Read the data buffer of esp32 cam as binary
Hi, I found this code to reach to the data of captured image. now i'm asking is there any why to read the data as byte(in binary)? and how can do that?
fb = esp_camera_fb_get();
Serial.print(fb->height); Serial.write(','); // write the height
Serial.print(fb->width); Serial.write(','); // write the width
for (int i = 0; i < fb->len; i++){ // dump the pixels' value
Serial.print(fb->buf[i]);
if (i != fb->len -1) Serial.write(',');
else Serial.println();
That line of code retrieves the [i] byte from the image buffer and prints it, so try;
mybyte = fb->buf[i];
all data in memory is binary. it can be displayed in different formats: ascii, decimal, hex, octal.
the code below produces
4,10,232,19,158,38,175,197,114,68,188,109,120,80,102,47,102,143,142,79,160,52,3,124,114,32,70,18,189,123,116,190,247,56,17,157,230,3,139,79,204,66
4,10,E8,13,9E,26,AF,C5,72,44,BC,6D,78,50,66,2F,66,8F,8E,4F,A0,34,3,7C,72,20,46,12,BD,7B,74,BE,F7,38,11,9D,E6,3,8B,4F,CC,42
#define HT  4
#define WID 10
#define LEN (HT*WID)
struct Camera {
    int     height;
    int     width;
    int     len;
    byte    buf [LEN];
} camera = { HT, WID, HT*WID };
void
camInit (void)
    for (int n = 0; n < camera.len; n++)  {
        camera.buf [n] = random (0, 255);
void
alex (
    Camera *fb,
    int     fmt )
    Serial.println ();
    Serial.print (fb->height);
    Serial.write (','); // write the height
    Serial.print (fb->width);
    for (int i = 0; i < fb->len; i++) {
        Serial.write (',');
        Serial.print (fb->buf[i], fmt);
    Serial.println ();
void setup ()
    Serial.begin (9600);
    camInit ();
    alex (& camera, DEC);
    alex (& camera, HEX);
void
loop () {
yes I know and I returned the output to an image. now I need the byte in binary .
which format: hex, octal, bits?
Thank you so much, I need the output in binary!
Bits
this?
4,10,11111111,00000000,11111111,00000000,11111111,11111111,00000000,00000000,11111111,00000000,00000000,00000000,00000000,00000000,00000000,11111111,11111111,00000000,11111111,00000000,00000000,00000000,00000000,00000000,00000000,00000000,11111111,00000000,00000000,11111111,11111111,00000000,00000000,11111111,11111111,00000000,11111111,00000000,11111111,00000000
yes :slight_smile: ,
corrected output
4,10,11101000,00010011,10011110,00100110,10101111,11000101,01110010,01000100,10111100,01101101,01111000,01010000,01100110,00101111,01100110,10001111,10001110,01001111,10100000,00110100,00000011,01111100,01110010,00100000,01000110,00010010,10111101,01111011,01110100,10111110,11110111,00111000,00010001,10011101,11100110,00000011,10001011,01001111,11001100,01000010
#define HT  4
#define WID 10
struct Camera {
    int     height;
    int     width;
    int     len;
    byte    buf [LEN];
void
camInit (void)
void
alex (
    Camera *fb,
    int     fmt )
    Serial.println ();
        Serial.write (',');
    Serial.println ();
void
alexBits (
    Camera *fb )
    Serial.println ();
        Serial.write (',');
        byte val = fb->buf[i];
        for (int b = 0; b < 8; b++, val <<= 1)  {
            bool bit = val & 0x80;
            Serial.print (bit);
    Serial.println ();
void setup ()
    camInit ();
    alexBits (& camera);
void
loop () {
The esp_camera_fb)get()_ returns fb which is a binary array of bytes in binary.
