Hi everyone,
My goal is to properly receive, store and print a simple MIDI messages.
Put simply:
- Hit one key of midi-keyboard
- receive all midi messages (status and data bytes)
- store the values in a variable
- display the values on the serial monitor (each byte in decimal data type).
My midi-keyboard is connected to the Arduino Uno via DIN midi cable (receive only). I used the exact schematics provided by Amanda Ghassaei (retrieved from instructables -> Step 10). Receiving messages seem to work as the internal LED flashes whenever the note "Middle C" is hit.
My problem:
- The received bytes are not displayed properly using the following code 1 (see picture attached)
- If I use code 2, four bytes are received and displayed in correct (decimal) format but it seems to be the wrong bit-sequences each time.
I would be grateful for a hint about altering the code or thinking in a different direction as my programming skills are very limited ![]()
It seems to me that receiving data on a serial port at 31250baud does not go along with using serial monitor which I cannot configure to use the same baud-rate.
Also, if I overlooked a thread that solved my issue --> My apologies, please drop me a link.
Thank you very much for your tips and time to stop by and studying my problem.
KR, hobbes02
