x00,0x38,0x00,0x00,0x30,0x00,0x00,0x03
,0x00,0x1e,0x00,0x00,0x30,0x00,0x00,0x03
,0x00,0x07,0xc0,0x00,0x30,0x00,0x00,0x03
,0x00,0x01,0xff,0x80,0x3f,0xff,0xff,0xff
,0x00,0x00,0x3f,0x80,0x1f,0xff,0xff,0xfe
#define FinPr_scan_width 64
#define FinPr_scan_height 64
const uint8_t PROGMEM FinPr_scan_bits[] = {
,0x00,0x00,0x00,0x1f,0xf8,0x00,0x00,0x00
,0x00,0x00,0x00,0x7f,0xff,0x00,0x00,0x00
,0x00,0x00,0x01,0xfc,0x7f,0xc0,0x00,0x00
,0x00,0x00,0x03,0xc0,0x03,0xe0,0x00,0x00
,0x00,0x00,0x07,0x80,0x00,0xf0,0x00,0x00
,0x00,0x00,0x0e,0x00,0x00,0x3c,0x00,0x00
,0x00,0x00,0x1c,0x1f,0xfc,0x1c,0x00,0x00
,0x00,0x00,0x38,0x7f,0xfe,0x0e,0x00,0x00
,0x00,0x00,0x78,0xf8,0x0f,0x87,0x00,0x00
,0x00,0x00,0x71,0xe0,0x03,0xc7,0x00,0x00
,0x00,0x00,0xe3,0x80,0x01,0xc3,0x80,0x00
,0x00,0x00,0xc3,0x83,0xc0,0xe3,0x80,0x00
,0x00,0x00,0xc7,0x0f,0xf0,0x71,0x80,0x00
,0x00,0x00,0x06,0x1f,0xf8,0x71,0xc0,0x00
,0x00,0x00,0x0e,0x1c,0x3c,0x31,0xc0,0x00
,0x00,0x00,0x1c,0x38,0x1c,0x31,0xc0,0x00
,0x00,0x00,0x38,0x70,0x0e,0x39,0xc0,0x00
,0x00,0x01,0xf0,0x71,0x8e,0x39,0xc0,0x00
,0x00,0x03,0xe0,0xe1,0x86,0x31,0xc0,0x00
,0x00,0x03,0x81,0xe3,0x8e,0x31,0x80,0x00
,0x00,0x00,0x03,0xc3,0x8e,0x33,0x80,0x00
,0x00,0x00,0x07,0x87,0x0c,0x73,0x80,0x00
,0x00,0x00,0x1f,0x0e,0x1c,0x73,0x80,0x00
,0x7f,0xff,0xff,0xff,0xff,0xff,0xff,0xfe
,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff
,0x00,0x03,0xf0,0x1e,0x3e,0x1c,0x00,0x00
,0x00,0x03,0x80,0x7c,0x77,0x0f,0x00,0x00
,0x00,0x00,0x01,0xf0,0xe3,0x07,0xc0,0x00
,0x00,0x00,0x07,0xe3,0xc3,0x81,0xf0,0x00
,0x00,0x00,0x3f,0x87,0x81,0xc0,0x60,0x00
,0x00,0x01,0xfc,0x1f,0x00,0xf0,0x00,0x00
,0x00,0x01,0xe0,0x3c,0x00,0x7c,0x00,0x00
,0x00,0x00,0x00,0xf8,0x78,0x1f,0x00,0x00
,0x00,0x00,0x07,0xe0,0xfc,0x0f,0xc0,0x00
,0x00,0x00,0x3f,0x83,0xef,0x03,0xc0,0x00
,0x00,0x00,0xfc,0x0f,0x87,0x80,0x00,0x00
,0x00,0x00,0x70,0x1f,0x03,0xe0,0x00,0x00
,0x00,0x00,0x00,0x7c,0x00,0xf8,0x00,0x00
,0x00,0x00,0x01,0xf0,0x00,0x3e,0x00,0x00
,0x00,0x00,0x0f,0xc0,0xf8,0x0f,0x00,0x00
,0x00,0x00,0x1f,0x03,0xfe,0x02,0x00,0x00
,0x00,0x00,0x0c,0x0f,0x8f,0x80,0x00,0x00
,0x00,0x00,0x00,0x3f,0x03,0xe0,0x00,0x00
,0x00,0x00,0x00,0xf8,0x00,0xf0,0x00,0x00
,0x00,0x00,0x01,0xe0,0x00,0x30,0x00,0x00
,0x00,0x00,0x01,0xc0,0xf8,0x00,0x00,0x00
,0x00,0x00,0x00,0x0f,0x8e,0x00,0x00,0x00
,0x00,0x00,0x00,0x06,0x00,0x00,0x00,0x00
  //-----------initiate OLED display-------------
  // SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
  if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
    Serial.println(F("SSD1306 allocation failed"));
    for(;;); // Don't proceed, loop forever
  // Show initial display buffer contents on the screen --
  // the library initializes this with an Adafruit splash screen.
