Here are the various way the data from PSRAM can be accessed. If you want to print them as floats then cast them as floats.
//#include "sdkconfig.h" //
//#include "freertos/FreeRTOS.h"
//#include "freertos/task.h"
//#include "freertos/queue.h"
//#include "esp_system.h" //This inclusion configures the peripherals in the ESP system.
#include "esp32-hal-psram.h"
#include "esp_himem.h"
// #include "esp_spiram.h"
// #include "rom/cache.h"
//extern "C"
////#include <esp_himem.h>
//#include <esp_spiram.h>
//extern "C"
const int SerialDataBits = 115200;
struct stuTime
int iSeconds = 0;
int iMinutes = 0;
int iHours = 0;
// Serial.println("========================================");
// Serial.printf("PSRAM total size : %u \n", esp_spiram_get_size());
// Serial.println("----------------------------------------");
// Serial.printf("PSRAM first 4MB size : %u \n", ESP.getPsramSize());
// Serial.printf("PSRAM first 4MB free : %u \n", ESP.getMaxAllocPsram());
// Serial.printf("PSRAM HI-MEM size : %u \n", esp_himem_get_phys_size());
// Serial.printf("PSRAM HI-MEM free : %u \n", esp_himem_get_free_size());
// Serial.printf("Internal RAM size : %u \n", ESP.getHeapSize());
// Serial.printf("Internal RAM free : %u \n", ESP.getFreeHeap());
// Serial.println("Testing the free memory of PSRAM HI-MEM ...");
// test_region(esp_himem_get_free_size(), 0xaaaa);
// Serial.println("Done!");
//esp_spiram_init();
//vTaskDelay(1);
// esp_himem_handle_t mh; //Handle for the address space we're using
// esp_himem_rangehandle_t rh; //Handle for the actual RAM.
// esp_himem_alloc( 1024, &mh);
// Serial.begin( SerialDataBits );
// psramInit();
// vTaskDelay(3);
// esp_spiram_init();
// vTaskDelay(1);
// log_i("Total heap: %u", ESP.getHeapSize());
// log_i("Free heap: %u", ESP.getFreeHeap());
log_i("Total PSRAM: %u", ESP.getPsramSize());
log_i("Free PSRAM: %d", ESP.getFreePsram());
// log_i("spiram size %u", esp_spiram_get_size());
// log_i("himem free %u", esp_himem_get_free_size());
// log_i("himem phys %u", esp_himem_get_phys_size());
// log_i("himem reserved %u", esp_himem_reserved_area_size());
// int *ptr, *ptr1;
// int n, n1, i, sum = 0;
// float *ptrFloat;
// // Get the number of elements for the array
// n = 10;
// n1 = 20;
// log_i("Number of elements ptr: %d", n);
// log_i("Number of elements ptr1: %d", n1);
// log_i("Number of elements ptr1: %d\n", n1);
// // Dynamically allocate memory using malloc()
// // ptr = (int*)ps_malloc(n * sizeof(int)); //works
// ptr = (int*)ps_calloc( n, sizeof(int) ); // works
// log_i("Free PSRAM: %d", ESP.getFreePsram());
// ptr1 = (int*)ps_calloc( n1, sizeof(int) ); // works
// // Check if the memory has been successfully
// // allocated in ps_ram
// ptrFloat = (float*)ps_calloc( n, sizeof(float) ); // works
// if (ptr == NULL) {
// log_i(" ptr memory not allocated.\n");
// exit(0);
// if (ptr1 == NULL)
// log_i("ptr1 memory not allocated.\n");
// exit(0);
// else
// // Memory has been successfully allocated
// // log_i("ps_ram memory successfully allocated using ps_calloc.");
// // put elements into ps_ram array
// for (i = 0; i < n; ++i)
// ptr[i] = i + 1;
// for (i = 0; i < n1; ++i)
// ptr1[i] = i + 2;
// ptrFloat[i] = (float)i + 1.06555f;
// // Print the elements of the array
// log_i("The elements of the ptr array are: ");
// for (i = 0; i < n; ++i) {
// log_i("%d, ", ptr[i]);
// log_i("The elements of the ptr1 array are: ");
// for (i = 0; i < n1; ++i) {
// log_i("%d, ", ptr1[i]);
// log_i("The elements of the ptrFloat array are: ");
// log_i("%f, ", ptrFloat[i]);
// // put a structure into psram. Works.
