RC car IBUS issues! AKA I cant figure this code out.
Hello! and Help! I have been working on this project all day and I cant get it to work.... Fully. I will explain...
So I have a RC car. it is equipped with a flysky FS-IA6B.
and a flysky FS-I6X. I am installing lights, a voltage sensor, and a temperature sensor (for the motor).
I already have the lights working. and the voltage sensor. and I know how I am going to do the temperature sensor.
but I am trying to transmit the sensor data over IBUS. there is some library's for it. Like iBUSTelemetry by adis1313
and IBusBM by bmellink. but I cant get any to work. I am using a arduino nano on a small 170 tie breadboard.
and I just want to know HOW to get the IBUS sensor working. This forum post steams to have worked Flysky IBUS Sensor But I just cant get it to work myself! here is my code:
#include <AverageValue.h>
#include <MyDelay.h>
float voltage;
double avgthrottle;
double avgstearing;
double avgswitch1;
double avgswitch2;
const long MAX_VALUES_NUM_THROTTLE = 10;
const long MAX_VALUES_NUM_STEARING = 10;
const long MAX_VALUES_NUM_SWITCH1 = 2;
const long MAX_VALUES_NUM_SWITCH2 = 2;
const long MAX_VALUES_NUM_VOLTAGE = 40;
const int reverselight = A0;
const int rearright = A1;
const int rearleft = A2;
const int frontright = A3;
const int frontleft = A4;
const int VoltPin = A5;
const int highbeams = 6;
const int lowbeams = 7;
const int ledbrightness = 150;
const int reverselightbrightness = 255;
int braking1 = 0;
int braking2 = 0;
int ch3 = 0;
int ch4 = 0;
int ch5 = 0;
int ch6 = 0;
int throttle = 1;
int stearing = 1;
int switch1 = 1;
int switch2 = 1;
int stearingstate = 1;
float sensorValue = 0;
uint16_t avgvoltage = 0;
const int ch3read = 2;
const int ch4read = 3;
const int ch5read = 4;
const int ch6read = 5;
AverageValue<long> averagethrottle(MAX_VALUES_NUM_THROTTLE);
AverageValue<long> averagestearing(MAX_VALUES_NUM_STEARING);
AverageValue<long> averageswitch1(MAX_VALUES_NUM_SWITCH1);
AverageValue<long> averageswitch2(MAX_VALUES_NUM_SWITCH2);
AverageValue<long> averagevoltage(MAX_VALUES_NUM_VOLTAGE);
void ledBlink();
MyDelay BlinkTime(500, ledBlink);
int ledState = 0;
void brakecheck();
MyDelay CheckTime(15, brakecheck);
int isbraking = 0;
void ledBlink()
  if (ledState == 0)
    ledState = ledbrightness;
    ledState = 0;
void brakecheck()
  braking2 = throttle;
  pinMode(reverselight, OUTPUT);
  pinMode(rearleft, OUTPUT);
  pinMode(rearright, OUTPUT);
  pinMode(frontleft, OUTPUT);
  pinMode(frontright, OUTPUT);
  pinMode(highbeams, OUTPUT);
  pinMode(lowbeams, OUTPUT);
  pinMode(VoltPin, INPUT);
  pinMode(ch3read, INPUT);
  pinMode(ch4read, INPUT);
  pinMode(ch5read, INPUT);
  pinMode(ch6read, INPUT);
  BlinkTime.start();
  CheckTime.start();
  if (stearingstate == 1) {
    BlinkTime.start();
    analogWrite(frontright, 0);
    analogWrite(frontleft, 0);
  else if (stearingstate == 2) {
    BlinkTime.update();
    analogWrite(frontleft, ledState);
    analogWrite(rearleft, ledState);
  else if (stearingstate == 0) {
    BlinkTime.update();
    analogWrite(frontright, ledState);
    analogWrite(rearright, ledState);
  sensorValue = analogRead(VoltPin);
  avgvoltage = sensorValue * (5 / 1024.0);
  avgvoltage = avgvoltage + avgvoltage;
  CheckTime.update();
  avgthrottle = pulseIn(ch3read, HIGH);
  avgstearing = pulseIn(ch4read, HIGH);
  avgswitch1 = pulseIn(ch5read, HIGH);
  avgswitch2 = pulseIn(ch6read, HIGH);
  averagethrottle.push(avgthrottle);
  averagestearing.push(avgstearing);
  averageswitch1.push(avgswitch1);
  averageswitch2.push(avgswitch2);
  averagevoltage.push(sensorValue);
  throttle = averagethrottle.average();
  stearing = averagestearing.average();
  switch1 = averageswitch1.average();
  switch2 = averageswitch2.average();
  avgvoltage = averagevoltage.average();
  braking1 = throttle;
  braking1 = braking1 + 3;
  if (braking1 < braking2)
    isbraking = 1;
  else if  (braking1 > braking2)
    isbraking = 0;
  if (isbraking == 1)
    analogWrite(rearright, ledbrightness);
    analogWrite(rearleft, ledbrightness);
    analogWrite(rearleft, 0);
    analogWrite(rearright, 0);
  if (throttle < 1486)
    analogWrite(reverselight, reverselightbrightness);
    analogWrite(reverselight, 0);
  if (stearing > 1602) {
    stearingstate = 2;
  else if (stearing < 1450) {
    stearingstate = 0;
    stearingstate = 1;
  if (switch1 < 1000 && switch2 < 1500)
    digitalWrite(highbeams, HIGH);
    digitalWrite(lowbeams, HIGH);
  else if (switch1 > 1400 && switch1 < 1500 && switch2 < 1500)
    digitalWrite(lowbeams, LOW);
  else if (switch1 > 1900 && switch2 < 1500)
    digitalWrite(highbeams, LOW);
  else if (switch2 > 1500)
Anybody????
I don't see your code using any of the IBUS librabries.
I suggest you install the IBusBM library first and test some of the examples that go with the library. Once you understand the communication between the receiver and the Arduino you can integrate that in your code.
