Hello everyone,
I'm trying to read distance with SR04 sensor during interrupt but the distance isn't right.
I tried to check the SR04 in separate function without the interrupt and in this function the SR04 works.
How can i read from SR04 during the interrupt to get the accurate distance?
#include <Servo.h>
#include<NewPing.h>
Servo myservo;
#include <AFMotor.h>
#define MAX_SPEED 100
#define SLOW_SPEED 110
#define MAX_DISTANCE 400
#define echoPinLeft 49 //LEFT ULTRASONIC
#define trigPinLeft 44 //LEFT ULTRASONIC
#define echoPinFRONT 47 //FRONT ULTRASONIC
#define trigPinFRONT 46 //FRONT ULTRASONIC
#define echoPinRIGHT 48 //RIGHT ULTRASONIC
#define trigPinRIGHT 45 //RIGHT ULTRASONIC
#define LED_FRONT_GREEN 52
#define LED_RIGHT_RED 53
#define LED_LEFT_YELLOW 51
AF_DCMotor Motor1(1,MOTOR12_64KHZ);
AF_DCMotor Motor2(2,MOTOR12_64KHZ);
AF_DCMotor Motor3(3,MOTOR12_64KHZ);
AF_DCMotor Motor4(4,MOTOR12_64KHZ);
NewPing sonarLEFT(trigPinLeft, echoPinLeft, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
NewPing sonarFront(trigPinFRONT, echoPinFRONT, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
NewPing sonarRIGHT(trigPinRIGHT, echoPinRIGHT, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
int frontReceiver = 15; //Read from the front receiver
int rightReceiver=16;
int leftReceiver=14;
int flag=0;
int distanceArik();
void front_signal();
void drive_slow_blind();
void drive_forward();
void stop_driving();
void drive_fast();
void drive_right();
void drive_left();
void drive_back();
void rotateRight90();
void lookLeftservo();
void lookRightServo();
void turnOnLeftLed();
int ReadDistanceFront();
int ReadDistanceLeft();
int ReadDistanceRight();
void avoid_obstacle();
void turnORightLed();
void turnOnLedFront();
void IR_signal();
void right_signal();
void left_signal();
pinMode(LED_FRONT_GREEN,OUTPUT); //LED FRONT
pinMode(LED_RIGHT_RED,OUTPUT); //LED RIGHT
pinMode(LED_LEFT_YELLOW,OUTPUT); //LED LEFT
pinMode(leftReceiver,INPUT);
pinMode(frontReceiver, INPUT);
pinMode(rightReceiver,INPUT);
pinMode(trigPinLeft,OUTPUT);
pinMode(echoPinLeft,INPUT);
pinMode(trigPinFRONT,OUTPUT);
pinMode(echoPinFRONT,INPUT);
pinMode(trigPinRIGHT,OUTPUT);
pinMode(echoPinRIGHT,INPUT);
attachInterrupt(digitalPinToInterrupt(21), front_signal, LOW); //FRONT
attachInterrupt(digitalPinToInterrupt(19), right_signal, LOW); //LEFT
attachInterrupt(digitalPinToInterrupt(20), left_signal, LOW); //RIGHT
void right_signal()
digitalWrite(LED_FRONT_GREEN,LOW);
digitalWrite(LED_RIGHT_RED,HIGH);
digitalWrite(LED_LEFT_YELLOW,LOW);
drive_right();
void left_signal()
digitalWrite(LED_RIGHT_RED,LOW);
digitalWrite(LED_LEFT_YELLOW,HIGH);
drive_left();
void front_signal()
digitalWrite(LED_FRONT_GREEN,HIGH);
drive_forward();
Motor1.setSpeed(70);
Motor2.setSpeed(70);
Motor3.setSpeed(70);
Motor4.setSpeed(70);
Motor1.run(FORWARD);
Motor2.run(FORWARD);
Motor3.run(FORWARD);
Motor4.run(FORWARD);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
int distanceR=ReadDistanceRight();
int distanceL=ReadDistanceLeft();
if (distanceR>distanceL)
drive_right();
while (ReadDistanceLeft()<70)
drive_forward();
drive_left();
drive_forward();
else if(distanceL>distanceR)
drive_left();
while (ReadDistanceRight()<70)
drive_forward();
drive_right();
drive_forward();
drive_fast();
return;
void drive_fast()
Motor1.setSpeed(MAX_SPEED);
Motor2.setSpeed(MAX_SPEED);
Motor3.setSpeed(MAX_SPEED);
Motor4.setSpeed(MAX_SPEED);
void drive_slow()
Motor1.setSpeed(SLOW_SPEED);
Motor2.setSpeed(SLOW_SPEED);
Motor3.setSpeed(SLOW_SPEED);
Motor4.setSpeed(SLOW_SPEED);
void stop_driving()
Motor1.setSpeed(0);
Motor1.run(RELEASE);
Motor2.run(RELEASE);
Motor2.setSpeed(0);
Motor3.run(RELEASE);
Motor3.setSpeed(0);
Motor4.run(RELEASE);
Motor4.setSpeed(0);
void drive_left()
drive_slow();
Motor1.run(BACKWARD);
Motor4.run(BACKWARD);
drive_slow();
stop_driving();
void rotateLeft90()
drive_slow();
Motor2.run(BACKWARD);
Motor3.run(BACKWARD);
stop_driving();
void drive_right()
drive_slow();
void drive_back()
drive_fast();
delay(30);
int sum=0;
int distance=0;
for (int i=0;i<10;i++)
distance=sonarLEFT.ping_cm();
sum=sum+distance;
distance=sum/10;
if (distance==0)
distance=5000;
return distance;
delay(30);
int distance=0;
int sum=0;
distance=sonarFront.ping_cm();
sum=sum+distance;
delay(20);
distance=sum/10;
if (distance==0)
distance=5000;
return distance;
delay(30);
int distance=0;
int sum=0;
distance=sonarRIGHT.ping_cm();
sum=sum+distance;
distance=sum/10;
if (distance==0)
distance=5000;
return distance;
Thank you very much!
