Hi, everyone!
My first post here! ![]()
I'm trying to make a sketch to read midi messages from my MIDI keyboard. So I made a circuit and tested it with code below. Everything works fine, but here is an issue - The Serial Monitor displays "?" symbols, the Arduino transmits something all the time, TX led is on.
Could you explain me, why the Arduino is sending messages over serial while midi keyboard is connected to RX? And how get rid of it. Thanks!
#include <MIDI.h> // Add Midi Library
#define LED 13 // Arduino Board LED is on Pin 13
//Create an instance of the library with default name, serial port and settings
MIDI_CREATE_DEFAULT_INSTANCE();void setup() {
pinMode (LED, OUTPUT); // Set Arduino board pin 13 to output
MIDI.begin(MIDI_CHANNEL_OMNI); // Initialize the Midi Library.
// OMNI sets it to listen to all channels.. MIDI.begin(2) would set it
// to respond to notes on channel 2 only.
MIDI.setHandleNoteOn(MyHandleNoteOn); // This is important!! This command
// tells the Midi Library which function you want to call when a NOTE ON command
// is received. In this case it's "MyHandleNoteOn".
MIDI.setHandleNoteOff(MyHandleNoteOff); // This command tells the Midi Library
// to call "MyHandleNoteOff" when a NOTE OFF command is received.
}void loop() { // Main loop
MIDI.read(); // Continuously check if Midi data has been received.
}// MyHandleNoteON is the function that will be called by the Midi Library
// when a MIDI NOTE ON message is received.
// It will be passed bytes for Channel, Pitch, and Velocity
void MyHandleNoteOn(byte channel, byte pitch, byte velocity) {
digitalWrite(LED,HIGH); //Turn LED on
}// MyHandleNoteOFF is the function that will be called by the Midi Library
// when a MIDI NOTE OFF message is received.
// * A NOTE ON message with Velocity = 0 will be treated as a NOTE OFF message *
void MyHandleNoteOff(byte channel, byte pitch, byte velocity) {
digitalWrite(LED,LOW); //Turn LED off