  // you can delet these three lines if you don't want to get the Adfruit logo appear
  display.display();
  delay(2000); // Pause for 2 seconds
  display.clearDisplay();
  connectToWiFi();
  Serial.println("\n\nAdafruit finger detect test");
    display.drawBitmap( 34, 0, FinPr_valid_bits, FinPr_valid_width, FinPr_valid_height, WHITE);
    display.display();
    display.drawBitmap( 32, 0, FinPr_failed_bits, FinPr_failed_width, FinPr_failed_height, WHITE);
    display.display();
  finger.getTemplateCount();
  Serial.print("Sensor contains "); Serial.print(finger.templateCount); Serial.println(" templates");
  Serial.println("Waiting for valid finger...");
  //------------*test the connection*------------
  //SendFingerprintID( FingerID );
  //check if there's a connection to WiFi or not
  if(WiFi.status() != WL_CONNECTED){
    connectToWiFi();
  //If there no fingerprint has been scanned return -1 or -2 if there an error or 0 if there nothing, The ID start form 1 to 127
  FingerID = getFingerprintID();  // Get the Fingerprint ID from the Scanner
  delay(50);            //don't need to run this at full speed.
  DisplayFingerprintID();
  ChecktoAddID();
  ChecktoDeleteID();
//************Display the fingerprint ID state on the OLED*************
void DisplayFingerprintID(){
  //Fingerprint has been detected
  if (FingerID > 0){
    display.display();
    SendFingerprintID( FingerID ); // Send the Fingerprint ID to the website.
  //No finger detected
  else if (FingerID == 0){
    display.drawBitmap( 32, 0, FinPr_start_bits, FinPr_start_width, FinPr_start_height, WHITE);
    display.display();
  //Didn't find a match
  else if (FingerID == -1){
    display.drawBitmap( 34, 0, FinPr_invalid_bits, FinPr_invalid_width, FinPr_invalid_height, WHITE);
    display.display();
  //Didn't find the scanner or there an error
  else if (FingerID == -2){
    display.display();
//************send the fingerprint ID to the website*************
void SendFingerprintID( int finger ){
  WiFiClient client;
  HTTPClient http;
     //Declare object of class HTTPClient
  //Post Data
  postData = "FingerID=" + String(finger); // Add the Fingerprint ID to the Post array in order to send it
  // Post methode
  http.begin(client,link); //initiate HTTP request, put your Website URL or Your Computer IP
  http.addHeader("Content-Type", "application/x-www-form-urlencoded");    //Specify content-type header
  int httpCode = http.POST(postData);   //Send the request
  String payload = http.getString();    //Get the response payload
  Serial.println(httpCode);   //Print HTTP return code
  Serial.println(payload);    //Print request response payload
  Serial.println(postData);   //Post Data
  Serial.println(finger);     //Print fingerprint ID
  if (payload.substring(0, 5) == "login") {
    String user_name = payload.substring(5);
//  Serial.println(user_name);
    display.setTextSize(2);             // Normal 2:2 pixel scale
    display.setTextColor(WHITE);        // Draw white text
    display.setCursor(15,0);             // Start at top-left corner
    display.print(F("Welcome"));
    display.setCursor(0,20);
    display.print(user_name);
    display.display();
  else if (payload.substring(0, 6) == "logout") {
    String user_name = payload.substring(6);
    display.setCursor(10,0);             // Start at top-left corner
    display.print(F("Good Bye"));
    display.display();
  postData = "";
  http.end();  //Close connection
//********************Get the Fingerprint ID******************
int getFingerprintID() {
  uint8_t p = finger.getImage();
  switch (p) {
      //Serial.println("Image taken");
      //Serial.println("No finger detected");
      return 0;
      //Serial.println("Communication error");
      return -2;
      //Serial.println("Imaging error");
      return -2;
    default:
      //Serial.println("Unknown error");
      return -2;
  // OK success!
