I simplified the project slightly and added a second sensor as I have 2 tanks. I managed to get the transmitter to send 2 values, one for each tank. to distinguish the 2 values I programmed the transmitter to send the value for Tank2 as negative (timed it by -1).
The code below is for the receiver. The result should be displayed on the LCD screen
TANK 1 - xx%
TANK 2 - xx%
For some reason I am getting the 2 numbers flashing on the TANK 1 line. One number is positive and the other negative.
I am using an arduino UNO R3 for the project. The code worked well with one sensor.
Can anyone help?
/* Reciever for water tank *//
#include <LiquidCrystal.h>
#include <SoftwareSerial.h>
SoftwareSerial HC12(7, 8);
LiquidCrystal lcd{12, 11, 2, 3, 4, 5};
int data = 0;
int TANK1 = 0;
int TANK2 = 0;
int contrast = A4;
int backlight = A5;
int ground = 13;
lcd.begin(16,2);
HC12.begin(9600);
pinMode(contrast, OUTPUT);
pinMode(ground, OUTPUT);
pinMode(backlight, OUTPUT);
analogWrite(contrast,10);
digitalWrite(ground, 0);
// Boot-up message //
lcd.setCursor(0,0);
lcd.print(" WELCOME ");
lcd.setCursor(0,1);
lcd.print(" -Nir-");
digitalWrite(backlight, 1);
while(HC12.available ()){
lcd.clear();
data = HC12.read();
if (data < 0) {data = data * -1;
TANK2 = map(data, 20, 175, 100, 0);}
else {TANK1 = map(data, 20, 175, 100, 0);}
lcd.setCursor(0,0);
lcd.print("TANK 1-");
lcd.print(TANK1);
lcd.print("%");
lcd.setCursor(0,1);
lcd.print("TANK 2-");
lcd.print(TANK2);
lcd.print("%");
Not with the code you posted. It doesn't even compile.
arduino-cli compile -b arduino:avr:uno --warnings all --output-dir ~/tmp --no-color (in directory: /home/me/Documents/sketchbook/Uno_R3/test)
/home/me/Documents/sketchbook/Uno_R3/test/test.ino:1:31: error: expected unqualified-id before '/' token
/* Reciever for water tank */ /
/home/me/Documents/sketchbook/Uno_R3/test/test.ino:6:1: error: 'LiquidCrystal' does not name a type; did you mean 'LiquidCrystal_h'?
LiquidCrystal lcd{ 12, 11, 2, 3, 4, 5 };
LiquidCrystal_h
/home/me/Documents/sketchbook/Uno_R3/test/test.ino: In function 'void setup()':
/home/me/Documents/sketchbook/Uno_R3/test/test.ino:16:4: error: 'lcd' was not declared in this scope
lcd.begin(16, 2);
/home/me/Documents/sketchbook/Uno_R3/test/test.ino: In function 'void loop()':
/home/me/Documents/sketchbook/Uno_R3/test/test.ino:37:7: error: 'lcd' was not declared in this scope
lcd.clear();
Used library Version Path
LiquidCrystal 1.0.7 /home/me/Documents/sketchbook/libraries/LiquidCrystal
SoftwareSerial 1.0 /home/me/.arduino15/packages/arduino/hardware/avr/1.8.3/libraries/SoftwareSerial
Used platform Version Path
arduino:avr 1.8.3 /home/me/.arduino15/packages/arduino/hardware/avr/1.8.3
Error during build: exit status 1
Compilation failed.
As you probably guessed, I am not a very experienced programmer. I used the code from the watertank project as a basis for my project. I did think that it was strange the the ground was allocated a pin... especially since nothing is connected to that pin in the actual board.
Below is the sender code. I am using a Atmel Atmega328, a HC module and 2 sonic sensors.
I tested it first with the serial monitor and I got correct readings one positive and one negative. The receiver unit is receiving a negative and positive value as they are being displayed on the screen. The only thing is that the number for TANK2 which is the neagative one is still showing negative and it is displayed in the TANK 1 line. The 2 values are alternating.
//* Water tank sensor transmitter*//
SoftwareSerial HC12(4, 5);
int POWER = 6;
long dist_1 = 0;
long dist_2a = 0;
long dist_2 = 0;
int TRIG1 = 2;
int ECHO1 = 3;
int TRIG2 = 8;
int ECHO2 = 7;
HC12.begin(9600);
pinMode(TRIG1, OUTPUT);
digitalWrite(TRIG1, LOW);
pinMode(ECHO1, INPUT);
pinMode(POWER, OUTPUT);
digitalWrite(POWER , 1);
pinMode(TRIG2, OUTPUT);
digitalWrite(TRIG2, LOW);
pinMode(ECHO2, INPUT);
delayMicroseconds(5);
digitalWrite(TRIG1, HIGH);
delayMicroseconds(10);
dist_1 = (pulseIn(ECHO1, HIGH))*0.034/2;
HC12.write(dist_1);
digitalWrite(TRIG2, HIGH);
dist_2 = (pulseIn(ECHO2, HIGH))*0.034/2;
dist_2a = dist_2 * -1;
HC12.write(dist_2a);
It looks as if the if/else statement is not doing what I would like it to do.
The narrative is: if the number in data is negative then time it by -1 (to make it positive again) and use it to with the map function in TANK2. Otherwise use data with the map function in TANK1.
What is happening is that data is used in the map function in TANK1 for both the negative and positive number. The if statement is ignored.
The HC12.write() statement is only sending the lowest 8 bits of long value returned by pulseIn(). There is no sign information in the data you are sending with
I think you will find easier going if you change the the structure of the program to send ascii data with .print() statements and follow the guidelines of the Serial Input Basics tutorial on how to read the multi digit numbers. You can then look for the char of the negative sign '-' or possibly change the transmission to have a tank indicator as well as the sign of the data.
