Using the AD9858 evaluation board, I am trying to read back the content of the FTW contained in the register (0x03) through the SDO pin 18 connected to pin 12 on the Arduino Nano. I can write and get the correct frequency equal to the FTW but haven't manage to do a read.
The circuit:
* analog evaluation board AD9858 Rev(D)
* External control pins of board attached to Arduino as follows:
** RESET ---------pin D6
** RDB (CS)-------pin D4
** WRB (SCLK)-----pin D13
** A0 (SDIO)------pin D11
** A1 (SDO)-------pin D12
** A2 (IORESET)---pin D2
** FUD -----------pin D7
#include <SPI.h>
const int RESET = 6;
const int RDBcs = 4;
const int WRBsclk = 13;
const int A2ioreset = 2;
const int FUD = 7;
const int timer = 100;
int iB = 0;
const byte READ = 0x80;
const byte WRITE = 0x00;
char buffer[10];
byte startPosition=0;
//Output frequency
byte byte1=0xf6; //LSB
byte byte2=0x28;
byte byte3=0x5c;
byte byte4=0x0f;//MSB
//---------Functions-----------
void FUD_Toggle()
digitalWrite (FUD, HIGH);
delay(timer); // Delay in millisecond
digitalWrite (FUD, LOW);
void Reset_Com()
digitalWrite (A2ioreset, HIGH);
delay(timer);
digitalWrite (A2ioreset, LOW);
void Reset_DDS()
digitalWrite (RESET, HIGH);
delay(timer);
digitalWrite (RESET, LOW);
// Open serial communications and wait for port to open
SPI.begin();
// Set pin 10 to output, even if not in use
pinMode(10, OUTPUT);
pinMode(RESET, OUTPUT);
pinMode(FUD, OUTPUT);
pinMode(A2ioreset,OUTPUT);
digitalWrite (RDBcs, HIGH);
Reset_DDS();
Reset_Com();
digitalWrite (RDBcs, LOW);
//--------Main Program------------------------
SPI.setDataMode(SPI_MODE0); //Rising edge - added as falling edge added later
SPI.transfer (WRITE); //CFR Address
delay(timer);
FUD_Toggle();
//CFR: 4 bytes
// single mode 0x00 00 00 7A
SPI.transfer (0x00);
delay(timer);
SPI.transfer (0x00);//CFR[23]=1 to enable auto clear accumulator
delay(timer);
SPI.transfer (0x00); //CFR[15]=1 sweep mode enabled
delay(timer);
SPI.transfer (0x7A); //0x7A with CFR[6]=1 or 0x3A with CFR[6]=0
delay(timer);
FUD_Toggle();
//Frequency Tuning Word
SPI.transfer (0x03); //FTW Address
delay(timer);
FUD_Toggle();
//FTW: 4 bytes
SPI.transfer (byte4);
delay(timer);
SPI.transfer (byte3);
delay(timer);
SPI.transfer (byte2);
delay(timer);
SPI.transfer (byte1);
delay(timer);
FUD_Toggle();
//---------To Read section----------
//Read
SPI.setDataMode(SPI_MODE2); // As read happens on the falling edge
SPI.transfer (READ); //Controller to read
delay(timer);
FUD_Toggle();
int bytes=Serial.available();
*buffer +=startPosition;
// parse buffer for your string/command
delay(timer);
Serial.readBytes(buffer, bytes);
delay(timer);
Serial.println(buffer);
delay(timer);
This code generate 60MHz
Here is the datasheet of the AD9858: http://www.analog.com/static/imported-files/data_sheets/AD9858.pdf
Thanks
