I have a solid state detector (an active component comprised of a P-type doped silicon semiconductor junction) simply diode. It has a BNC connector at the end.
The project is to connect the detector to a preamplifier then to Arduino ono with LCD reading in order to count an external photon beam from a linear accelerator.
I need your advice please.
MY advice is for you to explain what type of advice you think you need! Are you needing to power your system? Are you needing to write programs? Are you wanting someone to build and program something for you?
Morning Paul, Let's start with the list of components I've got so fare:
ARDUINO UNO Evaluation board
LCD SHIED KIT BLUE/WHITE DISPLAY 16x2
Photon detector EDP-15 3G: 15 mm water equivalent build-up, primarily designed for use in 6 to 12MV beams.
Also, I am going to design a preamplifier for signal purpose.
I am kindly asking for you guidance for settings and write programs
EDP-15 3G:
MV beams.
I cannot find the datasheet but copied the following details from the user's guide
This happens in the depletion zone. When radiation beam interact with the detector, electrons from the n-type migrate across the junction between the two layers to fill the holes in the p-type, creating a depletion zone or charge zone if you want.
This depletion zone behave like the detection area of the diode. Radiation interacting with the atoms inside the depletion zone causes them to re-ionize, and create an electronic pulse which can be measured.
OK, but again, what's the output frequency? I've worked with photomultiplier tube detectors that produce hundreds of MHz pulse output even at low light levels. Arduino is not going to read that.