// struct stuTime *ptrStuTime;
// log_i("size of structure: %d", sizeof(struct stuTime) );
// ptrStuTime = (struct stuTime *)ps_malloc(sizeof(struct stuTime));
// log_i("Free PSRAM after structure: %d", ESP.getFreePsram());
// ptrStuTime->iSeconds = 10;
// ptrStuTime->iMinutes = 60;
// ptrStuTime->iHours = 100;
// log_i("Seconds: %d Minutes: %d Hours: %d", ptrStuTime->iSeconds, ptrStuTime->iMinutes, ptrStuTime->iHours );
// free(ptr);
// free(ptr1);
// free(ptrStuTime);
// // works
// log_i("Free PSRAM before String: %d", ESP.getFreePsram());
// char *str;
// char OneChar = 'a';
// char TwoChar = 'b';
// char ThreeChar = 'c';
// str = (char *)ps_calloc(300, sizeof(char) );
// log_i("Free PSRAM after String: %d", ESP.getFreePsram());
// // concantenate one char variable to end of char array to the str
// strncat( str, &OneChar, 1 ); //works
// strncat( str, &TwoChar, 1 );
// strncat( str, &ThreeChar, 1 );
// //*(str+0) = 'G'; // works
// //*(str+1) = 'f';
// //*(str+2) = 'G';
// //*(str+3) = '\0';
// log_i("%s", str );
// free(str);
//size_t memfree=esp_himem_get_free_size();
//log_i( "himemFree %d", memfree );
// int memcnt=esp_himem_get_phys_size();
// int memfree=esp_himem_get_free_size();
// log_i( "SpiRamPhysSize %d", memcnt );
// log_i( "SpiRamFree %d", memfree );
// esp_himem_get_phys_size(void)
// esp_err_t intError = esp_himem_alloc( 4095, &mh);
// log_i( "%s", esp_err_to_name( intError) );
// log_i( "Handle %d", mh );
} // setup()
/* possible adds to the config
#define CONFIG_ESP32_SPIRAM_SUPPORT 1
#define CONFIG_SPIRAM_BOOT_INIT 1
#define CONFIG_SPIRAM_IGNORE_NOTFOUND 0
#define CONFIG_SPIRAM_USE_MALLOC 1
#define CONFIG_SPIRAM_TYPE_AUTO 1
#define CONFIG_SPIRAM_SIZE -1
#define CONFIG_SPIRAM_SPEED_40M 1
#define CONFIG_SPIRAM_MEMTEST 1
#define CONFIG_SPIRAM_CACHE_WORKAROUND 1
#define CONFIG_SPIRAM_BANKSWITCH_ENABLE 1
#define CONFIG_SPIRAM_BANKSWITCH_RESERVE 4
void loop() {}
static void fill_mem_seed(int seed, void *mem, int len)
// uint32_t *p = (uint32_t *)mem;
//unsigned int rseed = seed ^ 0xa5a5a5a5;
//for (int i = 0; i < len / 4; i++) {
// *p++ = rand_r(&rseed);
//Check the memory filled by fill_mem_seed. Returns true if the data matches the data
//that fill_mem_seed wrote (when given the same seed).
//Returns true if there's a match, false when the region differs from what should be there.
static bool check_mem_seed(int seed, void *mem, int len, int phys_addr)
uint32_t ex = rand_r(&rseed);
if (ex != *p) {
printf("check_mem_seed: %x has 0x%08x expected 0x%08x\n", phys_addr+((char*)p-(char*)mem), *p, ex);
return false;
p++;
return true;
//Allocate a himem region, fill it with data, check it and release it.
static bool test_region(int check_size, int seed)
bool ret = true;
//Allocate the memory we're going to check.
ESP_ERROR_CHECK(esp_himem_alloc(check_size, &mh));
//Allocate a block of address range
ESP_ERROR_CHECK(esp_himem_alloc_map_range(ESP_HIMEM_BLKSZ, &rh));
for (int i = 0; i < check_size; i += ESP_HIMEM_BLKSZ) {
uint32_t *ptr = NULL;
//Map in block, write pseudo-random data, unmap block.
ESP_ERROR_CHECK(esp_himem_map(mh, rh, i, 0, ESP_HIMEM_BLKSZ, 0, (void**)&ptr));
fill_mem_seed(i ^ seed, ptr, ESP_HIMEM_BLKSZ); //
ESP_ERROR_CHECK(esp_himem_unmap(rh, ptr, ESP_HIMEM_BLKSZ));
vTaskDelay(5); //give the OS some time to do things so the task watchdog doesn't bark
uint32_t *ptr;
//Map in block, check against earlier written pseudo-random data, unmap block.
if (!check_mem_seed(i ^ seed, ptr, ESP_HIMEM_BLKSZ, i)) {
printf("Error in block %d\n", i / ESP_HIMEM_BLKSZ);
ret = false;
if (!ret) break; //don't check rest of blocks if error occurred
//Okay, all done!
ESP_ERROR_CHECK(esp_himem_free(mh));
ESP_ERROR_CHECK(esp_himem_free_map_range(rh));
return ret;
What the above code you can look into the individual memory storage locations of your image and do whatever with them.