  p = finger.image2Tz();
  switch (p) {
      //Serial.println("Image converted");
      //Serial.println("Image too messy");
      return -1;
      return -2;
      //Serial.println("Could not find fingerprint features");
      return -2;
      return -2;
    default:
      return -2;
  // OK converted!
  p = finger.fingerFastSearch();
    //Serial.println("Found a print match!");
    return -2;
  } else if (p == FINGERPRINT_NOTFOUND) {
    //Serial.println("Did not find a match");
    return -1;
    return -2;
  // found a match!
  //Serial.print("Found ID #"); Serial.print(finger.fingerID);
  //Serial.print(" with confidence of "); Serial.println(finger.confidence);
  return finger.fingerID;
//******************Check if there a Fingerprint ID to delete******************
void ChecktoDeleteID(){
  WiFiClient client;
  HTTPClient http;    //Declare object of class HTTPClient
  //Post Data
  postData = "DeleteID=check"; // Add the Fingerprint ID to the Post array in order to send it
  // Post methode
  if (payload.substring(0, 6) == "del-id") {
    String del_id = payload.substring(6);
    Serial.println(del_id);
    deleteFingerprint( del_id.toInt() );
//******************Delete Finpgerprint ID*****************
uint8_t deleteFingerprint( int id) {
  uint8_t p = -1;
  p = finger.deleteModel(id);
    //Serial.println("Deleted!");
    display.setCursor(0,0);             // Start at top-left corner
    display.print(F("Deleted!\n"));
    display.display();
    return p;
    display.setTextSize(1);             // Normal 1:1 pixel scale
    display.print(F("Communication error!\n"));
    display.display();
    return p;
    //Serial.println("Could not delete in that location");
    display.print(F("Could not delete in that location!\n"));
    display.display();
    return p;
    //Serial.println("Error writing to flash");
    display.print(F("Error writing to flash!\n"));
    display.display();
    return p;
    //Serial.print("Unknown error: 0x"); Serial.println(p, HEX);
    display.print(F("Unknown error:\n"));
    display.display();
    return p;
//******************Check if there a Fingerprint ID to add******************
void ChecktoAddID(){
  WiFiClient client;
  //Post Data
  postData = "Get_Fingerid=get_id"; // Add the Fingerprint ID to the Post array in order to send it
  // Post methode
  if (payload.substring(0, 6) == "add-id") {
    String add_id = payload.substring(6);
    Serial.println(add_id);
    id = add_id.toInt();
    getFingerprintEnroll();
//******************Enroll a Finpgerprint ID*****************
  int p = -1;
  display.drawBitmap( 34, 0, FinPr_scan_bits, FinPr_scan_width, FinPr_scan_height, WHITE);
  display.display();
    switch (p) {
      display.display();
      //Serial.println(".");
      display.setTextSize(1);             // Normal 2:2 pixel scale
      display.print(F("scanning"));
      display.display();
      display.display();
    default:
  // OK success!
  switch (p) {
      display.display();
      display.display();
      return p;
      return p;
      return p;
      return p;
    default:
      return p;
  display.print(F("Remove"));
  display.print(F("finger"));
  display.display();
  //Serial.println("Remove finger");
  delay(2000);
  p = 0;
  p = -1;
  display.display();
    switch (p) {
      display.display();
      display.display();
    default:
  // OK success!
  switch (p) {
      display.display();
      return p;
      return p;
      return p;
      return p;
    default:
      return p;
  // OK converted!
