I am building a simple 24" flying wing made from a foam board. The motor I am using is a 2200 Kv brushless with a 30A ESC. This is my first Arduino project, so I have no experience with LiPo batteries. I tried to do some research, but I found many conflicting guides to picking batteries, and some of them were too complicated and involved specs I don't know. I am not looking for a perfect battery, just one that won't burn out my motor/ESC, will power my wing for about 10 minutes, and is not too large or expensive. Here is some information taken directly from the product page:
Fit for Battery: 2-3 Li-Poly, Fit for ESC: 30A
30A ESC Input Voltage: 2-3 cells lithium battery or 5/10NIMh battery
A2212 2200kv Motor Specification:
KV: 2200
Ri(M Ω): 0.033
Battery: 2-3Li-Po
Max Power: 342W
Test Prop: 7x3/7x4
30A Brushless ESC Specification:
BEC: 3A
Constant Current: 30A.
Max Current: 45A (less than 12s).
Low-voltage Cutoff: Auto detect.
Input: 2-3 LiPo or 5/10 NiMH.
From what I have learned it sounds like I should use a 2-3 cell 11.1V battery, but I'm not sure about the C rating or mAh. What would be a reasonable combo for these specs? Thanks!
