Hi everyone,
I am currently in the process of programming a Aruino Uno to collect data from a Gauge (https://www.idealvac.com/files/brochures/Pfeiffer_Single_Gauge_TPG261.pdf) and printing it on a OLED (SSD1315) as well as checking the position of 2 valves. In the future I want to send the data via ethernet port but I'm not there yet because I am running into a lot of issues regarding the serial communication.
I theory I should get well defined responses from my Gauge depending on the kind of request I'm making. In my code im only asking for the pressure on channel 1 and im expecting to get the status code 5 and a devault value since so sensor is currently connected to my Gauge. The code is right now in a state where I get exactly those results. If I however do minor (seemingly irrelevant) changes like adding or removing a Serial.print() command where I print an arbitrary String or variable, changing what is printed on the display etc. The Output I am getting from the gauge changes into something random and undefined.
For communcation I am currecntly using the RX and Tx pins of my port. In the past I tired using digital ones(10,11) in combination with SoftwareSerial but didnt have any luck with that either.
I would be very grateful if someone can help me find the source of my inconsistent outputs and will gladly elaborate on any not yet specified details.
Here is my Code:
#include <Arduino.h>
#include <U8g2lib.h>
#include <Wire.h>
#include <SoftwareSerial.h>
#include <ArduinoJson.h>
// #ifdef U8X8_HAVE_HW_SPI
// #include <SPI.h>
// #endif
// #ifdef U8X8_HAVE_HW_I2C
// #include <Wire.h>
// #endif
// U8G2_SSD1306_128X64_ALT0_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE, SCL,SDA); // SSD1306 and SSD1308Z are compatible
U8G2_SSD1306_128X64_NONAME_F_SW_I2C u8g2(U8G2_R0, /* clock=*/ SCL, /* data=*/ SDA, /* reset=*/ U8X8_PIN_NONE); //Low speed I2C
void setup(void) {
u8g2.begin();
u8g2.setFont(u8g2_font_ncenB08_tr);
pinMode(0,INPUT);
pinMode(1,OUTPUT);
int get_voltage(float *pin0,float *pin1){ //Sets pin0 and pin0 to a value between 1 and 1023 and V0, V1 to the corresponding voltage
char buffer[10]; //which is then printed on the display
float V0, V1;
*pin0=analogRead(A0);
*pin1=analogRead(A1);
V0=*pin0*5/1023;
V1=*pin1*5/1023;
dtostrf(V0, 6, 1, buffer);
u8g2.drawStr(15, 10, buffer);
dtostrf(V1, 6, 1, buffer);
u8g2.drawStr(15, 20, buffer);
return 0;
int valve_status(float pin0, float pin1){
if(pin0<1000&&pin1>=1000){ //constellation for valve open
u8g2.drawStr(55,15,"Valve closed");
else if(pin0>=1000&&pin1<1000){ //constellation for valve close
u8g2.drawStr(55,15,"Valve open");
else{ //if none of the conditions above are fullfilled the valve poistion is incorrect
u8g2.drawStr(60,15,"Error!");
u8g2.sendBuffer();
return 0;
void valve(){ //Evaluates and outputs the valve position
float pin0, pin1;
u8g2.clearBuffer();
u8g2.drawStr(0,10,"A0:");
u8g2.drawStr(40,10,"V");
u8g2.drawStr(0,20,"A1:");
u8g2.drawStr(40,20,"V");
u8g2.sendBuffer();
get_voltage(&pin0, &pin1);
valve_status(pin0, pin1);
void send_command(){
Serial.write("PR1"); // send command to request pressure reading
Serial.write(char(13));
Serial.write(char(10));
delay(1000); // wait for response
Serial.write(char(5));
String get_data(){
String data;
int i=0;
if (Serial.available()) {
while (Serial.available()) { // if data is available on the serial port
data=Serial.readStringUntil(char(13));
Serial.print(data);
i++;
if(i>30){
Serial.print("Too much output\n");
return "NULL";
else{
Serial.print("No Data\n");
u8g2.drawStr(85,35,"No data");
u8g2.sendBuffer();
return data;
int display_data(const String& data){
int status=data[1];
u8g2.drawStr(0,35,"Status:");
u8g2.sendBuffer();
switch (status) {
case 48:
u8g2.drawStr(55, 35, "Measurement data okay");
u8g2.drawStr(0, 50, "Pressure");
u8g2.sendBuffer();
Serial.print("Measurement data okay");
for(int j=4;j<14;j++){
char charac=char(data[j]);
u8g2.setCursor(55+(j-4)*6, 50);
u8g2.print(charac);
u8g2.sendBuffer();
case 49:
u8g2.drawStr(55, 35, "Underrange");
u8g2.sendBuffer();
case 50:
u8g2.drawStr(55, 35, "Overrrange");
u8g2.sendBuffer();
case 51:
u8g2.sendBuffer();
case 52:
u8g2.drawStr(55, 35, "Sensor off");
u8g2.sendBuffer();
case 53: //53=5 in ascii
u8g2.drawStr(55, 35, "No sensor");
u8g2.sendBuffer();
u8g2.print(charac);
u8g2.sendBuffer();
case 54:
u8g2.drawStr(55, 35, "Identification error");
u8g2.sendBuffer();
return 0;
float get_pressure(const String& data){ //trying to read the pressure encoded in the String data into a float--
float p; //printing the float p changes the read from the gauge into something invalid
for(int j=4;j<10;j++){ //correct response contains NAK ACK and then the data String(5, 2.0000E-02)
Serial.print(data); //printing p changes the response to alternate between AcK ACK and NAK 0001
if(j==4){ //even though data is given to this fuction as const String it is deleted/becomes empty
p+=char(data[j])-'0'; //after the first iteration of the loop
//Serial.print(p);
else if(j>5){
Serial.print(data);
p+=(charac-'0')*pow(10,j-5);
return p;
int write_json_data(float V0, float V1){
StaticJsonDocument<200> doc;
JsonArray voltages = doc.createNestedArray("Voltages");
voltages.add(V0);
voltages.add(V1);
//doc["Status"] = data[1];
doc["pressure"] = 1351824120;
serializeJson(doc, Serial);
return 0;
void loop(){
String data;
float V0,V1;
V0=analogRead(A0)/1023;
V1=analogRead(A1)/1023;
u8g2.clearBuffer();
valve();
send_command();
data=get_data();
display_data(data);
float press=get_pressure(data);
//Serial.print(press);
write_json_data(V0,V1);
delay(2000);
u8g2.clearBuffer();
