RC522 issues, nine readers
Hi guys!
Im having some issues with a simple task 🙂
I have 9 RC522 readers that, when correct refid card on corect reader should give a high on a pin to a relay.
The UID:s are correct and all seems fine but I never get the HIGH signal to relay.
Is there anyone who can give it a look?
TIA
* "Object Placement" Puzzle
* This puzzle requires the player to place one or more items in the
* correct location, at which point an RFID tag embedded in the object
* is detected by a sensor.
* When all sensors read the tag of the correct object, the puzzle is solved.
* Demonstrates:
* - SPI interface shared between several devices
* - RFID library
// DEFINES
// Provides debugging information over serial connection if defined
#define DEBUG
// LIBRARIES
// Standard SPI library comes bundled with the Arduino IDE
#include <SPI.h>
// Download and install from https://github.com/miguelbalboa/rfid
#include <MFRC522.h>
// CONSTANTS
// The number of RFID readers
const byte numReaders = 9;
// Each reader has a unique Slave Select pin
const byte ssPins[] = {2, 3, 4, 5, 6, 7, 8, 9, 10};
// They'll share the same reset pin
const byte resetPin = A0;
// This pin will be driven LOW to release a lock when puzzle is solved
const byte lockPin = A1;
// The sequence of NFC tag IDs required to solve the puzzle
const String correctIDs[] = { "f3df15ad" };
const String correctIDs2[] = { "333824aa" };
const String correctIDs3[] = { "12b2386f" };
const String correctIDs4[] = { "a39ba2aa" };
const String correctIDs5[] = { "231f2810" };
const String correctIDs6[] = { "d39ca24" };
const String correctIDs7[] = { "73a6b1aa" };
const String correctIDs8[] = { "1352d6aa" };
const String correctIDs9[] = { "1b4f426f" };
// GLOBALS
// Initialise an array of MFRC522 instances representing each reader
MFRC522 mfrc522[numReaders];
// The tag IDs currently detected by each reader
String currentIDs[numReaders];
 * Initialisation
  #ifdef DEBUG
  // Initialise serial communications channel with the PC
  Serial.println(F("Serial communication started"));
  #endif
  // Set the lock pin as output and secure the lock
  pinMode(lockPin, OUTPUT);
  digitalWrite(lockPin, HIGH);
	// We set each reader's select pin as HIGH (i.e. disabled), so
	// that they don't cause interference on the SPI bus when
	// first initialised
	for (uint8_t i=0; i<numReaders; i++) {
		pinMode(ssPins[i], OUTPUT);
		digitalWrite(ssPins[i], HIGH);
  // Initialise the SPI bus
  SPI.begin();
    // Initialise the reader
    // Note that SPI pins on the reader must always be connected to certain
    // Arduino pins (on an Uno, MOSI=> pin11, MISO=> pin12, SCK=>pin13)
    // The Slave Select (SS) pin and reset pin can be assigned to any pin
    mfrc522[i].PCD_Init(ssPins[i], resetPin);
    // Set the gain to max - not sure this makes any difference...
    // mfrc522[i].PCD_SetAntennaGain(MFRC522::PCD_RxGain::RxGain_max);
	#ifdef DEBUG
    // Dump some debug information to the serial monitor
    Serial.print(F("Reader #"));
    Serial.print(i);
    Serial.print(F(" initialised on pin "));
    Serial.print(String(ssPins[i]));
    Serial.print(F(". Antenna strength: "));
    Serial.print(mfrc522[i].PCD_GetAntennaGain());
    Serial.print(F(". Version : "));
    mfrc522[i].PCD_DumpVersionToSerial();
	#endif
    // Slight delay before activating next reader
    delay(100);
  #ifdef DEBUG
  Serial.println(F("--- END SETUP ---"));
  #endif
 * Main loop
  // Assume that the puzzle has been solved
  boolean puzzleSolved = true;
  // Assume that the tags have not changed since last reading
  boolean changedValue = false;
  // Loop through each reader
    boolean match = false;
    // Initialise the sensor
    mfrc522[i].PCD_Init();
    // String to hold the ID detected by each sensor
    String readRFID = "";
    // If the sensor detects a tag and is able to read it
    if(mfrc522[i].PICC_IsNewCardPresent() && mfrc522[i].PICC_ReadCardSerial()) {
      // Extract the ID from the tag
      readRFID = dump_byte_array(mfrc522[i].uid.uidByte, mfrc522[i].uid.size);
    // If the current reading is different from the last known reading
    if(readRFID != currentIDs[i]){
      // Set the flag to show that the puzzle state has changed
      changedValue = true;
      // Update the stored value for this sensor
      currentIDs[i] = readRFID;
    // If the reading fails to match the correct ID for this sensor
    if(currentIDs[i] == correctIDs[i]) {
      match = true;
    if (currentIDs[i] == correctIDs2[i]) {
      match = true;
    if (match == false) {
      // The puzzle has not been solved
      puzzleSolved = false;
    // Halt PICC
    mfrc522[i].PICC_HaltA();
    // Stop encryption on PCD
    mfrc522[i].PCD_StopCrypto1();
  #ifdef DEBUG
  // If the changedValue flag has been set, at least one sensor has changed
  if(changedValue){
    // Dump to serial the current state of all sensors
      Serial.print(String(i));
      Serial.print(F(" on Pin #"));
      Serial.print(String((ssPins[i])));
      Serial.print(F(" detected tag: "));
      Serial.println(currentIDs[i]);
    Serial.println(F("---"));
  #endif
  // If the puzzleSolved flag is set, all sensors detected the correct ID
  if(puzzleSolved){
    onSolve();
  // Add a short delay before next polling sensors
  //delay(100);
 * Called when correct puzzle solution has been entered
void onSolve(){
  #ifdef DEBUG
  // Print debugging message
  Serial.println(F("Puzzle Solved!"));
  #endif
  // Release the lock
  digitalWrite(lockPin, LOW);
  while(true) {
 * Helper function to return a string ID from byte array
String dump_byte_array(byte *buffer, byte bufferSize) {
  String read_rfid = "";
  for (byte i=0; i<bufferSize; i++) {
    read_rfid = read_rfid + String(buffer[i], HEX);
  return read_rfid;
Please tell us you tested with one card and it worked, then two cards and they worked, etc. Now with 9 cards it doesn't work?
thanks for taking time for this. This is what serial monitor says, so that part is ok:
Reader #0 on Pin #2 detected tag: f3df15ad
Reader #1 on Pin #3 detected tag: 333824aa
Reader #2 on Pin #4 detected tag: 12b2386f
Reader #3 on Pin #5 detected tag: a39ba2aa
Reader #4 on Pin #6 detected tag: 231f2810
Reader #5 on Pin #7 detected tag: d39ca24
Reader #6 on Pin #8 detected tag: 73a6b1aa
Reader #7 on Pin #9 detected tag: 1352d6aa
Reader #8 on Pin #10 detected tag: 1b4f426f
Please edit the opening post, select all code and click the <CODE/> button; next save the post.
This will apply code tags which make your code easier to read and copy and the forum software will display it properly.
Done, thank you for informing me, new here :slight_smile:
Ok, then I assume you have physically swapped reader 9 with one of the other readers and 9 still does not work.
The next step, for me, would be to serial.Print(i) at the places where you are: first, printing what you just listed as showing on the screen, then if that shows all reader values for i, then move to other places where you are iterating through an array and see if i actually goes through the whole array.
Are the readers in close proximity to each other? If so they can interfere with each other and stop them working.
Are you by any chance anything to do with another almost identical post at:-
hmm thats weird, I only did one post. will sort out.
also not close proximitry