#include "sdkconfig.h" // used for log printing
#include "esp_system.h"
#include "freertos/FreeRTOS.h" //freeRTOS items to be used
#include "freertos/task.h"
#include "certs.h"
#include "esp_camera.h"
#include "soc/soc.h"           // Disable brownout problems
#include "soc/rtc_cntl_reg.h"  // Disable brownout problems
#include "driver/rtc_io.h"
#include <WiFi.h>
#include <WiFiClient.h>
#include "ESP32_FTPClient.h"
#include <PubSubClient.h>
#include <ESP32Time.h>
WiFiClient      wifiClient; // do the WiFi instantiation thing
PubSubClient    MQTTclient( mqtt_server, mqtt_port, wifiClient ); //do the MQTT instantiation thing
ESP32_FTPClient ftp (ftp_server, ftp_user, ftp_pass, 5000, 2);
ESP32Time       rtc;
//#define evtDoMQTTParse  ( 1 << 0 ) // declare an event
//EventGroupHandle_t eg; // variable for the event group handle
SemaphoreHandle_t sema_MQTT_KeepAlive;
SemaphoreHandle_t sema_mqttOK;
QueueHandle_t xQ_Message; // payload and topic queue of MQTT payload and topic
const int payloadSize = 300;
struct stu_message
  char payload [payloadSize] = {'\0'};
  String topic ;
} x_message;
int  mqttOK = 0;
bool TimeSet = false;
bool FlashMode = false;
void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
  switch (event) {
    case SYSTEM_EVENT_STA_CONNECTED:
      log_i("Connected to WiFi access point");
    case SYSTEM_EVENT_STA_DISCONNECTED:
      log_i("Disconnected from WiFi access point");
    case SYSTEM_EVENT_AP_STADISCONNECTED:
      log_i("WiFi client disconnected");
    default: break;
} // void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
void IRAM_ATTR mqttCallback(char* topic, byte * payload, unsigned int length)
  // clear locations
  memset( x_message.payload, '\0', payloadSize );
  x_message.topic = ""; //clear string buffer
  x_message.topic = topic;
  int i = 0;
  for ( i; i < length; i++)
    x_message.payload[i] = ((char)payload[i]);
  x_message.payload[i] = '\0';
  xQueueOverwrite( xQ_Message, (void *) &x_message );// send data to queue
} // void mqttCallback(char* topic, byte* payload, unsigned int length)
  pinMode( GPIO_NUM_4, OUTPUT);
  digitalWrite( GPIO_NUM_4, LOW);
  WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0); //disable brownout detector
  //eg = xEventGroupCreate(); // get an event group handle
  x_message.topic.reserve( payloadSize );
  xQ_Message  = xQueueCreate( 1, sizeof(stu_message) );
  sema_mqttOK    =  xSemaphoreCreateBinary();
  xSemaphoreGive( sema_mqttOK );
  xTaskCreatePinnedToCore( MQTTkeepalive, "MQTTkeepalive", 7000, NULL, 3, NULL, 1 );
  xTaskCreatePinnedToCore( fparseMQTT, "fparseMQTT", 9000, NULL, 4, NULL, 1 ); // assign all to core 1, WiFi in use.
  xTaskCreatePinnedToCore( fmqttWatchDog, "fmqttWatchDog", 3000, NULL, 2, NULL, 1 );
  if ( configInitCamera() )
    log_i("        start camera task" );
    xTaskCreatePinnedToCore( capturePhoto_sendFTP, "capturePhoto_sendFTP", 60000, NULL, 6, NULL, 1 );
    log_i( "       camera failed to initilize, rebooting in 5." );
    vTaskDelay( 2000 );
    ESP.restart();
} // void setup()
void capturePhoto_sendFTP( void *pvParameters )
  TickType_t xLastWakeTime    = xTaskGetTickCount();
  const TickType_t xFrequency = 1000 * 5; //delay for mS
  int count = 3;
  //!!!!!Must wait for MQTT connection and proper setup of the sema_MQTT_KeepAlive!!!!
