Hello all,
I'm trying to program two boards to communicate via 433mhz chips. Using radiohead library I'm sending a
"A", "B","C" respectively using push buttons to the other end when the other receives the one it lights up led. The problem is that either the message isn't being sent or it's not being received. Either way, when I press my button nothing happens.
Transmitter Module:
// ask_transmitter.pde
// -*- mode: C++ -*-
// Simple example of how to use RadioHead to transmit messages
// with a simple ASK transmitter in a very simple way.
// Implements a simplex (one-way) transmitter with an TX-C1 module
// Tested on Arduino Mega, Duemilanova, Uno, Due, Teensy, ESP-12
#include <RH_ASK.h>
#ifdef RH_HAVE_HARDWARE_SPI
#include <SPI.h> // Not actually used but needed to compile
#endif
RH_ASK driver;
// RH_ASK driver(2000, 4, 5, 0); // ESP8266 or ESP32: do not use pin 11 or 2
// RH_ASK driver(2000, 3, 4, 0); // ATTiny, RX on D3 (pin 2 on attiny85) TX on D4 (pin 3 on attiny85),
// RH_ASK driver(2000, PD14, PD13, 0); STM32F4 Discovery: see tx and rx on Orange and Red LEDS
const int button_a = 2;
const int button_b = 3;
const int button_c = 4;
#ifdef RH_HAVE_SERIAL
Serial.begin(9600); // Debugging only
#endif
if (!driver.init())
Serial.println("init failed");
#else
#endif
pinMode(button_a, INPUT_PULLUP);
pinMode(button_b,INPUT_PULLUP);
pinMode(button_c,INPUT_PULLUP);
const char *msg1 = "A";
const char *msg2 = "B";
const char *msg3 = "C";
if (digitalRead(button_a)) {
driver.send((uint8_t *)msg1, strlen(msg1));
Serial.println("its here alse 1");
driver.waitPacketSent();
Serial.println("its here 1");
delay(200);
Serial.println("Button pressed! 1");
delay(1000); // Add a delay to prevent continuous readings while the button is pressed
if (digitalRead(button_b)) {
driver.send((uint8_t *)msg2, strlen(msg2));
delay(200);
if (digitalRead(button_c)) {
driver.send((uint8_t *)msg3, strlen(msg3));
delay(200);
Transmittor Circuit
Receiver Module:
// ask_receiver.pde
// Simple example of how to use RadioHead to receive messages
// Implements a simplex (one-way) receiver with an Rx-B1 module
#include <RH_ASK.h>
#endif
RH_ASK driver;
const int led_a = 7;
const int led_b = 6;
const int led_c = 5;
pinMode(led_a, OUTPUT);
pinMode(led_b, OUTPUT);
pinMode(led_c, OUTPUT);
Serial.begin(115200); // Debugging only
#endif
if (!driver.init())
#else
#endif
uint8_t buf[RH_ASK_MAX_MESSAGE_LEN];
uint8_t buflen = sizeof(buf);
if (driver.available()) // Non-blocking
int i;
String a = "";
// Message with a good checksum received, dump it.
// driver.printBuffer("Got:", buf, buflen);
for (int i = 0; i < buflen; i++)
//Serial.println("main :: ");
//Serial.print((char)buf[i]);
a = a + (char)buf[i];
Serial.println(a);
if (a == "A") {
digitalWrite(led_a, HIGH);
Serial.println("in If");
} else if (a == "B") {
digitalWrite(led_b, HIGH);
Serial.println("in ElseIf");
else if (a == "C") {
digitalWrite(led_c, HIGH);
Serial.println("C");
Receiver Circuit :
