Radio controlled Potentiometers; best way?
Hey guys, I'm looking to wireless control the output of several camera flashes independently. I'll be replacing the photo-resistor used for the automatic function with some sort of selectable resistance, determined by a remote control.
So the goal is several receivers, with one transmitter that can choose what receiver it's instructing. If the receivers can feedback their setting, all the better.
I see a couple ways to control the flash; there's a physical pot moved by a servo, a digital pot, an array of resistors chosen via transistors or relays, or an array of resistors physically switched.
What I don't know is which of these methods above is best suited to remote control, or what the best method of radio interface would be.
I imagine the finished project giving me an arduino-based control unit with a display, buttons to select which flash is being manipulated, and a power dial.
Resistance values and range are currently unknown and variable; once I get the flashes, I'll measure they're output curves and calibrate the power settings to be near equal. As an estimate, we're talking 2M-50k.
Definite goal would be to keep the cost of the receivers low, even if it raises the price of the transmitter.
Thanks for any and all suggestions!
The cheapest method might be the digital pot method; there are many ways to do this (you might be able to find an application specific chip for the R/C part), but the easiest way - and staying "arduino" would be to set up each digital pot connected to a standalone Arduino, set up to interpret the R/C PPM signal. Basically, you would have software on the Arduino that would monitor a pin from the R/C receiver, and convert that PPM signal into a number that you would then output to the digital pot to set it. Such small boards, if you bought your parts in quantity (>10 pcs each), you could probably get it down to $10.00-15.00 for each board.
The next cheapest would be the direct servo/potentiometer setup; heck, depending on where you bought the parts (say on Ebay from chinese suppliers), it might be cheaper to go that route! 9g Micro servos and small trimmer-style pots would probably allow you to make controllers really inexpensively...
:slight_smile:
The JeeNode and rfBee are both radio+ arduino in a single package, right? Is the xBee similar? Is one form of radio more reliable than another?
Do certain R/C setups favor multiple independent receivers? I assume the basic 433 and 915s don't, which means you need a microcontroller added to the receiver to accept instructions prefixed with a callsign code or the like.
With the xBee could you just send serial data directly to the pots?
Is there a better radio I'm missing? When I say better, I mean longer range, more reliable transmission?