  while ( !MQTTclient.connected() )
    vTaskDelay( 500 );
  for (;;)
    log_i( "tick");
    xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY );
    if ( count == 3 )
      if ( (wifiClient.connected()) && (WiFi.status() == WL_CONNECTED) )
        camera_fb_t * fb = NULL; // pointer
        if ( FlashMode )
          digitalWrite( GPIO_NUM_4, HIGH );
          vTaskDelay( 20 );
        digitalWrite( GPIO_NUM_4, LOW );
        if (!fb)
          log_i( "Camera capture failed" );
          esp_camera_fb_return(fb);
        } else
          ftp.OpenConnection(); // try open FTP
          if ( ftp.isConnected() )
            //try send file ftp
            ftp.ChangeWorkDir( ftp_path );
            ftp.DeleteFile( ftp_file_name );
            ftp.InitFile( ftp_file_type ); //"Type I"
            ftp.NewFile( ftp_file_name );
            ftp.WriteData( (unsigned char *)fb->buf, fb->len );
            ftp.CloseFile();
            ftp.CloseConnection();
          esp_camera_fb_return(fb); //return the frame buffer back to the driver for reuse
      count = 0;
      vTaskDelay( 5 );
      vTaskDelay( 5 );
    xSemaphoreGive( sema_MQTT_KeepAlive );
    count++;
    vTaskDelayUntil( &xLastWakeTime, xFrequency );
  vTaskDelete( NULL );
} //void capturePhoto_sendFTP( void *pvParameters )
void configureCameraSettings_grpE( int _lenC, int _Hmirror, int _Vflip, int _dcw, int _colorbar )
  sensor_t * s = esp_camera_sensor_get();
  s->set_lenc(s, _lenC);         // 0 = disable , 1 = enable
  s->set_hmirror(s, _Hmirror);   // 0 = disable , 1 = enable
  s->set_vflip(s, _Vflip);       // 0 = disable , 1 = enable
  s->set_dcw(s, _dcw);           // 0 = disable , 1 = enable
  ////s->set_colorbar(s, _colorbar); // 0 = disable , 1 = enable
void configureCameraSettings_grpD( int _gc, int _agc, int _celing, int _bpc, int _wpc, int _gma )
  s->set_gain_ctrl(s, _gc); // 0 = disable , 1 = enable
  s->set_agc_gain(s, _agc); // 0 to 30
  s->set_gainceiling(s, (gainceiling_t)_celing);  // 0 to 6
  s->set_bpc(s, _bpc);      // 0 = disable , 1 = enable
  s->set_wpc(s, _wpc);      // 0 = disable , 1 = enable
  s->set_raw_gma(s, _gma);  // 0 = disable , 1 = enable
void configureCameraSettings_grpC( int _exctl, int _aec2, int _ae, int _aec )
  s->set_exposure_ctrl(s, _exctl); // 0 = disable , 1 = enable
  s->set_aec2(s, _aec2);           // 0 = disable , 1 = enable
  s->set_ae_level(s, _ae);         // -2 to 2
  ////s->set_aec_value(s, _aec);       // 0 to 1200 CAUSES BLACK IMAGE????
void configureCameraSettings_grpB( int se, int wb, int awb, int wbmode )
  s->set_special_effect(s, se); // 0 to 6 (0 - No Effect, 1 - Negative, 2 - Grayscale, 3 - Red Tint, 4 - Green Tint, 5 - Blue Tint, 6 - Sepia)
  s->set_whitebal(s, wb);       // 0 = disable , 1 = enable
  s->set_awb_gain(s, awb);      // 0 = disable , 1 = enable
  s->set_wb_mode(s, wbmode);    // 0 to 4 - if awb_gain enabled (0 - Auto, 1 - Sunny, 2 - Cloudy, 3 - Office, 4 - Home)
void configureCameraSettings_grpA(int brightness, int contrast, int saturation )
  if ( ((brightness > -3) && (brightness < 3)) && ((contrast > -3) && (contrast < 3)) && ((saturation > -3) && (saturation < 3)) )
    s->set_brightness( s, brightness ); // -2 to 2
    s->set_contrast( s, contrast );    // -2 to 2
    s->set_saturation( s, saturation );  // -2 to 2
} //void configureCameraSettings()
  sensor_t * s = esp_camera_sensor_get(); //see certs.h for more info
  s->set_brightness(s, -1);     // -2 to 2 **************************
  s->set_contrast(s, 0);       // -2 to 2
