Receive and send raw ir
Hi, I'm a begginner, this is the second thing I try to make with arduino and there are several things I dont understand. I would like to use the Ir receiver sensor to get ir codes from remotes and then send back the last captured code using an ir led when a button is pushed.
I checked the ir trasmitting led with a camera and it works if i use the exemple code that uses irsend.sendNEC(results.value, 32); but i would like to send the signal in raw format, i tried using irsend.sendRaw(results.rawbuf, results.rawlen, 38); but the ir transmitting led doesn't light up. I think I'm missing something important.
Using this code something is captured but i dont understand how to manage it and send it back:
#include <IRremote.h>
#include <LiquidCrystal.h>
#define LEDr 4
#define button 6
#define ironoff 5
int RECV_PIN = 2;
int buttonState = 0;
IRsend irsend;
IRrecv irrecv(RECV_PIN);
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
decode_results results;
  lcd.begin(16,2);
  irrecv.enableIRIn();
  pinMode(button, INPUT);
  pinMode(3, OUTPUT);
  pinMode(LEDr, OUTPUT);
  pinMode(ironoff, OUTPUT);
  digitalWrite(ironoff, HIGH);
  buttonState = digitalRead(button);
  if ((irrecv.decode(&results)) && (buttonState == LOW) {
    lcd.clear();
    digitalWrite(LEDr, HIGH);
    Serial.println(results.value, HEX);
    //Serial.println(uint16_t rawData);
    lcd.setCursor(2, 0);
    lcd.print("Ir Code:");
    lcd.setCursor(0, 1);
    lcd.print(results.value, HEX);
    delay(90);
    irrecv.resume();
  } else {digitalWrite(LEDr, LOW);
  if (buttonState == HIGH) {
    digitalWrite(ironoff, LOW);
    //for (int i = 0; i < 3; i++) {
    delay(90);
I clearly don't understand how this works and would really appreciate if someone could help me out. Thank you and sorry for poor English.
You should save the raw buffer and length before resume() clears the results.
Oh, thanks a lot! Could I also ask you a hint on how to do so?
Look at the sample programs coming with the library.
Thank you for your answers, arduino code looks quite difficult and confusing from a beginner prospective. I used the sample code from the library and it works! Now I can send ir to some devices (i have tried some tv's), but for some reasons it doesn't work with ac, something is received and something is sent but the ac is unresponsive.
Thank you again for your help :grinning:
#include "PinDefinitionsAndMore.h"
// Define macros for input and output pin etc.
#define LEDr 4
 * Specify which protocol(s) should be used for decoding.
 * If no protocol is defined, all protocols (except Bang&Olufsen) are active.
 * This must be done before the #include <IRremote.hpp>
//#define DECODE_DENON        // Includes Sharp
//#define DECODE_JVC
//#define DECODE_KASEIKYO
//#define DECODE_PANASONIC    // alias for DECODE_KASEIKYO
//#define DECODE_LG
#define DECODE_NEC          // Includes Apple and Onkyo
//#define DECODE_SAMSUNG
//#define DECODE_SONY
//#define DECODE_RC5
//#define DECODE_RC6
//#define DECODE_BOSEWAVE
//#define DECODE_LEGO_PF
//#define DECODE_MAGIQUEST
//#define DECODE_WHYNTER
//#define DECODE_FAST
#if !defined(RAW_BUFFER_LENGTH)
#  if RAMEND <= 0x4FF || RAMSIZE < 0x4FF
#define RAW_BUFFER_LENGTH  120
#  elif RAMEND <= 0xAFF || RAMSIZE < 0xAFF // 0xAFF for LEONARDO
#define RAW_BUFFER_LENGTH  400 // 600 is too much here, because we have additional uint8_t rawCode[RAW_BUFFER_LENGTH];
#  else
#define RAW_BUFFER_LENGTH  750
#  endif
#endif
//#define EXCLUDE_UNIVERSAL_PROTOCOLS // Saves up to 1000 bytes program memory.
//#define EXCLUDE_EXOTIC_PROTOCOLS // saves around 650 bytes program memory if all other protocols are active
//#define NO_LED_FEEDBACK_CODE      // saves 92 bytes program memory
//#define RECORD_GAP_MICROS 12000   // Default is 5000. Activate it for some LG air conditioner protocols
//#define SEND_PWM_BY_TIMER         // Disable carrier PWM generation in software and use (restricted) hardware PWM.
//#define USE_NO_SEND_PWM           // Use no carrier PWM, just simulate an active low receiver signal. Overrides SEND_PWM_BY_TIMER definition
// MARK_EXCESS_MICROS is subtracted from all marks and added to all spaces before decoding,
// to compensate for the signal forming of different IR receiver modules. See also IRremote.hpp line 142.
#define MARK_EXCESS_MICROS    20    // Adapt it to your IR receiver module. 20 is recommended for the cheap VS1838 modules.
