RDA5807M tunes to 118.90 MHz
hi there,
Anyone have an idea why this module tunes to 118.90 and not responds to any commands?
I have tested it with several libreries and they all give the same result.
Code
#include <Arduino.h>
#include <Wire.h>
//RDA5807M library from - https://github.com/mathertel/Radio/tree/master
#include <radio.h>
#include <RDA5807M.h>
// ----- Fixed settings here. -----
#define FIX_BAND RADIO_BAND_FM  ///< The band that will be tuned by this sketch is FM.
#define FIX_STATION 8930        ///< The station that will be tuned by this sketch is 89.30 MHz.
#define FIX_VOLUME 10           ///< The volume that will be set by this sketch is level 4.
RDA5807M radio;  // Create an instance of Class for RDA5807M Chip
/// Setup a FM only radio configuration
/// with some debugging on the Serial port
  delay(3000);
  // open the Serial port
  Serial.println("RDA5807M Radio...");
  delay(200);
  // Enable information to the Serial port
  radio.debugEnable(true);
  radio._wireDebug(false);
  // Set FM Options for Europe
  radio.setup(RADIO_FMSPACING, RADIO_FMSPACING_100);   // for EUROPE
  radio.setup(RADIO_DEEMPHASIS, RADIO_DEEMPHASIS_50);  // for EUROPE
  // Initialize the Radio
  if (!radio.initWire(Wire)) {
    Serial.println("no radio chip found.");
    while(true)
  // Set all radio setting to the fixed values.
  radio.setBandFrequency(FIX_BAND, FIX_STATION);
  radio.setMono(false);
  radio.setMute(false);
  radio.setVolume(FIX_VOLUME);
}  // setup
/// show the current chip data every 3 seconds.
  char s[12];
  radio.formatFrequency(s, sizeof(s));
  Serial.print("Station:");
  Serial.println(s);
  Serial.print("Radio:");
  radio.debugRadioInfo();
  Serial.print("Audio:");
  radio.debugAudioInfo();
  delay(3000);
Serial monitor
Radio: --- -----  MONO   RSSI: 0  SNR: 0
Audio: ---- -------- ----
Station:118.90 MHz
Station:118.90 MHz
Station:118.90 MHz
Station:118.90 MHz
Station:118.90 MHz
Got it to work.
Seems I missed to include a decpupling capacitors near the VCC pin of the module.