  s->set_saturation(s, 0);     // -2 to 2
  s->set_special_effect(s, 0); // 0 to 6 (0 - No Effect, 1 - Negative, 2 - Grayscale, 3 - Red Tint, 4 - Green Tint, 5 - Blue Tint, 6 - Sepia)
  s->set_whitebal(s, 1);       // 0 = disable , 1 = enable
  s->set_awb_gain(s, 1);       // 0 = disable , 1 = enable
  s->set_wb_mode(s, 0);        // 0 to 4 - if awb_gain enabled (0 - Auto, 1 - Sunny, 2 - Cloudy, 3 - Office, 4 - Home)
  s->set_exposure_ctrl(s, 1);  // 0 = disable , 1 = enable
  s->set_aec2(s, 0);           // 0 = disable , 1 = enable
  s->set_ae_level(s, 0);       // -2 to 2
  s->set_aec_value(s, 300);    // 0 to 1200
  s->set_gain_ctrl(s, 1);      // 0 = disable , 1 = enable
  s->set_agc_gain(s, 0);       // 0 to 30
  s->set_gainceiling(s, (gainceiling_t)0);  // 0 to 6
  s->set_bpc(s, 0);            // 0 = disable , 1 = enable
  s->set_wpc(s, 1);            // 0 = disable , 1 = enable
  s->set_raw_gma(s, 1);        // 0 = disable , 1 = enable
  s->set_lenc(s, 1);           // 0 = disable , 1 = enable
  s->set_hmirror(s, 0);        // 0 = disable , 1 = enable
  s->set_vflip(s, 0);          // 0 = disable , 1 = enable
  s->set_dcw(s, 1);            // 0 = disable , 1 = enable
  s->set_colorbar(s, 0);       // 0 = disable , 1 = enable
bool configInitCamera()
  camera_config_t config = {}; // Stores the camera configuration parameters
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer   = LEDC_TIMER_0;
  config.pin_d0       = GPIO_NUM_5; //Y2
  config.pin_d1       = GPIO_NUM_18; //Y3
  config.pin_d2       = GPIO_NUM_19; //Y4
  config.pin_d3       = GPIO_NUM_21; //Y5
  config.pin_d4       = GPIO_NUM_36; //Y6
  config.pin_d5       = GPIO_NUM_39; //Y7
  config.pin_d6       = GPIO_NUM_34; //Y8
  config.pin_d7       = GPIO_NUM_35; // Y9
  config.pin_xclk     = GPIO_NUM_0; //XCLK
  config.pin_pclk     = GPIO_NUM_22; //PCLK
  config.pin_vsync    = GPIO_NUM_25; //VSSYNC
  config.pin_href     = GPIO_NUM_23; // HREF
  config.pin_sscb_sda = GPIO_NUM_26; //SIOD
  config.pin_sscb_scl = GPIO_NUM_27; //SIOC
  config.pin_pwdn     = GPIO_NUM_32; //PWDN
  config.pin_reset    = -1; //RESET
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG; //assuming default is has PSRAM
  config.frame_size = FRAMESIZE_UXGA; // FRAMESIZE_ + QVGA|CIF|VGA|SVGA|XGA|SXGA|UXGA
  config.jpeg_quality = 10; //0-63 lower number means higher quality
  config.fb_count = 2;
  // Initialize the Camera
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    log_i("Camera init failed with error %d", err );
    return false;
    configureCameraSettings();
    return true;
} //void configInitCamera()
void connectToWiFi()
  int TryCount = 0;
  while ( WiFi.status() != WL_CONNECTED )
    TryCount++;
    WiFi.disconnect();
    WiFi.begin( SSID, PASSWORD );
    vTaskDelay( 2500 );
    if ( TryCount == 10 )
      ESP.restart();
  WiFi.onEvent( WiFiEvent );
void MQTTkeepalive( void *pvParameters )
  sema_MQTT_KeepAlive   = xSemaphoreCreateBinary();
  xSemaphoreGive( sema_MQTT_KeepAlive ); // found keep alive can mess with a publish, stop keep alive during publish
  MQTTclient.setKeepAlive( 90 ); // setting keep alive to 90 seconds makes for a very reliable connection, must be set before the 1st connection is made.
  const TickType_t xFrequency = 250; //delay for ms
  for (;;)
    //check for a is-connected and if the WiFi 'thinks' its connected, found checking on both is more realible than just a single check
      xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY ); // !!!!!whiles MQTTlient.loop() is running no other mqtt operations should be in process!!!!!