    //Serial.println("Prints matched!");
    display.display();
    return p;
    return p;
    return p;
    return p;
    //Serial.println("Stored!");
    display.display();
    confirmAdding();
    return p;
    return p;
    return p;
    return p;
void confirmAdding(){
  WiFiClient client;
  //Post Data
  postData = "confirm_id=" + String(id); // Add the Fingerprint ID to the Post array in order to send it
  // Post methode
  display.setTextSize(1.5);             // Normal 1:1 pixel scale
  display.print(payload);
  display.display();
//********************connect to the WiFi******************
void connectToWiFi(){
    WiFi.mode(WIFI_OFF);        //Prevents reconnection issue (taking too long to connect)
    WiFi.mode(WIFI_STA);
    Serial.print("Connecting to ");
    Serial.println(ssid);
    WiFi.begin(ssid, password);
    display.setCursor(0, 0);             // Start at top-left corner
    display.print(F("Connecting to \n"));
    display.setCursor(0, 50);
    display.print(ssid);
    display.drawBitmap( 73, 10, Wifi_start_bits, Wifi_start_width, Wifi_start_height, WHITE);
    display.display();
      Serial.print(".");
    Serial.println("");
    Serial.println("Connected");
    display.setTextSize(2);             // Normal 1:1 pixel scale
    display.setCursor(8, 0);             // Start at top-left corner
    display.print(F("Connected \n"));
    display.drawBitmap( 33, 15, Wifi_connected_bits, Wifi_connected_width, Wifi_connected_height, WHITE);
    display.display();
    Serial.print("IP address: ");
    Serial.println(WiFi.localIP());  //IP address assigned to your ESP
this is backside of fingerprint sensor . please anyone can tell me pins datasheet.
Is there anychance i am not giving it anyother voltage. i am only using the laptop's power . can it be the problem.
And this display how it is showing content .
That's nor clear. Try to explain using another way. Does the upload crash or what?
What is blinkning?
Unclear, tells nothing useful.
Thanks.
Posting schematics is requested.
I am making a biometric attendance system . When i am uploading the given code . R307 fingerprint just starts blinking in delay of 5-7 seconds . And my oled display starts showing content only in a strip (row). how can i solve that error .The picture i have already uploaded.
schematic :
pin connection-
()R307-------------- esp8266
5v------------------ external 5v
Ground ----------ground
Tx ------------------D5
Rx ------------------D6
()display-------------- ESP8266
Ground------------- ground
VCC ------------------3v3
SCK------------------- D1
SDA------------------- D2
Use the first 4 pins
That's not schematics.
yes i connected as shown in the image but still display and sensor is not working .properly .
can you please review these lines .
  WiFiClient client;
  //Post Data
  // Post methode
please review the code once.
i want change the library from SSD1306 to SH110X what changes should i do in given code .
reason of change: because while using ss1306 library only 20% part of the led is working rest is showing the noise.
Can anyone tell me what changes should i do for changing the SH110x / SH1106G library..
#include <SPI.h>
#include <Wire.h>
// #include <Adafruit_SH110X.h>
// Adafruit_SH1106G display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
String postData ;
int FingerID = 0;
uint8_t id;
  display.display();
  connectToWiFi();
    display.display();
    display.display();
    connectToWiFi();
  delay(50);
  ChecktoAddID();
  ChecktoDeleteID();
  if (FingerID > 0){
    display.display();
    display.display();
    display.display();
    display.display();
  WiFiClient client;
  HTTPClient http;
    display.display();
    display.display();
  postData = "";
  switch (p) {
      return 0;
      return -2;
      return -2;
    default:
      return -2;
  // OK success!
  switch (p) {
      return -1;
      return -2;
      return -2;
      return -2;
    default:
      return -2;
  // OK converted!
    return -2;
    return -1;
    return -2;
  // found a match!
