Hello i want to modify my old rc car with the arduino uno board and i want your help on the code.
my code is
int const PWMA = 6;
int const PWMB = 5;
int const dirA = 7;
int const dirB = 4;
pinMode(PWMA, OUTPUT);
pinMode(PWMB, OUTPUT);
pinMode(dirA, OUTPUT);
pinMode(dirB, OUTPUT);
//initial set up straight forward, no speed
digitalWrite(dirA, HIGH);
digitalWrite(dirB, HIGH);
analogWrite(PWMA, 0);
analogWrite(PWMB, 0);
// see if there's incoming serial data:
if (Serial.available() > 0) {
// read the oldest byte in the serial buffer:
int incomingByte = Serial.read();
// action depending on the instruction
// as well as sending a confirmation back to the app
switch (incomingByte) {
case 'F':
moveForward(255, true);
Serial.println("Going forward");
case 'R':
turn(255, true);
Serial.println("Turning right");
case 'L':
turn(255, false);
Serial.println("Turning left");
case 'B':
moveForward(255, false);
Serial.println("Going backwards");
case 'S':
moveForward(0, true);
Serial.println("Stopping");
default:
// if nothing matches, do nothing
void moveForward(int speedBot, boolean forward){
//boolean forward controls motor direction
if (forward){
else{
digitalWrite(dirA, LOW);
digitalWrite(dirB, LOW);
analogWrite(PWMA, speedBot);
analogWrite(PWMB, speedBot);
void turn(int speedBot, boolean right){
//boolean right controls motor direction
if (right){
else{
My rc car is similat to this https://www.google.gr/search?q=rc+car+arduino&biw=1680&bih=949&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjbo-ypo_LJAhVJExoKHY1EAVcQ_AUIBigB#imgrc=Hyt7mC-mC1NBRM%3A
I upload the code but the steering motors doesn't work only go forward and backward.How to modify the code in order to work with steering motors?
My motor controller is this 2x1A DC Motor Shield for Arduino - DFRobot
Thanks for your time.
