Re: Interactive Traffic light - button doesn't work
First of all, sorry for my english.
I know it's been a while that this topic is not used, but I have a problem with the exercise about the interactive traffic lights excercise from The Arduino Starter Manual of Earthshine Design.
I'm using the simulator 123d.circuits.io and here the code i'm using
// Project 4 - Interactive Traffic Lights
int carRed = 12; // assign the car lights
int carYellow = 11;
int carGreen = 10;
int pedRed = 9; // assign the pedestrian lights
int pedGreen = 8;
int button = 2; // button pin
int crossTime = 5000; // time allowed to cross
unsigned long changeTime; // time since button pressed
 pinMode(carRed, OUTPUT);
 pinMode(carYellow, OUTPUT);
 pinMode(carGreen, OUTPUT);
 pinMode(pedRed, OUTPUT);
 pinMode(pedGreen, OUTPUT);
 pinMode(button, INPUT); // button on pin 2
 // turn on the green light
 digitalWrite(carGreen, HIGH);
 digitalWrite(pedRed, HIGH);
 int state = digitalRead(button);
 /* check if button is pressed and it is
 over 5 seconds since last button press */
 if (state == HIGH && (millis() - changeTime) > 5000) {
 // Call the function to change the lights
 changeLights();
void changeLights() {
 digitalWrite(carGreen, LOW); // green off
 digitalWrite(carYellow, HIGH); // yellow on
 delay(2000); // wait 2 seconds
 digitalWrite(carYellow, LOW); // yellow off
 digitalWrite(carRed, HIGH); // red on
 delay(1000); // wait 1 second till its safe
 digitalWrite(pedRed, LOW); // ped red off
 digitalWrite(pedGreen, HIGH); // ped green on
 delay(crossTime); // wait for preset time period
 // flash the ped green
 for (int x=0; x<10; x++) {
 delay(250);
 digitalWrite(pedGreen, LOW);
 delay(250);
 // turn ped red on
 digitalWrite(carRed, LOW); // red off
 // record the time since last change of lights
 changeTime = millis();
 // then return to the main program loop
I've attached a screen of the circuit.
When i click on start both green leds turn on and they keep to stay on and nothing else happens.
Where the mistake?
Thank you
itl scheme.pdf (84.8 KB)
Hmm, thread hijack and cross-posting, all in less than a quarter of an hour.
AWOL:
Sorry
In setup(), set any outputs not HIGH to LOW.
If that doesn't work
I'm using the simulator...
wouldn't you be better off asking the people who developed the simulator?
dannable:
Thank you for the answer, but I found out the error.
int pedGreen = 8;
In my circuit, according to the manual, the pedestrian red light was connected to the pin number 8 but in the code it says that int pedRed = 9; So i switched the numbers in the code and everything works fine.
Thanks all and sorry for my bad netiquette :slight_smile:
