Reading serial input from terminal
I am trying to read serial input from my Ubuntu terminal but I am running into in issue. Can someone please help me understand why is it happening. I pretty new with Arduino and I am trying to learn more.
Below is the sketch
int LedPin = 13;
char val = 0;
  pinMode(LedPin, OUTPUT);
// Read Value from serial and set a led high or low
void loop () {
  if (Serial.available() > 0) {
    String s = Serial.readStringUntil('\n');
    s.trim();
    Serial.println(s);
    if (s.equals("low")) {
      Serial.println("low");
      digitalWrite(LedPin,LOW);
    if (s.equals("high")) {
      Serial.println("High");
      digitalWrite(LedPin,HIGH);
Below is the output of my terminal which I am using as a serial monitor.
raghav@raghav-Latitude-5590:~$ stty -F /dev/ttyACM0 raw 115200
raghav@raghav-Latitude-5590:~$ cat /dev/ttyACM0
low
low
low^M^Jlow^M^J
low^M^Jlow^M^J^M
low^M^Jlow^M^J^M^
low^M^Jlow^M^J^M^high
low^M^Jlow^M^J^M^
low^M^Jlow^M^J^M^
low^M^Jlow^M^J^M^
low^M^Jlow^M^J^M^
^C
I cannot pass any other input after this.
Following is the command to send input to the serial. echo low > /dev/ttyACM0
It works absolutely fine when I run everything from the serial monitor.
Thanks, Any help is appreciated.
The ^M is a Carriage Return and the ^J is a Newline which you are sending from the terminal
But then why is it printing out the remaining text when I entered the command only once? and why can I not enter another command after that?
I don't know, but then I am not a user of Strings so have little experience of them
What happens if you either don't send the extra characters or detect them in the sketch and ignore them ?
Better still, use C style strings instead of Strings, which is the usual advice here