  WiFiClient client;
  //Post Data
  // Post method
  uint8_t p = -1;
    display.display();
    return 0;
    display.display();
    return p;
    display.display();
    return p;
    display.display();
    return p;
    display.display();
    return p;
  WiFiClient client;
  //Post Data
  // Post methode
  int p = -1;
  display.display();
    switch (p) {
      display.display();
      display.display();
      display.display();
    default:
  // OK success!
  switch (p) {
      display.display();
      display.display();
      return p;
      return p;
      return p;
      return p;
    default:
      return p;
  display.display();
  delay(2000);
  p = 0;
  p = -1;
  display.display();
    switch (p) {
      display.display();
      display.display();
    default:
  // OK success!
  switch (p) {
      display.display();
      return p;
      return p;
      return p;
      return p;
    default:
      return p;
  // OK converted!
    display.display();
    return p;
    return p;
    return p;
    display.display();
    confirmAdding();
    return p ;
    return p;
    return p;
    return p;
    return p;
  WiFiClient client;
  //Post Data
  // Post methode
  display.display();
    display.display();
      Serial.print(".");
    Serial.println("");
    display.display();
This is usually caused by writing outside the screen buffer or running out of memory. When you compile the sketch, what does the report show in the Output Monitor?
i have bought a 1.3 inch oled display . After uploading the example code in nodemcu esp8266 . only content is showing in a strip . all pixels are not showing the content . other pixels are like dot dot . please help me solve this error.
Please help us to help you solve this error!
Post the code you are using and a link to the specs of the OLED.
Read the forum guide so that you know how to post those things correctly.
 This is an example for our Monochrome OLEDs based on SSD1306 drivers
 Pick one up today in the adafruit shop!
 ------> http://www.adafruit.com/category/63_98
 This example is for a 128x64 pixel display using I2C to communicate
 3 pins are required to interface (two I2C and one reset).
 source code, please support Adafruit and open-source
 hardware by purchasing products from Adafruit!
 Written by Limor Fried/Ladyada for Adafruit Industries,
 with contributions from the open source community.
 BSD license, check license.txt for more information
 All text above, and the splash screen below must be
 included in any redistribution.
#include <SPI.h>
#include <Wire.h>
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
// The pins for I2C are defined by the Wire-library.
// On an arduino UNO:       A4(SDA), A5(SCL)
// On an arduino MEGA 2560: 20(SDA), 21(SCL)
// On an arduino LEONARDO:   2(SDA),  3(SCL), ...
#define OLED_RESET     -1 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3C ///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32
#define NUMFLAKES     10 // Number of snowflakes in the animation example
#define LOGO_HEIGHT   16
#define LOGO_WIDTH    16
static const unsigned char PROGMEM logo_bmp[] =
{ 0b00000000, 0b11000000,
  0b00000001, 0b11000000,
  0b00000011, 0b11100000,
  0b11110011, 0b11100000,
  0b11111110, 0b11111000,
  0b01111110, 0b11111111,
  0b00110011, 0b10011111,
  0b00011111, 0b11111100,
  0b00001101, 0b01110000,
  0b00011011, 0b10100000,
  0b00111111, 0b11100000,
  0b00111111, 0b11110000,
  0b01111100, 0b11110000,
  0b01110000, 0b01110000,
  0b00000000, 0b00110000 };
  if(!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
  display.display();
  // Clear the buffer
  // Draw a single pixel in white
  display.drawPixel(10, 10, SSD1306_WHITE);
  // Show the display buffer on the screen. You MUST call display() after
  // drawing commands to make them visible on screen!
  display.display();
  delay(2000);
  // display.display() is NOT necessary after every single drawing command,
  // unless that's what you want...rather, you can batch up a bunch of
  // drawing operations and then update the screen all at once by calling
  // display.display(). These examples demonstrate both approaches...
