Is it possible to read and display General MIDI signals from any device or any instrument on a general 16x2 LCD with Arduino ?
With pin details and all that !!
Yes.
a7
Woww Great !
So how to get a startup for this to make a proper setup ?
Please guide !!
You are new here, so I will explain that this is not a code-on-demand service forum, it's a "let's help you with the sketch you are writing and having trouble with" forum
Post the code you are currently working on, and say what it does that it should not, or what it is not doing that it should.
Post a schematic of the project as it is now.
Post links to any libraries and hardware that you are using.
a7
Different type of display, same idea: Control Surface: MIDI-Monitor-OLED.ino
Ya so many things are there to observe !!
I am unable to find connections with pin details and schematics
Where I would find so ??
What would you use as websearch parameters ?
Did you even glance at the link @PieterP provided?
I glanced and assert that it should keep you busy for awhile.
Looks like enough for a competent hobbyist like yourself to use directly or adapt for whatever exactly you want to do that differs.
Tell us exactly how what you want is not that project.
a7
