Re: Tutorial Request : Fuses
Why do you think so? Without knowing the current and the voltage you cannot select a fuse. The trace made a pretty nice fuse. Add a jumper wire and continue.
You also need to consider where you will place a fuse. Do you want to put one in each signal wire?
To protect input pins that are exposed to the "outside world", a 10K series resistor works well on either digital or analog inputs.
The resistor prevents the input protection diodes from burning out, up to +/- 20V or so.
  • To start, after 50+ years of experience in EE, the conclusion is fuses are protected by the circuit :grimacing:
  • In general, fuses are useful for protecting against catastrophic shorts.
    i.e. a car 12v battery (250 amp) is being used to power an Arduino 10 feet away.
    Place a 1 amp fuse at the battery not at the Arduino.
  • Of importance is fuse coordination; 12 above such circuits requires one 12A fuse at the battery feeding twelve 1A fuses each connected its own Arduino cable.
  • lots of information at Digikey already:
Probably not, in that case, unless it was very carefully chosen.
For experimentation, a current limiting lab power supply is invaluable. Set the current limit to a bit above the maximum that you would expect the project to draw, and it will respond instantaneously to overcurrent. Latching power off is an option on some, as is short circuit protection.
In addition, don't be misled by the voltage rating of a fuse. That ONLY tells you that the ARC when the element melts will self extinguish at the voltage or lower. Of equal importance is the fuse holder, if one is used. Many of the older circuit boards use a thru-hole fuse as one of the components on the board.
A fuse holder must maintain a very firm electrical contact with the fuse connections and be rated for the fuseing value.
No.
The time it takes to blow is many orders of magnitude greater that the time it takes you circuits to blow.
An IC is a device that protects a fuse from blowing.
I once had a neutral wire drop off the spur my house was connected to. This caused it to be supplied by two phases of the three phase voltage. Result was that the AC in my house effectively nearly doubled. I was using an audio amplifier as a baby monitor at the time and the amplifier had a mechanism to protect the right channel. It was called the left channel.
Fuses protect the wires and the supply, not the circuit being fed. They interrupt currents large enough to start fires, as others have noted electronic components are perfect for protecting fuses, not the other way round. Choose a fuse just above the highest current the circuit will draw in normal operation. Some fuses are filled with silica (sand), which quenches the arc that forms when it blows. Consider how much current the power source can supply into a short circuit, for example a car battery can probably supply a couple of thousand amps for a brief period, the same with lithium batteries. HRC, high rupture capacity (with the sand), are appropriate for breaking those kinds of current, especially with DC.
So, consider how much current the supply can feed into a short circuit and how much damage that might do. Use a fuse that is rated to interrupt that much current and use the lowest value fuse for the load being fed. Place the fuse close to the source of power. In a multy cell battery place a fuse between the cells to guarantee they are protected.
Don't assume that. I have seen 13A mains fuses last 5 minutes with 30A before they blew. Not advisable but a good demonstration of the gap between the fuse rating and what it takes to blow them. Try a 2A fuse, if it doesn't blow then it's ok. If it blows try 3A.
Not all fuses will blow in the same time. There are both specialised slow blow fuses as well as fast blow fuses. Then you have resettable fuses, either the type that act like a relay with a mechanical action like the residue ground current you get in mains, or the over current solid state ones like you get in the path between a USB connector and a device.
This latter type I used to use when designing access control systems. The time taken to blow depends on the size of the excess current, sometimes several minutes. So you have to carefully assess each situation. You can also consider the excess current monitoring circuits used in power supplies. The so called crow bar circuits. With this sort of thing you can design your own characteristics to be as complex as you need.
So for your example above I would look at the sort of slow blow fuses you can get and see if they will do.
Just my view (as a hobbyist)
The trace that burned can be considered a wire for the scenario that @Delta_G described. So that can be protected with a fuse in my view.
I would go for a fast fuse that can handle the inrush current of the pcb. Do I see that wrong?
No. I have seen equipment fuses with silver elements that will handle 100 percent of the rated current without heating, but will open with perhaps 10 percent or less overload. My plant had three 200 amp, three-phase services that were fused to blow at just a bit over 200 amps. Turning on a big transformer would sometimes pop a fuse and they were $75 each, so we just left the transformer on 24/7/365.
  • If the short is inside the LiPo battery, which can be the case, no fuse can help.
I don't like LiPo batteries :fire: :grimacing: . They scare the bejesus out of me.
Both those examples involve a battery capable of supplying large currents sufficient to cause a fire. Use fuses.
I would say so. If it can handle inrush current, then it is just a slow blow fuse. Sure it will blow with sustained over current.
I am reminded of a line in the satirical news show called "On the hour". It was and spoof advert for a food processors:-
"We let the fruit mature on the tree slowly, and then we harvest it quickly. "
Here are some data from Littelfuse:
3AG Fast-acting fuse 312/318 Series
0.062A --- 10A: @ 100% load will open in 4 hours Min
135% 1 hour Max
200% 5 seconds Max
3AG Time Lag fuse 373/375 Series
12A, 15A: @ 100% load will open in 4 hours Min
135% 1 hour Max
200% 5 seconds Min
60 seconds Max
3AB Very Fast-Acting fuse 322/332 Series
1A --- 10A: @ 100% load will open in 4 hours Min
250% 0.2 seconds Max
  • Some kind of battery management must be an integral part of these batteries.
    Both in charging and discharging; this would be the responsibility of the manufacturer.
    For cost saving, I am sure many manufacturers cut safety in their designs. :scream:
  • In our region, there have been several instances of spontaneous fires with LiPos.
    One can imagine this can be due to: manufacturing, abuse physical and electrically, deterioration, and environmental.
  • Should we add our own protection circuitry to prevent fire ?
    One needs to ask if the technology is such that there is an inherent/potential problem with LiPos. Shouldn’t we first question if we should even use them, or why should it be up to the end user to provide solutions to battery design flaws.
  • If I had to use LiPos, I would want two levels of overload current discharge protection.
    A fast acting fuse, possibly rated at 3/4 the recommended discharge rate and an electronic disconnect of some sort.
  • As for LiPo batteries that spontaneously catch fire the only solution is don’t use them in the first place.
    Maybe the newer technologies will have a break thru, such as solid state, sodium . . .
They protect the wire between the fuse and whatever is being powered. If the wire shorts to frame it will blow the fuse rather than melt the wire and possibly catch on fire. The fuse amp value is selected in consideration of the wire current carrying capability.
@2112
In the car, we still see the use of conventional fuses; why not using miniature fast-acting circuit breakers?
@GolamMostafa
I can only guess because of size and cost. Primarily cost.
There is a 500 mA polyfuse on the Arduino UNO Borad. It protects both the breadboard and the Power Supply/USB connector of the PC. Does it get opened at over current or its resistance increases to limit the current?
  • IMHO, at its simplest, a fast acting fuse rated at 3/4 the amp rating of your maximum discharge rate of the battery might be a place to start.
  • Let’s assume your battery is rated at 30,000 mAh.
    Let’s assume the maximum discharge current for your application is 10A.
    It might suggest a fast acting fuse of no larger than 15A should be considered.
  • Are the batteries used in an environment where temperatures, ventilation and humidity might be a problem ?
