long randNumber;
randomSeed(140584);
Serial.println("BEGIN HERE");
Serial.println("----------");
randNumber = random(101010100, 757575759);
Serial.println(randNumber);
Hi everyone, I am thoroughly enjoying learning development on my new ESP32 and I'm working on an idea that I've had for some time. I'd like to take a number (eventually it will be from a 1D barcode scan but for now I was just using a static number) and use it to generate a repeatable 9 digit number between 101010100 and 757575759. The random() and randomSeed() functions looked like they would be perfect by using pseudo-random numbers in the range I need with random() and then using randomSeed() to make it repeatable by starting at the same point in the random sequence on each execution of the sketch.
I used the code above and found that no matter what seed number I use the numbers are not repeatable, upon further research I found that the ESP32 has a true-random number generator by using the noise values on the WiFi/BLE chip, so that explains it.
This is one of the rare occurrences where the older pseudo-random functionality was more suited than true-random! By default the random() function calls esp_random() so I do not think it is possible to 'downgrade' and force the ESP32 to use seeded pseudo-random number sequences? I've been pulling my hair out with it.
May I ask if anyone has any advice? Many thanks, G