//#define DEBUG // Activate this for lots of lovely debug output from the decoders.
int SEND_BUTTON_PIN = 6;
int DELAY_BETWEEN_REPEAT = 50;
// Storage for the recorded code
struct storedIRDataStruct {
  IRData receivedIRData;
    // extensions for sendRaw
  uint8_t rawCode[RAW_BUFFER_LENGTH]; // The durations if raw
  uint8_t rawCodeLength; // The length of the code
} sStoredIRData;
bool sSendButtonWasActive;
void storeCode();
void sendCode(storedIRDataStruct *aIRDataToSend);
  pinMode(SEND_BUTTON_PIN, INPUT);
  pinMode(5, OUTPUT);
  //analogWrite(A0, 128);
  lcd.begin(16,2);
#if defined(__AVR_ATmega32U4__) || defined(SERIAL_PORT_USBVIRTUAL) || defined(SERIAL_USB) /*stm32duino*/|| defined(USBCON) /*STM32_stm32*/|| defined(SERIALUSB_PID) || defined(ARDUINO_attiny3217)
  delay(4000); // To be able to connect Serial monitor after reset or power up and before first print out. Do not wait for an attached Serial Monitor!
#endif
    // Just to know which program is running on my Arduino
  Serial.println(F("START " __FILE__ " from " __DATE__ "\r\nUsing library version " VERSION_IRREMOTE));
    // Start the receiver and if not 3. parameter specified, take LED_BUILTIN pin from the internal boards definition as default feedback LED
  IrReceiver.begin(IR_RECEIVE_PIN, ENABLE_LED_FEEDBACK);
  Serial.print(F("Ready to receive IR signals of protocols: "));
  printActiveIRProtocols(&Serial);
    Serial.println(F("at pin " STR(IR_RECEIVE_PIN)));
  IrSender.begin(); // Start with IR_SEND_PIN as send pin and enable feedback LED at default feedback LED pin
  Serial.print(F("Ready to send IR signals at pin " STR(IR_SEND_PIN) " on press of button at pin "));
  Serial.println(SEND_BUTTON_PIN);
    // If button pressed, send the code.
    bool tSendButtonIsActive = (digitalRead(SEND_BUTTON_PIN) == LOW); // Button pin is active LOW
     * Check for current button state
    if (tSendButtonIsActive) {
        if (!sSendButtonWasActive) {
          Serial.println(F("Stop receiving"));
          IrReceiver.stop();
         * Button pressed -> send stored data
        Serial.print(F("Button pressed, now sending "));
        if (sSendButtonWasActive == tSendButtonIsActive) {
            Serial.print(F("repeat "));
            sStoredIRData.receivedIRData.flags = IRDATA_FLAGS_IS_REPEAT;
            sStoredIRData.receivedIRData.flags = IRDATA_FLAGS_EMPTY;
        Serial.flush(); // To avoid disturbing the software PWM generation by serial output interrupts
        sendCode(&sStoredIRData);
        delay(DELAY_BETWEEN_REPEAT); // Wait a bit between retransmissions
    } else if (sSendButtonWasActive) {
         * Button is just released -> activate receiving
        // Restart receiver
        Serial.println(F("Button released -> start receiving"));
        IrReceiver.start();
    } else if (IrReceiver.decode()) {
         * Button is not pressed and data available -> store received data and resume
        storeCode();
        delay(400);
        lcd.setCursor(0, 0);
        IrReceiver.printIRResultRawFormatted(&lcd, true);
        IrReceiver.resume(); // resume receiver
    sSendButtonWasActive = tSendButtonIsActive;
    delay(100);
// Stores the code for later playback in sStoredIRData
// Most of this code is just logging
void storeCode() {
    if (IrReceiver.decodedIRData.rawDataPtr->rawlen < 4) {
        Serial.print(F("Ignore data with rawlen="));
        Serial.println(IrReceiver.decodedIRData.rawDataPtr->rawlen);
        return;
    if (IrReceiver.decodedIRData.flags & IRDATA_FLAGS_IS_REPEAT) {
        Serial.println(F("Ignore repeat"));
        return;
    if (IrReceiver.decodedIRData.flags & IRDATA_FLAGS_IS_AUTO_REPEAT) {
        Serial.println(F("Ignore autorepeat"));
        return;
    if (IrReceiver.decodedIRData.flags & IRDATA_FLAGS_PARITY_FAILED) {
        Serial.println(F("Ignore parity error"));
        return;
     * Copy decoded data
    sStoredIRData.receivedIRData = IrReceiver.decodedIRData;
    if (sStoredIRData.receivedIRData.protocol == UNKNOWN) {
        Serial.print(F("Received unknown code and store "));
        Serial.print(IrReceiver.decodedIRData.rawDataPtr->rawlen - 1);
        Serial.println(F(" timing entries as raw "));
        IrReceiver.printIRResultRawFormatted(&Serial, true); // Output the results in RAW format
        sStoredIRData.rawCodeLength = IrReceiver.decodedIRData.rawDataPtr->rawlen - 1;
         * Store the current raw data in a dedicated array for later usage
        IrReceiver.compensateAndStoreIRResultInArray(sStoredIRData.rawCode);
        IrReceiver.printIRResultShort(&Serial);
        IrReceiver.printIRSendUsage(&Serial);
        sStoredIRData.receivedIRData.flags = 0; // clear flags -esp. repeat- for later sending
void sendCode(storedIRDataStruct *aIRDataToSend) {
    if (aIRDataToSend->receivedIRData.protocol == UNKNOWN /* i.e. raw */) {
        // Assume 38 KHz
        IrSender.sendRaw(aIRDataToSend->rawCode, aIRDataToSend->rawCodeLength, 38);
        Serial.print(F("raw "));
        Serial.print(aIRDataToSend->rawCodeLength);
        Serial.println(F(" marks or spaces"));
         * Use the write function, which does the switch for different protocols
        IrSender.write(&aIRDataToSend->receivedIRData);
        printIRResultShort(&Serial, &aIRDataToSend->receivedIRData, false);
