Read data from EEPROM problem
Hi,I’m implementing data writing&reading with EEPROM of NodeMCU to save Wifi’s SSID and password,
I Power On NodeMCU Serial print infomation below:
EEPROM data is empty,can not get value,need SmartConfig!
Wait for SmartConfig
And when i do the smart config i get:
SSID:Superbox_Wifi_6117
PSW:6j6VAF6J7j
WiFi config saved to EEPROM SSID=Superbox_Wifi_6117,password=6j6VAF6J7j
IP address: 192.168.1.140
So everything seems working but when i unplug and plug the nodemcu i get:
Connect WiFi Timeout ,need to ReConfig!
So it seems like it doesnt store the date on eprom could you please tell me what i am doing wrong?
#include <EEPROM.h>
#include <ESP8266WiFi.h>
#include <Ticker.h>
int addr = 0;
int val =0;  //val=1 mean  EPROM saved data , val=0 mean EPROM is empty
String wifi;
String pwd;
Ticker timer0;
WiFiClient espClient;
struct CONFIG
   char ssid[32];
   char pass[32];
CONFIG buf;
void ResetFlag()
   EEPROM.begin(100);
   EEPROM.write(addr,0);
   EEPROM.end();
void SetFlag()
   EEPROM.begin(100);
   EEPROM.write(addr,1);
   EEPROM.end();
void ReConfig()
   ResetFlag();
   Serial.println("Connect WiFi Timeout ,need to ReConfig!");
void smartConfig()
  WiFi.mode(WIFI_STA);
  Serial.println("\r\nWait for SmartConfig");
  WiFi.beginSmartConfig();
  while (1)
    Serial.print(".");
    digitalWrite(LED_BUILTIN, 0);
    delay(200);
    digitalWrite(LED_BUILTIN, 1);
    delay(200);
    if (WiFi.smartConfigDone())
      Serial.println("SmartConfig Success");
      Serial.printf("SSID:%s\r\n", WiFi.SSID().c_str());
      Serial.printf("PSW:%s\r\n", WiFi.psk().c_str());
      wifi=WiFi.SSID();
      pwd =WiFi.psk();
      saveConfig();
      Serial.print("WiFi config saved to EEPROM SSID=");
      Serial.print (buf.ssid);
      Serial.print(",password=");
      Serial.println(buf.pass);
      SetFlag();
      delay(5000);
      Serial.print("IP address: ");
void saveConfig()  /*save config to eeprom */
  EEPROM.begin(512);
  strcpy(buf.ssid, WiFi.SSID().c_str());
  strcpy(buf.pass, WiFi.psk().c_str());
  EEPROM.put<CONFIG>(0, buf);
  EEPROM.commit();
void loadConfig()  /* load config from eeprom */
  EEPROM.begin(512);
  EEPROM.get<CONFIG>(0, buf);
void get_eeprom()
  EEPROM.begin(100);
  val = EEPROM.read(addr);
  if (val==0)
    Serial.println("EEPROM data is empty,can not get value,need SmartConfig!");
    smartConfig();
    Serial.println("Connect to Wifi");
    loadConfig();
    Serial.print("ssid=");Serial.println(buf.ssid);
    Serial.print("password=");Serial.println(buf.pass);
    WiFi.begin(buf.ssid,buf.pass);
    timer0.attach(10,ReConfig);
    while (WiFi.status() != WL_CONNECTED)
      Serial.print(".");
    Serial.println("");
    Serial.println("WiFi connected");
    Serial.println("IP address: ");
  if(!Serial){;}
  delay(3000);
  Serial.println("ESP8266 Module Starting....");
  get_eeprom();
test.ino (2.6 KB)
Hello
    Serial.print(".");
You never stop this timer0 so ReConfig will be called even when Wifi has connected
I suggest that you don't use this Ticker thing, instead increase a counter inside the while loop and call ReConfig when this counter reach a value like 20
Thank you for your reply but when i do this it still wont connect the wifi it will just slow down the serail print and connection attemp. Am i wrong?
I don't really understand what you are trying to do, the smartConfig will already store SSID and password in EEPROM, you don't need to do that manually.
yes i want to store them on eprom so when i unplug and plug the nodemcu i want it to connect to same wifi back again
  • Try connect to wifi
  • If it doesn't connect after a timeout of say 10 seconds, start smartConfig
That's all you have to do. Once smartConfig is done it will save SSID and password for later connections
i did that but it doesnt connect back that is the problem i am trying to solve.
I've just tried, it worked for me
See this quick example
    Serial.begin( 115200 );
    WiFi.mode( WIFI_STA );
    WiFi.begin();
    while(WiFi.status() != WL_CONNECTED)
        Serial.print(".");
        static uint8_t counter = 0;
        if( ++counter == 20 )
            Serial.println("Timeout\nStarting SmartConfig");
            while( !WiFi.smartConfigDone() )
                delay(100);
            Serial.println("SmartConfig done");
    Serial.println( "Should be connected to WiFi" );
Thank you. Now it is working as i intented but i still dont understand where i went wrong. Was it the implementation of the ticker?