  testdrawline();      // Draw many lines
  testdrawrect();      // Draw rectangles (outlines)
  testfillrect();      // Draw rectangles (filled)
  testdrawcircle();    // Draw circles (outlines)
  testfillcircle();    // Draw circles (filled)
  testdrawroundrect(); // Draw rounded rectangles (outlines)
  testfillroundrect(); // Draw rounded rectangles (filled)
  testdrawtriangle();  // Draw triangles (outlines)
  testfilltriangle();  // Draw triangles (filled)
  testdrawchar();      // Draw characters of the default font
  testdrawstyles();    // Draw 'stylized' characters
  testscrolltext();    // Draw scrolling text
  testdrawbitmap();    // Draw a small bitmap image
  // Invert and restore display, pausing in-between
  display.invertDisplay(true);
  display.invertDisplay(false);
  testanimate(logo_bmp, LOGO_WIDTH, LOGO_HEIGHT); // Animate bitmaps
void testdrawline() {
  int16_t i;
  display.clearDisplay(); // Clear display buffer
  for(i=0; i<display.width(); i+=4) {
    display.drawLine(0, 0, i, display.height()-1, SSD1306_WHITE);
    display.display(); // Update screen with each newly-drawn line
    delay(1);
  for(i=0; i<display.height(); i+=4) {
    display.drawLine(0, 0, display.width()-1, i, SSD1306_WHITE);
    display.display();
    delay(1);
  delay(250);
    display.drawLine(0, display.height()-1, i, 0, SSD1306_WHITE);
    display.display();
    delay(1);
  for(i=display.height()-1; i>=0; i-=4) {
    display.drawLine(0, display.height()-1, display.width()-1, i, SSD1306_WHITE);
    display.display();
    delay(1);
  delay(250);
  for(i=display.width()-1; i>=0; i-=4) {
    display.drawLine(display.width()-1, display.height()-1, i, 0, SSD1306_WHITE);
    display.display();
    delay(1);
    display.drawLine(display.width()-1, display.height()-1, 0, i, SSD1306_WHITE);
    display.display();
    delay(1);
  delay(250);
    display.drawLine(display.width()-1, 0, 0, i, SSD1306_WHITE);
    display.display();
    delay(1);
    display.drawLine(display.width()-1, 0, i, display.height()-1, SSD1306_WHITE);
    display.display();
    delay(1);
void testdrawrect(void) {
  for(int16_t i=0; i<display.height()/2; i+=2) {
    display.drawRect(i, i, display.width()-2*i, display.height()-2*i, SSD1306_WHITE);
    display.display(); // Update screen with each newly-drawn rectangle
    delay(1);
  delay(2000);
void testfillrect(void) {
  for(int16_t i=0; i<display.height()/2; i+=3) {
    // The INVERSE color is used so rectangles alternate white/black
    display.fillRect(i, i, display.width()-i*2, display.height()-i*2, SSD1306_INVERSE);
    delay(1);
  delay(2000);
void testdrawcircle(void) {
  for(int16_t i=0; i<max(display.width(),display.height())/2; i+=2) {
    display.drawCircle(display.width()/2, display.height()/2, i, SSD1306_WHITE);
    display.display();
    delay(1);
  delay(2000);
void testfillcircle(void) {
  for(int16_t i=max(display.width(),display.height())/2; i>0; i-=3) {
    // The INVERSE color is used so circles alternate white/black
    display.fillCircle(display.width() / 2, display.height() / 2, i, SSD1306_INVERSE);
    display.display(); // Update screen with each newly-drawn circle
    delay(1);
  delay(2000);
void testdrawroundrect(void) {
  for(int16_t i=0; i<display.height()/2-2; i+=2) {
    display.drawRoundRect(i, i, display.width()-2*i, display.height()-2*i,
      display.height()/4, SSD1306_WHITE);
    display.display();
    delay(1);
  delay(2000);
void testfillroundrect(void) {
    // The INVERSE color is used so round-rects alternate white/black
    display.fillRoundRect(i, i, display.width()-2*i, display.height()-2*i,
      display.height()/4, SSD1306_INVERSE);
    display.display();
    delay(1);
  delay(2000);
void testdrawtriangle(void) {
  for(int16_t i=0; i<max(display.width(),display.height())/2; i+=5) {
    display.drawTriangle(
      display.width()/2  , display.height()/2-i,
      display.width()/2-i, display.height()/2+i,
      display.width()/2+i, display.height()/2+i, SSD1306_WHITE);
    display.display();
    delay(1);
  delay(2000);
void testfilltriangle(void) {
  for(int16_t i=max(display.width(),display.height())/2; i>0; i-=5) {
    // The INVERSE color is used so triangles alternate white/black
    display.fillTriangle(
      display.width()/2+i, display.height()/2+i, SSD1306_INVERSE);
    display.display();
    delay(1);
  delay(2000);
void testdrawchar(void) {
  display.setTextColor(SSD1306_WHITE); // Draw white text
  display.cp437(true);         // Use full 256 char 'Code Page 437' font
  // Not all the characters will fit on the display. This is normal.
