Receiving BNO08x data without data gaps
I am selecting data from BNO08x via the library
The code is as follows
#include <Adafruit_BNO08x.h>
#define  SERIAL_PORT_SPEED  230400
#define  I2C_SPEED_SET  (400000) // kHz
#define BNO08X_RESET -1
#define sq(x) ((x)*(x))
const unsigned int BNO_Period = 5;
unsigned long BNO_Timestamp = 0;
long current_timestamp = millis();
long report_interval_euler = 1000;
// long report_interval_euler = 2000;
struct euler_t {
  float yaw;
  float pitch;
  float roll;
} ypr_float;
Adafruit_BNO08x  bno08x(BNO08X_RESET);
sh2_SensorValue_t sensorValue;
void quaternionToEuler(float qr, float qi, float qj, float qk, euler_t* ypr, bool degrees);
void quaternionToEulerRV(sh2_RotationVectorWAcc_t* rotational_vector, euler_t* ypr, bool degrees);
void setReports(void);
void setup(void) {
  Serial.begin(SERIAL_PORT_SPEED); // PA9, PA10
    Serial.println("Adafruit BNO08x test!");
    Wire.begin();
    // Try to initialize!
    if (!bno08x.begin_I2C()) {
      Serial.println("Failed to find BNO08x chip");
      while (1) {
        delay(120);
        NVIC_SystemReset();
    Wire.setClock(I2C_SPEED_SET); //Set clock speed to 400kHz
    Serial.println("BNO08x Found!");
    Serial.println("Reading events");
    delay(100);
    // default orient
    // Y - N, X - E, Z  - U
    // sh2_Quaternion_t sh_orientation = { 0, 0, sqrt(2) / 2, 0}; // Qx, Qy, Qz, Qw
    // Y - S, X - E, Z  - D
    sh2_Quaternion_t sh_orientation = { -1, 0, 0, 0}; // Qx, Qy, Qz, Qw
  setReports();
} // SETUP
    if (bno08x.wasReset()) {
      Serial.println("sensor was reset ");
    if (millis() - BNO_Timestamp >= BNO_Period) {
            bno08x.getSensorEvent(&sensorValue);
            telemetry_bno08x_min();
            BNO_Timestamp = millis();
      switch (sensorValue.sensorId) {
        // https://forums.adafruit.com/viewtopic.php?p=935347#p935347
        case SH2_ROTATION_VECTOR:
         quaternionToEulerRV(&sensorValue.un.rotationVector, &ypr_float, true);
  } // END MODE BNO08X
} //LOOP
void quaternionToEuler(float qr, float qi, float qj, float qk, euler_t* ypr, bool degrees = false) {
    float sqr = sq(qr);
    float sqi = sq(qi);
    float sqj = sq(qj);
    float sqk = sq(qk);
    ypr->yaw = atan2(2.0 * (qi * qj + qk * qr), (sqi - sqj - sqk + sqr));
    ypr->pitch = asin(-2.0 * (qi * qk - qj * qr) / (sqi + sqj + sqk + sqr));
    ypr->roll = atan2(2.0 * (qj * qk + qi * qr), (-sqi - sqj + sqk + sqr));
    if (degrees) {
      ypr->yaw *= RAD_TO_DEG;
      ypr->pitch *= -RAD_TO_DEG;
      ypr->roll *= RAD_TO_DEG;
void quaternionToEulerRV(sh2_RotationVectorWAcc_t* rotational_vector, euler_t* ypr, bool degrees = false) {
    quaternionToEuler(rotational_vector->real, rotational_vector->i, rotational_vector->j, rotational_vector->k, ypr, degrees);
void setReports(void) {
  Serial.println("Setting desired reports");
  if (!bno08x.enableReport(SH2_ROTATION_VECTOR, report_interval_euler)) {
    Serial.println("Could not enable rotation vector");
void telemetry_bno08x_min()
int textLength = 5 * 30;
char text[textLength];
char time[10];
char time_elapse[10];
char ex[10];
char ey[10];
char ez[10];
long timestamp = millis(); // Get the current time
long elapsed_time = timestamp - current_timestamp; // Calculate the time difference
dtostrf(timestamp, 10, 0, time);
dtostrf(elapsed_time, 10, 0, time_elapse);
dtostrf(ypr_float.roll, 10, 2, ex);
dtostrf(ypr_float.pitch, 10, 2, ey);
dtostrf(ypr_float.yaw, 10, 2, ez);
snprintf(text, textLength, "%10s,%4s,%8s,%8s,%8s", time, time_elapse, ex, ey, ez);
Serial.println(text);
// Updating the current time
current_timestamp = timestamp;
This code collects data from the sensor and transmits it to the serial port:
timestamp,elapsed,eul_x,eul_y,eul_z
      1227,      1227,      0.00,      0.00,      0.00
      1238,        11,      0.00,      0.00,      0.00
      1244,         6,      0.00,      0.00,      0.00
      1315,         9,    -33.17,    -14.75,    -46.33
      1323,         8,    -34.56,    -14.56,    -46.40
      1331,         8,    -35.82,    -14.35,    -46.46
      1338,         7,    -36.98,    -14.18,    -46.50
      1347,         9,    -38.07,    -14.01,    -46.56
      1355,         8,    -39.46,    -13.64,    -46.79
      1363,         8,    -40.43,    -13.39,    -46.89
      1371,         8,    -41.28,    -13.14,    -47.00
      1379,         8,    -42.27,    -12.81,    -47.12
      1387,         8,    -42.99,    -12.54,    -47.25
      1495,         9,    -47.76,    -10.88,    -46.61
      1503,         8,    -47.16,    -10.69,    -46.74
      1511,         8,    -46.55,    -10.56,    -46.79
      1519,         8,    -46.11,    -10.52,    -46.86
      1527,         8,    -44.69,    -10.41,    -46.88
      1541,        14,    -43.70,    -10.36,    -46.76
      1550,         9,    -42.47,    -10.25,    -46.57
      1566,         7,    -36.65,     -9.58,    -45.92
      1575,         9,    -34.20,     -9.29,    -45.70
      1582,         7,    -30.86,     -8.95,    -45.49
      1591,         9,    -29.30,     -8.75,    -45.46
      1600,         9,    -26.34,     -8.29,    -45.47
      1608,         8,    -23.87,     -7.88,    -45.43
      1616,         8,    -21.74,     -7.54,    -45.41
      1624,         8,    -19.56,     -7.19,    -45.42
      1632,         8,    -17.86,     -5.68,    -45.44
      1640,         8,    -15.87,     -5.12,    -45.47
      1648,         8,    -13.50,     -4.51,    -45.54
      1656,         8,    -11.75,     -4.14,    -45.60
The sampling time is 8-10 ms, which is about 100 Hz, but there are some strange things with sampling data from the sensor.
But for some reason, when you rotate the sensor slowly in roll or pitch angles, the data in the serial port goes every 8 ms, every 1 degree.
When you rotate the sensor quickly in roll or pitch angles, the angles in the serial port are output with gaps from 2 to 10 degrees.
What am I doing wrong?
I know about the INT pin and understand how to use it, but will this solve my problem and is there another way to deal with data gaps from the sensor - collecting data in a buffer, organizing a ring buffer, or something else?
I would be grateful for your help.
