Hi all!,
my research project involves the measurement of the time of reaction to a simple stimulus test.
I have decided to use arduino to implement a little box for the test execution, with a LED and a button, something like in Arduino Playground - ReactionTimeTester (no need to display data)
I would like to get smaller error bars possible (my arduino duemilanove gives 4 microsecs of accuracy), so I am here to ask the following question:
I will collect people reaction time...something of the order of 300 msec...but using a pc introduces hw and sw delays that I cannot control (standard keyboard signal can take 15 - 20 msec to be detected, depending on the OS, and so on...)
So I think "arduino is what i need".
I'd expect your due to be able to give you that kind of accuracy, either using millis or micros. But if it's people you're measuring, I wouldn't expect them to be able to do much better than 10ms.
Any microcontroller can easily handle this. An Uno can give you much higher resolution than 4uS, as can any of the boards. The 4uS resolution has to do with the prescaler valued picked by the Arduino development team. If you choose no prescaler, you can get 62.5nS resolution with a 16MHz clock. The 16 bit Timer1 would overflow about every 4mS so you'd need to keep track of the overflows.
wildbill:
In the CAD/CAM lectures I attended a long time ago, I think I recall hearing that the fastest reaction time humans can manage is measured in hundredths of a second. Fencers were given as an example.
Arduino advises the resolution for micros() is 8 us for the Uno, and 4 us for the 16 MHz Arduino boards (e.g. Duemilanove and Nano). Does anyone know the micros() resolution for the Due?
Watermargin:
But a Uno is a 16 Mhz 328P board just like a Duemilanove or Nano board, why would the resolution be different?
Watermargin:
Lefty
Not verified, but I'd guess that it's how the timer counter and prescaler are setup initially. If so, it might be possible to modify these to have a finer resolution, but you'd have to write custom code (modify the base code) to read the timer to account for the change.
The "default" resolution for the Uno is also 4uS. It's due to the prescaler of /64 being chosen. Any board with an 8MHz oscillator will have 8uS resolution, and any 16MHz board will have 4uS resolution. You can see that by choosing a prescaler divisor of 1, that the maximum resolution possible is much finer grained at 62.5nS for a 16MHz clock.
I'd like to respond to this thread with ideas from a setup we did use in our lab to measure reaction times. But first off, let me briefly respond to this:
wildbill:
The order of magnitude is indeed right. But the problem we face isn't measuring short reaction times, but precise reaction times. In experimental psychology, we deal with human responses that are highly variable. Mostly because subjects don't necessarily attend to the experiment with care, and, well, we just can't control what's in their head that precisely.
So we want to minimize the variability associated with the reaction times measure. When using the computer, the variability from the human response is added to that of the computer. For us this means that to observe a statistically significant difference between two experiments we'll need the subjects to perform more trials so that this variabilty averages out. That's a loss of time for everyone.
Hence, whatever the average reaction time is (which depends on the task at hand), the problem here is to reduce the variance.
As for the solution we had implemented. We are mostly doing psychoacoustics, so we could use the following trick. A sound card is inherently a very precise piece of hardware temporally speaking. So what we did was using a three channel sound card, two of which send the simuli (stereo), and the last one sending a clic to an arduino (it wasn't an arduino, because they didn't exist at the time, but that's irrelevant). We then had the arduino start a timer that was stopped by a button on the arduino (the subject's response button). The value was then sent to the computer.
The idea is really to have the arduino do the timing, and find a way to send it a "start" signal. In vision experiments, you could imagine doing this by taping a photoresistor to a corner of the screen, which you would light up when the stimulus starts.
recognition!
One of the problems I encountered in an experiment (in the early PC days) with reaction time is that we used a computer screen that refreshed @50 or 60 Hz.
It added between 0 and 20 ms to the average reaction time due to the time the screen took to build up.