  // Library will draw what it can and the rest will be clipped.
  for(int16_t i=0; i<256; i++) {
    if(i == '\n') display.write(' ');
    else          display.write(i);
  display.display();
  delay(2000);
void testdrawstyles(void) {
  display.println(F("Hello, world!"));
  display.setTextColor(SSD1306_BLACK, SSD1306_WHITE); // Draw 'inverse' text
  display.println(3.141592);
  display.setTextSize(2);             // Draw 2X-scale text
  display.print(F("0x")); display.println(0xDEADBEEF, HEX);
  display.display();
  delay(2000);
void testscrolltext(void) {
  display.setCursor(10, 0);
  display.println(F("scroll"));
  display.display();      // Show initial text
  delay(100);
  // Scroll in various directions, pausing in-between:
  display.startscrollright(0x00, 0x0F);
  delay(2000);
  display.stopscroll();
  display.startscrollleft(0x00, 0x0F);
  delay(2000);
  display.startscrolldiagright(0x00, 0x07);
  delay(2000);
  display.startscrolldiagleft(0x00, 0x07);
  delay(2000);
void testdrawbitmap(void) {
  display.drawBitmap(
    (display.width()  - LOGO_WIDTH ) / 2,
    (display.height() - LOGO_HEIGHT) / 2,
    logo_bmp, LOGO_WIDTH, LOGO_HEIGHT, 1);
  display.display();
#define XPOS   0 // Indexes into the 'icons' array in function below
#define YPOS   1
#define DELTAY 2
void testanimate(const uint8_t *bitmap, uint8_t w, uint8_t h) {
  int8_t f, icons[NUMFLAKES][3];
  // Initialize 'snowflake' positions
  for(f=0; f< NUMFLAKES; f++) {
    icons[f][XPOS]   = random(1 - LOGO_WIDTH, display.width());
    icons[f][YPOS]   = -LOGO_HEIGHT;
    icons[f][DELTAY] = random(1, 6);
    Serial.print(F("x: "));
    Serial.print(icons[f][XPOS], DEC);
    Serial.print(F(" y: "));
    Serial.print(icons[f][YPOS], DEC);
    Serial.print(F(" dy: "));
    Serial.println(icons[f][DELTAY], DEC);
  for(;;) { // Loop forever...
    display.clearDisplay(); // Clear the display buffer
    // Draw each snowflake:
      display.drawBitmap(icons[f][XPOS], icons[f][YPOS], bitmap, w, h, SSD1306_WHITE);
    display.display(); // Show the display buffer on the screen
    delay(200);        // Pause for 1/10 second
    // Then update coordinates of each flake...
      icons[f][YPOS] += icons[f][DELTAY];
      // If snowflake is off the bottom of the screen...
      if (icons[f][YPOS] >= display.height()) {
        // Reinitialize to a random position, just off the top
specs of led -
dimension in pixels - 128 * 64
4 pins- GND, VDD, SCK ,SDA
More specs please! That is why I asked for a link to the specs. As a beginner, you don't know which are important. For example, what controller chip is used.
My first thought for the controller on a 1.3" OLED would not be a SSD1306, but an SH1106G. Try using the library for the latter.
This isn't very helpful, but I wonder if anyone else has seen this. I've had this happen to a working OLED: it just started showing noise. I couldn't figure it out: checked all connections, verified signals with a scope, and finally concluded that I had somehow killed it, so I put it aside.
About a month later, I figured I'd pull off some parts for another project, but before I did that, I applied power to the existing circuit, without changes. OLED started up and displayed properly like nothing ever happened.
My best guess is that there might be a cold joint somewhere on the board where I didn't probe (I stopped at the I2C inputs), but I haven't tried to debug it further, since I have a bunch of other displays.
Anyone ever see this?
