Raspberry pico with sharp sensor
Have a nice day
I wanted to use raspberry pico microcontrollers with arduino IDE. I want to use and run the Sharp sensor library, but this problem occurs. I write the analogreference() values on the Arduino site, but it gives the same errors. I would be glad if you help me in this regard.
#include <SharpIR.h>
#define ir A0
#define model 20150
// ir: the pin where your sensor is attached
// model: an int that determines your sensor: 1080 for GP2Y0A21Y
// 20150 for GP2Y0A02Y
// (working distance range according to the datasheets)
// 15.02.2019
// updated by Andreas Skjong
// updated by Ahmad Nejrabi from Robojax.com
// get latest datasheets: http://www.sharp-world.com/products/device/lineup/selection/opto/haca/diagram.html
  • GP2Y0A02YK0F --> "20150"
    GP2Y0A21YK --> "1080"
    GP2Y0A710K0F --> "100500"
    GP2YA41SK0F --> "430"
SharpIR SharpIR(ir, model);
delay(2000);
unsigned long startTime=millis(); // takes the time before the loop on the library begins
double dis=SharpIR.distance(); // this returns the distance to the object you're measuring
Serial.print("Mean distance: "); // returns it to the serial monitor
Serial.println(dis);
unsigned long calcTime=millis()-startTime; // the following gives you the time taken to get the measurement
Serial.print("Time taken (ms): ");
Serial.println(calcTime);
c:\Users\517\Documents\Arduino\libraries\SharpIR\SharpIR.cpp: In constructor 'SharpIR::SharpIR(int, long int)':
c:\Users\517\Documents\Arduino\libraries\SharpIR\SharpIR.cpp:63:23: error: 'AR_DEFAULT' was not declared in this scope
63 | analogReference(AR_DEFAULT);
exit status 1
Compilation error: exit status 1