      MQTTclient.loop();
    else {
      if ( !(wifiClient.connected()) || !(WiFi.status() == WL_CONNECTED) )
        connectToWiFi();
      connectToMQTT();
  vTaskDelete ( NULL );
void connectToMQTT()
  byte mac[5]; // create client ID from mac address
  WiFi.macAddress(mac); // get mac address
  String clientID = String(mac[0]) + String(mac[4]) ; // use mac address to create clientID
    MQTTclient.connect( clientID.c_str(), mqtt_username, mqtt_password );
    vTaskDelay( 250 );
  MQTTclient.setCallback( mqttCallback );
  MQTTclient.subscribe( topicOK );
  MQTTclient.subscribe( topicGrpA );
  MQTTclient.subscribe( topicGrpB );
  MQTTclient.subscribe( topicGrpC );
  MQTTclient.subscribe( topicGrpD );
  MQTTclient.subscribe( topicGrpE );
  MQTTclient.subscribe( topicFlash );
} //void connectToMQTT()
void fmqttWatchDog( void * paramater )
  int UpdateImeTrigger = 86400; //seconds in a day
  int UpdateTimeInterval = 85000; // get another reading when = UpdateTimeTrigger
  int maxNonMQTTresponse = 3;
  const TickType_t xFrequency = 60000; //delay for mS
  for (;;)
    xSemaphoreTake( sema_mqttOK, portMAX_DELAY ); // update mqttOK
    mqttOK++;
    if ( mqttOK >= maxNonMQTTresponse )
      log_i( "mqtt watchdog rest" );
      vTaskDelay( 200 );
      ESP.restart();
    UpdateTimeInterval++; // trigger new time get
    if ( UpdateTimeInterval >= UpdateImeTrigger )
      TimeSet = false; // sets doneTime to false to get an updated time after a days count of seconds
      UpdateTimeInterval = 0;
} //void fmqttWatchDog( void * paramater )
void fparseMQTT( void *pvParameters )
  struct stu_message px_message;
  for (;;)
    if ( xQueueReceive(xQ_Message, &px_message, portMAX_DELAY) == pdTRUE )
      mqttOK = 0;
      if ( !TimeSet)
        if ( String(px_message.topic) == topicOK )
          String temp = "";
          temp        = px_message.payload[0];
          temp        += px_message.payload[1];
          temp        += px_message.payload[2];
          temp        += px_message.payload[3];
          int year    =  temp.toInt();
          temp        = "";
          temp        = px_message.payload[5];
          temp        += px_message.payload[6];
          int month   =  temp.toInt();
          temp        = "";
          temp        = px_message.payload[8];
          temp        += px_message.payload[9];
          int day     =  temp.toInt();
          temp        = "";
          temp        = px_message.payload[11];
          temp        += px_message.payload[12];
          int hour    =  temp.toInt();
          temp        = "";
          temp        = px_message.payload[14];
          temp        += px_message.payload[15];
          int min     =  temp.toInt();
          rtc.setTime( 0, min, hour, day, month, year );
          log_i( "%s   rtc  %s ", px_message.payload, rtc.getTime() );
          TimeSet     = true;
      if ( String(px_message.topic) == topicGrpA )
        //finding first letter
        String sTmp = String( px_message.payload );
        int commaIndex = sTmp.indexOf(',');
        if ( sTmp.substring(0, commaIndex) == "a" );
          int brt =  (sTmp.substring(0, commaIndex)).toInt();
          sTmp.remove( 0, (commaIndex + 1) );
          int ctrast = (sTmp.substring(0, commaIndex)).toInt();
          sTmp.remove( 0, (commaIndex + 1) ); // chop off begining of message
          int sat = (sTmp.substring(0, commaIndex)).toInt();
          configureCameraSettings_grpA( brt, ctrast, sat );
      if ( String(px_message.topic) == topicGrpB )
        if ( sTmp.substring(0, commaIndex) == "b" );
          int se =  (sTmp.substring(0, commaIndex)).toInt();
          int wbb = (sTmp.substring(0, commaIndex)).toInt();
          int wba = (sTmp.substring(0, commaIndex)).toInt();
          int wbm = (sTmp.substring(0, commaIndex)).toInt();
          configureCameraSettings_grpB( se, wbb, wba, wbm );
      if ( String(px_message.topic) == topicGrpC )
        if ( sTmp.substring(0, commaIndex) == "c" );
          int ex =  (sTmp.substring(0, commaIndex)).toInt();
