The ground of the encoder and the ground of the button are common according to the diagram below,
so as far as I understand there is no place for pull down resistor to wire the button.
The version with the external 10K pullup should work if the switch is normally open. Pin 8 should be LOW when the button is pushed. Post the code that did not work, maybe we can fix it. Why not enable the internal pullup on pin 8 (pinMode(8, INPUT_PULLUP) so the external resistor is not required.
groundfungus,
Thank you very much for your reply! Just 15 minutes before your message I found the answer about internal pullups here.
The button works fine now.
Thanks a lot for clearing it up for me anyway!
