I'm working with standard rx-tx arduino transmitters, 433mhz:
I'm trying to acquire signals from 2 different gate remotes with rx sketch and use with my tx sketch.
I'm using the Rc-switch library, and have worked well with one of them.
I've used the sketch ReceiveDemo_Advanced, that gave me:
Decimal: 5326626 (24Bit) Binary: 010100010100011100100010 Tri-State: not applicable PulseLength: 369 microseconds Protocol: 1
Raw data: 11480,348,1108,1088,372,340,1112,1084,376,344,1112,340,1116,340,1112,1084,376,340,1116,1084,376,340,1116,336,1116,340,1116,1084,376,1080,380,1080,380,336,1116,340,1116,1080,380,336,1120,336,1120,336,1116,1080,380,336,1120,
Trying to understand the binary output, i've pasted raw data in given online tool of rc-switch that prints this pattern:
It's quite easy to figure out the Binary, as stated in the message.
Since the other remote, doesn't output anything with previous sketch, i've tried a more "low level" one called SimpleRcScanner, that outputs me following raw trace:
1436,2304,1424,1100,2684,2292,2672,1084,1428,1096,1444,1080,1436,1088,1428,2316,1436,1084,2704,2272,2680,2296,1432,1088,1424,1104,1428,1092,2684,1076,1440,2300,1444,1080,1444,1080,1432,1092,2700,1056,1444,1080,1444,2544,5512,1084,1436,1084,1444,1080,2680,1080,1432,2308,1444,1080,2676,2300,2672,1084,1436,1088,1436,1088,1444,1080,1424,2316,1440,1084,2696,2280,2684,2292,1440,1084,1468,1056,1440,1084,2680,1076,1448,2296,1452,1072,1452,1068,1452,1076,2688,1068,1448,1076,1448,2540,5540,1056,1476,1048,1444,1080,2708,1052,1444,2296,1440,1084,2692,2284,2680,1076,1452,1072,1460,1064,1444,1080,1464,2276,1456,1068,2692,2284,2696,2280,1456,1068,1460,1064,1456,1068,2696,1064,1452,2288,1452,1072,1440,1084,1460,1064,2684,1072,1464,1060,1484,2508,5520,1072,1452,1072,1460,1064,2680,1080,1448,2292,1468,1056,2696,2276,2692,1068,1464,1060,1468,1056,1452,1068,1464,2280,1448,1072,2684,2292,2724,2252,1444,1080,1444,1080,1452,1068,2712,1048,1476,2260,1460,1068,1452,1068,1504,1020,2700,1060,1452,1068,1452,2540,5516,1076,1448,1076,1460,1064,2692,1064,1464,2276,1472,1052,2684,2292,2692,1064,1452,1072,1456,1068,1452,1072,1444,2296,1464,1060,2712,2264,2692,2280,1436,1088,1468,1056,1456,1068,2692,1064,1452,2288,1460,1064,1456,1068,1444,1076,2696,1064,1460,1064,1460,2528,5524,1068,1464,1060,1452,1072,2676,1080,1428,2312,1444,1080,2696,2276,2696,1064,1460,1060,1448,1076,1448,1076,1452,2288,1500,1024,2700,2276,2736,2240,1452,1072,1460,1060,1452,1072,2720,1040,1452,2288,1456,1068,1448,1072,1460,1064,2688,1072,1464,1060,1452,2536,5520,1072,1452,1072,1444,1076,2676,1084,1472,2268,1472,1052,2688,2288,2676,1080,1448,1076,1436,1084,1456,1068,1460,2284,1456,1064,2680,2296,2712,2260,1460,1064,1460,1064,1448,1076,2688,1068,1460,2280,1448,1076,1452,1072,1444,1076,2684,1076,1464,1060,1472,2516,5520,1072,1452,1072,1452,1072,2672,1084,1460,2280,1460,1064,2676,2300,2688,1068,1452,1072,1448,1076,1480,1044,1456,2284,1456,1068,2676,2300,2704,2268,1444,1080,1444,1080,1468,1056,2680,1076,1456,2288,1464,1056,1448,1076,1444,1080,2680,1080,1448,1072,1472,2516,5516,1080,1452,1072,1448,1072,2676,1084,1464,2276,1444,1080,2684,2288,2672,1088,1444,1080,1452,1072,1456,1068,1448,2292,1448,1076,2672,2304,2668,2304,1464,1060,1480,1040,1464,1060,2728,1032,1444,2296,1464,1060,1436,1088,1468,1056,2692,1064,1448,1076,1440,2548,5508,1088,1464,1060,1468,1056,2676,1080,1456,2284,1460,1064,2688,2288,2692,1064,1456,1068,1432,1092,1452,1072,1452,2292,1456,1064,2684,2292,2680,2296,1452,1072,1456,1068,1460,1060,2688,1072,1436,2304
That's the only data i got, so my question is, how can i extract pattern and pulselength from this?
What I've tried so far:
As you can easily imagine I've put this in the online tool to figure out the pattern:
it's very long, so i've tried to recognize and isolate the "repeated" part.
I've obtained following subset raw trace:
which plots:
So, based on previous remote experience, i've figure out following binary:
00001010000101100001000001
But unfortunately, the signal i output with this binary, doesn't have any effect on corresponding gate...
I don't know if matters, but I've noticed that the signal plots wider pattern, but I have not enough experience to calculate right pulselength and confirm i've done a good job trying to decode the plot to binary by observing it.
Now I'm stuck. I hope anybody's got an advice!
