Hello
I'm trying to read from several load cells using the Sprakfun HX711 board:
Because my arduino dosent have enoghf IO pins i disded to use Sparkfun's IO expander board SX1509:
As i mentioned, my purpose is to read from several Load cells.
This is my hookup for 1 HX711 amplifier, SX1509 and arduino.
The connection is very simple:
arduino____SX1509____HX711
SCL------------SCL
SDA -----------SDA
GND---------- GND---------- GND
3.3V-----------3v3----------- VDD
5V------------------------------VCC
----------------- 0------------- CLK
----------------- 1------------- DAT
For Start, from the HX711.cpp original library i took the read function, and placed it into arduino code, to see if this is the only function that i need to read RAW data from the HX711.
and it was all right and good.
After finding the calibration factor and the offset i could translate the RAW data to real force/weight.
Then i adjusted it a little bit and added my function to the SX1509.cpp original literary:
(of curse i declared on this function in the header file - SX1509.h):
long SX1509::read_my(byte DOUT, byte PD_SCK)
long SX1509::read_my(byte DOUT, byte PD_SCK) {
// byte DOUT = 1;
// byte PD_SCK = 0;
byte GAIN = 1;
unsigned long value = 0;
uint8_t data[3] = { 0 };
uint8_t filler = 0x00;
// pulse the clock pin 24 times to read the data
data[2] = shiftIn(DOUT, PD_SCK, MSBFIRST);
data[1] = shiftIn(DOUT, PD_SCK, MSBFIRST);
data[0] = shiftIn(DOUT, PD_SCK, MSBFIRST);
// set the channel and the gain factor for the next reading using the clock pin
for (unsigned int i = 0; i < GAIN; i++) {
digitalWrite(PD_SCK, HIGH);
digitalWrite(PD_SCK, LOW);
// Replicate the most significant bit to pad out a 32-bit signed integer
if (data[2] & 0x80) {
filler = 0xFF;
filler = 0x00;
// Construct a 32-bit signed integer
value = ( static_cast<unsigned long>(filler) << 24
| static_cast<unsigned long>(data[2]) << 16
| static_cast<unsigned long>(data[1]) << 8
| static_cast<unsigned long>(data[0]) );
return static_cast<long>(value);
Then i tried to use it like that:
#include <Wire.h> // Include the I2C library (required)
#include <SparkFunSX1509.h> // Include SX1509 library
#define SX1509_Data 1
#define SX1509_CSK 0
const byte SX1509_ADDRESS = 0x3E; // SX1509 I2C address
SX1509 io; // Create an SX1509 object to be used throughout
void setup(){
Serial.begin(38400);
delay(10);
if (!io.begin(SX1509_ADDRESS))
Serial.println("Failed to communicate.");
Serial.println("SX1509 Alive");
delay(10);
io.pinMode(SX1509_Data, INPUT);
io.pinMode(SX1509_CSK, OUTPUT);
Serial.println("Starting:");
Serial.print("Reading: ");
long t1 = io.read_my(SX1509_Data, SX1509_CSK);
Serial.println(t1);
delay(100);
Unfortunately the result that i'm getting is very different form the first attempt. And the values are jumping from 1 value to another, and it seems to be constant no matter what force i apply on the load cell.
I would appreciate if you could help me with that
Thanks.
Moderator: Link Tags added