          int aec2 = (sTmp.substring(0, commaIndex)).toInt();
          int ae = (sTmp.substring(0, commaIndex)).toInt();
          int aec = (sTmp.substring(0, commaIndex)).toInt();
          configureCameraSettings_grpC( ex, aec2, ae, aec );
      if ( String(px_message.topic) == topicGrpD )
        if ( sTmp.substring(0, commaIndex) == "d" );
          int gc =  (sTmp.substring(0, commaIndex)).toInt();
          int agc = (sTmp.substring(0, commaIndex)).toInt();
          int celing = (sTmp.substring(0, commaIndex)).toInt();
          int bpc = (sTmp.substring(0, commaIndex)).toInt();
          int wpc = (sTmp.substring(0, commaIndex)).toInt();
          int gma = (sTmp.substring(0, commaIndex)).toInt();
          configureCameraSettings_grpD( gc, agc, celing, bpc, wpc, gma );
      if ( String(px_message.topic) == topicGrpE )
        if ( sTmp.substring(0, commaIndex) == "e" );
          int lenC =  (sTmp.substring(0, commaIndex)).toInt();
          int Hmirror = (sTmp.substring(0, commaIndex)).toInt();
          int Vflip = (sTmp.substring(0, commaIndex)).toInt();
          int dcw = (sTmp.substring(0, commaIndex)).toInt();
          int colorbar = (sTmp.substring(0, commaIndex)).toInt();
          configureCameraSettings_grpE( lenC, Hmirror, Vflip, dcw, colorbar );
      if ( String(px_message.topic) == topicFlash )
        FlashMode = !FlashMode;
    } //if ( xQueueReceive(xQ_Message, &px_message, portMAX_DELAY) == pdTRUE )
  } //for(;;)
} // void fparseMQTT( void *pvParameters )
void loop() {}
You may see the line of code ftp.WriteData( (unsigned char *)fb->buf, fb->len ); where I transfer bytes of binary data via FTP. The data in FB is already binary and bytes.
I needed to that to check the size of my file because I have image (120 * 160) and the format of pixels value are RGB888 so, the total size must be = (120 * 160 * 3 = 57600 byte), now I copied these values in txt file. the size of file = 188 KB (193,515 bytes) WHY? I thought the size of txt file should be near to 57600 byte !
therefore, now I need check with binary
yes thank you, I needed to that to check the size of my file because I have image (120 * 160) and the format of pixels value are RGB888 so, the total size must be = (120 * 160 * 3 = 57600 byte), now I copied these values in txt file. the size of file = 188 KB (193,515 bytes) WHY? I thought the size of txt file should be near to 57600 byte !
Will print a byte such as 0xAA as '1' then '7' then '0', so three ASCII characters and bytes where one byte would do, however;
Serial.write(fb->buf[i]);
Would only write the 0xAA to the 'file'
Sorry I don't understand, I mean the difference in size when I print
fb->len that = 57600. therefor, I thought the size of (.txt file) should be near to 57600 byte ?
Is the length that the total binary file will be. Converting a binary file to text will NOT result in the same file size.
Lets say you have a 1. Let's say you have a 8 bit 1, 0000001. You want that as text. "0000001" occupies more bytes then 00000001b. The ESP32CAM stores each Byte into a 32 bit binary address. A byte then looks like this 0000000000000000000000000000b. A "1" looks like this 0000000000000000000000000001b a string of 32 bits "0000000000000000000000000000" is a lot longer then a 32 bit binary number.
Understand?
Why dont you print out the length of the image taken by the ESP32CAM and see if it matches what you think it should be ?
I printed it and the picture has a size of 120 * 160 and the format for the pixels is RGB, my question, If I have 57,600 bytes, why is the size of the Notepad not close to this number?
Show us the code you used to print out the actual length of the image taken by the ESP32CAM.
Better still why not post all the code you are using.
Sorry, I think you didn't understand what I meant. I didn't convert the file. I just dealt with a sized image (120*160) with RGB format and then I printed the buffer after that copy the output in notepad (as txt file). I'm wondering why the size of the .txt is not close to 57600?
